  4. Test Coronavirus Statistics for ioBroker
    6.3k
adapter installationadapterentwicklungtesten
1.2k Beiträge 120 Kommentatoren 498.6k Aufrufe 94 Beobachtet
  • harrymH Offline
    harrymH Offline
    harrym
    #257
    klick auf den text ;)
    ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
    • DutchmanD Dutchman
      Aktuelle Test Version 0.6.9
      Veröffentlichungsdatum 22-03-2021
      Github Link https://github.com/iobroker-community-adapters/ioBroker.coronavirus-statistics/blob/master/README.md
      NPM npm i ioBroker.coronavirus-statistics@latest
      Adapter to show Global Corona Virus information and current reports
      Coronavirus Live Statistics adapter for ioBroker
      There is no configuration required, after installation it will :
      • Receive global information world-wide and write it to "global_totals"
      • Create a folder for each country with all relevant information regarding COVID-19
      • Update the information every 15 minutes
      The following information is available :
      Datapoint Details
      active Amount of current infected people
      cases Amount of totally known cases
      casesPerOneMillion Amount of totally known cases per million citizen
      critical Amount of critical situation (Hospitalized)
      deaths Amount of current registered deaths
      deathsPerOneMillion Amount of current registered deaths per million citizen
      recovered Amount of totally known recovered cases
      todayCases New Cases by Today
      todayDeaths Amount of totally known people died today
      test Total number of covid-19 tests taken globally
      tests per one million counties Total number of covid-19 tests taken globally per one million
      Please be aware this adapter uses as much as possible up-to-date information but there can be an delay of several hours depending on the country's report.
      German Federal States : https://npgeo-corona-npgeo-de.hub.arcgis.com/ s
      Generic Source : https://coronavirus-19-api.herokuapp.com
      Advanced settings
      Option Description
      All Countries Get data for all countries World-Wide (Default: false)
      Continents Group total amounts by continent in seperate state (Default: false)
      Delete unused States Delete data when countries are deselected (Default: false)
      German counties Get counties data for Germany (Selected only, Default false)
      German federal states Get federal state data for Germany (Selected only, Default false)
      Get all German federal states Get federal state data for Germany (Default false)
      Get all German counties Get all counties data for Germany (Default false)
      For Germany only
      It's possible to get data for federal states (Bundesländer) and counties (Landeskreise).
      You can choose to recieve all data or just select specific regions in advanced settings.
      Please note : After activation the the adapter must run 1 time to get all federal states and counties before table loads !
      Add missing countries
      It may happen that countries are not recognized correctly because the API delivers some country names not ISO conform. In such a case you will get a warning message in the log, which looks like this
      coronavirus-statistics.0	2020-03-21 09:05:31.328	warn	(22937) Timor-Leste not found in lib! Must be added to the country name translator.
      Using the datapoint coronavirus-statistics.0.countryTranslator you can assign a country yourself. Look for the name of the corresponding country here:
      List with country names
      With the selected country name you have to create a JSON string and enter it in the datapoint coronavirus-statistics.0.countryTranslator.
      The JSON string then looks like this, for example:
      	"Cabo_Verde": "Cape Verde",
      	"Timor-Leste": "East Timor"
      As first value the name from the warning message must be taken from the log. The name of the country from the List with country names is then assigned to this.
      Changelog
      sigi234S Online
      sigi234S Online
      #258
      @Dutchman
      Kleiner Fehler:
      • sigi234S sigi234
        @Dutchman
        Kleiner Fehler:
        DutchmanD Offline
        DutchmanD Offline
        Dutchman
        #259
        @sigi234 sagte in Test Coronavirus Statistics for ioBroker:
        @Dutchman
        Kleiner Fehler:
        Kommt weil der nahmen zulange ist kan ich nicht einfach lösen ohne die Tabelle komplett anders auf zu bauen für die Par States belasse ich es dabei 🤣
        • jackblacksonJ Offline
          jackblackson
          schrieb am zuletzt editiert von jackblackson
          #260
          Kann das jemand von euch nachvollziehen: am Beispiel der Daten USA: 30dfdae3-1f4d-47ba-8910-d3d76c658b4e-grafik.png
          Daten der Fälle sind im Länder-Ordner sowie im Top 5 gleich. Hab mir die Top 5 als Tabelle aufgebaut - Zahl passt auch. Aber im Widget hab ich eine andere Zahl..
          Soll das so? Zahl ist von gestern Nachmittag..
          Version 0.4.0
          WebrangerW crunchipC 2 Antworten Letzte Antwort
          • jackblacksonJ jackblackson
            Version 0.4.0
            WebrangerW Offline
            WebrangerW Offline
            Webranger
            #261
            @jackblackson sagte in Test Coronavirus Statistics for ioBroker:
            Warum steht bei Dir schon Gesund? Bei mir immer noch Gesung!
            Wie kann ich das evtl selber ändern?
            Gruss
            Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
            jackblacksonJ 1 Antwort Letzte Antwort
            • WebrangerW Webranger
              Gruss
              jackblackson
              #262
              @Webranger Welche Version des Adapters hast du? Wurde glaub mit 0.2.5 oder so korrigiert.
              • WebrangerW Offline
                WebrangerW Offline
                Webranger
                #263
                ich hab schon 0.4.2 am laufen aber das Gesung ändert sich nicht
                  Version 0.4.0
                  crunchipC Abwesend
                  crunchipC Abwesend
                  #264
                  @jackblackson Browser eventuell aktualisieren, hattest wahrscheinlich kurz vorm Zählerwechsel noch das Fenster im Edit Modus offen, da wird nicht aktualisiert
                    crunchipC Abwesend
                    crunchipC Abwesend
                    #265
                    @Webranger eventuell nen upload vis Adapter anstossen und Browser cache löschen
                    • KLVNK Offline
                      KLVNK Offline
                      KLVN
                      #266
                      Ihr beiden habt noch eine alte Version bzw. veralteten Cache. Ich habe gestern die Bezeichnungen förmlicher und korrekter umgeschrieben, sodass "Gesund" (oder auch "Gesung" ;) ) jetzt "wieder gesund" heißt. Diese Änderung war schon in V4.0.0 enthalten.
                        WebrangerW Offline
                        Webranger
                        #267
                        Habe jetzt gerade schon die Instanz gelöscht und chache gelöscht aber keine änderung.
                        Muss ich den ganzen Adapter löschen?
                        Sind dann meine daten im history weg?
                          jackblackson
                          #268
                          @crunchip HM...ist auch im Vis so, nicht nur im Edit Modus. Hab den Upload gemacht, nun steht "Wieder Gesund" da - aber die selben Zahlen..af1ff010-6756-4712-8e1e-d98c1ddf5421-grafik.png
                          Kann es bei der Zahl wirklich am Cache liegen?
                            WebrangerW Offline
                            Webranger
                            #269
                            cache geleert und instanz neu installiert aber trotzdem auch im edit noch Gesung
                            • crunchipC Abwesend
                              crunchipC Abwesend
                              #270
                              da schein aber was mit dem widget nicht zu stimmen, ihr habt beide falschen Zahlen
                              hab grad testweise das widget mit usa erstellt, bei mir sind die Zahlen sogar noch niedriger als bei euch
                                WebrangerW Offline
                                Webranger
                                #271
                                Jetzt wo du es sagst.
                                Unter objekte andere Zahlen wie im Widget !?
                                  MartyBr
                                  #272
                                  @crunchip Stimmt. Ich habe die neu den DPs zugeordnet. Das war bestimmt ein Flüchtigkeitsfehler. Kein Wunder bei dem Tempo, dass hier vorgelegt wird 👍
                                  Martin
                                  Homematic und Homematic IP
                                  • M MartyBr
                                    jackblackson
                                    #273
                                    @MartyBr Ihr macht hier eine super Arbeit, wollte ich mal erwähnen!! Es ist beeindruckend, was hier in so kurzer Zeit entsteht. Da kann sowas natürlich mal passieren :)
                                      MartyBr
                                      #274
                                      @jackblackson Ich bin nur "Nutzniesser". Die Arbeit wird hier von @crunchip und @sigi234 @Dutchman und vielen weiteren gemacht
                                      Großes Lob 👍
                                      Martin
                                        WebrangerW Offline
                                        Webranger
                                        #275
                                        Also die Zahlen aus Objekte und dem widget sind komplett daneben.
                                        Hab jetzt instanz und adapter schon gelöscht. Ausserdem cache gelöscht.
                                        Weis nicht was ich sonst noch machen könnte.
                                        KLVNK 1 Antwort Letzte Antwort
                                          KLVNK Offline
                                          KLVNK Offline
                                          KLVN
                                          #276
                                          @Webranger hast du Vis schon mal neugestartet?
                                          WebrangerW 1 Antwort Letzte Antwort
