  4. Test Coronavirus Statistics for ioBroker
    6.3k
adapter installationadapterentwicklungtesten
1.2k Beiträge 120 Kommentatoren 498.6k Aufrufe 94 Beobachtet
  • Uli977U Uli977
    @sigi234
    Das passt auch noch nicht von der Zuordnung....
    1094 sind die infizierten heute
    130 sind Todesfälle heute.
    sigi234S Online
    sigi234S Online
    #255
    @Uli977 sagte in Test Coronavirus Statistics for ioBroker:
    @sigi234
    Korrigiert, Danke
    • MyzerATM Offline
      MyzerATM Offline
      MyzerAT
      #256
      bei mir sind die regler ausgegraut, kann sie nicht bedienen?
      lg Rudi
      Node 22.23.0
      Nodejs 22.23.0
      npm 10.9.8
      js-controller 7.2.2
      • harrymH Offline
        harrymH Offline
        harrym
        #257
        klick auf den text ;)
        ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
        • DutchmanD Dutchman
          Aktuelle Test Version 0.6.9
          Veröffentlichungsdatum 22-03-2021
          Github Link https://github.com/iobroker-community-adapters/ioBroker.coronavirus-statistics/blob/master/README.md
          NPM npm i ioBroker.coronavirus-statistics@latest
          Adapter to show Global Corona Virus information and current reports
          Coronavirus Live Statistics adapter for ioBroker
          There is no configuration required, after installation it will :
          • Receive global information world-wide and write it to "global_totals"
          • Create a folder for each country with all relevant information regarding COVID-19
          • Update the information every 15 minutes
          The following information is available :
          Datapoint Details
          active Amount of current infected people
          cases Amount of totally known cases
          casesPerOneMillion Amount of totally known cases per million citizen
          critical Amount of critical situation (Hospitalized)
          deaths Amount of current registered deaths
          deathsPerOneMillion Amount of current registered deaths per million citizen
          recovered Amount of totally known recovered cases
          todayCases New Cases by Today
          todayDeaths Amount of totally known people died today
          test Total number of covid-19 tests taken globally
          tests per one million counties Total number of covid-19 tests taken globally per one million
          Please be aware this adapter uses as much as possible up-to-date information but there can be an delay of several hours depending on the country's report.
          German Federal States : https://npgeo-corona-npgeo-de.hub.arcgis.com/ s
          Generic Source : https://coronavirus-19-api.herokuapp.com
          Advanced settings
          Option Description
          All Countries Get data for all countries World-Wide (Default: false)
          Continents Group total amounts by continent in seperate state (Default: false)
          Delete unused States Delete data when countries are deselected (Default: false)
          German counties Get counties data for Germany (Selected only, Default false)
          German federal states Get federal state data for Germany (Selected only, Default false)
          Get all German federal states Get federal state data for Germany (Default false)
          Get all German counties Get all counties data for Germany (Default false)
          For Germany only
          It's possible to get data for federal states (Bundesländer) and counties (Landeskreise).
          You can choose to recieve all data or just select specific regions in advanced settings.
          Please note : After activation the the adapter must run 1 time to get all federal states and counties before table loads !
          Add missing countries
          It may happen that countries are not recognized correctly because the API delivers some country names not ISO conform. In such a case you will get a warning message in the log, which looks like this
          coronavirus-statistics.0	2020-03-21 09:05:31.328	warn	(22937) Timor-Leste not found in lib! Must be added to the country name translator.
          Using the datapoint coronavirus-statistics.0.countryTranslator you can assign a country yourself. Look for the name of the corresponding country here:
          List with country names
          With the selected country name you have to create a JSON string and enter it in the datapoint coronavirus-statistics.0.countryTranslator.
          The JSON string then looks like this, for example:
          	"Cabo_Verde": "Cape Verde",
          	"Timor-Leste": "East Timor"
          As first value the name from the warning message must be taken from the log. The name of the country from the List with country names is then assigned to this.
          Changelog
          sigi234S Online
          sigi234S Online
          #258
          @Dutchman
          Kleiner Fehler:
          • sigi234S sigi234
            @Dutchman
            Kleiner Fehler:
            DutchmanD Offline
            DutchmanD Offline
            Dutchman
            #259
            @sigi234 sagte in Test Coronavirus Statistics for ioBroker:
            @Dutchman
            Kleiner Fehler:
            Kommt weil der nahmen zulange ist kan ich nicht einfach lösen ohne die Tabelle komplett anders auf zu bauen für die Par States belasse ich es dabei 🤣
            • jackblacksonJ Offline
              jackblackson
              schrieb am zuletzt editiert von jackblackson
              #260
              Kann das jemand von euch nachvollziehen: am Beispiel der Daten USA: 30dfdae3-1f4d-47ba-8910-d3d76c658b4e-grafik.png
              Daten der Fälle sind im Länder-Ordner sowie im Top 5 gleich. Hab mir die Top 5 als Tabelle aufgebaut - Zahl passt auch. Aber im Widget hab ich eine andere Zahl..
              Soll das so? Zahl ist von gestern Nachmittag..
              Version 0.4.0
              WebrangerW crunchipC 2 Antworten Letzte Antwort
              • jackblacksonJ jackblackson
                Version 0.4.0
                WebrangerW Offline
                WebrangerW Offline
                Webranger
                #261
                @jackblackson sagte in Test Coronavirus Statistics for ioBroker:
                Warum steht bei Dir schon Gesund? Bei mir immer noch Gesung!
                Wie kann ich das evtl selber ändern?
                Gruss
                Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
                jackblacksonJ 1 Antwort Letzte Antwort
                • WebrangerW Webranger
                  Gruss
                  jackblackson
                  #262
                  @Webranger Welche Version des Adapters hast du? Wurde glaub mit 0.2.5 oder so korrigiert.
                  • WebrangerW Offline
                    WebrangerW Offline
                    Webranger
                    #263
                    ich hab schon 0.4.2 am laufen aber das Gesung ändert sich nicht
                      Version 0.4.0
                      crunchipC Abwesend
                      crunchipC Abwesend
                      #264
                      @jackblackson Browser eventuell aktualisieren, hattest wahrscheinlich kurz vorm Zählerwechsel noch das Fenster im Edit Modus offen, da wird nicht aktualisiert
                        crunchipC Abwesend
                        crunchipC Abwesend
                        #265
                        @Webranger eventuell nen upload vis Adapter anstossen und Browser cache löschen
                        • KLVNK Offline
                          KLVNK Offline
                          KLVN
                          #266
                          Ihr beiden habt noch eine alte Version bzw. veralteten Cache. Ich habe gestern die Bezeichnungen förmlicher und korrekter umgeschrieben, sodass "Gesund" (oder auch "Gesung" ;) ) jetzt "wieder gesund" heißt. Diese Änderung war schon in V4.0.0 enthalten.
                            WebrangerW Offline
                            Webranger
                            #267
                            Habe jetzt gerade schon die Instanz gelöscht und chache gelöscht aber keine änderung.
                            Muss ich den ganzen Adapter löschen?
                            Sind dann meine daten im history weg?
                              jackblackson
                              #268
                              @crunchip HM...ist auch im Vis so, nicht nur im Edit Modus. Hab den Upload gemacht, nun steht "Wieder Gesund" da - aber die selben Zahlen..af1ff010-6756-4712-8e1e-d98c1ddf5421-grafik.png
                              Kann es bei der Zahl wirklich am Cache liegen?
                                WebrangerW Offline
                                Webranger
                                #269
                                cache geleert und instanz neu installiert aber trotzdem auch im edit noch Gesung
                                • crunchipC Abwesend
                                  crunchipC Abwesend
                                  #270
                                  da schein aber was mit dem widget nicht zu stimmen, ihr habt beide falschen Zahlen
                                  hab grad testweise das widget mit usa erstellt, bei mir sind die Zahlen sogar noch niedriger als bei euch
                                    WebrangerW Offline
                                    Webranger
                                    #271
                                    Jetzt wo du es sagst.
                                    Unter objekte andere Zahlen wie im Widget !?
                                      MartyBr
                                      #272
                                      @crunchip Stimmt. Ich habe die neu den DPs zugeordnet. Das war bestimmt ein Flüchtigkeitsfehler. Kein Wunder bei dem Tempo, dass hier vorgelegt wird 👍
                                      Martin
                                      Homematic und Homematic IP
                                      • M MartyBr
                                        jackblackson
                                        #273
                                        @MartyBr Ihr macht hier eine super Arbeit, wollte ich mal erwähnen!! Es ist beeindruckend, was hier in so kurzer Zeit entsteht. Da kann sowas natürlich mal passieren :)
                                          MartyBr
                                          #274
                                          @jackblackson Ich bin nur "Nutzniesser". Die Arbeit wird hier von @crunchip und @sigi234 @Dutchman und vielen weiteren gemacht
                                          Großes Lob 👍
                                          Martin
