  4. Material Design Widgets: Input, Select, Autocompl.
vis
148 Beiträge 39 Kommentatoren 40.3k Aufrufe 29 Beobachtet
  • Stephan SchleichS
    Stephan SchleichS
    Stephan Schleich
    schrieb am zuletzt editiert von Stephan Schleich
    @Scrounger Besteht im Select Widget die Möglichkeit das Icon hinter den text zu legen?
    Desweiteren hat das Select Widget eine feste Höhe hinterlegt, kann man diese ändern?
    In dem Widget wird der Wert erst angezeigt wenn man es anklickt:
    [{"tpl":"tplVis-materialdesign-Select","data":{"oid":"javascript.0.vis.HeatingControl.ProfileTypes.Sun.Periods.0.Temperature","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","inputType":"text","inputLayout":"regular","listDataMethod":"jsonStringObject","countSelectItems":"1","listPosition":"auto","showSelectedIcon":"no","showValue":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"jsonStringObject":"[\n\t{\n\t\t\"text\": \"12 °C\",\n\t\t\"value\": \"12\"\t\t\n\t},\n\t{\n\t\t\"text\": \"13 °C\",\n\t\t\"value\": \"13\"\n\t},\n\t{\n\t\t\"text\": \"14 °C\",\n\t\t\"value\": \"14\"\n\t},\n\t{\n\t\t\"text\": \"15 °C\",\n\t\t\"value\": \"15\"\n\t},\n\t\t{\n\t\t\"text\": \"16 °C\",\n\t\t\"value\": \"16\"\n\t},\n\t{\n\t\t\"text\": \"17 °C\",\n\t\t\"value\": \"17\"\n\t},\n\t{\n\t\t\"text\": \"18 °C\",\n\t\t\"value\": \"18\"\n\t},\n\t{\n\t\t\"text\": \"19 °C\",\n\t\t\"value\": \"19\"\n\t},\n\t{\n\t\t\"text\": \"20 °C\",\n\t\t\"value\": \"20\"\n\t},\n\t{\n\t\t\"text\": \"21 °C\",\n\t\t\"value\": \"21\"\n\t},\n\t{\n\t\t\"text\": \"22 °C\",\n\t\t\"value\": \"22\"\n\t},\n\t{\n\t\t\"text\": \"23 °C\",\n\t\t\"value\": \"23\"\n\t},\n\t{\n\t\t\"text\": \"24 °C\",\n\t\t\"value\": \"24\"\n\t},\n\t{\n\t\t\"text\": \"25 °C\",\n\t\t\"value\": \"25\"\n\t},\n\t{\n\t\t\"text\": \"26 °C\",\n\t\t\"value\": \"26\"\n\t},\n\t{\n\t\t\"text\": \"27 °C\",\n\t\t\"value\": \"27\"\n\t},\n\t{\n\t\t\"text\": \"28 °C\",\n\t\t\"value\": \"28\"\n\t},\n\t{\n\t\t\"text\": \"28 °C\",\n\t\t\"value\": \"28\"\n\t},\n\t{\n\t\t\"text\": \"29 °C\",\n\t\t\"value\": \"29\"\n\t},\n\t{\n\t\t\"text\": \"30 °C\",\n\t\t\"value\": \"30\"\n\t}\n]","inputLayoutBorderColor":"white","g_inputLabel":false,"g_inputAppendix":false,"g_inputSubText":false,"showInputMessageAlways":"true","g_counter":false,"g_icons":true,"inputTextColor":"black","inputTextFontSize":"14","listItemHeight":"","clearIconShow":false,"g_menuItems_§1":false,"g_menuItems_§0":false,"listPositionOffset":true,"listItemFontSize":"14","inputLayoutBorderColorHover":"white","inputLayoutBorderColorSelected":"lightgreen","inputLayoutBackgroundColorSelected":"","collapseIconSize":"","prepandInnerIconColor":"","appendOuterIcon":"","prepandIconColor":"","prepandInnerIcon":"","collapseIcon":"","collapseIconColor":"black","showInputCounter":"true"},"style":{"left":"1240px","top":"469px","width":"78px","height":"20px","overflow-y":"","overflow-x":"","border-width":"1px","border-style":"solid","border-color":"white","border-radius":"2px","background":"white"},"widgetSet":"materialdesign"}]
    ScroungerS 1 Antwort Letzte Antwort
    • ScroungerS Scrounger
      @Termina
      Der Wert muss auch ein Wert eines Menü Punktes sein, dann wird er beim laden auch angezeigt.
      rantanplanR
      rantanplanR
      rantanplan
      @Scrounger sagte in Material Design Widgets: Input, Select, Autocompl.:
      @Termina
      Klappt bei mit trotzdem nicht richtig. Habe jetzt etliche Versuche mit dem Select Widget hinter mir.
      Bei einem selbst angelegten Datenpunkt (Text), funktioniert es einwandfrei.
      Ich wollte das wirklich schöne Widget für meine Heizungssteuerung einsetzen. Datenpunkt "SET_TEMPERATURE".
      Erste Versuch:
      Werteliste: 18.0,18.5,19.0,19.5 (usw)
      Werteliste Beschriftung: 18.0°C,18.5°C,19.0°C,19.5°C (usw)
      Beim Laden wurde kein Wert angezeigt.
      Direkt beim Datenpunkt nachgeschaut. Dort steht z.B. 19°C.
      Also habe ich beim DP die Maßeinheit einfernt. -> Keine Änderung im Widget.
      Dann habe ich in der Werteliste alle ".0" entfernt. Im Vis-Editor wurde es dann korrekt angezeigt. Zur Laufzeit nicht mehr.
      Kann man den Widgets den inputType "Zahl" spendieren?
      Ich glaube/hoffe damit wäre das Problem erledigt.
      Rantanplan
      • Stephan SchleichS Stephan Schleich
        ScroungerS
        ScroungerS
        Scrounger
        schrieb am zuletzt editiert von Scrounger
        @Stephan-Schleich sagte in Material Design Widgets: Input, Select, Autocompl.:
        Nein, geht sicher per css überschreiben
        Lösch mal das Widget und erstell es komplett neu, höhe kann man einstellen, geht aber bei deinem exportierten auch nicht.
        @rantanplan sagte in Material Design Widgets: Input, Select, Autocompl.:
        @Termina
        Funktioniert wenn die Werteliste wie folgt ist:
        Werteliste: 18,18.5,19,19.5
        Edit: Hab noch was eingebaut, damit auch x.0 Werte funktionieren -> bitte aktuellen master von git testen
        rantanplanR Stephan SchleichS 2 Antworten Letzte Antwort
          @Termina
          rantanplanR
          rantanplanR
          rantanplan
          Danke für die schnelle Antwort.
          Ich hatte die Werteliste so eingetragen (find ich persönlich Übersichtlicher).
          18,
          18.5,
          19,
          19.5
          So funktioniert es nur mit einem eigenen Datenpunkt.
          Bei einem Aktor funktioniert es wenn alles in einer Zeile steht.
          In der Werteliste-Beschreibung funktionieren beide Arten.
          Werde ich machen.
          An dieser Stelle auch ein Danke vom mir, für die schönen Widgets.
          Vielleicht bist Du ja mal derjenige, der es schafft, über 80% der Smart-Aktoren ein einheitliches Design zu geben.
          Rantanplan
            @Termina
            Stephan SchleichS
            Stephan SchleichS
            Stephan Schleich
            @Scrounger Nach dem löschen des widgets gehts nun - danke
            Hab nun aber das PRoblem das hinter dem Widget ne Zahl steht, wie krieg ich die weg?
            Edit: Hat sich erledit, war der Punkt Zähler anzeigen
            • M
              M
              Mottimuc
              @Scrounger
              ich hätte gern an meinem AV Receiver ein Feld für die Auswahl des Inputs angelegt.
              Über Buttons und deren befehle würde das so aussehen:
              http://192.168.xxx.xxx/YamahaExtendedControl/v1/main/setInput?input=net_radio
              kann man sowas in ne Select Liste o.ä. bei Dir einbauen?
              (ein workaround wäre wohl, den Wert in ein User-Objekt zu schreiben und bei Änderung über ein Blockly oder ein JS diesen abzuholen und als befehl auszugeben...)
              ? Wäre aber wirklich um die Ecke....
              Viele Grüße
              Michael
              • M Mottimuc
                @Scrounger
                ScroungerS
                ScroungerS
                Scrounger
                @Mottimuc sagte in Material Design Widgets: Input, Select, Autocompl.:
                Das wird auch nur so gehen weil das Widget keine http befehle senden kann.
                Falls der Yamaha MusicCast kann, dann kannst das mit dem MusicCast Adapter und dem Select Widget realisieren.
                • M
                  M
                  Mottimuc
                  MusicCast
                  Merci!!! Das geht!
                  Viele Grüße
                  Michael
                  • BostilB
                    BostilB
                    Bostil
                    Kurzer Hinweis / Beobachtung @Scrounger und nur zur Info:
                    • bei Auswahl von "Date" können letztlich zwei "Entfernen-Symbole" auftauchen: Eines standardmäßig (nicht konfigurierbar) direkt neben der Datumsauswahl, das andere manuell konfigurierte erscheint dann daneben
                    Tolle Widgets hast du da programmiert ! Wirklich wahnsinn - werde dir die Tage etwas in die Kaffeekasse werfen.
                    • BostilB Bostil
                      ScroungerS
                      ScroungerS
                      Scrounger
                      @Bostil sagte in Material Design Widgets: Input, Select, Autocompl.:
                      Faszinierend ;-)
                      Mach mal bitte nen export von dem Widget, muss ich mir anschauen.
                      Welchen Browser verwendest du? Weil die Hoch-Runter Schaltfläche hab ich auch noch nie gesehen.
                      • BostilB
                        BostilB
                        Bostil
                        Interessant, dass gerade ich dich, als Crack, hier überraschen kann 🐶
                        Benutze seit kurzem "Vivaldi", auf Chromium-Basis. Unterhalb mal das Widget:
                        [{"tpl":"tplVis-materialdesign-Input","data":{"oid":"countdown.0.setup.Countdown5","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","inputType":"date","inputLayout":"solo-shaped","showInputMessageAlways":false,"showInputCounter":false,"clearIconShow":true,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"inputMask":"TT.MM.YYYY HH:MM","inputMaxLength":"-1","inputSuffix":"","inputTextFontFamily":"Akrobat","inputTextFontSize":"30","inputTextColor":"#d9d9d9","inputLabelText":"Datum","inputLabelFontFamily":"Akrobat","inputLabelFontSize":"10","clearIcon":"delete","clearIconColor":"#d9d9d9"},"style":{"left":"582px","top":"12px","width":"227px","height":"55px"},"widgetSet":"materialdesign"}]
                        • D
                          D
                          darkiop
                          @Scrounger Kurze Frage, kann es sein - dass das Select Widget (Werteliste) grundsätzlich versucht nen String zu senden?
                          ioBroker Object Explorer: https://forum.iobroker.net/topic/84117/iobroker-object-explorer-dashboard-zum-verwalten-von-dps?_=1789113045261 | Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
                          • D darkiop
                            ScroungerS
                            ScroungerS
                            Scrounger
                            @darkiop
                            Ja weil es eigentlich nen Input Widget im anderen Gewand ist. Wieso?
                              @darkiop
                              D
                              D
                              darkiop
                              @Scrounger Ich wollte damit einen Zeitwert (Sekunden/Minuten) in einen DP Typ number schreiben:
                              BostilB 1 Antwort Letzte Antwort
                              • D darkiop
                                BostilB
                                BostilB
                                Bostil
                                Wäre natürlich noch traumhafter, falls man den String noch variabler ändern könnte. Oder ich habe beim Typ "Mask" noch nicht ganz durchgeblickt. Für den Countdown-Adapter suche ich noch nach einer Möglichkeit das Datum nicht als YYYY-MM-DD, sondern als YYYY-MM-DD HH:MM zu übergeben ...
                                • P
                                  P
                                  PatrickFro
                                  schrieb am zuletzt editiert von PatrickFro
                                  GELÖST
                                  Moin zusammen,
                                  ich habe ein ungewöhnliches Verhalten des Input Widgets auf meinem Tablet mit fully.
                                  Klicke ich in fully auf das Input Widget, springt die View auf den Start View. Dieses Verhalten passierte mit Version 0.2.62, jedoch nach einem Update auf 0.2.66 ebenfalls. Am PC springt nichts zurück. Das Select Widget funktioniert auch ganz normal.
                                  View.txt
                                  Hat jemand eine Idee, woran es liegen kann?
                                  • P
                                    P
                                    PatrickFro
                                    Nachtrag: Hab gerade erkannt, dass es bei jedem Input Widget so passiert, auch in Views, in denen es bisher klappte.
                                    Somit hat es nichts mit Material Design zu tun. Hat vielleicht trotzdem jemand eine Idee?
                                    Edit: Nach Deaktivierung des Default-Views geht alles wieder.
                                    • M
                                      M
                                      Michi_Pi
                                      hab nun das nächste Problem, ich mach diese Chart in einem Pop-up auf.
                                      Jetzt wenn ich das Zeitintervall ancklicke, dann verschwindet die Auswahl im Hintergurund, wie kann ich das ändern?
                                      Edit: verschoben, da Frage Select Widget betrifft
                                      • C
                                        C
                                        Coffeelover
                                        Hi @Michi_Pi Welche z-Index Werte haben jeweils dein Popup und das Auswahlmenü? Bezüglich deiner Intervalle: Was genau meinst du mit "keine x-beliebigen"?
                                        @Scrounger vielen Dank für das einstellbare Timeout. Meine Charts sind jetzt alle sichtbar.
                                        • S
                                          S
                                          seppel786
                                          besteht die Möglichkeit ein bestehendes Select Values List Widget (mit Spotifyplaylisten gefüllt) mit dem
                                          Select Widget zu ersetzen?
                                          Einstellungen des Select Values List Widget:
                                          Danke und Grüße,
                                          Seppel
                                          84.1k
