<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Material Design Widgets: Input, Select, Autocompl.]]></title><description><![CDATA[<p dir="auto"><strong>Input Widget</strong> | <strong>Select Widget</strong> | <strong>Select Autocomplete</strong></p>
<p dir="auto"><img src="/assets/uploads/files/1580638349065-input.gif" alt="input.gif" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1580633079201-select.gif" alt="select.gif" class=" img-fluid img-markdown" /><img src="/assets/uploads/files/1580633084105-autocomplete.gif" alt="autocomplete.gif" class=" img-fluid img-markdown" /></p>
<p dir="auto">Sämtliche Fragen zu Einstellungen (VIS Editor, Bedienung, JSON strings, etc.) des Widgets hier stellen</p>
<p dir="auto">Das ist sicher besser für die Übersichtlichkeit und Dokumentation.</p>
<ul>
<li><a href="https://github.com/Scrounger/ioBroker.vis-materialdesign#text-input" rel="nofollow ugc">Dokumentation Input</a></li>
<li><a href="https://github.com/Scrounger/ioBroker.vis-materialdesign#select" rel="nofollow ugc">Dokumentation Select</a></li>
<li><a href="https://github.com/Scrounger/ioBroker.vis-materialdesign#autocomplete" rel="nofollow ugc">Dokumentation Autocomplete</a></li>
<li><a href="https://github.com/Scrounger/ioBroker.vis-materialdesign#online-example-project" rel="nofollow ugc">Online Beispiel</a></li>
</ul>
<p dir="auto"><strong><a href="https://forum.iobroker.net/search?term=Material%20Design%20Widgets%3A&amp;in=titles&amp;matchWords=all&amp;by%5B%5D=Scrounger&amp;categories%5B%5D=7&amp;sortBy=topic.title&amp;sortDirection=desc&amp;showAs=topics">Themen zu anderen Widgets findest du hier!</a></strong></p>
]]></description><link>https://forum.iobroker.net/topic/29666/material-design-widgets-input-select-autocompl</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 14:57:10 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/29666.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 02 Feb 2020 08:48:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Sat, 19 Apr 2025 23:46:33 GMT]]></title><description><![CDATA[<p dir="auto">Hallo zusammen,</p>
<p dir="auto">evtl. bin ich ja zu blind. Ich möchte gerne Autocomplete mit einem JSON Datenpunkt aus dem IOBroker bedienen.<br />
Über den Editor klappt das, aber funktioniert das Binding aus IOBroker heraus.</p>
<p dir="auto">Lt. Anleitung müsste es ja gehen.<br />
Zitat:</p>
<p dir="auto">Here you can add a JSON string to define the menu entries or use bindings to a datapoint that contains a JSON<br />
string.</p>
<p dir="auto">Könnt ihr mir da ein wenig auf die Sprünge helfen?</p>
<p dir="auto">Vielen Dank und schöne Ostern.</p>
]]></description><link>https://forum.iobroker.net/post/1266514</link><guid isPermaLink="true">https://forum.iobroker.net/post/1266514</guid><dc:creator><![CDATA[BamBam89]]></dc:creator><pubDate>Sat, 19 Apr 2025 23:46:33 GMT</pubDate></item><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Tue, 23 Apr 2024 15:42:06 GMT]]></title><description><![CDATA[<p dir="auto">Hallo ich versuche Material-Dsign Input eine Zeit einzugeben. Auf meinem Tablet kommt der Dialog der Zeiteingabe, ich verstehe, dass mit dem Button Festlegen der Wert an den DP übergeben wird. Leider wird der DP nicht übergeben. Wo ist mein Fehler?</p>
]]></description><link>https://forum.iobroker.net/post/1153775</link><guid isPermaLink="true">https://forum.iobroker.net/post/1153775</guid><dc:creator><![CDATA[michihorn]]></dc:creator><pubDate>Tue, 23 Apr 2024 15:42:06 GMT</pubDate></item><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Thu, 09 Mar 2023 14:32:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/liv-in-sky" aria-label="Profile: liv-in-sky">@<bdi>liv-in-sky</bdi></a> Danke. Das ist natürlich auch ein Weg auch wenn er etwas umständlicher ist als ein Eingabe Widget direkt zu verwenden. Für den Zweck wie ich es verwenden möchte, sollte es reichen.</p>
]]></description><link>https://forum.iobroker.net/post/960116</link><guid isPermaLink="true">https://forum.iobroker.net/post/960116</guid><dc:creator><![CDATA[Martin1982]]></dc:creator><pubDate>Thu, 09 Mar 2023 14:32:22 GMT</pubDate></item><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Thu, 09 Mar 2023 08:03:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/martin1982" aria-label="Profile: martin1982">@<bdi>martin1982</bdi></a></p>
<p dir="auto">kann dir nur ein beispiel meiner tests bieten - nutze jedoch nicht das materiald-widget :</p>
<p dir="auto"><img src="/assets/uploads/files/1678348923450-script-vis27.gif" alt="script-vis27.gif" class=" img-fluid img-markdown" /></p>
<p dir="auto"></p><section class="spoiler-wrapper"><button class="spoiler-control btn btn-default">widgets zum import</button><section style="display:none" class="spoiler-content"><p></p>
<pre><code>[{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"&lt;div style=\"white-space: pre\"&gt;\n{0_userdata.0.CONTROL-OWN.AAATEST.TestString2}\n&lt;/div&gt;"},"style":{"left":"950px","top":"919px","color":"#43e01a","font-weight":"bold","font-family":"Ubuntu-BoldItalic"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"    &lt;form onsubmit=\"return false\"&gt;\n    &lt;textarea id=\"myTextarea\" name=\"message\" rows=\"4\" cols=\"30\"&gt;&lt;/textarea&gt;\n    &lt;input type=\"submit\" value=\"Submit\" onclick=\"test1()\"&gt;\n    &lt;/form&gt;\n    \n  \n       \n       &lt;script&gt;\n           function test1(){\n               console.log(document.getElementById(\"myTextarea\").value);\n               vis.setValue('0_userdata.0.CONTROL-OWN.AAATEST.TestString2',document.getElementById(\"myTextarea\").value);\n           }\n       &lt;/script&gt;"},"style":{"left":"962px","top":"792px"},"widgetSet":"basic"}]
</code></pre>
<p dir="auto"></p></section></section><p></p>
]]></description><link>https://forum.iobroker.net/post/960015</link><guid isPermaLink="true">https://forum.iobroker.net/post/960015</guid><dc:creator><![CDATA[liv-in-sky]]></dc:creator><pubDate>Thu, 09 Mar 2023 08:03:27 GMT</pubDate></item><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Mon, 06 Mar 2023 09:52:31 GMT]]></title><description><![CDATA[<p dir="auto">Hallo,</p>
<p dir="auto">ich wollte eine sehr einfache PostIt Notiz Funktion in meine VIS einbauen.</p>
<p dir="auto">Eingabe übers Handy ==&gt; String Datenpunt ==&gt; Anzeige auf dem Tablet an der Wand.</p>
<p dir="auto">Das klappt eigentlich auch ganz gut und einfach. Aber ich habe keine Möglichkeit gefunden MultiLine Text in der VIS einzugeben. Am liebsten würde ich das Material Design Text Input verwenden. Da habe ich aber leider kein entsprechendes Property gefunden. Aber anscheid kann es auch kein anderes Control. Gibt es hier eventuell eine Möglichkeit und ich habe sie nur übersehen? Oder gibt es einen Grund warum das Text Input diese eigentlich grundlegende Funktion nicht hat?</p>
<p dir="auto">Gruß<br />
Martin</p>
]]></description><link>https://forum.iobroker.net/post/958272</link><guid isPermaLink="true">https://forum.iobroker.net/post/958272</guid><dc:creator><![CDATA[Martin1982]]></dc:creator><pubDate>Mon, 06 Mar 2023 09:52:31 GMT</pubDate></item><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Mon, 10 Oct 2022 13:59:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maikb85" aria-label="Profile: maikb85">@<bdi>maikb85</bdi></a> Datentyp ist String. Steht auch in der Doku <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f926.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--face_palm" style="height:23px;width:auto;vertical-align:middle" title=":face_palm:" alt="🤦" /> <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f601.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--grin" style="height:23px;width:auto;vertical-align:middle" title=":grin:" alt="😁" /><br />
Naja dann muss ich das irgendwie wieder zu Integerwerte parsen...</p>
]]></description><link>https://forum.iobroker.net/post/871081</link><guid isPermaLink="true">https://forum.iobroker.net/post/871081</guid><dc:creator><![CDATA[MaikB85]]></dc:creator><pubDate>Mon, 10 Oct 2022 13:59:27 GMT</pubDate></item><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Fri, 07 Oct 2022 15:35:04 GMT]]></title><description><![CDATA[<p dir="auto">Kann mir jemand erklären, wie das mit "Eingabetyp - Zeit" funktioniert. Wenn ich da eine Zeit eingebe, werden nur die Stunden als Wert eingetragen und das Input-Feld springt wieder zurück auf 12:30 (graue Schrift). Was soll das für ein Datentyp sein?</p>
]]></description><link>https://forum.iobroker.net/post/869832</link><guid isPermaLink="true">https://forum.iobroker.net/post/869832</guid><dc:creator><![CDATA[MaikB85]]></dc:creator><pubDate>Fri, 07 Oct 2022 15:35:04 GMT</pubDate></item><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Tue, 06 Sep 2022 09:29:36 GMT]]></title><description><![CDATA[<p dir="auto">Hallo zusammen,<br />
ist es möglich wenn man beim Input Widget Datum ausgewählt hat, dass er beim neu laden der Seite das aktuelle Datum Anzeigt und nicht was vorher darin stand?</p>
]]></description><link>https://forum.iobroker.net/post/853800</link><guid isPermaLink="true">https://forum.iobroker.net/post/853800</guid><dc:creator><![CDATA[Marc9025]]></dc:creator><pubDate>Tue, 06 Sep 2022 09:29:36 GMT</pubDate></item><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Tue, 26 Jul 2022 08:51:13 GMT]]></title><description><![CDATA[<p dir="auto">Hi Leute,</p>
<p dir="auto">bei mir wird der "Input Select Pfeil" doppelt angezeigt und ich habe keine Idee woher das kommt.<br />
Kann mir jemand sagen wie ich den kleinen "nicht ausgefüllten" Pfeil im Hintergrund loswerde ?</p>
<p dir="auto"><img src="/assets/uploads/files/1658824003583-5834128f-792c-4aad-a40c-a9570a3744e0-image.png" alt="5834128f-792c-4aad-a40c-a9570a3744e0-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Die kleinen Pfeile werden übrigens nur sichtbar wenn man die "font-size" auf xx-large stellt.<br />
Bleibt die "font-size" auf normal, dann rutschen die kleinen Pfeile hinter die großen und sind unsichtbar.</p>
<p dir="auto">Beste Grüße</p>
]]></description><link>https://forum.iobroker.net/post/834080</link><guid isPermaLink="true">https://forum.iobroker.net/post/834080</guid><dc:creator><![CDATA[Qlink]]></dc:creator><pubDate>Tue, 26 Jul 2022 08:51:13 GMT</pubDate></item><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Sat, 26 Feb 2022 07:13:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/namrenner" aria-label="Profile: namrenner">@<bdi>namrenner</bdi></a> keiner hat eine Idee?</p>
]]></description><link>https://forum.iobroker.net/post/768762</link><guid isPermaLink="true">https://forum.iobroker.net/post/768762</guid><dc:creator><![CDATA[Namrenner]]></dc:creator><pubDate>Sat, 26 Feb 2022 07:13:12 GMT</pubDate></item><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Mon, 21 Feb 2022 07:29:19 GMT]]></title><description><![CDATA[<p dir="auto">Hallo,</p>
<ol>
<li>wie bekomme ich den Abstand oben und unten weg, möchte selbe größe wie links haben?</li>
<li>Menü Auswahl Abstand links weg?<br />
Danke</li>
</ol>
<p dir="auto"><img src="/assets/uploads/files/1645428538445-unbenannt.jpg" alt="Unbenannt.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.iobroker.net/post/766070</link><guid isPermaLink="true">https://forum.iobroker.net/post/766070</guid><dc:creator><![CDATA[Namrenner]]></dc:creator><pubDate>Mon, 21 Feb 2022 07:29:19 GMT</pubDate></item><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Mon, 06 Sep 2021 15:36:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/conquest" aria-label="Profile: conquest">@<bdi>conquest</bdi></a> sagte in <a href="/post/668706">Material Design Widgets: Input, Select, Autocompl.</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/scrounger" aria-label="Profile: Scrounger">@<bdi>Scrounger</bdi></a><br />
Ich habe seit dem Update auf 0.5.9 ein Problem. Beim Select-Widget werden die Werte abgeschnitten obwohl das Widget groß genug ist. Gibt es da eine neue Einstellung?</p>
<p dir="auto"><img src="/assets/uploads/files/1629730110634-screenshot-192.168.178.46_8082-2021.08.23-16_44_23.png" alt="screenshot-192.168.178.46_8082-2021.08.23-16_44_23.png" class=" img-fluid img-markdown" /></p>
</blockquote>
<p dir="auto">Keiner eine Idee? Wäre super wenn mir jemand helfen könnte.<br />
Hier noch der Export vom Widget:</p>
<pre><code>[{"tpl":"tplVis-materialdesign-Select","data":{"oid":"heatingcontrol.0.vis.ProfileTypes.Sa-Su.Periods.1.Temperature","g_fixed":false,"g_visibility":true,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","inputType":"text","inputLayout":"regular","showInputMessageAlways":"true","showInputCounter":false,"clearIconShow":false,"listDataMethod":"valueList","countSelectItems":"2","listPosition":"bottom","showSelectedIcon":"no","showValue":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"inputLayoutBorderColor":"#mdwTheme:vis-materialdesign.0.colors.input.border","inputTextFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.input.text","inputTextColor":"#mdwTheme:vis-materialdesign.0.colors.input.text","collapseIconColor":"#mdwTheme:vis-materialdesign.0.colors.input.icon_collapse","listItemFont":"#mdwTheme:vis-materialdesign.0.fonts.input.dropdown.text","listItemFontColor":"#mdwTheme:vis-materialdesign.0.colors.input.menu.text","listItemValueFont":"#mdwTheme:vis-materialdesign.0.fonts.input.dropdown.value","listItemValueFontColor":"#mdwTheme:vis-materialdesign.0.colors.input.menu.value","value0":"1","value1":"2","value2":"3","label0":"","listItemBackgroundColor":"#mdwTheme:vis-materialdesign.0.colors.input.menu.background","inputTextFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.input.text","valueList":"12;12.5;13;13.5;14;14.5;15;15.5;16;16.5;17;17.5;18;18.5;19;19.5;20;20.5;21;21.5;22;22.5;23;23.5;24;24.5;25;25.5;26;26.5;27;27.5;28;28.5;29;29.5;30","valueListLabels":"12 °C;12,5 °C;13 °C;13,5 °C;14 °C;14,5 °C;15 °C;15,5 °C;16 °C;16,5 °C;17 °C;17,5 °C;18 °C;18,5 °C;19 °C;19,5 °C;20 °C;20,5 °C;21 °C;21,5 °C;22 °C;22,5 °C;23 °C;23,5 °C;24 °C;24,5 °C;25 °C;25,5 °C;26 °C;26,5 °C;27 °C;27,5 °C;28 °C;28,5 °C;29 °C;29,5 °C;30","inputLayoutBackgroundColorSelected":"black","vibrateOnMobilDevices":"50","inputAlignment":"left","inputLayoutBorderColorHover":"#mdwTheme:vis-materialdesign.0.colors.input.border_hover","inputLayoutBorderColorSelected":"#mdwTheme:vis-materialdesign.0.colors.input.border_selected","inputLabelColor":"#mdwTheme:vis-materialdesign.0.colors.input.label","inputLabelColorSelected":"#mdwTheme:vis-materialdesign.0.colors.input.label_selected","inputLabelFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.input.label","inputLabelFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.input.label","inputAppendixColor":"#mdwTheme:vis-materialdesign.0.colors.input.appendix","inputAppendixFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.input.appendix","inputAppendixFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.input.appendix","inputMessageFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.input.message","inputMessageFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.input.message","inputMessageColor":"#mdwTheme:vis-materialdesign.0.colors.input.message","inputCounterColor":"#mdwTheme:vis-materialdesign.0.colors.input.counter","inputCounterFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.input.counter","inputCounterFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.input.counter","clearIconColor":"#mdwTheme:vis-materialdesign.0.colors.input.icon_clear","listItemBackgroundHoverColor":"#mdwTheme:vis-materialdesign.0.colors.input.menu.hover","listItemBackgroundSelectedColor":"#mdwTheme:vis-materialdesign.0.colors.input.menu.selected","listItemRippleEffectColor":"#mdwTheme:vis-materialdesign.0.colors.input.menu.effect","listIconColor":"#mdwTheme:vis-materialdesign.0.colors.input.menu.icon","listItemFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.input.dropdown.text","listItemSubFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.input.dropdown.subText","listItemSubFont":"#mdwTheme:vis-materialdesign.0.fonts.input.dropdown.subText","listItemSubFontColor":"#mdwTheme:vis-materialdesign.0.colors.input.menu.subText","listItemValueFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.input.dropdown.value","autoFocus":false},"style":{"left":"1131.015625px","top":"181.984375px","width":"95px","height":"38px","z-index":"15","text-align":""},"widgetSet":"materialdesign"}]
</code></pre>
]]></description><link>https://forum.iobroker.net/post/674313</link><guid isPermaLink="true">https://forum.iobroker.net/post/674313</guid><dc:creator><![CDATA[Conquest]]></dc:creator><pubDate>Mon, 06 Sep 2021 15:36:25 GMT</pubDate></item><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Mon, 23 Aug 2021 14:49:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/scrounger" aria-label="Profile: Scrounger">@<bdi>Scrounger</bdi></a><br />
]]></description><link>https://forum.iobroker.net/post/668706</link><guid isPermaLink="true">https://forum.iobroker.net/post/668706</guid><dc:creator><![CDATA[Conquest]]></dc:creator><pubDate>Mon, 23 Aug 2021 14:49:09 GMT</pubDate></item><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Mon, 23 Aug 2021 14:59:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/scrounger" aria-label="Profile: Scrounger">@<bdi>Scrounger</bdi></a><br />
Eine Frage zum Wert <a href="https://github.com/Scrounger/ioBroker.vis-materialdesign#menu-json-properties" rel="nofollow ugc">„iconColor“ und „iconColorSelectedTextField“</a> im Select-Widget:</p>
<p dir="auto">Wenn das folgende JSON angegeben ist</p>
<pre><code>[
      "text": " ",
      "value": "1",
      "icon": "home",
      "iconColor": "blue",
      "iconColorSelectedTextField": "blue"
</code></pre>
<p dir="auto">sollte das Icon „home“ in blau erscheinen, aber wie? im Dropdown blau UND auch in blau wenn es ausgewählt/aktiv ist? aktuell ist es nur im Dropdown blau.</p>
<p dir="auto">v0.5.9</p>
]]></description><link>https://forum.iobroker.net/post/668338</link><guid isPermaLink="true">https://forum.iobroker.net/post/668338</guid><dc:creator><![CDATA[ice987]]></dc:creator><pubDate>Mon, 23 Aug 2021 14:59:06 GMT</pubDate></item><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Mon, 26 Jul 2021 08:29:17 GMT]]></title><description><![CDATA[<p dir="auto">Hallo,<br />
gibt es eine Möglichkeit das ganze noch weiter zu verkleinern?<br />
kleiner wie hier bekomme ich es nicht:</p>
<p dir="auto"><img src="/assets/uploads/files/1627288122155-4b0cc7ce-1dcc-4392-9224-eaabf56dcb20-image.png" alt="4b0cc7ce-1dcc-4392-9224-eaabf56dcb20-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Bekomm ich den schwarzen Balken überhalb des Textes irgendwie weg?</p>
<p dir="auto">Danke im Voraus.</p>
]]></description><link>https://forum.iobroker.net/post/656131</link><guid isPermaLink="true">https://forum.iobroker.net/post/656131</guid><dc:creator><![CDATA[nik82]]></dc:creator><pubDate>Mon, 26 Jul 2021 08:29:17 GMT</pubDate></item><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Sun, 25 Jul 2021 11:43:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/scrounger" aria-label="Profile: Scrounger">@<bdi>Scrounger</bdi></a><br />
Hallo,<br />
kann man den angezeigten Text beim Select Widget customizen/vom Schalter entkoppeln?</p>
<p dir="auto">Ich habe folgendes Ziel:</p>
<ul>
<li>Anzeige der aktuellen Station eines Heos-Radios (<code>current_station</code> Datenpunkt)</li>
<li>Umschalten auf eine der programmierten Favoriten (funktioniert über Senden eines passenden Strings an <code>command</code> Datenpunkt)<br />
Dabei sind die Favoriten ein Subset der potentiell auswählbaren Stationen, die ich aufgrund der schieren Menge auch nicht im Widget einprogrammieren will. Andererseits muss ich die Favoriten zuvor im Heos-Account konfigurieren und muss im <code>command</code> statt des Stationsnamens (Beschriftung des Items) einen String, der die Nummer des Favoriten enthält, (Value des Items) übergeben. Deshalb hätte ich das Select-Widget (anstelle von Autocomplete) verwendet.</li>
</ul>
<p dir="auto">Mein Ansatz wäre gewesen:</p>
<ul>
<li><code>current_station</code> anzeigen (der Datenpunkt ist read-only) -&gt; da weiß ich nicht, wie es geht</li>
<li>Alle Favoriten mit Name als Beschriftung und Player-Kommando (inkl. Favoritennummer) als Value hinterlegen mit dem <code>command</code> Datenpunkt als Schalter</li>
</ul>
<p dir="auto">Auch mit zusätzlichem Datenpunkt und Mapping über Javascript ist mir bisher nichts eingefallen.<br />
Gibt es da schon eine Lösung oder wäre das ein neues Feature?</p>
<p dir="auto">Danke &amp; viele Grüße<br />
Stephan</p>
]]></description><link>https://forum.iobroker.net/post/655954</link><guid isPermaLink="true">https://forum.iobroker.net/post/655954</guid><dc:creator><![CDATA[stephan.ritscher]]></dc:creator><pubDate>Sun, 25 Jul 2021 11:43:53 GMT</pubDate></item><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Tue, 20 Apr 2021 17:11:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/scrounger" aria-label="Profile: Scrounger">@<bdi>Scrounger</bdi></a></p>
<p dir="auto">Beim „materialdesign - input“ Widget in der Version 0.4.2 komme ich auf <a href="https://forum.iobroker.net/topic/29666/material-design-widgets-input-select-autocompl/111?_=1618938057657">meine Frage</a> zurück:</p>
<p dir="auto">ich möchte nur ein- bis vierstellige, positive Werte zulassen, mit keiner oder einer Kommastelle:<br />
Eingabetyp: <code>Maske</code><br />
Maske: <code>['#','#.#','##','##.#','###','###.#','####','####.#']</code></p>
<p dir="auto">Nun erlaubt es mir aber nur einstellige Werte mit oder ohne Kommastelle. Wie kann ich dies umsetzen?</p>
]]></description><link>https://forum.iobroker.net/post/618185</link><guid isPermaLink="true">https://forum.iobroker.net/post/618185</guid><dc:creator><![CDATA[ice987]]></dc:creator><pubDate>Tue, 20 Apr 2021 17:11:42 GMT</pubDate></item><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Wed, 06 Jan 2021 11:18:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sigi234" aria-label="Profile: sigi234">@<bdi>sigi234</bdi></a></p>
<p dir="auto">Ich bin am Erstellen einer Vis für mein Netzwerk und möchte hier div. Line Histories schalten. Die Zeitabstände hab ich über MDW Select schon erledigt, möchte jetzt aber noch die einzelnen Line History durchschalten. Derzeit sind diese in einem Line History Chart, die Erstellung einzelner Charts wär aber auch kein Problem</p>
<p dir="auto">Nur: Ich komm nicht auf die Lösung. Was hast du hier eingetragen?</p>
<p dir="auto"><img src="/assets/uploads/files/1609931816234-f042348f-1224-4699-b6c5-17fbc544a9e0-grafik.png" alt="f042348f-1224-4699-b6c5-17fbc544a9e0-grafik.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.iobroker.net/post/552258</link><guid isPermaLink="true">https://forum.iobroker.net/post/552258</guid><dc:creator><![CDATA[Hausbaer]]></dc:creator><pubDate>Wed, 06 Jan 2021 11:18:18 GMT</pubDate></item><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Tue, 29 Dec 2020 18:06:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/scrounger" aria-label="Profile: Scrounger">@<bdi>Scrounger</bdi></a></p>
<p dir="auto">Beim „materialdesign - autocomplete“ Widget in der Version 0.3.19 erscheint folgendes:</p>
<p dir="auto">Ist der eingegebene Wert bereits in der Autocomplete-Liste vorhanden, kann dieser ausgewählt werden, und die Auswahl verschwindet.<br />
Ist der Wert jedoch nicht vorhanden, verschwindet die Autocomplete-Liste während der Eingabe, erscheint jedoch nach Drücken der Enter-Taste. Könne dieses „nachträgliche“ erscheinen der Liste unterdrückt werden? Siehe evtl. auch Video:</p>
<p dir="auto"><a href="/assets/uploads/files/1609265029789-fullsizerender.mov">FullSizeRender.mov</a></p>
]]></description><link>https://forum.iobroker.net/post/546581</link><guid isPermaLink="true">https://forum.iobroker.net/post/546581</guid><dc:creator><![CDATA[ice987]]></dc:creator><pubDate>Tue, 29 Dec 2020 18:06:02 GMT</pubDate></item><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Mon, 28 Dec 2020 09:20:22 GMT]]></title><description><![CDATA[<p dir="auto">Ich versuche mit dem Input Feld einen Wert anzuzeigen und habe zwei Fragen. Wie kann ich aus dem Input Feld ein reines Output Feld machen sodass man keinen Wert eingeben kann. Ich versuche den Wert 587,2 so formatieren das nur die Vorkommastellen angezeigt werden. Das funktioniert aber nur wenn ich ### eingebe, wenn der Wert dann kleiner wird rutscht die Nachkomma stelle mit in die Anzeige. Hier ist der Wert mit 587.2 mit den Maksen ####, ###, und ##.</p>
<p dir="auto"><img src="/assets/uploads/files/1609147041911-bildschirmfoto-2020-12-28-um-10.15.45.png" alt="Bildschirmfoto 2020-12-28 um 10.15.45.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Wie muss die Maske aussehen damit immer nur die Vorkommastellen angezeigt werden egal wie groß die Zahl ist?</p>
]]></description><link>https://forum.iobroker.net/post/545279</link><guid isPermaLink="true">https://forum.iobroker.net/post/545279</guid><dc:creator><![CDATA[stephan1827]]></dc:creator><pubDate>Mon, 28 Dec 2020 09:20:22 GMT</pubDate></item><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Thu, 05 Nov 2020 11:08:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/scrounger" aria-label="Profile: Scrounger">@<bdi>Scrounger</bdi></a> sagte in <a href="/post/507274">Material Design Widgets: Input, Select, Autocompl.</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ple" aria-label="Profile: ple">@<bdi>ple</bdi></a> sagte in <a href="/post/505929">Material Design Widgets: Input, Select, Autocompl.</a>:</p>
<blockquote>
<p dir="auto">Schön wäre es im Widget, wenn ich im Widget bei Anwahl eines Datensatzes die Information, also die Nummer die es schon gibt und den Text umlegen kann auf einen State.</p>
</blockquote>
<p dir="auto">versteh leider wieder nicht was du machen willst :-)<br />
Nach dem du im select widget einen Datensatz ausgewählt hast soll dieser in einen anderen Datenpunkt, als der der dem Select Widget zugeordnet ist, geschrieben werden?</p>
</blockquote>
<p dir="auto">Ja ist nicht immer einfach.<br />
Ich versuch es mal anders.<br />
Das Widget hat ja 2 Eigenschaften. Einmal den Wert als Integer und einmal den Wert als Text.<br />
Wenn ich in der Vis was auswähle, brauch ich den Wert und den Text auf der S7 in DBs.<br />
Im iobroker habe ich einen Datenpunkt welcher als Json vorliegt. Verknüpfe ich das Objekt mit dem Widget erhalte ich den Integer zurück. Ok, jetzt brauchte ich noch den Text, der hinter dem Integer steckt.<br />
Gelöst habe ich es jetzt mit Javascript so.</p>
<pre><code>// Werte suchen im Json für Typnamen anhand der Typnummer
on({id: 's7.0.DBs.DB5._020_HMI_Rezept_Editor_DS_Nr', change: "ne"}, async function (obj) {
  var Value = obj.state.val;
var json_block = list.find(v =&gt; v.value === Value.toString());
var textinhalt = json_block ? json_block.text : null
setState("s7.0.DBs.DB5._020_HMI_Rezept_Editor_DS_aktuell_Typ_Name", textinhalt)
</code></pre>
]]></description><link>https://forum.iobroker.net/post/515697</link><guid isPermaLink="true">https://forum.iobroker.net/post/515697</guid><dc:creator><![CDATA[ple]]></dc:creator><pubDate>Thu, 05 Nov 2020 11:08:41 GMT</pubDate></item><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Sun, 01 Nov 2020 14:31:09 GMT]]></title><description><![CDATA[<p dir="auto">keiner eine Idee dazu? Ich bekomm das nicht zum laufen, am Tablet funktioniert es wie am PC.</p>
]]></description><link>https://forum.iobroker.net/post/513051</link><guid isPermaLink="true">https://forum.iobroker.net/post/513051</guid><dc:creator><![CDATA[MiB]]></dc:creator><pubDate>Sun, 01 Nov 2020 14:31:09 GMT</pubDate></item><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Mon, 26 Oct 2020 15:29:28 GMT]]></title><description><![CDATA[<p dir="auto">Hallo zusammen,<br />
ich sitze jetzt schon 2 Tage an dem Select Widget und muss nun doch mal fragen da ich wohl zu dämlich bin. Ich habe das Widget im VIS und am PC klapt auch alles, ich bin mir auch sicher am Tablet habe ich es gestern auch mit erfolg bedient. Nun mache ich noch ein VIS für das Handy und da will das Select Widget ums verrecken nicht aufklappen wenn ich drauf drücke. Ich habe das Widget vom Tablet Projekt kopiert und im Handy Project eingefügt. Ist also definitiv das gleiche. Auf dem Tab und dem Handy nutze ich den FullyBrowser. Hat jemand eine Idee warum es auf dem Handy nicht geht?</p>
]]></description><link>https://forum.iobroker.net/post/509977</link><guid isPermaLink="true">https://forum.iobroker.net/post/509977</guid><dc:creator><![CDATA[MiB]]></dc:creator><pubDate>Mon, 26 Oct 2020 15:29:28 GMT</pubDate></item><item><title><![CDATA[Reply to Material Design Widgets: Input, Select, Autocompl. on Fri, 23 Oct 2020 13:46:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bostil" aria-label="Profile: Bostil">@<bdi>Bostil</bdi></a> sagte in <a href="/post/507623">Material Design Widgets: Input, Select, Autocompl.</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/scrounger" aria-label="Profile: Scrounger">@<bdi>Scrounger</bdi></a> Hi Scrounger, kannst du verraten, wann die neue Version released werden soll ? Danke dir!</p>
</blockquote>
<p dir="auto">Plan war vor zwei Wochen <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f601.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--grin" style="height:23px;width:auto;vertical-align:middle" title=":grin:" alt="😁" /><br />
Dauert leider noch, komm grad nicht so dazu und es wird noch ein neues Feature geben, an dem ich aktuell arbeite.</p>
]]></description><link>https://forum.iobroker.net/post/508187</link><guid isPermaLink="true">https://forum.iobroker.net/post/508187</guid><dc:creator><![CDATA[Scrounger]]></dc:creator><pubDate>Fri, 23 Oct 2020 13:46:11 GMT</pubDate></item></channel></rss>
