Adapter "smartmeter"
Bis 0.5.9 runter hatte ich probiert 8-)
Downgrade auf 0.5.8 hat dann funktioniert und es werden jetzt erstmalig die Datenpunkte angelegt:
Leider bleibt es bei dem einmaligen Einlesen, im log kommt dann wieder der Fehler:
smartmeter.0 2017-08-15 14:33:54.508 debug SERIALPORT CLOSE smartmeter.0 2017-08-15 14:33:54.508 warn Exception: Error: No or too long message from Serial Device. smartmeter.0 2017-08-15 14:33:54.508 error Error: No or too long message from Serial Device. at SerialResponseTransport.handleSerialTimeout (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialR smartmeter.0 2017-08-15 14:33:54.507 error uncaught exception: No or too long message from Serial Device. smartmeter.0 2017-08-15 14:33:54.506 debug MESSAGE TIMEOUT TRIGGERED smartmeter.0 2017-08-15 14:33:44.454 debug REMAINING DATA AFTER MESSAGE HANDLING: smartmeter.0 2017-08-15 14:33:44.453 debug CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false smartmeter.0 2017-08-15 14:33:44.453 debug SET MESSAGE TIMEOUT TIMER: 10000 smartmeter.0 2017-08-15 14:33:44.453 debug SerialResponseTransport do not support sending of Data! Ignore them smartmeter.0 2017-08-15 14:33:44.453 debug CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false smartmeter.0 2017-08-15 14:33:44.452 debug CURRENT PROCESS STEP 2 IN HANDLEMESSAGE smartmeter.0 2017-08-15 14:33:44.452 debug PAUSE READING SERIALPORT TO HANDLE MESSAGE smartmeter.0 2017-08-15 14:33:44.451 debug MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.03\r\n" -> ["/ESY5Q3DA2004 V3.03\r\n","/ESY5Q3DA2004 V3.03"] smartmeter.0 2017-08-15 14:33:44.451 debug CURRENT PROCESS STEP 0 IN CHECKMESSAGE smartmeter.0 2017-08-15 14:33:44.449 debug MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.03" -> null smartmeter.0 2017-08-15 14:33:44.449 debug CURRENT PROCESS STEP 0 IN CHECKMESSAGE smartmeter.0 2017-08-15 14:33:44.449 debug MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.0" -> null smartmeter.0 2017-08-15 14:33:44.449 debug CURRENT PROCESS STEP 0 IN CHECKMESSAGE smartmeter.0 2017-08-15 14:33:44.448 debug MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3" -> null smartmeter.0 2017-08-15 14:33:44.448 debug CURRENT PROCESS STEP 0 IN CHECKMESSAGE smartmeter.0 2017-08-15 14:33:44.448 debug MATCH-RESULT SIGNON: "/ESY5Q3DA2004" -> null smartmeter.0 2017-08-15 14:33:44.447 debug CURRENT PROCESS STEP 0 IN CHECKMESSAGE smartmeter.0 2017-08-15 14:33:44.447 debug MATCH-RESULT SIGNON: "/ESY5" -> null smartmeter.0 2017-08-15 14:33:44.445 debug CURRENT PROCESS STEP 0 IN CHECKMESSAGE smartmeter.0 2017-08-15 14:33:43.558 debug SET MESSAGE TIMEOUT TIMER: 10000 smartmeter.0 2017-08-15 14:33:43.557 debug SERIALPORT OPEN smartmeter.0 2017-08-15 14:33:43.557 debug CREATE SERIALPORT: 9600 7 1 even smartmeter.0 2017-08-15 14:33:43.556 debug SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialResponseTransport","requestInterval":"10","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate":9600,"transportSe smartmeter.0 2017-08-15 14:33:43.555 info starting. Version 0.5.8 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v6.11.2 host.raspberrypi 2017-08-15 14:33:41.007 infoKann das ggfs. an der Leerzeile nach der ersten Zeile (/ESY5Q3DA2004 V3.03) der D0-Message liegen?
Iobroker läuft bei mir auf einem Rpi3 mit Raspbian Jessie! In meinem letzten post hatte ich den log angehangen, wo es funktioniert hat!
Ich habe den Adapter nochmal deinstalliert, reboot und dann neu installiert. Jetzt werden andere Datenpunkte angelegt:
Hier der log seit Neuinstallation:
host.raspberrypi 2017-08-16 09:51:39.924 error instance system.adapter.smartmeter.0 terminated with code 0 (OK) smartmeter.0 2017-08-16 09:51:39.893 info terminating smartmeter.0 2017-08-16 09:51:39.393 debug SERIALPORT CLOSE smartmeter.0 2017-08-16 09:51:39.389 warn Exception: Error: No or too long message from Serial Device. smartmeter.0 2017-08-16 09:51:39.383 error at Timer.listOnTimeout (timers.js:214:5) smartmeter.0 2017-08-16 09:51:39.383 error at tryOnTimeout (timers.js:250:5) smartmeter.0 2017-08-16 09:51:39.383 error at ontimeout (timers.js:386:14) smartmeter.0 2017-08-16 09:51:39.383 error at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialResponseTransport.js:87:22) smartmeter.0 2017-08-16 09:51:39.383 error at SerialResponseTransport.handleSerialTimeout (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialResponseTransport.js:200:11) smartmeter.0 2017-08-16 09:51:39.383 error Error: No or too long message from Serial Device. smartmeter.0 2017-08-16 09:51:39.382 error uncaught exception: No or too long message from Serial Device. smartmeter.0 2017-08-16 09:51:39.348 debug MESSAGE TIMEOUT TRIGGERED smartmeter.0 2017-08-16 09:49:39.346 debug REMAINING DATA AFTER MESSAGE HANDLING: smartmeter.0 2017-08-16 09:49:39.345 debug CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false smartmeter.0 2017-08-16 09:49:39.345 debug SET MESSAGE TIMEOUT TIMER: 120000 smartmeter.0 2017-08-16 09:49:39.344 debug SerialResponseTransport do not support sending of Data! Ignore them smartmeter.0 2017-08-16 09:49:39.342 debug CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false smartmeter.0 2017-08-16 09:49:39.337 debug CURRENT PROCESS STEP 2 IN HANDLEMESSAGE smartmeter.0 2017-08-16 09:49:39.333 debug PAUSE READING SERIALPORT TO HANDLE MESSAGE smartmeter.0 2017-08-16 09:49:39.332 debug MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.03\r\n" -> ["/ESY5Q3DA2004 V3.03\r\n","/ESY5Q3DA2004 V3.03"] smartmeter.0 2017-08-16 09:49:39.331 debug CURRENT PROCESS STEP 0 IN CHECKMESSAGE smartmeter.0 2017-08-16 09:49:39.330 debug MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.03\r" -> null smartmeter.0 2017-08-16 09:49:39.330 debug CURRENT PROCESS STEP 0 IN CHECKMESSAGE smartmeter.0 2017-08-16 09:49:39.329 debug MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.0" -> null smartmeter.0 2017-08-16 09:49:39.328 debug CURRENT PROCESS STEP 0 IN CHECKMESSAGE smartmeter.0 2017-08-16 09:49:39.327 debug MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3" -> null smartmeter.0 2017-08-16 09:49:39.327 debug CURRENT PROCESS STEP 0 IN CHECKMESSAGE smartmeter.0 2017-08-16 09:49:39.325 debug MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V" -> null smartmeter.0 2017-08-16 09:49:39.324 debug CURRENT PROCESS STEP 0 IN CHECKMESSAGE smartmeter.0 2017-08-16 09:49:39.323 debug MATCH-RESULT SIGNON: "/ESY" -> null smartmeter.0 2017-08-16 09:49:39.321 debug CURRENT PROCESS STEP 0 IN CHECKMESSAGE smartmeter.0 2017-08-16 09:49:37.752 debug SET MESSAGE TIMEOUT TIMER: 120000 smartmeter.0 2017-08-16 09:49:37.745 debug SERIALPORT OPEN smartmeter.0 2017-08-16 09:49:37.729 debug CREATE SERIALPORT: 9600 7 1 even smartmeter.0 2017-08-16 09:49:37.722 debug SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialResponseTransport","requestInterval":"300","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate":9600,"transport smartmeter.0 2017-08-16 09:49:37.711 info starting. Version 0.5.8 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v6.11.2 smartmeter.0 2017-08-16 09:49:37.632 debug statesDB connected smartmeter.0 2017-08-16 09:49:37.561 debug objectDB connected host.raspberrypi 2017-08-16 09:49:35.093 info instance system.adapter.smartmeter.0 started with pid 1232 host.raspberrypi 2017-08-16 09:49:35.042 info object change system.adapter.smartmeter.0 host.raspberrypi 2017-08-16 09:49:05.618 info object change system.adapter.smartmeter.0 host.raspberrypi 2017-08-16 09:48:50.699 info object change system.adapter.smartmeter.0 iobroker 2017-08-16 09:48:15.635 info exit 0 iobroker 2017-08-16 09:48:15.621 info host.raspberrypi object system.adapter.smartmeter.0 created host.raspberrypi 2017-08-16 09:48:15.615 info object change system.adapter.smartmeter.0 iobroker 2017-08-16 09:48:15.572 info host.raspberrypi object system.adapter.smartmeter.0.alive created iobroker 2017-08-16 09:48:15.541 info host.raspberrypi object system.adapter.smartmeter.0.connected created iobroker 2017-08-16 09:48:15.511 info host.raspberrypi object system.adapter.smartmeter.0.memHeapUsed created iobroker 2017-08-16 09:48:15.481 info host.raspberrypi object system.adapter.smartmeter.0.memHeapTotal created iobroker 2017-08-16 09:48:15.445 info host.raspberrypi object system.adapter.smartmeter.0.memRss created iobroker 2017-08-16 09:48:15.418 info host.raspberrypi object system.adapter.smartmeter.0.uptime created iobroker 2017-08-16 09:48:15.383 info host.raspberrypi object system.adapter.smartmeter.0.inputCount created iobroker 2017-08-16 09:48:15.352 info host.raspberrypi object system.adapter.smartmeter.0.outputCount created iobroker 2017-08-16 09:48:15.335 info host.raspberrypi create instance smartmeter iobroker 2017-08-16 09:48:13.496 info add smartmeter -
Hallo Apollon77
ich wollte an meinem Gaszähler den Verbrauch auslesen.
Genau ist es ein GT4 Gaszähler siehe Bild. Als Hardware wurde einfach ein Magnet-Reedkontakt an einem ESP8266 (WEMO D1 mini) angeschlossen.
Dort als Betriebssystem habe ich Tasmota installiert. Daten kommen über MQTT Adapter an IOBroker an.
Der magnetische Kontakt hängt jetzt am Zählwerk in der letzten Stelle des Zählwerks.
Somit wird alle 0.01 m³ (=10l) mein Reedkontakt kurzgeschlossen.
Unter MQTT Adapter sehe ich ob der Kontakt true oder false ist.
Ich kann den Eingang des Wemos auch so umkonfigurieren, dass man dort die Zählimpulse zählen kann…
Kannst Du mich auf die Spur bringen, ob dein Adapter damit umgehen kann?
Ich würde gerne mit dem FLOT Adapter mir eine schöne Grafik basteln.
Dazu ein Wert für den aktuellen Verbrauch, gesamten Verbrauch sowie Kosten loggen können.
Kannst Du helfen?
1526_141211-nabu-gaszaehler-mdommel.jpeg -
funktioniert der Adapter auch mit ESPeasy und dem Pulse Counter?
Oder gibt es Arduino Lösungen? Habe am Arduino im moment ein Read-Schalter, der
Read-Schalter am Gaszähler.
Ähnlich wie hier: https://voizchat.de/gaszaehler-verbrauc … erry-gpio/ `
noxx hat schon mal ne ähnliche Frage gestellt,geht nicht. Ein paar Seiten weiter vorn. Außerdem gibts von ihm auch noch ne Lösung wo aus einer Webseite Daten ausgelesen werden können.
http://forum.iobroker.net/viewtopic.php?f=21&t=7556&hilit=gasz%C3%A4hler gibts dazu noch ein paar Infos.
RappiRN
Guten Morgen,
ich habe jetzt alle Seiten durch gelesen! Leider habe ich noch ein Problem.
Ich habe mir diese Woche den extra den Multihost eingerichtet. Der Slave ein PI 3B ist im Keller und der Lesekopf von UDO angeschlossen.
Der Smartmeter Adapter lässt sich installieren. Beim Starten des Adapters erscheint die Fehlermeldung wie auf Seite 28 gefunden
host.rasp_pv1_goke 2017-07-24 21:35:41.501 error instance system.adapter.smartmeter.0 terminated with code 1 ()
host.rasp_pv1_goke 2017-07-24 21:35:40.719 info instance system.adapter.smartmeter.0 started with pid 11153
host.rasp_pv1_goke 2017-07-24 21:35:35.334 info Restart adapter system.adapter.smartmeter.0 because enabled
Scheinbar muss laut Seite 28
" Komisch … Dann löscht mal den "open-sml" ordner und installiere dann den Adapter. Sollte dann wieder installiert werden. Falls nicht wirf auch smartmeter-obis weg (oder gleich beides)"
gelöscht werden!
Leider finde ich weder wen der Adapter installiert ist, noch wenn er deinstalliert ist die beiden Verzeichnisse!
Danke für die Hilfe
Hallo Armin,
nur damit wir vom gleichen reden:
Bei Multihost darf vor der Verbindung zum Master NUR der admin (und der Discovery) installiert sein.
Alles andere muss anschließend über den Master (unter Host.1=Slave) installiert werden.
Auf keinen Fall vorher auf dem Keller-Pi installieren und dann erst als Slave definieren.
Hast du das so ausgeführt?
Danke für die Antwort,
dann ist die Grundinstallation schon mal ok (so habe ich es auch - allerdings mit einem Pi2) und es läuft.
Dann müsste @apollon77 etwas dazu sagen, der ist aber in Urlaub, was ihn aber anscheinend nicht hindern wird ;-)
die Dateien bzw. Verzeichnisse habe ich inzwischen gefunden gelöscht und neu installiert. Leider bekomme ich immer noch die Fehlermeldung
host.IOBrokerKeller 2017-08-17 14:30:03.823 info Do not restart adapter system.adapter.smartmeter.0 because disabled or deleted host.IOBrokerKeller 2017-08-17 14:30:03.822 error instance system.adapter.smartmeter.0 terminated with code 1 () host.IOBrokerKeller 2017-08-17 14:29:34.382 info instance system.adapter.smartmeter.0 terminated with code null () host.IOBrokerKeller 2017-08-17 14:29:34.381 warn instance system.adapter.smartmeter.0 terminated due to SIGTERM host.IOBrokerKeller 2017-08-17 14:29:34.374 info stopInstance system.adapter.smartmeter.0 killing pid 1842 host.IOBrokerKeller 2017-08-17 14:29:34.373 info stopInstance system.adapter.smartmeter.0 host.IOBrokerKeller 2017-08-17 14:29:34.373 info "system.adapter.smartmeter.0" disabled host.IOBrokerKeller 2017-08-17 14:29:34.372 info object change system.adapter.smartmeter.0 host.IOBrokerKeller 2017-08-17 14:29:33.143 info instance system.adapter.smartmeter.0 started with pid 1842 host.IOBrokerKeller 2017-08-17 14:29:32.146 info Restart adapter system.adapter.smartmeter.0 because enabled host.IOBrokerKeller 2017-08-17 14:29:32.146 error instance system.adapter.smartmeter.0 terminated with code 1 () host.IOBrokerKeller 2017-08-17 14:29:30.517 info instance system.adapter.smartmeter.0 started with pid 1836 host.IOBrokerKeller 2017-08-17 14:29:03.105 info Restart adapter system.adapter.smartmeter.0 because enabledHat noch jemand einen Tip?
Danke im Vorraus
LG
Arminhh
Mach mal eine Installation als root auf der Konsole.
cd /opt/iobroker npm install iobroker.smartmeter --productionGruß
Rainer `
die Idee hatte ich auch schon. Habe es aber trotzdem noch einmal probiert! War leider aber auch ohne Erfolg!
host.IOBrokerKeller 2017-08-17 15:03:47.884 info Restart adapter system.adapter.smartmeter.0 because enabled host.IOBrokerKeller 2017-08-17 15:03:47.883 error instance system.adapter.smartmeter.0 terminated with code 1 () host.IOBrokerKeller 2017-08-17 15:03:46.233 info instance system.adapter.smartmeter.0 started with pid 2111 host.IOBrokerKeller 2017-08-17 15:03:16.211 info Restart adapter system.adapter.smartmeter.0 because enabled host.IOBrokerKeller 2017-08-17 15:03:16.211 error instance system.adapter.smartmeter.0 terminated with code 1 () host.IOBrokerKeller 2017-08-17 15:03:14.596 info instance system.adapter.smartmeter.0 started with pid 2105Danke für die Hilfe!!
mfg
Arminhh
