  4. Test Adapter fb-checkpresence v0.2.x
avmfritzboxfb-checkpresencesoaptr-064
259 Beiträge 26 Kommentatoren 51.1k Aufrufe 28 Beobachtet
  • SantosS Santos
    Morgen zusammen,
    ich versuche seit ca. zwei Tagen den Adapter fb-presence zum Laufen zu bringen. Leider springt er beim Starten auf "gelb" und so bleibt er.
    Im Log kommt dieser Fehler aus, DPs stehen leer.
    fb-checkpresence.0	2020-03-08 06:57:16.209	error	(28835) getDeviceList: soapAction X_AVM-DE_GetHostListPath -> {"statusCode":401,"body":"<HTML><HEAD><TITLE>401 Unauthorized (ERR_NONE)</TITLE></HEAD><BODY><H1>401 Unauthorized</H1><BR>ERR_NONE<HR><B>
    fb-checkpresence.0	2020-03-08 06:57:16.161	info	(28835) service GetSecurityPort is supported
    fb-checkpresence.0	2020-03-08 06:57:16.131	info	(28835) service X_AVM-DE_GetSpecificHostEntryByIP is supported
    fb-checkpresence.0	2020-03-08 06:57:16.007	info	(28835) service GetSpecificHostEntry is supported
    fb-checkpresence.0	2020-03-08 06:57:15.891	info	(28835) service X_AVM-DE_GetHostListPath is supported
    fb-checkpresence.0	2020-03-08 06:57:15.572	info	(28835) start fb-checkpresence: ip-address: fritz.box polling interval: 1 Min.
    fb-checkpresence.0	2020-03-08 06:57:15.516	info	(28835) starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.16.1
    fb-checkpresence.0	2020-03-08 06:57:09.376	info	(10113) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    fb-checkpresence.0	2020-03-08 06:57:09.374	info	(10113) terminating
    fb-checkpresence.0	2020-03-08 06:57:09.372	info	(10113) cleaned everything up...
    fb-checkpresence.0	2020-03-08 06:57:09.369	info	(10113) Got terminate signal TERMINATE_YOURSELF
    fb-checkpresence.0	2020-03-08 06:56:57.583	error	(10113) getDeviceList: soapAction X_AVM-DE_GetHostListPath -> {"statusCode":401,"body":"<HTML><HEAD><TITLE>401 Unauthorized (ERR_NONE)</TITLE></HEAD><BODY><H1>401 Unauthorized</H1><BR>ERR_NONE<HR><B>
    afuerhoffA Offline
    afuerhoffA Offline
    afuerhoff
    #160
    @Santos
    Hallo, kannst du die Instanz mal auf Loglevel Debug stellen und dann vom Start bis zum Fehler hier posten.
    Bitte überprüfe auch, ob du einen Fritzbox User mit Passwort eingetragen hast. Das ist für die Funktion wichtig, ansonsten kommt man nicht an alle Werte.
    Du kannst hierfür einen extra User in der Fritzbox anlegen.
    SantosS E 2 Antworten Letzte Antwort
    • afuerhoffA afuerhoff
      @Santos
      SantosS Offline
      SantosS Offline
      Santos
      #161
      @afuerhoff said in Test Adapter fb-checkpresence v0.2.x:
      Genau das war das Problem, war kein Benutzer in der Fritzbox angelegt, ich habe mich immer nur mit dem Passwort eingeloggt.
        @Santos
        e-s
        #162
        @afuerhoff
        Hi, ich habe deinen Adapter in 2 Instanzen zu laufen, die 2. Instanz habe ich missbraucht um meine shellys leicht und einfach zu überprüfen, dafür brauchte ich damals allpresent, da läuft auch alles super.
        Aber, nachdem ich jetzt 25 shellys habe, geht mir der Überblick verloren beim hinzufügen von neuen devices. Ist es möglich in der Auswahlliste anzuzeigen welche schon in der Liste sind.
        Da man beim hinzufügen die Liste im Hintergrund auch nicht scrollen kann, muss man sich alles merken.
        Wäre es alternativ auch möglich statt mac oder ip adresse, beide gleichzeitig in der Familienliste anzeigen zu lassen und dann auch nach einem vom beiden sortieren zu lassen?
        • sigi234S sigi234
          @afuerhoff
          Adapter ab und zu Gelb:
          2020-02-18 10:35:46.011 - error: fb-checkpresence.0 (6740) getActive: soapAction GetSpecificHostEntry -> {"statusCode":500,"body":"\n\n\n\ns:Client\nUPnPError\n\n\n401\nInvalid Action\n\n\n\n\n","headers":{"date":"Tue, 18 Feb 2020 09:35:44 GMT","server":"FRITZ!Box 6590 Cable UPnP/1.0 AVM FRITZ!Box 6590 Cable 148.07.12","connection":"close","content-length":"429","content-type":"text/xml; charset=\"utf-8\""},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"192.168.178.1:49443","port":"49443","hostname":"192.168.178.1","hash":null,"search":null,"query":null,"pathname":"/upnp/control/hosts","path":"/upnp/control/hosts","href":"https://192.168.178.1:49443/upnp/control/hosts"},"method":"POST","headers":{"SoapAction":"urn:dslforum-org:service:Hosts:1#GetSpecificHostEntry","Content-Type":"text/xml","charset":"utf-8","content-length":588}}}
          SantosS Offline
          SantosS Offline
          Santos
          #163
          @sigi234 said in Test Adapter fb-checkpresence v0.2.x:
          @afuerhoff
          Ich habe mich zu früh gefreut, es kommt der gleicher Fehler auf, der Adapter ist auch gelb.
          fb-checkpresence.0	2020-03-09 11:04:40.244	debug	(4463) checkPresence first run
          fb-checkpresence.0	2020-03-09 11:04:40.239	error	(4463) getActive: soapAction GetSpecificHostEntry -> {"statusCode":500,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schem
          fb-checkpresence.0	2020-03-09 11:04:40.164	debug	(4463) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schema
          fb-checkpresence.0	2020-03-09 11:04:40.155	debug	(4463) getActive [{"Name":"Bendito","Active":"true","Kommt":"2020.03.08 21:40:10","Geht":"2020.03.08 21:40:14"},{"Name":"Galaxy-J6","Active":"false","Kommt":"2020.03.08 21:40:09","Geht":"2020.03.09 01
          fb-checkpresence.0	2020-03-09 11:04:40.085	debug	(4463) getActive MI6-Xiaomi 1
          fb-checkpresence.0	2020-03-09 11:04:40.082	debug	(4463) response: 0 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n
          fb-checkpresence.0	2020-03-09 11:04:40.041	debug	(4463) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schema
          fb-checkpresence.0	2020-03-09 11:04:39.990	debug	(4463) getActive [{"Name":"Bendito","Active":"true","Kommt":"2020.03.08 21:40:10","Geht":"2020.03.08 21:40:14"},{"Name":"Galaxy-J6","Active":"false","Kommt":"2020.03.08 21:40:09","Geht":"2020.03.09 01
          fb-checkpresence.0	2020-03-09 11:04:39.642	debug	(4463) getActive Galaxy-J6 0
          fb-checkpresence.0	2020-03-09 11:04:39.638	debug	(4463) response: 0 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\
          fb-checkpresence.0	2020-03-09 11:04:39.599	debug	(4463) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schem
          fb-checkpresence.0	2020-03-09 11:04:39.464	debug	(4463) getActive [{"Name":"Bendito","Active":"true","Kommt":"2020.03.08 21:40:10","Geht":"2020.03.08 21:40:14"},
          fb-checkpresence.0	2020-03-09 11:04:37.575	debug	(4463) getActive Bendito 1
          fb-checkpresence.0	2020-03-09 11:04:37.572	debug	(4463) response: 0 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\
          fb-checkpresence.0	2020-03-09 11:04:37.542	debug	(4463) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schem
          fb-checkpresence.0	2020-03-09 11:04:37.537	debug	(4463) getDeviceInfo blCnt: 50
          fb-checkpresence.0	2020-03-09 11:04:37.536	debug	(4463) getDeviceInfo activeCnt: 34
          fb-checkpresence.0	2020-03-09 11:04:37.460	debug	(4463) getDeviceList: [{"Index":"1","IPAddress":"192.168.1.250","MACAddress":"24:5E:BE:1E:C3:9A","Active":"1","HostName":"Bendito","InterfaceType":"Ethernet","X_AVM-DE_Port":"3","X_AVM-DE_Speed":"100
          • SantosS Santos
            @afuerhoff
            afuerhoffA Offline
            afuerhoffA Offline
            afuerhoff
            #164
            @Santos sagte in Test Adapter fb-checkpresence v0.2.x:
            Hallo, wie oft kommt der Fehler denn vor? Der Fehler sagt aus, das Server seitig ein Fehler aufgetreten ist. Evtl. muss ich hier die Fehlerausgabe mal überdenken.
            SantosS 1 Antwort Letzte Antwort
            • E e-s
              @afuerhoff
              afuerhoffA Offline
              afuerhoffA Offline
              afuerhoff
              #165
              @e-s sagte in Test Adapter fb-checkpresence v0.2.x:
              ist es möglich in der Auswahlliste anzuzeigen welche schon in der Liste sind.
              Hallo, das ist möglich. Ich plane das mal für das nächste Release ein.
              Wäre es alternativ auch möglich statt mac oder ip adresse, beide gleichzeitig in der Familienliste anzeigen zu lassen.
              Das wäre schon möglich. Es könnte aber sein, dass sich die IP-Adresse je nach Einstellung in der Fritzbox ändert. Eindeutig ist die Mac-Adresse. Die Möglichkeit mit der IP-Adresse macht nur Sinn, wenn sie in der Fritzbox festgeschrieben ist.
              ? E 2 Antworten Letzte Antwort
                #166
                Das ist eines der Dinge die ich an deinem Adapter mag. Warum auch immer sich eine IP ändern kann dem Adapter ist es egal 👍
                  e-s
                  #167
                  @afuerhoff
                  Könnte aber zumindest die aktuelle IP angezeigt werden und trotzdem nach Mac gesucht werden?
                  Schön wäre es natürlich wenn bei der Auswahl nur die angezeigt werden, die noch nicht in der Liste sind.
                    SantosS Offline
                    SantosS Offline
                    Santos
                    #168
                    Das kann ich jetzt nicht sagen, heute war der Adapter grün. Ich versuche zu beobachten, unter welchen Bedienungen er sich ändert.
                    • afuerhoffA Offline
                      afuerhoffA Offline
                      afuerhoff
                      #169
                      @Bluefox
                      Hallo, ich habe ein Problem mit meinem Adapter. Obwohl er vor ein paar Tagen ins stable Repository aufgenommen worden ist, wird er bei mir nicht als stable in der Adapterliste angezeigt. Er erscheint weiterhin in der gelben Farbe als Beta. Kann das jemand der Tester so bestätigen?
                      Wenn ich unter npm schaue, wird als stable Version die 0.3.0 dort angezeigt. Was auch korrekt ist.
                      Was habe ich hier falsch gemacht?
                      sigi234S H 2 Antworten Letzte Antwort
                        @Bluefox
                        sigi234S Online
                        sigi234S Online
                        #170
                        @afuerhoff sagte in Test Adapter fb-checkpresence v0.2.x:
                        kann das jemand der Tester so bestätigen?
                        Ja
                          @Bluefox
                          Headhunter70
                          #171
                          @afuerhoff habe gerade versucht zu installieren, bekomme aber Fehlermeldung, liegt es an meinem System ?
                          • H Headhunter70
                            afuerhoffA Offline
                            afuerhoffA Offline
                            afuerhoff
                            #172
                            @Headhunter70
                            Hallo, ich verwende einen RaspberryPI und ein TinkerBoard. Wie hast du denn installiert?
                            H 1 Antwort Letzte Antwort
                              @Headhunter70
                              Headhunter70
                              #173
                              @afuerhoff Habe auch Tinkerboard, installation versucht ganz normal über Iobroker adapter view
                              E afuerhoffA 2 Antworten Letzte Antwort
                              • H Headhunter70
                                e-s
                                #174
                                @Headhunter70
                                drück doch da mal auf mehr und zeig dann einen neuen screenshot
                                • H Headhunter70
                                  afuerhoffA Offline
                                  afuerhoffA Offline
                                  afuerhoff
                                  #175
                                  @Headhunter70
                                  Ich hab gerade eine neue Instanz installiert. Hat bei mir ohne Probleme geklappt. Gibt es im Log irgendwelche Hinweise?
                                    @Headhunter70
                                    Headhunter70
                                    #176
                                    @afuerhoff mehmmm das ist ja echt komisch, habe einen anderen adapter installiert und das ging ohne Probleme.
                                    Hier noch mal ein screenshot
                                      @Headhunter70
                                      Headhunter70
                                      #177
                                      @afuerhoff wenn ich das aus dem Info Adtaper heraus installiere, sagt er mir der Adapter is schon installiert...
                                      E 1 Antwort Letzte Antwort
                                      • H Headhunter70
                                        e-s
                                        #178
                                        @Headhunter70
                                        welche Versionen hat dein System, also npm, node.js usw
                                        • E e-s
                                          @Headhunter70
                                          Headhunter70
                                          #179
