Test Adapter fb-checkpresence v0.2.x
Morgen zusammen,
ich versuche seit ca. zwei Tagen den Adapter fb-presence zum Laufen zu bringen. Leider springt er beim Starten auf "gelb" und so bleibt er.
Im Log kommt dieser Fehler aus, DPs stehen leer.fb-checkpresence.0 2020-03-08 06:57:16.209 error (28835) getDeviceList: soapAction X_AVM-DE_GetHostListPath -> {"statusCode":401,"body":"<HTML><HEAD><TITLE>401 Unauthorized (ERR_NONE)</TITLE></HEAD><BODY><H1>401 Unauthorized</H1><BR>ERR_NONE<HR><B> fb-checkpresence.0 2020-03-08 06:57:16.161 info (28835) service GetSecurityPort is supported fb-checkpresence.0 2020-03-08 06:57:16.131 info (28835) service X_AVM-DE_GetSpecificHostEntryByIP is supported fb-checkpresence.0 2020-03-08 06:57:16.007 info (28835) service GetSpecificHostEntry is supported fb-checkpresence.0 2020-03-08 06:57:15.891 info (28835) service X_AVM-DE_GetHostListPath is supported fb-checkpresence.0 2020-03-08 06:57:15.572 info (28835) start fb-checkpresence: ip-address: fritz.box polling interval: 1 Min. fb-checkpresence.0 2020-03-08 06:57:15.516 info (28835) starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.16.1 fb-checkpresence.0 2020-03-08 06:57:09.376 info (10113) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason fb-checkpresence.0 2020-03-08 06:57:09.374 info (10113) terminating fb-checkpresence.0 2020-03-08 06:57:09.372 info (10113) cleaned everything up... fb-checkpresence.0 2020-03-08 06:57:09.369 info (10113) Got terminate signal TERMINATE_YOURSELF fb-checkpresence.0 2020-03-08 06:56:57.583 error (10113) getDeviceList: soapAction X_AVM-DE_GetHostListPath -> {"statusCode":401,"body":"<HTML><HEAD><TITLE>401 Unauthorized (ERR_NONE)</TITLE></HEAD><BODY><H1>401 Unauthorized</H1><BR>ERR_NONE<HR><B> -
Morgen zusammen,
Im Log kommt dieser Fehler aus, DPs stehen leer.fb-checkpresence.0 2020-03-08 06:57:16.209 error (28835) getDeviceList: soapAction X_AVM-DE_GetHostListPath -> {"statusCode":401,"body":"<HTML><HEAD><TITLE>401 Unauthorized (ERR_NONE)</TITLE></HEAD><BODY><H1>401 Unauthorized</H1><BR>ERR_NONE<HR><B> fb-checkpresence.0 2020-03-08 06:57:16.161 info (28835) service GetSecurityPort is supported fb-checkpresence.0 2020-03-08 06:57:16.131 info (28835) service X_AVM-DE_GetSpecificHostEntryByIP is supported fb-checkpresence.0 2020-03-08 06:57:16.007 info (28835) service GetSpecificHostEntry is supported fb-checkpresence.0 2020-03-08 06:57:15.891 info (28835) service X_AVM-DE_GetHostListPath is supported fb-checkpresence.0 2020-03-08 06:57:15.572 info (28835) start fb-checkpresence: ip-address: fritz.box polling interval: 1 Min. fb-checkpresence.0 2020-03-08 06:57:15.516 info (28835) starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.16.1 fb-checkpresence.0 2020-03-08 06:57:09.376 info (10113) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason fb-checkpresence.0 2020-03-08 06:57:09.374 info (10113) terminating fb-checkpresence.0 2020-03-08 06:57:09.372 info (10113) cleaned everything up... fb-checkpresence.0 2020-03-08 06:57:09.369 info (10113) Got terminate signal TERMINATE_YOURSELF fb-checkpresence.0 2020-03-08 06:56:57.583 error (10113) getDeviceList: soapAction X_AVM-DE_GetHostListPath -> {"statusCode":401,"body":"<HTML><HEAD><TITLE>401 Unauthorized (ERR_NONE)</TITLE></HEAD><BODY><H1>401 Unauthorized</H1><BR>ERR_NONE<HR><B>@Santos
Hallo, kannst du die Instanz mal auf Loglevel Debug stellen und dann vom Start bis zum Fehler hier posten.Bitte überprüfe auch, ob du einen Fritzbox User mit Passwort eingetragen hast. Das ist für die Funktion wichtig, ansonsten kommt man nicht an alle Werte.
Du kannst hierfür einen extra User in der Fritzbox anlegen. -
@Santos
Du kannst hierfür einen extra User in der Fritzbox anlegen.@afuerhoff said in Test Adapter fb-checkpresence v0.2.x:
Du kannst hierfür einen extra User in der Fritzbox anlegen.Genau das war das Problem, war kein Benutzer in der Fritzbox angelegt, ich habe mich immer nur mit dem Passwort eingeloggt.
Danke -
@Santos
Hi, ich habe deinen Adapter in 2 Instanzen zu laufen, die 2. Instanz habe ich missbraucht um meine shellys leicht und einfach zu überprüfen, dafür brauchte ich damals allpresent, da läuft auch alles super.
Aber, nachdem ich jetzt 25 shellys habe, geht mir der Überblick verloren beim hinzufügen von neuen devices. Ist es möglich in der Auswahlliste anzuzeigen welche schon in der Liste sind.
Da man beim hinzufügen die Liste im Hintergrund auch nicht scrollen kann, muss man sich alles merken.
Wäre es alternativ auch möglich statt mac oder ip adresse, beide gleichzeitig in der Familienliste anzeigen zu lassen und dann auch nach einem vom beiden sortieren zu lassen? -
Adapter ab und zu Gelb:
2020-02-18 10:35:46.011 - error: fb-checkpresence.0 (6740) getActive: soapAction GetSpecificHostEntry -> {"statusCode":500,"body":"\n\n\n\ns:Client\nUPnPError\n\n\n401\nInvalid Action\n\n\n\n\n","headers":{"date":"Tue, 18 Feb 2020 09:35:44 GMT","server":"FRITZ!Box 6590 Cable UPnP/1.0 AVM FRITZ!Box 6590 Cable 148.07.12","connection":"close","content-length":"429","content-type":"text/xml; charset=\"utf-8\""},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"192.168.178.1:49443","port":"49443","hostname":"192.168.178.1","hash":null,"search":null,"query":null,"pathname":"/upnp/control/hosts","path":"/upnp/control/hosts","href":"https://192.168.178.1:49443/upnp/control/hosts"},"method":"POST","headers":{"SoapAction":"urn:dslforum-org:service:Hosts:1#GetSpecificHostEntry","Content-Type":"text/xml","charset":"utf-8","content-length":588}}}@sigi234 said in Test Adapter fb-checkpresence v0.2.x:
2020-02-18 10:35:46.011 - error: fb-checkpresence.0 (6740) getActive: soapAction GetSpecificHostEntry -> {"statusCode":500,"body":"\n\n\n\ns:Client\nUPnPError\n\n\n401\nInvalid Action\n\n\n\n\n","headers":{"date":"Tue, 18 Feb 2020 09:35:44 GMT","server":"FRITZ!Box 6590 Cable UPnP/1.0 AVM FRITZ!Box 6590 Cable 148.07.12","connection":"close","content-length":"429","content-type":"text/xml; charset=\"utf-8\""},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"192.168.178.1:49443","port":"49443","hostname":"192.168.178.1","hash":null,"search":null,"query":null,"pathname":"/upnp/control/hosts","path":"/upnp/control/hosts","href":"https://192.168.178.1:49443/upnp/control/hosts"},"method":"POST","headers":{"SoapAction":"urn:dslforum-org:service:Hosts:1#GetSpecificHostEntry","Content-Type":"text/xml","charset":"utf-8","content-length":588}}}Ich habe mich zu früh gefreut, es kommt der gleicher Fehler auf, der Adapter ist auch gelb.
fb-checkpresence.0 2020-03-09 11:04:40.244 debug (4463) checkPresence first run fb-checkpresence.0 2020-03-09 11:04:40.239 error (4463) getActive: soapAction GetSpecificHostEntry -> {"statusCode":500,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schem fb-checkpresence.0 2020-03-09 11:04:40.164 debug (4463) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schema fb-checkpresence.0 2020-03-09 11:04:40.155 debug (4463) getActive [{"Name":"Bendito","Active":"true","Kommt":"2020.03.08 21:40:10","Geht":"2020.03.08 21:40:14"},{"Name":"Galaxy-J6","Active":"false","Kommt":"2020.03.08 21:40:09","Geht":"2020.03.09 01 fb-checkpresence.0 2020-03-09 11:04:40.085 debug (4463) getActive MI6-Xiaomi 1 fb-checkpresence.0 2020-03-09 11:04:40.082 debug (4463) response: 0 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n fb-checkpresence.0 2020-03-09 11:04:40.041 debug (4463) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schema fb-checkpresence.0 2020-03-09 11:04:39.990 debug (4463) getActive [{"Name":"Bendito","Active":"true","Kommt":"2020.03.08 21:40:10","Geht":"2020.03.08 21:40:14"},{"Name":"Galaxy-J6","Active":"false","Kommt":"2020.03.08 21:40:09","Geht":"2020.03.09 01 fb-checkpresence.0 2020-03-09 11:04:39.642 debug (4463) getActive Galaxy-J6 0 fb-checkpresence.0 2020-03-09 11:04:39.638 debug (4463) response: 0 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\ fb-checkpresence.0 2020-03-09 11:04:39.599 debug (4463) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schem fb-checkpresence.0 2020-03-09 11:04:39.464 debug (4463) getActive [{"Name":"Bendito","Active":"true","Kommt":"2020.03.08 21:40:10","Geht":"2020.03.08 21:40:14"}, fb-checkpresence.0 2020-03-09 11:04:37.575 debug (4463) getActive Bendito 1 fb-checkpresence.0 2020-03-09 11:04:37.572 debug (4463) response: 0 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\ fb-checkpresence.0 2020-03-09 11:04:37.542 debug (4463) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schem fb-checkpresence.0 2020-03-09 11:04:37.537 debug (4463) getDeviceInfo blCnt: 50 fb-checkpresence.0 2020-03-09 11:04:37.536 debug (4463) getDeviceInfo activeCnt: 34 fb-checkpresence.0 2020-03-09 11:04:37.460 debug (4463) getDeviceList: [{"Index":"1","IPAddress":"192.168.1.250","MACAddress":"24:5E:BE:1E:C3:9A","Active":"1","HostName":"Bendito","InterfaceType":"Ethernet","X_AVM-DE_Port":"3","X_AVM-DE_Speed":"100 -
fb-checkpresence.0 2020-03-09 11:04:40.244 debug (4463) checkPresence first run fb-checkpresence.0 2020-03-09 11:04:40.239 error (4463) getActive: soapAction GetSpecificHostEntry -> {"statusCode":500,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schem fb-checkpresence.0 2020-03-09 11:04:40.164 debug (4463) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schema fb-checkpresence.0 2020-03-09 11:04:40.155 debug (4463) getActive [{"Name":"Bendito","Active":"true","Kommt":"2020.03.08 21:40:10","Geht":"2020.03.08 21:40:14"},{"Name":"Galaxy-J6","Active":"false","Kommt":"2020.03.08 21:40:09","Geht":"2020.03.09 01 fb-checkpresence.0 2020-03-09 11:04:40.085 debug (4463) getActive MI6-Xiaomi 1 fb-checkpresence.0 2020-03-09 11:04:40.082 debug (4463) response: 0 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n fb-checkpresence.0 2020-03-09 11:04:40.041 debug (4463) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schema fb-checkpresence.0 2020-03-09 11:04:39.990 debug (4463) getActive [{"Name":"Bendito","Active":"true","Kommt":"2020.03.08 21:40:10","Geht":"2020.03.08 21:40:14"},{"Name":"Galaxy-J6","Active":"false","Kommt":"2020.03.08 21:40:09","Geht":"2020.03.09 01 fb-checkpresence.0 2020-03-09 11:04:39.642 debug (4463) getActive Galaxy-J6 0 fb-checkpresence.0 2020-03-09 11:04:39.638 debug (4463) response: 0 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\ fb-checkpresence.0 2020-03-09 11:04:39.599 debug (4463) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schem fb-checkpresence.0 2020-03-09 11:04:39.464 debug (4463) getActive [{"Name":"Bendito","Active":"true","Kommt":"2020.03.08 21:40:10","Geht":"2020.03.08 21:40:14"}, fb-checkpresence.0 2020-03-09 11:04:37.575 debug (4463) getActive Bendito 1 fb-checkpresence.0 2020-03-09 11:04:37.572 debug (4463) response: 0 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\ fb-checkpresence.0 2020-03-09 11:04:37.542 debug (4463) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schem fb-checkpresence.0 2020-03-09 11:04:37.537 debug (4463) getDeviceInfo blCnt: 50 fb-checkpresence.0 2020-03-09 11:04:37.536 debug (4463) getDeviceInfo activeCnt: 34 fb-checkpresence.0 2020-03-09 11:04:37.460 debug (4463) getDeviceList: [{"Index":"1","IPAddress":"192.168.1.250","MACAddress":"24:5E:BE:1E:C3:9A","Active":"1","HostName":"Bendito","InterfaceType":"Ethernet","X_AVM-DE_Port":"3","X_AVM-DE_Speed":"100@Santos sagte in Test Adapter fb-checkpresence v0.2.x:
Hallo, wie oft kommt der Fehler denn vor? Der Fehler sagt aus, das Server seitig ein Fehler aufgetreten ist. Evtl. muss ich hier die Fehlerausgabe mal überdenken.
@afuerhoff
Wäre es alternativ auch möglich statt mac oder ip adresse, beide gleichzeitig in der Familienliste anzeigen zu lassen und dann auch nach einem vom beiden sortieren zu lassen?@e-s sagte in Test Adapter fb-checkpresence v0.2.x:
ist es möglich in der Auswahlliste anzuzeigen welche schon in der Liste sind.
Hallo, das ist möglich. Ich plane das mal für das nächste Release ein.
Wäre es alternativ auch möglich statt mac oder ip adresse, beide gleichzeitig in der Familienliste anzeigen zu lassen.
Das wäre schon möglich. Es könnte aber sein, dass sich die IP-Adresse je nach Einstellung in der Fritzbox ändert. Eindeutig ist die Mac-Adresse. Die Möglichkeit mit der IP-Adresse macht nur Sinn, wenn sie in der Fritzbox festgeschrieben ist.
Das ist eines der Dinge die ich an deinem Adapter mag. Warum auch immer sich eine IP ändern kann dem Adapter ist es egal
Könnte aber zumindest die aktuelle IP angezeigt werden und trotzdem nach Mac gesucht werden?
Schön wäre es natürlich wenn bei der Auswahl nur die angezeigt werden, die noch nicht in der Liste sind. -
Das kann ich jetzt nicht sagen, heute war der Adapter grün. Ich versuche zu beobachten, unter welchen Bedienungen er sich ändert.
@Bluefox
Hallo, ich habe ein Problem mit meinem Adapter. Obwohl er vor ein paar Tagen ins stable Repository aufgenommen worden ist, wird er bei mir nicht als stable in der Adapterliste angezeigt. Er erscheint weiterhin in der gelben Farbe als Beta. Kann das jemand der Tester so bestätigen?
Wenn ich unter npm schaue, wird als stable Version die 0.3.0 dort angezeigt. Was auch korrekt ist.Was habe ich hier falsch gemacht?
@Bluefox
@afuerhoff sagte in Test Adapter fb-checkpresence v0.2.x:
kann das jemand der Tester so bestätigen?
Ja
@Bluefox
@afuerhoff habe gerade versucht zu installieren, bekomme aber Fehlermeldung, liegt es an meinem System ?
@Headhunter70
Hallo, ich verwende einen RaspberryPI und ein TinkerBoard. Wie hast du denn installiert?@afuerhoff Habe auch Tinkerboard, installation versucht ganz normal über Iobroker adapter view
@Headhunter70
drück doch da mal auf mehr und zeig dann einen neuen screenshot -
@Headhunter70
Ich hab gerade eine neue Instanz installiert. Hat bei mir ohne Probleme geklappt. Gibt es im Log irgendwelche Hinweise?@afuerhoff mehmmm das ist ja echt komisch, habe einen anderen adapter installiert und das ging ohne Probleme.
Hier noch mal ein screenshot
@Headhunter70
Ich hab gerade eine neue Instanz installiert. Hat bei mir ohne Probleme geklappt. Gibt es im Log irgendwelche Hinweise?@afuerhoff wenn ich das aus dem Info Adtaper heraus installiere, sagt er mir der Adapter is schon installiert...
