  4. Test Adapter TrashSchedule
adaptercalendaricalkalendermülltrash
1.4k Beiträge 186 Kommentatoren 715.7k Aufrufe 171 Beobachtet
  • J jwedenig
    Hi!
    Seit gestern (js controller update) ist mein Adapter rot.
    Hier das Log:
    host.raspberrypi	2020-01-28 08:31:31.600	error	Cannot download and install adapter "trashschedule@0.0.3". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
    host.raspberrypi	2020-01-28 08:31:31.599	info	iobroker npm-install: exit 1
    host.raspberrypi	2020-01-28 08:31:31.585	info	iobroker npm-install: host.raspberrypi download trashscheduleFile not found: trashschedule
    host.raspberrypi	2020-01-28 08:31:31.583	error	iobroker npm-install: host.raspberrypi Unknown packetName trashschedule
    host.raspberrypi	2020-01-28 08:31:29.441	error	Cannot download and install adapter "trashschedule@0.0.3". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
    host.raspberrypi	2020-01-28 08:31:29.439	info	iobroker npm-install: exit 1
    host.raspberrypi	2020-01-28 08:31:29.406	info	iobroker npm-install: host.raspberrypi download trashscheduleFile not found: trashschedule
    host.raspberrypi	2020-01-28 08:31:29.405	error	iobroker npm-install: host.raspberrypi Unknown packetName trashschedule
    host.raspberrypi	2020-01-28 08:31:29.201	error	Cannot download and install adapter "trashschedule@0.0.3". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
    host.raspberrypi	2020-01-28 08:31:28.169	info	iobroker install trashschedule@0.0.3 using installedVersion
    host.raspberrypi	2020-01-28 08:31:28.169	warn	startInstance cannot find adapter "trashschedule@0.0.3". Try to install it... 4 attempt
    host.raspberrypi	2020-01-28 08:31:28.167	info	iobroker npm-install: exit 1
    host.raspberrypi	2020-01-28 08:31:28.158	info	iobroker npm-install: host.raspberrypi download trashscheduleFile not found: trashschedule
    host.raspberrypi	2020-01-28 08:31:28.150	error	iobroker npm-install: host.raspberrypi Unknown packetName trashschedule
    host.raspberrypi	2020-01-28 08:31:26.225	info	iobroker install trashschedule@0.0.3 using installedVersion
    host.raspberrypi	2020-01-28 08:31:26.224	warn	startInstance cannot find adapter "trashschedule@0.0.3". Try to install it... 3 attempt
    host.raspberrypi	2020-01-28 08:31:25.176	info	iobroker install trashschedule@0.0.3 using installedVersion
    host.raspberrypi	2020-01-28 08:31:25.175	warn	startInstance cannot find adapter "trashschedule@0.0.3". Try to install it... 2 attempt
    host.raspberrypi	2020-01-28 08:31:25.173	info	iobroker npm-install: exit 1
    host.raspberrypi	2020-01-28 08:31:25.166	info	iobroker npm-install: File not found: trashschedule
    host.raspberrypi	2020-01-28 08:31:25.163	info	iobroker npm-install: host.raspberrypi download trashschedule
    host.raspberrypi	2020-01-28 08:31:25.154	error	iobroker npm-install: host.raspberrypi Unknown packetName trashschedule
    host.raspberrypi	2020-01-28 07:31:22.334	info	iobroker install trashschedule@0.0.3 using installedVersion
    host.raspberrypi	2020-01-28 07:31:22.333	warn	startInstance cannot find adapter "trashschedule@0.0.3". Try to install it... 1 attempt
    host.raspberrypi	2020-01-28 07:31:22.330	info	"system.adapter.trashschedule.0" enabled
    Wer eine Idee?
    jwedenig
    #216
    Habe den Adapter nochmals über Github installiert, jetzt läufts wieder!
      mikiline
      #217
      Hi und Super Adapter. Zu dem Thema mit dem Geburtstag und dem anzuzeigenden Alter mal ein Vorschlag.
      Da man im Kalender eh einen Eintrag machen muss/kann mit z.B. Geburtstag Karin könnte man den doch auch etwas erweitern.
      Und zwar mit dem Geburtsjahr. Das kann man sicher aus dem Text extrahieren "Geburtstag Karin 1989", dann mit dem aktuellen Jahr verrechnen und schon hat man das Alter....
      Grüsse und Danke für die Entwicklung
      • J Offline
        jwedenig
        #218
        Hi!
        Irgendwer eine Idee, warum der Wert bei "Ferien"mir so angezeigt wird?
        Bei allen anderen funktionierts!
          stockics6
          #219
          bei mir stürzt regelmäßig die iCal Instanz, die für den TrashSchedule zuständig ist, immer ab.
          Weiß jemand woran das liegen kann?
          Danke!
          • S stockics6
            Danke!
            SBorgS Offline
            SBorgS Offline
            SBorg
            #220
            @stockics6 Da stürzt nix ab :)
            "Terminated (NO_ERROR): Without reason" ist eine Standardmeldung, dass sich der Dienst ohne Fehler/Grund korrekt beendet hat. iCal (und andere) sind sogenannte "schedulded Adapter" die nicht immer laufen, sondern nur zu einem bestimmten Zeitpunkt gestartet werden und sich dann beenden ;)
            LG SBorg ( SBorg auf GitHub)
            • NegaleinN Offline
              NegaleinN Offline
              Negalein
              #221
              @haus-automatisierung
              Ist es möglich, die Kommastellen zu entfernen?
              Im Adapter gibt es keine Möglichkeit dazu.
              ° Fixer ---> iob fix
              HomoranH haus-automatisierungH 2 Antworten Letzte Antwort
              • NegaleinN Negalein
                #222
                @Negalein Mit welchem Widget zeigst du sie an?
                Da gibt es bestimmt die Möglichkeit
                Muss natürlich ein Zahlen-Widget sein
                Nicht wenn du basic string statt basic number nimmst ;-)
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  #223
                  @Homoran sagte in Test Adapter TrashSchedule v0.0.x:
                  Ahhhh, klar hab ich das falsche erwischt.
                  Ist mir nie aufgefallen, da bis zum letzten Update (glaube ich) von Trashschedule nur ganze Zahlen angezeigt wurden.
                  • opossumO Offline
                    opossumO Offline
                    opossum
                    schrieb am zuletzt editiert von opossum
                    #224
                    Hallo, @sigi234 ,
                    Du zeigst bei Dir in der vIS auch die Ferien an. Leider klappt das bei mir nicht. Ich habe mir aus dem Netz die ics-Datei für die Ferien 2020/2021 für Mecklenburg-Vorpommern heruntergeladen und diese in meinen Google-Kalender importiert. Dann im ical-Adapter testweise die Winterferien eingetragen mit komplettem Wortlaut, trotz dem werden diese Ferien nicht gefunden. Wie hast Du die Ferien eingetragen, ist dort für jeden einzelnen Tag Ferien eingetragen? Vielleicht könntest Du das in groben Zügen mal skizzieren?
                    EDIT: Habe es hinbekommen, im ical war es schon ermittelt, Trashscedule hatte noch nicht den richtigen Suchbegriff.
                    https://www.schlepper-petersdorf.de
                      haus-automatisierungH Offline
                      #225
                      @Negalein Die Nachkommastellen sind in der letzten Version raus. Das hatte etwas mit der Umstellung der Uhrzeit auf Sommerzeit zu tun (dadurch war eine Stunde Differenz und eben kein vollständiger Tag mehr).
                      📚 Meine Dokumentation
                      • ? Offline
                        #226
                        das ist wirklich ein hilfreicher Adapter.
                        Wie benutze ich das Widget? Irgendwie verstehe ich das nicht.
                          BoehserWolf
                          #227
                          Gibt es Pläne den Adapter ins stable Repo zu schieben?
                          Die Installation aus github Repo per Katze liefert neben einem unbekannten Zustand von github ja auch keine Aktualisierungsinfo.
                          • NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            #228
                            Es gibt jetzt ein Widget vom Trashschedule
                            https://forum.iobroker.net/topic/22912/vorlagen-ideen-müllplan-view-widget/152
                              sigi234S Online
                              sigi234S Online
                              #229
                              @telekom0815 sagte in Test Adapter TrashSchedule v0.0.x:
                              Und ein bisschen CSS
                              .trashtype .daysleft {
                                  background: transparent !important;
                                  color: #222222 !important;
                              .trashtype .dumpster {
                                   transform: scale(0.80) !important;
                              Und Adaptereinstellungen:
                              Ergebnis:
                              Widget:
                              [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"15px","top":"17px","width":"544px","height":"265px","border-width":"1px","border-style":"solid","border-radius":"5px","border-color":"#bfbfbf"},"widgetSet":"basic"},{"tpl":"tplTrashscheduleHelper","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"trashschedule.0.type.json","extraAttr":""},"style":{"left":"26px","top":"31px","width":"520px","height":"241px","z-index":"1","color":"#bdbdbd","font-family":"RobotoCondensed-Light","transform":"","text-align":"","font-size":"medium","line-height":"","border-width":"","border-style":"","border-radius":"","border-color":"","opacity":"","text-shadow":""},"widgetSet":"trashschedule"}]
                              • Meister MopperM Online
                                Meister Mopper
                                #230
                                Moinsen,
                                was läuft denn hier falsch? Passiert das woanders auch?
                                Proxmox und HA ...
                                  Moinsen,
                                  sigi234S Online
                                  sigi234S Online
                                  #231
                                  @Meister-Mopper sagte in Test Adapter TrashSchedule v0.0.x:
                                  Nö, welche Version hast du?
                                  • sigi234S sigi234
                                    Meister Mopper
                                    #232
                                    @sigi234 0.03
                                    Proxmox und HA ...
                                      @sigi234 0.03
                                      NegaleinN Offline
                                      NegaleinN Offline
                                      Negalein
                                      #233
                                      0.03
                                      dann geh mal auf 0.0.5
                                        Meister Mopper
                                        #234
                                        Danke, das hat funktioniert 😊
                                        Proxmox und HA ...
                                        • sigi234S sigi234
                                          Ergebnis:
                                          Widget:
                                          lobomauL Offline
                                          lobomauL Offline
                                          lobomau
                                          #235
                                          @sigi234 top, dein widget-export 👍
                                          Wie kann ich den Abstand zwischen Tonnen etwas vergrößern? Ich benutze eine andere und größere Schrift und möchte das die Texte alle jeweils in einer Zeile, also ohne Zeilenumbruch, dargestellt werden, damit es passt:
                                          Host: NUC8i3 mit Proxmox:
                                          • Slave: Pi4
