  4. [Projekt] MDCSS v2: Material Design CSS Version 2
    apollon77A
material uivismaterial css
717 Beiträge 74 Kommentatoren 279.7k Aufrufe 77 Beobachtet
  • mrFenyxM
    mrFenyxM
    mrFenyx
    #98
    Hi, kann ich in tnav ein widget haben das nicht wie alle andere aligned sind sondern, z.B. ganz rechts? Die wären auch keine navitems.
    UhulaU 1 Antwort Letzte Antwort
    • mrFenyxM mrFenyx
      UhulaU
      UhulaU
      Uhula
      #99
      @mrFenyx Klar, du musst es mit "mdui-noflex" nur aus der flex-Anordnung rausnehmen, dann kannst du es beliebig positionieren, z.B. mit: left=calc(100% - 40px). Kann auch weiterhin ein "mdui-navitem" sein, muss aber nicht.
      [{"tpl":"tplJquiIconNav","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"class":"mdui-navitem  mdui-noflex ","text":"<i class='material-icons'>help</i>","nav_view":"pageDemoEx1","g_last_change":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"calc(100% - 40px)","top":"0px","width":"40px","height":"39px","position":""},"widgetSet":"jqui"}]
      Uhula - Leise und Weise
      Ex: ioBroker on Gigabyte NUC Proxmox
      mrFenyxM jpgorganizerJ 2 Antworten Letzte Antwort
      • T
        T
        Tirador
        #100
        ich probiere nun auch meine ersten Gehversuche.
        Dabei versuche ich die "Grid-Struktur" mit mdui-cols-n umzusetzen.
        Ich hätte gerne das Responsive Design so, dass es sowohl im Quer- als auch Hochformat gut aussieht.
        Mein Handy hat die folgende Auflösung:
        • 396px im Hochformat
        • 766px im Querformat
        Im Hochformat passt prinzipiell nur eine Card auf den Schirm. Im Querformat könnte man zwei nebeneinander packen.
        Muss ich dann alles auf den kleinsten gemeinsamen Nenner ausrichten, d.h. 766 / 2 = 383 px?
        Ich habe gesehen das es im CSS für jede mdui-col-x Breite ein min-width und ein max-width gibt.
        Oder muss ich dann max-width auf 396 px einstellen und min-width auf 383 px?
        Die weitere Verkomplizierung.
        Es gibt nun noch ein Tablet, dass ich mit dem gleichen Design füttern wollen würde.
        Das Tablet hat die folgende Auflösung:
        • 587px im Hochformat
        • 939px im Querformat
        Ist das überhaupt mit einem responsive Design alles unter einen Hut zu zaubern?
        • T Tirador
          Dominik F.D
          Dominik F.D
          Dominik F.
          #101
          @Tirador
          Du musst dann mdui-cols-4-toc-5 einstellen, dann passt sich die Breite automatisch auf 320px-400px an. Beim quer sollten die sich dann nebeneinander anordnen. Du musst immer vom kleinsten ausgehen.
          • UhulaU Uhula
            mrFenyxM
            mrFenyxM
            mrFenyx
            #102
            @Uhula Super, danke! 👍
            • mrFenyxM mrFenyx
              B
              B
              BoehserWolf
              schrieb am zuletzt editiert von BoehserWolf
              #103
              @Uhula
              Habe ein Problem mit dem Importieren der "Einstellungen" cards aus MD_Demo in MD_Simple.
              Die Idee war:
              • Export/Import der entsprechenden Cards aus MD_Demo, also cardConfig, cardConfigCards, cardConfigColors in ein neues Projekt auf Basis von MD_Simple
              • sowie Export/Import des nötigen Einstellungen Widgets aus lnav
              • Einstellungen im neuen Projekt nutzen
              Das haut leider nicht hin, die Einstellungen lassen sich nicht anpassen, es passiert einfach nichts im neuen Projekt.
              Habe ich parallel das importierte MD_Demo Projekt in einem anderen Browser Tab auf, werden die Einstellungen dieses Projekts angepasst.
              Alles klar dachte ich, dann ändere ich die Bezeichnungen der Object IDs in den Widgets von cardConfigCards, cardConfigColors von demo_config_xxx in einen anderen Namen.
              Bspw. in cardConfigCards das Widget zur Card-Darstell. hat als Object ID "demo_card_title_color", also geändert in "proj_card_title_color". Das habe ich analog für alle Widgets in den entsprechenden Cards vorgenommen. Dann kann ich jedoch nichts mehr konfigurieren.
              Habe schon alles Mögliche probiert um das zum Laufen zu bringen...
              Bin für jeden Tipp dankbar.
              Hinweis am Rande: Ein Verweis auf eine Übersicht aller Material Design Icons habe ich hier gefunden. Würde vorschlagen einen Hinweis in github zu setzen. Dann hat man schnell die Übersicht über die Icons gefunden ohne lange googeln zu müssen.
              P UhulaU 2 Antworten Letzte Antwort
              • B BoehserWolf
                @Uhula
                Die Idee war:
                P
                P
                Pittini
                #104
                @BoehserWolf sagte in [Projekt] Material Design CSS v2:
                Die Idee war:
                Was in Deiner Auflistung auf jeden Fall fehlt sind die 3 Blöcke aus der abar. Hol die mal noch aus der MD_Demo rüber, dann sollte es klappen. Hab das auch in nem Projekt so gemacht und grundsätzlich klappt das auch.
                • P Pittini
                  Die Idee war:
                  B
                  B
                  BoehserWolf
                  #105
                  @Pittini
                  Funktioniert einwandfrei bis auf das Select für Primary Color. Das Select reagiert einfach mal gar nicht. Da noch ne Idee?
                  P 1 Antwort Letzte Antwort
                  • B BoehserWolf
                    @Pittini
                    P
                    P
                    Pittini
                    #106
                    Da noch ne Idee?
                    Beim ändern der Namen vertippt oder einen Eintrag vergessen? Entweder im Config Dialog, in einem der 3 abar Blöcke oder im Css.
                    • P Pittini
                      Da noch ne Idee?
                      B
                      B
                      BoehserWolf
                      #107
                      @Pittini
                      So ähnlich. Der VIS Editor hatte scheinbar beim Ändern des Namens der Object ID die Werte und Texte verworfen - warum auch immer!?
                      Also View aus Demo nochmal exportiert und neu importiert. Beim Importieren die Namen der Widgets bereits korrekt angepasst. Jetzt funzt es.
                      Thx nochmal 👍
                      • B BoehserWolf
                        @Uhula
                        Die Idee war:
                        UhulaU
                        UhulaU
                        Uhula
                        schrieb am zuletzt editiert von Uhula
                        #108
                        @BoehserWolf Danke, der Link zu den Icons ist im MD_Demo in der Icon-Card drin - kann ich aber auch noch im readme mit aufnehmen.
                        Den Rest hat @Pittini ja schon mit dir geklärt - hätte ich nicht besser gekonnt ;-)
                        • UhulaU Uhula
                          jpgorganizerJ
                          jpgorganizerJ
                          jpgorganizer
                          #109
                          @Uhula
                          Du hast weiter oben beschrieben, wie man etwas am rechten Rand ausrichtet. Das kannte ich zwar schon, aber das brachte wieder ein Thema bei mir hoch.
                          Ausgangsituation ist so, dass ich ein Widget am rechten Rand anheften will, in diesem Fall ein mdui-navitem, trifft aber bei allen Texten zu. Das mache ich so:
                          Das Problem ist die Breite (width). Im Beispiel steht hier 50px, da hier aktuell der angezeigte Text eben so reinpasst. Da meine Texte aber variabel sind, wird das über kurz oder lang eben zu klein oder zu groß sein. Im einen Fall wird dann abgeschnitten, im anderen Fall ist es nicht mehr rechts aussen.
                          Dazu müsste ich die tatsächlich notwendige Breite kennen. Also so eine Art text.length(). Oder eine ganz andere Lösung. Ich könnte mir auch vorstellen, dass ich einen maximale Breite verwende und dann innerhalb des Feldes rechtsbündig schreibe. Das habe ich aber bisher nicht hinbekommen. Hast du einen Tipp für mich?
                          jpgorganizer
                          smartgarden Adapter für GARDENA smart system
                          mrFenyxM 1 Antwort Letzte Antwort
                          • jpgorganizerJ jpgorganizer
                            @Uhula
                            jpgorganizer
                            mrFenyxM
                            mrFenyxM
                            mrFenyx
                            #110
                            @jpgorganizer Die idee mit "max_length" sollte schon passen. Was du dann tun musst ist im "CSS Font & Text" Bereich das "text-align" zu "right" setzen. Wichtig ist dass du für dieses Element nicht "mdui-center(-v/-h)" benutzt denn dieses überschreibt das normale text-align. Kann sein dass auch andere mdui- Klassen das tun, weiß ich nicht. Hoffe es passt so.
                            jpgorganizerJ 1 Antwort Letzte Antwort
                            • bilberryB
                              bilberryB
                              bilberry
                              #111
                              Ich hoffe nicht, dass ich die Antwort auf folgende Frage irgendwo schon überlesen habe:
                              Wenn ich mehrere Cards auf einer Seite darstelle (z.B. alle mit mdui-cols-4-toc-5) sind die auf dem Monitor schön nebeneinander und auf dem Smartphone wunderbar untereinander.
                              Aber, wenn ich die die letzte/unterste Card zusammenklappe (oder gar mit mdui-onload schon zusammengeklappt öffne), verschwindet Card die so weit hinter der tbar, dass man sie nicht mehr expandieren kann.
                              Hab's es soeben noch mal in der DEMO probiert, damit ihr nachvollziehen könnt, was ich meine. Für mich jetzt überraschend ist dort das Verhalten offenbar nicht so. Ein Seitenvergleich hat auf Anhieb keine Unterschiede gebracht. Hat jemand eine Idee, woran das bei mir liegen kann?
                              • bilberryB bilberry
                                P
                                P
                                Pittini
                                #112
                                @bilberry sagte in [Projekt] Material Design CSS v2:
                                Ich würde vermuten dass Dein content Bereich zu groß ist. Wenn Du mit ner tnav arbeitest muss der content calc(100% - 3 * 40px) sein. Hast Du nur 2mal 40 abgezogen geht der content zu weit nach unten. Wär zumindest jetzt mein Verdacht.
                                bilberryB 1 Antwort Letzte Antwort
                                • P Pittini
                                  bilberryB
                                  bilberryB
                                  bilberry
                                  #113
                                  @Pittini Danke für den Tipp. Es könnte tatsächlich sein, dass ich ursprünglich einer Vorlage ohne bnav begonnen habe. Die Stelle schaue ich mir heute Abend noch mal genauer an .
                                  • G
                                    G
                                    GiuseppeS
                                    schrieb am zuletzt editiert von GiuseppeS
                                    #114
                                    @Uhula
                                    Du verwendest in Deinem Script einige Methoden wie z.B. ele.closest, ele.attr, removeAttr, usw.
                                    Sind das ioBroker-eigene Methoden oder gibt es dazu einen offiziellen Begriff wonach man googlen könnte?
                                    Habe nur folgendes gefunden, aber da stehen deine Methoden nicht drin:
                                    HTML DOM Element Object
                                    Evtl hast du ja eine Quelle für mich :-)
                                    • mrFenyxM
                                      mrFenyxM
                                      mrFenyx
                                      schrieb am zuletzt editiert von mrFenyx
                                      #115
                                      Weiß jemand was man tun muss so dass die Material Icons korrekt in der ioBroker Android App angezeigt werden? Ist das eigentlich möglich? Jetzt wird nur das "Text" angezeigt also werden die Font Dateien nicht gefunden.
                                      UPDATE: man muss einfach nur die komplette Adresse für den Font URL angeben, dann alles in der App reload / resync und es geht!
                                      • G GiuseppeS
                                        @Uhula
                                        UhulaU
                                        UhulaU
                                        Uhula
                                        #116
                                        @GiuseppeS Früher, im HTML-Mittelalter, gab es kaum elegante Methoden um sich browserseitig durch die DOM Elemente zu bewegen. Eine Bibliothek, jquery, bot hier viel bessere Möglichkeiten. Mittlerweile könnte man auf jquery verzichten, aber ioBroker nutzt es noch (wie >80% der WebSites). Info/API/Dok: jquery
                                        G 1 Antwort Letzte Antwort
                                        • UhulaU Uhula
                                          G
                                          G
                                          GiuseppeS
                                          #117
                                          @Uhula
                                          Hey Klasse, danke für den Hinweis und den Link. So kann ich mich dran versuchen ein paar eigene Ideen umzusetzen :-)
                                          Wo ist eigentlich dein "Buy me a beer" - Link?
                                          84.1k
