  4. Test Adapter mihome-vacuum v2.0.x
    1.0k
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 665.1k Aufrufe 118 Beobachtet
  • D dehein2
    @Meistertr :
    Bitte und vor allem Danke:
    [user/pw] habe ich korrigiert
    mihome-vacuum.0	2020-02-28 20:25:03.304	debug	(20439) requesting params every: 60 Sec
    mihome-vacuum.0	2020-02-28 20:24:41.738	debug	(20439) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1582917881731,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066090653}
    mihome-vacuum.0	2020-02-28 20:24:27.242	info	(20439) trigger cleaning all null
    mihome-vacuum.0	2020-02-28 20:24:27.236	debug	(20439) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
    mihome-vacuum.0	2020-02-28 20:24:27.235	debug	(20439) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1582917867230,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581065963877}
    mihome-vacuum.0	2020-02-28 20:24:12.825	debug	(20439) CLEAN_LOGGING[{"Datum":"28.2","Start":"19:59","Saugzeit":"0 min","Fläche":"0.12 m²","Error":0,"Ende":false},{"Datum":"28.2","Start":"19:56","Saugzeit":"1 min","Fläche":"0.35 m²","Error":0,"End
    mihome-vacuum.0	2020-02-28 20:24:07.821	debug	(20439) CLEAN_LOGGING[{"Datum":"28.2","Start":"19:59","Saugzeit":"0 min","Fläche":"0.12 m²","Error":0,"Ende":false},{"Datum":"28.2","Start":"19:56","Saugzeit":"1 min","Fläche":"0.35 m²","Error":0,"En
    mihome-vacuum.0	2020-02-28 20:24:06.314	info	(20439) create state for carpet_mode
    mihome-vacuum.0	2020-02-28 20:24:03.827	info	(20439) set nächster Timer: Nicht verfügbar
    mihome-vacuum.0	2020-02-28 20:24:03.369	debug	(20439) requesting params every: 60 Sec
    mihome-vacuum.0	2020-02-28 20:24:03.356	info	(20439) Connected
    mihome-vacuum.0	2020-02-28 20:24:03.322	info	(20439) New generation or new fw detected, create new states goto and zoneclean
    mihome-vacuum.0	2020-02-28 20:24:03.311	debug	(20439) server started on 0.0.0.0:53421
    mihome-vacuum.0	2020-02-28 20:24:03.305	warn	(20439) Xiaomi Cloud username or password missing.
    mihome-vacuum.0	2020-02-28 20:24:03.303	info	(20439) Disconnect
    mihome-vacuum.0	2020-02-28 20:24:03.287	info	(20439) Cloud control disabled
    mihome-vacuum.0	2020-02-28 20:24:03.285	info	(20439) Expert mode disabled, states deleted
    mihome-vacuum.0	2020-02-28 20:24:03.283	error	(20439) Xiaomi Cloud: username or password missing.
    mihome-vacuum.0	2020-02-28 20:24:03.280	debug	(20439) load Map creator... true
    mihome-vacuum.0	2020-02-28 20:24:03.192	info	(20439) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.1
    mihome-vacuum.0	2020-02-28 20:24:00.445	debug	(20439) statesDB connected
    mihome-vacuum.0	2020-02-28 20:24:00.444	debug	(20439) States connected to redis: 127.0.0.1:9000
    mihome-vacuum.0	2020-02-28 20:24:00.426	debug	(20439) States create System PubSub Client
    mihome-vacuum.0	2020-02-28 20:24:00.423	debug	(20439) States create User PubSub Client
    mihome-vacuum.0	2020-02-28 20:24:00.408	debug	(20439) Redis States: Use Redis connection: 127.0.0.1:9000
    mihome-vacuum.0	2020-02-28 20:24:00.404	debug	(20439) objectDB connected
    mihome-vacuum.0	2020-02-28 20:24:00.394	debug	(20439) Objects connected to redis: 127.0.0.1:9001
    mihome-vacuum.0	2020-02-28 20:24:00.376	debug	(20439) Objects client initialize lua scripts
    mihome-vacuum.0	2020-02-28 20:24:00.375	debug	(20439) Objects create User PubSub Client
    mihome-vacuum.0	2020-02-28 20:24:00.374	debug	(20439) Objects create System PubSub Client
    mihome-vacuum.0	2020-02-28 20:24:00.369	debug	(20439) Objects client ready ... initialize now
    mihome-vacuum.0	2020-02-28 20:24:00.015	debug	(20439) Redis Objects: Use Redis connection: 127.0.0.1:9001
    mihome-vacuum.0	2020-02-28 20:23:56.615	info	(3200) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    mihome-vacuum.0	2020-02-28 20:23:56.613	info	(3200) terminating
    mihome-vacuum.0	2020-02-28 20:23:56.609	info	(3200) Got terminate signal TERMINATE_YOURSELF
    mihome-vacuum.0	2020-02-28 20:24:07.821	debug	(20439) CLEAN_LOGGING[{"Datum":"28.2","Start":"19:59","Saugzeit":"0 min","Fläche":"0.12 m²","Error":0,"Ende":false},{"Datum":"28.2","Start":"19:56","Saugzeit":"1 min","Fläche":"0.35 m²","Error":0,"End
    dirkhe
    #453
    @dehein2 funktioniert es denn jetzt?
    MeistertrM 1 Antwort Letzte Antwort
    • bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      #454
      gestellt auf "Info".
      Instanz gestartet um 20:23
      mihome-vacuum.0	2020-02-28 20:23:22.870	info	(16940) create state for carpet_mode
      mihome-vacuum.0	2020-02-28 20:23:20.396	info	(16940) set nächster Timer: Nicht verfügbar
      mihome-vacuum.0	2020-02-28 20:23:19.956	warn	(16940) Time difference between Mihome Vacuum and ioBroker: 15 sec
      mihome-vacuum.0	2020-02-28 20:23:19.955	info	(16940) Connected
      mihome-vacuum.0	2020-02-28 20:23:19.921	info	(16940) New generation or new fw detected, create new states goto and zoneclean
      mihome-vacuum.0	2020-02-28 20:23:19.864	info	(16940) Disconnect
      mihome-vacuum.0	2020-02-28 20:23:19.851	info	(16940) Cloud control disabled
      mihome-vacuum.0	2020-02-28 20:23:19.850	info	(16940) Expert mode enabled, states created
      mihome-vacuum.0	2020-02-28 20:23:19.791	info	(16940) starting. Version 2.0.7 in C:/ioBroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0
      Bis jetzt 20:33 kein disconnent, connect mehr.
      Danke.
        dehein2
        #455
        @dirkhe: leider nein. Es ist aber so, dass die Karte immer über die Cloud kommt, oder? Direkt vom Gerät geht es nicht?
        • D dirkhe
          MeistertrM Offline
          MeistertrM Offline
          Meistertr
          #456
          @dirkhe sagte in Test Adapter mihome-vacuum v2.0.x:
          die frage wollte ich auch gerade stellen
            dirkhe
            #457
            Soweit ich weiss, ist das so. Der robbi schickt die daten in die Cloud und von da kann msn sich die karte abholen. Mein robbi ist zb. Nicht mit dem Internet verbunden, daher bekomme ich kein Karte. Ich habe mir die Karte nur einmal runtergeladen.
            • D dehein2
              MeistertrM Offline
              MeistertrM Offline
              Meistertr
              #458
              @dehein2 nein direkt geht es nur, wenn du Valetudo nutzt und eine andere Firmware aufspielst, dabei wird die gesamte Xiaomi Verbindung getrennt und alle daten nur noch lokal gesendet
              • X xADDRx
                @xADDRx said in Test Adapter mihome-vacuum v2.0.x:
                @blackeagle998 Hallo blackeagle998, danke für die Antwort.
                Das meinte ich jedoch nicht. Ich meine im Vis ein Widget.
                Aktuell benutze ich das hqwidgets on/off Widget als Steuerung. Leider fährt der Roboter immer 2 mal, obwohl nur einmal gedrückt wird.
                Ich vermute das liegt an dem Widget.
                Jemand eine Idee, warum der sonst immer 2 mal fährt?
                X Offline
                X Offline
                xADDRx
                #459
                Hat denn wirklich keiner eine Idee warum mein Sauger immer doppelt fährt??
                Sonos, Intel Nuc, Iobroker Pro, Proxmox, IPad Air (Wand), Vis, Xiaomi, Devolo, Bose, Philips Hue, Instar, Synology
                • X xADDRx
                  dirkhe
                  #460
                  @xADDRx ich kann es zwar nicht genau sagen, aber ich vermute mal, dass du ein falsches Widget benutzt. Es ist kein on/Off, es sind Buttons.
                  • MeistertrM Meistertr
                    dehein2
                    #461
                    @Meistertr said in Test Adapter mihome-vacuum v2.0.x:
                    Valetudo
                    Hat Valetudo sonst irgendwelche Nachteile? Ich würde die Cloud Verbindung eh gerne los werden und benötige die App auch nicht wirklich.
                      skorpil
                      #462
                      Installation der aktuellen Version bei mir komplett unproblematisch. Herzlichen Dank allen Akteueren. Männer, ihr habt Großartiges geleistet.
                      • D dehein2
                        Valetudo
                        MeistertrM Offline
                        MeistertrM Offline
                        Meistertr
                        #463
                        @dehein2 nein hat keine Nachteile.
                        • MeistertrM Offline
                          MeistertrM Offline
                          Meistertr
                          #464
                          so habe gerade die config noch etwas verfeinert und das ganze sollte dann ab morgen auch in der latest Adapterliste angezeigt werden.
                          • D dirkhe
                            bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            #465
                            Ich hatte bisher immer "hqwidget on/off",
                            Lief einwandfrei.
                            Aber nun nicht mehr.
                            Welches ist denn das richtige widget ?
                            Danke.
                            • bahnuhrB bahnuhr
                              Lief einwandfrei.
                              dirkhe
                              #466
                              @bahnuhr man könnte noch explizit abfragen, ob true übergeben wird und false ignorieren. Aber es ist trotzdem das falsche Widget. Was du brauchst, ist ein Button und keine "checkbox". Du kannst nur den Impuls auslösen aber nicht ein und ausschalten
                                dehein2
                                #467
                                Danke. Dann installiere ich das erstmal und richte den Adapter neu ein. Danach klappts bestimmt ;)
                                • D dirkhe
                                  bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  #468
                                  Wie gesagt; bisher lief dies einwandfrei.
                                  Kannst du mir konkret sagen, welches widget du meinst ?
                                  Danke vorab.
                                  Danke.
                                    Aktuelle Test Version 2.0.1
                                    Veröffentlichungsdatum xx.xx.xxxx
                                    Github Link https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum
                                    ich habe soeben die version 2.0.1 hochgeladen. Testen und feedback gewünscht!!!
                                    was gibt es neues?
                                    • Cloud login zum besorgen des token bis lang china oder de server
                                    • Option zum aktivieren der Karte, diese wird als Canvas und png gespeicher
                                    • außerdem wird das neue Kartenformat mit rooms unterstützt
                                    #469
                                    @Meistertr @dirkhe
                                    Hallo Ihr zwei fleissigen Lieben!
                                    Mir ist gerade aufgefallen, dass auf Github die iobroker-community-adapters/ioBroker.mihome-vacuum das Setup in den Instanzen nicht richtig darstellt ( ich testete von dort geladen Version 2.0.7 ca 17.00 Uhr heute runtergezogen ).
                                    Habe upload, und zurückgehen auf 2.0.6 .. alles hat nicht funktioniert, dann ist mir eingefallen, dass dirkhe ja auf seiner Github Seite auch eine Version hat, diese installiert ( Version 2.0.8 von 18.25 Uhr heute), und siehe da, die Einstellungen etc. funktioniert alles. Dafür bleibt der Adapter auf Gelb und hat keine Verbindung zum Robot... :-/
                                      @Meistertr @dirkhe
                                      MeistertrM Offline
                                      MeistertrM Offline
                                      Meistertr
                                      schrieb am zuletzt editiert von Meistertr
                                      #470
                                      @ilovegym sagte in Test Adapter mihome-vacuum v2.0.x:
                                      screenshot wäre super mit der 2.07 vom community
                                        #471
                                        @Meistertr sagte in Test Adapter mihome-vacuum v2.0.x:
                                        Unmögliches sofort, Wunder dauern einen Moment länger.. :-) hier die erste Seite von 2.0.7
                                        hier die zweite Seite, siehst du rechts die beiden Scrollbalken? Ich kann damit im ganzen Setup hoch und runter scrollen, das sollen doch normal Tabs sein, und nicht eine ganze Seite zum scrollen.. denke, da liegt der Fehler..
                                        MeistertrM D 2 Antworten Letzte Antwort
                                          MeistertrM Offline
                                          MeistertrM Offline
                                          Meistertr
                                          #472
                                          @ilovegym ich habe es gerade nochmal auf meinem devsystem getestet, es ist alles so wie es soll. ich sehe aber an deinem 2ten bild auch, dass sie gesamte navbar an der linken seite nicht so aussieht wie es soll, installiere nochmal den admin neu, kann sein dass der darstellungsfehler daher kommt
