  4. [Projekt] MDCSS v2: Material Design CSS Version 2
material uivismaterial css
717 Beiträge 74 Kommentatoren 281.6k Aufrufe 77 Beobachtet
  • Dominik F.D Dominik F.
    @Uhula
    Das würde wenn ich jetzt richtig getestet habe bedeuten, dass ich von dem CSS weg müsste und das raised etc nachbauen müsste, was schade wäre
    Ich habe als Test dieses Widget genutzt und wollte folgende Farbe anstatt mdui-green-bg nutzen :#02c908. Das mdui-green-bg muss ich dann entfernen damit es funktioniert, das Widget sieht danach leider nicht mehr so "schön" aus
    [{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"class":"mdui-card-raised mdui-green-bg mdui-center mdui-label","g_last_change":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"IP: {tr-064.0.devices.raspberrypi4-io.lastIP}","comment":""},"style":{"left":"16px","top":"163px","width":"150px","height":"40px","z-index":0,"background":"","background-color":""},"widgetSet":"basic"}]
    UhulaU
    UhulaU
    Uhula
    #87
    @Dominik-F Stimmt, da du mdui-card-raised verwendest, wirkt sich die eigene background-color natürlich auf das gesamte Widget aus, nicht nur auf den inneren "card"-Anteil. Du "missbrauchst" hier ein wenig die mdui-card Zuweisung, welche z.B. auch margins und paddings setzt.
    Mit einer eigenen background-color musst du, wie du erkannt hast, die mdui-card-raised nachbilden und als CSS entfernen. Hier ein Beispiel, wie das Widget dann aussieht (eigene shadow/border-radius usw)
    [{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":true,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"class":"mdui-center mdui-label ","g_last_change":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"IP: 0.0.0.0","comment":"xmdui-card-raised xmdui-green-bg xmdui-center xmdui-label"},"style":{"left":"16px","top":"163px","width":"150px","height":"40px","z-index":0,"background":"#02c908","box-shadow":"0 0 0 1px rgba(255,255,255,0.025) inset, 0 3px 6px rgba(0,0,0,0.16), 0 3px 6px rgba(0,0,0,0.23)","border-radius":"4px"},"widgetSet":"basic"}]
    Grafana-refresh funktioniert, es muss nur in der URL (Quelle) mit angegeben werden. Bsp: &refresh=5m ergänzen.
    Uhula - Leise und Weise
    Ex: ioBroker on Gigabyte NUC Proxmox
    • D
      D
      der-eine
      schrieb am zuletzt editiert von der-eine
      #88
      @Uhula nochmal eine Frage zur lnav und rnav. Wenn ich die rnav öffne und irgendwo auf den Display hinklicke fährt sie wieder ganz normal ein. Das macht die lnav nicht. Sollte das nicht auch so funktionieren? Ich kann sie nur schließen wenn ich auf das Hamburger-Menü-Symbol klicke. Sind die beiden nicht "gleich" von der Funktion her?
      • UhulaU Uhula
        Dominik F.D
        Dominik F.D
        Dominik F.
        #89
        @Uhula
        Super, das Widget sieht genauso aus wie es sein sollte und hab nun eine Vorlage für den Shadow falls ich sowas nochmal brauche.
        Das mit dem Refresh funktioniert bei mir nicht richtig.
        http://192.168.178.38:3000/d/UxKIGxkgz/temperaturen?orgId=1&refresh=30m&kiosk&from=1582543232156&to=1582629632156&panelId=2&fullscreen
        Refresh ist dort schon enthalten und der aktualisiert sich bei mir trotzdem nicht.
          @Uhula
          D
          D
          der-eine
          #90
          @Dominik-F bei mir sieht der link so aus:
          http://192.168.178.51:3000/d/BFQXFoQZz/raume?orgId=1&from=1582794576508&to=1582880976508&panelId=10&fullscreen&kiosk&theme=dark&refresh=1m
          und er wird auch aktualisiert.
          • mrFenyxM mrFenyx
            @Bastelritius Hi, wenn du ioBroker.vis-material benutzt dann bitte deinstallieren. Es benutzt eine alte Version von MDUI und macht alles durcheinander.
            BastelritiusB
            BastelritiusB
            Bastelritius
            #91
            @mrFenyx: Danke, ich glaube das war es. Dann kann ich ja mal etwas rumprobieren.
            • Stefan GlückS
              Stefan GlückS
              Stefan Glück
              schrieb am zuletzt editiert von Stefan Glück
              #92
              hallo,
              ich würde gerne deine 2 Demo Projekte importieren, bekomme aber immer wieder fehlermeldungen:
              hat vielleicht jemand eine idee für mich?
              danke
              edit: funktioniert. da hatte ich beim Download ein Problem
              • Stephan SchleichS
                Stephan SchleichS
                Stephan Schleich
                #93
                Ich hab ein Problem mit der v2.1.1 23.02.2020, und zwar lassen sich dadurch iframes nicht mehr verschieben.
                Eine andere Frage noch am Rande, ersetzte ich meinen Script Baustein komplett durch deinen oder füge ich den nur dazu, was bewirken diese eigentlic, vor allem was ist wenn ich deins mal wieder lösche und mein altes nicht mehr habe, kommt es dann zu Problemen?
                UhulaU 1 Antwort Letzte Antwort
                • Stefan GlückS Stefan Glück
                  hallo,
                  danke
                  Dominik F.D
                  Dominik F.D
                  Dominik F.
                  #94
                  @Stefan-Glück
                  hast du dir das Projekt als Zip Datei heruntergeladen und dann versucht diese ZIP Datei zu importieren?
                  @Stephan-Schleich
                  Wenn du ein eigenes CSS Skript geschrieben hast, dann kann es natürlich zu Problemen kommen, muss aber nicht unbedingt je nachdem was du gezaubert hast. Du legst ja selber fest wann du was vom Skript nutzt oder nicht.
                  Uhulas Projekt ist darauf ausgelegt, dass du sein CSS Script und das Script dazu nutzt. Dieses bewirkt optische Veränderungen verschiedener Widgets und viele Anpassungsmöglichkeiten. Wenn du seins löscht und deine Vis auf seiner CSS aufgebaut hast, dann kommt es auf jedenfall zu optischen Problemen und vieles wird nicht mehr funktionieren bzw sehr komisch aussehen. Ich bin mir aber auch nicht sicher ob ich deiner letzte Frage richtig verstanden habe :D
                  Stephan SchleichS 1 Antwort Letzte Antwort
                    @Stefan-Glück
                    @Stephan-Schleich
                    Stephan SchleichS
                    Stephan SchleichS
                    Stephan Schleich
                    #95
                    @Dominik-F Danke für die Infos.
                    Ich hab den CSS und Script Code einfach in mein Projekt kopiert. Unter Script steht z.b. schon was drin wenn ich das lösche verändert sich auch nichts ob gut oder schlecht weiß ich nicht, hab dort bisher nie was gemacht, deswegen wusst ich nicht ob überschreiben oder dazu kopieren.
                    gehen bei dir denn die iframes wenn du neue hinzufügst?
                    • Stephan SchleichS Stephan Schleich
                      Dominik F.D
                      Dominik F.D
                      Dominik F.
                      #96
                      @Stephan-Schleich
                      Ich hab bisher noch eine ältere Version laufen und bin da selber mit den Iframes und Grafana am rumprobieren. Ich konnte bisher aber die Iframes problemlos einfügen.
                        UhulaU
                        UhulaU
                        Uhula
                        #97
                        @Stephan-Schleich Wenn du mit "nicht verschieben" meinst, dass du die iframes nicht mehr per Klick auswählen kannst, dass Problem habe ich auch manchmal. Du kannst es aber immer über "Widgets | Aktives Widget" aus der Widgetliste auswählen. Eine Ursache kenne ich nicht, das Script scheidet aus, da es im vis Editor nicht ausgeführt wird;: evtl. eine CSS Anweisung, muss ich mal suchen.
                        • mrFenyxM
                          mrFenyxM
                          mrFenyx
                          #98
                          Hi, kann ich in tnav ein widget haben das nicht wie alle andere aligned sind sondern, z.B. ganz rechts? Die wären auch keine navitems.
                          • mrFenyxM mrFenyx
                            UhulaU
                            UhulaU
                            Uhula
                            #99
                            @mrFenyx Klar, du musst es mit "mdui-noflex" nur aus der flex-Anordnung rausnehmen, dann kannst du es beliebig positionieren, z.B. mit: left=calc(100% - 40px). Kann auch weiterhin ein "mdui-navitem" sein, muss aber nicht.
                            [{"tpl":"tplJquiIconNav","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"class":"mdui-navitem  mdui-noflex ","text":"<i class='material-icons'>help</i>","nav_view":"pageDemoEx1","g_last_change":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"calc(100% - 40px)","top":"0px","width":"40px","height":"39px","position":""},"widgetSet":"jqui"}]
                            mrFenyxM jpgorganizerJ 2 Antworten Letzte Antwort
                            • T
                              T
                              Tirador
                              #100
                              ich probiere nun auch meine ersten Gehversuche.
                              Dabei versuche ich die "Grid-Struktur" mit mdui-cols-n umzusetzen.
                              Ich hätte gerne das Responsive Design so, dass es sowohl im Quer- als auch Hochformat gut aussieht.
                              Mein Handy hat die folgende Auflösung:
                              • 396px im Hochformat
                              • 766px im Querformat
                              Im Hochformat passt prinzipiell nur eine Card auf den Schirm. Im Querformat könnte man zwei nebeneinander packen.
                              Muss ich dann alles auf den kleinsten gemeinsamen Nenner ausrichten, d.h. 766 / 2 = 383 px?
                              Ich habe gesehen das es im CSS für jede mdui-col-x Breite ein min-width und ein max-width gibt.
                              Oder muss ich dann max-width auf 396 px einstellen und min-width auf 383 px?
                              Die weitere Verkomplizierung.
                              Es gibt nun noch ein Tablet, dass ich mit dem gleichen Design füttern wollen würde.
                              Das Tablet hat die folgende Auflösung:
                              • 587px im Hochformat
                              • 939px im Querformat
                              Ist das überhaupt mit einem responsive Design alles unter einen Hut zu zaubern?
                              • T Tirador
                                Dominik F.D
                                Dominik F.D
                                Dominik F.
                                #101
                                @Tirador
                                Du musst dann mdui-cols-4-toc-5 einstellen, dann passt sich die Breite automatisch auf 320px-400px an. Beim quer sollten die sich dann nebeneinander anordnen. Du musst immer vom kleinsten ausgehen.
                                • UhulaU Uhula
                                  mrFenyxM
                                  mrFenyxM
                                  mrFenyx
                                  #102
                                  @Uhula Super, danke! 👍
                                  • mrFenyxM mrFenyx
                                    B
                                    B
                                    BoehserWolf
                                    schrieb am zuletzt editiert von BoehserWolf
                                    #103
                                    @Uhula
                                    Habe ein Problem mit dem Importieren der "Einstellungen" cards aus MD_Demo in MD_Simple.
                                    Die Idee war:
                                    • Export/Import der entsprechenden Cards aus MD_Demo, also cardConfig, cardConfigCards, cardConfigColors in ein neues Projekt auf Basis von MD_Simple
                                    • sowie Export/Import des nötigen Einstellungen Widgets aus lnav
                                    • Einstellungen im neuen Projekt nutzen
                                    Das haut leider nicht hin, die Einstellungen lassen sich nicht anpassen, es passiert einfach nichts im neuen Projekt.
                                    Habe ich parallel das importierte MD_Demo Projekt in einem anderen Browser Tab auf, werden die Einstellungen dieses Projekts angepasst.
                                    Alles klar dachte ich, dann ändere ich die Bezeichnungen der Object IDs in den Widgets von cardConfigCards, cardConfigColors von demo_config_xxx in einen anderen Namen.
                                    Bspw. in cardConfigCards das Widget zur Card-Darstell. hat als Object ID "demo_card_title_color", also geändert in "proj_card_title_color". Das habe ich analog für alle Widgets in den entsprechenden Cards vorgenommen. Dann kann ich jedoch nichts mehr konfigurieren.
                                    Habe schon alles Mögliche probiert um das zum Laufen zu bringen...
                                    Bin für jeden Tipp dankbar.
                                    Hinweis am Rande: Ein Verweis auf eine Übersicht aller Material Design Icons habe ich hier gefunden. Würde vorschlagen einen Hinweis in github zu setzen. Dann hat man schnell die Übersicht über die Icons gefunden ohne lange googeln zu müssen.
                                    P UhulaU 2 Antworten Letzte Antwort
                                    • B BoehserWolf
                                      @Uhula
                                      Die Idee war:
                                      P
                                      P
                                      Pittini
                                      #104
                                      @BoehserWolf sagte in [Projekt] Material Design CSS v2:
                                      Die Idee war:
                                      Was in Deiner Auflistung auf jeden Fall fehlt sind die 3 Blöcke aus der abar. Hol die mal noch aus der MD_Demo rüber, dann sollte es klappen. Hab das auch in nem Projekt so gemacht und grundsätzlich klappt das auch.
                                      • P Pittini
                                        Die Idee war:
                                        B
                                        B
                                        BoehserWolf
                                        #105
                                        @Pittini
                                        Funktioniert einwandfrei bis auf das Select für Primary Color. Das Select reagiert einfach mal gar nicht. Da noch ne Idee?
                                        P 1 Antwort Letzte Antwort
                                        • B BoehserWolf
                                          @Pittini
                                          P
                                          P
                                          Pittini
                                          #106
                                          Da noch ne Idee?
                                          Beim ändern der Namen vertippt oder einen Eintrag vergessen? Entweder im Config Dialog, in einem der 3 abar Blöcke oder im Css.
                                          84.2k
