  4. [gelöst] Stromzähler B+G SDM630:Modbus RS 485/USB + mqtt ?
sdm630modbus adapter
144 Beiträge 11 Kommentatoren 40.5k Aufrufe 12 Beobachtet
  • P Offline
    panki2
    #69
    Hallo, back again.
    Ich habe nun Version 3.0.0 installiert
    Nun kommt eine "Reaktion, welche ich aber nicht interpretieren kann.
    putty Konsole:
    • debug: modbus.0 (5868) Poll device 1
      2020-02-21 20:47:36.030 - debug: modbus.0 (5868) Poll holdingRegs DevID(1) address 48 - 6 bytes
      2020-02-21 20:47:36.066 - error: modbus.0 (5868) Wrong CRC for frame: 0,1,3,12,0,0,0,0
      2020-02-21 20:47:36.082 - error: modbus.0 (5868) unknown function code: 0
      2020-02-21 20:47:41.038 - warn: modbus.0 (5868) Error: undefined
      2020-02-21 20:47:41.039 - error: modbus.0 (5868) Request timed out.
      2020-02-21 20:47:41.042 - warn: modbus.0 (5868) Poll error count: 1 code: {"err":"timeout"}
      2020-02-21 20:47:42.043 - info: modbus.0 (5868) Disconnected from slave
      2020-02-21 20:47:42.052 - debug: modbus.0 (5868) Clearing timeout of the current request.
      2020-02-21 20:47:42.055 - debug: modbus.0 (5868) Cleaning up request fifo.
      2020-02-21 20:48:42.046 - debug: modbus.0 (5868) connect to serial /dev/ttyUSB0 with 9600
      2020-02-21 20:48:42.054 - info: modbus.0 (5868) Connected to slave
      2020-02-21 20:48:42.056 - debug: modbus.0 (5868) Poll device 1
      2020-02-21 20:48:42.058 - debug: modbus.0 (5868) Poll holdingRegs DevID(1) address 48 - 6 bytes
      2020-02-21 20:48:47.062 - warn: modbus.0 (5868) Error: undefined
      2020-02-21 20:48:47.064 - error: modbus.0 (5868) Request timed out.
      2020-02-21 20:48:47.066 - warn: modbus.0 (5868) Poll error count: 2 code: {"err":"timeout"}
      2020-02-21 20:48:48.067 - info: modbus.0 (5868) Disconnected from slave
      2020-02-21 20:48:48.074 - debug: modbus.0 (5868) Clearing timeout of the current request.
      2020-02-21 20:48:48.084 - debug: modbus.0 (5868) Cleaning up request fifo.
      2020-02-21 20:49:48.072 - debug: modbus.0 (5868) connect to serial /dev/ttyUSB0 with 9600
    • P Offline
      panki2
      #70
      . es kommen aber nicht immer die selben Reaktionen:
      • debug: modbus.0 (4883) Poll device 1
        2020-02-21 20:38:28.353 - debug: modbus.0 (4883) Poll holdingRegs DevID(1) address 48 - 2 bytes
        2020-02-21 20:38:28.395 - debug: modbus.0 (4883) Poll holdingRegs DevID(1) address 30001 - 2 bytes
        2020-02-21 20:38:28.424 - error: modbus.0 (4883) Wrong CRC for frame: 0,1,3,4,0,0,0,0
        2020-02-21 20:38:33.398 - warn: modbus.0 (4883) Error: undefined
        2020-02-21 20:38:33.399 - error: modbus.0 (4883) Request timed out.
        2020-02-21 20:38:33.401 - warn: modbus.0 (4883) Poll error count: 1 code: {"err":"timeout"}
        2020-02-21 20:38:34.402 - info: modbus.0 (4883) Disconnected from slave
        2020-02-21 20:38:34.413 - debug: modbus.0 (4883) Clearing timeout of the current request.
        2020-02-21 20:38:34.415 - debug: modbus.0 (4883) Cleaning up request fifo.
        2020-02-21 20:39:34.407 - debug: modbus.0 (4883) connect to serial /dev/ttyUSB0 with 9600
        2020-02-21 20:39:34.415 - info: modbus.0 (4883) Connected to slave
      • wendy2702W Offline
        wendy2702W Offline
        #71
        @panki2 sagte in Stromzähler B+G E-Tech SDM630Modbus V2 via RS 485 /USB ?:
        address 48
        Lösche mal das Register mit Adresse 48 und zeige dann mal das log.
        P 1 Antwort Letzte Antwort
        • wendy2702W wendy2702
          address 48
          panki2
          #72
          @wendy2702 jetzt sind alle holding Register im iobroker "leer", also keine Einträge.
          Hast Du das so gemeint?
          2020-02-21 21:14:23.169 - info: host.raspberrypi instance system.adapter.modbus.0 started with pid 8483
          2020-02-21 21:14:24.769 - debug: modbus.0 (8483) Redis Objects: Use Redis connection: 127.0.0.1:9001
          2020-02-21 21:14:24.834 - debug: modbus.0 (8483) Objects client ready ... initialize now
          2020-02-21 21:14:24.843 - debug: modbus.0 (8483) Objects create System PubSub Client
          2020-02-21 21:14:24.845 - debug: modbus.0 (8483) Objects create User PubSub Client
          2020-02-21 21:14:24.847 - debug: modbus.0 (8483) Objects client initialize lua scripts
          2020-02-21 21:14:24.867 - debug: modbus.0 (8483) Objects connected to redis: 127.0.0.1:9001
          2020-02-21 21:14:24.892 - debug: modbus.0 (8483) objectDB connected
          2020-02-21 21:14:24.897 - debug: modbus.0 (8483) Redis States: Use Redis connection: 127.0.0.1:9000
          2020-02-21 21:14:24.909 - debug: modbus.0 (8483) States create User PubSub Client
          2020-02-21 21:14:24.914 - debug: modbus.0 (8483) States create System PubSub Client
          2020-02-21 21:14:24.926 - debug: modbus.0 (8483) States connected to redis: 127.0.0.1:9000
          2020-02-21 21:14:24.928 - debug: modbus.0 (8483) statesDB connected
          2020-02-21 21:14:25.302 - info: sql.0 (1474) enabled logging of modbus.0.info.connection, Alias=false
          2020-02-21 21:14:25.343 - info: modbus.0 (8483) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.modbus, node: v10.18.1
          2020-02-21 21:14:25.585 - info: sql.0 (1474) disabled logging of modbus.0.info.pollTime
          2020-02-21 21:14:26.044 - debug: modbus.0 (8483) connect to serial /dev/ttyUSB0 with 9600
          2020-02-21 21:14:26.065 - info: modbus.0 (8483) Connected to slave
          2020-02-21 21:14:26.070 - info: modbus.0 (8483) Disconnected from slave
          2020-02-21 21:14:26.077 - debug: modbus.0 (8483) Cleaning up request fifo.
            wendy2702W Offline
            #73
            Nö,
            Du sollst einen Eintrag drin lassen.
            Laut einem deiner Post gibt es ja die Adresse 30001, oder?
            Teste mit der.
              Nö,
              Teste mit der.
              panki2
              #74
              @wendy2702 Sorry
              jetzt stehht wieder die Adresse 30001 drin
              Ergebnis
              2020-02-21 21:29:38.277 - debug: modbus.0 (9908) States create System PubSub Client
              2020-02-21 21:29:38.290 - debug: modbus.0 (9908) States connected to redis: 127.0.0.1:9000
              2020-02-21 21:29:38.292 - debug: modbus.0 (9908) statesDB connected
              2020-02-21 21:29:38.597 - info: sql.0 (1474) enabled logging of modbus.0.info.connection, Alias=false
              2020-02-21 21:29:38.635 - info: modbus.0 (9908) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.modbus, node: v10.18.1
              2020-02-21 21:29:38.922 - info: sql.0 (1474) disabled logging of modbus.0.info.pollTime
              2020-02-21 21:29:39.475 - debug: modbus.0 (9908) connect to serial /dev/ttyUSB0 with 9600
              2020-02-21 21:29:39.493 - info: modbus.0 (9908) Connected to slave
              2020-02-21 21:29:39.496 - debug: modbus.0 (9908) Poll device 1
              2020-02-21 21:29:39.500 - debug: modbus.0 (9908) Poll holdingRegs DevID(1) address 30001 - 2 bytes
              2020-02-21 21:29:39.534 - error: modbus.0 (9908) Wrong CRC for frame: 0,1,3,4,0,0,0,0
              2020-02-21 21:29:44.508 - warn: modbus.0 (9908) Error: undefined
              2020-02-21 21:29:44.509 - error: modbus.0 (9908) Request timed out.
              2020-02-21 21:29:44.512 - warn: modbus.0 (9908) Poll error count: 1 code: {"err":"timeout"}
              2020-02-21 21:29:45.513 - info: modbus.0 (9908) Disconnected from slave
              2020-02-21 21:29:45.521 - debug: modbus.0 (9908) Clearing timeout of the current request.
              2020-02-21 21:29:45.523 - debug: modbus.0 (9908) Cleaning up request fifo.
              • P panki2
                @wendy2702 Sorry
                Ergebnis
                wendy2702W Offline
                wendy2702W Offline
                #75
                Ich denke „Float Big Endian“ ist nicht richtig.
                Da solltest du mal von oben nach unten durch probieren. Ich weiß das es lästig ist aber wenn es nicht in der Anleitung steht und es im Netzt keine weitere Info gibt wird wohl kein weg daran vorbei führen.
                • P Offline
                  panki2
                  #76
                  Ich fange damit leider nicht viel an:
                  Vielleicht hilft es einem FAchmann weiter
                  modbus protokoll SDM630V2
                  https://bg-etech.de/download/manual/SDM630Register1-5.pdf
                    panki2
                    #77
                    @wendy2702 said in Stromzähler B+G E-Tech SDM630Modbus V2 via RS 485 /USB ?:
                    Was schreibe ich bei Faktor, Länge und Offset rein?
                      wendy2702W Offline
                      #78
                      Faktor und Offset sind erstmal uninteressant.
                      Länge 1 oder 2 ohne in das PDF geschaut zu haben.
                      Ist je nach Einstellung (Float, Signed. Etc) aber eh fest gelegt.
                      • P Offline
                        panki2
                        #79
                        Ich habe jetzt alle float, endian von oben nach unten usw durch.
                        ..geändert,
                        grüner Haken und
                        Speichern und dann in putty geschaut. immer wrong CRC....
                          wendy2702W Offline
                          #80
                          Float Big Endian mal mit Länge 2 versucht?
                          Bin nur am IPad und kann selber nicht schauen bei mir.
                            panki2
                            #81
                            Ja, Länge 2
                            Value ist richtig bei "Rolle"?
                              wendy2702W Offline
                              #82
                              Value passt.
                              Hast du auch Float BIG Endian Byte und Word Swap probiert?
                                Value passt.
                                panki2
                                schrieb am zuletzt editiert von panki2
                                #83
                                Ich habe alle von oben nach unten durchexerziert...
                                aber auf Länge usw nicht geachtet
                                • P panki2
                                  wendy2702W Offline
                                  wendy2702W Offline
                                  #84
                                  @panki2 ich schaue mal ins PDF...
                                  Nur leider heute nicht mehr.
                                    panki2
                                    #85
                                    @wendy2702
                                    Ok, lieb von Dir. Ist egal, es kommt da uf einen Tag nicht drauf an.
                                    Ich spiel dann mal mit den anderen adaptern rum. Wetterstation, google home usw. Da tut wenigstens etwas..
                                    Also vielen DAnk für Deine Mühe bisher...
                                      wendy2702W Offline
                                      #86
                                      Hier https://wiki.volkszaehler.org/hardware/channels/meters/power/eastron_sdm630_modbus
                                      Gibt es noch einen Hinweis zum BUS. Pull UP/Down und Abschluß erforderlich.
                                      Auch sind die Anschlüsse wohl verdreht.
                                      Hier mal lesen und scrollen. Steht auch mit Bild etwas bezüglich BUS Anbindung:
                                      https://github.com/gonium/gosdm630
                                        panki2
                                        #87
                                        Die Abschlusswiderstände habe ich, die pullup and down nicht, da auf youtube andere User mit dem SDM 630 nur mit Abschlusswiderständen mit normalen Klingeldraht erfolgreich waren..
                                        Ich lese mir das nochmal durch. Kabel hatte ich schon vertauscht (Anschlüsse)
                                          dimaiv
                                          schrieb am zuletzt editiert von dimaiv
                                          #88
                                          Hier How To wie ich das gemacht habe:
                                          1. Das hier Runterladen :
                                            https://github.com/letscontrolit/ESPEasy/releases/download/mega-20200204/ESPEasy_mega-20200204.zip
                                          Entpacken
                                          Markierte Datei auf ESP flashen
                                          1. MQTT Broker in IoBroker installieren.
                                          2. ESPEasy Einstellungen:
                                          ioBroker- NUC8i3 / Proxmox / VM
                                          Node.js v22.21.0
                                          NPM v10.9.4
                                          JS controller 7.1.0
                                          Admin 7.7.20
                                          ZigBee Adapter 3.3.1alpha.0
                                          Zigbee LAN Gateway CC2652P
                                          Zigbee Firmware 20250321
                                          P 3 Antworten Letzte Antwort
