  4. ioBroker in Proxmox VM startet nicht
iobroker proxmox
37 Beiträge 8 Kommentatoren 5.4k Aufrufe 5 Beobachtet
  • moppel2810M moppel2810
    @Homoran
    0 info it worked if it ends with ok
    1 verbose cli [ '/usr/bin/node',
    1 verbose cli   '/usr/bin/npm',
    1 verbose cli   'i',
    1 verbose cli   'iobroker',
    1 verbose cli   '--loglevel',
    1 verbose cli   'error' ]
    2 info using npm@6.11.3
    3 info using node@v10.17.0
    4 verbose npm-session a5e0904b88ae8b94
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 silly fetchPackageMetaData error for iobroker@latest The value "4294967295" is invalid for option "family"
    8 timing stage:rollbackFailedOptional Completed in 13ms
    9 timing stage:runTopLevelLifecycles Completed in 1373ms
    10 verbose stack TypeError [ERR_INVALID_OPT_VALUE]: The value "4294967295" is invalid for option "family"
    10 verbose stack     at lookup (dns.js:112:11)
    10 verbose stack     at net.js:1004:5
    10 verbose stack     at defaultTriggerAsyncIdScope (internal/async_hooks.js:294:19)
    10 verbose stack     at lookupAndConnect (net.js:1003:3)
    10 verbose stack     at TLSSocket.Socket.connect (net.js:938:5)
    10 verbose stack     at Object.connect (_tls_wrap.js:1165:13)
    10 verbose stack     at HttpsAgent.createConnection (https.js:120:22)
    10 verbose stack     at HttpsAgent.createSocket (/usr/lib/node_modules/npm/node_modules/agentkeepalive/lib/_http_agent.js:265:26)
    10 verbose stack     at HttpsAgent.createSocket (/usr/lib/node_modules/npm/node_modules/agentkeepalive/lib/agent.js:77:11)
    10 verbose stack     at HttpsAgent.addRequest (/usr/lib/node_modules/npm/node_modules/agentkeepalive/lib/_http_agent.js:239:10)
    10 verbose stack     at new ClientRequest (_http_client.js:249:16)
    10 verbose stack     at request (https.js:289:10)
    10 verbose stack     at fetch.Promise (/usr/lib/node_modules/npm/node_modules/node-fetch-npm/src/index.js:54:17)
    10 verbose stack     at new Promise (<anonymous>)
    10 verbose stack     at fetch (/usr/lib/node_modules/npm/node_modules/node-fetch-npm/src/index.js:41:10)
    10 verbose stack     at retry (/usr/lib/node_modules/npm/node_modules/make-fetch-happen/index.js:332:14)
    11 verbose cwd /opt/iobroker
    12 verbose Linux 4.19.0-6-amd64
    13 verbose argv "/usr/bin/node" "/usr/bin/npm" "i" "iobroker" "--loglevel" "error"
    14 verbose node v10.17.0
    15 verbose npm  v6.11.3
    16 error code ERR_INVALID_OPT_VALUE
    17 error The value "4294967295" is invalid for option "family"
    18 verbose exit [ 1, true ]
    das wäre jetzt der loginhalt
    HomoranH Offline
    HomoranH Offline
    @moppel2810
    Gut - da haben wir die ganzen Infos auf einen Schlag ;-)
    @moppel2810 sagte in ioBroker in Proxmox VM startet nicht:
    12 verbose Linux 4.19.0-6-amd64 13 verbose argv "/usr/bin/node" "/usr/bin/npm" "i" "iobroker" "--loglevel" "error" 14 verbose node v10.17.0 15 verbose npm v6.11.3
    Der Fehler ist der selbe - keine weiteren Informationen :-(
    Die Suche danach 4294967295" is invalid for option "family"
    ergibt einen Treffer - https://forum.iobroker.net/topic/12605/nodejs-und-npm-update/109
    Sieh mal ob du da etwas für dich ableiten kannst
    moppel2810M 1 Antwort Letzte Antwort
      @moppel2810
      moppel2810M Offline
      moppel2810M Offline
      moppel2810
      @Homoran
      ich glaube mittlerweile das es doch am proxmox liegt. Ich hab jetzt alles probiert...
      Ich installiere die vm mit Debian und muss aber beim erstellen siehe Bild 4.JPG diese Einstellung wählen das ich iobroker installieren kann hab ich irgendwo gelesen aber damit schlägt die automatische Netzwerkkonfig fehl und ich bekomm auch nichts manuell hin. Wenn ich aber diese 5.JPG Einstellung wähle läuft das Netzwerk aber da funktioniert eben die Installation vom iobroker nicht.
      Ich bin hier nach über einer Woche echt am ENDE😞
      HomoranH crunchipC 3 Antworten Letzte Antwort
        @Homoran
        HomoranH Offline
        HomoranH Offline
        @moppel2810 Seltsam ich habe die Intel E1000 als Netzwerkkarte
          @Homoran
          crunchipC Offline
          crunchipC Offline
          @moppel2810 das Problem hatte ich auch mit meinem alten HP Thin610. Komm nur grad nicht drauf, was ich da damals eingestellt hatte. Ist schon ne weile her.
          Wenn mich nicht alles täuscht, hat @ostseereiter nen Hp mit Proxmox laufen, vllt weiss er was
            moppel2810M Offline
            moppel2810M Offline
            moppel2810
            @crunchip das wäre super! ich bin echt am verzweifeln😞
            ostseereiterO 1 Antwort Letzte Antwort
              ostseereiterO Offline
              ostseereiter
              @moppel2810 Ich habe zwar einen HP aber der läuft autark kein Proxmox drauf nur der Iobroker.
              Gruß OSR
              Plattform
                @Homoran
                crunchipC Offline
                crunchipC Offline
                @moppel2810 also, wie Homoran schon schrieb, mit der Intel E1000 sollte es eigentlich funktionieren, siehe
                Vllt fehlt auch irgendein Treiber, bei der Buster Installation, gab es da Hinweise beim Installieren?
                du könntest auch mal Debian 9 probieren.
                Alternativ wäre die Option, statt einer VM, einen LXC zu erstellen, der müsste dann definitiv laufen. Ist aber wiederum eine Entscheidung, zwecks Bluetooth/ Usb Stick/Zigbee, da das einbinden, etwas umfangreicher ist.
                • ostseereiterO ostseereiter
                  moppel2810M Offline
                  moppel2810M Offline
                  moppel2810
                  @ostseereiter hast du da debian als System drauf? Ich überlege auch ob ich proxmox weg lasse da ich das System eh nur als iobroker nutzen möchte. Hast du conbee stick oder ähnliches auch eingebunden? Wie läuft das?
                    moppel2810M Offline
                    moppel2810M Offline
                    moppel2810
                    @crunchip debian 9 könnte ich mal probieren. Fehlermeldungen kamen keine bei der debian Installation.
                      anna
                      hat zwar mit dem Ursprungspost nichts zu tun, aber ich habe das gleiche Problem wie @moppel2810. Gibt es hier schon eine Lösung?
                      Proxmox 5.4-13 auf einem alten Laptop,
                      ioBroker läuft schon länger im Container. Wegen eines BT-Sticks wollte ich mit ioBroker jetzt aber auf eine VM umziehen - klappt nicht.
                      Habe es mit Debian 10.3 und 9.12, der Anleitung und in sämtlichen Kombinationen mit node 8, 10 und 12 versucht.
                      Bei Debian 10.13 und node 10 scheint alles erstmal okay bis zur Installation von iobroker:
                      io@iobroker:~$ node -v
                      v10.19.0
                      io@iobroker:~$ nodejs -v
                      v10.19.0
                      io@iobroker:~$ npm -v
                      6.13.4
                      io@iobroker:~$ curl -sL https://iobroker.net/install.sh | bash -
                      library: loaded
                      Library version=2020-01-30
                          Welcome to the ioBroker installer!
                          Installer version: 2020-01-25
                          You might need to enter your password a couple of times.
                          Installing prerequisites (1/4)
                      [sudo] Passwort für io:
                      Ign:1 http://ftp.de.debian.org/debian stretch InRelease
                      Holen:2 http://security.debian.org/debian-security stretch/updates InRelease [94,3 kB]
                      OK:3 http://ftp.de.debian.org/debian stretch-updates InRelease
                      OK:4 http://ftp.de.debian.org/debian stretch Release
                      OK:5 https://deb.nodesource.com/node_10.x stretch InRelease
                      Es wurden 94,3 kB in 16 s geholt (5.854 B/s).
                      Changing npm registry to https://registry.npmjs.org
                      Installed acl
                      Installed libcap2-bin
                      Installed gcc-c++
                      Installed libavahi-compat-libdnssd-dev
                      Installed libudev-dev
                      Installed libpam0g-dev
                      Installed git
                      Installed unzip
                      Installed python-dev
                          Creating ioBroker user and directory (2/4)
                      User iobroker created
                      Directory /opt/iobroker created
                          Installing ioBroker (3/4)
                      npm ERR! code ERR_INVALID_OPT_VALUE
                      npm ERR! The value "4294967295" is invalid for option "family"
                      npm ERR!     /home/io/.npm/_logs/2020-02-20T15_32_13_579Z-debug.log
                          Finalizing installation (4/4)
                      Enabling autostart...
                      Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
                      Autostart enabled!
                          ioBroker was installed successfully
                          Open http://192.168.178.239:8081 in a browser and start configuring!
                      You need to re-login before doing anything else on the console!
                      Log /home/io/.npm/_logs/2020-02-20T15_32_13_579Z-debug.log
                      1 verbose cli   'i',
                      2 info using npm@6.13.4
                      3 info using node@v10.19.0
                      4 verbose npm-session 0b4dc7a080c86c84
                      8 timing stage:rollbackFailedOptional Completed in 38ms
                      9 timing stage:runTopLevelLifecycles Completed in 2119ms
                      10 verbose stack     at new ClientRequest (_http_client.js:258:16)
                      12 verbose Linux 4.9.0-12-amd64
                      14 verbose node v10.19.0
                      15 verbose npm  v6.13.4
                      Bei Debian 9 mit node 10 gibt's den gleichen Fehler wie oben, bei Debian 9 mit node 8:
                      v8.17.0
                      v8.17.0
                      6.13.4
                      library: loaded
                      OK:1 http://security.debian.org/debian-security stretch/updates InRelease
                      Ign:2 http://ftp.de.debian.org/debian stretch InRelease
                      OK:5 https://deb.nodesource.com/node_8.x stretch InRelease
                      Installed acl
                      Installed gcc-c++
                      Installed git
                      Installed unzip
                      npm ERR! Invalid argument: family must be 4 or 6
                      npm ERR!     /home/io/.npm/_logs/2020-02-20T16_54_53_481Z-debug.log
                      Autostart enabled!
                          Open http://192.168.178.240:8081 in a browser and start configuring!
                      Log /home/io/.npm/_logs/2020-02-20T16_54_53_481Z-debug.log
                      1 verbose cli   'i',
                      3 info using node@v8.17.0
                      4 verbose npm-session 4e4798bb54b8d9d9
                      7 silly fetchPackageMetaData error for iobroker@latest Invalid argument: family must be 4 or 6
                      8 timing stage:rollbackFailedOptional Completed in 21ms
                      9 timing stage:runTopLevelLifecycles Completed in 2044ms
                      10 verbose stack TypeError: Invalid argument: family must be 4 or 6
                      10 verbose stack     at lookup (dns.js:129:11)
                      10 verbose stack     at net.js:1091:5
                      10 verbose stack     at defaultTriggerAsyncIdScope (internal/async_hooks.js:281:19)
                      10 verbose stack     at lookupAndConnect (net.js:1090:3)
                      10 verbose stack     at TLSSocket.Socket.connect (net.js:1025:5)
                      10 verbose stack     at Object.exports.connect (_tls_wrap.js:1088:12)
                      10 verbose stack     at HttpsAgent.createConnection (https.js:117:22)
                      10 verbose stack     at new ClientRequest (_http_client.js:268:16)
                      10 verbose stack     at Object.request (http.js:39:10)
                      10 verbose stack     at request (https.js:245:15)
                      14 verbose node v8.17.0
                      16 error Invalid argument: family must be 4 or 6
                      17 verbose exit [ 1, true ]
                      • A anna
                        v10.19.0
                        v10.19.0
                        6.13.4
                        library: loaded
                        Installed acl
                        Installed gcc-c++
                        Installed git
                        Installed unzip
                        Autostart enabled!
                        1 verbose cli   'i',
                        v8.17.0
                        v8.17.0
                        6.13.4
                        library: loaded
                        Installed acl
                        Installed gcc-c++
                        Installed git
                        Installed unzip
                        Autostart enabled!
                        1 verbose cli   'i',
                        crunchipC Offline
                        crunchipC Offline
                        @anna
                        @anna sagte in ioBroker in Proxmox VM startet nicht:
                        einem alten Laptop
                        welche iso hast du genommen?
                        Debian Buster erfordert node.js v10.x!!
                        v12 ist noch nicht "ausgereift" und sollte nicht unbedingt verwendet werden
                          @anna
                          einem alten Laptop
                          anna
                          @crunchip said in ioBroker in Proxmox VM startet nicht:
                          einem alten Laptop
                          Für die VM? debian-10.3.0-amd64-netinst.iso von debian.org und debian-9.12.0-amd64-netinst.iso
                          Hab ich da auch bemerkt 😆 Bei Debian 10 wird die Debian-Version von node 10 und nodejs ohne npm installiert, wenn man node 8 versucht zu installieren. Aber mit Debian 9 läuft node 8 ja noch. Fehlermeldung gab's bei der Iobroker-Installation ja dann trotzdem.
                          Im Container läuft node v8.16.0 / nodejs 8.16.0 / npm 6.4.1, deshalb der Versuch mit Debian 9 & node 8.
                          Eigentlich habe ich sämtliche Lösungsansätze ausprobiert, die Google so ausgespuckt hat. Ich glaube, es liegt am alten Laptop und probiere es einfach irgendwann nochmal, wenn mein System umgezogen ist... 🙄
                          • A anna
                            einem alten Laptop
                            crunchipC Offline
                            crunchipC Offline
                            @anna die Frage war eher wegen dem alten Laptop ob amd64 überhaupt geeignet ist.
