- ioBroker Community Home
- Deutsch
- Tester
- Test Adapter mihome-vacuum v2.0.x
wollte grade die aktuelle Version testen.
Leider kommt es zu folgenden Fehler:
canvas@2.6.1 install /opt/iobroker/node_modules/canvas
node-pre-gyp install --fallback-to-buildnode-pre-gyp WARN Using request for node-pre-gyp https download
node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.1/canvas-v2.6.1-node-v64-linux-glibc-arm.tar.gz
node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.1 and node@10.19.0 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
Package pixman-1 was not found in the pkg-config search path.
Perhaps you should add the directory containingpixman-1.pc' to the PKG_CONFIG_PATH environment variable No package 'pixman-1' found gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp gyp ERR! configure error gyp ERR! stack Error:gyp` failed with exit code: 1
gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
gyp ERR! stack at ChildProcess.emit (events.js:198:13)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
gyp ERR! System Linux 4.19.97-v7l+
gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
gyp ERR! cwd /opt/iobroker/node_modules/canvas
gyp ERR! node -v v10.19.0
gyp ERR! node-gyp -v v5.0.5
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
node-pre-gyp ERR! stack at ChildProcess.emit (events.js:198:13)
node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:982:16)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
node-pre-gyp ERR! System Linux 4.19.97-v7l+
node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
node-pre-gyp ERR! node -v v10.19.0
node-pre-gyp ERR! node-pre-gyp -v v0.11.0
node-pre-gyp ERR! not ok
npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! canvas@2.6.1 install:node-pre-gyp install --fallback-to-build
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the canvas@2.6.1 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.npm ERR! A complete log of this run can be found in:
npm ERR! /home/iobroker/.npm/_logs/2020-02-17T18_44_10_000Z-debug.logHardware ist ein RPI4
Nodejs 10.19.0Hat einer die neue Version schon auf dem RPI4 ans laufen bekommen?
Edit: Hab es mit dem Beitrag von Foxriver fixen können:
https://forum.iobroker.net/topic/26900/hinzufuegen-von-roomba-adapter-wirft-fehler/2@sabphil22 schau mal in der readme habe es gerade hinzugefügt
@AggroRalf das dropdown Menü ist nur ein Zwischenspeicher nach Auswahl des Gerätes werden die anderen Felder gesetzt. Die Liste der Geräte wird nur tämporär gespeichert da man nur ein aus der Liste braucht.
@Meistertr sagte in Test Adapter mihome-vacuum v2.0.x:
Ich habe nur ein Gerät zur Auswahl, allerdings wird, wenn ich es anklicke, der manuelle Bereich für den Token nicht gefüllt und speichern kann ich nicht, da kein Token eingetragen ist.
@sabphil22 ist es den das richtige gerät? steht der token mit im Dropdown drin ? Die Liste MUSS exact den angelegenten Geräten in der app entsprechen, da beide sie von der gleichen stelle abgreifen. Ist dies nicht der fall, ist wahrscheinlich der Server falsch
@Meistertr das Gerät, Token und Ip Adresse stimmen. Wenn ich auf "Get Devices" klicke wird das Gerät vorgeblendet. Auch wenn ich es nochmal im Dropdown anwähle, wird der Token in den manuellen Einstellungen nicht eingetragen.
@sabphil22 ok den Fall mit einem Gerät hatte ich noch nicht, schau ich mir morgen an
die 2.0.4 bringt soweit keine Fehler mehr.
Danke dafür!
Nun hakt es bei der aktuellen Karte bzw. map url.mihome-vacuum.0 2020-02-17 18:49:53.608 error (5783) Error when receiving mapurl
In VIS zeigt er noch die Karte von gestern vom 1 .Stock an.
Starte ich jetzt den Robbi im Erdgeschoss, dann wird in der App die aktuelle Karte angezeigt, in VIS bleibt aber die von gestern und es tut sich nichts.Log versuche ich zu bekommen beim nächsten Saugversuch.
@haselchen sagte in Test Adapter mihome-vacuum v2.0.x:
Danke dafür!
Bei mir kommt heute auch nur dieser Fehler.
2020-02-17 19:51:16.744 - [31merror [39m: mihome-vacuum.0 (19013) Error when receiving mapurlAllerdings sagt sogar die MiHome App dass sie Probleme hat Daten vom China Server zu erhalten. Also warte ich mal ab und gehe von einem Netzwerk Problem aus.
..:: So long! Tom ::..
Danke dafür!
Hab den DE Server.
Mitunter bekomme ich jetzt ab und zu wilde Fehlermeldungen.2020-02-17 19:40:42.807 - error: mihome-vacuum.0 (7751) Unknown state "mihome-vacuum.0.rooms.manual_1.mapIndex"
2020-02-17 19:42:05.670 - info: mihome-vacuum.0 (7751) create new room: manual_2
2020-02-17 19:43:04.001 - info: mihome-vacuum.0 (7751) create new room: manual_3
2020-02-17 19:43:48.096 - info: mihome-vacuum.0 (7751) create new room: manual_4Obwohl die Räume vorher auch so angelegt waren. Räume 2,3,4 wurden ja auch wie man sieht normal angelegt.
Und das kam mit der Version 2.0.5 als ich eine Raumreinigung gemacht habe, die auch normal ausgeführt wurde.
2020-02-17 19:56:48.393 - error: mihome-vacuum.0 (8437) TypeError: Cannot read property '0' of undefined
2020-02-17 19:56:50.698 - error: mihome-vacuum.0 (8437) TypeError: Cannot read property '0' of undefined
2020-02-17 19:56:52.983 - error: mihome-vacuum.0 (8437) TypeError: Cannot read property '0' of undefined
2020-02-17 19:56:55.230 - error: mihome-vacuum.0 (8437) TypeError: Cannot read property '0' of undefined
2020-02-17 19:56:57.485 - error: mihome-vacuum.0 (8437) TypeError: Cannot read property '0' of undefined
2020-02-17 19:56:59.792 - error: mihome-vacuum.0 (8437) TypeError: Cannot read property '0' of undefined
2020-02-17 19:57:02.041 - error: mihome-vacuum.0 (8437) TypeError: Cannot read property '0' of undefinedMit der Karte muss ich mal gucken wie das ist, wenn er wieder im 1.Stock war und dann wieder Erdgeschoss.
Aber ansonsten klasse Leistung von den Entwicklern.
Ich denke, dass sie nicht mehr weit vom perfekten MiHome-Vacuum Adapter weg sind!Synology DS218+ & 2 x Fujitsu Esprimo (VM/Container) + FritzBox7590 + 2 AVM 3000 Repeater & Homematic & HUE & Osram & Xiaomi, NPM 10.9.8, Nodejs 22.23.2 ,JS Controller 7.2.2 ,Admin 8.0.4
Da werden wir wohl ein debug log brauchen, so können wir damit leider nichts anfangen
@Patchwork-3001 du hast auch das canvas Problem, entweder manuell nachinstallieren oder ignorieren und die Kartenfunktion nicht nutzen
@dirkhe habe bis jetzt alles neu aufgesetzt habe es mir total zerschossen. würde halt schon gern die einzelnen zimmer räume nutzen wenn es geht
Was heisst zerschossen, ggf. Mal den adapter deinstallieren und dann wieder neu installieren.
@dirkhe hab solange rum probiert bis der ras4 nicht mehr die Web Oberfläche aufmachen wollte.
dann halt mehrfach versucht ein Backup wieder einzuspielen aber immer an unterschiedlichen punkten Fehler gehabt.
also zum Saturn ne jute micro sd geholt und sauber neu aufgespielt. läuft jetzt bis auf die neue für den robo s5 -
Also was klappt denn nicht? Wenn das installieren nicht klappt, gibt es hier im Forum genug Hinweise. Gestern habe ich sogar einen eigenen Thread dafür gesehen.
Wenn irgendeine Funktion nicht geht, am besten auf debug stellen und das dann hier Posten. -
Wenn irgendeine Funktion nicht geht, am besten auf debug stellen und das dann hier Posten.@dirkhe hat alles geklappt und läuft bis auf den Fehler mit GET DEVICES suchen was auch ein anderer hier schreibt man kann es anwählen mit Token und IP alles stimmt aber wenn man die Einstellung schlisst und wieder rein geht ist es wieder weg . sonst alles top Geräte Daten und mi Anmeldung geht. auch die Ordner Map und Rooms sind da. im Log steht (7615) Error when receiving mapurl.
mir fällt es schwer dem Thema zu folgen, weil mir irgendwie eine Übersicht der Vorraussetzungen für den Adapter fehlt. Es wäre schön wenn ihr eine kurze Übersicht im git erstellen könntet, welche Robo´s (Gen1, Gen 2 S6 usw) mit welcher Firmware (original und/oder Valetudo/RE) unterstützt werden bzw. welche Funktionen (Raumreinigung, Map, Token usw.) mit dem Adapter verfügbar sind.
Wäre das machbar?
Mfg
0018 -
@Patchwork-3001
das sieht bei mir genau so aus, ich habe den 1S. Die Karte wird nicht geladen (7615) Error when receiving mapurl.
Das hat aber definitiv schon mal funktioniert in der Version 2.0.3. -
@Patchwork-3001
Das hat aber definitiv schon mal funktioniert in der Version 2.0.3.@schmuh Habe auch den 1S und den Fehler. Demnach scheint da wirklich was nicht zu passen.
Mit 2.0.3 hatte ich nur das map64 Objekt, aber nie ein Wert in mapURL. Seit 2.0.4 habe ich beides nicht mehr. Bin aber von lokalen Netzwerkproblemen ausgegangen. Der 1S ließ sich aber normal über den Adapter steuern.@Meistertr Anscheinend ist da doch ein Bug in der 2.0.4/5.
Mit das geht nicht mehr seit... Oder ich habe diesen Fehler KANN ich NICHT arbeiten. ich brauche Debug logs damit ich sehe wo und wieso der Fehler auftritt man bedenke dass hier zich Roboter Versionen im Umlauf sind, nur weil alle die map anzeigen, heißt es nicht, dass es bei allen gleich ist.
Gerde bei Fehler ist es wichtig zu sehen was davor passiert ist.
@Meistertr
hier mein Debug Log, das läuft in einer "Endlosschleife"
mihome-vacuum.0 2020-02-18 16:05:07.476 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":126}<<< 21310050000000000f92f4f95e4bfd22797b48a4e87cd0b21a3689da7771ea72a22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a7a67 mihome-vacuum.0 2020-02-18 16:05:07.463 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:05:07.462 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd23317be043d7ddb25601d2b307ef8fa617b1fe25ea9a607e0212c58872dbb169bf8da15e6f6251190b54a3d4f533aa00b229ee224e5c2d7324b141f6a3981622db mihome-vacuum.0 2020-02-18 16:05:07.462 debug (951) sendMsg >>> {"id":126,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:05:07.461 debug (951) Timestamp: 5e4bfd23 mihome-vacuum.0 2020-02-18 16:05:07.460 debug (951) lastid{"get_status":121,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_ mihome-vacuum.0 2020-02-18 16:05:06.959 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":125}<<< 21310050000000000f92f4f95e4bfd2200429f85790c2132f2990b69289ac264a22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a67ad mihome-vacuum.0 2020-02-18 16:05:06.931 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:05:06.931 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd229fb00e06b44f383f42d5cd5dd08be0421be606cd7255ff2d7ffedd90a2fbbc8602007e90ac010eadc7e484a479a11c0b3a4318cad373bb14b6e91b67d4215dd4 mihome-vacuum.0 2020-02-18 16:05:06.931 debug (951) sendMsg >>> {"id":125,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:05:06.931 debug (951) Timestamp: 5e4bfd22 mihome-vacuum.0 2020-02-18 16:05:06.930 debug (951) lastid{"get_status":121,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_ mihome-vacuum.0 2020-02-18 16:05:06.430 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":124}<<< 21310050000000000f92f4f95e4bfd2144ab4ea92fbd95302932a07cb2b7cd53a22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477aa9f6 mihome-vacuum.0 2020-02-18 16:05:06.381 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:05:06.381 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd22d99f638762fb9127814e6c06ebe762eb250d6093fc26e3afc6b9ec2b98d0890bb6fb894189ff5942e2685405687a06a5e3a57ef874d63634f42535a284b3aa36 mihome-vacuum.0 2020-02-18 16:05:06.381 debug (951) sendMsg >>> {"id":124,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:05:06.381 debug (951) Timestamp: 5e4bfd22 mihome-vacuum.0 2020-02-18 16:05:06.380 debug (951) lastid{"get_status":121,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_ mihome-vacuum.0 2020-02-18 16:05:05.880 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":123}<<< 21310050000000000f92f4f95e4bfd217cc9682420235577a54fee04729768dda22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477ac9be mihome-vacuum.0 2020-02-18 16:05:05.871 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:05:05.871 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd21699543ddbebf6098b3453d0a344e90b47e3ec3ab7182660bff309f91ed4e241e4e310dfe31d1489a7cdaf36320d425f6f7854eb6acd3d41efbc5c784fe83588d mihome-vacuum.0 2020-02-18 16:05:05.870 debug (951) sendMsg >>> {"id":123,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:05:05.870 debug (951) Timestamp: 5e4bfd21 mihome-vacuum.0 2020-02-18 16:05:05.869 debug (951) lastid{"get_status":121,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_ mihome-vacuum.0 2020-02-18 16:05:05.368 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":122}<<< 21310050000000000f92f4f95e4bfd20272b3fd6148e3d77e613b18a3288b6e4a22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a81b8 mihome-vacuum.0 2020-02-18 16:05:05.315 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:05:05.315 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd213199792a502a6f409baeffe6de2c0d3a5406c7363edf87e5775855338d6592f39f9bf0b68e714e378c03ca76c0d91c48807a7634b7598447244dde83d7f60acc mihome-vacuum.0 2020-02-18 16:05:05.315 debug (951) sendMsg >>> {"id":122,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:05:05.315 debug (951) Timestamp: 5e4bfd21 mihome-vacuum.0 2020-02-18 16:05:05.314 debug (951) lastid{"get_status":121,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_ mihome-vacuum.0 2020-02-18 16:05:05.102 debug (951) Receive <<< {"result":[{"msg_ver":1,"msg_seq":2902,"state":8,"battery":100,"clean_time":3207,"clean_area":56722500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state mihome-vacuum.0 2020-02-18 16:05:05.089 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd21fcd3a444a1bc756117eddf3cefbbb81788b0ebd3841a95e6b31a4aa3e90961c5e84e41b73b6e3816680e53f6614e4387405e090b2087fa909abe46b4b37edfd4 mihome-vacuum.0 2020-02-18 16:05:05.089 debug (951) sendMsg >>> {"id":121,"method":"get_status"} mihome-vacuum.0 2020-02-18 16:05:05.088 debug (951) Timestamp: 5e4bfd21 mihome-vacuum.0 2020-02-18 16:05:05.088 debug (951) lastid{"get_status":121,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_ mihome-vacuum.0 2020-02-18 16:05:04.814 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":120}<<< 21310050000000000f92f4f95e4bfd20890fb9e4404f855d4d324a0d51494f13a22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477aee4b mihome-vacuum.0 2020-02-18 16:05:04.808 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:05:04.808 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd20b2e7ffdc18eb2e32d5912195a9aaadfdbe9b59fd8a06cd53ae6701b59d1d3726e25bc509c248047c906951b734d5ebf98a9ffd8564923bf5fd26ab7c50b32901 mihome-vacuum.0 2020-02-18 16:05:04.808 debug (951) sendMsg >>> {"id":120,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:05:04.807 debug (951) Timestamp: 5e4bfd20 mihome-vacuum.0 2020-02-18 16:05:04.807 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:05:04.306 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":119}<<< 21310050000000000f92f4f95e4bfd1f376dd073fd7b26b31bfcd0d7a2da0af0a22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a97c0 mihome-vacuum.0 2020-02-18 16:05:04.297 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:05:04.297 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd20a71561f77188680488a2ba68884906d0953a4a9e4f5c97298936ef3080c96dee06dedadcafbe4d99c4b8c0f6cbb112142df800a955f65efda194362f8f143f40 mihome-vacuum.0 2020-02-18 16:05:04.297 debug (951) sendMsg >>> {"id":119,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:05:04.297 debug (951) Timestamp: 5e4bfd20 mihome-vacuum.0 2020-02-18 16:05:04.296 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:05:03.796 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":118}<<< 21310050000000000f92f4f95e4bfd1fa66dbe49310ec142ded65d02dd3f3638a22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a6725 mihome-vacuum.0 2020-02-18 16:05:03.784 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:05:03.784 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd1f707afacc699776a6b4ae1b9e4a7594fd8725e69e96857dee6bf5dca3c7c018a77323153df39bbc892642aab4ddbe5d3b219d8fa779954274e4c7fc596d42f230 mihome-vacuum.0 2020-02-18 16:05:03.784 debug (951) sendMsg >>> {"id":118,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:05:03.784 debug (951) Timestamp: 5e4bfd1f mihome-vacuum.0 2020-02-18 16:05:03.783 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:05:03.283 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":117}<<< 21310050000000000f92f4f95e4bfd1ecd8187694312d5fe7858b325d791eb46a22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a49c2 mihome-vacuum.0 2020-02-18 16:05:03.274 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:05:03.274 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd1facda2f5fb915b858b50116e0f3e6cfd1bbb95b9cf51b4b98adfeb6ebe7133ac4033a7e09f417e756b4208a15f803d60c1bb66635411491ebff4a38f3ad552c49 mihome-vacuum.0 2020-02-18 16:05:03.274 debug (951) sendMsg >>> {"id":117,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:05:03.274 debug (951) Timestamp: 5e4bfd1f mihome-vacuum.0 2020-02-18 16:05:03.273 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:05:02.771 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":116}<<< 21310050000000000f92f4f95e4bfd1e702426d33b806ffd387ae1658e23a801a22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477ace8b mihome-vacuum.0 2020-02-18 16:05:02.765 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:05:02.765 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd1e141874dee59c183d73a9b266619172a7428732b01f383500a0c41121887913c03959a4867dfe52b2d250384606693c64f7df1ee09cbcb8993f2a10f78e7d2c47 mihome-vacuum.0 2020-02-18 16:05:02.765 debug (951) sendMsg >>> {"id":116,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:05:02.765 debug (951) Timestamp: 5e4bfd1e mihome-vacuum.0 2020-02-18 16:05:02.764 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:05:02.263 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":115}<<< 21310050000000000f92f4f95e4bfd1d1846d5c5ec33e0520767463305f2c647a22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477aef85 mihome-vacuum.0 2020-02-18 16:05:02.244 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:05:02.244 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd1e37c673f656f2f8b8c700fbf8fd0bdbe766e62af3f5fcfea189b9ad657c2b6c63de92cd46c3aa9b312c12af9de6a9ff9cb9d8939823b2082da1591ed9b015e19f mihome-vacuum.0 2020-02-18 16:05:02.244 debug (951) sendMsg >>> {"id":115,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:05:02.243 debug (951) Timestamp: 5e4bfd1e mihome-vacuum.0 2020-02-18 16:05:02.243 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:05:01.741 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":114}<<< 21310050000000000f92f4f95e4bfd1d839f8abc7ee98455b3e08a06d4776854a22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a2165 mihome-vacuum.0 2020-02-18 16:05:01.731 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:05:01.731 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd1d7725274ef002dce5eb68469e475ca29e534b17c794c589b88432d93d7b4ddea186683388d208816deede78a7bdca319f2badf687476f51678397407585dc56dd mihome-vacuum.0 2020-02-18 16:05:01.730 debug (951) sendMsg >>> {"id":114,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:05:01.730 debug (951) Timestamp: 5e4bfd1d mihome-vacuum.0 2020-02-18 16:05:01.730 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:05:01.228 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":113}<<< 21310050000000000f92f4f95e4bfd1c611a9cb6a0325b592ce301b568cc4db7a22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a3e8b mihome-vacuum.0 2020-02-18 16:05:01.219 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:05:01.219 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd1d6c783601c7e8a89139c3d6a850e4b7781b146bef709ce01bb280104b066044d147a7456b9795c2add78fc07ee99e01f7b49183b8012e42a027953289866154a5 mihome-vacuum.0 2020-02-18 16:05:01.219 debug (951) sendMsg >>> {"id":113,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:05:01.219 debug (951) Timestamp: 5e4bfd1d mihome-vacuum.0 2020-02-18 16:05:01.218 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:05:00.718 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":112}<<< 21310050000000000f92f4f95e4bfd1c5147c4fb78e70a8434c05461fe4f4e3da22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477af2ed mihome-vacuum.0 2020-02-18 16:05:00.708 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:05:00.708 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd1ca1414cf68cedc4ca76f0f1ecccadceb89c1bb8680584bcacd9dd525de50434e5ade32cf3f601a0bc8544bcf4f96cabefc290d23211c19c1c80865678081bdd0c mihome-vacuum.0 2020-02-18 16:05:00.708 debug (951) sendMsg >>> {"id":112,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:05:00.707 debug (951) Timestamp: 5e4bfd1c mihome-vacuum.0 2020-02-18 16:05:00.707 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:05:00.206 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":111}<<< 21310050000000000f92f4f95e4bfd1b22207754b86db0cf38c9c95bb8ca285ba22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477ab33b mihome-vacuum.0 2020-02-18 16:05:00.184 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:05:00.184 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd1c96d8cf34fecb63ea71cae8e62f079c0716d16fac259239dfb2a3ba91551ab8c7c491e77162d32cd0ef7aef3c9e360cc95e4328c24a3b6eb1b4be613870eb439b mihome-vacuum.0 2020-02-18 16:05:00.184 debug (951) sendMsg >>> {"id":111,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:05:00.184 debug (951) Timestamp: 5e4bfd1c mihome-vacuum.0 2020-02-18 16:05:00.183 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:59.683 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":110}<<< 21310050000000000f92f4f95e4bfd1b4cdcccfacc6c7d168abed033d287b0f3a22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a76e6 mihome-vacuum.0 2020-02-18 16:04:59.669 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:04:59.669 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd1bbb17ad33c99e68c5498fcc407b7dfe4fe4a02c794a1dca407d6fe5d06a6bfd0108126b2b24e03927540c5b33f1ae57ed64cdc13296ce9ffad33ffb51cc9d3e05 mihome-vacuum.0 2020-02-18 16:04:59.668 debug (951) sendMsg >>> {"id":110,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:59.668 debug (951) Timestamp: 5e4bfd1b mihome-vacuum.0 2020-02-18 16:04:59.668 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:59.167 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":109}<<< 21310050000000000f92f4f95e4bfd1a611752f42eae0ff87a0f78ba7416abeba22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a146b mihome-vacuum.0 2020-02-18 16:04:58.197 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:04:58.196 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd1a6973aca553173a64d011649d3d68241e9d56a13257d2b95d5f5dac72656fb62bb55b8adc6af517818852e092ff2952a6da2a8f241077f229bcde43370b31fc00 mihome-vacuum.0 2020-02-18 16:04:58.196 debug (951) sendMsg >>> {"id":109,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:58.196 debug (951) Timestamp: 5e4bfd1a mihome-vacuum.0 2020-02-18 16:04:58.196 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:57.695 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":108}<<< 21310050000000000f92f4f95e4bfd19cc79d605429fd6c1c6a6b46f9e2ce21ba22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a0d74 mihome-vacuum.0 2020-02-18 16:04:57.688 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:04:57.688 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd19f91f548a9a0980742cf439a74cd7e975392b138723a882d8edea826d8e2a52a9200412f49dabc0926e03777f8f543477afbda12bd6bbcdf4d199eb0d1493115b mihome-vacuum.0 2020-02-18 16:04:57.688 debug (951) sendMsg >>> {"id":108,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:57.687 debug (951) Timestamp: 5e4bfd19 mihome-vacuum.0 2020-02-18 16:04:57.687 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:57.186 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":107}<<< 21310050000000000f92f4f95e4bfd18814a5d5cc5b4eeba64287c9e3825ae0ea22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a53bd mihome-vacuum.0 2020-02-18 16:04:57.176 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:04:57.176 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd199c735d788db191306b69766b9305ef588d3b06bdb24e91ddbd3f2bb9e46bbea066ad0e1d7b554cc5d0e0bb00f623966eac0924dd95c235b71fe2f44bb122ec83 mihome-vacuum.0 2020-02-18 16:04:57.176 debug (951) sendMsg >>> {"id":107,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:57.176 debug (951) Timestamp: 5e4bfd19 mihome-vacuum.0 2020-02-18 16:04:57.175 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:56.674 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":106}<<< 21310050000000000f92f4f95e4bfd18d45f8cde824c871707717f865284301ea22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a1fe0 mihome-vacuum.0 2020-02-18 16:04:56.664 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:04:56.664 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd182a542865b0187f7f754a877c4e9e628bc730032765136f530e17243d311dab8f596f92032a57e68fa43484e800d39f3a2d687ea30cd070bd72bc6c4e6e9472dc mihome-vacuum.0 2020-02-18 16:04:56.664 debug (951) sendMsg >>> {"id":106,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:56.664 debug (951) Timestamp: 5e4bfd18 mihome-vacuum.0 2020-02-18 16:04:56.663 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:56.163 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":105}<<< 21310050000000000f92f4f95e4bfd17c2b461881f4801062af8276a17a3e6b7a22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a8ea7 mihome-vacuum.0 2020-02-18 16:04:56.153 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:04:56.153 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd18a50b59dfe35e5ebbd0f3508243d15de9b2017717ca09893d3abf80e7147f010e15d7de2bce1479ddbc34875a06a3aebd2accf9926496ed81334ad54778e27235 mihome-vacuum.0 2020-02-18 16:04:56.153 debug (951) sendMsg >>> {"id":105,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:56.152 debug (951) Timestamp: 5e4bfd18 mihome-vacuum.0 2020-02-18 16:04:56.152 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:55.650 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":104}<<< 21310050000000000f92f4f95e4bfd174b4b028ffce61f2adfae66ea1b1ea9dfa22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477afe63 mihome-vacuum.0 2020-02-18 16:04:55.641 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:04:55.640 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd1776380961c7984f781910cc2611c854a494b0ab6a1b100acd178df5754ea6959f039211b31c80110fce01faf69b56323f56f3cd876f4dd1b50096d756fda2f9e2 mihome-vacuum.0 2020-02-18 16:04:55.640 debug (951) sendMsg >>> {"id":104,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:55.640 debug (951) Timestamp: 5e4bfd17 mihome-vacuum.0 2020-02-18 16:04:55.639 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:55.139 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":103}<<< 21310050000000000f92f4f95e4bfd166a99bb366ec15be4e1943588f2429396a22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477afbf1 mihome-vacuum.0 2020-02-18 16:04:55.128 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:04:55.128 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd171ad64d9d4738c62ba0af9f817066ec1257aa72e1f1181439543d9d747fffca3203be3d6cfa27018138f0e607b2f8a5681e62d3ffabc60526bbd1abf5980715cc mihome-vacuum.0 2020-02-18 16:04:55.128 debug (951) sendMsg >>> {"id":103,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:55.128 debug (951) Timestamp: 5e4bfd17 mihome-vacuum.0 2020-02-18 16:04:55.127 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:54.627 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":102}<<< 21310050000000000f92f4f95e4bfd1616996f5d2c589434ac0f0e30f517111ba22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477ac63f mihome-vacuum.0 2020-02-18 16:04:54.610 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:04:54.610 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd1671ece8b0be553a40c54079d287d5dad90ca6a39ffb671e4b386744e28549ccee6dfb22378442a25aa73b9f1b3fb1bb2f8cfff071574c22454d90313e02a6600c mihome-vacuum.0 2020-02-18 16:04:54.609 debug (951) sendMsg >>> {"id":102,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:54.609 debug (951) Timestamp: 5e4bfd16 mihome-vacuum.0 2020-02-18 16:04:54.609 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:54.107 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":101}<<< 21310050000000000f92f4f95e4bfd15b6d79fdfbe4ee361bd39a3a13afe1a6ba22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a4381 mihome-vacuum.0 2020-02-18 16:04:54.099 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:04:54.099 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd166bfe90efd8fb62c7bd0ad8bf814297abe67a70c253052040b1468b120e92164d9af867e3a371cf54d28a78744e334c651aed0996b55364156fb6987dd136bc09 mihome-vacuum.0 2020-02-18 16:04:54.098 debug (951) sendMsg >>> {"id":101,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:54.098 debug (951) Timestamp: 5e4bfd16 mihome-vacuum.0 2020-02-18 16:04:54.098 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:53.597 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":100}<<< 21310050000000000f92f4f95e4bfd15fe7755d0459d2cf7dd369a80408158f6a22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a9280 mihome-vacuum.0 2020-02-18 16:04:53.588 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:04:53.587 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd15b5eb74327e3c45d12deb981022f3eece87ce4658776868c50083840aa6cbd3ba55cdcd16538a49eaea2448c10ad4190ed798f819994a381bda80a0e28ccfd8c3 mihome-vacuum.0 2020-02-18 16:04:53.587 debug (951) sendMsg >>> {"id":100,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:53.587 debug (951) Timestamp: 5e4bfd15 mihome-vacuum.0 2020-02-18 16:04:53.587 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:53.086 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":99}<<< 21310050000000000f92f4f95e4bfd14da9cdf7072effa694813291916bf5fd8a22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a9544c mihome-vacuum.0 2020-02-18 16:04:53.077 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:04:53.077 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd15cf38f94cdb01b71e1cc50a4649b65715816b8c328eb9c73f7808700fadeb133a076deb63cbb045edfe012d68f2fd48a546f6e402469d574692d4f7e4cff927cd mihome-vacuum.0 2020-02-18 16:04:53.076 debug (951) sendMsg >>> {"id":99,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:53.076 debug (951) Timestamp: 5e4bfd15 mihome-vacuum.0 2020-02-18 16:04:53.076 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:52.574 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":98}<<< 21310050000000000f92f4f95e4bfd14cf1f039ea76581b1f16774e2be9fe3e9a22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a5ca9f mihome-vacuum.0 2020-02-18 16:04:52.566 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:04:52.566 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd1492afebf8b56892f79d3d9beb4df649998a20036c86f713198c80570149ed317766aa510abc1b6eb2b2e442c125da4079e414686aebcedf6208217ea098bccc76 mihome-vacuum.0 2020-02-18 16:04:52.566 debug (951) sendMsg >>> {"id":98,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:52.566 debug (951) Timestamp: 5e4bfd14 mihome-vacuum.0 2020-02-18 16:04:52.565 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:52.064 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":97}<<< 21310050000000000f92f4f95e4bfd13b0cc0125768b79bb588564162f54f31ba22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a14f7d mihome-vacuum.0 2020-02-18 16:04:52.054 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:04:52.054 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd1425074769d719091283c963688a27df8e878a5578eefd93aa6327d6c44232b4edf7065d3fe17ba11bb454ceac0d34e7ced95a675f09145e8c02a78b67883bc5a3 mihome-vacuum.0 2020-02-18 16:04:52.050 debug (951) sendMsg >>> {"id":97,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:52.049 debug (951) Timestamp: 5e4bfd14 mihome-vacuum.0 2020-02-18 16:04:52.049 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:51.547 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":96}<<< 21310050000000000f92f4f95e4bfd1278250b488ba05b8dd8fee1e472aeac7aa22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477aa057e mihome-vacuum.0 2020-02-18 16:04:51.542 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:04:51.542 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd13f507b425e888a80d78d091bd0563afe1028459dde8294eabee4ab6f0d9e2cd80cc99f73b27e3bb9f2a79097d69fdbc04ac5c7f73f6d46f133463ec1a7b837448 mihome-vacuum.0 2020-02-18 16:04:51.542 debug (951) sendMsg >>> {"id":96,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:51.542 debug (951) Timestamp: 5e4bfd13 mihome-vacuum.0 2020-02-18 16:04:51.541 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:51.041 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":95}<<< 21310050000000000f92f4f95e4bfd129665629033353a571035ad0105784c85a22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a024ed mihome-vacuum.0 2020-02-18 16:04:51.024 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:04:51.024 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd13a25451ae505dfd3239bc74e0ed4c30c8f3d0cc371110a02029c7b69107b20757a57135c5375130b6d95f8d33c5d4a8861c3f5f18cdf0e5c3b8d9b35f52143150 mihome-vacuum.0 2020-02-18 16:04:51.024 debug (951) sendMsg >>> {"id":95,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:51.023 debug (951) Timestamp: 5e4bfd13 mihome-vacuum.0 2020-02-18 16:04:51.023 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:50.521 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":94}<<< 21310050000000000f92f4f95e4bfd112d42a41bf6cea47e58ce85acc814eb84a22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477ae8d36 mihome-vacuum.0 2020-02-18 16:04:50.507 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:04:50.507 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd12f4f5a6dbe37ee7372774722291d782fff3bde7237e584a3d24883db2e5db7f6faa4dbf0e7f02c5820bf4daa9b5577e3efc4011737c6bbe10041581bc16ad903f mihome-vacuum.0 2020-02-18 16:04:50.507 debug (951) sendMsg >>> {"id":94,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:50.506 debug (951) Timestamp: 5e4bfd12 mihome-vacuum.0 2020-02-18 16:04:50.506 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:50.005 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":93}<<< 21310050000000000f92f4f95e4bfd119b5b4d84289bbdcaa280e993414a64b7a22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477af8394 mihome-vacuum.0 2020-02-18 16:04:49.997 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:04:49.997 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd11754d43eb9e41b5710c1caeda57e96cf9e292d43df220cc7f4c2c3040316b9dac028f1efd9785bf72e54ecc87c739814637e7d30e73232236ca1e8b08e495e98d mihome-vacuum.0 2020-02-18 16:04:49.992 debug (951) sendMsg >>> {"id":93,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:49.991 debug (951) Timestamp: 5e4bfd11 mihome-vacuum.0 2020-02-18 16:04:49.990 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:49.490 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":92}<<< 21310050000000000f92f4f95e4bfd10ea12c94468b59ba3c71feabd6b15382ea22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a07718 mihome-vacuum.0 2020-02-18 16:04:49.481 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:04:49.481 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd11ad300f0eeeff8b1d9984fc91b4befcc2eb0fd881b27dae840ee9a6369365b2dac5ff3b1c7d6aa4659d60367f9f3de98f6b4a9de64b27449a402bbd812ace8bef mihome-vacuum.0 2020-02-18 16:04:49.481 debug (951) sendMsg >>> {"id":92,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:49.480 debug (951) Timestamp: 5e4bfd11 mihome-vacuum.0 2020-02-18 16:04:49.480 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:48.979 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":91}<<< 21310050000000000f92f4f95e4bfd103f943ebbb8451528306816c4586e7332a22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a32108 mihome-vacuum.0 2020-02-18 16:04:48.966 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:04:48.966 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd10959ecea9f694a827d3cb0f1ff6d5f4dcf0ab355f1fe0a81c30d9c7358ade33f9367b67aa9c509b51dc867f0e89710d1b565530e0a5809a453b7394ab26f1c04d mihome-vacuum.0 2020-02-18 16:04:48.966 debug (951) sendMsg >>> {"id":91,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:48.966 debug (951) Timestamp: 5e4bfd10 mihome-vacuum.0 2020-02-18 16:04:48.965 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:48.465 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":90}<<< 21310050000000000f92f4f95e4bfd0f5f4676703190d36d140cad1da00a872ba22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a62b92 mihome-vacuum.0 2020-02-18 16:04:48.455 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:04:48.455 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd10fc838bb68df26090f4455da992d486f57fd659c66be050f9ed1b9390094ec592198165c38ed93855225cb5730b08a50d2895abff9bc570430f7a83fb69d95e37 mihome-vacuum.0 2020-02-18 16:04:48.455 debug (951) sendMsg >>> {"id":90,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:48.454 debug (951) Timestamp: 5e4bfd10 mihome-vacuum.0 2020-02-18 16:04:48.454 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:47.954 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":89}<<< 21310050000000000f92f4f95e4bfd0fc31f3929e9a13fc5233400e8a947df2fa22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477af50af mihome-vacuum.0 2020-02-18 16:04:47.945 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:04:47.945 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd0f0daf33fe39bb6dd10d0a2365af92842abcd69e5632e20db6c736f92c793a7e389c7608fda258a40ced67953b52739cd04c4690bc91993e04690e397735dfa731 mihome-vacuum.0 2020-02-18 16:04:47.945 debug (951) sendMsg >>> {"id":89,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:47.945 debug (951) Timestamp: 5e4bfd0f mihome-vacuum.0 2020-02-18 16:04:47.944 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:47.443 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":88}<<< 21310050000000000f92f4f95e4bfd0ea4f52306e52156a956ab269ac5ada2eda22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477af5a55 mihome-vacuum.0 2020-02-18 16:04:47.433 debug (951) Mappointer_nomap___ruby2%2F261289209%2F18 mihome-vacuum.0 2020-02-18 16:04:47.433 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd0f9b7489960398a0a7f3cd2606d45f7516e76344f64906453301d769c61f7f7ae49e157183420779d991ed725459ef367daf536432cf2b2c9c085f9a9ca73808c6 mihome-vacuum.0 2020-02-18 16:04:47.433 debug (951) sendMsg >>> {"id":88,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:47.432 debug (951) Timestamp: 5e4bfd0f mihome-vacuum.0 2020-02-18 16:04:47.432 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:46.931 debug (951) Receive <<< {"result":["ruby2%2F261289209%2F18"],"id":87}<<< 21310050000000000f92f4f95e4bfd0e7e135e09c634d923123d767684d6c01ca22551c6f331272a72df6ab044ef49df20f4834faa8d17a13d8f68e1429a477a29a73 mihome-vacuum.0 2020-02-18 16:04:46.922 debug (951) Mappointer_nomap___retry mihome-vacuum.0 2020-02-18 16:04:46.922 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd0ecf6b0698ab07336368411aac091b53e24d90e16b572be5c4a395c8e77eddeaef1a256d8272a00ddc1fc5b7a544443bd96475dd04857f9bff781cc9ca72e5844e mihome-vacuum.0 2020-02-18 16:04:46.922 debug (951) sendMsg >>> {"id":87,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:46.921 debug (951) Timestamp: 5e4bfd0e mihome-vacuum.0 2020-02-18 16:04:46.921 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:46.420 debug (951) Receive <<< {"result":["retry"],"id":86}<<< 21310040000000000f92f4f95e4bfd0da900dd8369dbf1b46724acb0915924dc0f403f442ceaf84856a62c4354fcd51f7c2452d2348b6c43fa32318c5dac63b8 mihome-vacuum.0 2020-02-18 16:04:46.410 debug (951) Mappointer_nomap___retry mihome-vacuum.0 2020-02-18 16:04:46.410 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd0e242fe04bae82173f6a76982bb14a1e09189606e6a81346938870dd0b2cf1fc09a9cff4f2fe3e66647b59d1fde95f6138689c34daa8085ab643103c8cecb939ca mihome-vacuum.0 2020-02-18 16:04:46.410 debug (951) sendMsg >>> {"id":86,"method":"get_fresh_map_v1"} mihome-vacuum.0 2020-02-18 16:04:46.409 debug (951) Timestamp: 5e4bfd0e mihome-vacuum.0 2020-02-18 16:04:46.409 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:45.907 debug (951) Receive <<< {"result":["retry"],"id":85}<<< 21310040000000000f92f4f95e4bfd0d016fb1f068e97663488d6c29b6ac25b40f403f442ceaf84856a62c4354fcd51f627c45070e6c9f36c7b7ab48bbf04462 mihome-vacuum.0 2020-02-18 16:04:45.902 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfd0da1b83f09973a184e1b5f18cddfd862d7e3d8573da40393e9cfdc77220036a3fb2de8abd2a1eb244a50d5c1febefe1a17 mihome-vacuum.0 2020-02-18 16:04:45.902 debug (951) sendMsg >>> {"id":85,"method":"get_map_v1"} mihome-vacuum.0 2020-02-18 16:04:45.901 debug (951) Timestamp: 5e4bfd0d mihome-vacuum.0 2020-02-18 16:04:45.901 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:45.712 debug (951) Receive <<< {"result":[50],"id":84}<<< 21310040000000000f92f4f95e4bfd0d2fa64dda16d81ec42f994fb780f1cb294ab542983d00e07ddf295438334714b100159cf21f4591881243dcd944387cb3 mihome-vacuum.0 2020-02-18 16:04:45.699 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd0d5f92674630b0bd662e3fe04da6a631ca42a6215ea394a4f9723003c9241824f03c26462bdf55710525d83dad5ced203c34ebf92cd69cb55d37a2b3f82ccfc7b1 mihome-vacuum.0 2020-02-18 16:04:45.699 debug (951) sendMsg >>> {"id":84,"method":"get_sound_volume"} mihome-vacuum.0 2020-02-18 16:04:45.699 debug (951) Timestamp: 5e4bfd0d mihome-vacuum.0 2020-02-18 16:04:45.698 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":84,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:45.497 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd0d3f5e9de7d7377ff292445247ff350216e7fd91517f4918f6173aeb3f48e0dd77987ce4388fcafc6f29b0af7e2c99b93ee25357b7c34d77887623c48095af658f mihome-vacuum.0 2020-02-18 16:04:45.497 debug (951) sendMsg >>> {"id":83,"method":"get_clean_summary"} mihome-vacuum.0 2020-02-18 16:04:45.497 debug (951) Timestamp: 5e4bfd0d mihome-vacuum.0 2020-02-18 16:04:45.496 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":83,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":77,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:45.296 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfd0dea51e5d339ab12fedb1e60d4e2aafa425fe8d452c72d8353ac1efa25af5d8ac8a62fb1e850f1dbd048e404e3980ce163820adbb69451090eced7b20fde3455e8 mihome-vacuum.0 2020-02-18 16:04:45.296 debug (951) sendMsg >>> {"id":82,"method":"get_consumable"} mihome-vacuum.0 2020-02-18 16:04:45.295 debug (951) Timestamp: 5e4bfd0d mihome-vacuum.0 2020-02-18 16:04:45.295 debug (951) lastid{"get_status":80,"get_consumable":82,"get_clean_summary":76,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":77,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:45.094 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfd0d6246638918464c4ef3b2ebb8b47cd4ae17469aabfbdcba74e94ad56ff5c067d30c12742337b69a0af0cc847b4277ff67 mihome-vacuum.0 2020-02-18 16:04:45.093 debug (951) sendMsg >>> {"id":81,"method":"miIO.info"} mihome-vacuum.0 2020-02-18 16:04:45.093 debug (951) Timestamp: 5e4bfd0d mihome-vacuum.0 2020-02-18 16:04:45.093 debug (951) lastid{"get_status":80,"get_consumable":75,"get_clean_summary":76,"get_clean_record":0,"X_send_command":0,"miIO.info":81,"get_sound_volume":77,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:45.093 debug (951) requesting params every: 60 Sec mihome-vacuum.0 2020-02-18 16:04:45.093 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfd0d7ef6fafeb08d78619a9230575800940e993623199990186168828802961de716dd8a58dfe2de9ef512f6fb4d2fe452bf mihome-vacuum.0 2020-02-18 16:04:45.093 debug (951) sendMsg >>> {"id":80,"method":"get_status"} mihome-vacuum.0 2020-02-18 16:04:45.093 debug (951) Timestamp: 5e4bfd0d mihome-vacuum.0 2020-02-18 16:04:45.092 debug (951) lastid{"get_status":80,"get_consumable":75,"get_clean_summary":76,"get_clean_record":0,"X_send_command":0,"miIO.info":74,"get_sound_volume":77,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:45.092 debug (951) Connected mihome-vacuum.0 2020-02-18 16:04:45.092 debug (951) Receive <<< Helo <<< 21310020000000000f92f4f95e4bfd0cffffffffffffffffffffffffffffffff mihome-vacuum.0 2020-02-18 16:04:28.088 debug (951) Disconnect mihome-vacuum.0 2020-02-18 16:04:25.088 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfcf938eb3b09e77c80a0e4dfbc5e79d801a211e8399e0cae1b21f3d492f45ca83d88e6818a7896d5da29662c63d698c92e20 mihome-vacuum.0 2020-02-18 16:04:25.088 debug (951) sendMsg >>> {"id":79,"method":"get_status"} mihome-vacuum.0 2020-02-18 16:04:25.087 debug (951) Timestamp: 5e4bfcf9 mihome-vacuum.0 2020-02-18 16:04:25.087 debug (951) lastid{"get_status":79,"get_consumable":75,"get_clean_summary":76,"get_clean_record":0,"X_send_command":0,"miIO.info":74,"get_sound_volume":77,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:05.905 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfce5cc8f24ee67f4a471f121a2f5610403d4861f9c4bdaecf58bfebf35c588be6cb56616624be27246a9cf74d87a5fcac927 mihome-vacuum.0 2020-02-18 16:04:05.904 debug (951) sendMsg >>> {"id":78,"method":"get_map_v1"} mihome-vacuum.0 2020-02-18 16:04:05.904 debug (951) Timestamp: 5e4bfce5 mihome-vacuum.0 2020-02-18 16:04:05.904 debug (951) lastid{"get_status":73,"get_consumable":75,"get_clean_summary":76,"get_clean_record":0,"X_send_command":0,"miIO.info":74,"get_sound_volume":77,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:05.703 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfce501b065a8ca7602cab34f79b2975068fbbc0ebaa64465532adc2abb01d546f0ff3d0ac0625036d64d0a3dc750b3071cbb8b1a2a785106e16cfe000a97ead882d0 mihome-vacuum.0 2020-02-18 16:04:05.703 debug (951) sendMsg >>> {"id":77,"method":"get_sound_volume"} mihome-vacuum.0 2020-02-18 16:04:05.702 debug (951) Timestamp: 5e4bfce5 mihome-vacuum.0 2020-02-18 16:04:05.702 debug (951) lastid{"get_status":73,"get_consumable":75,"get_clean_summary":76,"get_clean_record":0,"X_send_command":0,"miIO.info":74,"get_sound_volume":77,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:05.501 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfce554223ce40ea11f355a189a1502ace10b0add1ba70eebbd43add9164044b2ba79d15deba8eab7f8b3dfc103102899c535035846a1b0794366ebf5d2a39944da3f mihome-vacuum.0 2020-02-18 16:04:05.501 debug (951) sendMsg >>> {"id":76,"method":"get_clean_summary"} mihome-vacuum.0 2020-02-18 16:04:05.501 debug (951) Timestamp: 5e4bfce5 mihome-vacuum.0 2020-02-18 16:04:05.500 debug (951) lastid{"get_status":73,"get_consumable":75,"get_clean_summary":76,"get_clean_record":0,"X_send_command":0,"miIO.info":74,"get_sound_volume":71,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:05.299 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfce5657ab2c7aaccc069cadf69c56ebeacbb45c03e014c3f8abafb3691f6c2a69c80396a453810fd739d3b2286cb2ca5fc5f4a2727fc25d3759d31e14171920ac382 mihome-vacuum.0 2020-02-18 16:04:05.299 debug (951) sendMsg >>> {"id":75,"method":"get_consumable"} mihome-vacuum.0 2020-02-18 16:04:05.299 debug (951) Timestamp: 5e4bfce5 mihome-vacuum.0 2020-02-18 16:04:05.298 debug (951) lastid{"get_status":73,"get_consumable":75,"get_clean_summary":70,"get_clean_record":0,"X_send_command":0,"miIO.info":74,"get_sound_volume":71,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:05.093 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfce5ea26b08bde6e4db40e6c8fb912753711a40ffcdd02ec94adb1d29f78b5bbbc9344cb42f8d76d2e7e77e1cef98512d6c5 mihome-vacuum.0 2020-02-18 16:04:05.093 debug (951) sendMsg >>> {"id":74,"method":"miIO.info"} mihome-vacuum.0 2020-02-18 16:04:05.093 debug (951) Timestamp: 5e4bfce5 mihome-vacuum.0 2020-02-18 16:04:05.092 debug (951) lastid{"get_status":73,"get_consumable":69,"get_clean_summary":70,"get_clean_record":0,"X_send_command":0,"miIO.info":74,"get_sound_volume":71,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:05.092 debug (951) requesting params every: 60 Sec mihome-vacuum.0 2020-02-18 16:04:05.092 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfce52a41be847568aa5e7be23727760243eea5e23cb947e05ceea578c2e6a2d426fede24082e4431627a2fa77a472a08d6c8 mihome-vacuum.0 2020-02-18 16:04:05.092 debug (951) sendMsg >>> {"id":73,"method":"get_status"} mihome-vacuum.0 2020-02-18 16:04:05.092 debug (951) Timestamp: 5e4bfce5 mihome-vacuum.0 2020-02-18 16:04:05.091 debug (951) lastid{"get_status":73,"get_consumable":69,"get_clean_summary":70,"get_clean_record":0,"X_send_command":0,"miIO.info":67,"get_sound_volume":71,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:04:05.091 debug (951) Connected mihome-vacuum.0 2020-02-18 16:04:05.091 debug (951) Receive <<< Helo <<< 21310020000000000f92f4f95e4bfce4ffffffffffffffffffffffffffffffff mihome-vacuum.0 2020-02-18 16:03:48.085 debug (951) Disconnect mihome-vacuum.0 2020-02-18 16:03:45.874 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfcd1231bca20367ce47404d48f4785c720c5dbda28461cf93dbe3a75f184118316173f9cd424e61c376322fe2ccb4891ba34 mihome-vacuum.0 2020-02-18 16:03:45.874 debug (951) sendMsg >>> {"id":72,"method":"get_map_v1"} mihome-vacuum.0 2020-02-18 16:03:45.874 debug (951) Timestamp: 5e4bfcd1 mihome-vacuum.0 2020-02-18 16:03:45.873 debug (951) lastid{"get_status":68,"get_consumable":69,"get_clean_summary":70,"get_clean_record":0,"X_send_command":0,"miIO.info":67,"get_sound_volume":71,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:03:45.673 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfcd1bfac0c4ade716d20c3a054fafa753cca951b05ee467d4a51e1ace94b1f4d8442ffa2f52f84461e1bb3903bc579aa828238b0f47f528379fc840dcd3ff10317cc mihome-vacuum.0 2020-02-18 16:03:45.672 debug (951) sendMsg >>> {"id":71,"method":"get_sound_volume"} mihome-vacuum.0 2020-02-18 16:03:45.672 debug (951) Timestamp: 5e4bfcd1 mihome-vacuum.0 2020-02-18 16:03:45.672 debug (951) lastid{"get_status":68,"get_consumable":69,"get_clean_summary":70,"get_clean_record":0,"X_send_command":0,"miIO.info":67,"get_sound_volume":71,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:03:45.470 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfcd15a8e5154b787ca4a83bfdfb07fb941d208e915272314d82fc66840cc8607c899575bebd661b17b7d8eadf2d8cf2ebf1f572d5731175451b7f2a635727948e97a mihome-vacuum.0 2020-02-18 16:03:45.470 debug (951) sendMsg >>> {"id":70,"method":"get_clean_summary"} mihome-vacuum.0 2020-02-18 16:03:45.470 debug (951) Timestamp: 5e4bfcd1 mihome-vacuum.0 2020-02-18 16:03:45.470 debug (951) lastid{"get_status":68,"get_consumable":69,"get_clean_summary":70,"get_clean_record":0,"X_send_command":0,"miIO.info":67,"get_sound_volume":65,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:03:45.270 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfcd1effa52086537a9469436dd31c0c35380d54a9950b4f69132924249dc1ebdf29b038df50ad0dd11a4493298d5a812441594693f0d394fe633c6fe37545ba4a9f6 mihome-vacuum.0 2020-02-18 16:03:45.269 debug (951) sendMsg >>> {"id":69,"method":"get_consumable"} mihome-vacuum.0 2020-02-18 16:03:45.269 debug (951) Timestamp: 5e4bfcd1 mihome-vacuum.0 2020-02-18 16:03:45.269 debug (951) lastid{"get_status":68,"get_consumable":69,"get_clean_summary":64,"get_clean_record":0,"X_send_command":0,"miIO.info":67,"get_sound_volume":65,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:03:45.085 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfcd1f13d52fa289d4e2a794968b9596d1c82d85b43509d2151546354488afa372e51a88cd7bd7a4344ed5c9d878c3182da3e mihome-vacuum.0 2020-02-18 16:03:45.085 debug (951) sendMsg >>> {"id":68,"method":"get_status"} mihome-vacuum.0 2020-02-18 16:03:45.085 debug (951) Timestamp: 5e4bfcd1 mihome-vacuum.0 2020-02-18 16:03:45.084 debug (951) lastid{"get_status":68,"get_consumable":63,"get_clean_summary":64,"get_clean_record":0,"X_send_command":0,"miIO.info":67,"get_sound_volume":65,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:03:45.067 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfcd1930c511911dbb364dce9fd2b17a47feee80c82d7d32798c38a7afe323ebfe95fe8a52578050bd72e18036952dd4b102e mihome-vacuum.0 2020-02-18 16:03:45.067 debug (951) sendMsg >>> {"id":67,"method":"miIO.info"} mihome-vacuum.0 2020-02-18 16:03:45.067 debug (951) Timestamp: 5e4bfcd1 mihome-vacuum.0 2020-02-18 16:03:45.066 debug (951) lastid{"get_status":61,"get_consumable":63,"get_clean_summary":64,"get_clean_record":0,"X_send_command":0,"miIO.info":67,"get_sound_volume":65,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:03:45.066 debug (951) requesting params every: 60 Sec mihome-vacuum.0 2020-02-18 16:03:25.911 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfcbd457967392fef142e2db28feea8059af710978afea4e140dea15196a7d9a40789141fb815cdaf66c8823a0399629da6b9 mihome-vacuum.0 2020-02-18 16:03:25.911 debug (951) sendMsg >>> {"id":66,"method":"get_map_v1"} mihome-vacuum.0 2020-02-18 16:03:25.911 debug (951) Timestamp: 5e4bfcbd mihome-vacuum.0 2020-02-18 16:03:25.910 debug (951) lastid{"get_status":61,"get_consumable":63,"get_clean_summary":64,"get_clean_record":0,"X_send_command":0,"miIO.info":62,"get_sound_volume":65,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:03:25.709 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfcbd011ef5aeefc81017d529062fe150dd18cdd27a124750f8cbe96f6df76c991a7e4bff7689e8990c37edfa6ac655fb39bcd36551f8b18c3a21fb9931fd899ec7bb mihome-vacuum.0 2020-02-18 16:03:25.709 debug (951) sendMsg >>> {"id":65,"method":"get_sound_volume"} mihome-vacuum.0 2020-02-18 16:03:25.709 debug (951) Timestamp: 5e4bfcbd mihome-vacuum.0 2020-02-18 16:03:25.709 debug (951) lastid{"get_status":61,"get_consumable":63,"get_clean_summary":64,"get_clean_record":0,"X_send_command":0,"miIO.info":62,"get_sound_volume":65,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:03:25.508 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfcbdca55dd09c25737ac58868b95a3f2d03432456b9181f8c6dee632750e757aa7ee07252a3e91c9cbc15cf9dcb51bd5b67b7bfc81e1da36334501fbe970bda616e5 mihome-vacuum.0 2020-02-18 16:03:25.507 debug (951) sendMsg >>> {"id":64,"method":"get_clean_summary"} mihome-vacuum.0 2020-02-18 16:03:25.507 debug (951) Timestamp: 5e4bfcbd mihome-vacuum.0 2020-02-18 16:03:25.507 debug (951) lastid{"get_status":61,"get_consumable":63,"get_clean_summary":64,"get_clean_record":0,"X_send_command":0,"miIO.info":62,"get_sound_volume":58,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:03:25.306 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfcbded9fb2a2949edccc330f754a94039f740a5189c9afc14a245470de8fa7918bd828ece54b6ce30209be306721c74c8b846871154931d3613447b929728fb3a561 mihome-vacuum.0 2020-02-18 16:03:25.305 debug (951) sendMsg >>> {"id":63,"method":"get_consumable"} mihome-vacuum.0 2020-02-18 16:03:25.305 debug (951) Timestamp: 5e4bfcbd mihome-vacuum.0 2020-02-18 16:03:25.305 debug (951) lastid{"get_status":61,"get_consumable":63,"get_clean_summary":57,"get_clean_record":0,"X_send_command":0,"miIO.info":62,"get_sound_volume":58,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:03:25.103 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfcbd4513bf9c8e95615ae85e90fbb76673a7823256082f2d862bc04dd99b433f3e50e45030b8467045361d6e3940c5008c8f mihome-vacuum.0 2020-02-18 16:03:25.103 debug (951) sendMsg >>> {"id":62,"method":"miIO.info"} mihome-vacuum.0 2020-02-18 16:03:25.103 debug (951) Timestamp: 5e4bfcbd mihome-vacuum.0 2020-02-18 16:03:25.103 debug (951) lastid{"get_status":61,"get_consumable":56,"get_clean_summary":57,"get_clean_record":0,"X_send_command":0,"miIO.info":62,"get_sound_volume":58,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:03:25.103 debug (951) requesting params every: 60 Sec mihome-vacuum.0 2020-02-18 16:03:25.103 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfcbdabeac8602a4fb5682ebe12d971e873c230deb959a021906a8264bf5c5c94c43e6288e5e5b7be30a388cf2528d60dc619 mihome-vacuum.0 2020-02-18 16:03:25.103 debug (951) sendMsg >>> {"id":61,"method":"get_status"} mihome-vacuum.0 2020-02-18 16:03:25.102 debug (951) Timestamp: 5e4bfcbd mihome-vacuum.0 2020-02-18 16:03:25.102 debug (951) lastid{"get_status":61,"get_consumable":56,"get_clean_summary":57,"get_clean_record":0,"X_send_command":0,"miIO.info":55,"get_sound_volume":58,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:03:25.088 debug (951) Connected mihome-vacuum.0 2020-02-18 16:03:25.087 debug (951) Receive <<< Helo <<< 21310020000000000f92f4f95e4bfcbcffffffffffffffffffffffffffffffff mihome-vacuum.0 2020-02-18 16:03:08.082 debug (951) Disconnect mihome-vacuum.0 2020-02-18 16:03:05.083 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfca959da5c28bf3c747e340c0596285b3d2726a25b2483f2e30e82e1b736009de73f3b03e437ce7780132536d70a46db8d96 mihome-vacuum.0 2020-02-18 16:03:05.082 debug (951) sendMsg >>> {"id":60,"method":"get_status"} mihome-vacuum.0 2020-02-18 16:03:05.082 debug (951) Timestamp: 5e4bfca9 mihome-vacuum.0 2020-02-18 16:03:05.082 debug (951) lastid{"get_status":60,"get_consumable":56,"get_clean_summary":57,"get_clean_record":0,"X_send_command":0,"miIO.info":55,"get_sound_volume":58,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:02:45.907 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfc95782fd1ea090c56e36a2ee3819dc991cd43334c0bee925f84c7a643c923f89672c63474e745da0390cd32d741595c30b5 mihome-vacuum.0 2020-02-18 16:02:45.907 debug (951) sendMsg >>> {"id":59,"method":"get_map_v1"} mihome-vacuum.0 2020-02-18 16:02:45.906 debug (951) Timestamp: 5e4bfc95 mihome-vacuum.0 2020-02-18 16:02:45.906 debug (951) lastid{"get_status":54,"get_consumable":56,"get_clean_summary":57,"get_clean_record":0,"X_send_command":0,"miIO.info":55,"get_sound_volume":58,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:02:45.705 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfc95b77a8f3c4a3bd31afafd82d80116ac0ae67356ec58b0344841b0ef910fb52461323c9249445066580086735eba3667f4b1fa98c2e1f6d912c6fefe428482dba9 mihome-vacuum.0 2020-02-18 16:02:45.705 debug (951) sendMsg >>> {"id":58,"method":"get_sound_volume"} mihome-vacuum.0 2020-02-18 16:02:45.704 debug (951) Timestamp: 5e4bfc95 mihome-vacuum.0 2020-02-18 16:02:45.704 debug (951) lastid{"get_status":54,"get_consumable":56,"get_clean_summary":57,"get_clean_record":0,"X_send_command":0,"miIO.info":55,"get_sound_volume":58,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:02:45.503 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfc9545380a33c8a509fdf06a052680408027142a873a2e0116ede6703feadb45caeb65239773f489a019216891509915599bc758ced06df8ce2e286cb4b4c7154d9c mihome-vacuum.0 2020-02-18 16:02:45.503 debug (951) sendMsg >>> {"id":57,"method":"get_clean_summary"} mihome-vacuum.0 2020-02-18 16:02:45.503 debug (951) Timestamp: 5e4bfc95 mihome-vacuum.0 2020-02-18 16:02:45.502 debug (951) lastid{"get_status":54,"get_consumable":56,"get_clean_summary":57,"get_clean_record":0,"X_send_command":0,"miIO.info":55,"get_sound_volume":51,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:02:45.302 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfc953bd5d1f6346b734e78d569ea5ec92fa9bbab62f231a7a02d4ca6724ca1aa79f3bb287e08a774d8f168372792c9562ceccdbb4bfe1ff5fc49db06a72ec69cbb93 mihome-vacuum.0 2020-02-18 16:02:45.302 debug (951) sendMsg >>> {"id":56,"method":"get_consumable"} mihome-vacuum.0 2020-02-18 16:02:45.302 debug (951) Timestamp: 5e4bfc95 mihome-vacuum.0 2020-02-18 16:02:45.301 debug (951) lastid{"get_status":54,"get_consumable":56,"get_clean_summary":50,"get_clean_record":0,"X_send_command":0,"miIO.info":55,"get_sound_volume":51,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:02:45.097 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfc95342c7f7fe68d52e775cfb5fd35ecd800579cc3fa6fce51f87657606864b41d85df870400d10d76a0250415ba9f7e4d8f mihome-vacuum.0 2020-02-18 16:02:45.097 debug (951) sendMsg >>> {"id":55,"method":"miIO.info"} mihome-vacuum.0 2020-02-18 16:02:45.097 debug (951) Timestamp: 5e4bfc95 mihome-vacuum.0 2020-02-18 16:02:45.097 debug (951) lastid{"get_status":54,"get_consumable":49,"get_clean_summary":50,"get_clean_record":0,"X_send_command":0,"miIO.info":55,"get_sound_volume":51,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:02:45.086 debug (951) requesting params every: 60 Sec mihome-vacuum.0 2020-02-18 16:02:45.086 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfc954753b8e7c810bda09298f45d8acef0bab72dd85964d08de8f69ee278bb4ed12d9b4bf6a9f86ce0acff8ca8a6428fde0b mihome-vacuum.0 2020-02-18 16:02:45.085 debug (951) sendMsg >>> {"id":54,"method":"get_status"} mihome-vacuum.0 2020-02-18 16:02:45.085 debug (951) Timestamp: 5e4bfc95 mihome-vacuum.0 2020-02-18 16:02:45.085 debug (951) lastid{"get_status":54,"get_consumable":49,"get_clean_summary":50,"get_clean_record":0,"X_send_command":0,"miIO.info":48,"get_sound_volume":51,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:02:45.085 debug (951) Connected mihome-vacuum.0 2020-02-18 16:02:45.084 debug (951) Receive <<< Helo <<< 21310020000000000f92f4f95e4bfc94ffffffffffffffffffffffffffffffff mihome-vacuum.0 2020-02-18 16:02:28.080 debug (951) Disconnect mihome-vacuum.0 2020-02-18 16:02:25.080 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfc81d1c887279d2aa95376f016dec8aa632552ebecba9fe1762f3f2da65e3fb2d80027fcb3926d085229824bd9a5113fc5b0 mihome-vacuum.0 2020-02-18 16:02:25.080 debug (951) sendMsg >>> {"id":53,"method":"get_status"} mihome-vacuum.0 2020-02-18 16:02:25.080 debug (951) Timestamp: 5e4bfc81 mihome-vacuum.0 2020-02-18 16:02:25.079 debug (951) lastid{"get_status":53,"get_consumable":49,"get_clean_summary":50,"get_clean_record":0,"X_send_command":0,"miIO.info":48,"get_sound_volume":51,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:02:05.896 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfc6db8099daa8e6626284284867063520db5b312f2bbe5373e04c36781efa27f330a8679f56d4c686fc31f2d2840660c5c9d mihome-vacuum.0 2020-02-18 16:02:05.896 debug (951) sendMsg >>> {"id":52,"method":"get_map_v1"} mihome-vacuum.0 2020-02-18 16:02:05.895 debug (951) Timestamp: 5e4bfc6d mihome-vacuum.0 2020-02-18 16:02:05.895 debug (951) lastid{"get_status":47,"get_consumable":49,"get_clean_summary":50,"get_clean_record":0,"X_send_command":0,"miIO.info":48,"get_sound_volume":51,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:02:05.694 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfc6dd90272d547c1ce199b25b32eabee5ce3233cd95ce973380ad040d4e3bb1e2dfa01d63a40a2a633a0cbe8f62adc412353e2b5a2093518c0e41cdf0750c9b20d2e mihome-vacuum.0 2020-02-18 16:02:05.694 debug (951) sendMsg >>> {"id":51,"method":"get_sound_volume"} mihome-vacuum.0 2020-02-18 16:02:05.694 debug (951) Timestamp: 5e4bfc6d mihome-vacuum.0 2020-02-18 16:02:05.693 debug (951) lastid{"get_status":47,"get_consumable":49,"get_clean_summary":50,"get_clean_record":0,"X_send_command":0,"miIO.info":48,"get_sound_volume":51,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:02:05.493 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfc6d4109c373de4af59f12a4b25ebd625caaae52946faa4bf704622b8cb5539f6b732c94ff10fb400be3726f016a1d71502b332bd452a4ab573431156b553f5fad69 mihome-vacuum.0 2020-02-18 16:02:05.492 debug (951) sendMsg >>> {"id":50,"method":"get_clean_summary"} mihome-vacuum.0 2020-02-18 16:02:05.492 debug (951) Timestamp: 5e4bfc6d mihome-vacuum.0 2020-02-18 16:02:05.492 debug (951) lastid{"get_status":47,"get_consumable":49,"get_clean_summary":50,"get_clean_record":0,"X_send_command":0,"miIO.info":48,"get_sound_volume":45,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:02:05.291 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfc6d750aba70edfde2751417435b1971f312cee8bff5abe856a332165f37314a05810a166ad20bbd25e820cf77ca29d44bedbbe35edd5666a2a121cb084f35b20abe mihome-vacuum.0 2020-02-18 16:02:05.291 debug (951) sendMsg >>> {"id":49,"method":"get_consumable"} mihome-vacuum.0 2020-02-18 16:02:05.291 debug (951) Timestamp: 5e4bfc6d mihome-vacuum.0 2020-02-18 16:02:05.290 debug (951) lastid{"get_status":47,"get_consumable":49,"get_clean_summary":44,"get_clean_record":0,"X_send_command":0,"miIO.info":48,"get_sound_volume":45,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:02:05.087 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfc6dfa914641433377f22d221a4b09f75311b83c249aadc3fe5c85ec2b32c534bc1efa1903d5eff0085ee038e4dad450f79a mihome-vacuum.0 2020-02-18 16:02:05.086 debug (951) sendMsg >>> {"id":48,"method":"miIO.info"} mihome-vacuum.0 2020-02-18 16:02:05.086 debug (951) Timestamp: 5e4bfc6d mihome-vacuum.0 2020-02-18 16:02:05.086 debug (951) lastid{"get_status":47,"get_consumable":43,"get_clean_summary":44,"get_clean_record":0,"X_send_command":0,"miIO.info":48,"get_sound_volume":45,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:02:05.086 debug (951) requesting params every: 60 Sec mihome-vacuum.0 2020-02-18 16:02:05.086 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfc6de8736aa2cc42611c7c865c7836ebd93a3ddb2b36e7872c90fe6b37af8a547946b319219b8c57ffac635964e2bbf1e9f1 mihome-vacuum.0 2020-02-18 16:02:05.086 debug (951) sendMsg >>> {"id":47,"method":"get_status"} mihome-vacuum.0 2020-02-18 16:02:05.085 debug (951) Timestamp: 5e4bfc6d mihome-vacuum.0 2020-02-18 16:02:05.085 debug (951) lastid{"get_status":47,"get_consumable":43,"get_clean_summary":44,"get_clean_record":0,"X_send_command":0,"miIO.info":41,"get_sound_volume":45,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:02:05.085 debug (951) Connected mihome-vacuum.0 2020-02-18 16:02:05.082 debug (951) Receive <<< Helo <<< 21310020000000000f92f4f95e4bfc6cffffffffffffffffffffffffffffffff mihome-vacuum.0 2020-02-18 16:01:48.078 debug (951) Disconnect mihome-vacuum.0 2020-02-18 16:01:45.872 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfc59ff438c015383982afd2f76c10d16987e83fcd90cac0306bf7664328fc10f80c414cd691f2da199dc6d3462bdd95a2a16 mihome-vacuum.0 2020-02-18 16:01:45.872 debug (951) sendMsg >>> {"id":46,"method":"get_map_v1"} mihome-vacuum.0 2020-02-18 16:01:45.872 debug (951) Timestamp: 5e4bfc59 mihome-vacuum.0 2020-02-18 16:01:45.871 debug (951) lastid{"get_status":42,"get_consumable":43,"get_clean_summary":44,"get_clean_record":0,"X_send_command":0,"miIO.info":41,"get_sound_volume":45,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:01:45.671 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfc59732c9f3aee0933bc92726c057c9b81858698a6322306013472686f904d817038de5a573988de4418c887cda04ba4708b99c3913f37b8f5f953a336c7da555c45 mihome-vacuum.0 2020-02-18 16:01:45.671 debug (951) sendMsg >>> {"id":45,"method":"get_sound_volume"} mihome-vacuum.0 2020-02-18 16:01:45.671 debug (951) Timestamp: 5e4bfc59 mihome-vacuum.0 2020-02-18 16:01:45.670 debug (951) lastid{"get_status":42,"get_consumable":43,"get_clean_summary":44,"get_clean_record":0,"X_send_command":0,"miIO.info":41,"get_sound_volume":45,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:01:45.470 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfc59c921da1900088192cddd34d8f505ddea4f4410e17254d0837d34793c2e08c2827a0a6a43fe80acd214d36b1015513f39faee85a5e2f17112f421c29e516910f7 mihome-vacuum.0 2020-02-18 16:01:45.469 debug (951) sendMsg >>> {"id":44,"method":"get_clean_summary"} mihome-vacuum.0 2020-02-18 16:01:45.469 debug (951) Timestamp: 5e4bfc59 mihome-vacuum.0 2020-02-18 16:01:45.469 debug (951) lastid{"get_status":42,"get_consumable":43,"get_clean_summary":44,"get_clean_record":0,"X_send_command":0,"miIO.info":41,"get_sound_volume":39,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:01:45.268 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfc593ecb2497c6969021a530916cd8660cc865811b80d04ed64b0816b82dada1b4cdf330cea56647edec73cc205a1026f4eb10e99372022d027a16dec269449f04c4 mihome-vacuum.0 2020-02-18 16:01:45.268 debug (951) sendMsg >>> {"id":43,"method":"get_consumable"} mihome-vacuum.0 2020-02-18 16:01:45.267 debug (951) Timestamp: 5e4bfc59 mihome-vacuum.0 2020-02-18 16:01:45.267 debug (951) lastid{"get_status":42,"get_consumable":43,"get_clean_summary":38,"get_clean_record":0,"X_send_command":0,"miIO.info":41,"get_sound_volume":39,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:01:45.078 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfc591dbf24ad2d4e4c79691a57f9df40ba44933c1f2a2bc86e635db4ead98d9e1d093578d47413314be4ff4239b58829b97f mihome-vacuum.0 2020-02-18 16:01:45.078 debug (951) sendMsg >>> {"id":42,"method":"get_status"} mihome-vacuum.0 2020-02-18 16:01:45.078 debug (951) Timestamp: 5e4bfc59 mihome-vacuum.0 2020-02-18 16:01:45.077 debug (951) lastid{"get_status":42,"get_consumable":37,"get_clean_summary":38,"get_clean_record":0,"X_send_command":0,"miIO.info":41,"get_sound_volume":39,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:01:45.067 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfc59c55d3efaf11e88677a7766fa44f654d31546c9db31133850c1a6e5feba1db9d17d8cd1b643cef882e6e76d6fd63e3c3e mihome-vacuum.0 2020-02-18 16:01:45.067 debug (951) sendMsg >>> {"id":41,"method":"miIO.info"} mihome-vacuum.0 2020-02-18 16:01:45.066 debug (951) Timestamp: 5e4bfc59 mihome-vacuum.0 2020-02-18 16:01:45.066 debug (951) lastid{"get_status":35,"get_consumable":37,"get_clean_summary":38,"get_clean_record":0,"X_send_command":0,"miIO.info":41,"get_sound_volume":39,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:01:45.066 debug (951) requesting params every: 60 Sec mihome-vacuum.0 2020-02-18 16:01:25.891 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfc451b33c0c6ff2c6f77619be78ee3e1b0373eedbb71897beab5ad00795e33138d63378d167ce25a330b74f5c811c7c10838 mihome-vacuum.0 2020-02-18 16:01:25.891 debug (951) sendMsg >>> {"id":40,"method":"get_map_v1"} mihome-vacuum.0 2020-02-18 16:01:25.891 debug (951) Timestamp: 5e4bfc45 mihome-vacuum.0 2020-02-18 16:01:25.890 debug (951) lastid{"get_status":35,"get_consumable":37,"get_clean_summary":38,"get_clean_record":0,"X_send_command":0,"miIO.info":36,"get_sound_volume":39,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:01:25.690 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfc45c1b26ceb9f1f02a809b0d27fe06fae67a2640a652c0e816764910bad869c2913cb815851ca54ef97a9d83c02d1993ab617e84f831b39781a7b63c36eb94f6d15 mihome-vacuum.0 2020-02-18 16:01:25.690 debug (951) sendMsg >>> {"id":39,"method":"get_sound_volume"} mihome-vacuum.0 2020-02-18 16:01:25.689 debug (951) Timestamp: 5e4bfc45 mihome-vacuum.0 2020-02-18 16:01:25.689 debug (951) lastid{"get_status":35,"get_consumable":37,"get_clean_summary":38,"get_clean_record":0,"X_send_command":0,"miIO.info":36,"get_sound_volume":39,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:01:25.489 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfc451db40bb692347ec0ce5fd9e809262e0ee21dfecbc96bc870c85fae2482c05c8eacd4c40ac3362a8cd606cadacee785619ea618fdb1dea407ce1970347fd05f7c mihome-vacuum.0 2020-02-18 16:01:25.489 debug (951) sendMsg >>> {"id":38,"method":"get_clean_summary"} mihome-vacuum.0 2020-02-18 16:01:25.489 debug (951) Timestamp: 5e4bfc45 mihome-vacuum.0 2020-02-18 16:01:25.488 debug (951) lastid{"get_status":35,"get_consumable":37,"get_clean_summary":38,"get_clean_record":0,"X_send_command":0,"miIO.info":36,"get_sound_volume":32,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:01:25.288 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfc45a5782340f1d0b47a87da01a2682924ebb66f3db187431f86fd72517fa9f5a851abb1681c5bab324cef33d4a29952d3e8a3dd2d1904f0820c553d5641c4f0a775 mihome-vacuum.0 2020-02-18 16:01:25.288 debug (951) sendMsg >>> {"id":37,"method":"get_consumable"} mihome-vacuum.0 2020-02-18 16:01:25.288 debug (951) Timestamp: 5e4bfc45 mihome-vacuum.0 2020-02-18 16:01:25.287 debug (951) lastid{"get_status":35,"get_consumable":37,"get_clean_summary":31,"get_clean_record":0,"X_send_command":0,"miIO.info":36,"get_sound_volume":32,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:01:25.082 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfc45398f7bb4a002aeb49fdc48111dec066f664127090c0db3250b045926a2a1064d3ccf4862e87a2c52b50ab1a62c32afe6 mihome-vacuum.0 2020-02-18 16:01:25.082 debug (951) sendMsg >>> {"id":36,"method":"miIO.info"} mihome-vacuum.0 2020-02-18 16:01:25.082 debug (951) Timestamp: 5e4bfc45 mihome-vacuum.0 2020-02-18 16:01:25.081 debug (951) lastid{"get_status":35,"get_consumable":30,"get_clean_summary":31,"get_clean_record":0,"X_send_command":0,"miIO.info":36,"get_sound_volume":32,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:01:25.081 debug (951) requesting params every: 60 Sec mihome-vacuum.0 2020-02-18 16:01:25.081 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfc4514bfee2cfd76f858fb9c8c7bd7171eff981f6c5bc721a0a2a860feb572a816f670df4a42967ccf5db6f123900be3398d mihome-vacuum.0 2020-02-18 16:01:25.081 debug (951) sendMsg >>> {"id":35,"method":"get_status"} mihome-vacuum.0 2020-02-18 16:01:25.081 debug (951) Timestamp: 5e4bfc45 mihome-vacuum.0 2020-02-18 16:01:25.081 debug (951) lastid{"get_status":35,"get_consumable":30,"get_clean_summary":31,"get_clean_record":0,"X_send_command":0,"miIO.info":29,"get_sound_volume":32,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:01:25.080 debug (951) Connected mihome-vacuum.0 2020-02-18 16:01:25.080 debug (951) Receive <<< Helo <<< 21310020000000000f92f4f95e4bfc44ffffffffffffffffffffffffffffffff mihome-vacuum.0 2020-02-18 16:01:08.076 debug (951) Disconnect mihome-vacuum.0 2020-02-18 16:01:05.076 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfc310fd011524314ea130f3f1fc1e94509a29b3904002410780120907abb4f2a0759c8a89ebdfc4449f60dc183a93e6494b3 mihome-vacuum.0 2020-02-18 16:01:05.076 debug (951) sendMsg >>> {"id":34,"method":"get_status"} mihome-vacuum.0 2020-02-18 16:01:05.076 debug (951) Timestamp: 5e4bfc31 mihome-vacuum.0 2020-02-18 16:01:05.075 debug (951) lastid{"get_status":34,"get_consumable":30,"get_clean_summary":31,"get_clean_record":0,"X_send_command":0,"miIO.info":29,"get_sound_volume":32,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:00:45.890 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfc1dec51a4dd267a4d2b84fd046fed1a48e922dd51f498c5d6df8f0ba9b6a9b67ab066c05fc5e70a106998b23948bfd9507d mihome-vacuum.0 2020-02-18 16:00:45.890 debug (951) sendMsg >>> {"id":33,"method":"get_map_v1"} mihome-vacuum.0 2020-02-18 16:00:45.890 debug (951) Timestamp: 5e4bfc1d mihome-vacuum.0 2020-02-18 16:00:45.889 debug (951) lastid{"get_status":28,"get_consumable":30,"get_clean_summary":31,"get_clean_record":0,"X_send_command":0,"miIO.info":29,"get_sound_volume":32,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:00:45.689 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfc1da20b51e19fdd7bfdf22e2997be9867f8a8190e8f0bbed64c62520ec78ad7c9765bddb40ca4d659ff0216e7ac8dbaca088da258d21d783a37e161115d5ab3aa5d mihome-vacuum.0 2020-02-18 16:00:45.689 debug (951) sendMsg >>> {"id":32,"method":"get_sound_volume"} mihome-vacuum.0 2020-02-18 16:00:45.689 debug (951) Timestamp: 5e4bfc1d mihome-vacuum.0 2020-02-18 16:00:45.688 debug (951) lastid{"get_status":28,"get_consumable":30,"get_clean_summary":31,"get_clean_record":0,"X_send_command":0,"miIO.info":29,"get_sound_volume":32,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:00:45.488 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfc1d25408263b2b04ab049fe66d2ed8be6c892b0acbfe862c45d6b60b1e7331ded988edc8eafd704af7555f114a6b72019776eabc96c8be45b70e9e693d59e2dec19 mihome-vacuum.0 2020-02-18 16:00:45.488 debug (951) sendMsg >>> {"id":31,"method":"get_clean_summary"} mihome-vacuum.0 2020-02-18 16:00:45.488 debug (951) Timestamp: 5e4bfc1d mihome-vacuum.0 2020-02-18 16:00:45.487 debug (951) lastid{"get_status":28,"get_consumable":30,"get_clean_summary":31,"get_clean_record":0,"X_send_command":0,"miIO.info":29,"get_sound_volume":25,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:00:45.287 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfc1de184737a02740c47f5fdafd8c3db46b774040de2ed0971a954807aa485a9bd531b5fd5cb6a4e6a36c15338e2fb82979ed47cf4228bd866b1b81199cdd379a685 mihome-vacuum.0 2020-02-18 16:00:45.287 debug (951) sendMsg >>> {"id":30,"method":"get_consumable"} mihome-vacuum.0 2020-02-18 16:00:45.286 debug (951) Timestamp: 5e4bfc1d mihome-vacuum.0 2020-02-18 16:00:45.286 debug (951) lastid{"get_status":28,"get_consumable":30,"get_clean_summary":24,"get_clean_record":0,"X_send_command":0,"miIO.info":29,"get_sound_volume":25,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:00:45.080 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfc1da20929b26878370d1594fbc53d5d0f91cbd924410fbddae38a48ed58367766a5b8a1378ba8489e5abd43c944829b1971 mihome-vacuum.0 2020-02-18 16:00:45.080 debug (951) sendMsg >>> {"id":29,"method":"miIO.info"} mihome-vacuum.0 2020-02-18 16:00:45.080 debug (951) Timestamp: 5e4bfc1d mihome-vacuum.0 2020-02-18 16:00:45.079 debug (951) lastid{"get_status":28,"get_consumable":23,"get_clean_summary":24,"get_clean_record":0,"X_send_command":0,"miIO.info":29,"get_sound_volume":25,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:00:45.079 debug (951) requesting params every: 60 Sec mihome-vacuum.0 2020-02-18 16:00:45.079 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfc1de24ffb2a23573815245ebbb2f738136d29495f0ba0f67433555c71b884b3b74d52e76149b7e350b8483fa4fa85a33db0 mihome-vacuum.0 2020-02-18 16:00:45.079 debug (951) sendMsg >>> {"id":28,"method":"get_status"} mihome-vacuum.0 2020-02-18 16:00:45.079 debug (951) Timestamp: 5e4bfc1d mihome-vacuum.0 2020-02-18 16:00:45.079 debug (951) lastid{"get_status":28,"get_consumable":23,"get_clean_summary":24,"get_clean_record":0,"X_send_command":0,"miIO.info":22,"get_sound_volume":25,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:00:45.078 debug (951) Connected mihome-vacuum.0 2020-02-18 16:00:45.078 debug (951) Receive <<< Helo <<< 21310020000000000f92f4f95e4bfc1cffffffffffffffffffffffffffffffff mihome-vacuum.0 2020-02-18 16:00:28.073 debug (951) Disconnect mihome-vacuum.0 2020-02-18 16:00:25.073 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfc09bccf476dab7538c36eec9179e5765212c95a68d73c4f9debcafe1d49b611e3ce82dbf8e05f7dbe4b6dc54802d9b88a2f mihome-vacuum.0 2020-02-18 16:00:25.073 debug (951) sendMsg >>> {"id":27,"method":"get_status"} mihome-vacuum.0 2020-02-18 16:00:25.073 debug (951) Timestamp: 5e4bfc09 mihome-vacuum.0 2020-02-18 16:00:25.072 debug (951) lastid{"get_status":27,"get_consumable":23,"get_clean_summary":24,"get_clean_record":0,"X_send_command":0,"miIO.info":22,"get_sound_volume":25,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:00:05.884 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfbf5e926186668a9510f26a3711215d9c814ea5e908bc6dfc8f6be5ac6d3668686e832434ead9821e3567803046da81ed055 mihome-vacuum.0 2020-02-18 16:00:05.884 debug (951) sendMsg >>> {"id":26,"method":"get_map_v1"} mihome-vacuum.0 2020-02-18 16:00:05.884 debug (951) Timestamp: 5e4bfbf5 mihome-vacuum.0 2020-02-18 16:00:05.884 debug (951) lastid{"get_status":21,"get_consumable":23,"get_clean_summary":24,"get_clean_record":0,"X_send_command":0,"miIO.info":22,"get_sound_volume":25,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:00:05.683 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfbf52959a3fad04a3bb89a03f3e6d6d73680bd39b3642e5e23bd1e2fbfae8d25d8023f05b2605ecc2a98d10b15abcbfaf90c1a544a5ccd3e95b1f10ed3205552e93f mihome-vacuum.0 2020-02-18 16:00:05.682 debug (951) sendMsg >>> {"id":25,"method":"get_sound_volume"} mihome-vacuum.0 2020-02-18 16:00:05.682 debug (951) Timestamp: 5e4bfbf5 mihome-vacuum.0 2020-02-18 16:00:05.682 debug (951) lastid{"get_status":21,"get_consumable":23,"get_clean_summary":24,"get_clean_record":0,"X_send_command":0,"miIO.info":22,"get_sound_volume":25,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:00:05.482 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfbf5b469e5812641ff114090831176823942e73e05937c9188ded32e873f076f8eac1aacb29a344aff44a8639e0e7c8256ae6ef94e8889ad86e006e7b6ff8728684d mihome-vacuum.0 2020-02-18 16:00:05.481 debug (951) sendMsg >>> {"id":24,"method":"get_clean_summary"} mihome-vacuum.0 2020-02-18 16:00:05.481 debug (951) Timestamp: 5e4bfbf5 mihome-vacuum.0 2020-02-18 16:00:05.481 debug (951) lastid{"get_status":21,"get_consumable":23,"get_clean_summary":24,"get_clean_record":0,"X_send_command":0,"miIO.info":22,"get_sound_volume":19,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:00:05.280 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfbf5546c2e9c1b4960b957ae0061a050377ddce49b9fa663390401b1f2ffbf5917d9be29c5143b52778265f91e22baafbbe53dedf6e0e2750918d2ba87b897d42250 mihome-vacuum.0 2020-02-18 16:00:05.280 debug (951) sendMsg >>> {"id":23,"method":"get_consumable"} mihome-vacuum.0 2020-02-18 16:00:05.280 debug (951) Timestamp: 5e4bfbf5 mihome-vacuum.0 2020-02-18 16:00:05.280 debug (951) lastid{"get_status":21,"get_consumable":23,"get_clean_summary":18,"get_clean_record":0,"X_send_command":0,"miIO.info":22,"get_sound_volume":19,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:00:05.077 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfbf54e91c611b05cc48cb054e753ff65c5af27e878438f5097a165e137a18dc63d3afcf262bc3d12b88e757094ec9c09b37b mihome-vacuum.0 2020-02-18 16:00:05.077 debug (951) sendMsg >>> {"id":22,"method":"miIO.info"} mihome-vacuum.0 2020-02-18 16:00:05.077 debug (951) Timestamp: 5e4bfbf5 mihome-vacuum.0 2020-02-18 16:00:05.077 debug (951) lastid{"get_status":21,"get_consumable":17,"get_clean_summary":18,"get_clean_record":0,"X_send_command":0,"miIO.info":22,"get_sound_volume":19,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:00:05.076 debug (951) requesting params every: 60 Sec mihome-vacuum.0 2020-02-18 16:00:05.076 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfbf56a3aaf67a7cd7c866ac4b9ff9f34f4fa3f81aaaee624b22ae8c692ce62fd4a29c159516f621917c0c67d17584d4a312e mihome-vacuum.0 2020-02-18 16:00:05.076 debug (951) sendMsg >>> {"id":21,"method":"get_status"} mihome-vacuum.0 2020-02-18 16:00:05.076 debug (951) Timestamp: 5e4bfbf5 mihome-vacuum.0 2020-02-18 16:00:05.076 debug (951) lastid{"get_status":21,"get_consumable":17,"get_clean_summary":18,"get_clean_record":0,"X_send_command":0,"miIO.info":15,"get_sound_volume":19,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 16:00:05.076 debug (951) Connected mihome-vacuum.0 2020-02-18 16:00:05.075 debug (951) Receive <<< Helo <<< 21310020000000000f92f4f95e4bfbf4ffffffffffffffffffffffffffffffff mihome-vacuum.0 2020-02-18 15:59:48.068 debug (951) Disconnect mihome-vacuum.0 2020-02-18 15:59:45.871 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfbe1fafb606e5e0e0a2926c3b53b6115286783aeb479f5cfe52bd263828a9094d5c48bfd1316a93345c45c1b122688617dd8 mihome-vacuum.0 2020-02-18 15:59:45.871 debug (951) sendMsg >>> {"id":20,"method":"get_map_v1"} mihome-vacuum.0 2020-02-18 15:59:45.871 debug (951) Timestamp: 5e4bfbe1 mihome-vacuum.0 2020-02-18 15:59:45.870 debug (951) lastid{"get_status":16,"get_consumable":17,"get_clean_summary":18,"get_clean_record":0,"X_send_command":0,"miIO.info":15,"get_sound_volume":19,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 15:59:45.670 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfbe1a47eaae3d4d7c78fbda56371d15d9a10ab158cccb4098313eff7718d3f39ff1772b4b9dd30b4477cc9c289c53c638f5e87c2acbe200eded7a1dd99ab0524577d mihome-vacuum.0 2020-02-18 15:59:45.670 debug (951) sendMsg >>> {"id":19,"method":"get_sound_volume"} mihome-vacuum.0 2020-02-18 15:59:45.670 debug (951) Timestamp: 5e4bfbe1 mihome-vacuum.0 2020-02-18 15:59:45.669 debug (951) lastid{"get_status":16,"get_consumable":17,"get_clean_summary":18,"get_clean_record":0,"X_send_command":0,"miIO.info":15,"get_sound_volume":19,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 15:59:45.469 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfbe19430c745490ab0f0562a7900534b447aa5053d21f2c8896b84a7d4014a8fbfa189d91ad4910c082a4a7b11f07d0d5f0a4090b9ef2155b509062d3e3e1b1fa54d mihome-vacuum.0 2020-02-18 15:59:45.469 debug (951) sendMsg >>> {"id":18,"method":"get_clean_summary"} mihome-vacuum.0 2020-02-18 15:59:45.469 debug (951) Timestamp: 5e4bfbe1 mihome-vacuum.0 2020-02-18 15:59:45.468 debug (951) lastid{"get_status":16,"get_consumable":17,"get_clean_summary":18,"get_clean_record":0,"X_send_command":0,"miIO.info":15,"get_sound_volume":13,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 15:59:45.267 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfbe1d2793c01c0254f3c6b61765ded5be5a6f5d6b84e56800aa346492d17dcd78049368b0485c392673c10a639297930665faeff275c598209cf73ceea50a1149ab3 mihome-vacuum.0 2020-02-18 15:59:45.267 debug (951) sendMsg >>> {"id":17,"method":"get_consumable"} mihome-vacuum.0 2020-02-18 15:59:45.267 debug (951) Timestamp: 5e4bfbe1 mihome-vacuum.0 2020-02-18 15:59:45.267 debug (951) lastid{"get_status":16,"get_consumable":17,"get_clean_summary":12,"get_clean_record":0,"X_send_command":0,"miIO.info":15,"get_sound_volume":13,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 15:59:45.069 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfbe1c732c739ca8892cfe0b9d1440bea4c03b3ca471b9351ae6b194a3529831fefd39c4ef8974748ce736485772a00830496 mihome-vacuum.0 2020-02-18 15:59:45.069 debug (951) sendMsg >>> {"id":16,"method":"get_status"} mihome-vacuum.0 2020-02-18 15:59:45.069 debug (951) Timestamp: 5e4bfbe1 mihome-vacuum.0 2020-02-18 15:59:45.068 debug (951) lastid{"get_status":16,"get_consumable":11,"get_clean_summary":12,"get_clean_record":0,"X_send_command":0,"miIO.info":15,"get_sound_volume":13,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v mihome-vacuum.0 2020-02-18 15:59:45.066 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfbe14f465e9021eedd6b999aa143ed0a9ddf79905d719e63e0d772c50734a7f67d3e4becc44992b1393edac821467923051b mihome-vacuum.0 2020-02-18 15:59:45.066 debug (951) sendMsg >>> {"id":15,"method":"miIO.info"} mihome-vacuum.0 2020-02-18 15:59:45.065 debug (951) Timestamp: 5e4bfbe1 mihome-vacuum.0 2020-02-18 15:59:45.065 debug (951) lastid{"get_status":9,"get_consumable":11,"get_clean_summary":12,"get_clean_record":0,"X_send_command":0,"miIO.info":15,"get_sound_volume":13,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v1 mihome-vacuum.0 2020-02-18 15:59:45.065 debug (951) requesting params every: 60 Sec mihome-vacuum.0 2020-02-18 15:59:25.882 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfbcd3b08a696b4a8b61a678907fa47bfdb350f415dac390530511caf4b28aadbee4c43247b4142602a40f16c1c54f4de5632 mihome-vacuum.0 2020-02-18 15:59:25.881 debug (951) sendMsg >>> {"id":14,"method":"get_map_v1"} mihome-vacuum.0 2020-02-18 15:59:25.881 debug (951) Timestamp: 5e4bfbcd mihome-vacuum.0 2020-02-18 15:59:25.881 debug (951) lastid{"get_status":9,"get_consumable":11,"get_clean_summary":12,"get_clean_record":0,"X_send_command":0,"miIO.info":10,"get_sound_volume":13,"get_carpet_mode":6,"get_room_mapping":7,"get_map_v1 mihome-vacuum.0 2020-02-18 15:59:25.680 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfbcde3d21fa2dde62d736ab83d5761d2e191dd0c32700e09dca2f6cd08e7671f74bcd70d59c93000ae4cf3b42381bb566f38de05a4a84d88118ac9d72493c99f74c1 mihome-vacuum.0 2020-02-18 15:59:25.680 debug (951) sendMsg >>> {"id":13,"method":"get_sound_volume"} mihome-vacuum.0 2020-02-18 15:59:25.680 debug (951) Timestamp: 5e4bfbcd mihome-vacuum.0 2020-02-18 15:59:25.679 debug (951) lastid{"get_status":9,"get_consumable":11,"get_clean_summary":12,"get_clean_record":0,"X_send_command":0,"miIO.info":10,"get_sound_volume":13,"get_carpet_mode":6,"get_room_mapping":7} mihome-vacuum.0 2020-02-18 15:59:25.479 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfbcd19130f14e117b125c9a1e1a4f2fb7e6eb54fbef3726880bbca7268b6faee8a176cdb74d77cc08f24ab5891341edf072ce6013d0f5328ad02714179130ecd0232 mihome-vacuum.0 2020-02-18 15:59:25.479 debug (951) sendMsg >>> {"id":12,"method":"get_clean_summary"} mihome-vacuum.0 2020-02-18 15:59:25.478 debug (951) Timestamp: 5e4bfbcd mihome-vacuum.0 2020-02-18 15:59:25.478 debug (951) lastid{"get_status":9,"get_consumable":11,"get_clean_summary":12,"get_clean_record":0,"X_send_command":0,"miIO.info":10,"get_sound_volume":5,"get_carpet_mode":6,"get_room_mapping":7} mihome-vacuum.0 2020-02-18 15:59:25.277 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfbcd666be90d90a62720049514555d7ec9b6d3a3e52b733ca787d89aa571ff707c7bb63cc3006212774a9dc04dcac1316ef96e8298f6a222336cd9c8ce6c959944b0 mihome-vacuum.0 2020-02-18 15:59:25.277 debug (951) sendMsg >>> {"id":11,"method":"get_consumable"} mihome-vacuum.0 2020-02-18 15:59:25.276 debug (951) Timestamp: 5e4bfbcd mihome-vacuum.0 2020-02-18 15:59:25.276 debug (951) lastid{"get_status":9,"get_consumable":11,"get_clean_summary":4,"get_clean_record":0,"X_send_command":0,"miIO.info":10,"get_sound_volume":5,"get_carpet_mode":6,"get_room_mapping":7} mihome-vacuum.0 2020-02-18 15:59:25.074 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfbcd7111df54168bd71404b3b8a50076eaaf4a76c7ee37bf14ca341b216cafd5b8a450e1259535ac30fd9f2a5be6a1d172c6 mihome-vacuum.0 2020-02-18 15:59:25.074 debug (951) sendMsg >>> {"id":10,"method":"miIO.info"} mihome-vacuum.0 2020-02-18 15:59:25.074 debug (951) Timestamp: 5e4bfbcd mihome-vacuum.0 2020-02-18 15:59:25.074 debug (951) lastid{"get_status":9,"get_consumable":3,"get_clean_summary":4,"get_clean_record":0,"X_send_command":0,"miIO.info":10,"get_sound_volume":5,"get_carpet_mode":6,"get_room_mapping":7} mihome-vacuum.0 2020-02-18 15:59:25.074 debug (951) requesting params every: 60 Sec mihome-vacuum.0 2020-02-18 15:59:25.073 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfbcd7526d0d6a12d8de79b8e8666f5f573bd2eb8e718aaedc96c842d7b4861304aca9a753b8abc7e8334d72dde5370b02ad6 mihome-vacuum.0 2020-02-18 15:59:25.073 debug (951) sendMsg >>> {"id":9,"method":"get_status"} mihome-vacuum.0 2020-02-18 15:59:25.073 debug (951) Timestamp: 5e4bfbcd mihome-vacuum.0 2020-02-18 15:59:25.073 debug (951) lastid{"get_status":9,"get_consumable":3,"get_clean_summary":4,"get_clean_record":0,"X_send_command":0,"miIO.info":2,"get_sound_volume":5,"get_carpet_mode":6,"get_room_mapping":7} mihome-vacuum.0 2020-02-18 15:59:25.073 debug (951) Connected mihome-vacuum.0 2020-02-18 15:59:25.072 debug (951) Receive <<< Helo <<< 21310020000000000f92f4f95e4bfbccffffffffffffffffffffffffffffffff mihome-vacuum.0 2020-02-18 15:59:08.065 debug (951) Disconnect mihome-vacuum.0 2020-02-18 15:59:05.066 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfbb9f11bed4c44ca5c4f68ee6547d62aeeeb7a7268e7ec363b8b5266ca94e9e88fcb75adf0f3fc46cc403b4279a629bdd13c mihome-vacuum.0 2020-02-18 15:59:05.066 debug (951) sendMsg >>> {"id":8,"method":"get_status"} mihome-vacuum.0 2020-02-18 15:59:05.066 debug (951) Timestamp: 5e4bfbb9 mihome-vacuum.0 2020-02-18 15:59:05.065 debug (951) lastid{"get_status":8,"get_consumable":3,"get_clean_summary":4,"get_clean_record":0,"X_send_command":0,"miIO.info":2,"get_sound_volume":5,"get_carpet_mode":6,"get_room_mapping":7} mihome-vacuum.0 2020-02-18 15:58:48.067 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfba8e668f39c733e4e039d43a9b346a2c00ef0410824fdb8626d0fe5a4cce82fb65a69d0cba41684107bd42c1ee1c4b564ce5c64dde5cdf0497d4ade068ff73c5f89 mihome-vacuum.0 2020-02-18 15:58:48.067 debug (951) sendMsg >>> {"id":7,"method":"get_room_mapping"} mihome-vacuum.0 2020-02-18 15:58:48.067 debug (951) Timestamp: 5e4bfba8 mihome-vacuum.0 2020-02-18 15:58:48.067 debug (951) lastid{"get_status":1,"get_consumable":3,"get_clean_summary":4,"get_clean_record":0,"X_send_command":0,"miIO.info":2,"get_sound_volume":5,"get_carpet_mode":6,"get_room_mapping":7} mihome-vacuum.0 2020-02-18 15:58:48.067 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfba88c720466dbef65c2c03f4f9ee41f3de59a3b5b003a24917d189bc9fbfeaa9bd7d5ad22661e7deb4204a632aa8a80998d7bc26469589d52e9666a46cb09624637 mihome-vacuum.0 2020-02-18 15:58:48.067 debug (951) sendMsg >>> {"id":6,"method":"get_carpet_mode"} mihome-vacuum.0 2020-02-18 15:58:48.066 debug (951) Timestamp: 5e4bfba8 mihome-vacuum.0 2020-02-18 15:58:48.066 debug (951) lastid{"get_status":1,"get_consumable":3,"get_clean_summary":4,"get_clean_record":0,"X_send_command":0,"miIO.info":2,"get_sound_volume":5,"get_carpet_mode":6} mihome-vacuum.0 2020-02-18 15:58:47.643 debug (951) Xiaomi Cloud: Login successful mihome-vacuum.0 2020-02-18 15:58:45.712 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfba5fea28ea9ba79d362762e12a468986b4006309904a82bf1f156a07061d4b94b5c26b52b357dea080e99ab4db0c16f14e9012cd2d79305e0d6a7ae4847ff79fe9c mihome-vacuum.0 2020-02-18 15:58:45.712 debug (951) sendMsg >>> {"id":5,"method":"get_sound_volume"} mihome-vacuum.0 2020-02-18 15:58:45.711 debug (951) Timestamp: 5e4bfba5 mihome-vacuum.0 2020-02-18 15:58:45.711 debug (951) lastid{"get_status":1,"get_consumable":3,"get_clean_summary":4,"get_clean_record":0,"X_send_command":0,"miIO.info":2,"get_sound_volume":5} mihome-vacuum.0 2020-02-18 15:58:45.570 info (951) set nächster Timer: Nicht verfügbar mihome-vacuum.0 2020-02-18 15:58:45.509 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfba5a492e8b0c84fadcbee68bc599e80a8249d7e7c52770f031d8d3a52d414869bd7c26dae6b8e73e46ac44075f9b7bad744feb9296b63ae7817f0c051a844abd5c9 mihome-vacuum.0 2020-02-18 15:58:45.509 debug (951) sendMsg >>> {"id":4,"method":"get_clean_summary"} mihome-vacuum.0 2020-02-18 15:58:45.509 debug (951) Timestamp: 5e4bfba5 mihome-vacuum.0 2020-02-18 15:58:45.509 debug (951) lastid{"get_status":1,"get_consumable":3,"get_clean_summary":4,"get_clean_record":0,"X_send_command":0,"miIO.info":2} mihome-vacuum.0 2020-02-18 15:58:45.308 debug (951) sendMsgRaw >>> 21310050000000000f92f4f95e4bfba5cdd919eb342d83719be4148ef696d42bd91200f1415618e5353b3d7e188677e661da4d7e24b95cb5a3426655717f1cd7cdd960396aeeb6f580b561447c11b64e mihome-vacuum.0 2020-02-18 15:58:45.307 debug (951) sendMsg >>> {"id":3,"method":"get_consumable"} mihome-vacuum.0 2020-02-18 15:58:45.307 debug (951) Timestamp: 5e4bfba5 mihome-vacuum.0 2020-02-18 15:58:45.307 debug (951) lastid{"get_status":1,"get_consumable":3,"get_clean_summary":0,"get_clean_record":0,"X_send_command":0,"miIO.info":2} mihome-vacuum.0 2020-02-18 15:58:45.100 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfba5399528b051370ce0b9335866b2e2f2b518af33e4da50f51f2b34b326512c2c8d37f47026b25267cc78188591a2d63fde mihome-vacuum.0 2020-02-18 15:58:45.100 debug (951) sendMsg >>> {"id":2,"method":"miIO.info"} mihome-vacuum.0 2020-02-18 15:58:45.100 debug (951) Timestamp: 5e4bfba5 mihome-vacuum.0 2020-02-18 15:58:45.100 debug (951) lastid{"get_status":1,"get_consumable":0,"get_clean_summary":0,"get_clean_record":0,"X_send_command":0,"miIO.info":2} mihome-vacuum.0 2020-02-18 15:58:45.100 debug (951) requesting params every: 60 Sec mihome-vacuum.0 2020-02-18 15:58:45.099 debug (951) sendMsgRaw >>> 21310040000000000f92f4f95e4bfba559d0c2057a78a8b46b193bfa3943a1f33ed19fe9dd9e7078a3ddcd6dab664a8e9554fc458c0a971679eb008e1c9a3775 mihome-vacuum.0 2020-02-18 15:58:45.099 debug (951) sendMsg >>> {"id":1,"method":"get_status"} mihome-vacuum.0 2020-02-18 15:58:45.099 debug (951) Timestamp: 5e4bfba5 mihome-vacuum.0 2020-02-18 15:58:45.099 debug (951) lastid{"get_status":1,"get_consumable":0,"get_clean_summary":0,"get_clean_record":0,"X_send_command":0} mihome-vacuum.0 2020-02-18 15:58:45.098 debug (951) Connected mihome-vacuum.0 2020-02-18 15:58:45.098 debug (951) Receive <<< Helo <<< 21310020000000000f92f4f95e4bfba4ffffffffffffffffffffffffffffffff mihome-vacuum.0 2020-02-18 15:58:45.089 info (951) New generation or new fw detected, create new states goto and zoneclean mihome-vacuum.0 2020-02-18 15:58:45.088 info (951) change states from State control.fan_power mihome-vacuum.0 2020-02-18 15:58:45.066 debug (951) server started on 0.0.0.0:53421 mihome-vacuum.0 2020-02-18 15:58:45.060 info (951) Cloud control disabled mihome-vacuum.0 2020-02-18 15:58:45.059 info (951) Expert mode enabled, states created mihome-vacuum.0 2020-02-18 15:58:45.056 debug (951) Xiaomi Cloud: Logging in mihome-vacuum.0 2020-02-18 15:58:45.055 debug (951) Maphelper_config___{"username":"xxxxxxx","password":"xxxxxxx","deviceId":"","clientId":"ztzyjt","server":"de","valetudo":false,"mimap":true,"ip":"192.168.1.70","COLOR_OPTIONS":{" mihome-vacuum.0 2020-02-18 15:58:45.055 debug (951) load Map creator... true mihome-vacuum.0 2020-02-18 15:58:45.026 info (951) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0 mihome-vacuum.0 2020-02-18 15:58:43.315 debug (951) statesDB connected mihome-vacuum.0 2020-02-18 15:58:43.314 debug (951) States connected to redis: 127.0.0.1:9000 mihome-vacuum.0 2020-02-18 15:58:43.312 debug (951) States create System PubSub Client mihome-vacuum.0 2020-02-18 15:58:43.312 debug (951) States create User PubSub Client mihome-vacuum.0 2020-02-18 15:58:43.310 debug (951) Redis States: Use Redis connection: 127.0.0.1:9000 mihome-vacuum.0 2020-02-18 15:58:43.309 debug (951) objectDB connected mihome-vacuum.0 2020-02-18 15:58:43.307 debug (951) Objects connected to redis: 127.0.0.1:9001 mihome-vacuum.0 2020-02-18 15:58:43.303 debug (951) Objects client initialize lua scripts mihome-vacuum.0 2020-02-18 15:58:43.303 debug (951) Objects create User PubSub Client mihome-vacuum.0 2020-02-18 15:58:43.302 debug (951) Objects create System PubSub Client mihome-vacuum.0 2020-02-18 15:58:43.301 debug (951) Objects client ready ... initialize now mihome-vacuum.0 2020-02-18 15:58:43.199 debug (951) Redis Objects: Use Redis connection: 127.0.0.1:9001
Wenn ich mehr tun kann, lass es mich bitte wissen.
