  4. (solved) zigbee stick cc2538 max 20-21 devices
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
zigbee 3.0cc2538pairingzigbeexiami aqara
103 Beiträge 16 Kommentatoren 21.3k Aufrufe 20 Beobachtet
    @arteck hier das komplette Log:
    zigbee.0	2020-02-14 08:25:39.572	info	(3261) Zigbee started
    zigbee.0	2020-02-14 08:25:39.571	info	(3261) 0x00158d0002739dc7 (addr 43041): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    zigbee.0	2020-02-14 08:25:39.571	info	(3261) 0x00158d000276c23e (addr 45102): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    zigbee.0	2020-02-14 08:25:39.571	info	(3261) 0x00158d000276c461 (addr 46205): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    zigbee.0	2020-02-14 08:25:39.570	info	(3261) 0x00158d000276c157 (addr 50651): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    zigbee.0	2020-02-14 08:25:39.570	info	(3261) 0x00158d0002b8fa09 (addr 13712): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    zigbee.0	2020-02-14 08:25:39.569	info	(3261) 0x00158d000275cb32 (addr 1820): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    zigbee.0	2020-02-14 08:25:39.569	info	(3261) 0x00158d00026edf58 (addr 28454): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    zigbee.0	2020-02-14 08:25:39.569	info	(3261) 0x00158d0002389e06 (addr 25399): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    zigbee.0	2020-02-14 08:25:39.568	info	(3261) 0x00158d0002c645cb (addr 49964): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    zigbee.0	2020-02-14 08:25:39.568	info	(3261) 0x00158d000272b615 (addr 21143): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    zigbee.0	2020-02-14 08:25:39.567	info	(3261) 0x00158d0002b90584 (addr 6947): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    zigbee.0	2020-02-14 08:25:39.567	info	(3261) 0x00158d0002760d2e (addr 42744): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    zigbee.0	2020-02-14 08:25:39.566	info	(3261) 0x00158d0002c644ee (addr 46743): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    zigbee.0	2020-02-14 08:25:39.566	info	(3261) 0x00158d00027379dd (addr 23995): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    zigbee.0	2020-02-14 08:25:39.566	info	(3261) 0x00158d00024e4345 (addr 31519): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    zigbee.0	2020-02-14 08:25:39.565	info	(3261) 0x00158d000276e4aa (addr 54332): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    zigbee.0	2020-02-14 08:25:39.565	info	(3261) 0x00158d000277253a (addr 43804): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    zigbee.0	2020-02-14 08:25:39.564	info	(3261) 0x00158d0002731600 (addr 52056): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    zigbee.0	2020-02-14 08:25:39.564	info	(3261) 0x00158d0002731501 (addr 9607): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    zigbee.0	2020-02-14 08:25:39.563	info	(3261) 0x00158d000273154c (addr 32534): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    zigbee.0	2020-02-14 08:25:39.560	info	(3261) Currently 20 devices are joined:
    zigbee.0	2020-02-14 08:25:39.554	info	(3261) --> transmitPower : normal
    zigbee.0	2020-02-14 08:25:39.551	info	(3261) Disable LED
    zigbee.0	2020-02-14 08:25:39.547	info	(3261) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200128}}
    zigbee.0	2020-02-14 08:25:38.344	info	(3261) Starting Zigbee...
    zigbee.0	2020-02-14 08:25:38.332	info	(3261) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.17.0
    zigbee.0	2020-02-14 08:25:34.618	info	(668) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    zigbee.0	2020-02-14 08:25:34.618	info	(668) terminating
    zigbee.0	2020-02-14 08:25:34.559	info	(668) Zigbee: disabling joining new devices.
    zigbee.0	2020-02-14 08:25:34.558	info	(668) cleaned everything up...
    zigbee.0	2020-02-14 08:25:34.556	info	(668) Got terminate signal TERMINATE_YOURSELF
    Ich hatte am Anfang nur den Stick gewechselt, dann kamen jedoch Probleme mit den Osram Plugs.
    Daher habe ich dann den Stick mit HardReset zurückgesetzt und in ioBroker alle Objekte belassen.
    Das ist die aktuelle Situation in der bei 20 Geräten Schluss ist.
    Ich kann auch gerne nochmal alles zurücksetzen und die Objekte in ioBroker und den Adapter und die Instanz löschen.
    Würde das aber nur machen, wenn es sinnvoll ist. Da es doch etwas Arbeit ist alles wieder einzurichten...
    XsevX
    XsevX
    Xsev
    schrieb am zuletzt editiert von Xsev
    @nis sagte in zigbee stick cc2538 max 20-21 devices:
    Die Plugs sind aber aktuell nicht angelernt oder? Zumindest laut log nur die Sensoren. Ich lerne immer erst alle Plugs (router) an und dann die Sensoren (auch alles Xiaomi), aktuell über 40 Geräte.
    • XsevX Xsev
      @Xsev die plugs sind nicht angelernt, korrekt. Eigentlich möchte ich die auch komplett rauslassen wenn es geht, da mir 200 Geräte erstmal reichen würden.
        ich probiere nun mal ob das Problem mit einem Osram Plug sich beheben lässt.
        Aktuell kann ich immer noch max 20 Geräte anlernen, lösche ich dann zwei wieder kann ich wieder zwei anlernen.
        Ich komme nur nie über 20 Geräte hinaus.
        Echt frustrierend.
        • D dimaiv
          @nis
          Hi, da fehlt bei dir im Log mindestens eine Zeile oben, "Currently xx devices are joined"
          Hast du mit sauberem Adapter angefangen (alle Geräte vom alten Coordinator abgemeldet)? Oder hast du einfach die Sticks umgesteckt?
          Bei mir waren es 43 auf einem direkt verbunden. Im Moment sind es 26 auf einem, weil ich aufgeteilt habe um die verschiedene Firmware zu testen.
          Und ich habe noch von keinem gehört über irgendwelche Limits. Es gibt auch Installationen mit über 60 Geräte.
          @dimaiv @arteck wie kommt die magische Grenze von 200? Ist die irgendwo als Variable hinterlegt? Ich finde im Netz ein paar Einträge zur Suche "cc2538 limit no of devices" die als Ergebnis besagen, dass 20 die Grenze ist.
          Hier z.B.:
          https://e2e.ti.com/support/wireless-connectivity/zigbee-and-thread/f/158/t/641845?CC2538-CC2592EMK-Maximum-no-of-devices-allowed-in-zigbee-network-
          Oder hier:
          http://e2e.ti.com/support/wireless-connectivity/zigbee-and-thread/f/158/t/651268?CC2538-CC2592EMK-Network-size-limit-issue-
          Was genau besagt die Variable NWK_MAX_DEVICE_LIST im Zusammenhang mit cc2538 und ioBroker? Ist das überhaupt relevant?
            Hier z.B.:
            Oder hier:
            @nis Osram Plugs lassen sich leider nicht anlernen. Mit denen war ich irgendwie schon immer auf Kriegsfuss
              @nis Ich habe gleich mal nachgezählt.bei mir sind es bis jetzt 27 Geräte.
              @ostseereiter was hast du für Geräte genau. Sind die 27 Geräte alles Sensoren von Xiaomi? Sind es alles batteriebetriebene?
              ostseereiterO 1 Antwort Letzte Antwort
                ostseereiterO
                ostseereiterO
                ostseereiter
                @nis sind sogar 32
                11 osrams Plug
                6 Lampen Osram
                1 Osram Strips
                1 Lampe Innr
                2 Xiaomi Bewegungsmelder
                6 Xiaomi Fensterkontakte
                4 Xiaomi Temperatursensoren
                1 Xiaomi Switch
                Gruß OSR
                Plattform
                • ostseereiterO ostseereiter
                  @nis sind sogar 32
                  11 osrams Plug
                  6 Lampen Osram
                  1 Osram Strips
                  1 Lampe Innr
                  1 Xiaomi Switch
                  @ostseereiter Ok, durch die Osram Plugs hast du ja weitere Router bei dir im Zigbee Netzwerk. Dadurch kommst du auch auf mehr als 20 Geräte im Gesamten. Dann ist dein Setup leider doch nicht mit meinem vergleichbar.
                    ostseereiterO
                    ostseereiterO
                    ostseereiter
                    @nis
                    aber meinst Du das liegt daran?
                    Gruß OSR
                    Plattform
                      @nis
                      @ostseereiter ich habe aktuell keine Ahnung wo die Ursache liegt, definitiv kann ich nicht mehr als 20 Geräte anlernen. Welche Firmware hast du bei dir auf dem Stick?
                      Auch genau diese?
                        Auch genau diese?
                        ostseereiterO
                        ostseereiterO
                        ostseereiter
                        @nis wie kann ich diese auslesen?
                        Gruß OSR
                        Plattform
                          @ostseereiter das steht im Log beim Start der Instanz
                            ostseereiterO
                            ostseereiterO
                            ostseereiter
                            @nis
                            	info	(16946) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200128}}
                            Gruß OSR
                            Plattform
                            • D dimaiv
                              @nis
                              @dimaiv ich bin nun nochmal tiefer eingestiegen und habe mir die Firmware angesehen...
                              Vorrausgesetzt diese Anleitung ist zutreffend auf den Stick von mir:
                              https://github.com/Koenkk/Z-Stack-firmware/blob/master/coordinator/Z-Stack_3.0.x/COMPILE.md#cc2538_cc2592_modkamru_v3
                              Dann ergibt sich daraus folgendes:
                              • Die Verlinkte Version Z-STACK-3.0.2. beinhaltet tatsächlich als default Wert für NWK_MAX_DEVICE_LIST den Wert 20.
                              • Das Verlinkte Patchfile überschreibt den Wert nicht. Somit ist weiterhin der Wert auf 20 gesetzt.
                              @arteck wo kann ich den Wert 200 entnehmen den du oben erwähnt hast?!? Wird der irgendwie beim kompilieren gesetzt?
                              @dimaiv @arteck ich habe bislang noch keine Ahnung vom Umgang mit Stick und neuer Firmware. Aber irgendwie will ich dem Problem auf den Grund kommen. Vielen Dank für eure Hilfe vielleicht habt ihr noch weitere Ideen zur Lösung
                              D ostseereiterO 2 Antworten Letzte Antwort
                                D
                                D
                                dimaiv
                                schrieb am zuletzt editiert von dimaiv
                                @nis
                                Hi, hast du Möglichkeit die Firmware neu flaschen?
                                Hab auch den ganzen Tag versucht Fehler zu finden, bei dem Patch ist mir auch gerade aufgefallen dass da die Angaben zu Max Device fehlen. Im aktuellen Patch sind die drin und steht auf 80 (direkte).
                                Ich versuche gerade das mit dem Autor zu besprechen.
                                ioBroker- NUC8i3 / Proxmox / VM
                                Node.js v22.21.0
                                NPM v10.9.4
                                JS controller 7.1.0
                                Admin 7.7.20
                                ZigBee Adapter 3.3.1alpha.0
                                Zigbee LAN Gateway CC2652P
                                Zigbee Firmware 20250321
                                ? 2 Antworten Letzte Antwort
                                  ostseereiterO
                                  ostseereiterO
                                  ostseereiter
                                  @nis wie kann man den auslesen? dann muss ja bei mir mehr stehen.
                                  Gruß OSR
                                  Plattform
                                    D
                                    D
                                    dimaiv
                                    @ostseereiter
                                    Ist nicht so einfach, fast unmöglich.
                                    Du hast aber absolut die gleiche Firmware wie nis.
                                    Node.js v22.21.0
                                    NPM v10.9.4
                                    JS controller 7.1.0
                                    Admin 7.7.20
                                    • D dimaiv
                                      @ostseereiter
                                      ostseereiterO
                                      ostseereiterO
                                      ostseereiter
                                      @dimaiv aber mehr Geräte dran.
                                      Gruß OSR
                                      Plattform
                                      • D dimaiv
                                        @nis
                                        @dimaiv sagte in zigbee stick cc2538 max 20-21 devices:
                                        Keine Ahnung. Wie geht das denn? Gibt's dazu irgendwo eine Anleitung?
                                        • D dimaiv
                                          @nis
                                          Müssten das nicht 200 sein? Oder wie kommt man auf die magische Obergrenze?
                                          D arteckA 3 Antworten Letzte Antwort
                                          33.2k
                                          84.3k
