  5. Alexa Radiosender eingeschalten bei Bewegung im Raum
    5.4k
blockly
48 Beiträge 8 Kommentatoren 9.8k Aufrufe 8 Beobachtet
  • Semie1S Semie1
    @dslraser
    das stimmt geht mir auf den Kranz hab es aber wie gesagt nicht hinbekommen
    dslraserD Offline
    dslraserD Offline
    dslraser
    @Semie1
     <variables>
       <variable type="undefined" id="timeout">timeout</variable>
     </variables>
     <block type="on_ext" id="r-nlIeYfQsB!7hW8z)n/" x="138" y="88">
       <mutation items="1"></mutation>
       <value name="OID0">
         <shadow type="field_oid" id="ZH5Fq?HHGR2tM0D(3@+w">
           <field name="oid">hm-rpc.0.000C18A996B41F.1.PRESENCE_DETECTION_STATE</field>
         </shadow>
       </value>
       <statement name="STATEMENT">
         <block type="timeouts_cleartimeout" id="q|-p2?k`?,pDxba#s-;e">
           <next>
             <block type="controls_if" id="8x[QmC/L=v)5,3EL]k((">
               <value name="IF0">
                 <block type="logic_operation" id="%YWl/m6hY]Vfxff_/ng?" inline="false">
                   <field name="OP">AND</field>
                   <value name="A">
                     <block type="on_source" id="jCA,k#ie!DDYa}CnEF)m">
                     </block>
                   </value>
                   <value name="B">
                     <block type="time_compare_ex" id="SxaKx-sfWwm)oNM%6^R{">
                       <mutation end_time="true" actual_time="true"></mutation>
                       <field name="USE_ACTUAL_TIME">TRUE</field>
                       <field name="OPTION">between</field>
                       <value name="START_TIME">
                         <shadow type="text" id="id/^ZerlywV_wIRA]#`m">
                           <field name="TEXT">10:00</field>
                         </shadow>
                       </value>
                       <value name="END_TIME">
                         <shadow type="text" id="|MH-Z)!3tFj$V8E9s,DT">
                           <field name="TEXT">23:00</field>
                         </shadow>
                       </value>
                     </block>
                   </value>
                 </block>
               </value>
               <statement name="DO0">
                 <block type="control" id=".7Tp[*pw%Qj=OW(I9wg=">
                   <mutation delay_input="false"></mutation>
                   <field name="OID">alexa2.0.Echo-Devices.G070RQ10751703Q5.Music-Provider.TuneIn</field>
                   <value name="VALUE">
                     <block type="text" id="}y;pL{Gd2~ccmb{(`O|3">
                       <field name="TEXT">NDR2</field>
                     </block>
                   </value>
                 </block>
               </statement>
               <statement name="ELSE">
                 <block type="timeouts_settimeout" id="M?fSimc$R_kHs7PWfJOd">
                   <field name="DELAY">10</field>
                     <block type="control" id="sUs/n(4vP|~T16G0._$a">
                       <field name="OID">alexa2.0.Echo-Devices.G070RQ10751703Q5.Player.controlPause</field>
                         <block type="logic_boolean" id="v-hsBwQx=u62s?(Qa19#">
                         </block>
                       </value>
                     </block>
                   </statement>
                 </block>
               </statement>
             </block>
           </next>
         </block>
       </statement>
     </block>
    </xml>
    Editiert--Zeit eingefügt
    F 1 Antwort Letzte Antwort
    • Semie1S Offline
      Semie1S Offline
      Semie1
      Probiere ich gleich mal aus. Besten Dank erstmal
      • dslraserD dslraser
        @Flopsi
        Hat Dein BWM bei erkannter Bewegung kein true/false ? Dein Trigger ist auf wurde aktualisiert und löst dann immer bei erneuter Bewegung aus.
        Flopsi
        @dslraser doch hat er er kann true/false
        • Semie1S Offline
          Semie1S Offline
          Semie1
          habe das vom dsraser probiert
          trotzdem fängt es immer wiedr von neuen an wenn ich am BW vorbei laufe. Das ist mist es sollte nur einmal und solange bis ich den Raum wieder verlasse laufen
            @Semie1
             <variables>
             </variables>
               <value name="OID0">
                 </shadow>
               </value>
                   <next>
                       <value name="IF0">
                           <value name="A">
                             </block>
                           </value>
                           <value name="B">
                                 </shadow>
                               </value>
                                 </shadow>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                             </block>
                           </value>
                         </block>
                       </statement>
                                 </block>
                               </value>
                             </block>
                           </statement>
                         </block>
                       </statement>
                     </block>
                   </next>
                 </block>
               </statement>
             </block>
            </xml>
            Flopsi
            @dslraser Was bedeutet der Block Wert ? Warum ist der stop timeout Block über dem falls Block ? Bei dem Blockly ist auch kein true/false eingebaut .....
            • Semie1S Semie1
              Flopsi
              @Semie1 ja so will ich das auch nur einmal bis der Raum verlassen wird
              • Semie1S Offline
                Semie1S Offline
                Semie1
                nochmal geändert hoffe ist jetzt richtig
                • Semie1S Semie1
                  Flopsi
                  schrieb am zuletzt editiert von Flopsi
                  @Semie1 was hast du den geändert sehe keinen unterschied zu deinem vorherigen Post ....
                  und woher ist die blaue "und" Block ?
                  • Semie1S Offline
                    Semie1S Offline
                    Semie1
                    Habe es von dslraser übernommen und auf meine Geräte abgeändert, Was zum Teufel macht der Block "wert" gehört er da überhaupt hin.
                    • F Flopsi
                      Adnim
                      schrieb am zuletzt editiert von Adnim
                      @Flopsi sagte in Alexa Radiosender eingeschalten bei Bewegung im Raum:
                      wert übernimmt den Trigger also ist der wert vom trigger wahr
                      stop block damit der timer nicht 2x gestartet wird
                      • Semie1S Semie1
                        Flopsi
                        @Semie1 :) ich sehe wir sind auf dem selben Level :)
                        • F Offline
                          Flopsi
                          Ich finden den Block und nicht....
                          und
                          den Block falls mache sonst auch nicht.....
                          Wo gibts es die ??!!??
                          • F Flopsi
                            und
                            Adnim
                            @Flopsi
                            Wert Block unter trigger steht objekt ID dran kannst du nach einfügen dann per dropdown umstellen auf wert
                            den falls block einfügen und dann auf das zahnrad klicken einen sonst block dazumachen.
                            • F Offline
                              Flopsi
                              Ok Sonst habe ich gefunden :) Danke
                              diesen BLock leider nicht.
                              Wo kann man sich das Wissen aneignen ... gibts ne WIKI oder Handbücher ... oder nur learning by doing ? und andere Leute löcher in Bauch fragen ??
                              A oberfraggerO 2 Antworten Letzte Antwort
                              • Semie1S Semie1
                                @Flopsi
                                Bei mir funzt es so schon sehr lange
                                oberfraggerO Offline
                                oberfragger
                                @Semie1 Also die Ansage ist ja wiklich großes Kino! Allein dafür sollte ich mir wohlnen Präsenzmelder zulegen ;)
                                • F Flopsi
                                  Adnim
                                  @Flopsi
                                  klar das ist der normale "und" Block mit rechtsklick auf externe eingänge umgeschaltet
                                  Es gibt alles, aber learning by doing ist dann immer noch angesagt. Hier gibts im Forum ja auch tausend beispiele für alles...
                                  • F Flopsi
                                    oberfragger
                                    @Flopsi Youtube und ioBroker Forum. Durchwühlen & forschen, dann wirds was.
                                    Hinweis zum Blockly: Unter Logik
                                    • oberfraggerO oberfragger
                                      Flopsi
                                      @oberfragger genau der block war es was ich nicht wusste das man dann noch auf interne und externe Eingänge stellen kann. Ist aber jetzt abgespeichert :)und2.JPG
                                      • F Offline
                                        Flopsi
                                        So sieht es bei mir jetzt aus leider immer noch das Problem das bei jeder Bewegung alexa immer neu startet.
                                        Ich möcht aber das sie nur einmal startet und wenn keine bewegung mehr erkannt wird dann aus geht.
                                        • F Flopsi
                                          Adnim
                                          @Flopsi
                                          erhöhe mal das timeout auf die zeit die dein Bewegungsmelder brauch um den state zu ändern. wie schnell sendet der denn keine bewegung erkannt?
                                          und du musst device stop mit wahr steuern im timer!
                                          wenn das nicht hilft dann beim einschalten mit abfragen ob alexa schon dudelt
                                          alexa2.0.Echo-Devices.GXXXXXXXXXBG.Player.currentState
