  5. Alexa Radiosender eingeschalten bei Bewegung im Raum
    5.4k
blockly
48 Beiträge 8 Kommentatoren 9.8k Aufrufe 8 Beobachtet
  • dslraserD dslraser
    @Semie1
     <variables>
       <variable type="undefined" id="timeout">timeout</variable>
     </variables>
     <block type="on_ext" id="r-nlIeYfQsB!7hW8z)n/" x="138" y="88">
       <mutation items="1"></mutation>
       <value name="OID0">
         <shadow type="field_oid" id="ZH5Fq?HHGR2tM0D(3@+w">
           <field name="oid">hm-rpc.0.000C18A996B41F.1.PRESENCE_DETECTION_STATE</field>
         </shadow>
       </value>
       <statement name="STATEMENT">
         <block type="timeouts_cleartimeout" id="q|-p2?k`?,pDxba#s-;e">
           <next>
             <block type="controls_if" id="8x[QmC/L=v)5,3EL]k((">
               <value name="IF0">
                 <block type="logic_operation" id="%YWl/m6hY]Vfxff_/ng?" inline="false">
                   <field name="OP">AND</field>
                   <value name="A">
                     <block type="on_source" id="jCA,k#ie!DDYa}CnEF)m">
                     </block>
                   </value>
                   <value name="B">
                     <block type="time_compare_ex" id="SxaKx-sfWwm)oNM%6^R{">
                       <mutation end_time="true" actual_time="true"></mutation>
                       <field name="USE_ACTUAL_TIME">TRUE</field>
                       <field name="OPTION">between</field>
                       <value name="START_TIME">
                         <shadow type="text" id="id/^ZerlywV_wIRA]#`m">
                           <field name="TEXT">10:00</field>
                         </shadow>
                       </value>
                       <value name="END_TIME">
                         <shadow type="text" id="|MH-Z)!3tFj$V8E9s,DT">
                           <field name="TEXT">23:00</field>
                         </shadow>
                       </value>
                     </block>
                   </value>
                 </block>
               </value>
               <statement name="DO0">
                 <block type="control" id=".7Tp[*pw%Qj=OW(I9wg=">
                   <mutation delay_input="false"></mutation>
                   <field name="OID">alexa2.0.Echo-Devices.G070RQ10751703Q5.Music-Provider.TuneIn</field>
                   <value name="VALUE">
                     <block type="text" id="}y;pL{Gd2~ccmb{(`O|3">
                       <field name="TEXT">NDR2</field>
                     </block>
                   </value>
                 </block>
               </statement>
               <statement name="ELSE">
                 <block type="timeouts_settimeout" id="M?fSimc$R_kHs7PWfJOd">
                   <field name="DELAY">10</field>
                     <block type="control" id="sUs/n(4vP|~T16G0._$a">
                       <field name="OID">alexa2.0.Echo-Devices.G070RQ10751703Q5.Player.controlPause</field>
                         <block type="logic_boolean" id="v-hsBwQx=u62s?(Qa19#">
                         </block>
                       </value>
                     </block>
                   </statement>
                 </block>
               </statement>
             </block>
           </next>
         </block>
       </statement>
     </block>
    </xml>
    Editiert--Zeit eingefügt
    Flopsi
    @dslraser Was bedeutet der Block Wert ? Warum ist der stop timeout Block über dem falls Block ? Bei dem Blockly ist auch kein true/false eingebaut .....
    • Semie1S Semie1
      habe das vom dsraser probiert
      trotzdem fängt es immer wiedr von neuen an wenn ich am BW vorbei laufe. Das ist mist es sollte nur einmal und solange bis ich den Raum wieder verlasse laufen
      Flopsi
      @Semie1 ja so will ich das auch nur einmal bis der Raum verlassen wird
      • Semie1S Offline
        Semie1S Offline
        Semie1
        nochmal geändert hoffe ist jetzt richtig
        F 1 Antwort Letzte Antwort
        • Semie1S Semie1
          Flopsi
          schrieb am zuletzt editiert von Flopsi
          @Semie1 was hast du den geändert sehe keinen unterschied zu deinem vorherigen Post ....
          und woher ist die blaue "und" Block ?
          • Semie1S Offline
            Semie1S Offline
            Semie1
            Habe es von dslraser übernommen und auf meine Geräte abgeändert, Was zum Teufel macht der Block "wert" gehört er da überhaupt hin.
            • F Flopsi
              Adnim
              schrieb am zuletzt editiert von Adnim
              @Flopsi sagte in Alexa Radiosender eingeschalten bei Bewegung im Raum:
              wert übernimmt den Trigger also ist der wert vom trigger wahr
              stop block damit der timer nicht 2x gestartet wird
              • Semie1S Semie1
                Flopsi
                @Semie1 :) ich sehe wir sind auf dem selben Level :)
                • F Offline
                  Flopsi
                  Ich finden den Block und nicht....
                  und
                  den Block falls mache sonst auch nicht.....
                  Wo gibts es die ??!!??
                  • F Flopsi
                    und
                    Adnim
                    @Flopsi
                    Wert Block unter trigger steht objekt ID dran kannst du nach einfügen dann per dropdown umstellen auf wert
                    den falls block einfügen und dann auf das zahnrad klicken einen sonst block dazumachen.
                    • F Offline
                      Flopsi
                      Ok Sonst habe ich gefunden :) Danke
                      diesen BLock leider nicht.
                      Wo kann man sich das Wissen aneignen ... gibts ne WIKI oder Handbücher ... oder nur learning by doing ? und andere Leute löcher in Bauch fragen ??
                      A oberfraggerO 2 Antworten Letzte Antwort
                      • Semie1S Semie1
                        @Flopsi
                        Bei mir funzt es so schon sehr lange
                        oberfraggerO Offline
                        oberfragger
                        @Semie1 Also die Ansage ist ja wiklich großes Kino! Allein dafür sollte ich mir wohlnen Präsenzmelder zulegen ;)
                        • F Flopsi
                          Adnim
                          @Flopsi
                          klar das ist der normale "und" Block mit rechtsklick auf externe eingänge umgeschaltet
                          Es gibt alles, aber learning by doing ist dann immer noch angesagt. Hier gibts im Forum ja auch tausend beispiele für alles...
                          • F Flopsi
                            oberfragger
                            @Flopsi Youtube und ioBroker Forum. Durchwühlen & forschen, dann wirds was.
                            Hinweis zum Blockly: Unter Logik
                            • oberfraggerO oberfragger
                              Flopsi
                              @oberfragger genau der block war es was ich nicht wusste das man dann noch auf interne und externe Eingänge stellen kann. Ist aber jetzt abgespeichert :)und2.JPG
                              • F Offline
                                Flopsi
                                So sieht es bei mir jetzt aus leider immer noch das Problem das bei jeder Bewegung alexa immer neu startet.
                                Ich möcht aber das sie nur einmal startet und wenn keine bewegung mehr erkannt wird dann aus geht.
                                • F Flopsi
                                  Adnim
                                  @Flopsi
                                  erhöhe mal das timeout auf die zeit die dein Bewegungsmelder brauch um den state zu ändern. wie schnell sendet der denn keine bewegung erkannt?
                                  und du musst device stop mit wahr steuern im timer!
                                  wenn das nicht hilft dann beim einschalten mit abfragen ob alexa schon dudelt
                                  alexa2.0.Echo-Devices.GXXXXXXXXXBG.Player.currentState
                                  • F Offline
                                    Flopsi
                                    Wie kann ich diese Abfrage einbauen ob alexa schon dudelt habe leider keine Idee, kannst du mir ein Blocky beispiel machen als Screen.
                                    • F Flopsi
                                      Adnim
                                      einfach noch nen falls block um phrase to play with tunein dort dann denn state von deinem Echo raussuchen.
                                      • F Offline
                                        Flopsi
                                        So scheint es aktuell zu gehen....
                                        Semie1S 1 Antwort Letzte Antwort
                                        • F Flopsi
                                          Semie1S Offline
                                          Semie1S Offline
                                          Semie1
                                          @Flopsi
                                          also bei mir geht es nicht so
