  4. Wifilight - soef install Problem
wifilight adaptersoeftypeerror
16 Beiträge 4 Kommentatoren 1.3k Aufrufe 4 Beobachtet
  • MaufloM Offline
    MaufloM Offline
    Mauflo
    Ich habe seit meinem Umzug vom PI3 auf den PI4 ein Problem, dass immer wieder kommt und ich weiß nicht wieso.
    Bei einem Neustart des iobroker kommt folgende Fehlermeldung:
    2020-01-31 21:48:37.877 - info: host.iobrokerP4 Do not restart adapter system.adapter.wifilight.0 because disabled or deleted
    2020-01-31 21:48:37.877 - error: host.iobrokerP4 instance system.adapter.wifilight.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-01-31 21:48:37.877 - error: host.iobrokerP4 Caught by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
    2020-01-31 21:48:37.877 - error: host.iobrokerP4 Caught by controller[0]: at startup (internal/bootstrap/node.js:283:19)
    2020-01-31 21:48:37.877 - error: host.iobrokerP4 Caught by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
    2020-01-31 21:48:37.876 - error: host.iobrokerP4 Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    2020-01-31 21:48:37.876 - error: host.iobrokerP4 Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    2020-01-31 21:48:37.876 - error: host.iobrokerP4 Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    2020-01-31 21:48:37.876 - error: host.iobrokerP4 Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    2020-01-31 21:48:37.876 - error: host.iobrokerP4 Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    2020-01-31 21:48:37.876 - error: host.iobrokerP4 Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.wifilight/wifilight.js:20:20)
    2020-01-31 21:48:37.876 - error: host.iobrokerP4 Caught by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1148:23)
    2020-01-31 21:48:37.875 - error: host.iobrokerP4 Caught by controller[0]: TypeError: fns.adapter is not a function
    2020-01-31 21:48:37.875 - error: host.iobrokerP4 Caught by controller[0]: ^
    2020-01-31 21:48:37.875 - error: host.iobrokerP4 Caught by controller[0]: fns.adapter = fns.adapter(options);
    2020-01-31 21:48:37.874 - error: host.iobrokerP4 Caught by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1148
    Nun gibt es einen Workaround der so funktioniert:
    cd /opt/iobroker/node_modules/iobroker.wifilight
    sudo npm install soef
    Nachden ich dies durchführe, ist eigentlich alles wieder ok. Wenn ich aber nach ein paar Tagen den iobroker neustarte, bekomme ich den Fehler wieder und ich muß das Prozedere wieder durchführen.
    Meine Frage an @soef wäre daher: Gibt es irgendeinen dauerhaften Fix für dieses Problem?
    RaspberryPi 4 4 GB - Raspbian light Buster - ARMv7 Processor rev 3 (v7l) - Node.js v12.18.0 - NPM 6.14.4 - Aktive Instanzen 18 (admin, alexa2, backitup, broadlink2, ham-wemo, harmony, history, hs100, hue, info, iot, javascript, radar2, scenes, tr-064, web [2x], wifilight) all latest and updated
      Dreamboy74de
      Den Entwickler Soef gibt es doch hier nicht mehr. Dein Adapter ist veraltet, der Community Nachfolger heißt derzeit "ioBroker.wifilight-community" stelle deinen alten Adapter mal auf Pause und installiere dir eine Instanze von dem Neuen und Teste ob dir damit geholfen wurde. Dann kannst du den alten ja löschen. Vielleicht erbarmt sich ja jemand schmeißt den alten Adapter aus dem Repo und ändert den Name wieder ohne dieses " Community" um, so wie beim TR-064 Adapter;-)
      Raspi4 4GB Home/CCU3 FW 3.85.7/Admin 7.7.23/Node.js v22.22.0/NPM 10.9.4/JS-Controller 7.1.0
      Raspi4 4GB Szd/CCU3 FW 3.73.9/Admin 6.13.15/Node.js v18.19.0/NPM 10.2.3/JS-Controller5.0.17
      MaufloM 1 Antwort Letzte Antwort
      • D Dreamboy74de
        MaufloM Offline
        MaufloM Offline
        Mauflo
        @Dreamboy74de Danke für die Info. Aber wie installiere ich den "ioBroker.wifilight-community" Adapter korrekt?
        • MaufloM Mauflo
          crunchipC Abwesend
          crunchipC Abwesend
          @Mauflo du kannst auf Adapter installieren...beliebiger Quelle...
          https://github.com/iobroker-community-adapters/ioBroker.wifilight-community
            MaufloM Offline
            MaufloM Offline
            Mauflo
            @crunchip Danke hab's gefunden. Nur leider habe ich auch damit wieder die gleichen Probleme! ;-(
            crunchipC J 2 Antworten Letzte Antwort
            • MaufloM Mauflo
              crunchipC Abwesend
              crunchipC Abwesend
              @Mauflo was heisst gleiche Probleme? Soef?
              das musst du wahrscheinlich erneut ausführen
              • MaufloM Mauflo
                Jan1
                @Mauflo
                Willst damit die MagicHome Contoller in IOBroker einbinden?
                  MaufloM Offline
                  MaufloM Offline
                  Mauflo
                  @crunchip das ist ja das Problem - das muss ich jedesmal machen, wenn ich einen Neustart von ioBroker mache. Das würd ich mir gerne ersparen. Im Übrigen habe ich mit dem community Adapter dann folgende Probleme:
                  host.iobrokerP4	2020-02-01 10:52:01.766	info	instance system.adapter.wifilight-community.0 terminated with code 0 (NO_ERROR)
                  host.iobrokerP4	2020-02-01 10:52:01.765	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:90593)
                  host.iobrokerP4	2020-02-01 10:52:01.765	error	Caught by controller[0]: at objects.getObjectView (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3599:25)
                  host.iobrokerP4	2020-02-01 10:52:01.765	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.wifilight-community/node_modules/soef/soef.js:848:21
                  host.iobrokerP4	2020-02-01 10:52:01.765	error	Caught by controller[0]: at safeCallback (/opt/iobroker/node_modules/iobroker.wifilight-community/node_modules/soef/soef.js:188:13)
                  host.iobrokerP4	2020-02-01 10:52:01.765	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.wifilight-community/node_modules/soef/soef.js:1297:9
                  host.iobrokerP4	2020-02-01 10:52:01.765	error	Caught by controller[0]: at main (/opt/iobroker/node_modules/iobroker.wifilight-community/main.js:917:54)
                  host.iobrokerP4	2020-02-01 10:52:01.764	error	Caught by controller[0]: at WifiLight.run (/opt/iobroker/node_modules/iobroker.wifilight-community/main.js:170:10)
                  host.iobrokerP4	2020-02-01 10:52:01.764	error	Caught by controller[0]: at WifiLight.createDevice (/opt/iobroker/node_modules/iobroker.wifilight-community/main.js:197:19)
                  host.iobrokerP4	2020-02-01 10:52:01.764	error	Caught by controller[0]: at CDevice.getFullId (/opt/iobroker/node_modules/iobroker.wifilight-community/node_modules/soef/soef.js:1113:20)
                  host.iobrokerP4	2020-02-01 10:52:01.763	error	Caught by controller[0]: at dcs (/opt/iobroker/node_modules/iobroker.wifilight-community/node_modules/soef/soef.js:304:33)
                  host.iobrokerP4	2020-02-01 10:52:01.762	error	Caught by controller[0]: TypeError: Cannot read property '0' of undefined
                  wifilight-community.0	2020-02-01 10:52:00.661	error	(8446) uncaught exception: Cannot read property '0' of undefined
                  wifilight-community.0	2020-02-01 10:52:00.564	info	(8446) starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.wifilight-community, node: v10.18.1
                  host.iobrokerP4	2020-02-01 10:51:58.687	info	instance system.adapter.wifilight-community.0 started with pid 8446
                  Und auch hier startet der Adapter dauernd neu und müllt mir mein Logfile zu!
                  • J Jan1
                    @Mauflo
                    MaufloM Offline
                    MaufloM Offline
                    Mauflo
                    @Jan1 ja habe ich auch schon. Hat bislang wunderbar funktioniert. Erst seit dem Umzug und dem Update auf Node.js 10.x habe ich die Probleme!
                    • MaufloM Mauflo
                      Jan1
                      @Mauflo
                      NPM Rebuild hast aber gemacht?
                      Wie @crunchip schon geschrieben hat gibts da auch ne community Veresion des Adapter, wobei ich mich erinnern kann, dass ich mit der auch Probleme hatte.
                      Alternativ kannst die MagicHome Controller auch mit Tasmota flashen und über den Sonoff Adapter einbinden. Alexa läuft damit auch wunderbar und die Dinger sind im IOBroker wesentlich besser zu steuern, weil damit ein echter Rückkanal hast. Einzig die App läuft nicht mehr, was aber nicht tragisch, da man das dann entweder über die Alexa App macht, oder über iQontroll.
                      • J Jan1
                        @Mauflo
                        MaufloM Offline
                        MaufloM Offline
                        Mauflo
                        schrieb am zuletzt editiert von Mauflo
                        @Jan1 NPM Rebuild war nicht erforderlich, da ich mir die Mühe gemacht habe, den Rasperry Pi4 komplett mit Buster neu aufzusetzen den IoBroker neu und clean installiert habe und mittels backup alles neu istallieren ließ. So hatte ich ein komplett sauberes System und hatte eigentlich auch mit keinem anderen Adapter Probleme. NPM Rebuild wäre doch nur notwendig, wenn ich mein bestehendes System update - oder liege ich da falsch?
                        • MaufloM Mauflo
                          Jan1
                          @Mauflo
                          Vollkommen richtig und die perfekte Methode umzuziehen, war auch nur ne Frage um das gleich ausschließen zu können👍
                          • J Jan1
                            @Mauflo
                            MaufloM Offline
                            MaufloM Offline
                            Mauflo
                            @Jan1 das mit dem flashen weiß ich. aber ehrlich gesagt will ich das nicht. 1. Herumgefummle, 2. habe ich bereits 4 dieser Dinger. 3. sind die DP in zahlreichen scripts eingebaut. Das wäre eine mühsame Angelegenheit. ;-(
                            • MaufloM Mauflo
                              Jan1
                              @Mauflo
                              Ich habe 6 Stück geflasht, war recht schnell passiert, ebenfalls das Umbasteln der Scripte.
                              War auch nur ein Vorschlag und ich hatte eben meine Probleme mit dem fehlenden Rückkanal bei der originale FW und der recht unzuverlässigen Steuerung über den Wifilight Adapter. Hatte mit dem Flashen auch lange gewartet, weil Tasmota die Dinger noch nicht so lange wirklich voll unterstützt.
                              • J Jan1
                                @Mauflo
                                MaufloM Offline
                                MaufloM Offline
                                Mauflo
                                @Jan1 Ja der fehlende Rückkanal ist lästig. Liegt aber wohl an der restrektiven Haltung der Magic Home Software. Die lassen beispielsweise nur eine Rückmeldung über Alexa zu, wenn Du vorher über den Magic Home Alexa Skill eine Schaltung vorgenommen hast. Sonst bekommst Du folgende Meldung zurück wenn du den Request Button im entsprechenden Geräte DP vom Alexa - Adapter drückst:
                                (24080) Smart Home device request blocked for SKILL_eyJza2lsbElkIjoiYW16bjEuYXNrLnNraWxsLjhhNjYzMDNjLTI3NWUtNDUzYy1iN2ViLWUxMjllMTE2YjZlOCIsInN0YWdlIjoibGl2ZSJ9_DC4F22E3C566
                                Da waren wohl sehr schlaue Programmierer vom Hersteller unterwegs, die damit jeglichen Traffic einer Abfrage kontrollieren... ;-)
                                Hast Du irgend eine Ahnung, wo man Hinweise für das API vom Magic Home Server bekommen könnte?
                                • MaufloM Mauflo
                                  Jan1
                                  @Mauflo
                                  Nein, hab mich damit nicht weiter beschäftigt nach dem ich auf Tasmota umgestellt habe.
                                  82.9k
