  4. [gelöst] iobroker offline nach admin update
adminadapterupdatejs.controllerfrage
86 Beiträge 8 Kommentatoren 16.4k Aufrufe 5 Beobachtet
  • J JRiddim
    @haselchen
    ps -A | grep iobroker
      541 ?        00:19:16 iobroker.js-con
    haselchenH
    haselchenH
    haselchen
    @JRiddim
    ok
    erst den befehl eingeben
    cd /opt/iobroker
    dann den
    node node_modules/iobroker.js-controller/controller.js --logs
    • haselchenH haselchen
      @JRiddim
      ok
      cd /opt/iobroker
      dann den
      J
      J
      JRiddim
      @haselchen sagte in iobroker nicht mehr erreichbar nach admin update:
      2020-01-29 22:32:59.327  - info: host.raspberrypi iobroker.js-controller version 2.2.8 js-controller starting
      2020-01-29 22:32:59.336  - info: host.raspberrypi Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
      2020-01-29 22:32:59.337  - info: host.raspberrypi hostname: raspberrypi, node: v10.18.1
      2020-01-29 22:32:59.339  - info: host.raspberrypi ip addresses: 192.168.100.50 fe80::dea6:32ff:fe0a:7cb6 fe80::fc97:c0ff:fef0:a5a8
      2020-01-29 22:32:59.803  - info: host.raspberrypi  Error inMem-objects listening on port 9001
      2020-01-29 22:33:00.351  - info: host.raspberrypi  Error inMem-states listening on port 9000
      2020-01-29 22:33:00.405  - info: host.raspberrypi connected to Objects and States
      2020-01-29 22:33:00.551  - info: host.raspberrypi 33 instances found
      host.raspberrypi check instance "system.adapter.discovery.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.info.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.mihome-vacuum.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.telegram.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.hue.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.hm-rpc.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.hm-rega.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.hm-rpc.1" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.ping.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.web.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.vis.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.vis-hqwidgets.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.vis-timeandweather.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.vis-jqui-mfd.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.vis-metro.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.spotify-premium.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.vis-google-fonts.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.vis-fancyswitch.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.vis-bars.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.vis-history.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.ical.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.vis-justgage.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.weatherunderground.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.yr.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.backitup.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.terminal.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.zigbee.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.javascript.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.yahka.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.youtube.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.admin.1" for host "raspberrypi"
      2020-01-29 22:33:00.615  - info: host.raspberrypi starting 30 instances
      2020-01-29 22:33:00.665  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 19462
      ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
      2020-01-29 22:33:02.894  - error: host.raspberrypi instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      2020-01-29 22:33:02.894  - info: host.raspberrypi Do not restart adapter system.adapter.admin.0 because desired by instance
      ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
      2020-01-29 22:33:04.633  - info: host.raspberrypi instance system.adapter.admin.1 started with pid 19655
      ================================== > LOG REDIRECT system.adapter.admin.1 => false [Process stopped]
      2020-01-29 22:33:06.831  - error: host.raspberrypi instance system.adapter.admin.1 terminated by request of the instance itself and will not be restarted, before user restarts it.
      2020-01-29 22:33:06.832  - info: host.raspberrypi Do not restart adapter system.adapter.admin.1 because desired by instance
      ================================== > LOG REDIRECT system.adapter.admin.1 => false [system.adapter.admin.1.logging]
      2020-01-29 22:33:08.633  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 19684
      2020-01-29 22:33:10.198  - error: host.raspberrypi instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2020-01-29 22:33:10.199  - info: host.raspberrypi Restart adapter system.adapter.discovery.0 because enabled
      2020-01-29 22:33:12.632  - info: host.raspberrypi instance system.adapter.info.0 started with pid 19861
      2020-01-29 22:33:14.750  - error: host.raspberrypi instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2020-01-29 22:33:14.751  - info: host.raspberrypi Restart adapter system.adapter.info.0 because enabled
      2020-01-29 22:33:16.630  - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 19893
      2020-01-29 22:33:18.147  - error: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2020-01-29 22:33:18.148  - info: host.raspberrypi Restart adapter system.adapter.mihome-vacuum.0 because enabled
      2020-01-29 22:33:20.631  - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 20087
      das will nicht mehr aufhören geht ewig weiter
      Langsam aber sicher.
      • J JRiddim
        haselchenH
        haselchenH
        haselchen
        @JRiddim
        gib iobroker stop ein
        dann
        npm install iobroker.js-controller
        dann
        iobroker start
        J 2 Antworten Letzte Antwort
          @JRiddim
          dann
          dann
          iobroker start
          J
          J
          JRiddim
          schrieb am zuletzt editiert von JRiddim
          tut sich nichts läuft munter weiter. Kann ich die Konsole einfach schließen?
          • J JRiddim
            haselchenH
            haselchenH
            haselchen
            @JRiddim
            Ich mach das immer nach try and error.
            Auf eigene Gefahr.
            Ich hatte das Problem auch.
            Und bin die Befehle durchgegangen.
            Versuch mal iobroker neu zu starten. Also das Gerät.
              @JRiddim
              dann
              dann
              iobroker start
              J
              J
              JRiddim
              @JRiddim
              dann
              dann
              iobroker start
              auf der Ebene opt/iobroker oder?
              • J JRiddim
                @JRiddim
                dann
                dann
                iobroker start
                haselchenH
                haselchenH
                haselchen
                @JRiddim
                richtig.
                  @JRiddim
                  richtig.
                  J
                  J
                  JRiddim
                  @haselchen
                  erhalte diese Meldung dabei.
                  npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
                  > iobroker.js-controller@2.2.8 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                  > node lib/preinstallCheck.js
                  NPM version: 6.13.4
                  > iobroker.js-controller@2.2.8 install /opt/iobroker/node_modules/iobroker.js-controller
                  > node iobroker.js setup first
                  npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
                  npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                  + iobroker.js-controller@2.2.8
                  updated 1 package and audited 4821 packages in 35.829s
                  12 packages are looking for funding
                    run `npm fund` for details
                  found 57 vulnerabilities (40 low, 3 moderate, 14 high)
                    run `npm audit fix` to fix them, or `npm audit` for details
                  • J JRiddim
                    @haselchen
                    NPM version: 6.13.4
                    haselchenH
                    haselchenH
                    haselchen
                    @JRiddim
                    Viele Wege führen hier nach Rom.
                    Kommste mit iobroker start oder iobroker start admin.0 jetzt auf die Oberfläche?
                    Ansonsten kannst du noch den Fixer laufen lassen oder clever wäre auch beim raspi ein
                    sudo apt update und dann ein
                    sudo apt full-upgrade
                    zu machen.
                    dann ist der raspberry erstmal auf dem neuesten stand.
                      @JRiddim
                      zu machen.
                      J
                      J
                      JRiddim
                      @haselchen
                      habe den rpi jetzt aktualisiert. port: 8081 funktioniert immer noch nicht.
                      Wie kann ich den Fixer laufen lassen? :)
                      • J JRiddim
                        @haselchen
                        haselchenH
                        haselchenH
                        haselchen
                        @JRiddim
                        curl -sL https://iobroker.net/fix.sh | bash -
                        • J JRiddim
                          Edit also konnte den js.controller nochmal neu installieren.
                          iobroker läuft im Hintergrund, aber komme einfach nicht drauf!
                          iobroker l i --port
                            system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.hm-rpc.0                : hm-rpc                -  enabled, port: 0
                          Hi nach dem update des neuen Admin adapters komme ich nicht mehr auf iobroker.
                          Nach Neuinstallation bekomme ich folgende Fehlermeldung.
                          sudo npm install iobroker.admin@3.7.7 --production
                          + iobroker.admin@3.7.7
                          updated 1 package and audited 3971 packages in 18.952s
                          15 packages are looking for funding
                          found 56 vulnerabilities (39 low, 3 moderate, 14 high)
                          iobroker list adapters/instances ergibt:
                          iobroker list instances
                          internal/modules/cjs/loader.js:638
                              throw err;
                          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                              at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                              at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                              at startup (internal/bootstrap/node.js:283:19)
                              at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                          kann unter node_modules keinen iobroker.js-controller finden.
                          beim versuch diesen zu installieren kommt:
                          /opt/iobroker $ npm install iobroker.jscontroller
                          npm ERR! code E404
                          npm ERR! 404 Not Found - GET https://registry.npmjs.org/iobroker.jscontroller - Not found
                          npm ERR! 404
                          npm ERR! 404  'iobroker.jscontroller@latest' is not in the npm registry.
                          npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
                          npm ERR! 404
                          npm ERR! 404 Note that you can also install from a
                          npm ERR! 404 tarball, folder, http url, or git url.
                          npm ERR!     /home/juju/.npm/_logs/2020-01-29T16_03_29_506Z-debug.log
                          Bin langsam echt am verzweifeln. Ich glaube ich verschlimmbessere nur alles!
                          Bin für eure Hilfe sehr dankbar!
                          Liebe Grüße
                          Jan
                          T
                          T
                          timtig
                          @JRiddim
                          bis jetzt war ich stiller beobachter und leser hier. Aber weil es mir immer wieder geholfen hat, wollte ich es hier auch zurück geben und versuchen zu helfen. Hatte den gleiche Fehler. War auch sehr verzweifelt. Alle adapter waren weg, nichts ging mehr. Verwende aber mein Haupt iobroker unter Sysnology mit portainer, den zweiten als slave auf RPI.
                          Hatte auch ohne drauf zu schauen den admin adapter upgedatet und dann war alles weg. Bis in die nacht oder morgen früh war ich am Rechner, aber erst am zweiten Abend hatte ich alles reparieren können. Mein vorgehen war:
                          container starten, natürlich startet iobroker nicht. Mit portainer auf die console und schauen ob da noch was von iobroker läuft:
                          ps auxww|grep io
                          #killen wenn noch was läuft
                          dann
                          npm install iobroker.js-controller@2.2.8
                          #und
                          iobroker upgrade self
                          wichtig ist natürlich, dass du den aktuellen node und so hast:
                          link text
                          dann container neustarten. Dann waren alle adapter erst mal da, aber dann schreck, die sind alle rot und starten nicht. Keine panik, die werden jetzt nach und nach neu installiert. Evtl. muss du ein oder anderen adapter neu starten. Kannst im log beobachten wie die installiert werden. Viel erfolg!
                          sonst hier noch ein paar links dazu:
                          link text
                          link text
                            @JRiddim
                            J
                            J
                            JRiddim
                            brachte leider noch keinen Erfolg.
                            ist es normal das unter Biobroker list instances der admin mit 0.0.0.0 angegeben wird?
                            • T timtig
                              @JRiddim
                              ps auxww|grep io
                              dann
                              #und
                              link text
                              link text
                              link text
                              J
                              J
                              JRiddim
                              @timtig
                              bei ps auxww|grep io kommt.
                              root        12  0.0  0.0      0     0 ?        S    20:08   0:00 [migration/0]
                              root        15  0.0  0.0      0     0 ?        S    20:08   0:00 [migration/1]
                              root        20  0.0  0.0      0     0 ?        S    20:08   0:00 [migration/2]
                              root        25  0.0  0.0      0     0 ?        S    20:08   0:00 [migration/3]
                              root        42  0.0  0.0      0     0 ?        I<   20:08   0:00 [rpciod]
                              root        44  0.0  0.0      0     0 ?        I<   20:08   0:00 [xprtiod]
                              root        48  0.0  0.0      0     0 ?        I<   20:08   0:00 [nfsiod]
                              root        64  0.0  0.0      0     0 ?        I<   20:08   0:00 [DWC Notificatio]
                              message+   333  0.0  0.0   6644  3548 ?        Ss   20:08   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
                              root      1789  0.3  2.0 269844 82356 ?        Sl   20:08   0:39 java -Xmx128m -Dos.arch=arm -Dlog4j.configuration=file:///etc/config/log4j.xml -Dfile.encoding=ISO-8859-1 -Dgnu.io.rxtx.SerialPorts=/dev/mmd_hmip -jar /opt/HMServer/HMIPServer.jar /etc/crRFD.conf /etc/HMServer.conf
                              iobroker 12828 18.0  2.8 199400 114016 ?       Ssl  22:55   0:58 iobroker.js-controller
                              iobroker 12881  0.4  1.1 136028 47856 ?        Sl   22:56   0:01 io.discovery.0
                              iobroker 12896  3.2  1.3 155804 55184 ?        Sl   22:56   0:10 io.info.0
                              iobroker 12917  1.1  1.0 144536 41024 ?        Sl   22:56   0:03 io.mihome-vacuum.0
                              iobroker 13344  1.4  1.2 153408 49440 ?        Sl   22:56   0:04 io.telegram.0
                              iobroker 13365  1.8  1.1 148252 44392 ?        Sl   22:56   0:05 io.hue.0
                              iobroker 13511  1.2  1.0 144764 42460 ?        Sl   22:56   0:03 io.hm-rpc.0
                              iobroker 13572  1.3  1.1 148148 46580 ?        Sl   22:56   0:04 io.hm-rega.0
                              iobroker 13735  1.3  1.2 149256 48172 ?        Sl   22:56   0:03 io.hm-rpc.1
                              iobroker 13797  0.7  1.0 136372 41596 ?        Sl   22:56   0:02 io.ping.0
                              iobroker 13999  0.7  1.3 148360 54868 ?        Sl   22:56   0:02 io.web.0
                              iobroker 14203  3.3  1.4 163012 59532 ?        Sl   22:56   0:09 io.spotify-premium.0
                              iobroker 14635  0.7  1.3 148708 53304 ?        Sl   22:57   0:01 io.terminal.0
                              iobroker 14673  1.6  1.1 150376 45628 ?        Sl   22:57   0:04 io.zigbee.0
                              iobroker 14820  4.9  2.3 199452 92496 ?        Sl   22:57   0:12 io.javascript.0
                              iobroker 14906  0.8  1.1 148136 44420 ?        Sl   22:57   0:02 io.yahka.0
                              juju     20733  0.0  0.0   7360   484 pts/1    S+   23:01   0:00 grep --color=auto io
                              node -v
                              v10.18.1
                              nodejs -v
                              v10.18.1
                              npm -v
                              6.13.4
                              • J JRiddim
                                haselchenH
                                haselchenH
                                haselchen
                                @JRiddim
                                das ist richtig so.
                                und normal sollte alles gehen.
                                du kannst mal
                                iobroker stop admin.0 eingeben
                                und dann wieder starten
                                  @JRiddim
                                  das ist richtig so.
                                  du kannst mal
                                  J
                                  J
                                  JRiddim
                                  @haselchen
                                  leider auch nicht. ich hatte einen chmod 777 mal auf den iobroker gemacht kann das vllt. damit zusammenhängen?
                                  • J JRiddim
                                    @haselchen
                                    haselchenH
                                    haselchenH
                                    haselchen
                                    @JRiddim
                                    Mit Rechtevergaben kenne ich mich nicht aus.
                                    Was passiert denn wenn du die IP:8081 eingibst?
                                      @JRiddim
                                      J
                                      J
                                      JRiddim
                                      @haselchen
                                      es tut sich nichts. Auf Vis komme ich ohne weiteres.
                                      • J JRiddim
                                        @haselchen
                                        haselchenH
                                        haselchenH
                                        haselchen
                                        @JRiddim
                                        Cache vom Browser geleert?
                                        Mal F5 gedrückt nach der IP:8081 Eingabe?
                                          @JRiddim
                                          J
                                          J
                                          JRiddim
                                          @haselchen
                                          :( tut sich leider auch nix
                                          84.2k
