  4. [gelöst] iobroker offline nach admin update
adminadapterupdatejs.controllerfrage
86 Beiträge 8 Kommentatoren 16.4k Aufrufe 5 Beobachtet
  • J JRiddim
    @haselchen sagte in iobroker nicht mehr erreichbar nach admin update:
    node node_modules/iobroker.js-controller/controller.js --logs
    2020-01-29 22:32:59.327  - info: host.raspberrypi iobroker.js-controller version 2.2.8 js-controller starting
    2020-01-29 22:32:59.336  - info: host.raspberrypi Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
    2020-01-29 22:32:59.337  - info: host.raspberrypi hostname: raspberrypi, node: v10.18.1
    2020-01-29 22:32:59.339  - info: host.raspberrypi ip addresses: 192.168.100.50 fe80::dea6:32ff:fe0a:7cb6 fe80::fc97:c0ff:fef0:a5a8
    2020-01-29 22:32:59.803  - info: host.raspberrypi  Error inMem-objects listening on port 9001
    2020-01-29 22:33:00.351  - info: host.raspberrypi  Error inMem-states listening on port 9000
    2020-01-29 22:33:00.405  - info: host.raspberrypi connected to Objects and States
    2020-01-29 22:33:00.551  - info: host.raspberrypi 33 instances found
    host.raspberrypi check instance "system.adapter.discovery.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.info.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.mihome-vacuum.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.telegram.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.hue.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.hm-rpc.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.hm-rega.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.hm-rpc.1" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.ping.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.web.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.vis.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.vis-hqwidgets.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.vis-timeandweather.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.vis-jqui-mfd.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.vis-metro.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.spotify-premium.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.vis-google-fonts.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.vis-fancyswitch.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.vis-bars.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.vis-history.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.ical.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.vis-justgage.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.weatherunderground.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.yr.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.backitup.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.terminal.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.zigbee.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.javascript.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.yahka.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.youtube.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.admin.1" for host "raspberrypi"
    2020-01-29 22:33:00.615  - info: host.raspberrypi starting 30 instances
    2020-01-29 22:33:00.665  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 19462
    ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
    2020-01-29 22:33:02.894  - error: host.raspberrypi instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2020-01-29 22:33:02.894  - info: host.raspberrypi Do not restart adapter system.adapter.admin.0 because desired by instance
    ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
    2020-01-29 22:33:04.633  - info: host.raspberrypi instance system.adapter.admin.1 started with pid 19655
    ================================== > LOG REDIRECT system.adapter.admin.1 => false [Process stopped]
    2020-01-29 22:33:06.831  - error: host.raspberrypi instance system.adapter.admin.1 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2020-01-29 22:33:06.832  - info: host.raspberrypi Do not restart adapter system.adapter.admin.1 because desired by instance
    ================================== > LOG REDIRECT system.adapter.admin.1 => false [system.adapter.admin.1.logging]
    2020-01-29 22:33:08.633  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 19684
    2020-01-29 22:33:10.198  - error: host.raspberrypi instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2020-01-29 22:33:10.199  - info: host.raspberrypi Restart adapter system.adapter.discovery.0 because enabled
    2020-01-29 22:33:12.632  - info: host.raspberrypi instance system.adapter.info.0 started with pid 19861
    2020-01-29 22:33:14.750  - error: host.raspberrypi instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2020-01-29 22:33:14.751  - info: host.raspberrypi Restart adapter system.adapter.info.0 because enabled
    2020-01-29 22:33:16.630  - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 19893
    2020-01-29 22:33:18.147  - error: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2020-01-29 22:33:18.148  - info: host.raspberrypi Restart adapter system.adapter.mihome-vacuum.0 because enabled
    2020-01-29 22:33:20.631  - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 20087
    das will nicht mehr aufhören geht ewig weiter
    haselchenH
    haselchenH
    haselchen
    @JRiddim
    gib iobroker stop ein
    dann
    npm install iobroker.js-controller
    dann
    iobroker start
    J 2 Antworten Letzte Antwort
    • haselchenH haselchen
      @JRiddim
      dann
      dann
      iobroker start
      J
      J
      JRiddim
      schrieb am zuletzt editiert von JRiddim
      tut sich nichts läuft munter weiter. Kann ich die Konsole einfach schließen?
      Langsam aber sicher.
      • J JRiddim
        haselchenH
        haselchenH
        haselchen
        @JRiddim
        Ich mach das immer nach try and error.
        Auf eigene Gefahr.
        Ich hatte das Problem auch.
        Und bin die Befehle durchgegangen.
        Versuch mal iobroker neu zu starten. Also das Gerät.
          @JRiddim
          dann
          dann
          iobroker start
          J
          J
          JRiddim
          @JRiddim
          dann
          dann
          iobroker start
          auf der Ebene opt/iobroker oder?
          • J JRiddim
            @JRiddim
            dann
            dann
            iobroker start
            haselchenH
            haselchenH
            haselchen
            @JRiddim
            richtig.
              @JRiddim
              richtig.
              J
              J
              JRiddim
              @haselchen
              erhalte diese Meldung dabei.
              npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
              > iobroker.js-controller@2.2.8 preinstall /opt/iobroker/node_modules/iobroker.js-controller
              > node lib/preinstallCheck.js
              NPM version: 6.13.4
              > iobroker.js-controller@2.2.8 install /opt/iobroker/node_modules/iobroker.js-controller
              > node iobroker.js setup first
              npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
              npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              + iobroker.js-controller@2.2.8
              updated 1 package and audited 4821 packages in 35.829s
              12 packages are looking for funding
                run `npm fund` for details
              found 57 vulnerabilities (40 low, 3 moderate, 14 high)
                run `npm audit fix` to fix them, or `npm audit` for details
              • J JRiddim
                @haselchen
                NPM version: 6.13.4
                haselchenH
                haselchenH
                haselchen
                @JRiddim
                Viele Wege führen hier nach Rom.
                Kommste mit iobroker start oder iobroker start admin.0 jetzt auf die Oberfläche?
                Ansonsten kannst du noch den Fixer laufen lassen oder clever wäre auch beim raspi ein
                sudo apt update und dann ein
                sudo apt full-upgrade
                zu machen.
                dann ist der raspberry erstmal auf dem neuesten stand.
                  @JRiddim
                  zu machen.
                  J
                  J
                  JRiddim
                  @haselchen
                  habe den rpi jetzt aktualisiert. port: 8081 funktioniert immer noch nicht.
                  Wie kann ich den Fixer laufen lassen? :)
                  • J JRiddim
                    @haselchen
                    haselchenH
                    haselchenH
                    haselchen
                    @JRiddim
                    curl -sL https://iobroker.net/fix.sh | bash -
                    • J JRiddim
                      Edit also konnte den js.controller nochmal neu installieren.
                      iobroker läuft im Hintergrund, aber komme einfach nicht drauf!
                      iobroker l i --port
                        system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.hm-rpc.0                : hm-rpc                -  enabled, port: 0
                      Hi nach dem update des neuen Admin adapters komme ich nicht mehr auf iobroker.
                      Nach Neuinstallation bekomme ich folgende Fehlermeldung.
                      sudo npm install iobroker.admin@3.7.7 --production
                      + iobroker.admin@3.7.7
                      updated 1 package and audited 3971 packages in 18.952s
                      15 packages are looking for funding
                      found 56 vulnerabilities (39 low, 3 moderate, 14 high)
                      iobroker list adapters/instances ergibt:
                      iobroker list instances
                      internal/modules/cjs/loader.js:638
                          throw err;
                      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                          at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                          at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                          at startup (internal/bootstrap/node.js:283:19)
                          at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                      kann unter node_modules keinen iobroker.js-controller finden.
                      beim versuch diesen zu installieren kommt:
                      /opt/iobroker $ npm install iobroker.jscontroller
                      npm ERR! code E404
                      npm ERR! 404 Not Found - GET https://registry.npmjs.org/iobroker.jscontroller - Not found
                      npm ERR! 404
                      npm ERR! 404  'iobroker.jscontroller@latest' is not in the npm registry.
                      npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
                      npm ERR! 404
                      npm ERR! 404 Note that you can also install from a
                      npm ERR! 404 tarball, folder, http url, or git url.
                      npm ERR!     /home/juju/.npm/_logs/2020-01-29T16_03_29_506Z-debug.log
                      Bin langsam echt am verzweifeln. Ich glaube ich verschlimmbessere nur alles!
                      Bin für eure Hilfe sehr dankbar!
                      Liebe Grüße
                      Jan
                      T
                      T
                      timtig
                      @JRiddim
                      bis jetzt war ich stiller beobachter und leser hier. Aber weil es mir immer wieder geholfen hat, wollte ich es hier auch zurück geben und versuchen zu helfen. Hatte den gleiche Fehler. War auch sehr verzweifelt. Alle adapter waren weg, nichts ging mehr. Verwende aber mein Haupt iobroker unter Sysnology mit portainer, den zweiten als slave auf RPI.
                      Hatte auch ohne drauf zu schauen den admin adapter upgedatet und dann war alles weg. Bis in die nacht oder morgen früh war ich am Rechner, aber erst am zweiten Abend hatte ich alles reparieren können. Mein vorgehen war:
                      container starten, natürlich startet iobroker nicht. Mit portainer auf die console und schauen ob da noch was von iobroker läuft:
                      ps auxww|grep io
                      #killen wenn noch was läuft
                      dann
                      npm install iobroker.js-controller@2.2.8
                      #und
                      iobroker upgrade self
                      wichtig ist natürlich, dass du den aktuellen node und so hast:
                      link text
                      dann container neustarten. Dann waren alle adapter erst mal da, aber dann schreck, die sind alle rot und starten nicht. Keine panik, die werden jetzt nach und nach neu installiert. Evtl. muss du ein oder anderen adapter neu starten. Kannst im log beobachten wie die installiert werden. Viel erfolg!
                      sonst hier noch ein paar links dazu:
                      link text
                      link text
                        @JRiddim
                        J
                        J
                        JRiddim
                        brachte leider noch keinen Erfolg.
                        ist es normal das unter Biobroker list instances der admin mit 0.0.0.0 angegeben wird?
                        • T timtig
                          @JRiddim
                          ps auxww|grep io
                          dann
                          #und
                          link text
                          link text
                          link text
                          J
                          J
                          JRiddim
                          @timtig
                          bei ps auxww|grep io kommt.
                          root        12  0.0  0.0      0     0 ?        S    20:08   0:00 [migration/0]
                          root        15  0.0  0.0      0     0 ?        S    20:08   0:00 [migration/1]
                          root        20  0.0  0.0      0     0 ?        S    20:08   0:00 [migration/2]
                          root        25  0.0  0.0      0     0 ?        S    20:08   0:00 [migration/3]
                          root        42  0.0  0.0      0     0 ?        I<   20:08   0:00 [rpciod]
                          root        44  0.0  0.0      0     0 ?        I<   20:08   0:00 [xprtiod]
                          root        48  0.0  0.0      0     0 ?        I<   20:08   0:00 [nfsiod]
                          root        64  0.0  0.0      0     0 ?        I<   20:08   0:00 [DWC Notificatio]
                          message+   333  0.0  0.0   6644  3548 ?        Ss   20:08   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
                          root      1789  0.3  2.0 269844 82356 ?        Sl   20:08   0:39 java -Xmx128m -Dos.arch=arm -Dlog4j.configuration=file:///etc/config/log4j.xml -Dfile.encoding=ISO-8859-1 -Dgnu.io.rxtx.SerialPorts=/dev/mmd_hmip -jar /opt/HMServer/HMIPServer.jar /etc/crRFD.conf /etc/HMServer.conf
                          iobroker 12828 18.0  2.8 199400 114016 ?       Ssl  22:55   0:58 iobroker.js-controller
                          iobroker 12881  0.4  1.1 136028 47856 ?        Sl   22:56   0:01 io.discovery.0
                          iobroker 12896  3.2  1.3 155804 55184 ?        Sl   22:56   0:10 io.info.0
                          iobroker 12917  1.1  1.0 144536 41024 ?        Sl   22:56   0:03 io.mihome-vacuum.0
                          iobroker 13344  1.4  1.2 153408 49440 ?        Sl   22:56   0:04 io.telegram.0
                          iobroker 13365  1.8  1.1 148252 44392 ?        Sl   22:56   0:05 io.hue.0
                          iobroker 13511  1.2  1.0 144764 42460 ?        Sl   22:56   0:03 io.hm-rpc.0
                          iobroker 13572  1.3  1.1 148148 46580 ?        Sl   22:56   0:04 io.hm-rega.0
                          iobroker 13735  1.3  1.2 149256 48172 ?        Sl   22:56   0:03 io.hm-rpc.1
                          iobroker 13797  0.7  1.0 136372 41596 ?        Sl   22:56   0:02 io.ping.0
                          iobroker 13999  0.7  1.3 148360 54868 ?        Sl   22:56   0:02 io.web.0
                          iobroker 14203  3.3  1.4 163012 59532 ?        Sl   22:56   0:09 io.spotify-premium.0
                          iobroker 14635  0.7  1.3 148708 53304 ?        Sl   22:57   0:01 io.terminal.0
                          iobroker 14673  1.6  1.1 150376 45628 ?        Sl   22:57   0:04 io.zigbee.0
                          iobroker 14820  4.9  2.3 199452 92496 ?        Sl   22:57   0:12 io.javascript.0
                          iobroker 14906  0.8  1.1 148136 44420 ?        Sl   22:57   0:02 io.yahka.0
                          juju     20733  0.0  0.0   7360   484 pts/1    S+   23:01   0:00 grep --color=auto io
                          node -v
                          v10.18.1
                          nodejs -v
                          v10.18.1
                          npm -v
                          6.13.4
                          • J JRiddim
                            haselchenH
                            haselchenH
                            haselchen
                            @JRiddim
                            das ist richtig so.
                            und normal sollte alles gehen.
                            du kannst mal
                            iobroker stop admin.0 eingeben
                            und dann wieder starten
                              @JRiddim
                              das ist richtig so.
                              du kannst mal
                              J
                              J
                              JRiddim
                              @haselchen
                              leider auch nicht. ich hatte einen chmod 777 mal auf den iobroker gemacht kann das vllt. damit zusammenhängen?
                              • J JRiddim
                                @haselchen
                                haselchenH
                                haselchenH
                                haselchen
                                @JRiddim
                                Mit Rechtevergaben kenne ich mich nicht aus.
                                Was passiert denn wenn du die IP:8081 eingibst?
                                  @JRiddim
                                  J
                                  J
                                  JRiddim
                                  @haselchen
                                  es tut sich nichts. Auf Vis komme ich ohne weiteres.
                                  • J JRiddim
                                    @haselchen
                                    haselchenH
                                    haselchenH
                                    haselchen
                                    @JRiddim
                                    Cache vom Browser geleert?
                                    Mal F5 gedrückt nach der IP:8081 Eingabe?
                                      @JRiddim
                                      J
                                      J
                                      JRiddim
                                      @haselchen
                                      :( tut sich leider auch nix
                                      • J JRiddim
                                        @haselchen
                                        haselchenH
                                        haselchenH
                                        haselchen
                                        @JRiddim
                                        Hm. Also das ist heavy.
                                        Bleibt noch in dem Pfad /opt/iobroker
                                        ein
                                        npm rebuild
                                          @JRiddim
                                          ein
                                          npm rebuild
                                          J
                                          J
                                          JRiddim
                                          @haselchen
                                          am Ende wird das hier angezeigt.
                                          │ New patch version of npm available! 6.13.4 → 6.13.7 │
                                          │ Changelog: https://github.com/npm/cli/releases/tag/v6.13.7 │
                                          │ Run npm install -g npm to update! │
                                          84.2k
