  4. [gelöst] iobroker offline nach admin update
adminadapterupdatejs.controllerfrage
86 Beiträge 8 Kommentatoren 16.4k Aufrufe 5 Beobachtet
  • J JRiddim
    @haselchen
    erhalte diese Meldung dabei.
    npm install iobroker.js-controller
    npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
    > iobroker.js-controller@2.2.8 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.13.4
    > iobroker.js-controller@2.2.8 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
    npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    + iobroker.js-controller@2.2.8
    updated 1 package and audited 4821 packages in 35.829s
    12 packages are looking for funding
      run `npm fund` for details
    found 57 vulnerabilities (40 low, 3 moderate, 14 high)
      run `npm audit fix` to fix them, or `npm audit` for details
    haselchenH
    haselchenH
    haselchen
    @JRiddim
    Viele Wege führen hier nach Rom.
    Kommste mit iobroker start oder iobroker start admin.0 jetzt auf die Oberfläche?
    Ansonsten kannst du noch den Fixer laufen lassen oder clever wäre auch beim raspi ein
    sudo apt update und dann ein
    sudo apt full-upgrade
    zu machen.
    dann ist der raspberry erstmal auf dem neuesten stand.
    • haselchenH haselchen
      @JRiddim
      zu machen.
      J
      J
      JRiddim
      schrieb am zuletzt editiert von JRiddim
      @haselchen
      habe den rpi jetzt aktualisiert. port: 8081 funktioniert immer noch nicht.
      Wie kann ich den Fixer laufen lassen? :)
      Langsam aber sicher.
      • J JRiddim
        @haselchen
        haselchenH
        haselchenH
        haselchen
        @JRiddim
        curl -sL https://iobroker.net/fix.sh | bash -
        • J JRiddim
          Edit also konnte den js.controller nochmal neu installieren.
          iobroker läuft im Hintergrund, aber komme einfach nicht drauf!
          iobroker l i --port
            system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.hm-rpc.0                : hm-rpc                -  enabled, port: 0
          Hi nach dem update des neuen Admin adapters komme ich nicht mehr auf iobroker.
          Nach Neuinstallation bekomme ich folgende Fehlermeldung.
          sudo npm install iobroker.admin@3.7.7 --production
          + iobroker.admin@3.7.7
          updated 1 package and audited 3971 packages in 18.952s
          15 packages are looking for funding
          found 56 vulnerabilities (39 low, 3 moderate, 14 high)
          iobroker list adapters/instances ergibt:
          iobroker list instances
          internal/modules/cjs/loader.js:638
              throw err;
          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
              at Function.Module._load (internal/modules/cjs/loader.js:562:25)
              at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
              at startup (internal/bootstrap/node.js:283:19)
              at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
          kann unter node_modules keinen iobroker.js-controller finden.
          beim versuch diesen zu installieren kommt:
          /opt/iobroker $ npm install iobroker.jscontroller
          npm ERR! code E404
          npm ERR! 404 Not Found - GET https://registry.npmjs.org/iobroker.jscontroller - Not found
          npm ERR! 404
          npm ERR! 404  'iobroker.jscontroller@latest' is not in the npm registry.
          npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
          npm ERR! 404
          npm ERR! 404 Note that you can also install from a
          npm ERR! 404 tarball, folder, http url, or git url.
          npm ERR!     /home/juju/.npm/_logs/2020-01-29T16_03_29_506Z-debug.log
          Bin langsam echt am verzweifeln. Ich glaube ich verschlimmbessere nur alles!
          Bin für eure Hilfe sehr dankbar!
          Liebe Grüße
          Jan
          T
          T
          timtig
          @JRiddim
          bis jetzt war ich stiller beobachter und leser hier. Aber weil es mir immer wieder geholfen hat, wollte ich es hier auch zurück geben und versuchen zu helfen. Hatte den gleiche Fehler. War auch sehr verzweifelt. Alle adapter waren weg, nichts ging mehr. Verwende aber mein Haupt iobroker unter Sysnology mit portainer, den zweiten als slave auf RPI.
          Hatte auch ohne drauf zu schauen den admin adapter upgedatet und dann war alles weg. Bis in die nacht oder morgen früh war ich am Rechner, aber erst am zweiten Abend hatte ich alles reparieren können. Mein vorgehen war:
          container starten, natürlich startet iobroker nicht. Mit portainer auf die console und schauen ob da noch was von iobroker läuft:
          ps auxww|grep io
          #killen wenn noch was läuft
          dann
          npm install iobroker.js-controller@2.2.8
          #und
          iobroker upgrade self
          wichtig ist natürlich, dass du den aktuellen node und so hast:
          link text
          dann container neustarten. Dann waren alle adapter erst mal da, aber dann schreck, die sind alle rot und starten nicht. Keine panik, die werden jetzt nach und nach neu installiert. Evtl. muss du ein oder anderen adapter neu starten. Kannst im log beobachten wie die installiert werden. Viel erfolg!
          sonst hier noch ein paar links dazu:
          link text
          link text
            @JRiddim
            J
            J
            JRiddim
            @haselchen sagte in iobroker nicht mehr erreichbar nach admin update:
            brachte leider noch keinen Erfolg.
            ist es normal das unter Biobroker list instances der admin mit 0.0.0.0 angegeben wird?
            • T timtig
              @JRiddim
              ps auxww|grep io
              dann
              #und
              link text
              link text
              link text
              J
              J
              JRiddim
              @timtig
              bei ps auxww|grep io kommt.
              root        12  0.0  0.0      0     0 ?        S    20:08   0:00 [migration/0]
              root        15  0.0  0.0      0     0 ?        S    20:08   0:00 [migration/1]
              root        20  0.0  0.0      0     0 ?        S    20:08   0:00 [migration/2]
              root        25  0.0  0.0      0     0 ?        S    20:08   0:00 [migration/3]
              root        42  0.0  0.0      0     0 ?        I<   20:08   0:00 [rpciod]
              root        44  0.0  0.0      0     0 ?        I<   20:08   0:00 [xprtiod]
              root        48  0.0  0.0      0     0 ?        I<   20:08   0:00 [nfsiod]
              root        64  0.0  0.0      0     0 ?        I<   20:08   0:00 [DWC Notificatio]
              message+   333  0.0  0.0   6644  3548 ?        Ss   20:08   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
              root      1789  0.3  2.0 269844 82356 ?        Sl   20:08   0:39 java -Xmx128m -Dos.arch=arm -Dlog4j.configuration=file:///etc/config/log4j.xml -Dfile.encoding=ISO-8859-1 -Dgnu.io.rxtx.SerialPorts=/dev/mmd_hmip -jar /opt/HMServer/HMIPServer.jar /etc/crRFD.conf /etc/HMServer.conf
              iobroker 12828 18.0  2.8 199400 114016 ?       Ssl  22:55   0:58 iobroker.js-controller
              iobroker 12881  0.4  1.1 136028 47856 ?        Sl   22:56   0:01 io.discovery.0
              iobroker 12896  3.2  1.3 155804 55184 ?        Sl   22:56   0:10 io.info.0
              iobroker 12917  1.1  1.0 144536 41024 ?        Sl   22:56   0:03 io.mihome-vacuum.0
              iobroker 13344  1.4  1.2 153408 49440 ?        Sl   22:56   0:04 io.telegram.0
              iobroker 13365  1.8  1.1 148252 44392 ?        Sl   22:56   0:05 io.hue.0
              iobroker 13511  1.2  1.0 144764 42460 ?        Sl   22:56   0:03 io.hm-rpc.0
              iobroker 13572  1.3  1.1 148148 46580 ?        Sl   22:56   0:04 io.hm-rega.0
              iobroker 13735  1.3  1.2 149256 48172 ?        Sl   22:56   0:03 io.hm-rpc.1
              iobroker 13797  0.7  1.0 136372 41596 ?        Sl   22:56   0:02 io.ping.0
              iobroker 13999  0.7  1.3 148360 54868 ?        Sl   22:56   0:02 io.web.0
              iobroker 14203  3.3  1.4 163012 59532 ?        Sl   22:56   0:09 io.spotify-premium.0
              iobroker 14635  0.7  1.3 148708 53304 ?        Sl   22:57   0:01 io.terminal.0
              iobroker 14673  1.6  1.1 150376 45628 ?        Sl   22:57   0:04 io.zigbee.0
              iobroker 14820  4.9  2.3 199452 92496 ?        Sl   22:57   0:12 io.javascript.0
              iobroker 14906  0.8  1.1 148136 44420 ?        Sl   22:57   0:02 io.yahka.0
              juju     20733  0.0  0.0   7360   484 pts/1    S+   23:01   0:00 grep --color=auto io
              node -v
              v10.18.1
              nodejs -v
              v10.18.1
              npm -v
              6.13.4
              • J JRiddim
                haselchenH
                haselchenH
                haselchen
                @JRiddim
                das ist richtig so.
                und normal sollte alles gehen.
                du kannst mal
                iobroker stop admin.0 eingeben
                und dann wieder starten
                  @JRiddim
                  das ist richtig so.
                  du kannst mal
                  J
                  J
                  JRiddim
                  @haselchen
                  leider auch nicht. ich hatte einen chmod 777 mal auf den iobroker gemacht kann das vllt. damit zusammenhängen?
                  • J JRiddim
                    @haselchen
                    haselchenH
                    haselchenH
                    haselchen
                    @JRiddim
                    Mit Rechtevergaben kenne ich mich nicht aus.
                    Was passiert denn wenn du die IP:8081 eingibst?
                      @JRiddim
                      J
                      J
                      JRiddim
                      @haselchen
                      es tut sich nichts. Auf Vis komme ich ohne weiteres.
                      • J JRiddim
                        @haselchen
                        haselchenH
                        haselchenH
                        haselchen
                        @JRiddim
                        Cache vom Browser geleert?
                        Mal F5 gedrückt nach der IP:8081 Eingabe?
                          @JRiddim
                          J
                          J
                          JRiddim
                          @haselchen
                          :( tut sich leider auch nix
                          • J JRiddim
                            @haselchen
                            haselchenH
                            haselchenH
                            haselchen
                            @JRiddim
                            Hm. Also das ist heavy.
                            Bleibt noch in dem Pfad /opt/iobroker
                            ein
                            npm rebuild
                              @JRiddim
                              ein
                              npm rebuild
                              J
                              J
                              JRiddim
                              @haselchen
                              am Ende wird das hier angezeigt.
                              │ New patch version of npm available! 6.13.4 → 6.13.7 │
                              │ Changelog: https://github.com/npm/cli/releases/tag/v6.13.7 │
                              │ Run npm install -g npm to update! │
                              • J JRiddim
                                @haselchen
                                haselchenH
                                haselchenH
                                haselchen
                                @JRiddim
                                genau das machst du
                                npm install -g npm
                                  @JRiddim
                                  genau das machst du
                                  npm install -g npm
                                  J
                                  J
                                  JRiddim
                                  npm install -g npm
                                  npm install -g npm
                                  npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/bin-links
                                  npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/env-paths
                                  npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/get-caller-file
                                  npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/invert-kv
                                  npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lcid
                                  npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mimic-fn
                                  npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/nopt
                                  npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/semver
                                  npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mem
                                  npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/os-locale
                                  npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pacote
                                  npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs
                                  npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpx
                                  npm ERR! code EACCES
                                  npm ERR! syscall access
                                  npm ERR! path /usr/lib/node_modules/npm/node_modules/bin-links
                                  npm ERR! errno -13
                                  npm ERR! Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/bin-links'
                                  npm ERR!  { [Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/bin-links']
                                  npm ERR!   stack:
                                  npm ERR!    'Error: EACCES: permission denied, access \'/usr/lib/node_modules/npm/node_modules/bin-links\'',
                                  npm ERR!   errno: -13,
                                  npm ERR!   code: 'EACCES',
                                  npm ERR!   syscall: 'access',
                                  npm ERR!   path: '/usr/lib/node_modules/npm/node_modules/bin-links' }
                                  npm ERR!
                                  npm ERR! The operation was rejected by your operating system.
                                  npm ERR! It is likely you do not have the permissions to access this file as the current user
                                  npm ERR!
                                  npm ERR! If you believe this might be a permissions issue, please double-check the
                                  npm ERR! permissions of the file and its containing directories, or try running
                                  npm ERR! the command again as root/Administrator.
                                  npm ERR!     /home/juju/.npm/_logs/2020-01-29T22_36_52_146Z-debug.log
                                  muss ich das mit sudo ausführen?
                                  • J JRiddim
                                    npm install -g npm
                                    npm install -g npm
                                    npm ERR! errno -13
                                    npm ERR!   stack:
                                    npm ERR!
                                    npm ERR!
                                    haselchenH
                                    haselchenH
                                    haselchen
                                    @JRiddim
                                    wäre meine nächste idee gewesen ;)
                                    Den Befehl aber nicht im iobroker verzeichnis eingeben
                                    sondern im hauptverzeichnis vom PI
                                    J 2 Antworten Letzte Antwort
                                      @JRiddim
                                      J
                                      J
                                      JRiddim
                                      @haselchen
                                      :) mit sudo
                                      sudo npm install -g npm
                                      [sudo] Passwort für juju:
                                      /usr/bin/npm -> /usr/lib/node_modules/npm/bin/npm-cli.js
                                      /usr/bin/npx -> /usr/lib/node_modules/npm/bin/npx-cli.js
                                      + npm@6.13.7
                                      added 7 packages from 3 contributors, removed 3 packages and updated 12 packages in 62.708s
                                      jetzt zeigt er mir admin.0 als alive!
                                      • system.adapter.admin.0 : admin - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        @JRiddim
                                        J
                                        J
                                        JRiddim
                                        @JRiddim
                                        oh das Mist ich habe es im Biobroker Verzeichnis gemacht! Hab das völlig überlesen!
                                        • J JRiddim
                                          @haselchen
                                          :) mit sudo
                                          + npm@6.13.7
                                          haselchenH
                                          haselchenH
                                          haselchen
                                          @JRiddim
                                          Wiederhol es einfach im Hauptverzeichnis nochmal.
                                          Bitte sag das es jetzt funktioniert :)
                                          84.2k
