  4. Test Adapter Contact v1.1.x
contactkontakttestetestgooglegoogle kontaktgoogle contactadapteradapter test
161 Beiträge 11 Kommentatoren 29.2k Aufrufe 13 Beobachtet
  • bahnuhrB bahnuhr
    Update durchgeführt.
    Instanz stop und neu gestartet.
    Im log kam dann das:
    contact.0	2019-12-29 21:50:08.160	info	Delete channel contact.0.7489793e0c0a54f3_emailAddress
    contact.0	2019-12-29 21:50:08.160	warn	contact.0.7489793e0c0a54f3.emailAddress
    contact.0	2019-12-29 21:50:08.160	info	Delete channel contact.0.7489793e0c0a54f3_phoneNumber
    contact.0	2019-12-29 21:50:08.160	warn	contact.0.7489793e0c0a54f3.phoneNumber
    contact.0	2019-12-29 21:50:08.160	info	Delete channel contact.0.7489793e0c0a54f3_address
    contact.0	2019-12-29 21:50:08.160	warn	contact.0.7489793e0c0a54f3.address
    contact.0	2019-12-29 21:50:08.160	info	Delete channel contact.0.1fc4cc300ef3f10b_phoneNumber
    contact.0	2019-12-29 21:50:08.160	warn	contact.0.1fc4cc300ef3f10b.phoneNumber
    contact.0	2019-12-29 21:50:08.160	info	Delete channel contact.0.544897b889cf4f2d_phoneNumber
    contact.0	2019-12-29 21:50:08.160	warn	contact.0.544897b889cf4f2d.phoneNumber
    contact.0	2019-12-29 21:50:08.160	info	Delete channel contact.0.3167a5398d057924
    contact.0	2019-12-29 21:50:08.160	warn	contact.0.3167a5398d057924
    contact.0	2019-12-29 21:50:08.160	info	Delete channel contact.0.6be0d3ee8bf7255c
    contact.0	2019-12-29 21:50:08.160	warn	contact.0.6be0d3ee8bf7255c
    contact.0	2019-12-29 21:49:46.805	info	Contacts for account "Contact Google" have been updated.
    contact.0	2019-12-29 21:49:46.805	info	No display name found for connection.
    contact.0	2019-12-29 21:49:44.712	info	starting. Version 1.0.1 in C:/ioBroker/node_modules/iobroker.contact, node: v10.18.0
    Dann alle Objekte gelöscht.
    Neu gestartet.
    Und dann kam im log :
    contact.0	2019-12-29 21:57:48.446	info	Contacts for account "Contact Google" have been updated.
    contact.0	2019-12-29 21:57:48.446	info	No display name found for connection.
    contact.0	2019-12-29 21:57:46.452	info	starting. Version 1.0.1 in C:/ioBroker/node_modules/iobroker.contact, node: v10.18.0
    Fazit:
    Dann hat es wohl geklappt.
    Allerdings hab ich immer noch einen mit "..No display name..."
    Schalte mal auf debug.
    mfg
    bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    #111
    @bahnuhr sagte in Test Adapter Contact v1.0.x:
    Und dies war ein Kontakt wo nur eine email stand.
    Also weder Name, Vorname noch Unternehmen.
    Habs nun mal in google geändert.
    Danke.
    • bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      #112
      So, auf google geändert.
      Instanz neu gestartet.
      Und der Fehler ist weg.
      contact.0	2019-12-29 22:05:55.170	info	Contacts for account "Contact Google" have been updated.
      contact.0	2019-12-29 22:05:52.919	info	starting. Version 1.0.1 in C:/ioBroker/node_modules/iobroker.contact, node: v10.18.0
      So findet man Fehler auf google ;-)
      Danke.
      • bahnuhrB bahnuhr
        Noch ne Idee:
        In google sind die Kontakte ja eingeordnet in Gruppen, z.B.
        Privat, Firma, Freunde, etc. (zumindest bei mir so.)
        In der Fritz.box kann man nun auswählen welche Gruppe übernommen werden soll (oder auch alle).
        Wäre doch ne Idee wenn das hier auch auswählbar wäre.
        Also, z.B.:
        Die Gruppen werden in der config der Instanz angezeigt und man kann auswählen ob man nur einzelne übernehmen will.
        mfg
        Dieter
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        #113
        Noch ne Idee:
        Also, z.B.:
        mfg
        Dieter
        Das wäre noch ne Idee / Wunsch von mir.
        mfg
        Danke.
        • J.A.R.V.I.S.J J.A.R.V.I.S.
          @bahnuhr Debug ist super, da wird der fehlerhate ausgegeben. Du kannst aber auch schon einmal schauen, ob dein Unternehmen überhaupt angezeigt wird. Vielleicht ist sonst doch noch ein Fehler da.
          liv-in-skyL Offline
          liv-in-skyL Offline
          #114
          @J-A-R-V-I-S hi
          er startet und legt alle datenpunkte an - morgen kontrolliere ich den cpu verbrauch - der erste start funktioniert auf jeden fall
          • a200A Offline
            a200A Offline
            a200
            #115
            @J-A-R-V-I-S
            bis jetzt läuft alles ganz gut. CPU-Load bleibt niedrig. Allerdings gab es noch kein reload des Adapters.
            Das in Nextcloud erzeugte App-Passwort funktioniert problemlos.
            Danke für deine Arbeit.
            IoBroker auf QNAP TS-451, Raspi und NUC
            J.A.R.V.I.S.J 1 Antwort Letzte Antwort
            • a200A a200
              @J-A-R-V-I-S
              J.A.R.V.I.S.J Offline
              J.A.R.V.I.S.
              #116
              @a200 sagte in Test Adapter Contact v1.0.x:
              Freut mich zu hören.
              Was genau meinst du mit reload?
              liv-in-skyL a200A 2 Antworten Letzte Antwort
                liv-in-skyL Offline
                liv-in-skyL Offline
                #117
                @J-A-R-V-I-S
                bei mir auch nix auffallendes 👍
                  a200A Offline
                  a200A Offline
                  a200
                  #118
                  @J-A-R-V-I-S sagte in Test Adapter Contact v1.0.x:
                  Damit meinte ich die erneute Synchronisation nach 12 Stunden. Aber auch die ist problemlos durchgelaufen. Danke!
                  • bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    #119
                    @J-A-R-V-I-S
                    Könntest du uns da unterstützen:
                    https://forum.iobroker.net/topic/28294/asynchron-callback-promise-await-hilfe/20
                    Danke.
                      Aktuelle Test Version 1.1.2
                      Veröffentlichungsdatum 07.01.2020
                      Github Link https://github.com/WLAN-Kabel/ioBroker.contact
                      NPM Link https://www.npmjs.com/package/iobroker.contact
                      Da es einen Wunsch nach einem Contact Adapter gab, habe ich mich mal dran gesetzt und möchte euch nun darum bitten, diesen zu test.
                      Funktionen
                      • lädt eure Kontakte aus eurem Google Konto in ioBroker
                      • Rückwärtssuche von Kontakten (Telefonnummer eingeben, Kontakt erhalten)
                      Konfiguration
                      Damit Ihr den Adapter verwendet könnt, benötigt ihr einen API Key.
                      Wichtig: Sollte dein ioBroker nicht lokal laufen, musst du zunächst noch folgende Schritte durchführen:
                      Windows:
                      Öffne nodepad.exe mit Adminrechten und öffne die Datei C:\Windows\System32\drivers\etc\hosts. Füge einen Eintrag hinzu:
                      192.168.0.10 example.com //<IP-Adresse ioBroker> <FQDN>
                      Speichere die Datei und lass das Programm geöffnet. Rufe deinen ioBroker über die Domain auf, die du gerade eingetragen hast. Beispiel:
                      http://example.com:8081
                      Trage in der Adapterconfig im Reiter Google bei FQDN deinen Eintrag ein. Beispiel: example.com
                      Wichtig: Wenn du die komplette Konfiguration fertig hast, lösche den Eintrag wieder aus der Datei und speichere die Datei wieder ab.
                      Linux:
                      Die Vorgehensweise ist mir nicht bekannt, darf mir gerne Beschrieben werden, wird dann hier eingefügt.
                      Mac
                      API Key besorgen:
                      • Gehe auf https://console.cloud.google.com/apis/dashboard und logge dich mit deinem Google Account ein.
                      • Öffne die Liste in der Kopfzeile und erstelle im sich öffnenden Fenster ein neues Projekt.
                      • Gib einen Namen ein und klicke auf erstellen. Beispielname: "ioBroker"
                      • Gehe sicher, dass du das richtige Projekt in der Liste ausgewählt hast.
                      • Öffne den Tab "Bibliothek" und suche dort nach "people".
                      • Wähle den Eintrag "Google People API" und klicke auf "aktivieren".
                      • Klick auf "APIs & Dienste" und öffne den Tab "OAuth-Zustimmungsbildschirm".
                      • Schreibe dort einen Namen und speichere die Seite ab.
                      • Öffne den Tab"Anmeldedaten" und klicke auf "Anmeldedaten erstellen".
                      • Wähle "OAuth-Client-ID" und im nächsten Fenster "Webanwendung".
                      • Trage dort einen Namen ein z.B. "ioBroker" oder "Webclient".
                      • Füge "JavaScript Quellen" folgenden Eintrag hinzu: http://<FQDN aus Adapterconfig>:<Port aus Adapterconfig>
                      • Füge bei "Authorisierte Rediret URIs" folgende Einträge hinzu: http://<FQDN aus Adapterconfig>:<Port aus Adapterconfig>/google und http://<FQDN aus Adapterconfig>:<Port aus Adapterconfig>/google/
                      • Speichere diese Seite und kopiere dir die darauf angezeigte Client ID sowie das Client Secret.
                      • Füge beide in die Adapterconfig ein und starte den Adapter.
                      Authentifizieren:
                      Schaue im Log nach, dort wird dir ein Link mitgeteilt, über den du dich Authentifizieren kannst. Sollte alles gut gehen, steht am Ende ein "Done" im Browser Fenster.
                      Changelog
                      1.1.3 (2020-01-23)
                      • Staterollen wurden auf Offizielle geändert
                      • Deprecation von Buffer behoben
                      • Fehlerbehandlung vom HTTP-Server hinzugefügt
                      1.1.2 (2020-01-07)
                      • Der Server wird beim beenden gestoppt
                      • Adapter aus den Statuseinstellungen entfernt
                      1.1.1 (2020-01-06)
                      • Cron job wird beim beenden des Adapters gestoppt
                      • Problem behoben, bei dem nicht alle States gelöscht wurden
                      • Einige Debugnachrichten hinzugefügt
                      1.1.0 (2020-01-05)
                      • sendTo() wird jetzt unterstützt
                      • Problem behoben, bei dem Straßen in die Rolle geschrieben werden
                      • Problem behoben, bei dem Kontakte beim Aktualisieren gelöscht werden
                      1.0.1 (2019-12-29)
                      • Problem mit Unternehmen in Google-Kontakten behoben
                      • 'undefined' von fullName entfernt, wenn ein Name fehlt
                      • Adapter hängt nicht mehr beim Aktualisieren auf
                      • Nextcloud-Standardkennwort geändert, da das alte Kennwort Nachrichten verursachte
                      1.0.0 (2019-12-23)
                      • Nextcloud Kontakte wurden hinzugefügt
                      • Neuer DP fullName bei der Suche sowie bei allen Kontakten
                      • FDQN und Intervall wurden auf die Hauptseite verschoben
                      • Channelnamen für addresses, emailAddresses und phoneNumbers wurden geändert
                      • Neuer DP type für emailAddresses und phoneNumbers
                      0.0.3 (2019-12-21)
                      • Der Standard-Ländercode kann jetzt selbst ausgewählt werden.
                      0.0.2 (2019-12-21)
                      • Es wurde ein Problem behoben, durch das die Suche eingeschränkt wurde.
                      • Begrenzung von 100 Kontakten wurde entfernt.
                      0.0.1 (2019-12-17)
                      • Erstveröffentlichung
                      Datenpunkte
                      contact.0.
                      Datenpunkt Beschreibung
                      query Dort wird die Rufnummer eingetragen, nach der gesucht werden soll
                      familyName Familienname des Kontaktes, der gesucht wurde (kann direkt für die VIS genutzt werden)
                      givenName Vornamename des Kontaktes, der gesucht wurde (kann direkt für die VIS genutzt werden)
                      photo Foto des Kontaktes, der gesucht wurde (kann direkt für die VIS genutzt werden)
                      id ID des Kontaktes, der gesucht wurde (kann in der nachfolgenden Tabelle bei <id> eingesetzt werden, für Scripte interessant)
                      contact.0.<id>.
                      addresses.* Adressen des Kontaktes
                      emailAddresses.* Emailadressen des Kontaktes
                      phoneNumbers.* Rufnummern des Kontaktes
                      Javascript
                      An den Adapter kann per sendTo() eine Anfrage geschickt werden, so wie es auch der query Datenpunkt macht, jedoch erhalt man dadurch ein JSON Object zurück, das man in einem Skript verarbeiten kann (Wurde auch schon genutzt: https://forum.iobroker.net/topic/28294/asynchron-callback-promise-await-hilfe.
                      sendTo('contact.0', 'query', {phonenumberr: '+49 1234 567890'}, (obj) => {
                          if(obj.error) {
                              log(obj.error);
                          } else {
                              log(JSON.stringify(obj.contact));
                      Für weitere Ideen und Vorschläge bin ich offen und freue mich auf eure Hilfe.
                      Ihr müsst nicht zwingend hier Kommentieren, sondern könnt dies auch auf Github tun.
                      Vielen Dank im Vorraus :)
                      Todo
                      Hilfe
                      Wer Probleme bei der Konfiguration hat, kann auch mal im folgenden Thread vorbeischauen, dort wurden schon ein paar Probleme erleutert (https://forum.iobroker.net/topic/27136/ideensammlung-kalender-adapter-google-outlook/29). Der Adapter verwendet die gleiche Vorgehensweise bezüglich des API Keys und Authetifizierung.
                      sigi234S Online
                      sigi234S Online
                      #120
                      @J-A-R-V-I-S
                      Contacte werden einfach beim abrufen alle gelöscht? V 1.0.1
                      contact.0 2020-01-04 18:00:00.145 info (1812) Delete channel contact.0.29814fd08ebf0078
                      contact.0 2020-01-04 18:00:00.145 warn (1812) contact.0.29814fd08ebf0078
                      usw...........
                      • sigi234S sigi234
                        @J-A-R-V-I-S
                        usw...........
                        J.A.R.V.I.S.
                        #121
                        @sigi234 wenn die Kontakte aus deinem Telefonbuch gelöscht wurden, dann werden sie auch im ioBroker gelöscht. Ich könnte dies aber mal mitnehmen und als Option in die Adapterkonfig packen. Dann kann man wählen ob gelöschte Kontakte aus ioBroker entfernt werden sollen.
                          sigi234S Online
                          sigi234S Online
                          #122
                          Nein , ich habe keine Kontakte gelöscht, weder im Handy noch bei Google.```
                          LOG Auszug gekürzt:
                          2020-01-04 19:00:00.218 - info: contact.0 (14224) Delete channel contact.0.4ec003398fbe5535
                          2020-01-04 19:00:00.218 - warn: contact.0 (14224) contact.0.3a2d07da8c0b220e
                          2020-01-04 19:00:00.219 - info: contact.0 (14224) Delete channel contact.0.3a2d07da8c0b220e
                          2020-01-04 19:00:00.219 - warn: contact.0 (14224) contact.0.f87d3cd0a1bf44c
                          2020-01-04 19:00:00.219 - info: contact.0 (14224) Delete channel contact.0.f87d3cd0a1bf44c
                          2020-01-04 19:00:00.512 - info: contact.0 (14224) Contacts for account "contact" have been updated.
                          2020-01-04 19:01:11.454 - debug: contact.0 (14224) Queried phonenumber:
                          2020-01-04 19:01:11.457 - debug: contact.0 (14224) Compared phonenumber: 43xxxxxxxxx
                          43xxxxxxxxxxx
                          Wird jede Stunde ausgeführt, da im Adapter ja auf Jede Stunde gestellt.
                          Screenshot:
                          Daten kommen erst nach dem die Instanz neu geladen wurde.
                          J.A.R.V.I.S.J bahnuhrB 2 Antworten Letzte Antwort
                          • bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            #123
                            @J-A-R-V-I-S
                            Ich hatte dies auch schon. Nach einem Update kam dann dieses Verhalten (delete).
                            Habe dann alle Objekte gelöscht und Instanz neu gestartet.
                            Dann hat es wieder gepasst.
                            mfg
                            Danke.
                            • sigi234S sigi234
                              LOG Auszug gekürzt:
                              43xxxxxxxxxxx
                              Screenshot:
                              J.A.R.V.I.S.
                              #124
                              @sigi234 okay, das werde ich mir anschauen.
                              • bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                #125
                                Fehler gefunden !
                                Die Straße wird in die Rolle geschrieben:
                                Danke.
                                  sigi234S Online
                                  sigi234S Online
                                  #126
                                  OO:OO Uhr und ALLES wurde gelöscht!
                                  • bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    #127
                                    Jetzt sind bei mir sämtlichen Namen und Adressen weg ?!?!?
                                    Danke.
                                    • bahnuhrB bahnuhr
                                      sigi234S Online
                                      sigi234S Online
                                      #128
                                      @bahnuhr
                                      Ja, da stimmt was nicht. Adapter neu starten und sie kommen wieder.
                                      • bahnuhrB Online
                                        bahnuhrB Online
                                        bahnuhr
                                        #129
                                        So,
                                        Instanz gelöscht.
                                        Browsercache gelöscht.
                                        Instanz neu installiert.
                                        google neu eingegeben.
                                        Jetzt sind sie wieder da.
                                        Straße ist immer noch falsch.
                                        @sigi234
                                        Ist bei dir die Straße auch falsch ?
                                        Danke.
                                        • bahnuhrB bahnuhr
                                          So,
                                          Instanz gelöscht.
                                          @sigi234
                                          sigi234S Online
                                          sigi234S Online
                                          #130
                                          Da steht gleich nix drinnen.
