  4. Test Adapter HeatingControl v3.xx
heating
3.3k Beiträge 239 Kommentatoren 2.5m Aufrufe 201 Beobachtet
  • G guergen
    @Hobi Nimm das Widget (vis-jqui-mfd muss installiert sein):
    [{"tpl":"tplJquiInputDatetime","data":{"oid":"heatingcontrol.0.Profiles.0.Bad.Mon.Periods.0.time","g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"timeOnly":true,"hideSeconds":true,"size":"4","class":"","filterkey":"","name":"Mo Zeit bis","locked":false,"g_last_change":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"140px","top":"470px","width":"77px","height":"25px","font-weight":"bold","font-size":"","word-spacing":"","letter-spacing":"","line-height":"","z-index":"10","color":"","border-width":"","border-style":"","border-radius":"4px"},"widgetSet":"jqui"}]
    Hobi
    #717
    @guergen
    Hallo! Das hatte ich Anfangs genommen - allerdings öffnet der Fully oder auch Chrome auf meinem Tablet dann immer eine Tastatur.
    Daher habe ich ein System verwendet, dass ich bereits bei meiner Timer-Konfiguration verwendet habe.
    LG
    Holger
    P.S.: Guten Rutsch!
    • G guergen
      Hobi
      #718
      @guergen
      LG
      Holger
      P.S.: Guten Rutsch!
      • Rene_HMR Rene_HM
        @martinschm sagte in Test Adapter HeatingControl v0.3.x:
        ist evtl untergegangen
        nein, das habe ich noch auf dem Schirm. Ich verstehe hier leider nur noch nicht, was hier schief läuft. Da bin ich noch am suchen...
        Welche Version vom adapter läuft eigentlich bei dir?
        martinschm
        #719
        @Rene_HM said in Test Adapter HeatingControl v0.3.x:
        Hi Rene,
        frohes neues Jahr.
        Bei mir läuft 0.3.9
        Rene_HMR 1 Antwort Letzte Antwort
        • M martinschm
          Hi Rene,
          frohes neues Jahr.
          Bei mir läuft 0.3.9
          Rene_HMR Offline
          Rene_HMR Offline
          Rene_HM
          #720
          @martinschm nimm mal bitte die 0.3.14 aus github. Ich habe dort noch ein log hinzugefügt, dann sollte ich sehen, wo das Problem leigt...
          • P Offline
            Pittini
            #721
            Vis Update 1.1.20 - Update der Mehrprofilversion.
            Hinzugefügt: "Aktiv" im Statusfenster, zeigt an welche Heizperiode gerade aktiviert ist.
            Hinzugefügt: "Minimaltemperatur" bei den Profilparametern, korrespondierend zur neuen Einstellmöglichkeit im Adapteradmin (löschen wenn unbenutzt).
            Hinzugefügt: Grüner Balken unter den Zeit/Temp Einstellungen zur Anzeige der gerade aktiven Periode
            Hinzugefügt: Anzeige des aktiven Profils in allen relevanten Blöcken "(P1...)
            Edit: Kosmetik
            Sieht jetzt so aus
            • Jan FiedlerJ Offline
              Jan Fiedler
              #722
              gibt es eine "Start"anleitung? Bei mir wird nach Installation des Adapters nichts an Geräten und/oder Räumen gefunden. Bekomme nur die Meldung " (23387) device list is empty, add dummy device [{"id":0,"name":"TestThermostat","isActive":false,"room":"Office","type":1,"OID_Current":"Test_OID"}]"
              • P Pittini
                Edit: Kosmetik
                Sieht jetzt so aus
                MyMeyer
                #723
                @Pittini sagte in Test Adapter HeatingControl v0.3.x:
                Wie ist der Thread zum View damit ich ein Import machen könnte ?
                MyMeyer
                Hardware: Intel I5 mit ****Debian ProxMox OS: Debian **** <<< >>> Network with UniFi <<<
                HomeMatic CCU-2 (Wired und Funk) / Philips HUE / Echo.DOT / Echo.SHOW / Xiaomi Smart-Home / Xiaomi Robot Vacuum Cleaner / Synology DS 918+ / Shelly 1&2 <<<
                P 1 Antwort Letzte Antwort
                • M MyMeyer
                  Pittini
                  #724
                  @MyMeyer sagte in Test Adapter HeatingControl v0.3.x:
                  Einfach auf das blaue "Vis" in der Ankündigung klicken, das isn Link.
                  • G Offline
                    Gsiberger
                    #725
                    Um den WAF nicht von Anfang an auf Gefriertemperatur zu setzen, möchte ich für das Badezimmer auf Knopfdruck den Override realisieren. Wird der Taster gedrückt werden TemperaturOverride und TemperaturOverrideTime beschrieben.
                    Das Blockly:
                    Die Temperatur und Zeit werden gesetzt und der Status geht auch auf override
                    Im Log sind nach dem starten des Scripts diese Meldungen:
                    2020-01-02 16:30:53.568 - info: javascript.0 (22252) script.js.common.Tests.Baden__Duschen: Typ von TemperaturOverride ist string
                    2020-01-02 16:30:53.569 - warn: javascript.0 (22252) You are assigning a string to the state "heatingcontrol.0.Rooms.aTEST.TemperaturOverride" which expects a float. Please fix your code to use a float or change the state type to string. This warning might become an error in future versions.
                    Wenn ich die Solltemperatur nicht konvertiere, dann ist die erste Warnmeldung:
                    You are assigning a number to the state .....
                    Wie kann ich das Blockly ändern, damit es nicht zu diesen Warnungen kommt? Der Typ der Solltemperatur wurde auf alle möglichen (und unmöglichen) Einstellungen geändert um ohne Konvertierung zu übergeben, alles leider ohne Erfolg.
                    Kurt
                    • Jan FiedlerJ Jan Fiedler
                      Rene_HMR Offline
                      Rene_HMR Offline
                      Rene_HM
                      #726
                      @Jan-Fiedler eine Start-Anleitung gibt es noch nicht, aber die Frage wurde hier schon öfters gestellt...
                      1. keine Räume: das liegt daran, dass du in der Aufzählung hier keine Räume hast. Einfach Räume hinzufügen und im admin "Suche Räume" anklicken.
                      1. keine Geräte: Derzeit werden nur Homematic - Geräte automatisch gefunden. Alles andere muss manuell konfiguriert werden:
                      Jan FiedlerJ 1 Antwort Letzte Antwort
                      • G Gsiberger
                        Das Blockly:
                        Rene_HMR Offline
                        Rene_HMR Offline
                        Rene_HM
                        #727
                        @Gsiberger mit Blockly kenne ich mich nicht aus. Mit javascript würde ich folgendes versuchen:
                        setState('heatingcontrol.0.Rooms.Arbeitszimmer.TemperaturOverride', parseFloat("25.0"));
                        setState('heatingcontrol.0.Rooms.Arbeitszimmer.TemperaturOverrideTime',"00:20");
                        Ich denke aber, die Warnung kannst du ignorieren, solange die Werte übernommen werden...
                        G 1 Antwort Letzte Antwort
                        • Rene_HMR Rene_HM
                          Gsiberger
                          #728
                          @Rene_HM
                          OK, danke
                          Kurt
                          • Rene_HMR Rene_HM
                            Jan Fiedler
                            #729
                            @Rene_HM Danke!
                            • P Offline
                              Paan83
                              #730
                              der Adapter läuft jetzt seid zwei Wochen und erstmal ein grosses Dankeschön an @Rene_HM für diese tolle Arbeit.
                              Zwei kleine Fragen hätte ich noch:
                              -Ich habe momentan die Version 0.3.10. Wie installiere ich die neueste Version des Adapters ohne dass ich die alte Instanz deinstallieren muss? Oder kann man nicht einfach "drüberinstallieren"? Ich habs mit dem Button upload versucht, bleibt aber immer auf Version 0.3.10.
                              -Ich hab in einem Raum drei Thermostate von HM und habe mir jetzt einen Wandthermostat von HM dazu gekauft. Wo muss ich im Adapter welche welche Eintragen, damit das Zusammenspiel der Heizkörperthermostate und des Wandthermosatates funktioniert?
                              Danke euch
                              • P Paan83
                                Danke euch
                                Sempre
                                #731
                                @Paan83
                                zu 1. Entweder das Repository auf Latest stellen, dann sind auch nicht Stable Updates sichtbar, du solltest dir dann aber im klaren sein was du machst, oder einfach über den Github-Link wie bei der initialen Installation "drüber" installieren.
                                zu 2. Du konfigurierst in der CCU eine Gruppe bzw. verknüpfst deine Thermostate mit dem Wandthermostat und wenn das alles passt änderst du in Heatingcontrol einfach in dem entsprechenden Raum deine Konfiguration auf den Wandthermostat ab. Der Wandthermostat steuert ja die einzelnen Heizkörper, das muss nicht durch Heatingcontrol erfolgen. Ich habe es genau so bei mir auch am laufen und das nun seit ca. 3 Monaten.
                                • S Sempre
                                  @Paan83
                                  Paan83
                                  schrieb am zuletzt editiert von Paan83
                                  #732
                                  @Sempre
                                  Danke für deine schnelle Antwort.
                                  Das Update hat geklappt 👍
                                  Okay habe eine Gruppe in der CCU erstellt. Was muss ich jetzt im Heating Control Adapter wo reinsetzen?
                                  Momentan sieht es so aus:
                                  Diese Heizkörperthermostate müssten ja dann auch wieder auf Automatik gestellt werden, oder irre ich mich?
                                  • P Offline
                                    Paan83
                                    #733
                                    Ich habe das Wandthermostat mal eingetragen und die Heizkörperthermostate deaktiviert. Bildschirmfoto 2020-01-03 um 12.12.09.png
                                    Das Wandthermostat muss auf jetzt auf manuell stehen, und die Heizkörperthermostate auf Automatik oder müssen die auch auf Manuell eingestellt sein?
                                    • Rene_HMR Rene_HM
                                      inspiriert vom Heizungsthermostat-Script und weil meine homeputer-Lizenz abgelaufen ist, und ich meine Heizungssteuerung von dort nach iobroker portieren wollte, ist der Adapter HeatingControl entstanden.
                                      Features:
                                      • setzen der Zieltemperatur in verschiedenen Thermostaten
                                      • beliebige Anzahl von täglichen Zeitabschnitten mit unterschiedlichen Zieltemperaturen
                                      • Zeit und Zieltemperatur per Visualisierung konfigurierbar
                                      • automatische Suche nach vorhandenen Thermostaten im System (über Gewerk) und Zuordnung zu Räumen
                                      • Für den Fall, dass der Thermostat nur als Thermometer verwendet wird, behandelt der Adapter auch digitale Outputs zum Schalten der Ventile. Im Moment ist dafür nur eine einfache Ein/Aus-Regelung implementiert (die für meine Zwecke ausreichend ist). Weitere Regelungen sind aber als Idee bereits vorhanden und können implementiert werden. Es gibt nun auch einen linearen on/off mit Hysterese
                                      • es werden bis zu zwei Outputs für Ventile unterstützt
                                      • Outputs werden auch automatisch den Räumen zugeordnet. Dafür müssen diese dem gleichen Gewerk wie Thermostate zugeordnet sein.
                                      • im Admin des Adapters können Räume deaktiviert werden
                                      • Absenkung bei Abwesenheit
                                      • Ventile ein oder aus außerhalb der Heizperiode
                                      • Verbindung zu ical
                                      • Verbindung zu Feiertags-Adapter
                                      • Senden von Nachrichten per email, Signal, Telegram, discord, ...
                                      • Kamin-Modus
                                      • Wartungsmodus
                                      • mehrere Profile
                                      • Tages-Programme für
                                        - Montag - Sonntag
                                        - Montag - Freitag + Samstag - Samstag
                                        - jeden Tag separat
                                      Versionen:
                                      • 3.0.0
                                        Status: beta seit 29.12.2025
                                        NPM: ja
                                        github: ja
                                        weitere Informationen: github
                                      • 2.12.19
                                        Status: stable seit 26.10.2025
                                        NPM: ja
                                        github: ja
                                      W Offline
                                      W Offline
                                      Wiggins
                                      #734
                                      @Rene_HM Geh ich recht in der Annahme, dass ich für diesen Adapter zwingend eine CCU benötige? Nur Homematic IP mit Accesspoint reicht hier nicht, oder?
                                      • W Wiggins
                                        Rene_HMR Offline
                                        Rene_HMR Offline
                                        Rene_HM
                                        #735
                                        @Wiggins nein, du brauchst die CCU nicht. Wenn deine Homematic IP in ioBroker intergriert ist, solltest du die notwendigen Datenpunkte (eigentlich im einfachsten Fall nur die Zieltemperatur des Thermostat) bereits im System haben. Du musst dann nur noch den Datenpunkt hier im Adapter konfigurieren (siehe ein paar posts weiter oben...)
                                        W 1 Antwort Letzte Antwort
                                          K_o_bold
                                          #736
                                          @Rene_HM ,
                                          ich bin gerade auf diesen Adapter aufmerksam geworden und überlege ob er all meine jetzigen Skripte ablösen könnte.
                                          Erst mal vielen Dank für deine Arbeit. Ich habe ihn zwar noch nicht installiert, aber was man hier so ließt sieht vielversprechend aus.
                                          Ich habe eine Frage.
                                          Ich habe Fenstersensoren die ich zur Thermostatregelung verwende. Folgendes passiert in meinem Skript.
                                          Und zwar wenn das Fenster geöffnet wird, warte ich solange bis sich das Ventil öffnet ( Heizen beginnt) und gebe dann eine Solltemperatur von 5 Grad vor( Heizen beenden).
                                          Dieses Vorgehen erscheint mir die beste Lösung, um nicht unnötig das Thermostat zu schalten. Wenn man kurz das Fenster zum lüften aufmacht, wird es nicht immer so kalt, dass das Thermostat aufmacht.
                                          Die Frage ist also, kann ich den Datenpunkt "Ventilstellung" für die Fenster offen Erkennung als Trigger verwenden?
