  5. Gedanken zur Feinstaubmessung
150 Beiträge 10 Kommentatoren 30.5k Aufrufe 8 Beobachtet
  • HomoranH
    #98
    Letzte Änderung für heute:
     <variables>
       <variable type="" id="|zrtv-e98n%+)6SmMQGz">Anfang</variable>
       <variable type="" id="#UHnaMpV=lSawq.B$u/_">tausch</variable>
       <variable type="" id="%g9ob`$FnQ!zF#~C8Ret">Ende</variable>
       <variable type="" id="2DY4,TA7#ra1oA6Bz925">URL</variable>
       <variable type="" id="+7xcGWJ647XP265eD.Ll">JSON</variable>
       <variable type="" id="d[?QaF(N/mc|eq/IOy75">Param1</variable>
       <variable type="" id="@hb0FIlN^F6YBg^(y}Pm">Station</variable>
       <variable type="" id="IN6AA6TiKW]?_gBN5J!v">SensemapJson</variable>
       <variable type="" id="?%Q@y58(tY1cXr7e17Gc">Unit1</variable>
       <variable type="" id="kXTaix[lp7nNNGO=Zc+@">result</variable>
       <variable type="" id="s@1tudN:J=lhR59TGl{3">Sensor1</variable>
       <variable type="" id="G7^Cu8s)%C@Yuc,yq:|[">Wert1</variable>
       <variable type="" id="Dj2Zyap_1N~eP!+x^$`B">Pfad</variable>
     </variables>
     <block type="variables_set" id="FQtuv{|Ya/Ot:jPQ_n7`" x="62" y="-912">
       <field name="VAR" id="|zrtv-e98n%+)6SmMQGz" variabletype="">Anfang</field>
       <value name="VALUE">
         <block type="math_number" id="Kv4sBHn,XC@!]A7I[f(i">
           <field name="NUM">0</field>
         </block>
       </value>
       <next>
         <block type="variables_set" id="P4j]IyBxs.:ehO`N#lN.">
           <field name="VAR" id="%g9ob`$FnQ!zF#~C8Ret" variabletype="">Ende</field>
             <block type="math_number" id="g$70HI]Kt!Q.)tZQK[Pg">
             </block>
           </value>
           <next>
             <block type="variables_set" id="tIZY3oqO)|P0~/DcO);}">
               <field name="VAR" id="+7xcGWJ647XP265eD.Ll" variabletype="">JSON</field>
                 <block type="text" id="aJ%kCZCrT#wMIt-|-$uJ">
                   <field name="TEXT">leer</field>
                 </block>
               </value>
               <next>
                 <block type="variables_set" id="5WmS{8Gu)!|OLFGxd1*_">
                   <field name="VAR" id="d[?QaF(N/mc|eq/IOy75" variabletype="">Param1</field>
                     <block type="text" id="sk7Oa[r2x[O+}zh]jh;I">
                     </block>
                   </value>
                   <next>
                     <block type="variables_set" id="agz5l]A3M1?R5tjDMM|`">
                       <field name="VAR" id="?%Q@y58(tY1cXr7e17Gc" variabletype="">Unit1</field>
                         <block type="text" id=";%v6zGGw8ltr/KfOT9m-">
                         </block>
                       </value>
                       <next>
                         <block type="variables_set" id="@R`~[Kt_N@ZwqJ$q*AYA">
                           <field name="VAR" id="s@1tudN:J=lhR59TGl{3" variabletype="">Sensor1</field>
                             <block type="text" id="~OUigK^EGJrnUq1z5pK`">
                             </block>
                           </value>
                           <next>
                             <block type="variables_set" id="L1BTNCNCyf$`cFoeHi^b">
                               <field name="VAR" id="G7^Cu8s)%C@Yuc,yq:|[" variabletype="">Wert1</field>
                                 <block type="math_number" id="bbN[Tip0g;Q)H`aTIOBS">
                                 </block>
                               </value>
                               <next>
                                 <block type="variables_set" id="uK/sjNNqX.M=;f:vwWKx">
                                   <field name="VAR" id="IN6AA6TiKW]?_gBN5J!v" variabletype="">SensemapJson</field>
                                     <block type="text" id=":EK7!rwUA9Cr(hS._@?a">
                                     </block>
                                   </value>
                                   <next>
                                     <block type="comment" id="SO{1x)9(IrO=t/HzhQ{q">
                                       <field name="COMMENT">StationsID hier eintragen</field>
                                       <next>
                                         <block type="variables_set" id="yf|Zs$Eg)0-sY-z@UPq%">
                                           <field name="VAR" id="@hb0FIlN^F6YBg^(y}Pm" variabletype="">Station</field>
                                             <block type="text" id="{v/]|(@@$?rt:K?ykRBS">
                                               <field name="TEXT">5daad22b25683a001a6260f5</field>
                                             </block>
                                           </value>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </next>
     </block>
     <block type="procedures_defnoreturn" id="S0*nkNsu`02K8Z[2=4oC" x="988" y="-937">
       <field name="NAME">Sensorwerte_auslesen</field>
       <statement name="STACK">
         <block type="variables_set" id="c0[adpg`4BA?`19@Z+G/">
             <block type="text_indexOf" id=",Ifp_}FhWon~]!uqsSaz">
               <field name="END">FIRST</field>
                 <block type="variables_get" id="{PSVZc3Mt]U=2EX!8|y.">
                 </block>
               </value>
               <value name="FIND">
                 <shadow type="text" id=":QjI.87@s4}se7F`#0~0">
                   <field name="TEXT">tle":"</field>
                 </shadow>
               </value>
             </block>
           </value>
           <next>
             <block type="variables_set" id="ZbM/.4%L?dlr7LC6~d.~">
                 <block type="text_indexOf" id="Ky}|pA4xEq}19rIH1|wa">
                     <block type="variables_get" id="vm@=7U5{//Z@-VC2!C.r">
                     </block>
                   </value>
                   <value name="FIND">
                     <shadow type="text" id="vqIa??-dUtC3tx[?y/%5">
                       <field name="TEXT">","uni</field>
                     </shadow>
                   </value>
                 </block>
               </value>
               <next>
                 <block type="variables_set" id="hI7XEC?nQ.ybOxR=pim8">
                     <block type="convert_tostring" id="C*XQ}C]lyC=ai{CU7i5~">
                         <block type="text_getSubstring" id="H|t5#|Q,T#H/n$;$dM?[">
                           <mutation at1="true" at2="true"></mutation>
                           <field name="WHERE1">FROM_START</field>
                           <field name="WHERE2">FROM_START</field>
                           <value name="STRING">
                             <block type="variables_get" id="]`@9[9V_f5,bI3dR|Sn9">
                             </block>
                           </value>
                           <value name="AT1">
                             <block type="math_arithmetic" id="F}dh5=wXD/kE3,CQPb^n">
                               <field name="OP">ADD</field>
                               <value name="A">
                                 <shadow type="math_number" id="uYdt.$Ve!GC|WDs/^5]u">
                                   <field name="NUM">1</field>
                                 </shadow>
                                 <block type="variables_get" id="C!E[O!zbDhe=|sXd9/u9">
                                 </block>
                               </value>
                               <value name="B">
                                 <shadow type="math_number" id="lBUyeQ}#rN^8ab`lfRDD">
                                   <field name="NUM">6</field>
                                 </shadow>
                               </value>
                             </block>
                           </value>
                           <value name="AT2">
                             <block type="math_arithmetic" id="hb{d,FiAoPA=b2u8OHkt">
                               <value name="A">
                                 </shadow>
                                 <block type="variables_get" id="FcT4LNed=RL+4CY_t_i]">
                                 </block>
                               </value>
                               <value name="B">
                                 <shadow type="math_number" id="7Pgpj2}emCKVmwM#7OvV">
                                 </shadow>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </value>
                   <next>
                     <block type="variables_set" id="c7C2u6X2#UffWFDl=8Gq">
                         <block type="procedures_callcustomreturn" id="%wzpiI/a@QQAjXYmlR6j">
                           <mutation name="besserer Punktekiller">
                             <arg name="tausch"></arg>
                           </mutation>
                           <value name="ARG0">
                             <block type="variables_get" id=":MP2_-vmlCh$EopvE$?q">
                             </block>
                           </value>
                         </block>
                       </value>
                       <next>
                         <block type="variables_set" id="1#:Sf4T5R@hTztixi3xL">
                             <block type="text_indexOf" id="?bbVO}89ok~c1:54AAL*">
                                 <block type="variables_get" id="chyaG7ihvA~HWj8QLIw2">
                                 </block>
                               </value>
                               <value name="FIND">
                                 <shadow type="text" id="j.,UtM!x1ax1T7Jhyr2)">
                                   <field name="TEXT">nit":"</field>
                                 </shadow>
                               </value>
                             </block>
                           </value>
                           <next>
                             <block type="variables_set" id="FECM,;fW1}3L+?T|MBEt">
                                 <block type="text_indexOf" id="XFb#?n*^L=DiWeAyDo{{">
                                     <block type="variables_get" id="hgTcpZGeW^icqqo}$Jmq">
                                     </block>
                                   </value>
                                   <value name="FIND">
                                     <shadow type="text" id="WnR}(d{It%ar@+MOj=k-">
                                       <field name="TEXT">","sen</field>
                                     </shadow>
                                   </value>
                                 </block>
                               </value>
                               <next>
                                 <block type="controls_if" id="hR_r#gpr)H[Zc3qvcgE{">
                                   <value name="IF0">
                                     <block type="logic_compare" id="cx(1+^(%UG:}8yZtNOTd">
                                       <field name="OP">EQ</field>
                                       <value name="A">
                                         <block type="variables_get" id="}Tj#s^zKP}KBz+6mn@mR">
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="text" id="A$mL|h8e0~0O-KD7js,W">
                                           <field name="TEXT">Luftdruck</field>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <statement name="DO0">
                                     <block type="variables_set" id="CiZ0)tI@8$,{1o2lc:1r">
                                         <block type="convert_tostring" id="ECk^JHX|+Rzq07bGN8!d">
                                             <block type="text" id="(2d7^0D{z.!}q5@w.[-m">
                                               <field name="TEXT">hPa</field>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </statement>
                                   <statement name="ELSE">
                                     <block type="variables_set" id="IBdVHUvt%i|B*_fq+`r%">
                                         <block type="convert_tostring" id="`hyGfP3yD|0SmuaUpL*G">
                                             <block type="text_getSubstring" id="a~1zAziTK7_2w%lM1em-">
                                                 <block type="variables_get" id="jksgw1yp+;sLL]N{]SaO">
                                                 </block>
                                               </value>
                                               <value name="AT1">
                                                 <block type="math_arithmetic" id="g27+8^AN3#=^49*z%hQU">
                                                   <value name="A">
                                                     </shadow>
                                                     <block type="variables_get" id="Qb2-2@20]f`?a`_62ip@">
                                                     </block>
                                                   </value>
                                                   <value name="B">
                                                     <shadow type="math_number" id="HqU`kd0a+jsNd5w_V7Ac">
                                                     </shadow>
                                                   </value>
                                                 </block>
                                               </value>
                                               <value name="AT2">
                                                 <block type="math_arithmetic" id="u2jFPtyVOn]x~D!?x472">
                                                   <value name="A">
                                                     </shadow>
                                                     <block type="variables_get" id="qqt4kx/8G*[TJ;13,zq!">
                                                     </block>
                                                   </value>
                                                   <value name="B">
                                                     <shadow type="math_number" id="X9/f]q+I_Ceiz|*94f)g">
                                                     </shadow>
                                                   </value>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </statement>
                                   <next>
                                     <block type="variables_set" id="33HNy-m9hQ.@x,,06u2[">
                                         <block type="text_indexOf" id=",MM!^6Knj8Vd-=(k+K%6">
                                             <block type="variables_get" id="vN}Uc(edJ(=,SrNFZ!B(">
                                             </block>
                                           </value>
                                           <value name="FIND">
                                             <shadow type="text" id="/DT!$G}3%:Vyw;F5lUG2">
                                               <field name="TEXT">Type":"</field>
                                             </shadow>
                                           </value>
                                         </block>
                                       </value>
                                       <next>
                                         <block type="variables_set" id="*m4F$b$TO~o}r(O_%,Q;">
                                             <block type="text_indexOf" id="|pR9b1/m3/EvX3*3n%T$">
                                                 <block type="variables_get" id="2Lsy{l#to~XP]k|b#B{U">
                                                 </block>
                                               </value>
                                               <value name="FIND">
                                                 <shadow type="text" id="R3+JJk`.^}P[O9*OVI(;">
                                                   <field name="TEXT">","ico</field>
                                                 </shadow>
                                               </value>
                                             </block>
                                           </value>
                                           <next>
                                             <block type="variables_set" id="zi_JF/7ZG2nnNN6-H+yf">
                                                 <block type="convert_tostring" id="|#K/cR7hW1x[T^beQU?q">
                                                     <block type="text_getSubstring" id="t_XOX5,2igg(E]UF9.UM">
                                                         <block type="variables_get" id="Fn@vgJ8o_6bine]:,8|#">
                                                         </block>
                                                       </value>
                                                       <value name="AT1">
                                                         <block type="math_arithmetic" id="eE^Cqu7umn2}|%.[A.LY">
                                                           <value name="A">
                                                             </shadow>
                                                             <block type="variables_get" id="5HyE-}uIls!Ex*nm{C!=">
                                                             </block>
                                                           </value>
                                                           <value name="B">
                                                             <shadow type="math_number" id="RuVFkSl*`pZvj$`yAIza">
                                                               <field name="NUM">7</field>
                                                             </shadow>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <value name="AT2">
                                                         <block type="math_arithmetic" id="m%|25vuw6#q+U+vRb=Os">
                                                           <value name="A">
                                                             </shadow>
                                                             <block type="variables_get" id="T^GKJa:jKjr(VQeu$:QL">
                                                             </block>
                                                           </value>
                                                           <value name="B">
                                                             <shadow type="math_number" id="$;j=!Awvlt;)!QD#?a.%">
                                                             </shadow>
                                                           </value>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <next>
                                                 <block type="variables_set" id="P8Sbo8:R6dJJrWy;Z2_C">
                                                     <block type="procedures_callcustomreturn" id=";BiMLknZ:+(+ns_R08iL">
                                                       </mutation>
                                                       <value name="ARG0">
                                                         <block type="variables_get" id="8#i5#YK+8v{kCKBTg*wv">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <next>
                                                     <block type="variables_set" id="/0A~_.]v:Ze{tkYo]@NG">
                                                         <block type="text_indexOf" id="y~*$cEVANX`~sMxH%z,f">
                                                             <block type="variables_get" id="IR!4R-vTG)GyxSR`Lh1V">
                                                             </block>
                                                           </value>
                                                           <value name="FIND">
                                                             <shadow type="text" id="oR*pi7MJ3pLDZro)HR-0">
                                                               <field name="TEXT">lue":"</field>
                                                             </shadow>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <next>
                                                         <block type="variables_set" id="`HCUZb7mgfzPb%99ltI4">
                                                             <block type="text_indexOf" id="V;)0%M$DHIf,YgbwpbAl">
        <block type="variables_get" id="v/i0zZ,Bv~!Exy}A6(MK">
        </block>
                                                               </value>
                                                               <value name="FIND">
        <shadow type="text" id="IPJ~]J49PVN{.SKe2GF*">
        <field name="TEXT">","cre</field>
        </shadow>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <next>
                                                             <block type="controls_if" id="p(q*jC%{Cd+-X$LI+ps^">
                                                               <value name="IF0">
        <block type="logic_compare" id=",}!QK)T?En){DIEn,*a%">
        <value name="A">
        <block type="variables_get" id="}]2F`v{Oe/wYx82+k`Ze">
        </block>
        </value>
        <value name="B">
        <block type="text" id="eu+@B(T?F;Xau$8=Nu;.">
        </block>
        </value>
        </block>
                                                               </value>
        <block type="variables_set" id="w5p0?+}q}/4k2UIPIqJ|">
        <block type="math_rndfixed" id="u#Pps!@-djj#52`#53{U" inline="false">
        <field name="n">1</field>
        <value name="x">
        <shadow type="math_number" id="1yA`y-}#_r{O,eT`b;^u">
        <field name="NUM">3.1234</field>
        </shadow>
        <block type="math_arithmetic" id="p^(k%B8L:beLF.bXnCO:" inline="false">
        <field name="OP">DIVIDE</field>
        <value name="A">
        <shadow type="math_number" id="(KD!_QMa_d{ENxR]A{@m">
        </shadow>
        <block type="convert_tonumber" id="P(=Kapc@m7(gRg:kcCja">
        <block type="text_getSubstring" id="|[eAX8i5`[gMbg@cBVMB">
        <block type="variables_get" id="U|BXf5Hd.E/-$CqQboe9">
        </block>
        </value>
        <value name="AT1">
        <block type="math_arithmetic" id="e2ymvlPlxob9*8)0//gT">
        <value name="A">
        </shadow>
        <block type="variables_get" id=",4OZ;f]3QK(AKBT[#?~o">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="kbdVQS[2aKS?.fC{4uHr">
        </shadow>
        </value>
        </block>
        </value>
        <value name="AT2">
        <block type="math_arithmetic" id="yDH65DG0ySkM9)7)It*x">
        <value name="A">
        </shadow>
        <block type="variables_get" id="-]hsPn8xD8]{v:f^}oo{">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="T*vpx9*i)+hzIB?S;Kf*">
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id=",I;tb_;FA6U!PB{C}/=O">
        <field name="NUM">100</field>
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
                                                               </statement>
        <block type="variables_set" id="Kva1CD*.4l5V*Wt/If@/">
        <block type="convert_tonumber" id="IKWCBIrOgq,JKY/LZ].x">
        <block type="text_getSubstring" id="eQ#KoXEdco@OXzNKs)RE">
        <block type="variables_get" id="EE{3EO^M}jC}]p/5?X:r">
        </block>
        </value>
        <value name="AT1">
        <block type="math_arithmetic" id="!tUwB)]?kN`cPWI-y#a{">
        <value name="A">
        </shadow>
        <block type="variables_get" id="9S}$zW[ilGD{xC!_=.xn">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="E5xB:Z5Oy~L#bwV=|]J]">
        </shadow>
        </value>
        </block>
        </value>
        <value name="AT2">
        <block type="math_arithmetic" id="`xE6xPnslg~DASN$|X:w">
        <value name="A">
        </shadow>
        <block type="variables_get" id="kmS~#Oql)QWtCi8CE?Yh">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="lE|Ax*`pou)-*3[2ORDY">
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
                                                               </statement>
                                                               <next>
        <block type="comment" id=":Hmm)PF]TzV!|7Y5YjPP">
        <field name="COMMENT">Bei Bedarf den Pfad zum DP hier ändern</field>
        <next>
        <block type="variables_set" id="dF3M=]rwX9J.p`nh.:/A">
        <field name="VAR" id="Dj2Zyap_1N~eP!+x^$`B" variabletype="">Pfad</field>
        <block type="text_join" id="nxFydL,as8ZjY]Bj`V_~">
        <mutation items="6"></mutation>
        <value name="ADD0">
        <block type="text" id="fshO^7SBIJLbLFfrXfaJ">
        <field name="TEXT">Luftdaten.</field>
        </block>
        </value>
        <value name="ADD1">
        <block type="variables_get" id="}kj.bsAvPB1B3s8t-rWs">
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="RW29(Xaj-Hn)YQ7yfAZy">
        <field name="TEXT">.</field>
        </block>
        </value>
        <value name="ADD3">
        <block type="variables_get" id="(@h9,j_+Lmiys64V2$T5">
        </block>
        </value>
        <value name="ADD4">
        <block type="text" id="8$9r6vcOl,fmK/i@!{4n">
        </block>
        </value>
        <value name="ADD5">
        <block type="variables_get" id="wZYLDCY.SwgKoOzfaLcQ">
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="procedures_callcustomnoreturn" id="S5!AiF|c[:o;`T.dEJNF">
        <mutation name="DP anlegen"></mutation>
        <next>
        <block type="control_ex" id="kGx%e^r^h=4G1A%R?IR,">
        <field name="TYPE">true</field>
        <value name="OID">
        <shadow type="field_oid" id="Fk{ir@V2=n__3I1-H=(4">
        <field name="oid">Object ID</field>
        </shadow>
        <block type="variables_get" id="DOc`Oi;@12kV]HU.A-fA">
        </block>
        </value>
        <shadow type="logic_boolean" id="V~d6J^rX-y(l28S+gVCO">
        </shadow>
        <block type="variables_get" id="{4Q[prwGIZkadbq{bLD?">
        </block>
        </value>
        <value name="DELAY_MS">
        <shadow type="math_number" id="b+(_Mj~N(Bj+m^-PiLo?">
        </shadow>
        </value>
        <next>
        <block type="variables_set" id="TB3Q#LK[(+U[s1(lti3Z">
        <block type="text_getSubstring" id="7#!6#t1#K{_L_7/_=`Hf">
        <block type="variables_get" id="lT2/5k~:F?*n9ubOJqsg">
        </block>
        </value>
        <value name="AT1">
        <block type="math_arithmetic" id="7gES8GK6wo~JH}0k^DwU">
        <value name="A">
        </shadow>
        <block type="variables_get" id="8qF:R(NqG#h]D/XFC1(B">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="HQA9B#2}g_CaSNxXVV{l">
        <field name="NUM">30</field>
        </shadow>
        </value>
        </block>
        </value>
        <value name="AT2">
        <block type="math_number" id="o!n;egr4g,m+WsTiuS%x">
        <field name="NUM">100000</field>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </statement>
     </block>
     <block type="schedule" id="B6o]GUG/x9B//xGnKk2E" x="-87" y="-613">
       <field name="SCHEDULE">*/10 * * * *</field>
       <statement name="STATEMENT">
         <block type="variables_set" id="CzeTqycGqM(9}wMTb*:]">
           <field name="VAR" id="2DY4,TA7#ra1oA6Bz925" variabletype="">URL</field>
             <block type="text_join" id="8dSeeND{w@xNX^TY4@;w">
               <value name="ADD0">
                 <block type="text" id="eL@Cb!-8FhFK[Hqa#|j=">
                   <field name="TEXT">https://api.opensensemap.org/boxes/</field>
                 </block>
               </value>
               <value name="ADD1">
                 <block type="variables_get" id="!X!CI`e~-Lo8M64061bA">
                 </block>
               </value>
             </block>
           </value>
           <next>
             <block type="request" id="p@PZa|FbALxdQG[!5P=P">
               <mutation with_statement="true"></mutation>
               <field name="WITH_STATEMENT">TRUE</field>
               <field name="LOG"></field>
               <value name="URL">
                 <shadow type="text" id="R;W-TQbUXG)5Gbz=QPrM">
                   <field name="TEXT">https://api.opensensemap.org/boxes/5dd2e6674ec04e001aa48f9e</field>
                 </shadow>
                 <block type="variables_get" id="1~Xe85EKFq+2l2a,TIlB">
                 </block>
               </value>
                 <block type="variables_set" id="8!8U?^1.~Gs*4QiZGMs?">
                     <block type="variables_get" id="1HyJyj/-EN2D]=M$n.-g">
                       <field name="VAR" id="kXTaix[lp7nNNGO=Zc+@" variabletype="">result</field>
                     </block>
                   </value>
                   <next>
                     <block type="update" id="{n0Q9R:Qrus}otFtjJJ{">
                       <mutation delay_input="false"></mutation>
                       <field name="OID">0_userdata.0.Umwelt.Feinstaub_JSON</field>
                         <block type="variables_get" id="0upL:$#(xjQbDK)Zgt`{">
                         </block>
                       </value>
                       <next>
                         <block type="variables_set" id="of$45[(ktxK;VNWg?Pm@">
                             <block type="variables_get" id="uA@D|=UY6z3KUkJtZI%N">
                             </block>
                           </value>
                           <next>
                             <block type="variables_set" id="Y3Q#eQY#t@tsyPP$cASP">
                                 <block type="text_indexOf" id="R2W04B_qDzPjtc#LBDe/">
                                     <block type="variables_get" id="-bRF{~mX@pD^XMwb69)H">
                                     </block>
                                   </value>
                                   <value name="FIND">
                                     <shadow type="text" id="LH:VbO]s6~=V]x~HqKM#">
                                     </shadow>
                                   </value>
                                 </block>
                               </value>
                               <next>
                                 <block type="variables_set" id=".ln4OSn}+rIV8TL*?To5">
                                     <block type="text_getSubstring" id="MJe{?9Q1|u8lxE_epWer">
                                         <block type="variables_get" id="w:FhPP}r83^0zJ:JE.KZ">
                                         </block>
                                       </value>
                                       <value name="AT1">
                                         <block type="math_arithmetic" id="q9u?dh1$Q(RA/2HFvdt$">
                                           <value name="A">
                                             </shadow>
                                             <block type="variables_get" id="0dJX?S6|pWC8Oqg~cABf">
                                             </block>
                                           </value>
                                           <value name="B">
                                             <shadow type="math_number" id="V7w1T/(|Vphqv}$?8d/o">
                                             </shadow>
                                           </value>
                                         </block>
                                       </value>
                                       <value name="AT2">
                                         <block type="math_number" id="4TCR*ajRjd%Wl-}OKK)~">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <next>
                                     <block type="controls_repeat_ext" id="`Gx_^#EsfD@%Z3?Z5UV?">
                                       <value name="TIMES">
                                         <shadow type="math_number" id="?H;a}JW1J$2HqpPfi]AS">
                                           <field name="NUM">10</field>
                                         </shadow>
                                       </value>
                                       <statement name="DO">
                                         <block type="procedures_callnoreturn" id="BCR/,j`4mC+mgEX];feQ">
                                           <mutation name="Sensorwerte_auslesen"></mutation>
                                         </block>
                                       </statement>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </statement>
             </block>
           </next>
         </block>
       </statement>
     </block>
     <block type="procedures_defcustomnoreturn" id="wb~:H(f(:]+}syLMNgvt" x="113" y="-137">
       <mutation statements="false"></mutation>
       <field name="NAME">DP anlegen</field>
       <field name="SCRIPT">Y3JlYXRlU3RhdGUoUGZhZCwgMCwge3R5cGU6J251bWJlcicsIHVuaXQ6VW5pdDEsIHJlYWQ6dHJ1ZSwgd3JpdGU6ZmFsc2UsIHJvbGU6J3ZhbHVlJ30pOw==</field>
     </block>
     <block type="math_round" id="rx#`?~Kd@o)c3r|HUy@M" x="1901" y="-161">
       <field name="OP">ROUND</field>
       <value name="NUM">
         <shadow type="math_number" id="VCOG@@sI^m[=;uJ*-}XZ">
           <field name="NUM">3.1</field>
         </shadow>
       </value>
     </block>
     <block type="procedures_defcustomreturn" id="vR$WvEqR.bO)LEm12;J[" x="113" y="-62">
         <arg name="tausch" varid="#UHnaMpV=lSawq.B$u/_"></arg>
       </mutation>
       <field name="NAME">besserer Punktekiller</field>
       <field name="SCRIPT">cmV0dXJuIHRhdXNjaC5yZXBsYWNlKC9bXC5cc1wtXS9nLCAiXyIp</field>
     </block>
    </xml>
    Änderungen:
    • Leerzeichen Punkt und Bindestrich durch Unterstriche ersetzt
      • in Sensornamen
      • in Parameterbezeichnungen
    Dazu sollten alle bisherigen Datenpunkte gelöscht werden.
    Wie man hier sieht:
    Hat der BMP280 noch 3 Nachkommastellen.
    Das kommt daher, da ich die Rundung und Umrechnung von Pa auf hPa für den Parameter Luftfeuchte umgesetzt habe.
    Hier heisst der Parameter aber anders. Der Sensor scheint sowieso hPa zu liefern und nur wegen der Nachkommastellen das auch noch abzufangen sehe ich im Moment nicht ein.
    Umgekehrt kann das heißen, dass es noch andere Sensoren/Parameter gibt, wo noch etwas zu machen ist, oder gar die gemachte Änderung negativ zuschlägt.
    Wenn jemand das Blockly nutzen sollte (vielleicht mache ich dafür einen anderen Thread auf) und die von ihm/ihr gewählte Station(en) falsche Ergebnisse liefern, bitte ich um Info.
       <variables>
       </variables>
           </block>
         </value>
         <next>
               </block>
             </value>
             <next>
                   </block>
                 </value>
                 <next>
                       </block>
                     </value>
                     <next>
                           </block>
                         </value>
                         <next>
                               </block>
                             </value>
                             <next>
                                   </block>
                                 </value>
                                 <next>
                                       </block>
                                     </value>
                                     <next>
                                         <next>
                                               </block>
                                             </value>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </next>
           </block>
         </next>
       </block>
                   </block>
                 </value>
                 <value name="FIND">
                   </shadow>
                 </value>
               </block>
             </value>
             <next>
                       </block>
                     </value>
                     <value name="FIND">
                       </shadow>
                     </value>
                   </block>
                 </value>
                 <next>
                               </block>
                             </value>
                             <value name="AT1">
                                 <value name="A">
                                   </shadow>
                                   </block>
                                 </value>
                                 <value name="B">
                                   </shadow>
                                 </value>
                               </block>
                             </value>
                             <value name="AT2">
                                 <value name="A">
                                   </shadow>
                                   </block>
                                 </value>
                                 <value name="B">
                                   </shadow>
                                 </value>
                               </block>
                             </value>
                           </block>
                         </value>
                       </block>
                     </value>
                     <next>
                             </mutation>
                             <value name="ARG0">
                               </block>
                             </value>
                           </block>
                         </value>
                         <next>
                                   </block>
                                 </value>
                                 <value name="FIND">
                                   </shadow>
                                 </value>
                               </block>
                             </value>
                             <next>
                                       </block>
                                     </value>
                                     <value name="FIND">
                                       </shadow>
                                     </value>
                                   </block>
                                 </value>
                                 <next>
                                     <value name="IF0">
                                         <value name="A">
                                           </block>
                                         </value>
                                         <value name="B">
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                       </block>
                                     </statement>
                                                   </block>
                                                 </value>
                                                 <value name="AT1">
                                                     <value name="A">
                                                       </shadow>
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                       </shadow>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <value name="AT2">
                                                     <value name="A">
                                                       </shadow>
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                       </shadow>
                                                     </value>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                       </block>
                                     </statement>
                                     <next>
                                               </block>
                                             </value>
                                             <value name="FIND">
                                               </shadow>
                                             </value>
                                           </block>
                                         </value>
                                         <next>
                                                   </block>
                                                 </value>
                                                 <value name="FIND">
                                                   </shadow>
                                                 </value>
                                               </block>
                                             </value>
                                             <next>
                                                           </block>
                                                         </value>
                                                         <value name="AT1">
                                                             <value name="A">
                                                               </shadow>
                                                               </block>
                                                             </value>
                                                             <value name="B">
                                                               </shadow>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <value name="AT2">
                                                             <value name="A">
                                                               </shadow>
                                                               </block>
                                                             </value>
                                                             <value name="B">
                                                               </shadow>
                                                             </value>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <next>
                                                         </mutation>
                                                         <value name="ARG0">
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <next>
                                                               </block>
                                                             </value>
                                                             <value name="FIND">
                                                               </shadow>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <next>
        </block>
        </value>
        <value name="FIND">
        </shadow>
        </value>
                                                               </block>
                                                             </value>
                                                             <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <value name="x">
        </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="AT1">
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        <value name="AT2">
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        </block>
        </value>
        <value name="AT1">
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        <value name="AT2">
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <next>
        <next>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        <value name="ADD2">
        </block>
        </value>
        <value name="ADD3">
        </block>
        </value>
        <value name="ADD4">
        </block>
        </value>
        <value name="ADD5">
        </block>
        </value>
        </block>
        </value>
        <next>
        <next>
        <value name="OID">
        </shadow>
        </block>
        </value>
        </shadow>
        </block>
        </value>
        </shadow>
        </value>
        <next>
        </block>
        </value>
        <value name="AT1">
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        <value name="AT2">
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </next>
           </block>
         </statement>
       </block>
                 <value name="ADD0">
                   </block>
                 </value>
                 <value name="ADD1">
                   </block>
                 </value>
               </block>
             </value>
             <next>
                 <value name="URL">
                   </shadow>
                   </block>
                 </value>
                       </block>
                     </value>
                     <next>
                           </block>
                         </value>
                         <next>
                               </block>
                             </value>
                             <next>
                                       </block>
                                     </value>
                                     <value name="FIND">
                                       </shadow>
                                     </value>
                                   </block>
                                 </value>
                                 <next>
                                           </block>
                                         </value>
                                         <value name="AT1">
                                             <value name="A">
                                               </shadow>
                                               </block>
                                             </value>
                                             <value name="B">
                                               </shadow>
                                             </value>
                                           </block>
                                         </value>
                                         <value name="AT2">
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                     <next>
                                           </shadow>
                                         </value>
                                           </block>
                                         </statement>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </statement>
               </block>
             </next>
           </block>
         </statement>
       </block>
       </block>
         <value name="NUM">
           </shadow>
         </value>
       </block>
         </mutation>
       </block>
      </xml>
      Änderungen:
        • in Sensornamen
      Wie man hier sieht:
      K
      K
      klassisch
      #99
      @Homoran sagte in Gedanken zur Feinstaubmessung:
      Ja, das wäre gut, damit erkennbar ist, daß es jetzt auch eine Alternative zu den Luftdaten gibt. Herzlichen Dank dafür! Klasse Arbeit!
      Habe jetzt das Blockly nochmals kopiert und eine weitere Station eingetragen. Das hat funktioniert.
      Was aus meiner Sicht noch etwas unhandlich ist:
      • die Wartezeit bis die Objekte angelegt und die esten Daten da sind wird zu vielen Nachfragen führen. Kann man da nicht zwei Initdurchläufe veranstalten, damit die Daten gleich da sind?
      • Die Kanal-Id ist so etwas sperrig und wenig sprechend. Da wäre es hilfreich, wenn man den Namen frei wählen könnte oder der Name aus den Metadaten. Das scheint es ab und an zu geben.
      • K klassisch
        #100
        @klassisch
        Habe ich inzwischen gemacht - ich tippe halt nicht steno ;-)
        @all
        Fragen und Unterstützung zum Skript bitte jetzt hier:
        https://forum.iobroker.net/topic/28374/luft-messdaten-von-opensensemap-auslesen
        • K klassisch
          #101
          @klassisch
          Deine beiden Punkte hatte ich auch selber schon auf dem Schirm, weiß aber noch keine Lösung.
          Die ID ist eindeutig, ob die Namen es sind weiß ich nicht.
          Ich wollte die Namen gerne zusätzlich ins Feld Name setzen. Das geht bei der Struktur nicht.
          Ich fürchte ich hätte die Station als Channel anlegen müssen.
          Die zwei Durchläufe sind IMHO zu verschmerzen - aber auch auf der ToDo
            @klassisch
            #102
            @Homoran @klassisch Das gibt ja hier in BaWü sogar eine amtl. Publikation zu dem Thema:
            Messungen mit dem Feinstaubsensor SDS011
              #103
              @Beliar_666
              Danke - 35 Seiten wissenschaftliche (?) Publikation heruntergeladen.
              Lese ich mir mal durch
              EDIT:
              schnell die Zusammenfassung gelesen ;-)
              Ergebnisse:
               zufriedenstellende Korrelation an Tagen mit mittlerer Luftfeuchtigkeit (50 - 70 % r. F.)
              und Konzentrationen kleiner 20 µg/m³
               deutliche Abweichungen bei Schwankungen der klimatischen Bedingungen (Luft-
              feuchte, Luftdruck, Lufttemperatur)
               Sensoren aus unterschiedlichen Chargen weisen unterschiedliche Messergebnisse
              auf
               undefinierter Probengasstrom durch ungeregelten Lüfter führt zu starken Schwan-
              kungen des Messvolumens
              • K
                K
                klassisch
                schrieb am zuletzt editiert von klassisch
                #104
                Ja, Interessant wirds ab S. 17:
                • Bei hoher Feuchte messen die SDS011 zu hoch, was wir schon "wissen"
                • Bei 50% aber zu tief
                • Ganz wirr Abbildung 4.2.1 2 Tage mit ähnlicher Feuchte ca. 90% aber die Abweichungen sind stark unterschiedlich. Man vermutet Luftdruckeinfluß
                • Abb 4.3.1 Chargenabhängige Streuung
                Ab S. 22 das Fazit
                • Aus den Resultaten konnte keine Korrekturformel ermittelt werden
                • Vorschläge ur Weiterentwickling
                  • Probenahmepumpe statt des Lüfters
                  • Beiheizte Probenahmevorrichtung (das hatten wir schon auf den Bildern des anderen Berichts gesehen)
                  • Kalibriervorrichtung
                • K klassisch
                  Ab S. 22 das Fazit
                  #105
                  @klassisch sagte in Gedanken zur Feinstaubmessung:
                  Beheizte Probenahmevorrichtung (das hatten wir schon auf den Bildern des anderen Berichts gesehen)
                  Dann bastel mal ;-)
                  Die Heizung hätte ich auch vorgeschlagen, da sich damit die rH heruntersetzen lässt.
                  wenn die dann noch geregelt wird um eine stabile rH zwischen 50 und 70 % zu erhalten, bräuchte es keine Kalibrierung mehr.
                  Aber wie in der Kammer die rH messen?
                    Dann bastel mal ;-)
                    K
                    K
                    klassisch
                    #106
                    ...Heizung...
                    Doch , die war zur Erkennung / Kompensation der Langzeitdrifts gedacht. Alterung, Pollen etc.
                    Die ganze Sache ist nicht so einfach. Man braucht eine richtige Probenahme, die einen konstanten Durchfluß erzeugt. Dann kann man auch ein längeres und dünneres Rohr verwenden. Das Rohr muß lang genug sein, damit sich auch ein einigermaßen gleicmäßiges Konzentrationsprofil über den Querschnitt ausbilden kann und das Wasser verdampfen kann. Also turbulent, was aber schnell erreicht ist. Dann muß das Ding an eine beheizte Kammer angeschlossen sein, in der die Feuchtesensoren sitzen und der Partikelsensor abgeht. Das heizen kostet Strom, was man minimieren möchte. Also auch noch außerhalb oder am Saugeingang T-H- Sensoren, um den Heizbedarf zu ermitteln, sozusagen zur Vorsteuerung. einer Kaskadenregelung.
                    Und dann wird auch noch der Luftdruck erwähnt 😕 .
                    Man kann viel überlgen und bauen. Alles sehr reizvoll. Um das ordentlich zu machen braucht man aber Zeit und Zugang zu einem Referenzgerät.
                    Vor gaanz langer Zeit habe ich mal eine Trocknungsanlage mit enem PTFE Schlauch und getrockneter Luft gemacht. da konnte der Wasserdampf durch die PTF Wandung diffundieren und der interessante Rest blieb weitgehend im Strom drin.
                    Vielleicht gibt es solche beheizte Leitungen auch schon fertig für GC oder HPLC, aber halt ohne Säulenfüllung.
                    • K klassisch
                      ...Heizung...
                      #107
                      Da könnte ich mich mal schlau machen - ich arbeite genau in dem Segment
                      Semipermeable Schläuche nutzen wir als Entgaser - aber nicht anders herum
                        K
                        K
                        klassisch
                        #108
                        eben
                        Ihr setzt zur Trockung auf die (mikro)poröse Struktur der Schläuche. Damit kann das Gas raus, aber die Flüssigkeiten werden durch deren Oberflächenspannung am Durchtritt gehindert. Das wird bei wasserdichten elektronischen Geräten auch eingesetzt in den sogenannten Druck-Ausgleichs-Elementen, Beispiel
                        Man kann aber mit Schläuchen auch bei einem wasserdamphaltigen Gas den Wasserdampfgehalt reduzieren. H2O ist ein sehr kleines Molekül und diffundiert schneller durch die Wandungen als die meisten anderen Gase.
                        Damit das funktioniert muß der Schlauch auf der Trockenseite auch immer trocken sein, also mit trockener Luft umspült sein.
                        Das geht natürlich nicht, wenn das zu messende Gasmolekül noch kleiner als das H2O Molekül ist. Also bei Wasserstoff oder Helium wirds schwierig.
                        • K klassisch
                          eben
                          #109
                          eben
                          Ich werde mich nach dem bayerischen Feiertag mal mit unseren Technikern zusammensetzen, ob die entsprechende beheizte Lufttrocknungsschläuche kennen
                          • HomoranH
                            #110
                            Ich wollte noch mal zum Feinstaubstammtisch zurückkehren und politische Reden schwingen.
                            Wenn ich mir den Verlauf der Immission am Sylvesterabend/Neujahrestag ansehe (Vorsicht bei flot ist in geringer Auflösung der Tageswechsel erst um 01:00!)
                            Wissend das die Sensoren bei diesem Wetter zu hoch messen wirkt das BImSchG doch wirklich lachhaft.
                            der Tagesmittelwert PM10 darf höchstens an 35 Tagen im Jahr die 50 ppm Grenze überschreiten.
                            Selbst nach einer Feinstauborgie, der laut diverser Presseinformationen ein Großteil der Jahresfeinstaubmenge ausmacht...
                            logo (ZDF:
                            Das Umweltbundesamt hat bekannt gegeben, dass jedes Jahr ungefähr 4.500 Tonnen Feinstaub an Silvester entstehen. Im Straßenverkehr brauchen alle Autos und LKWs in Deutschland etwa zwei Monate, um so eine große Menge Feinstaub freizusetzen.
                            Spiegel (2017)
                            Diese Menge entspricht in etwa 17 Prozent der jährlich im Straßenverkehr angegebenen Feinstaubmenge
                            ... fällt bis zum nächsten morgen dieser Mittelwert üblicherweise unter die Alarmschwelle.
                            Wäre der Wert ab ca 13:00 nicht wieder angestiegen, hätte es auch dieses Jahr geklappt.
                            Tagesschau.de
                            Normalerweise geht die Feinstaubbelastung nach dem Silvesterfeuerwerk zügig zurück. In diesem Jahr halten sich die winzigen Teilchen allerdings in einigen Gebieten Deutschlands noch hartnäckig in der Luft.
                              logo (ZDF:
                              Spiegel (2017)
                              Tagesschau.de
                              #111
                              @Homoran @klassisch Mal eine ganz dumme Frage, das der DHT22 eher Müll ist, ist ja allg. bekannt, aber das die Werte zw. BME280 und DHT22 bei der Feuchtigkeit um 30% auseinanderdriften ist eher nicht normal, oder?
                              Und dann gleich noch eine Frage, wäre der Sensor BME680 nicht zuverlässiger? Zumal wenn ich das richtig verstanden habe dieser ja sogar eine Heizung in der Messkammer hat.
                              Zumindest gibt das Script auf der Seite das her:
                                // Initialisierung von  Oversampling und Filter
                                bme.setTemperatureOversampling(BME680_OS_8X);
                                bme.setHumidityOversampling(BME680_OS_2X);
                                bme.setPressureOversampling(BME680_OS_4X);
                                bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
                                bme.setGasHeater(320, 150); // 320*C for 150 ms
                              • R
                                R
                                rockflopp
                                #112
                                Hallo zusammen, wo finde ich denn Infos darüber die Feinstaubwerte bei yahka als AirQualitySensor einzubinden? Direkt den Wert in PM10Density respektive PM2_5Density zu übernehmen funktioniert leider nicht. Muss ich was konvertieren?
                                Besten Dank
                                • R rockflopp
                                  Besten Dank
                                  K
                                  K
                                  klassisch
                                  #113
                                  @rockflopp sagte in Gedanken zur Feinstaubmessung:
                                  yahka
                                  Welchen Feinstaubsensor hast Du, wie und wohin liefert er seine Werte und was ist yahka?
                                  • R
                                    R
                                    rockflopp
                                    #114
                                    Hi @klassisch: Ich importiere die Feinstaubdaten mit dem luftdaten.info Adapter und möchte diese mit dem yahka Adapter (yet another HOMEKIT adapter) als Sensorwert in meiner Apple Home App anzeigen. Da beim yahka Adapter selbst keine weiteren Infos zum Thema AirQualitySensor zu finden waren hatte ich gehofft, dass ein Nutzer dieses Threads bereits eine Integration in Homekit vorgenommen hat.
                                    • R rockflopp
                                      K
                                      K
                                      klassisch
                                      #115
                                      @rockflopp Gut, dazu kann ich nichts sagen. Ich verwende ja nicht das Luftdaten.info Programm. Wenn Du das Programm umschreiben kannst, dann gibt es den Weg die Daten über den simpleAPI Adapter ioBroker Objekte zu legen. Dann könnten sie über den "normalen Weg" von Objekten zu Homekit gelangen. Da kann ich selbst aber auch nichts sagen; Apple nicht meine Welt, das muß ich nur geschäftlich nutzen. Gibt aber sicherlich Nutzer oder Fans hier.
                                      • M
                                        M
                                        mike1976
                                        #116
                                        das mit dem SDS011 geht ja soweit.
                                        Hat schon wer den sps30 von sensirion am laufen bzw zum laufen gebracht?
                                        Mit der PC-Software bring er ja schöne werte per uart-usb kabel.
                                        • M mike1976
                                          K
                                          K
                                          klassisch
                                          #117
                                          @mike1976 Habe leider keinen. Der ist ja unter 40 EUR nicht zu bekommen. Sensirion hat aber eine eigene Arduino Lib bei github zur Verfügung gestellt. Sollte also gehen. Da es auch ein I2C Interface gibt sollte das auch mit einem 8266 machbar sein.
                                          Empfohlen bis 80% rel Feuchte.
                                          84.1k
