  4. [gelöst] Sonoff Adapter plötzlich rot
sonoff adapter
20 Beiträge 5 Kommentatoren 863 Aufrufe 3 Beobachtet
  • AxelF1977A Offline
    AxelF1977A Offline
    AxelF1977
    schrieb am zuletzt editiert von AxelF1977
    mir fiel heute auf, dass mein Sonoff Adapter rot bleibt. Das ganze wohl schon seit gestern. Das Log sagt folgendes:
    sonoff.0	2019-12-30 17:42:39.903	info	(20994) Terminated (NO_ERROR): Without reason
    sonoff.0	2019-12-30 17:42:39.902	info	(20994) terminating
    sonoff.0	2019-12-30 17:42:39.895	error	(20994) Error: listen EADDRINUSE: address already in use 0.0.0.0:1883 at Server.setupListenHandle [as _listen2] (net.js:1280:14) at listenInCluster (net.js:1328:12) at doListen (net.js:146
    sonoff.0	2019-12-30 17:42:39.895	error	(20994) uncaught exception: listen EADDRINUSE: address already in use 0.0.0.0:1883
    sonoff.0	2019-12-30 17:42:39.880	info	(20994) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.sonoff, node: v10.18.0
    sonoff.0	2019-12-30 17:42:08.045	info	(20072) Terminated (NO_ERROR): Without reason
    sonoff.0	2019-12-30 17:42:08.045	info	(20072) terminating
    sonoff.0	2019-12-30 17:42:08.026	error	(20072) Error: listen EADDRINUSE: address already in use 0.0.0.0:1883 at Server.setupListenHandle [as _listen2] (net.js:1280:14) at listenInCluster (net.js:1328:12) at doListen (net.js:146
    sonoff.0	2019-12-30 17:42:08.026	error	(20072) uncaught exception: listen EADDRINUSE: address already in use 0.0.0.0:1883
    sonoff.0	2019-12-30 17:42:08.003	info	(20072) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.sonoff, node: v10.18.0
    sonoff.0	2019-12-30 17:41:36.488	info	(19092) Terminated (NO_ERROR): Without reason
    sonoff.0	2019-12-30 17:41:36.487	info	(19092) terminating
    sonoff.0	2019-12-30 17:41:36.431	error	at process._tickCallback (internal/process/next_tick.js:63:19)
    sonoff.0	2019-12-30 17:41:36.431	error	at doListen (net.js:1461:7)
    sonoff.0	2019-12-30 17:41:36.431	error	at listenInCluster (net.js:1328:12)
    sonoff.0	2019-12-30 17:41:36.431	error	at Server.setupListenHandle [as _listen2] (net.js:1280:14)
    sonoff.0	2019-12-30 17:41:36.431	error	(19092) Error: listen EADDRINUSE: address already in use 0.0.0.0:1883
    sonoff.0	2019-12-30 17:41:36.430	error	(19092) uncaught exception: listen EADDRINUSE: address already in use 0.0.0.0:1883
    sonoff.0	2019-12-30 17:41:36.393	info	(19092) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.sonoff, node: v10.18.0
    sonoff.0	2019-12-30 17:41:04.748	info	(18113) Terminated (NO_ERROR): Without reason
    sonoff.0	2019-12-30 17:41:04.747	info	(18113) terminating
    sonoff.0	2019-12-30 17:41:04.680	error	at process._tickCallback (internal/process/next_tick.js:63:19)
    sonoff.0	2019-12-30 17:41:04.680	error	at doListen (net.js:1461:7)
    sonoff.0	2019-12-30 17:41:04.680	error	at listenInCluster (net.js:1328:12)
    sonoff.0	2019-12-30 17:41:04.680	error	at Server.setupListenHandle [as _listen2] (net.js:1280:14)
    sonoff.0	2019-12-30 17:41:04.680	error	(18113) Error: listen EADDRINUSE: address already in use 0.0.0.0:1883
    sonoff.0	2019-12-30 17:41:04.680	error	(18113) uncaught exception: listen EADDRINUSE: address already in use 0.0.0.0:1883
    sonoff.0	2019-12-30 17:41:04.661	info	(18113) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.sonoff, node: v10.18.0
    sonoff.0	2019-12-30 17:40:33.130	info	(17178) Terminated (NO_ERROR): Without reason
    sonoff.0	2019-12-30 17:40:33.130	info	(17178) terminating
    sonoff.0	2019-12-30 17:40:33.109	error	at process._tickCallback (internal/process/next_tick.js:63:19)
    sonoff.0	2019-12-30 17:40:33.109	error	at doListen (net.js:1461:7)
    Seit 16:28 Uhr hab es gestern die letzte Aktualisierung der Werte. Um den zeitopunkt rum könnte ich auf Node 10.18.0 aktualisiert haben. Evtl. ein Bug im Adapter und der läuft nicht mit der Node Version?
    Vielleicht wird ja einer von Euch draus schlau. Das der Port wohl vergeben ist, kann nicht sein, ich habe seit Tagen nicht verändert, der Adapter lief aber bis dahin.
    ASROCK Deskmini Intel I3 8100 16GB mit Proxmox VM ioBroker VM DIYHue| CCU piVCCU + FHEM auf Raspberry | Maria DB mit Grafana und Prometheus auf Tinker Board
    J crunchipC 2 Antworten Letzte Antwort
    • AxelF1977A AxelF1977
      Jan1
      @AxelF1977
      Der Port macht wohl Probleme. Hast den MQTT Adapter auch laufen?
      NPM rebuield nach dem Update gemacht?
      AxelF1977A 1 Antwort Letzte Antwort
        crunchipC Abwesend
        crunchipC Abwesend
        @AxelF1977 schon mal nach Prozesse/Ports gesehn was läuft?
        lsof -i -P | grep -i LISTEN
        • J Jan1
          @AxelF1977
          AxelF1977A Offline
          AxelF1977A Offline
          AxelF1977
          @Jan1 sagte in Sonoff Adapter plötzlich rot:
          @AxelF1977
          Hi, MQTT Adapter ist installiert, die Instanz aber deaktiviert.
          Ein npm rebuild hatte ich nicht gemacht, hatte ich noch nie. Eben probiert, folgende Meldung
          root@ioBrokerPC:~# npm rebuild
          Error: EACCES: permission denied, scandir '/root'
          TypeError: Cannot read property 'get' of undefined
              at errorMessage (/usr/lib/node_modules/npm/lib/utils/error-message.js:38:39)
              at errorHandler (/usr/lib/node_modules/npm/lib/utils/error-handler.js:201:13)
              at /usr/lib/node_modules/npm/bin/npm-cli.js:78:20
              at cb (/usr/lib/node_modules/npm/lib/npm.js:225:22)
              at /usr/lib/node_modules/npm/lib/npm.js:263:24
              at /usr/lib/node_modules/npm/lib/config/core.js:81:7
              at Array.forEach (<anonymous>)
              at /usr/lib/node_modules/npm/lib/config/core.js:80:13
              at f (/usr/lib/node_modules/npm/node_modules/once/once.js:25:25)
              at /usr/lib/node_modules/npm/lib/config/core.js:110:20
          TypeError: Cannot read property 'loaded' of undefined
              at exit (/usr/lib/node_modules/npm/lib/utils/error-handler.js:97:27)
              at process.errorHandler (/usr/lib/node_modules/npm/lib/utils/error-handler.js:216:3)
              at process.emit (events.js:198:13)
              at emitPromiseRejectionWarnings (internal/process/promises.js:140:18)
              at process._tickCallback (internal/process/next_tick.js:69:34)
            var doExit = npm.config.loaded ? npm.config.get('_exit') : true
              at process._fatalException (internal/bootstrap/node.js:497:27)
          @crunchip sagte in Sonoff Adapter plötzlich rot:
          Hatte ich noch nicht, ebenfalls soeben ausgeführt, ich finde einen laufenden Prozess der den Port belegt: mosquitto
          Allerdings habe ich keine Ahnung, was das für ein Prozess ist
          root@ioBrokerPC:~# lsof -i -P | grep -i LISTEN
          cupsd       459      root    6u  IPv6  18480      0t0  TCP localhost:631 (LISTEN        )
          cupsd       459      root    7u  IPv4  18481      0t0  TCP localhost:631 (LISTEN        )
          iobroker.   500  iobroker   19u  IPv4  20807      0t0  TCP localhost:9001 (LISTE        N)
          iobroker.   500  iobroker   20u  IPv4  21850      0t0  TCP localhost:9000 (LISTE        N)
          sshd        519      root    3u  IPv4  18548      0t0  TCP *:22 (LISTEN)
          sshd        519      root    4u  IPv6  18550      0t0  TCP *:22 (LISTEN)
          dnsmasq     529   dnsmasq    5u  IPv4  18557      0t0  TCP *:53 (LISTEN)
          dnsmasq     529   dnsmasq    7u  IPv6  18559      0t0  TCP *:53 (LISTEN)
          io.admin.   673  iobroker   25u  IPv6  24697      0t0  TCP *:8081 (LISTEN)
          mosquitto   693 mosquitto    5u  IPv4  19290      0t0  TCP *:1883 (LISTEN)
          mosquitto   693 mosquitto    6u  IPv6  19291      0t0  TCP *:1883 (LISTEN)
          apache2     957    gordon    4u  IPv6  24119      0t0  TCP *:46757 (LISTEN)
          apache2     959    gordon    4u  IPv6  24119      0t0  TCP *:46757 (LISTEN)
          apache2     961    gordon    4u  IPv6  24119      0t0  TCP *:46757 (LISTEN)
          io.harmon  1603  iobroker   27u  IPv6  27323      0t0  TCP *:61991 (LISTEN)
          io.hm-rpc  1648  iobroker   26u  IPv4  26500      0t0  TCP ioBrokerPC.fritz.box:        18701 (LISTEN)
          io.hm-rpc  1663  iobroker   26u  IPv4  25316      0t0  TCP ioBrokerPC.fritz.box:        12001 (LISTEN)
          io.hm-rpc  1678  iobroker   26u  IPv4  27424      0t0  TCP ioBrokerPC.fritz.box:        12010 (LISTEN)
          io.termin  4022  iobroker   25u  IPv6  32646      0t0  TCP *:8088 (LISTEN)
          io.web.0   4531  iobroker   25u  IPv6  34823      0t0  TCP *:8082 (LISTEN)
            @AxelF1977
            Jan1
            @AxelF1977
            Ok, einer der die Doku nicht liest und ein NPM Rebuild für überflüssig hält.
            Nachholen wie in der Doku beschrieben, Node Versionen checken und bitte hier posten.
            • J Jan1
              @AxelF1977
              AxelF1977A Offline
              AxelF1977A Offline
              AxelF1977
              @AxelF1977
              Ich habe am Anfang etliche Dokus gelesen... Aber das ist schon länger her, in den letzten 2 Jahren in denen ioBroker bei mir läuft, was das bisher nicht nötig...
              Node.js
              v10.18.0
              NPM
              6.13.4
              wie gesagt, bei einem rebuilt, bekomme ich folgende Rückmeldung in Putty
              auch nachdem der Fixer über die Installation lief
                @AxelF1977
                Node.js
                v10.18.0
                NPM
                6.13.4
                Jan1
                @AxelF1977
                Es reicht eigentlich die Doku zur IOBroker Installation. Da steht auch wie man die Node Versionen prüft und Du hast nur eine gepostet.
                  @AxelF1977
                  Node.js
                  v10.18.0
                  NPM
                  6.13.4
                  crunchipC Abwesend
                  crunchipC Abwesend
                  @AxelF1977 du bist nicht im iobroker verzeichnis
                  J AxelF1977A 2 Antworten Letzte Antwort
                    Jan1
                    @crunchip
                    Wenn er nach Doku arbeiten würde, wäre er da wo er sein soll und das Problem entweder erkannt oder schon gelöst😉
                    • Ralla66R Offline
                      Ralla66R Offline
                      Ralla66
                      Hilf ihm einfach und gut ist.
                      Vorwürfe machen das nicht besser.
                      Gerade das zeichnet dieses Forum aus, hier bekommt man Hilfe ohne Besserwisserei.
                      • Ralla66R Ralla66
                        Jan1
                        @Ralla66
                        Mach ich doch und warte immer noch drauf das er die Node Versionen postet, so wie es in der Doku steht. Oder soll ich das hier auch noch mal schreiben? Dann braucht er sie nie lesen, bisschen was muss man sicher immer selber erarbeiten.
                        Ist ein Forum hier und nicht wünsch Dir was😎
                        • Ralla66R Offline
                          Ralla66R Offline
                          Ralla66
                          @Jan1
                          Meinst diese von oben ?
                          Node.js
                          v10.18.0
                          • Ralla66R Ralla66
                            @Jan1
                            Node.js
                            v10.18.0
                            Jan1
                            @Ralla66
                            Ja aber beide und nicht nur eine, weil vermutlich war er im falschen Verzeichnis beim Update und hat nun 2 laufen. Nur eben vermutlich, wenn er nicht liest und postet.
                            RTFM und antworte auf Fragen, hilft meist😎
                              AxelF1977A Offline
                              AxelF1977A Offline
                              AxelF1977
                              Danke, hatte ich übersehen. npm rebuilt lief jetzt
                              @Ralla66 sagte in Sonoff Adapter plötzlich rot:
                              Danke, aber das lockt mich nicht aus der Reserve.
                              @Ralla66
                              Folgende node Versionen spuckt das System nun aus
                              root@ioBrokerPC:/opt/iobroker# node -v
                              v10.18.0
                              root@ioBrokerPC:/opt/iobroker# nodejs -v
                              v10.18.0
                              root@ioBrokerPC:/opt/iobroker# cd
                              root@ioBrokerPC:~# node -v
                              v10.18.0
                              root@ioBrokerPC:~# nodejs -v
                              v10.18.0
                              Übrigens kam das Update von node, welches den Sonoff Adapter außer Kraft gesetzt hat über "sudo apt-get update && sudo apt-get"
                                @Ralla66
                                v10.18.0
                                v10.18.0
                                v10.18.0
                                v10.18.0
                                Jan1
                                @AxelF1977
                                Node wird immer vom System Update angestoßen, allerdings nur innerhalb der Grundversion also wenn 8 drauf war, bleibt auch 8 drauf und da ist ein NPM Rebuild nicht nötig (steht auch so in der Doku).
                                Die Versionen sehen schon mal gut aus und es reicht wenn man die im root abfragt.
                                Hattest Du schon von Anfang an Node 10 drauf und da auch manuell nichts dran geändert?
                                Zurück zum eigentlichen Problem. Du hast den MQTT auch drauf aber deaktiviert. Lösche den mal ganz und schau obs dann läuft, da irgend wie der Port 1883 anderweitig belegt ist, oder ändere den im Sonoff Adapter und den Geräten auf einen anderen. Wenn es dann läuft, liegt schon mal hier der Hund begraben.
                                • H Offline
                                  Hhjung16
                                  Moin
                                  Wenn ich mich nicht verlesen habe, dann wurde das noch nicht beantwortet: Mosquitto ist auch ein MQTT Server , ich hab den versehentlich bei Ubuntu Server mit installiert, der hat mir dann in die Suppe gespuckt. Nach einer Deinstallation lief alles wieder und Port 1883 war wieder frei.
                                  Hoffe, ich konnte helfen :)
                                  • H Hhjung16
                                    Moin
                                    Jan1
                                    @Hhjung16
                                    Treffer, hatte ich überlesen.
                                    Der sollte runter oder wenn benötigt, muss eben entweder beim Sonoff oder beim Mosquitto der Port geändert werden, dann läuft das wieder.
                                    Da steht es ja schon was zum ersten Log Error vom Sonoff Adapter passt:
                                    belegt den selben Port!
                                    • H Offline
                                      Hhjung16
                                      Unter Ubuntu konnte ich es nur so deinstallieren wie im Link beschrieben
                                      https://www.utappia.org/2016/04/how-to-search-install-remove-snap.html?m=1
                                      Die Info hatte ich ursprünglich auch aus diesem Forum
                                      https://forum.iobroker.net/topic/22245/gelöst-ubuntu-serverseitiges-mosquitto-entfernen/5
                                      • J Jan1
                                        @AxelF1977
                                        AxelF1977A Offline
                                        AxelF1977A Offline
                                        AxelF1977
                                        @AxelF1977
                                        Guten Morgen,
                                        ich war mir tatsächlich nicht mehr sicher, ob es nun reicht die Version im root abzufragen oder nicht. Daher habe ich mal lieber beides gepostet.
                                        Ja, es war auf dem Rechner von Anfang an die 10er Version drauf. Es erfolgte ledeglich ein Erhöhung von er 10.17 auf 10.18.
                                        MQTT habe ich mal deinstalliert. Aber ich habe erstmal den Port aller Geräte und im Adapter geändert. Das hat das Problem behoben. Und genau das sind die Gründe warum ich hier im Forum nachfrage. Denn sowas traue ich mich nicht so einfach, einfach aus Angst was zerschießen zu können.
                                        @Hhjung16 sagte in Sonoff Adapter plötzlich rot:
                                        Moin
                                        Ja, das konntest Du, vielen Dank. Werde es gleich deinstallieren, auch wenn es jetzt wieder läuft.
                                        Danke für die Links, die sind sehr hilfreich.
                                        Danke an alle für die Hilfe!
                                          @AxelF1977
                                          Guten Morgen,
                                          Moin
                                          Jan1
                                          @AxelF1977
                                          Wenn den Mosquitto und MQTT nicht brauchst, kannst auch wieder auf den Standard Port im Sonoff zurück.
                                          Es können auch alle 3 parallel laufen, wenn man für jeden ein extra Port verwendet.
                                          Kannst dann noch die Überschrift im ersten Post auf gelöst setzten.
                                          82.8k
