  4. js-controller 2 jetzt für alle im Stable
js-controllerjs-controller 2
556 Beiträge 74 Kommentatoren 209.4k Aufrufe 56 Beobachtet
  • apollon77A Offline
    #389
    Und jetzt bitte mal log von dem Install direkt per npm mit der 2.1.1
      Motsche1
      #390
      also 2.1.1 install und dann noch mal in die log schauen
        Motsche1
        #391
        iobroker log nix drin also neuer eintrag
        in der npm log steht
        0 info it worked if it ends with ok
        1 verbose cli [ '/usr/bin/node',
        1 verbose cli   '/usr/bin/npm',
        1 verbose cli   'install',
        1 verbose cli   'iobroker.js-controller@2.1.1' ]
        2 info using npm@6.13.4
        3 info using node@v10.18.0
        4 verbose npm-session 64667189d8460ead
        5 silly install loadCurrentTree
        6 silly install readLocalPackageData
        7 http fetch GET 304 https://registry.npmjs.org/iobroker.js-controller 325ms (from cache)
        8 silly pacote version manifest for iobroker.js-controller@2.1.1 fetched in 347ms
        9 timing stage:loadCurrentTree Completed in 11475ms
        10 silly install loadIdealTree
        11 silly install cloneCurrentTreeToIdealTree
        12 timing stage:loadIdealTree:cloneCurrentTree Completed in 136ms
        13 silly install loadShrinkwrap
        14 timing stage:loadIdealTree:loadShrinkwrap Completed in 2548ms
        15 silly install loadAllDepsIntoIdealTree
        16 silly resolveWithNewModule iobroker.js-controller@2.1.1 checking installable status
        17 http fetch GET 304 https://registry.npmjs.org/decache 124ms (from cache)
        18 silly pacote range manifest for decache@^4.5.1 fetched in 129ms
        19 silly resolveWithNewModule decache@4.5.1 checking installable status
        20 http fetch GET 304 https://registry.npmjs.org/semver 145ms (from cache)
        21 silly pacote range manifest for semver@^6.3.0 fetched in 152ms
        22 silly resolveWithNewModule semver@6.3.0 checking installable status
        23 http fetch GET 304 https://registry.npmjs.org/respjs 288ms (from cache)
        24 http fetch GET 304 https://registry.npmjs.org/readline-sync 294ms (from cache)
        25 silly pacote range manifest for respjs@^4.2.0 fetched in 300ms
        26 silly resolveWithNewModule respjs@4.2.0 checking installable status
        27 silly pacote range manifest for readline-sync@^1.4.10 fetched in 308ms
        28 silly resolveWithNewModule readline-sync@1.4.10 checking installable status
        29 http fetch GET 304 https://registry.npmjs.org/mime 319ms (from cache)
        30 http fetch GET 304 https://registry.npmjs.org/node-forge 322ms (from cache)
        31 http fetch GET 304 https://registry.npmjs.org/chokidar 345ms (from cache)
        32 silly pacote range manifest for mime@^2.4.4 fetched in 347ms
        33 silly resolveWithNewModule mime@2.4.4 checking installable status
        34 silly pacote range manifest for node-forge@^0.9.1 fetched in 351ms
        35 silly resolveWithNewModule node-forge@0.9.1 checking installable status
        36 http fetch GET 304 https://registry.npmjs.org/event-stream 363ms (from cache)
        37 silly pacote range manifest for chokidar@^3.3.0 fetched in 373ms
        38 silly resolveWithNewModule chokidar@3.3.1 checking installable status
        39 http fetch GET 304 https://registry.npmjs.org/ioredis 372ms (from cache)
        40 http fetch GET 304 https://registry.npmjs.org/iobroker.objects-redis 386ms (from cache)
        41 http fetch GET 304 https://registry.npmjs.org/socket.io-client 223ms (from cache)
        42 http fetch GET 304 https://registry.npmjs.org/socket.io 264ms (from cache)
        43 silly pacote range manifest for event-stream@^4.0.1 fetched in 417ms
        44 silly resolveWithNewModule event-stream@4.0.1 checking installable status
        45 silly pacote range manifest for ioredis@^4.14.1 fetched in 427ms
        46 silly resolveWithNewModule ioredis@4.14.1 checking installable status
        47 silly pacote range manifest for iobroker.objects-redis@^1.2.8 fetched in 444ms
        48 silly resolveWithNewModule iobroker.objects-redis@1.2.13 checking installable status
        49 silly pacote version manifest for socket.io-client@2.3.0 fetched in 280ms
        50 silly resolveWithNewModule socket.io-client@2.3.0 checking installable status
        51 silly pacote version manifest for socket.io@2.3.0 fetched in 322ms
        52 silly resolveWithNewModule socket.io@2.3.0 checking installable status
        53 http fetch GET 304 https://registry.npmjs.org/winston 217ms (from cache)
        54 http fetch GET 304 https://registry.npmjs.org/tar 229ms (from cache)
        • M Motsche1
          Motsche1
          #392
          @Motsche1
          5377 warn enoent ENOENT: no such file or directory, open '/home/pi/package.json'
          5378 verbose enoent This is related to npm not being able to find a file.
          5379 warn pi No description
          5380 warn pi No repository field.
          5381 warn pi No README data
          5382 warn pi No license field.
          5383 warn optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
          5384 warn notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
          5385 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid OS:    darwin
          5385 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid Arch:  any
          5385 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual OS:   linux
          5385 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual Arch: arm64
          5386 verbose stack Error: iobroker.js-controller@2.1.1 install: `node iobroker.js setup first`
          5386 verbose stack Exit status 25
          5386 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
          5386 verbose stack     at EventEmitter.emit (events.js:198:13)
          5386 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
          5386 verbose stack     at ChildProcess.emit (events.js:198:13)
          5386 verbose stack     at maybeClose (internal/child_process.js:982:16)
          5386 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
          5387 verbose pkgid iobroker.js-controller@2.1.1
          5388 verbose cwd /home/pi
          5389 verbose Linux 4.4.192-rockchip64
          5390 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.js-controller@2.1.1"
          5391 verbose node v10.18.0
          5392 verbose npm  v6.13.4
          5393 error code ELIFECYCLE
          5394 error errno 25
          5395 error iobroker.js-controller@2.1.1 install: `node iobroker.js setup first`
          5395 error Exit status 25
          5396 error Failed at the iobroker.js-controller@2.1.1 install script.
          5396 error This is probably not a problem with npm. There is likely additional logging output above.
          5397 verbose exit [ 25, true ]
          • M Motsche1
            @Motsche1
            5394 error errno 25
            #393
            @Motsche1 sagte in js-controller 2 jetzt für alle im Stable:
            startest du das npm install im richtigen verzeichnis? Muss /opt/iobroker sein! Nicht /home/pi
              Motsche1
              #394
              @apollon77 said in js-controller 2 jetzt für alle im Stable:
              /opt/iobroker
              ja schon
              • M Motsche1
                /opt/iobroker
                ja schon
                #395
                @Motsche1 Das log oben sagt aber was anderes
                  Motsche1
                  #396
                  ja sorry hab es eben falsch gemacht
                  jetzt steht bei istall folgendes
                  Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
                  Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
                  Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat'
                  fs.js:114
                      throw err;
                  Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
                      at Object.mkdirSync (fs.js:757:3)
                      at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:688:58)
                      at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:235:23)
                      at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2408:5)
                      at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
                      at Module._compile (internal/modules/cjs/loader.js:778:30)
                      at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                      at Module.load (internal/modules/cjs/loader.js:653:32)
                      at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                      at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                  npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.6 (node_modules/node-bluetooth):
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.6 install: `node-gyp configure build`
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.2 (node_modules/unix-dgram):
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.2 install: `node-gyp rebuild`
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 1
                  npm ERR! iobroker.js-controller@2.1.1 install: `node iobroker.js setup first`
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the iobroker.js-controller@2.1.1 install script.
                  npm ERR!     /root/.npm/_logs/2019-12-27T17_32_40_659Z-debug.log
                    #397
                    Installation Fixer laufen gelassen wie oben schon gefragt? Permission Errors sind blöd
                    • C Offline
                      CruziX
                      schrieb am zuletzt editiert von CruziX
                      #398
                      Hallo zusammen.
                      Ich versuche es einfach mal hier.
                      Bin nun auf ein besseres System umgestiegen.
                      Nun funktionieren meine selektoren aber leider nicht mehr.
                      Habe die meisten Ids über ein Skript im Verzeichnis alias angelegt und das ging auch beim vorherigen System.
                      z.B. habe ich
                      var selectorBattery = $('[id=alias* Licht *An]');
                      selectorBattery.each(function(id, i)
                      if(getObject(id).common.role =='switch')
                      log(id);
                      im Log wird aber nichts ausgegeben.
                      Wenn ich nun die Bedingung rausnehme und nur noch $('[id=alias*]') als selektor nehme bekomme ich genau 2 state ausgegeben. Obwohl ich deutlich mehr habe.
                      Weiß jemand woran das liegt?
                      Neugestartet habe ich schon.
                        Andre R.
                        #399
                        @apollon77 Radar 2 Adapter
                        • E Offline
                          Elektroman
                          #400
                          Moin,
                          bei mir wird im Log immer error angezeigt, den Host gibt es aber nicht mehr bei mir 😕
                          Was jetzt? Über ein Hilfe würde ich mich sehr freuen!!!
                          192.168.1.102:6862 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                          • E Elektroman
                            Moin,
                            #401
                            @Elektroman wenn der Fehler kommt versucht irgend ein Prozess der auf js-Controller 1.5 läuft auf den 2.1er Controller zuzugreifen. Also irgend ein alter Prozess oder alter hängengebliebener Backup Prozess ... ggf rebooten aller relevanten hosts hilft.
                            • E Offline
                              Elektroman
                              #402
                              Danke für die schnelle Antwort!
                              Den Host kann ich nicht mehr neu starten, es gibt Ihn ja nicht mehr 😗
                              • E Offline
                                Elektroman
                                #403
                                jetzt habe ich noch etwas rumprobiert, da ist mir aufgefallen das ich den Master nicht stoppen kann
                                pi@raspberrypi:~ $ cd /
                                pi@raspberrypi:/ $ cd opt/iobroker
                                pi@raspberrypi:/opt/iobroker $ iobroker stop
                                iobroker controller daemon is not running
                                pi@raspberrypi:/opt/iobroker $ sudo iobroker stop
                                pi@raspberrypi:/opt/iobroker $ iobroker status
                                At least one iobroker host is running.
                                Objects type: file
                                States  type: file
                                • E Elektroman
                                  #404
                                  @Elektroman wenn es den nicht gibt dann kann der Fehler da nicht her kommen. Also wenn der Fehler kommt dann gibt es definitiv einen Prozess der mit nem 1.5er Controller (noch) läuft und auf den 2.0er verbinden will. Wo auch immer her. Dann boote mal die anderen iobroker hosts durch.
                                  E 1 Antwort Letzte Antwort
                                  • apollon77A apollon77
                                    Elektroman
                                    schrieb am zuletzt editiert von Elektroman
                                    #405
                                    @apollon77
                                    Vielen Dank, 🙄 ja da war noch ein Prozess im Hintergrund am laufen
                                    Das andere Problem bleibt leider bestehen. Ich kann ioBroker nicht mehr stoppen und zusätzlich ist mir aufgefallen das ich Probleme beim Updaten von Adaptern habe
                                    Das wird mir beim Updaten eines Adapters angezeigt
                                    Fertig mit Fehler: host.raspberrypi Cannot install iobroker.daswetter@2.8.1: 243
                                    $ ./iobroker upgrade daswetter
                                    Update daswetter from @2.8.0 to @2.8.1
                                    NPM version: 6.9.0npm install iobroker.daswetter@2.8.1 --loglevel error --prefix "/opt/iobroker" (System call)
                                    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller/node_modulesnpm ERR! code EACCESnpm ERR! errno -13npm ERR! syscall access
                                    npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.js-controller/node_modules'npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.js-controller/node_modules']npm ERR!   stack:npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.js-controller/node_modules\'',npm ERR!   errno: -13,npm ERR!   code: 'EACCES',npm ERR!   syscall: 'access',npm ERR!   path:npm ERR!    '/opt/iobroker/node_modules/iobroker.js-controller/node_modules' }npm ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator (though this is not recommended).
                                    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-12-29T14_26_31_011Z-debug.log
                                    ERROR: host.raspberrypi Cannot install iobroker.daswetter@2.8.1: 243
                                    • E Elektroman
                                      @apollon77
                                      #406
                                      @Elektroman was steht denn gaaaaaaaanz oben gaaaaaanz am Anfang ... und in diesem thread mindestens schon 20 mal?!
                                      Permission errors? Dann den installation fixer laufen lassen. Sollte auch dein stop Problem fixen.
                                        Elektroman
                                        #407
                                        @apollon77
                                        Sorry, ich verstehe das leider nicht. Ist "installation fixer" was zum ausführen? Ich habe mir den oberen Teil öfters angeschaut aber leider nicht draus schlau geworden. Ich habe es wirklich erst alleine versucht und mich eingelesen😳
                                        • E Elektroman
                                          @apollon77
                                          sigi234S Online
                                          sigi234S Online
                                          #408
                                          @Elektroman sagte in js-controller 2 jetzt für alle im Stable:
                                          @apollon77
                                          https://forum.iobroker.net/topic/20211/iobroker-installation-fixer-beta-verfügbar
