  4. js-controller 2 jetzt für alle im Stable
js-controllerjs-controller 2
556 Beiträge 74 Kommentatoren 209.4k Aufrufe 56 Beobachtet
    Motsche1
    #394
    @apollon77 said in js-controller 2 jetzt für alle im Stable:
    /opt/iobroker
    ja schon
    • M Motsche1
      /opt/iobroker
      ja schon
      #395
      @Motsche1 Das log oben sagt aber was anderes
        Motsche1
        #396
        ja sorry hab es eben falsch gemacht
        jetzt steht bei istall folgendes
        > node iobroker.js setup first
        Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
        Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
        Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat'
        fs.js:114
            throw err;
        Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
            at Object.mkdirSync (fs.js:757:3)
            at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:688:58)
            at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:235:23)
            at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2408:5)
            at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
            at Module._compile (internal/modules/cjs/loader.js:778:30)
            at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
            at Module.load (internal/modules/cjs/loader.js:653:32)
            at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
            at Function.Module._load (internal/modules/cjs/loader.js:585:3)
        npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.6 (node_modules/node-bluetooth):
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.6 install: `node-gyp configure build`
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.2 (node_modules/unix-dgram):
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.2 install: `node-gyp rebuild`
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! iobroker.js-controller@2.1.1 install: `node iobroker.js setup first`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the iobroker.js-controller@2.1.1 install script.
        npm ERR!     /root/.npm/_logs/2019-12-27T17_32_40_659Z-debug.log
        • apollon77A Offline
          #397
          Installation Fixer laufen gelassen wie oben schon gefragt? Permission Errors sind blöd
          • C Offline
            CruziX
            schrieb am zuletzt editiert von CruziX
            #398
            Hallo zusammen.
            Ich versuche es einfach mal hier.
            Bin nun auf ein besseres System umgestiegen.
            Nun funktionieren meine selektoren aber leider nicht mehr.
            Habe die meisten Ids über ein Skript im Verzeichnis alias angelegt und das ging auch beim vorherigen System.
            z.B. habe ich
            var selectorBattery = $('[id=alias* Licht *An]');
            selectorBattery.each(function(id, i)
            if(getObject(id).common.role =='switch')
            log(id);
            im Log wird aber nichts ausgegeben.
            Wenn ich nun die Bedingung rausnehme und nur noch $('[id=alias*]') als selektor nehme bekomme ich genau 2 state ausgegeben. Obwohl ich deutlich mehr habe.
            Weiß jemand woran das liegt?
            Neugestartet habe ich schon.
              Andre R.
              #399
              @apollon77 Radar 2 Adapter
              • E Offline
                Elektroman
                #400
                Moin,
                bei mir wird im Log immer error angezeigt, den Host gibt es aber nicht mehr bei mir 😕
                Was jetzt? Über ein Hilfe würde ich mich sehr freuen!!!
                192.168.1.102:6862 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                • E Elektroman
                  Moin,
                  #401
                  @Elektroman wenn der Fehler kommt versucht irgend ein Prozess der auf js-Controller 1.5 läuft auf den 2.1er Controller zuzugreifen. Also irgend ein alter Prozess oder alter hängengebliebener Backup Prozess ... ggf rebooten aller relevanten hosts hilft.
                  • E Offline
                    Elektroman
                    #402
                    Danke für die schnelle Antwort!
                    Den Host kann ich nicht mehr neu starten, es gibt Ihn ja nicht mehr 😗
                    • E Offline
                      Elektroman
                      #403
                      jetzt habe ich noch etwas rumprobiert, da ist mir aufgefallen das ich den Master nicht stoppen kann
                      pi@raspberrypi:~ $ cd /
                      pi@raspberrypi:/ $ cd opt/iobroker
                      pi@raspberrypi:/opt/iobroker $ iobroker stop
                      iobroker controller daemon is not running
                      pi@raspberrypi:/opt/iobroker $ sudo iobroker stop
                      pi@raspberrypi:/opt/iobroker $ iobroker status
                      At least one iobroker host is running.
                      Objects type: file
                      States  type: file
                      • E Elektroman
                        #404
                        @Elektroman wenn es den nicht gibt dann kann der Fehler da nicht her kommen. Also wenn der Fehler kommt dann gibt es definitiv einen Prozess der mit nem 1.5er Controller (noch) läuft und auf den 2.0er verbinden will. Wo auch immer her. Dann boote mal die anderen iobroker hosts durch.
                        E 1 Antwort Letzte Antwort
                        • apollon77A apollon77
                          Elektroman
                          schrieb am zuletzt editiert von Elektroman
                          #405
                          @apollon77
                          Vielen Dank, 🙄 ja da war noch ein Prozess im Hintergrund am laufen
                          Das andere Problem bleibt leider bestehen. Ich kann ioBroker nicht mehr stoppen und zusätzlich ist mir aufgefallen das ich Probleme beim Updaten von Adaptern habe
                          Das wird mir beim Updaten eines Adapters angezeigt
                          Fertig mit Fehler: host.raspberrypi Cannot install iobroker.daswetter@2.8.1: 243
                          $ ./iobroker upgrade daswetter
                          Update daswetter from @2.8.0 to @2.8.1
                          NPM version: 6.9.0npm install iobroker.daswetter@2.8.1 --loglevel error --prefix "/opt/iobroker" (System call)
                          npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller/node_modulesnpm ERR! code EACCESnpm ERR! errno -13npm ERR! syscall access
                          npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.js-controller/node_modules'npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.js-controller/node_modules']npm ERR!   stack:npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.js-controller/node_modules\'',npm ERR!   errno: -13,npm ERR!   code: 'EACCES',npm ERR!   syscall: 'access',npm ERR!   path:npm ERR!    '/opt/iobroker/node_modules/iobroker.js-controller/node_modules' }npm ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator (though this is not recommended).
                          npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-12-29T14_26_31_011Z-debug.log
                          ERROR: host.raspberrypi Cannot install iobroker.daswetter@2.8.1: 243
                          • E Elektroman
                            @apollon77
                            #406
                            @Elektroman was steht denn gaaaaaaaanz oben gaaaaaanz am Anfang ... und in diesem thread mindestens schon 20 mal?!
                            Permission errors? Dann den installation fixer laufen lassen. Sollte auch dein stop Problem fixen.
                              Elektroman
                              #407
                              @apollon77
                              Sorry, ich verstehe das leider nicht. Ist "installation fixer" was zum ausführen? Ich habe mir den oberen Teil öfters angeschaut aber leider nicht draus schlau geworden. Ich habe es wirklich erst alleine versucht und mich eingelesen😳
                              • E Elektroman
                                @apollon77
                                sigi234S Online
                                sigi234S Online
                                #408
                                @Elektroman sagte in js-controller 2 jetzt für alle im Stable:
                                @apollon77
                                https://forum.iobroker.net/topic/20211/iobroker-installation-fixer-beta-verfügbar
                                • sigi234S sigi234
                                  @apollon77
                                  Elektroman
                                  #409
                                  @sigi234 Vielen Dank!!!
                                  Jetzt bekomme ich ioBroker noch nicht zum stoppen
                                  Stopping iobroker controller daemon...
                                  iobroker controller daemon stopped.
                                  No "killall.sh" script found. Just stop.
                                  pi@raspberrypi:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash -
                                  ioBroker or some processes are still running:
                                   io.admin.1
                                   io.web.0
                                   io.yamaha.0
                                   io.cloud.2
                                   io.info.0
                                   io.javascript.2
                                   io.mihome.0
                                   io.javascript.3
                                   io.alexa2.0
                                   io.mclighting.0
                                   io.unifi.0
                                   io.musiccast.0
                                   io.harmony.0
                                   io.meross.0
                                   io.scenes.0
                                   io.backitup.1
                                   io.ble.0
                                   io.linkeddevices.0
                                   io.enigma2.0
                                   io.sia.0
                                   io.openhab.0
                                   io.tradfri.0
                                   io.mclighting.1
                                   io.milight.0
                                  Please stop them first and try again!
                                  • E Elektroman
                                     io.admin.1
                                     io.web.0
                                     io.yamaha.0
                                     io.cloud.2
                                     io.info.0
                                     io.javascript.2
                                     io.mihome.0
                                     io.javascript.3
                                     io.alexa2.0
                                     io.mclighting.0
                                     io.unifi.0
                                     io.musiccast.0
                                     io.harmony.0
                                     io.meross.0
                                     io.scenes.0
                                     io.backitup.1
                                     io.ble.0
                                     io.linkeddevices.0
                                     io.enigma2.0
                                     io.sia.0
                                     io.openhab.0
                                     io.tradfri.0
                                     io.mclighting.1
                                     io.milight.0
                                    #410
                                    @Elektroman Versuche
                                    sudo systemctl stop iobroker
                                      Elektroman
                                      #411
                                      @apollon77
                                      Vielen Danke, läuft glaube ich jetzt alles wieder
                                      • O Offline
                                        O Offline
                                        Olfrygt
                                        #412
                                        Moin moin und gutes neues jahr zusammen
                                        ich hab mir grad mal das update vorgenommen, wer lesen kann ist klar im vorteil!
                                        hab es natürlich falsch gemacht, erst den Master und jetzt spinnt alles.
                                        was kann ich tun? ich brauche die anderen Hosts zum glück nicht mehr aber jetzt läuft mir der log voll
                                        host.ioBroker-RasPi4	2020-01-01 15:54:54.785	error	Objects 192.168.178.113:33858 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                                        host.ioBroker-RasPi4	2020-01-01 15:54:54.784	error	States 192.168.178.111:45466 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                                        host.ioBroker-RasPi4	2020-01-01 15:54:54.783	error	States 192.168.178.112:39636 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                                        host.ioBroker-RasPi4	2020-01-01 15:54:54.782	error	States 192.168.178.113:48818 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                                        host.ioBroker-RasPi4	2020-01-01 15:54:49.339	error	Objects 192.168.178.112:39844 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                                        host.ioBroker-RasPi4	2020-01-01 15:54:49.338	error	Objects 192.168.178.111:48388 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                                        host.ioBroker-RasPi4	2020-01-01 15:54:49.338	error	Objects 192.168.178.113:33854 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                                        host.ioBroker-RasPi4	2020-01-01 15:54:49.338	error	States 192.168.178.112:39624 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                                        host.ioBroker-RasPi4	2020-01-01 15:54:49.337	error	States 192.168.178.111:45460 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                                        host.ioBroker-RasPi4	2020-01-01 15:54:49.337	error	States 192.168.178.113:48814 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                                        host.ioBroker-RasPi4	2020-01-01 15:54:43.873	error	Objects 192.168.178.112:39834 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                                        host.ioBroker-RasPi4	2020-01-01 15:54:43.873	error	Objects 192.168.178.111:48384 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                                        host.ioBroker-RasPi4	2020-01-01 15:54:43.872	error	Objects 192.168.178.113:33850 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                                        host.ioBroker-RasPi4	2020-01-01 15:54:43.872	error	States 192.168.178.112:39614 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                                        host.ioBroker-RasPi4	2020-01-01 15:54:43.871	error	States 192.168.178.111:45456 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                                        wie bekomme ich das weg
                                        danke euch schonmal
                                        • O Olfrygt
                                          danke euch schonmal
                                          #413
                                          @Olfrygt FAQ-im zweiten Post gelesen? Da ist exakt Deine Frage drin
                                          O 1 Antwort Letzte Antwort
