  4. Adapter: PAW - echt coole Sache
298 Beiträge 75 Kommentatoren 125.6k Aufrufe 29 Beobachtet
  • MathiasJM MathiasJ
    @ilovegym
    hier das Logfile:
    paw.0	2019-12-13 07:00:44.419	warn	(18577) Update app on device: K800
    paw.0	2019-12-13 07:00:44.418	debug	(18577) version: undefined
    paw.0	2019-12-13 07:00:44.417	debug	(18577) {"value":"4.198","device":"K800","name":"voltage","namespace":"paw.0","path":"info.battery.voltage"}
    paw.0	2019-12-13 07:00:44.416	warn	(18577) Update app on device: K800
    paw.0	2019-12-13 07:00:44.416	debug	(18577) version: undefined
    paw.0	2019-12-13 07:00:44.415	debug	(18577) {"value":"AC","device":"K800","name":"type","namespace":"paw.0","path":"info.battery.type"}
    paw.0	2019-12-13 07:00:44.414	warn	(18577) Update app on device: K800
    paw.0	2019-12-13 07:00:44.413	debug	(18577) version: undefined
    paw.0	2019-12-13 07:00:44.413	debug	(18577) {"value":"25.0","device":"K800","name":"temperature","namespace":"paw.0","path":"info.battery.temperature"}
    paw.0	2019-12-13 07:00:44.412	warn	(18577) Update app on device: K800
    paw.0	2019-12-13 07:00:44.411	debug	(18577) version: undefined
    paw.0	2019-12-13 07:00:44.410	debug	(18577) {"value":"good","device":"K800","name":"health","namespace":"paw.0","path":"info.battery.health"}
    paw.0	2019-12-13 07:00:44.409	warn	(18577) Update app on device: K800
    paw.0	2019-12-13 07:00:44.409	debug	(18577) version: undefined
    paw.0	2019-12-13 07:00:44.408	debug	(18577) {"value":"100","device":"K800","name":"level","namespace":"paw.0","path":"info.battery.level"}
    paw.0	2019-12-13 07:00:44.406	debug	(18577) path: /api/ POST: {"level":{"value":"100","device":"K800","name":"level","namespace":"paw.0","path":"info.battery.level"},"health":{"value":"good","device":"K800","name":"health","namespace":"
    paw.0	2019-12-13 07:00:44.405	debug	(18577) [object Object]
    paw.0	2019-12-13 07:00:44.402	warn	(18577) Update app on device: K800
    paw.0	2019-12-13 07:00:44.402	debug	(18577) version: undefined
    paw.0	2019-12-13 07:00:44.401	debug	(18577) {"value":"4.198","device":"K800","name":"voltage","namespace":"paw.0","path":"info.battery.voltage"}
    paw.0	2019-12-13 07:00:44.400	warn	(18577) Update app on device: K800
    paw.0	2019-12-13 07:00:44.399	debug	(18577) version: undefined
    paw.0	2019-12-13 07:00:44.399	debug	(18577) {"value":"AC","device":"K800","name":"type","namespace":"paw.0","path":"info.battery.type"}
    paw.0	2019-12-13 07:00:44.398	warn	(18577) Update app on device: K800
    paw.0	2019-12-13 07:00:44.397	debug	(18577) version: undefined
    paw.0	2019-12-13 07:00:44.396	debug	(18577) {"value":"25.0","device":"K800","name":"temperature","namespace":"paw.0","path":"info.battery.temperature"}
    paw.0	2019-12-13 07:00:44.395	warn	(18577) Update app on device: K800
    paw.0	2019-12-13 07:00:44.395	debug	(18577) version: undefined
    paw.0	2019-12-13 07:00:44.394	debug	(18577) {"value":"good","device":"K800","name":"health","namespace":"paw.0","path":"info.battery.health"}
    paw.0	2019-12-13 07:00:44.393	warn	(18577) Update app on device: K800
    paw.0	2019-12-13 07:00:44.392	debug	(18577) version: undefined
    paw.0	2019-12-13 07:00:44.392	debug	(18577) {"value":"100","device":"K800","name":"level","namespace":"paw.0","path":"info.battery.level"}
    paw.0	2019-12-13 07:00:44.390	debug	(18577) path: /api/ POST: {"level":{"value":"100","device":"K800","name":"level","namespace":"paw.0","path":"info.battery.level"},"health":{"value":"good","device":"K800","name":"health","namespace":"
    paw.0	2019-12-13 07:00:44.387	debug	(18577) [object Object]
    die App ist aber up to date. Wie gesagt, Objekte: Fehlanzeige.
    Neustart von IObroker: keine Besserung
    Installations-Fix nochmal ausgeführt: keine Besserung
    Adapter und Instanz deinstalliert und installiert: keine Besserung
    Die PAW-App auf einem Smartphone installiert: das gleiche in grün.......
    Ich weiß jetzt echt nicht mehr, was in noch tun soll.
    Gruß,
    Mathias
    W Offline
    W Offline
    Wuschl
    schrieb am zuletzt editiert von Wuschl
    #214
    @MathiasJ
    Hast du bei der Neuinstallation auf dem Smartphone den Ordner PAW gelöscht? Das Problem hatte ich auch, App deinstalliert, Ordner gelöscht, App neuinstalliet und Smartphone neugestartet. Danach funktionierte es bei mir wieder. Allerdings dauerte es etwas bis alle Objekte angezeigt wurden...
    MathiasJM 1 Antwort Letzte Antwort
    • W Wuschl
      @MathiasJ
      MathiasJM Offline
      MathiasJM Offline
      MathiasJ
      schrieb am zuletzt editiert von MathiasJ
      #215
      @Wuschl
      das kann ich noch versuchen.....
      danke, aber vor heute Abend wird's dann wohl nichts.
      Edit
      habe es so gemacht, läuft nicht 😠
      habe nun auch den Adapter deinstalliert, den Ordner
      /opt/iobroker/node-modules/iobroker.paw
      gelöscht,
      PAW neu installiert.
      geht auch nicht.
      PAW deinstalliert...... was will ich mit einem Adapter, der nicht läuft? 😠
      das mache ich eigentlich immer so..... Programme, die nicht laufen werden deinstalliert, Speicherplatz frei machen, nenne ich das.......
      IObroker auf dem NUC als VM.
      W 1 Antwort Letzte Antwort
        @Wuschl
        Edit
        gelöscht,
        geht auch nicht.
        W Offline
        W Offline
        Wuschl
        #216
        @MathiasJ
        Das ist schade. bei mir läuft er ohne Probleme, ich kann eben nur leider keine Befehle über iobroker senden....
        • W Wuschl
          @MathiasJ
          MathiasJM Offline
          MathiasJM Offline
          MathiasJ
          #217
          @Wuschl
          Das eigenartige dran, er lief ja auch bisher ohne Probleme.
          erst seit dem Update des JS-Contollers geht der nicht mehr.
          ...und jetzt werde ich deswegen keine Zeit mehr damit verschwenden.
          Dann muß ich mir etwas anderes einfallen lassen, um das Display des
          Tablets einzuschalten, wenn man da reinglotzen will :)
            @Wuschl
            W Offline
            W Offline
            Wuschl
            #218
            @MathiasJ
            Bin ganz bei dir, mein Handy funktioniert jetzt auch nicht mehr. Aber dafür habe ich mein Tablet zum reden gebracht....Bild1.jpg
            • MathiasJM Offline
              MathiasJM Offline
              MathiasJ
              #219
              Es soll ja in meinem Fall nicht reden, sondern das Display einschalten, wenn jemand vorbei geht.
              Der Akku soll mit einem Sonoff S20 geladen werden, wenn eine Kapazität unterschritten wird, bzw nicht mehr laden bei einer Überschreitung....
                W Offline
                W Offline
                Wuschl
                #220
                @MathiasJ
                • MathiasJM Offline
                  MathiasJM Offline
                  MathiasJ
                  #221
                  aha, interessant....
                  gibt's da keine Objekte mehr?
                  ich habe das bisher so gemacht:
                  und dann habe ich nur das:
                  da fehlt doch noch was.....
                  Gruß,
                  Mathias
                    Gruß,
                    Mathias
                    W Offline
                    W Offline
                    Wuschl
                    #222
                    @MathiasJ
                    tausche einfach das "steuere" mit sendto aus. genauso wie auf meinem Bild... Nur deine IP musst halt anpassen.
                    • W Wuschl
                      @MathiasJ
                      MathiasJM Offline
                      MathiasJM Offline
                      MathiasJ
                      #223
                      @Wuschl
                      habe ich doch gemacht.
                      bei mir fehlt trotzdem was (siehe 2. Bild)
                        @Wuschl
                        #224
                        @MathiasJ sagte in Adapter: PAW - echt coole Sache:
                        @Wuschl
                        Was fehlt denn da? Der 2. Parameter?
                        Dann klicke doch mal oben links auf den `blauen Einstellungsring´
                          @Wuschl
                          MathiasJM Offline
                          MathiasJM Offline
                          MathiasJ
                          #225
                          @Yetiberg
                          Ups, vergessen.......
                          Geht trotzdem nicht :(
                            @Yetiberg
                            W Offline
                            W Offline
                            Wuschl
                            #226
                            @MathiasJ
                            Dann musst du in der PAW2 App wohl noch die Berechtigung erteilen, Display On/Off
                            • MathiasJM Offline
                              MathiasJM Offline
                              MathiasJ
                              #227
                              mache ich, wenn es dann soweit ist.
                              Ich habe noch eine wichtigere Baustelle:
                              backitup macht Backups, die riesige 0kb groß sind. egal ob CCU oder IObroker.
                              Ich muß erst mal das klären, bevor es hier weiter geht :(
                              • -cs-- Offline
                                -cs-- Offline
                                -cs-
                                #228
                                gibt es eigentlich schon eine Lösung wegen der Update-Warnungen, das man die App Aktualisieren soll?
                                Bei mir kommen minütlich diese Meldungen:
                                (App am Table schon mehrfach gelöscht, inkl. dazugehörige Ordner)
                                • -cs-- -cs-
                                  MathiasJM Offline
                                  MathiasJM Offline
                                  MathiasJ
                                  #229
                                  @csr sagte in Adapter: PAW - echt coole Sache:
                                  Mir ist nichts bekannt.
                                  Nun ignoriere ich diese Warnungen einfach.
                                  Mathias
                                  • O Offline
                                    O Offline
                                    oxident
                                    #230
                                    Hoffe, ich darf eine kurze Zwischenfrage stellen: Kann es sein, dass der Adapter nur für's lokale Netz gedacht ist?
                                    Will sagen, von unterwegs (mit Portfreigabe im Router und DynDns) kann ich ihn wegen ständig wechselnder IP des Handys ja gar nicht nutzen, oder?
                                    • MathiasJM Offline
                                      MathiasJM Offline
                                      MathiasJ
                                      #231
                                      @oxident
                                      Was willst du denn mit dem Adapter unterwegs machen?
                                      Der Adapter ist nur dazu da, um Dein Tablet zu steuern.
                                      Der Bildschirm geht schon mal an, wenn Bewegung im Raum erkannt wird.
                                      Nur wie ich den Sonoff (mangels der Objekte) ein- und ausschalten kann, weiß ich noch nicht.
                                      Was bei mir auch eigenartig ist, von Zeit zu Zeit verliert mein Tablet mit dem Adapter die Verbindung. Jetzt wird das Tablet automatisch aus- und eingeschaltet.
                                      O 1 Antwort Letzte Antwort
                                      • D3ltoroxpD Offline
                                        D3ltoroxpD Offline
                                        D3ltoroxp
                                        #232
                                        Hallo zusammen.
                                        ich würde gerne mal den Adapter ausprobieren. Da das Fire HD 10 einfach keinen Ordner Commands in ioBroker anzeigt, versuche ich mal über den PAW Sprachausgabe aufs Tablet. Gibt es irgendwo eine Anleitung was zu tun ist ? Was kommt in den Adapter rein ? Server IP ist die auf der ioBroker läuft ja ?
                                        Unten IP von meinem Tablet und dann auf suchen ? Passiert nichts ..
                                        Auf dem Tablet Paw II App installiert und das Wizard durchlaufen. So dann auf Connect. Was muss ich nun weiter tun ?
                                        Wenn mir da einer helfen könnte, wäre klasse.
                                        ldittmarL 1 Antwort Letzte Antwort
                                        • D3ltoroxpD D3ltoroxp
                                          Hallo zusammen.
                                          ldittmarL Online
                                          ldittmarL Online
                                          ldittmar
                                          schrieb am zuletzt editiert von ldittmar
                                          #233
                                          @D3ltoroxp Also... App auf dem Tablet, Wizard durchlaufen und dann auf Connect gehen.... Auf dem ioBroker setzt du die IP deines Tabs ein und klickst auf suchen. Dein Tab sollte dann unten erscheinen. Es wird dann auch im ioBroker ein Datenpunkt mit dem Tab Daten angelegt. Was genau geht bei dir nicht?
                                          Schau mal unter http://IPvomTabletOderHandy:8080/control.html ob die App läuft.
