Apple Homekit Siri
Für die Auswahl wäre vllt das wie es das highcharts-Adon macht auch eine coole Idee: "Einfach" pro Homekit-Adapter in der UI bei den Channeln eine weitere Spalte einblenden mit ner Checkbox wo man wählen kann ob es dabei sein soll oder nicht … das wäre dann die "Luxus"-Variante der Enum :)
ich hab mal versucht den Adapter zu installieren. Klappt aber nicht. Hab folgendes gemacht:
npm install https://github.com/husky-koglhof/ioBroker.homekit/tarball/master --productionDanach kamen folgende Fehlermeldungen im Terminal:
npm http GET https://github.com/husky-koglhof/ioBroker.homekit/tarball/master npm http 200 https://github.com/husky-koglhof/ioBroker.homekit/tarball/master > ioBroker.homekit@0.0.3 preinstall /opt/iobroker/node_modules/ioBroker.homekit > sudo apt-get install git-core libnss-mdns libavahi-compat-libdnssd-dev -y Reading package lists... Done Building dependency tree Reading state information... Done libavahi-compat-libdnssd-dev is already the newest version. git-core is already the newest version. libnss-mdns is already the newest version. 0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded. 1 not fully installed or removed. After this operation, 0 B of additional disk space will be used. Setting up linux-image-sunxi (4.3) ... ln: failed to create symbolic link `/boot/zImage': Operation not permitted cp: writing `/boot/zImage': No space left on device cp: failed to extend `/boot/zImage': No space left on device dpkg: error processing linux-image-sunxi (--configure): subprocess installed post-installation script returned error exit status 1 Errors were encountered while processing: linux-image-sunxi E: Sub-process /usr/bin/dpkg returned an error code (1) npm ERR! ioBroker.homekit@0.0.3 preinstall: `sudo apt-get install git-core libnss-mdns libavahi-compat-libdnssd-dev -y` npm ERR! Exit status 100 npm ERR! npm ERR! Failed at the ioBroker.homekit@0.0.3 preinstall script. npm ERR! This is most likely a problem with the ioBroker.homekit package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! sudo apt-get install git-core libnss-mdns libavahi-compat-libdnssd-dev -y npm ERR! You can get their info via: npm ERR! npm owner ls ioBroker.homekit npm ERR! There is likely additional logging output above. npm ERR! System Linux 3.4.108-sunxi npm ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "https://github.com/husky-koglhof/ioBroker.homekit/tarball/master" "--production" npm ERR! cwd /opt/iobroker npm ERR! node -v v0.10.22 npm ERR! npm -v 1.3.14 npm ERR! code ELIFECYCLE npm ERR! npm ERR! Additional logging details can be found in: npm ERR! /opt/iobroker/npm-debug.log npm ERR! not ok code 0Hab ich was falsch gemacht?
Viele Grüße
Trident
hab den Fehler selbst entdeckt… Muss natürlich vorher die aktuelle Version von Github laden.
Installiert ist nun eine Instanz. Beim Start bekomme ich im iobroker-log folgende Meldungen:
host-cubietruck 2015-09-28 20:36:16 error instance system.adapter.homekit.0 terminated with code 6 (uncaught exception) SyntaxError: 2015-09-28 20:36:16 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20) SyntaxError: 2015-09-28 20:36:16 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) SyntaxError: 2015-09-28 20:36:16 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12) SyntaxError: 2015-09-28 20:36:16 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6) SyntaxError: 2015-09-28 20:36:16 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:151:27) SyntaxError: 2015-09-28 20:36:16 error at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2375:60 SyntaxError: 2015-09-28 20:36:16 error at /opt/iobroker/node_modules/iobroker.homekit/main.js:43:61 SyntaxError: 2015-09-28 20:36:16 error at /opt/iobroker/node_modules/iobroker.homekit/main.js:20:13 SyntaxError: 2015-09-28 20:36:16 error at main (/opt/iobroker/node_modules/iobroker.homekit/main.js:201:33) SyntaxError: 2015-09-28 20:36:16 error at Object.parse (native) SyntaxError: 2015-09-28 20:36:16 error Unexpected token u uncaught 2015-09-28 20:36:16 error exception: Unexpected token u homekit-0 2015-09-28 20:36:16 info Parent Object Adress: hm-rpc.0.LEQ0277589 homekit-0 2015-09-28 20:36:16 info HAP-NodeJS starting... homekit-0 2015-09-28 20:36:16 info received all states homekit-0 2015-09-28 20:36:15 info received all objects homekit-0 2015-09-28 20:36:13 info requesting all objects homekit-0 2015-09-28 20:36:13 info requesting all states homekit-0 2015-09-28 20:36:13 info starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.homekit homekit-0 2015-09-28 20:36:13 debug statesDB connected homekit-0 2015-09-28 20:36:13 debug objectDB connected host-cubietruck 2015-09-28 20:36:10 info instance system.adapter.homekit.0 started with pid 7122Nur als Info für die Entwickler…. Vielleicht liegt es auch an mir?
Viele Grüße
Trident
Bei mir stürzt der Adapter immer wieder ab:
> warn host.iobroker instance system.adapter.homekit.0 terminated due to SIGSEGV`Schliesse mich dem an.
Möchte an der Stelle aber auch meine Begeisterung für den Adapter ausdrücken! Teste gerne mit ;-)
konnte die Fehler beheben und der Adapter läuft nun stabil. Ich hatte nicht unterstütze Geräte in mein enum aufgenommen. Es klappt bei mir derzeit NUR mit der Ist-Temperatur der neuen Heizungsthermostaten. Allerdings erkennt die App auf meinem iPhone den Adapter nicht.. Gibt es da einen Trick?
Viele Grüße
Fabian
ich schaffe es gar nicht, den Adapter zu installieren.
Neueste Version von Github geladen, zip-Datei in iobroker/node_modules/iobroker.homekit entpackt.
Adapter erscheint in ioBroker.admin Oberfläche (Version 0.0.3). Beim Installieren einer Instanz dieser Fehler:
$ ./iobroker add homekit
host.MacMini-Ethernet.fritz.box install adapter homekitnpm install --production --prefix "/Users/pix/Documents/iobroker/node_modules/iobroker.homekit" (System call)
! sudo: no tty present and no askpass program specified
! npm
ERR! ioBroker.homekit@0.0.3 preinstall:sudo apt-get install git-core libnss-mdns libavahi-compat-libdnssd-dev -ynpm ERR!
Exit status 1
npm ERR!
npm ERR! Failed at the ioBroker.homekit@0.0.3 preinstall script.npm
ERR! This is most likely a problem with the ioBroker.homekit package,npm ERR! not with npm itself.
npm
ERR! npm owner ls ioBroker.homekitnpm ERR!
There is likely additional logging output above.npm ERR!
System Darwin 14.5.0npm ERR! command "node" "/usr/local/bin/npm" "install" "--production" "--prefix" "/Users/pix/Documents/iobroker/node_modules/iobroker.homekit"
npm ERR! cwd /Users/pix/Documents
npm ERR!
node -v v0.10.33npm
ERR! npm -v 1.4.28
npm ERR!
npm ERR! /Users/pix/Documents/npm-debug.log
! Cannot install iobroker.homekit: 1
ERROR: process exited with code 25Ist OS X Terminal, deshalb kein apt. Homebrew ging auch nicht. Hat jemand eine Idee? Gruß, Pix __EDIT (10.12.2015): Bei einem weiteren Versuch, eine Instanz zu installieren, lief alles sauber durch. Kann es nicht erklären, aber freue mich__ :?: :D -
hab jetzt auf dem Cubie parallel die homebridge laufen. Klappt auf Anhieb mit allen Devices. Echt sehr cool. Blöd ist nur die fehlende Integration in IO-Broker. Die Räume und Gerätenamen sind nicht synchron :). Ich denke es lohnt sich auf jeden Fall hier mal reinzuschauen! Vielleicht wird es eher ein "homebridge" Adapter für ioBroker?
> [https://github.com/thkl/homebridge](https://github.com/thkl/homebridge)Der homekit-adapter wird leider nicht von der App auf dem iPhone erkannt….
Viele Grüße
Trident
könnte mal einer das mit der Einrichtung der enums etwas erläutern.
Wenn es nicht zu viel Aufwand ist, eventuell mit ein paar Bilder und 1-2 Beispielen.
Ich hab den Adapter soweit problemlos installieren können. Jetzt scheitere ich aber an der enum-Konfiguration.
Danke & Gruss
Silvio
hallo, ich würde mich gerne beteiligen.
habe den adapter auch per console installiert aber bekomme bei den Adaptern einen Fehler?
Mit freundlichen Grüßen
909_bildschirmfoto_2015-12-09_um_22.05.37.png -
Das Installationsproblem hatte ich auch. In dem Verzeichnis der Adapter heißt das Verzeichnis "ioBroker.homekit". Habe mit "mv ioBroker.homekit/ iobroker.homekit" das Verzeichnis umbenannt. Jetzt kann man Instanzen von Adaptern installieren.
Instanz installiert und einen Homematic Switch in den Aufzählungen eingefügt.
Beim Start der Instanz erhalte ich diesen Fehler:
2015-12-09 23:30:20.894 - info: host.MacMini-Ethernet.fritz.box object change system.adapter.homekit.0
2015-12-09 23:30:20.902 - info: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 started with pid 14256
2015-12-09 23:30:21.876 - error: uncaught exception: Could not locate the bindings file. Tried:
→ /Users/pix/Documents/iobroker/node_modules/curve25519/build/curve.node
→ /Users/pix/Documents/iobroker/node_modules/curve25519/build/Debug/curve.node
→ /Users/pix/Documents/iobroker/node_modules/curve25519/build/Release/curve.node
→ /Users/pix/Documents/iobroker/node_modules/curve25519/out/Debug/curve.node
→ /Users/pix/Documents/iobroker/node_modules/curve25519/Debug/curve.node
→ /Users/pix/Documents/iobroker/node_modules/curve25519/out/Release/curve.node
→ /Users/pix/Documents/iobroker/node_modules/curve25519/Release/curve.node
→ /Users/pix/Documents/iobroker/node_modules/curve25519/build/default/curve.node
→ /Users/pix/Documents/iobroker/node_modules/curve25519/compiled/5.0.0/darwin/x64/curve.node
2015-12-09 23:30:21.882 - error: Error: Could not locate the bindings file. Tried:
at bindings (/Users/pix/Documents/iobroker/node_modules/bindings/bindings.js:88:9)
at Object. <anonymous>(/Users/pix/Documents/iobroker/node_modules/curve25519/index.js:1:96)
at Module._compile (module.js:425:26)
at Object.Module._extensions..js (module.js:432:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:311:12)
at Module.require (module.js:366:17)
at require (module.js:385:17)
at Object. <anonymous>(/Users/pix/Documents/iobroker/node_modules/HAP-NodeJS/lib/util/encryption.js:3:18)
2015-12-09 23:30:21.929 - debug: homekit.0 objectDB connected
2015-12-09 23:30:21.934 - debug: homekit.0 statesDB connected
2015-12-09 23:30:22.064 - info: homekit.0 starting. Version 0.0.3 in /Users/pix/Documents/iobroker/node_modules/iobroker.homekit
2015-12-09 23:30:22.067 - info: homekit.0 requesting all states
2015-12-09 23:30:22.068 - info: homekit.0 requesting all objects
2015-12-09 23:30:22.914 - error: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)</anonymous></anonymous>error: Error: Could not locate the bindings file Was kann das sein? Gruß, Pix -
Weil ich's grad gesehen habe, kannst du bitte die letzte Version installieren?
Ist mittlerweile 0.0.5 auf GitHub. `
Hallo,hab das Update versucht, ging leider nicht durch:
MacMini-Ethernet:iobroker pix$ npm install https://github.com/husky-koglhof/ioBroker.homekit/tarball/master --production
npm WARN addRemoteGit git://github.com/KhaosT/node-srp.git resetting remote /Users/pix/.npm/_git-remotes/git-github-com-KhaosT-node-srp-git-2835e45f024c21e40cb2d65bd72f2b3c because of error: git: error: couldn't open cache file '/var/folders/qh/p1_kkf_x1fzdqzjpj7t18xqr0000gq/T/xcrun_db' (errno=File exists)
npm WARN addRemoteGit git://github.com/KhaosT/node-curve25519.git resetting remote /Users/pix/.npm/_git-remotes/git-github-com-KhaosT-node-curve25519-git-33ca66a69c843d2ebb70497fca566be0 because of error: git: error: couldn't open cache file '/var/folders/qh/p1_kkf_x1fzdqzjpj7t18xqr0000gq/T/xcrun_db' (errno=File exists)
npm WARN addRemoteGit git://github.com/KhaosT/ed25519.git resetting remote /Users/pix/.npm/_git-remotes/git-github-com-KhaosT-ed25519-git-cef11b6e9b2bb55b3b8f0a59f5a2d6bf because of error: git: error: couldn't open cache file '/var/folders/qh/p1_kkf_x1fzdqzjpj7t18xqr0000gq/T/xcrun_db' (errno=File exists)
! > ioBroker.homekit@0.0.5 preinstall /Users/pix/Documents/iobroker/node_modules/.staging/ioBroker.homekit-2481c4b93d734e6c4c816539f7b84a58
! Password:
Sorry, try again.
Password:
sudo: apt-get: command not found- nan@2.1.0 node_modules/bignum/node_modules/nan
- nan@1.9.0 node_modules/curve25519/node_modules/nan
- nan@2.1.0 node_modules/ed25519/node_modules/nan
- ansi-regex@2.0.0 node_modules/iobroker.homekit/node_modules/ansi-regex
- ansi-styles@2.1.0 node_modules/iobroker.homekit/node_modules/ansi-styles
- camelcase@2.0.1 node_modules/iobroker.homekit/node_modules/camelcase
- decamelize@1.1.1 node_modules/iobroker.homekit/node_modules/decamelize
- invert-kv@1.0.0 node_modules/iobroker.homekit/node_modules/invert-kv
- lcid@1.0.0 node_modules/iobroker.homekit/node_modules/lcid
- number-is-nan@1.0.0 node_modules/iobroker.homekit/node_modules/number-is-nan
- is-fullwidth-code-point@1.0.0 node_modules/iobroker.homekit/node_modules/is-fullwidth-code-point
- code-point-at@1.0.0 node_modules/iobroker.homekit/node_modules/code-point-at
- os-locale@1.4.0 node_modules/iobroker.homekit/node_modules/os-locale
- strip-ansi@3.0.0 node_modules/iobroker.homekit/node_modules/strip-ansi
- string-width@1.0.1 node_modules/iobroker.homekit/node_modules/string-width
- window-size@0.1.4 node_modules/iobroker.homekit/node_modules/window-size
- wrap-ansi@1.0.0 node_modules/iobroker.homekit/node_modules/wrap-ansi
- cliui@3.1.0 node_modules/iobroker.homekit/node_modules/cliui
- y18n@3.2.0 node_modules/iobroker.homekit/node_modules/y18n
- yalm@2.0.0 node_modules/iobroker.homekit/node_modules/yalm
- yargs@3.31.0 node_modules/iobroker.homekit/node_modules/yargs
- nan@2.0.9 node_modules/mdns/node_modules/nan
- HAP-NodeJS@0.0.1 node_modules/HAP-NodeJS
├── mdns@2.2.11
└── srp@0.2.0 (git://github.com/KhaosT/node-srp.git#7feff53254897a0b1b9f0667ad17a8beb78acbb9)
! npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/package.json'
npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/ftp-response-parser/package.json'
npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/jsftp/package.json'
npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/mqtt-packet/package.json'
npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/node_modules/package.json'
npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/socket.io-parser/package.json'
npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/through2/package.json'
npm WARN EPACKAGEJSON iobroker No description
npm WARN EPACKAGEJSON iobroker No repository field.
npm WARN EPACKAGEJSON iobroker No README data
npm WARN EPACKAGEJSON iobroker No license field.
npm ERR! Darwin 15.0.0
npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "https://github.com/husky-koglhof/ioBroker.homekit/tarball/master" "--production"
npm ERR! node v5.0.0
npm ERR! npm v3.4.0
! npm ERR! ioBroker.homekit@0.0.5 preinstall:sudo apt-get install git-core libnss-mdns libavahi-compat-libdnssd-dev -y
npm ERR!
npm ERR! Failed at the ioBroker.homekit@0.0.5 preinstall script 'sudo apt-get install git-core libnss-mdns libavahi-compat-libdnssd-dev -y'.
npm ERR! Make sure you have the latest version of node.js and npm installed.
npm ERR! If you do, this is most likely a problem with the ioBroker.homekit package,
! npm ERR! Please include the following file with any support request:
npm ERR! /Users/pix/Documents/iobroker/npm-debug.lognpm install [https://github.com/husky-koglhof/ioBrok … all/master](https://github.com/husky-koglhof/ioBroker.homekit/tarball/master) --production Das updaten in Admin wird noch nicht angeboten. Gruß, Pix -
Guten Morgen!
Hab eine neue Version in GitHub hochgeladen, auf Mac und Raspian liess es sich installieren.
Das sind die Änderungen:
Added new Devices
Temperature can now be a negative Value (Needed for Outdoor Temperature)
Package Name changed to lowercase
Removed Dependency for installation of Packages
Bitte mal testen ob die Installation nun korrekt funktioniert.
Es sind im Moment nicht viele Geräte aktiviert, muss erst mal schauen, das diese korrekt funktionieren.
die Installation lief jetzt fast glatt durch, danke:
MacMini-Ethernet:iobroker pix$ npm install https://github.com/husky-koglhof/ioBroker.homekit/tarball/master --production /Users/pix/Documents/iobroker └── iobroker.homekit@0.0.6 ! npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/package.json' npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/ftp-response-parser/package.json' npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/jsftp/package.json' npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/mqtt-packet/package.json' npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/node_modules/package.json' npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/socket.io-parser/package.json' npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/through2/package.json' npm WARN EPACKAGEJSON iobroker No description npm WARN EPACKAGEJSON iobroker No repository field. npm WARN EPACKAGEJSON iobroker No README data npm WARN EPACKAGEJSON iobroker No license field. MacMini-Ethernet:iobroker pix$ !allerdings habe ich bei Aktivierung der Instanz wieder diesen Fehler:
2015-12-12 15:01:07.886 - info: host.MacMini-Ethernet.fritz.box object change system.adapter.homekit.0
2015-12-12 15:01:07.896 - info: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 started with pid 16645
2015-12-12 15:01:08.712 - error: uncaught exception: Could not locate the bindings file. Tried:
2015-12-12 15:01:08.717 - error: Error: Could not locate the bindings file. Tried:
at Object. <anonymous>(/Users/pix/Documents/iobroker/node_modules/hap-nodejs/lib/util/encryption.js:3:18)
2015-12-12 15:01:08.762 - debug: homekit.0 objectDB connected
2015-12-12 15:01:08.766 - debug: homekit.0 statesDB connected
2015-12-12 15:01:08.911 - info: homekit.0 starting. Version 0.0.6 in /Users/pix/Documents/iobroker/node_modules/iobroker.homekit
2015-12-12 15:01:08.914 - info: homekit.0 requesting all states
2015-12-12 15:01:08.914 - info: homekit.0 requesting all objects
2015-12-12 15:01:09.768 - error: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)</anonymous></anonymous>Hast du noch einen Tipp? Pix -
Hallo, so sieht es bei mir aus:
Christians-Mac-mini:tmp christian$ npm install https://github.com/husky-koglhof/ioBroker.homekit/tarball/master --production > ed25519@0.0.3 install /private/tmp/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/ed25519 > node-gyp rebuild CC(target) Release/obj.target/ed25519/src/ed25519/keypair.o CC(target) Release/obj.target/ed25519/src/ed25519/sign.o CC(target) Release/obj.target/ed25519/src/ed25519/open.o CC(target) Release/obj.target/ed25519/src/ed25519/crypto_verify_32.o CC(target) Release/obj.target/ed25519/src/ed25519/ge_double_scalarmult.o CC(target) Release/obj.target/ed25519/src/ed25519/ge_frombytes.o CC(target) Release/obj.target/ed25519/src/ed25519/ge_scalarmult_base.o CC(target) Release/obj.target/ed25519/src/ed25519/ge_precomp_0.o CC(target) Release/obj.target/ed25519/src/ed25519/ge_p2_0.o CC(target) Release/obj.target/ed25519/src/ed25519/ge_p2_dbl.o CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_0.o CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_dbl.o CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_to_p2.o CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_to_cached.o CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_tobytes.o CC(target) Release/obj.target/ed25519/src/ed25519/ge_madd.o CC(target) Release/obj.target/ed25519/src/ed25519/ge_add.o CC(target) Release/obj.target/ed25519/src/ed25519/ge_msub.o CC(target) Release/obj.target/ed25519/src/ed25519/ge_sub.o CC(target) Release/obj.target/ed25519/src/ed25519/ge_p1p1_to_p3.o CC(target) Release/obj.target/ed25519/src/ed25519/ge_p1p1_to_p2.o CC(target) Release/obj.target/ed25519/src/ed25519/ge_tobytes.o CC(target) Release/obj.target/ed25519/src/ed25519/fe_0.o CC(target) Release/obj.target/ed25519/src/ed25519/fe_1.o CC(target) Release/obj.target/ed25519/src/ed25519/fe_cmov.o CC(target) Release/obj.target/ed25519/src/ed25519/fe_copy.o CC(target) Release/obj.target/ed25519/src/ed25519/fe_neg.o CC(target) Release/obj.target/ed25519/src/ed25519/fe_add.o CC(target) Release/obj.target/ed25519/src/ed25519/fe_sub.o CC(target) Release/obj.target/ed25519/src/ed25519/fe_mul.o CC(target) Release/obj.target/ed25519/src/ed25519/fe_sq.o CC(target) Release/obj.target/ed25519/src/ed25519/fe_sq2.o CC(target) Release/obj.target/ed25519/src/ed25519/fe_invert.o CC(target) Release/obj.target/ed25519/src/ed25519/fe_tobytes.o CC(target) Release/obj.target/ed25519/src/ed25519/fe_isnegative.o CC(target) Release/obj.target/ed25519/src/ed25519/fe_isnonzero.o CC(target) Release/obj.target/ed25519/src/ed25519/fe_frombytes.o CC(target) Release/obj.target/ed25519/src/ed25519/fe_pow22523.o CC(target) Release/obj.target/ed25519/src/ed25519/sc_reduce.o CC(target) Release/obj.target/ed25519/src/ed25519/sc_muladd.o CXX(target) Release/obj.target/ed25519/src/ed25519.o SOLINK_MODULE(target) Release/ed25519.node > curve25519@1.1.0 install /private/tmp/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/curve25519 > node-gyp rebuild CXX(target) Release/obj.target/curve/node_curve.o SOLINK_MODULE(target) Release/curve.node > bignum@0.11.0 install /private/tmp/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum > node-gyp configure build CXX(target) Release/obj.target/bignum/bignum.o SOLINK_MODULE(target) Release/bignum.node > mdns@2.2.11 install /private/tmp/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdns > node-gyp rebuild CXX(target) Release/obj.target/dns_sd_bindings/src/dns_sd.o CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_browse.o CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_enumerate_domains.o CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_get_addr_info.o CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_process_result.o CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_ref.o CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_ref_deallocate.o CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_ref_sock_fd.o CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_register.o CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_resolve.o CXX(target) Release/obj.target/dns_sd_bindings/src/mdns_utils.o CXX(target) Release/obj.target/dns_sd_bindings/src/network_interface.o CXX(target) Release/obj.target/dns_sd_bindings/src/socket_watcher.o CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_ref.o CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_create.o CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_deallocate.o CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_set_value.o CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_get_length.o CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_buffer_to_object.o SOLINK_MODULE(target) Release/dns_sd_bindings.node iobroker.homekit@0.0.6 node_modules/iobroker.homekit ├── yalm@2.0.0 (ansi-styles@2.1.0) ├── yargs@3.31.0 (decamelize@1.1.1, camelcase@2.0.1, window-size@0.1.4, y18n@3.2.0, cliui@3.1.0, os-locale@1.4.0, string-width@1.0.1) └── hap-nodejs@0.0.7 (debug@2.2.0, node-persist@0.0.6, ed25519@0.0.3, curve25519@1.1.0, srp@0.2.0, mdns@2.2.11)Welche Node Version hast du bei dir am laufen?
Christians-Mac-mini:tmp christian$ node -v v0.12.7 Christians-Mac-mini:tmp christian$ npm -v 2.11.3
