  4. JavaScript
  5. [Vorlage] JS: Log-Datei aufbereiten für VIS
    6.3k
617 Beiträge 60 Kommentatoren 211.3k Aufrufe 49 Beobachtet
  • NegaleinN Negalein
    @Mic sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
    Update:
    Script siehe hier:
    Hi Mic!
    Ich habe gerade dein aktuelles Script für mich angepasst und beim Start hagelt es leider nur so von Fehlermeldungen.
    javascript.0	2019-11-04 17:08:02.012	error	at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
    javascript.0	2019-11-04 17:08:02.012	error	at Socket.Readable.push (_stream_readable.js:223:10)
    javascript.0	2019-11-04 17:08:02.012	error	at readableAddChunk (_stream_readable.js:268:11)
    javascript.0	2019-11-04 17:08:02.012	error	at addChunk (_stream_readable.js:287:12)
    javascript.0	2019-11-04 17:08:02.011	error	at Socket.emit (events.js:198:13)
    javascript.0	2019-11-04 17:08:02.011	error	at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
    javascript.0	2019-11-04 17:08:02.011	error	at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
    javascript.0	2019-11-04 17:08:02.011	error	at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
    javascript.0	2019-11-04 17:08:02.011	error	at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
    javascript.0	2019-11-04 17:08:02.011	error	at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
    javascript.0	2019-11-04 17:08:02.011	error	at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
    javascript.0	2019-11-04 17:08:02.011	error	at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
    javascript.0	2019-11-04 17:08:02.011	error	at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
    javascript.0	2019-11-04 17:08:02.011	error	at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
    javascript.0	2019-11-04 17:08:02.011	error	at WebSocket.emit (events.js:198:13)
    javascript.0	2019-11-04 17:08:02.011	error	at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
    javascript.0	2019-11-04 17:08:02.011	error	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
    javascript.0	2019-11-04 17:08:02.011	error	at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
    javascript.0	2019-11-04 17:08:02.011	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
    javascript.0	2019-11-04 17:08:02.011	error	at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-11-04 17:08:02.011	error	at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
    javascript.0	2019-11-04 17:08:02.011	error	at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
    javascript.0	2019-11-04 17:08:02.011	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-11-04 17:08:02.011	error	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-11-04 17:08:02.011	error	at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
    javascript.0	2019-11-04 17:08:02.011	error	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    javascript.0	2019-11-04 17:08:02.011	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    javascript.0	2019-11-04 17:08:02.010	error	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-11-04 17:08:02.010	error	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    javascript.0	2019-11-04 17:08:02.010	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-11-04 17:08:02.010	error	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-11-04 17:08:02.010	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    javascript.0	2019-11-04 17:08:02.010	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    javascript.0	2019-11-04 17:08:02.010	error	at Socket.adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:845:17)
    javascript.0	2019-11-04 17:08:02.010	error	at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1254:17)
    javascript.0	2019-11-04 17:08:02.010	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1201:37)
    javascript.0	2019-11-04 17:08:02.010	error	at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:978:28)
    javascript.0	2019-11-04 17:08:02.009	error	at Object.createScript (vm.js:277:10)
    javascript.0	2019-11-04 17:08:02.009	error	at new Script (vm.js:83:7)
    javascript.0	2019-11-04 17:08:02.009	error	SyntaxError: Unexpected token *
    javascript.0	2019-11-04 17:08:02.009	error	^
    javascript.0	2019-11-04 17:08:02.007	error	*/
    javascript.0	2019-11-04 17:08:02.006	error	at script.js.common.ioBroker_Log:263
    javascript.0	2019-11-04 17:08:02.006	error	script.js.common.ioBroker_Log compile failed:
    Könntest du bitte drüberschaun, ob ich irgendwo was falsch konfiguriert habe?
    Danke dir!!
    ioBroker_Log_für_Vis.txt
    GlasfaserG Offline
    GlasfaserG Offline
    #222
    @Negalein
    Da ist ein Sternchen ( * ) reingekommen !!
    ändere mal auf :
    • GlasfaserG Glasfaser
      @Negalein
      ändere mal auf :
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      #223
      @Glasfaser sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
      Danke!
      Wie lange dauert es, bis das 1. mal was in den Objekten steht?
      Derzeit ist noch alles leer!
      ° Fixer ---> iob fix
        Danke!
        GlasfaserG Offline
        GlasfaserG Offline
        #224
        @Negalein
        Erzeuge mal absichtlich ein Error Meldung !!
          @Negalein
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          #225
          funktioniert.
            funktioniert.
            GlasfaserG Offline
            GlasfaserG Offline
            #226
            @Negalein
            Kein Problem ;)
              @Negalein
              Kein Problem ;)
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              #227
              Kein Problem
              kannst du mir nochmal weiterhelfen?
              Wie zeig ich das am besten in VIS an?
              Ich hab zB den DP:
              javascript.0.Log-Script.logWarnanderror.log
              Mit diesem Inhalt:
              2019-11-04 20:43:30.720 - warn: denon.0 [2 Einträge] AVR timed out due to no response2019-11-04 20:43:10.087 - warn: host.iobroker [3 Einträge] "system.host.ioBroker-RasPi4" is offline2019-11-04 20:35:03.037 - error: fb-checkpresence.0 Error getHostNo: undefined2019-11-04 20:35:03.037 - error: fb-checkpresence.0 soapAction error: Error: connect EHOSTUNREACH 10.0.1.1:490002019-11-04 20:18:13.308 - warn: admin.0 [2 Einträge] No repository source configured
              Dann auch noch diesen DP:
              javascript.0.Log-Script.logWarnanderror.logJSON
              Mit diesem Inhalt:
              [{"date":"04.11.2019 20:43","level":"<span class='log-warn'>warn</span>","source":"denon.0","msg":"[2 Einträge] AVR timed out due to no response"},{"date":"04.11.2019 20:43","level":"<span class='log-warn'>warn</span>","source":"host.iobroker","msg":"[3 Einträge] \"system.host.ioBroker-RasPi4\" is offline"},{"date":"04.11.2019 20:35","level":"<span class='log-error'>error</span>","source":"fb-checkpresence.0","msg":"Error getHostNo: undefined"},{"date":"04.11.2019 20:35","level":"<span class='log-error'>error</span>","source":"fb-checkpresence.0","msg":"soapAction error: Error: connect EHOSTUNREACH 10.0.1.1:49000"},{"date":"04.11.2019 20:18","level":"<span class='log-warn'>warn</span>","source":"admin.0","msg":"[2 Einträge] No repository source configured"}]
              Als Basic-Table sieht es kacke aus und ich weis nicht wie ich diese Tabelle anpassen/aufhübschen könnte.
                Kein Problem
                Ich hab zB den DP:
                Mit diesem Inhalt:
                Mit diesem Inhalt:
                GlasfaserG Offline
                GlasfaserG Offline
                #228
                @Negalein
                Nimm mein Widget :
                [{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"ioBroker Warn - Error Logs","name":"!_Überschrift"},"style":{"left":"699px","top":"7px","z-index":"10","color":"white","font-family":"Arial, Helvetica, sans-serif","font-size":"20px","width":"600px","height":"30px","text-align":"center"},"widgetSet":"basic"},{"tpl":"tplHqButton","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","oid":"javascript.0.Log-Script.logWarnanderror.clearJSON","min":"false","max":"true","iconName":"/vis.0/Wohnen/Mülle.png","btIconWidth":"45","offsetAuto":true,"leftOffset":"23","topOffset":"55","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"pushButton":true,"g_leftRight":true,"timeAsInterval":"true","infoLeftFontSize":"12","infoFontRightSize":"12","infoLeftPaddingLeft":"15","infoLeftPaddingRight":"50","infoRightPaddingRight":"15","descriptionLeft":"Clear JSON log Warnanderror","descriptionLeftDisabled":true},"style":{"left":"1302px","top":"1px","z-index":"30","width":"60px","height":"54px"},"widgetSet":"hqwidgets"},{"tpl":"tplTableBody","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":true,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","static_value":"","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/Kuddel1/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/Kuddel1/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/Kuddel1/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"table_oid":"javascript.0.Log-Script.logWarnanderror.logJSON","colName1":"Uhrzeit","colWidth1":"1x","colCount":"4","colWidth2":"10px","colWidth4":"450px","colWidth5":"40px","colWidth6":"40px","colName2":"Log-Eintrag","class":"mdui-table mdui-table-ascard-r250-l mdui-table-striped noSwipe","show_scroll":true,"hide_header":true,"g_last_change":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"new_on_top":true,"max_rows":"2000","detailed_wid":"w00377","name":"System_Logs","g_header_§2":true,"colName3":"Log-Eintrag","colWidth3":"100px"},"style":{"left":"594px","top":"43px","width":"770px","height":"680px","text-align":"left","color":"#ffffff","background-color":"","font-family":"Arial, Helvetica, sans-serif","z-index":"20","background":"","box-shadow":"","border-radius":"10px","font-size":"15px","border-style":"solid","border-color":"#303030"},"widgetSet":"basic"},{"tpl":"tplShapes","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":true,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","svgType":"square","strokeColor":"","fill":"#212121","strokeWidth":"5","scaleWidth":"1","scaleHeight":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"rotate":"45","name":"!_Hintergrund"},"style":{"left":"593px","top":"0px","background":"#212121","background-color":"#212121","z-index":"0","width":"783px","height":"730px","border-radius":"10px","box-shadow":"2px 2px 3px rgba(20, 20, 20, 50)","font-family":"Arial, Helvetica, sans-serif"},"widgetSet":"basic"}]
                Datenpunkt :
                NegaleinN O 2 Antworten Letzte Antwort
                  @Negalein
                  Nimm mein Widget :
                  Datenpunkt :
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  #229
                  Nimm mein Widget :
                  Bin noch am überlegen ob ich das Log-Script weiterverwende oder nicht.
                  In der Zeit wo der Cron läuft wird das System doch sehr träge. Und das trotz sehr guter Hardware.
                  GlasfaserG sigi234S crunchipC 3 Antworten Letzte Antwort
                    Nimm mein Widget :
                    GlasfaserG Offline
                    GlasfaserG Offline
                    #230
                    @Negalein
                    Ich sehe kein Trägheit durch das verwenden des Skript´s , aber dazu kann dir @Mic mehr dazu erklären bzw. sagen .
                      Nimm mein Widget :
                      sigi234S Online
                      sigi234S Online
                      #231
                      @Negalein sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
                      Das stimmt, ich schalte es nur manchmal ein.
                        Nimm mein Widget :
                        crunchipC Offline
                        crunchipC Offline
                        #232
                        @Negalein da es in der Vergangenheit diesbezüglich Probleme gab, hatte Mic doch schon das Skript angepasst. Hast du vllt noch eine alte Version laufen?
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          #233
                          @crunchip sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
                          Nein, ich verwende die aktuelle 3.1
                            GlasfaserG Offline
                            GlasfaserG Offline
                            #234
                            @Negalein
                            Sehr komisch … in der aktuellen sind 20 sek. und bei dir 10 sek. !??
                              @Negalein
                              NegaleinN Offline
                              NegaleinN Offline
                              Negalein
                              #235
                              Ja, hatte ich am Anfang auf 10 Sekunden geändert.
                              Dann schrittweise um 10 Sekunden erhöht.
                              Bei 1 Minute hab ich aufgehört.
                              Jedesmal wenn der Cron gestartet wird, wird das System sehr träge.
                                GlasfaserG Offline
                                GlasfaserG Offline
                                #236
                                @Negalein
                                Noch nie Probleme auf meiner Synology gehabt , aber sicherlich kann @Mic vielleicht eine Fehlerquelle bei dir finden ….. warum es bei dir das System sehr träge macht !?
                                  @Negalein
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  #237
                                  Ja, ich warte jetzt mal auf @Mic!
                                  Normal kenn ich auf der Syno auf keine Performanceeinbußen.
                                  Die CPU ist von 5% auf 16% angestiegen.
                                  Der RAM nur sehr minimal.
                                  Aber am ioBroker hab ich es vorallem an der VIS bemerkt, dass der Seitenaufbau sehr träge war und
                                  zB ein Button mit mdui-raisedbutton mdui-blue-blink nur ca. alle 10 Sekunden geblinkt hat (statt normal jede Sekunde).
                                    sigi234S Online
                                    sigi234S Online
                                    #238
                                    Vis ist bei mir auch träge geworden, ist das bei dir nur wenn du das Skript von @Mic laufen hast?
                                    • sigi234S sigi234
                                      NegaleinN Offline
                                      NegaleinN Offline
                                      Negalein
                                      #239
                                      @sigi234 sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
                                      Ja, nur bei diesem Script.
                                      Schalte ich das Script aus, läuft alles pipifein!
                                        crunchipC Offline
                                        crunchipC Offline
                                        #240
                                        @Negalein hab oben mal dein skript durchgesehen, du hast unter anderem
                                        const LOG_NO_OF_ENTRIES = 200;
                                        vllt wieder herab setzen auf 100
                                        GlasfaserG NegaleinN 2 Antworten Letzte Antwort
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          #241
                                          @crunchip
                                          Jipp … das hat er auch geändert . Wachsames Auge ;)
                                          sigi234S NegaleinN 2 Antworten Letzte Antwort
