  4. Test Adapter HeatingControl v3.xx
heating
3.3k Beiträge 239 Kommentatoren 2.5m Aufrufe 201 Beobachtet
  • M mrMuppet
    @mrMuppet sagte in Test Adapter HeatingControl v0.3.x:
    Bei mir klappt die Installation leider auch nicht:
    Im zweiten Anlauf anscheinend schon!
    host.iobroker-v1	2019-10-29 21:58:09.464	info	iobroker exit 0
    host.iobroker-v1	2019-10-29 21:58:08.417	info	iobroker Update "system.adapter.heatingcontrol.0"
    host.iobroker-v1	2019-10-29 21:58:08.342	info	iobroker upload [0] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/heatingcontrol.png heatingcontrol.png image/png
    host.iobroker-v1	2019-10-29 21:58:08.289	info	iobroker upload [1] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/index_m.html index_m.html text/html
    host.iobroker-v1	2019-10-29 21:58:08.235	info	iobroker upload [2] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/styles.css styles.css text/css
    host.iobroker-v1	2019-10-29 21:58:08.145	info	iobroker upload [3] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/words.js words.js application/javascript
    host.iobroker-v1	2019-10-29 21:58:08.064	info	iobroker found 29 vulnerabilities (21 low, 8 high) run `npm audit fix` to fix them, or `npm audit` for details
    host.iobroker-v1	2019-10-29 21:58:08.063	info	iobroker + iobroker.heatingcontrol@0.3.1updated 1 package and audited 4920 packages in 8.6s
    host.iobroker-v1	2019-10-29 21:57:58.791	info	iobroker npm install https://github.com/rg-engineering/ioBroker.heatingcontrol/tarball/0ae797ab207431c8611dccd290dcc119704f8208 --loglevel error --production --save --prefix "/opt/iobroker" (System c
    host.iobroker-v1	2019-10-29 21:57:58.790	info	iobroker NPM version: 6.11.3
    host.iobroker-v1	2019-10-29 21:57:58.541	info	iobroker install https://github.com/rg-engineering/ioBroker.heatingcontrol/tarball/0ae797ab207431c8611dccd290dcc119704f8208
    host.iobroker-v1	2019-10-29 21:57:57.248	info	iobroker url "https://github.com/rg-engineering/ioBroker.heatingcontrol" --debug
    Leider speichert er bei mir immer noch nichts.
    coyoteC Offline
    coyoteC Offline
    coyote
    #288
    @mrMuppet setz auch mal den Haken zum Löschen, speichern und schließen und dann nochmal von vorne eintragen
    • coyoteC coyote
      mrMuppet
      #289
      @coyote sagte in Test Adapter HeatingControl v0.3.x:
      Tatsächlich! Hat geklappt. Erstes Thermostat ist gespeichert. 😁
      ioBroker auf NUC (Celeron mit Ubuntu-Server)
      Homematic, HMIP, Hue, Unifi, Plex, Nest, Roborock, Google Assistant
      • B Baerny
        @Rene_HM ich hab die VIS hier aus dem Tread, gehörte ursprünglich zu dem Heizungsscript
        Ohne Titel.tiff
        MyMeyer
        #290
        @Baerny sagte in Test Adapter HeatingControl v0.3.x:
        Ohne Titel.tiff
        Hi ich hatte das gleiche Probleme mit dem alten VIS. Habe jetzt folgende Anpassung gemacht und 0,5 Werte entfernt. Finde ich etwas überzogen 0,5 Grad zu stellen. Aber mit dieser Einstellung scheint es zu laufe.
        Siehe Bild:
        MyMeyer
        Hardware: Intel I5 mit ****Debian ProxMox OS: Debian **** <<< >>> Network with UniFi <<<
        HomeMatic CCU-2 (Wired und Funk) / Philips HUE / Echo.DOT / Echo.SHOW / Xiaomi Smart-Home / Xiaomi Robot Vacuum Cleaner / Synology DS 918+ / Shelly 1&2 <<<
        • B Baerny
          Ohne Titel.tiff
          MyMeyer
          schrieb am zuletzt editiert von MyMeyer
          #291
          Ohne Titel.tiff
          Vergess meine Idee. :-( es funktioniert doch nicht. Daten werden nicht ans Thermostat gesendet !
          heatingcontrol.0 2019-10-29 23:12:55.694 debug ### hm-rpc.0.OEQ1704316.4.ACTUAL_TEMPERATURE heatingcontrol.0.Profiles.0.Buero.Mo-Fr.Periods.5.Temperature 16.3 16
          heatingcontrol.0 2019-10-29 23:12:38.068 debug ### state change already handled: 16 / 16 /// heatingcontrol.0.Profiles.0.Buero.Mo-Fr.Periods.5.Temperature / heatingcontrol.0.Profiles.0.Buero.Mo-Fr.Periods.5.Temperature
          heatingcontrol.0 2019-10-29 23:12:38.068 debug ### not handled heatingcontrol.0.Profiles.0.Buero.Mo-Fr.Periods.5.Temperature {"val":"16\n","ack":true,"ts":1572387158066,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc"
          heatingcontrol.0 2019-10-29 23:12:38.068 warn device not found heatingcontrol.0.Profiles.0.Buero.Mo-Fr.Periods.5.Temperature
          heatingcontrol.0 2019-10-29 23:12:38.068 debug handle actors heatingcontrol.0.Profiles.0.Buero.Mo-Fr.Periods.5.Temperature{"val":"16\n","ack":true,"ts":1572387158066,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":15
          heatingcontrol.0 2019-10-29 23:12:38.068 debug ### heatingcontrol.0.Profiles.0.Buero.Mo-Fr.Periods.5.Temperature hm-rpc.0.PEQ1190210.4.SET_TEMPERATURE 16 18
          heatingcontrol.0 2019-10-29 23:12:38.068 debug ### handle state change heatingcontrol.0.Profiles.0.Buero.Mo-Fr.Periods.5.Temperature {"val":"16\n","ack":true,"ts":1572387158066,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.adm
          heatingcontrol.0 2019-10-29 23:12:38.066 debug ### handle state change heatingcontrol.0.Profiles.0.Buero.Mo-Fr.Periods.5.Temperature {"val":"16\n","ack":false,"ts":1572387158065,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1
          MyMeyer
          • M MyMeyer
            Ohne Titel.tiff
            BlackJAck
            #292
            @MyMeyer
            Moin,
            hast du mal versucht statt "," einen "." zu verwenden?
            Oft ein Problem.
            • C Offline
              ChrisXY
              #293
              alsoo ich hab nun die 0.3.1 per Github Direktlink geladen .. nun geht es Actoren bleiben drin.
              Wie geht man nun am besten vor ?
              Gibt es ein Video dazu ?
              Sollte man lieber die einzelnen Räume/Gruppen hinzufügen ? Also Wohnzimmer, Kinderzimmer ?
              Ich nutze HM Geräte über die CCU2 ? Aktuell habe ich dort noch einen Heizplan drin. Muss ich diesen löschen ? Wird er Überschrieben ?
              Vielen Dank
                AhleWurscht75
                schrieb am zuletzt editiert von AhleWurscht75
                #294
                Hallöchen, bekomme mit der neuesten Version 0.3.1 folgende Meldung im Log
                exception in SubscribeStates [TypeError: Cannot read property 'isActive' of null]
                Bei den Sensoren nutze ich einen Xiaomi Fensterkontakt, die Temperatur Absenkung will irgendwie auch nicht funktionieren. Hängt dies evtl. mit obiger Fehlermeldung zusammen?
                Danke für eine kurze Hilfe
                PS: Vielleicht kann noch einmal jemand sauber darstellen was bei den Geräten wo einzutragen ist hinsichtlich der Rubriken Thermostat, Aktor und Sensoren. Hier gibt es ja die verschiedensten Konstellationen (HM, MAX, Xiaomi etc.) ich selbst nutze bei mir aktuell noch das „alte“ Heizungsscript. Da dieses aber nicht mehr weiterentwickelt wird, würde ich umsteigen. Bei dem alten Heizungsscript gab es einige Erläuterungen hinsichtlich Einstellungsmöglichkeiten etc. Evtl. Kann man dies ja hier auch im ersten Beitrag im Thread mit aufnehmen, zumindest die rudimentären Einstellungsmöglichkeiten.
                Rene_HMR 1 Antwort Letzte Antwort
                • B BlackJAck
                  @MyMeyer
                  Moin,
                  Oft ein Problem.
                  MyMeyer
                  #295
                  @BlackJAck sagte in Test Adapter HeatingControl v0.3.x:
                  @MyMeyer
                  Moin,
                  Oft ein Problem.
                  Hatte ich versucht ging auch nicht korrekt. Ich lasse das Thema VIS verstellen erstmal liegen und gebe den Entwickler Zeit für die wichtigen Dinge :-) Kommt bestimmt noch die Anpassung.
                  Habe jetzt die korrekten Werte unter Objekte hinterlegt und gut erstmal.
                  MyMeyer
                  • A AhleWurscht75
                    Rene_HMR Offline
                    Rene_HMR Offline
                    Rene_HM
                    #296
                    @AhleWurscht75 Kannst du mal das gesamte log beim Starten des Adapters posten? Eigentlich sollte die 0.3.1. genau das Problem beheben. Wir haben aber oben schon gesehen, dass manchmal die interne Datenstruktur nochmal gelöscht werden muss (also Haken "alles löschen" im admin einmal setzen, admin schliessen, wieder öffnen und die Einstellungen nochmal durchführen)
                    • Rene_HMR Rene_HM
                      AhleWurscht75
                      #297
                      @Rene_HM
                      Danke für die Rückmeldung. Das löschen habe ich heute Morgen mehrfach durchprobiert wie beschrieben. Also Haken rein, speichern und schließen, öffnen, Haken raus, neu anlegen etc. Hier das Log von soeben.
                      undefined2019-10-31 20:17:32.213 - info: host.ioBroker object change system.adapter.heatingcontrol.0
                      2019-10-31 20:17:32.238 - info: host.ioBroker instance system.adapter.heatingcontrol.0 started with pid 3632
                      2019-10-31 20:17:33.225 - info: heatingcontrol.0 starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.heatingcontrol, node: v8.12.0
                      2019-10-31 20:17:33.441 - error: heatingcontrol.0 exception in SubscribeStates [TypeError: Cannot read property 'isActive' of null]
                      2019-10-31 20:17:33.641 - info: heatingcontrol.0 calculating new target temperatures
                      2019-10-31 20:17:33.683 - info: heatingcontrol.0 room Büro Thermostat maxcube.0.devices.thermostat_16a13f.temp set to 19
                      • A AhleWurscht75
                        @Rene_HM
                        Rene_HMR Offline
                        Rene_HMR Offline
                        Rene_HM
                        #298
                        @AhleWurscht75 Ich hatte vergessen zu sagen, den Adapter bitte im debug-Mode starten.
                        siehe https://forum.iobroker.net/topic/22579/test-adapter-heatingcontrol-v0-3-x/94
                        • Rene_HMR Rene_HM
                          AhleWurscht75
                          #299
                          @Rene_HM macht natürlich Sinn...
                          2019-10-31 21:22:10.218 - info: host.ioBroker instance system.adapter.heatingcontrol.0 terminated with code null ()
                          2019-10-31 21:22:12.715 - info: host.ioBroker instance system.adapter.heatingcontrol.0 started with pid 1339
                          2019-10-31 21:22:13.510 - debug: heatingcontrol.0 objectDB connected
                          2019-10-31 21:22:13.566 - debug: heatingcontrol.0 statesDB connected
                          2019-10-31 21:22:13.677 - info: heatingcontrol.0 starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.heatingcontrol, node: v8.12.0
                          2019-10-31 21:22:13.681 - debug: heatingcontrol.0 devices [{"id":1,"name":"TestThermostat","isActive":true,"room":"Office","type":1,"OID_Current":"Test_OID"},{"id":2,"name":"maxcube.0.devices.thermostat_16a13f.temp","OID_Current":"maxcube.0.devices.thermostat_16a13f.temp","OID_Target":"maxcube.0.devices.thermostat_16a13f.setpoint","isActive":true,"type":1,"room":"Büro"},{"id":3,"name":"Is opened","OID_Current":"mihome.0.devices.magnet_158d0001c314f5.state","isActive":true,"type":3,"room":"Büro"}]
                          2019-10-31 21:22:13.684 - debug: heatingcontrol.0 CreateDatepoints
                          2019-10-31 21:22:13.868 - debug: heatingcontrol.0 rooms 15
                          2019-10-31 21:22:13.868 - debug: heatingcontrol.0 create data points for Büro
                          2019-10-31 21:22:13.912 - debug: heatingcontrol.0 room Büro with 5 periods
                          2019-10-31 21:22:13.912 - debug: heatingcontrol.0 Profile Type Mo-FR + Sa-So, profiles 1
                          2019-10-31 21:22:13.913 - debug: heatingcontrol.0 add state Profiles.0.Büro.Mo-Fr.Periods.0 max 5
                          2019-10-31 21:22:13.914 - debug: heatingcontrol.0 add state Profiles.0.Büro.Mo-Fr.Periods.1 max 5
                          2019-10-31 21:22:13.914 - debug: heatingcontrol.0 add state Profiles.0.Büro.Mo-Fr.Periods.2 max 5
                          2019-10-31 21:22:13.915 - debug: heatingcontrol.0 add state Profiles.0.Büro.Mo-Fr.Periods.3 max 5
                          2019-10-31 21:22:13.915 - debug: heatingcontrol.0 add state Profiles.0.Büro.Mo-Fr.Periods.4 max 5
                          2019-10-31 21:22:13.915 - debug: heatingcontrol.0 add state Profiles.0.Büro.Su-So.Periods.0 max 5
                          2019-10-31 21:22:13.916 - debug: heatingcontrol.0 add state Profiles.0.Büro.Su-So.Periods.1 max 5
                          2019-10-31 21:22:13.916 - debug: heatingcontrol.0 add state Profiles.0.Büro.Su-So.Periods.2 max 5
                          2019-10-31 21:22:13.916 - debug: heatingcontrol.0 add state Profiles.0.Büro.Su-So.Periods.3 max 5
                          2019-10-31 21:22:13.916 - debug: heatingcontrol.0 add state Profiles.0.Büro.Su-So.Periods.4 max 5
                          2019-10-31 21:22:13.917 - debug: heatingcontrol.0 not active.... Flur OG
                          2019-10-31 21:22:13.917 - debug: heatingcontrol.0 not active.... Bad
                          2019-10-31 21:22:13.917 - debug: heatingcontrol.0 not active.... Garage
                          2019-10-31 21:22:13.917 - debug: heatingcontrol.0 not active.... Wohnzimmer
                          2019-10-31 21:22:13.917 - debug: heatingcontrol.0 not active.... Schlafzimmer
                          2019-10-31 21:22:13.917 - debug: heatingcontrol.0 not active.... Flur EG
                          2019-10-31 21:22:13.917 - debug: heatingcontrol.0 not active.... Bad EG
                          2019-10-31 21:22:13.918 - debug: heatingcontrol.0 not active.... Küche
                          2019-10-31 21:22:13.918 - debug: heatingcontrol.0 not active.... Aussen
                          2019-10-31 21:22:13.918 - debug: heatingcontrol.0 not active.... Esszimmer
                          2019-10-31 21:22:13.918 - debug: heatingcontrol.0 not active.... Waschküche
                          2019-10-31 21:22:13.918 - debug: heatingcontrol.0 not active.... Hannah Schafzimmer
                          2019-10-31 21:22:13.918 - debug: heatingcontrol.0 not active.... Hannah Wohnzimmer
                          2019-10-31 21:22:13.918 - debug: heatingcontrol.0 not active.... Leer
                          2019-10-31 21:22:13.919 - debug: heatingcontrol.0 #start subscribtion
                          2019-10-31 21:22:13.920 - debug: heatingcontrol.0 no subscribe Path2FeiertagAdapter
                          2019-10-31 21:22:13.920 - debug: heatingcontrol.0 no subscribe Path2PresentDP
                          2019-10-31 21:22:13.920 - error: heatingcontrol.0 exception in SubscribeStates [TypeError: Cannot read property 'isActive' of null]
                          2019-10-31 21:22:13.923 - debug: heatingcontrol.0 start CalculateNextTime, profile type 2
                          2019-10-31 21:22:13.923 - debug: heatingcontrol.0 get profile
                          2019-10-31 21:22:13.927 - debug: heatingcontrol.0 profile 0
                          2019-10-31 21:22:13.928 - debug: heatingcontrol.0 setting Mo - Fr
                          2019-10-31 21:22:13.933 - debug: heatingcontrol.0 ---1 found time for Büro at {"val":"05:00","ack":true,"ts":1572375462656,"q":0,"from":"system.adapter.heatingcontrol.0","lc":1572375462656} 05:00
                          2019-10-31 21:22:13.934 - debug: heatingcontrol.0 push to list = 05,00
                          2019-10-31 21:22:13.942 - debug: heatingcontrol.0 ---1 found time for Büro at {"val":"08:00","ack":true,"ts":1572375462657,"q":0,"from":"system.adapter.heatingcontrol.0","lc":1572375462657} 08:00
                          2019-10-31 21:22:13.942 - debug: heatingcontrol.0 push to list = 08,00
                          2019-10-31 21:22:13.949 - debug: heatingcontrol.0 ---1 found time for Büro at {"val":"12:00","ack":true,"ts":1572375462661,"q":0,"from":"system.adapter.heatingcontrol.0","lc":1572375462661} 12:00
                          2019-10-31 21:22:13.949 - debug: heatingcontrol.0 push to list = 12,00
                          2019-10-31 21:22:13.975 - debug: heatingcontrol.0 ---1 found time for Büro at {"val":"16:00","ack":true,"ts":1572375462680,"q":0,"from":"system.adapter.heatingcontrol.0","lc":1572375462680} 16:00
                          2019-10-31 21:22:13.976 - debug: heatingcontrol.0 push to list = 16,00
                          2019-10-31 21:22:14.006 - debug: heatingcontrol.0 ---1 found time for Büro at {"val":"21:00","ack":true,"ts":1572375462683,"q":0,"from":"system.adapter.heatingcontrol.0","lc":1572375462683} 21:00
                          2019-10-31 21:22:14.007 - debug: heatingcontrol.0 push to list = 21,00
                          2019-10-31 21:22:14.008 - debug: heatingcontrol.0 setting Sa - Su
                          2019-10-31 21:22:14.014 - debug: heatingcontrol.0 ---2 found time for Büro at {"val":"05:00","ack":true,"ts":1572375462695,"q":0,"from":"system.adapter.heatingcontrol.0","lc":1572375462695} 05:00
                          2019-10-31 21:22:14.015 - debug: heatingcontrol.0 push to list = 05,00
                          2019-10-31 21:22:14.020 - debug: heatingcontrol.0 ---2 found time for Büro at {"val":"08:00","ack":true,"ts":1572375462697,"q":0,"from":"system.adapter.heatingcontrol.0","lc":1572375462697} 08:00
                          2019-10-31 21:22:14.020 - debug: heatingcontrol.0 push to list = 08,00
                          2019-10-31 21:22:14.023 - debug: heatingcontrol.0 ---2 found time for Büro at {"val":"12:00","ack":true,"ts":1572375462698,"q":0,"from":"system.adapter.heatingcontrol.0","lc":1572375462698} 12:00
                          2019-10-31 21:22:14.023 - debug: heatingcontrol.0 push to list = 12,00
                          2019-10-31 21:22:14.026 - debug: heatingcontrol.0 ---2 found time for Büro at {"val":"16:00","ack":true,"ts":1572375462699,"q":0,"from":"system.adapter.heatingcontrol.0","lc":1572375462699} 16:00
                          2019-10-31 21:22:14.026 - debug: heatingcontrol.0 push to list = 16,00
                          2019-10-31 21:22:14.029 - debug: heatingcontrol.0 ---2 found time for Büro at {"val":"21:00","ack":true,"ts":1572375462703,"q":0,"from":"system.adapter.heatingcontrol.0","lc":1572375462703} 21:00
                          2019-10-31 21:22:14.029 - debug: heatingcontrol.0 push to list = 21,00
                          2019-10-31 21:22:14.031 - debug: heatingcontrol.0 create cron job #0 at 5:0 string: 0 0 5 * * 1-5 Europe/Berlin
                          2019-10-31 21:22:14.070 - debug: heatingcontrol.0 create cron job #1 at 8:0 string: 0 0 8 * * 1-5 Europe/Berlin
                          2019-10-31 21:22:14.083 - debug: heatingcontrol.0 create cron job #2 at 12:0 string: 0 0 12 * * 1-5 Europe/Berlin
                          2019-10-31 21:22:14.094 - debug: heatingcontrol.0 create cron job #3 at 16:0 string: 0 0 16 * * 1-5 Europe/Berlin
                          2019-10-31 21:22:14.100 - debug: heatingcontrol.0 create cron job #4 at 21:0 string: 0 0 21 * * 1-5 Europe/Berlin
                          2019-10-31 21:22:14.113 - debug: heatingcontrol.0 create cron job #5 at 5:0 string: 0 0 5 * * 0,6 Europe/Berlin
                          2019-10-31 21:22:14.118 - debug: heatingcontrol.0 create cron job #6 at 8:0 string: 0 0 8 * * 0,6 Europe/Berlin
                          2019-10-31 21:22:14.125 - debug: heatingcontrol.0 create cron job #7 at 12:0 string: 0 0 12 * * 0,6 Europe/Berlin
                          2019-10-31 21:22:14.130 - debug: heatingcontrol.0 create cron job #8 at 16:0 string: 0 0 16 * * 0,6 Europe/Berlin
                          2019-10-31 21:22:14.137 - debug: heatingcontrol.0 create cron job #9 at 21:0 string: 0 0 21 * * 0,6 Europe/Berlin
                          2019-10-31 21:22:14.147 - debug: heatingcontrol.0 [INFO] status = true next event: 1 Nov 2019 05:00:00
                          2019-10-31 21:22:14.150 - debug: heatingcontrol.0 [INFO] status = true next event: 1 Nov 2019 08:00:00
                          2019-10-31 21:22:14.158 - debug: heatingcontrol.0 [INFO] status = true next event: 1 Nov 2019 12:00:00
                          2019-10-31 21:22:14.162 - debug: heatingcontrol.0 [INFO] status = true next event: 1 Nov 2019 16:00:00
                          2019-10-31 21:22:14.172 - debug: heatingcontrol.0 [INFO] status = true next event: 1 Nov 2019 21:00:00
                          2019-10-31 21:22:14.174 - debug: heatingcontrol.0 [INFO] status = true next event: 2 Nov 2019 05:00:00
                          2019-10-31 21:22:14.177 - debug: heatingcontrol.0 [INFO] status = true next event: 2 Nov 2019 08:00:00
                          2019-10-31 21:22:14.180 - debug: heatingcontrol.0 [INFO] status = true next event: 2 Nov 2019 12:00:00
                          2019-10-31 21:22:14.183 - debug: heatingcontrol.0 [INFO] status = true next event: 2 Nov 2019 16:00:00
                          2019-10-31 21:22:14.189 - debug: heatingcontrol.0 [INFO] status = true next event: 2 Nov 2019 21:00:00
                          2019-10-31 21:22:14.190 - debug: heatingcontrol.0 Check sensors for Büro
                          2019-10-31 21:22:14.202 - debug: heatingcontrol.0 got sensor state {"val":false,"ack":true,"ts":1572515728024,"q":0,"from":"system.adapter.mihome.0","lc":1572515728024} from mihome.0.devices.magnet_158d0001c314f5.state
                          2019-10-31 21:22:14.205 - info: heatingcontrol.0 calculating new target temperatures
                          2019-10-31 21:22:14.233 - debug: heatingcontrol.0 profile type 2
                          2019-10-31 21:22:14.234 - debug: heatingcontrol.0 get profile
                          2019-10-31 21:22:14.238 - debug: heatingcontrol.0 profile 0
                          2019-10-31 21:22:14.239 - debug: heatingcontrol.0 check room Büro
                          2019-10-31 21:22:14.239 - debug: heatingcontrol.0 number of periods 5
                          2019-10-31 21:22:14.239 - debug: heatingcontrol.0 check ID Profiles.0.Büro.Mo-Fr.Periods.0.time
                          2019-10-31 21:22:14.249 - debug: heatingcontrol.0 check time for Büro Profiles.0.Büro.Mo-Fr.Periods.0.time 19
                          2019-10-31 21:22:14.250 - debug: heatingcontrol.0 check ID Profiles.0.Büro.Mo-Fr.Periods.1.time
                          2019-10-31 21:22:14.261 - debug: heatingcontrol.0 check time for Büro Profiles.0.Büro.Mo-Fr.Periods.1.time 20
                          2019-10-31 21:22:14.261 - debug: heatingcontrol.0 check ID Profiles.0.Büro.Mo-Fr.Periods.2.time
                          2019-10-31 21:22:14.271 - debug: heatingcontrol.0 check time for Büro Profiles.0.Büro.Mo-Fr.Periods.2.time 20
                          2019-10-31 21:22:14.271 - debug: heatingcontrol.0 check ID Profiles.0.Büro.Mo-Fr.Periods.3.time
                          2019-10-31 21:22:14.279 - debug: heatingcontrol.0 check time for Büro Profiles.0.Büro.Mo-Fr.Periods.3.time 19
                          2019-10-31 21:22:14.279 - debug: heatingcontrol.0 check ID Profiles.0.Büro.Mo-Fr.Periods.4.time
                          2019-10-31 21:22:14.298 - debug: heatingcontrol.0 check time for Büro Profiles.0.Büro.Mo-Fr.Periods.4.time 21
                          2019-10-31 21:22:14.298 - debug: heatingcontrol.0 ### 21 0 0 0 0 0
                          2019-10-31 21:22:14.298 - info: heatingcontrol.0 room Büro Thermostat maxcube.0.devices.thermostat_16a13f.temp set to 21
                          2019-10-31 21:22:14.313 - debug: heatingcontrol.0 thermostat maxcube.0.devices.thermostat_16a13f.setpoint to 21
                          2019-10-31 21:22:14.320 - debug: heatingcontrol.0 [INFO] status = true next event: 1 Nov 2019 05:00:00
                          2019-10-31 21:22:14.325 - debug: heatingcontrol.0 [INFO] status = true next event: 1 Nov 2019 08:00:00
                          2019-10-31 21:22:14.333 - debug: heatingcontrol.0 [INFO] status = true next event: 1 Nov 2019 12:00:00
                          2019-10-31 21:22:14.337 - debug: heatingcontrol.0 [INFO] status = true next event: 1 Nov 2019 16:00:00
                          2019-10-31 21:22:14.347 - debug: heatingcontrol.0 [INFO] status = true next event: 1 Nov 2019 21:00:00
                          2019-10-31 21:22:14.349 - debug: heatingcontrol.0 [INFO] status = true next event: 2 Nov 2019 05:00:00
                          2019-10-31 21:22:14.351 - debug: heatingcontrol.0 [INFO] status = true next event: 2 Nov 2019 08:00:00
                          2019-10-31 21:22:14.354 - debug: heatingcontrol.0 [INFO] status = true next event: 2 Nov 2019 12:00:00
                          2019-10-31 21:22:14.358 - debug: heatingcontrol.0 [INFO] status = true next event: 2 Nov 2019 16:00:00
                          • A AhleWurscht75
                            Rene_HMR Offline
                            Rene_HMR Offline
                            Rene_HM
                            #300
                            @AhleWurscht75 Danke. Ich sehe schon das Problem... Ich baue den bug fix morgen ein...
                            • Rene_HMR Rene_HM
                              AhleWurscht75
                              #301
                              @Rene_HM
                              perfekt, Danke 👍🏻
                                mrMuppet
                                #302
                                ich richte gerade das erste Mal den Adapter richtig bei mir ein. Da hab ich eine winzige Verständnisfrage:
                                die Periode wird mit "Period from" angezeigt. Bedeutet dies, dass die Perioden, anders als im Heizungsscript, quasi ihre Startzeit statt einer Endzeit eingetragen bekommen?
                                • M mrMuppet
                                  Rene_HMR Offline
                                  Rene_HMR Offline
                                  Rene_HM
                                  #303
                                  @mrMuppet genau. Ab einem bestimmten Zeitpunkt (="time") wird die Temperatur (="temperature") verwendet. Das gilt solange, bis die nächste Periode startet... übrigens auch über 00:00 Uhr hinaus. Man muss also keinen Zeitpunkt 00:00 Uhr anlegen...
                                  Wenn man den Adapter im debug-Mode startet, werden übrigens die nächste Zeitpunkte, wann der Adapter Umstellungen vornimmt, ausgeloggt.
                                  Das sieht so aus:
                                  heatingcontrol.0	2019-11-01 13:46:04.129	debug	(7507) [INFO] status = true next event: 1 Nov 2019 21:00:00
                                  heatingcontrol.0	2019-11-01 13:46:04.125	debug	(7507) [INFO] status = true next event: 1 Nov 2019 16:00:00
                                  heatingcontrol.0	2019-11-01 13:46:04.123	debug	(7507) [INFO] status = true next event: 2 Nov 2019 12:00:00
                                  heatingcontrol.0	2019-11-01 13:46:04.119	debug	(7507) [INFO] status = true next event: 2 Nov 2019 08:00:00
                                  heatingcontrol.0	2019-11-01 13:46:04.115	debug	(7507) [INFO] status = true next event: 2 Nov 2019 05:00:00
                                  heatingcontrol.0	2019-11-01 13:46:04.112	debug	(7507) [INFO] status = true next event: 31 Mar 2020 23:55:00
                                  heatingcontrol.0	2019-11-01 13:46:04.098	debug	(7507) [INFO] status = true next event: 1 Oct 2020 00:05:00
                                  • A AhleWurscht75
                                    @Rene_HM
                                    perfekt, Danke 👍🏻
                                    Rene_HMR Offline
                                    Rene_HMR Offline
                                    Rene_HM
                                    #304
                                    @AhleWurscht75 im npm und im github liegt die Version 0.3.2, die das Problem mit subscribe beheben sollte...
                                    • Rene_HMR Rene_HM
                                      Das sieht so aus:
                                      mrMuppet
                                      #305
                                      @Rene_HM Vielen Dank.
                                      Ich glaube da gibts auch noch einen Tippfehler: Su-So müsste doch Sa-Su heißen, oder?
                                      • M mrMuppet
                                        mrMuppet
                                        schrieb am zuletzt editiert von mrMuppet
                                        #306
                                        Wie gehe ich am besten mit überzähligen Perioden um? Also in manchen Zimmern benötige ich nur 2 Schaltzeiten, in anderen vier... Wie kann ich nicht benötigte Periodeneinträge einfach deaktivieren damit ich nicht so viele überflüssige Zeiten einstellen muss?
                                        Edit: Ist es sinnvoller die überzähliugen alle auf die selbe Zeit zu stellen? Oder besser andere Zeiten?
                                        Edit2: Oder werden Schaltzeiten die in der Reihenfolge quasi zu spät kommen einfach übersprungen? Für mich wäre es dann jedenfalls angnehmer, wenn alle Punkte pe default auf 00:00 oder 23:59 liegen würden.
                                        • Rene_HMR Rene_HM
                                          AhleWurscht75
                                          #307
                                          @Rene_HM
                                          Super! Herzlichen Dank für den schnellen support. Ich habe soeben installiert und es läuft.
                                          Werde jetzt mal alles einrichten und so wie es aussieht werde ich dann das "alte Heizungsscript" in die Rente schicken. Es fehlt jetzt nur noch eine schicke VIS dazu, die alte ist mir zu unübersichtlich und sieht auch nicht so hübsch aus. Ectl. bastele ich dazu mal was und kann damit mal was zurückgeben an die Community.
                                          Eine Anmerkung von mir noch. Ich würde es für sinnvoll erachten, wenn man bei der Reaktion auf die Sensoren und die anschließende Absenkung der Temperatur eine variable, also auswählbare, Zeitverzögerung einbauen könnte. Wir haben einen Hund und immer, wenn wir den rauslassen, Balkontür auf und wieder zu, löst natürlich das Script aus und senkt die Temperatur und hebt sie dann sofort wieder an. Diesen "Datentraffic" könnte man sich sparen. Evtl. ist eine Berücksichtigung in der weiteren Entwicklung möglich.
                                          An dieser Stelle nochmals Danke für Deine Arbeit in dieser Sache!!!!
