  4. [PROBLEM] Fehler: ... javascript@4.3.2: 243
javascript fehlerupdatefehler
6 Beiträge 4 Kommentatoren 865 Aufrufe 4 Beobachtet
  • ? Offline
    das Update Script Engine 4.3.2 macht leider Probleme.
    Fertig mit Fehler: host.ioBroker Cannot install iobroker.javascript@4.3.2: 243
    $ ./iobroker upgrade javascript
    Update javascript from @4.3.1 to @4.3.2
    NPM version: 6.11.3
    npm install iobroker.javascript@4.3.2 --loglevel error --production --save --prefix "/opt/iobroker" (System call)
    npm
    ERR!
    code EACCES
    npm
    ERR! syscall
    accessnpm
    ERR!
    path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
    npm
    ERR! errno
    -13
    npm
    ERR!
    Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node'npm
    ERR! { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node']
    npm ERR!
    stack:npm
    ERR! 'Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node'',
    npm
    ERR! errno: -13,
    npm ERR!
    code: 'EACCES',npm
    ERR! syscall: 'access',npm
    ERR! path:npm ERR! '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node' }npm ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm
    ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator.
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2019-10-28T06_37_57_742Z-debug.log
    ERROR: host.ioBroker Cannot install iobroker.javascript@4.3.2: 243
      NPM version: 6.11.3
      npm
      ERR!
      code EACCES
      npm
      ERR! syscall
      accessnpm
      ERR!
      npm
      ERR! errno
      -13
      npm
      ERR!
      npm ERR!
      stack:npm
      npm
      ERR! errno: -13,
      npm ERR!
      code: 'EACCES',npm
      GlasfaserG Offline
      GlasfaserG Offline
      @Nuggelbeb sagte in [PROBLEM] Fehler: ... javascript@4.3.2: 243:
      Mit Root Rechte ausführen !
      • GlasfaserG Glasfaser
        AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        @Glasfaser @Nuggelbeb
        Auch wenn das da steht, wäre die bessere Alternative, den Fixer auszuführen. Root verkorkst die Berechtigungen nur noch mehr. In der neuesten Fixer-Version haben wir hoffentlich auch alle Ursachen gefunden, die die Berechtigungen überhaupt erst verkorksen können.
        • AlCalzoneA AlCalzone
          arteckA Offline
          arteckA Offline
          arteck
          @Nuggelbeb fixer drüber fertig
          • ? Offline
            Danke, es geht nach dem ich den Fixer ausgeführt habe.
            Nur, ist mir unerklärlich warum auf einmal die root-Rechte weg waren.
            Ich hatte nach dem Update von nodejs vor ca. einer Woche den Fixer schon mal drüber gebügelt.
            UNERKLÄRLICH
            Aber noch mal Danke. Ich habe "... root/Administrator." nicht gesehen.
            Mit 60 wird man langsam blind. 🤗
              UNERKLÄRLICH
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              Irgendwas manuell per npm installiert? Dazu haben wir erst vor kurzem was eingebaut.
