<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[PROBLEM] Fehler: ... javascript@4.3.2: 243]]></title><description><![CDATA[<p dir="auto">Hallo,<br />
das Update Script Engine 4.3.2 macht leider Probleme.</p>
<p dir="auto"><strong>Fertig mit Fehler: host.ioBroker Cannot install iobroker.javascript@4.3.2: 243</strong><br />
</p><section class="spoiler-wrapper"><button class="spoiler-control btn btn-default">Spoiler</button><section style="display:none" class="spoiler-content"><br />
$ ./iobroker upgrade javascript<br />
Update javascript from @4.3.1 to @4.3.2<br />
NPM version: 6.11.3<br />
npm install iobroker.javascript@4.3.2 --loglevel error --production --save --prefix "/opt/iobroker" (System call)<br />
npm<br />
ERR!<br />
code EACCES<br />
npm<br />
ERR! syscall<br />
accessnpm<br />
ERR!<br />
path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node<br />
npm<br />
ERR! errno<br />
-13<br />
npm<br />
ERR!<br />
Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node'npm<br />
ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node']<br />
npm ERR!<br />
stack:npm<br />
ERR!    'Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node'',<br />
npm<br />
ERR!   errno: -13,<br />
npm ERR!<br />
code: 'EACCES',npm<br />
ERR!   syscall: 'access',npm<p></p>
<p dir="auto">ERR!   path:npm ERR!    '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node' }npm ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm<br />
ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator.</p>
<p dir="auto">npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-10-28T06_37_57_742Z-debug.log<br />
ERROR: host.ioBroker Cannot install iobroker.javascript@4.3.2: 243<br />
ERROR: process exited with code 25<br />
</p></section></section><p></p>
]]></description><link>https://forum.iobroker.net/topic/26164/problem-fehler-javascript-4-3-2-243</link><generator>RSS for Node</generator><lastBuildDate>Sun, 26 Apr 2026 20:26:23 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/26164.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 28 Oct 2019 06:45:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [PROBLEM] Fehler: ... javascript@4.3.2: 243 on Tue, 29 Oct 2019 07:27:59 GMT]]></title><description><![CDATA[<p dir="auto">@Nuggelbeb sagte in <a href="/post/317934">[PROBLEM] Fehler: ... javascript@4.3.2: 243</a>:</p>
<blockquote>
<p dir="auto">Nur, ist mir unerklärlich warum auf einmal die root-Rechte weg waren.</p>
</blockquote>
<p dir="auto">Irgendwas manuell per npm installiert? Dazu haben wir erst vor kurzem was eingebaut.</p>
]]></description><link>https://forum.iobroker.net/post/318154</link><guid isPermaLink="true">https://forum.iobroker.net/post/318154</guid><dc:creator><![CDATA[AlCalzone]]></dc:creator><pubDate>Tue, 29 Oct 2019 07:27:59 GMT</pubDate></item><item><title><![CDATA[Reply to [PROBLEM] Fehler: ... javascript@4.3.2: 243 on Mon, 28 Oct 2019 15:47:24 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">den Fixer auszuführen</p>
</blockquote>
<p dir="auto">Danke, es geht nach dem ich den Fixer ausgeführt habe.<br />
Nur, ist mir unerklärlich warum auf einmal die root-Rechte weg waren.<br />
Ich hatte nach dem Update von nodejs vor ca. einer Woche den Fixer schon mal drüber gebügelt.<br />
UNERKLÄRLICH</p>
<p dir="auto">Aber noch mal Danke. Ich habe "... root/Administrator." nicht gesehen.<br />
Mit 60 wird man langsam blind. <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f917.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--hugging_face" style="height:23px;width:auto;vertical-align:middle" title=":hugging_face:" alt="🤗" /></p>
]]></description><link>https://forum.iobroker.net/post/317934</link><guid isPermaLink="true">https://forum.iobroker.net/post/317934</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 28 Oct 2019 15:47:24 GMT</pubDate></item><item><title><![CDATA[Reply to [PROBLEM] Fehler: ... javascript@4.3.2: 243 on Mon, 28 Oct 2019 12:28:03 GMT]]></title><description><![CDATA[<p dir="auto">@Nuggelbeb <a href="https://forum.iobroker.net/topic/20211/iobroker-installation-fixer-beta-verf%C3%BCgbar">fixer</a> drüber fertig</p>
]]></description><link>https://forum.iobroker.net/post/317869</link><guid isPermaLink="true">https://forum.iobroker.net/post/317869</guid><dc:creator><![CDATA[arteck]]></dc:creator><pubDate>Mon, 28 Oct 2019 12:28:03 GMT</pubDate></item><item><title><![CDATA[Reply to [PROBLEM] Fehler: ... javascript@4.3.2: 243 on Mon, 28 Oct 2019 11:54:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/glasfaser" aria-label="Profile: Glasfaser">@<bdi>Glasfaser</bdi></a> @Nuggelbeb<br />
Auch wenn das da steht, wäre die bessere Alternative, den Fixer auszuführen. Root verkorkst die Berechtigungen nur noch mehr. In der neuesten Fixer-Version haben wir hoffentlich auch alle Ursachen gefunden, die die Berechtigungen überhaupt erst verkorksen können.</p>
]]></description><link>https://forum.iobroker.net/post/317847</link><guid isPermaLink="true">https://forum.iobroker.net/post/317847</guid><dc:creator><![CDATA[AlCalzone]]></dc:creator><pubDate>Mon, 28 Oct 2019 11:54:25 GMT</pubDate></item><item><title><![CDATA[Reply to [PROBLEM] Fehler: ... javascript@4.3.2: 243 on Mon, 28 Oct 2019 06:46:58 GMT]]></title><description><![CDATA[<p dir="auto">@Nuggelbeb sagte in <a href="/post/317716">[PROBLEM] Fehler: ... javascript@4.3.2: 243</a>:</p>
<blockquote>
<p dir="auto">permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator.</p>
</blockquote>
<p dir="auto">Mit Root Rechte ausführen !</p>
]]></description><link>https://forum.iobroker.net/post/317717</link><guid isPermaLink="true">https://forum.iobroker.net/post/317717</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Mon, 28 Oct 2019 06:46:58 GMT</pubDate></item></channel></rss>
