  4. js-controller 2.0 ab sofort im Latest Repo
js-controller
1.1k Beiträge 89 Kommentatoren 520.3k Aufrufe 64 Beobachtet
  • M Marty56
    Installations schlägt leider fehl. Anbei das Log File.
    Was kann ich machen?
    2019-10-22T15_05_31_974Z-debug.log
    apollon77A
    apollon77A
    #500
    @Marty56 Hm ... also das sieht soweit ok aus ... bis dann:
    3754 warn bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
    3755 warn bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
    3756 verbose stack TypeError: Cannot read property '0' of undefined
    3756 verbose stack     at rmStuff (/usr/lib/node_modules/npm/lib/unbuild.js:61:24)
    3756 verbose stack     at tryCatcher (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
    3756 verbose stack     at ret (eval at makeNodePromisifiedEval (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promisify.js:184:12), <anonymous>:13:39)
    3756 verbose stack     at lifecycle.then.then (/usr/lib/node_modules/npm/lib/install/action/unbuild.js:12:12)
    3756 verbose stack     at Promise._settlePromiseFromHandler (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:512:31)
    3756 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:569:18)
    3756 verbose stack     at Promise._settlePromise0 (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:614:10)
    3756 verbose stack     at Promise._settlePromises (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:694:18)
    3756 verbose stack     at Promise._fulfill (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:638:18)
    3756 verbose stack     at /usr/lib/node_modules/npm/node_modules/bluebird/js/release/nodeback.js:42:21
    kommt ... ich tippe auf npm bug. Wenn man googelt dann findet man Idee das eine kaputte package-lock.json Ursche sein kann. ALso lösch die mal und versuch nochmal.
    Ansonsten (auch wenn ich es ungern sage): npm updaten und hoffen
    • apollon77A apollon77
      @Andreas-Hochstöger Gibt doch bitte mal etwas mehr Details. WIe heissen die? "Selbst angelegt" heisst eigener "Namespace" (MeineObjekt.0.xyyz oder was?)
      Andreas HochstögerA
      Andreas HochstögerA
      Andreas Hochstöger
      #501
      @apollon77
      Der Ordner heißt .Meine_Geräte und darin befinden sich dann sachen wie Bürolicht Wohnzimmerlicht usw.
      • F
        F
        flock
        #502
        habe das gleiche Problem wie telekom0815.
        Beim öffnen von VIS kommt File index.html not found: permissionError bzw. File edit.html not found: permissionError
        Beim öffnen der Seite des Webadapters kommt eine fast leere Seite, oben links steht nur Sign out.
        Beim öffnen von HABpanel kommt auch wieder die Meldung File index.html not found: permissionError.
        VVIS ist Version 1.2.1, Web 2.4.6 und HABpanel 0.3.4.
        js-controler habe ich auf 2-0-35 geupdatet.
        • Andreas HochstögerA Andreas Hochstöger
          @apollon77
          apollon77A
          apollon77A
          #503
          @Andreas-Hochstöger ein Punkt Am Anfang?? Und keine „.0“ oder sondanach? Abgesehen davon das es vllt bisher ging bricht es intern nahezu alle Konventionen für valide Objekt IDs.
          Gib mal ein vollständiges Beispiel Bitte bzw zeig mal einen Screenshot vom Admin ...
          Andreas HochstögerA 2 Antworten Letzte Antwort
            Andreas HochstögerA
            Andreas HochstögerA
            Andreas Hochstöger
            #504
              apollon77A
              apollon77A
              #505
              @Andreas-Hochstöger Klapp mal bitte auf. Zeig mal bis runter zu einem state
              Andreas HochstögerA 1 Antwort Letzte Antwort
                Andreas HochstögerA
                Andreas HochstögerA
                Andreas Hochstöger
                #506
                  Andreas HochstögerA
                  Andreas HochstögerA
                  Andreas Hochstöger
                  #507
                  @apollon77
                  Du hast recht, der Ordner ist falsch angelegt worden. habe einen Test Ordner angelegt, der funktioniert.
                  Kann man den bestehenden ordner .Meine_Geräte umbenennen oder muss ich alle Geräte neu anlegen?
                    @apollon77
                    apollon77A
                    apollon77A
                    #508
                    @Andreas-Hochstöger Also in der Benahmung sind zwei Fehler drin: Einmal der "." Am Anfang und semantisch muss danach ein ".0" kommen, also Meine_Objekte.0.xxx wäre ok.
                    Theoretisch könntest Du auf controller 1.5 zurück, deine Objekte exportieren, umbenennen, wieder importieren und dann neu updaten. Alternativ:
                    ioBroker stoppen, dann in iobroker-data/objects.json und states.json überall ".MeineDaten." durch "Meine_Objekte.0." erstzen und neu starten. Dann Deine Skripte und Visu anpassen
                    K Andreas HochstögerA 3 Antworten Letzte Antwort
                      K
                      K
                      knopers1
                      #509
                      ich bin jetzt auch auf den js-controler 2.0.35 umgestiegen. Es rennt alles nach wie vor!
                      Besten Dank!
                        Andreas HochstögerA
                        Andreas HochstögerA
                        Andreas Hochstöger
                        #510
                        @apollon77
                        Danke, werde ich heute Nachmittag gleich mal versuchen.
                        Du hast mir sehr geholfen. Das war eine fertige IoBroker Version von Elzershark, der hat den falschen Ordner angelegt. Melde mich noch mal ob es geklappt hat.
                        Danke nochmal!
                        R 1 Antwort Letzte Antwort
                          @apollon77
                          Danke nochmal!
                          R
                          R
                          RappiRN
                          #511
                          @Andreas-Hochstöger sagte in js-controller 2.0 ab sofort im Latest Repo:
                          Da haben wir wieder das Problem! 😠
                          Es gibt auch offizielle fertige ioBroker Images, die auch vorher von erfahrenen Usern getestet wurden und auch besser supportet werden können, weil bekannt ist, was da eingestellt wurde.
                          Oben in der Forumleiste (jedenfalls bei mir!) ist ein Link zu (offiziellen!) Doku, vielleicht noch nicht vollständig, aber mit dem Wichtigsten versehen um ioBroker auf verschiedenen Wegen zu installieren.
                          Enrico
                            M
                            M
                            Marty56
                            schrieb am zuletzt editiert von Marty56
                            #512
                            @apollon77 seltsam. Das Update vom Vis auf Version 1.2 hat funktioniert. in diesem Fall scheint npm also zu funktionieren.
                            Update: Ich konnte den Bug mit Hilfe von
                            https://github.com/epoberezkin/ajv/issues/601#issuecomment-488970199
                            fixen.
                            HW:NUC (16 GB Ram)
                            OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
                            • opossumO
                              opossumO
                              opossum
                              schrieb am zuletzt editiert von opossum
                              #513
                              eine Frage: Wenn ich iobroker auf den 2.0.35 anheben möchte, nehme ich die Befehle aus den ersten Post. Soweit klar. Mittlerweile wird aber auch für Node.js die 10.17.0 angeboten. Wird das dann gleich mit upgedated? Wollte eigentlich bei 10.16.3 bleiben bzw. das nicht alles gleich zusammen machen. Es geht um mein ProdSystem.
                              https://www.schlepper-petersdorf.de
                              • opossumO opossum
                                J
                                J
                                Jan1
                                #514
                                @opossum
                                Zwei mal nein.
                                1. ist der 2.0.35 bereits im latest und wenn Du auf latest bist, dann kann man das js Update wie gewohnt machen.
                                2. Node wird mit nem System Update hochgezogen.
                                opossumO BBTownB 2 Antworten Letzte Antwort
                                • J Jan1
                                  @opossum
                                  Zwei mal nein.
                                  opossumO
                                  opossumO
                                  opossum
                                  #515
                                  @Jan1 sagte in js-controller 2.0 ab sofort im Latest Repo:
                                  @opossum
                                  Zwei mal nein.
                                  Danke.
                                  • J Jan1
                                    @opossum
                                    Zwei mal nein.
                                    BBTownB
                                    BBTownB
                                    BBTown
                                    #516
                                    Nur um Missverständnissen vorzubeugen.
                                    Mit Systemupdate ist dann bspw. ein Umstieg von debian v9.x (Strecth) auf v10.x (Buster) gemeint
                                    Ein Systemupdate in Form von apt update && apt ugrade -y aktualisiert node nicht von v8.x auf bspw. v10.x
                                    ioBroker auf NUC (VM debian v13 (Trixie ), node v24.22.2 npm v11.19.0, js-controller v7.2.5 jsonl/jsonl / HomeMatic CCU-2 (Wired und Funk) / Philips HUE / echo.DOT / Broadlink RM pro / SONOS
                                    J ostseereiterO 2 Antworten Letzte Antwort
                                    • BBTownB BBTown
                                      J
                                      J
                                      Jan1
                                      #517
                                      @BBTown
                                      Nicht ganz.
                                      Das wäre ein einfaches Systemupdate
                                      apt-get update && apt-get upgrade
                                      Das hat dann auch weniger mit Strech und Buster zu tun, da beide für sich noch gepflegt werden.
                                      Es wird auch nur innerhalb der Node Version ein Update geben, sprich 8.* wird danach auch 8.* bleiben und nicht auf 10.* upgedatet.
                                      BBTownB 1 Antwort Letzte Antwort
                                      • J Jan1
                                        @BBTown
                                        Nicht ganz.
                                        BBTownB
                                        BBTownB
                                        BBTown
                                        schrieb am zuletzt editiert von BBTown
                                        #518
                                        👆 darauf wollte ich hinaus.
                                        Während ja ein Upgrade von debian v9.x auf debian v10.x automatisch auch ein Erhöhung auf node v10.x beinhaltet.
                                        • BBTownB BBTown
                                          ostseereiterO
                                          ostseereiterO
                                          ostseereiter
                                          #519
                                          @BBTown sagte in js-controller 2.0 ab sofort im Latest Repo:
                                          Ich habe ein Debian 9 System kann man diesen Befehl gefahrlos machen oder wird Iobroker damit gegeben falls auch zerschossen. Ich lasse halt gerne nach einer Installation das System so wie es war aus Furcht das was nicht mehr funktioniert.
                                          Gruß OSR
                                          Plattform
                                          84.2k
