  4. JavaScript
  5. Hilfe bei Javaskript Device Counter
    1.5k
    1.5k
javascript
24 Beiträge 4 Kommentatoren 4.3k Aufrufe 1 Beobachtet
  • A Adnim
    Hi!
    der Cache Selektor zeile 11 "Error" funktioniert nicht mehr mit folgender Fehlermeldung. Das klappte aber immer so, jemand ne Idee was ich tun kann ?
    //Add device rules
    addDeviceCounter("lowbat",         $('channel[state.id=*LOWBAT]'),                     true);
    addDeviceCounter("lowbat",         $('channel[state.id=*lowbat]'),                      true);
    addDeviceCounter("sticky_unreach", $('channel[state.id=*.STICKY_UNREACH]'),              true);
    addDeviceCounter("unreach",        $('channel[state.id=*.UNREACH]'),                     true);
    addDeviceCounter("config_pending", $('channel[state.id=*.CONFIG_PENDING]'),              true);
    addDeviceCounter("Motion",  $('channel[state.id=*.MOTION]'),               true);
    addDeviceCounter("DutyCycle",  $('channel[state.id=*.DUTYCYCLE]'),               true);
    addDeviceCounter("Spannungsüberwachung",  $('channel[state.id=*.VOLTAGE]'),           function(state){return state<200;});
    addDeviceCounter("Auskühlschutz",  $('channel[state.id=*.ACTUAL_TEMPERATURE]'),           function(state){return state<14;});
    addDeviceCounter("ERROR",  $('channel[state.id=*.ERROR*]'),               function(state){return state>0;});
    addDeviceCounter("Heizbedarf",  $('channel[state.id=*.VALVE_STATE]'),           function(state){return state>15;});
    addDeviceCounter("Alive",         $('channel[state.id=*alive]'),                     false);
    addDeviceCounter("CONNECTED",         $('channel[state.id=*.connected]'),                     false);
    addDeviceCounter("open_shutters",  $('channel{TYPE=BLIND}[state.id=*.LEVEL]'),           function(state){return state>0;});
    addDeviceCounter("open_windows",   $('channel{TYPE=SHUTTER_CONTACT}[state.id=*.STATE]'), true);
     * Code - do not change anything bellow this line *
    function addDeviceCounter(name, selector, val_to_count) {
        //Total amount of devices found by selector
        var state_total = 'deviceCounter.' + name + '.total';
        createState(state_total, 0);
        //List of devices that match condition
        var state_list = 'deviceCounter.' + name + '.list';
        createState(state_list, "");
        //Number of devices that match condition
        var state_counter = 'deviceCounter.' + name + '.counter';
        createState(state_counter, 0);
        function countDevs(obj) {
            var d_count = 0;
            var d_list  = [];
            selector.each(function (id, i) {
                var status = getState(id).val;
                var obj    = getObject(id);
                if ((typeof val_to_count === 'function' && val_to_count(status)) ||
                    (typeof val_to_count === 'boolean'  && val_to_count == status)) {
                    //Get parent object
                    var parentChannelId = id.slice(id.lastIndexOf("."));
                    var parentDevicelId = id.split(".").slice(0,-2).join(".");
                    var deviceObject = getObject(parentDevicelId);
                    //remember device name
                    d_list.push(deviceObject.common.name);
                ++d_count;                                                 // Zählt die Anzahl der vorhandenen Geräte unabhängig vom Status
    //if ("state_counter" > 0) {event(name + "(" + d_count + "): " + d_list);
            setState(state_list,     d_list.join('<br>'));
            setState(state_counter,  d_list.length);
            setState(state_total,    d_count);
        //Re-evaluate when a device status changes
        selector.on(function(obj) {    // bei Zustandänderung *. LOWBAT in allen Gewerken
            countDevs(obj);
        //Re-evaluate each hour
        schedule("*/60 * * * *", countDevs);
        //Evaluate for the first time
        countDevs();
    javascript.0	2019-10-12 16:02:30.844	info	(13143) Stop script script.js.common.DeviceCounter
    javascript.0	2019-10-12 16:02:19.889	error	(13143) at Script.runInContext (vm.js:133:20)
    javascript.0	2019-10-12 16:02:19.889	error	(13143) at script.js.common.DeviceCounter:11:1
    javascript.0	2019-10-12 16:02:19.889	error	(13143) at addDeviceCounter (script.js.common.DeviceCounter:72:5)
    javascript.0	2019-10-12 16:02:19.889	error	(13143) at countDevs (script.js.common.DeviceCounter:40:18)
    javascript.0	2019-10-12 16:02:19.889	error	(13143) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:808:29)
    javascript.0	2019-10-12 16:02:19.889	error	(13143) at script.js.common.DeviceCounter:50:42
    javascript.0	2019-10-12 16:02:19.889	error	(13143) TypeError: Cannot read property 'common' of null
    javascript.0	2019-10-12 16:02:19.889	error	(13143) ^
    javascript.0	2019-10-12 16:02:19.889	error	(13143) d_list.push(deviceObject.common.name);
    javascript.0	2019-10-12 16:02:19.889	error	(13143) script.js.common.DeviceCounter: script.js.common.DeviceCounter:50
    javascript.0	2019-10-12 16:02:19.888	warn	(13143) Object "javascript.0.deviceCounter" does not exist
    paul53P
    paul53P
    @Adnim sagte:
    $('channel[state.id=.ERROR]')
    Was liefert ?
    $('channel[state.id=*.ERROR*]').each(function(id, i) {
       log(id);
    • A
      A
      Adnim
      @paul53 sagte in Hilfe bei Javaskript Device Counter:
      @Adnim sagte:
      Was liefert ?
      Da bekomm ich nen error, irgendwo fehlt eine klammer?
      @Glasfaser
      habe die objekte gelöscht sie werden angelegt ,dann stürzt das skript aber mit der Fehlermeldung ab, neustart hilft dann auch nicht
      Danke euch!
      • A Adnim
        @Adnim sagte:
        Was liefert ?
        @Glasfaser
        Danke euch!
        GlasfaserG
        GlasfaserG
        @Adnim
        … das Skript von paul53 in ein neues Skript starten !!!
        • GlasfaserG Glasfaser
          @Adnim
          A
          A
          Adnim
          @Glasfaser
          oh ok, habe ich versucht. Da kommt nix nur Start Skript im Log
          • A Adnim
            @Glasfaser
            GlasfaserG
            GlasfaserG
            @Adnim
            so muss es aussehen :
            • A
              A
              Adnim
              sieht bei mir aber so aus
              • A Adnim
                GlasfaserG
                GlasfaserG
                @Adnim
                Datenpunkte mit ERROR ,die bei mir z.B aufgelistet werden :
                • A
                  A
                  Adnim
                  ja habe ich auch ne ganze menge von den Errors States ,148 laut dem Skript er zählt sie ja beim ersten start
                  aber irgendwie findet er sie nicht mit Pauls Skript, habe Neustart und den Fixer aber gleiches Ergebnis
                  • A Adnim
                    GlasfaserG
                    GlasfaserG
                    @Adnim
                    Gib mal anstatt " ERROR" im Skript von paul53 ,"UNREACH" ein
                    Zeig mal bitte die ausgabe von
                    iobroker list adapters
                      @Adnim
                      A
                      A
                      Adnim
                      @Glasfaser sagte in Hilfe bei Javaskript Device Counter:
                      @Adnim
                      Ok habe UNREACH , ALIVE, CONNECTED nix führt zu einer ausgabe im LOG sieht immer so aus
                      Lenny.CBL 1 Antwort Letzte Antwort
                      • A Adnim
                        @Adnim
                        Lenny.CBL
                        Lenny.CBL
                        Lenny.CB
                        @Adnim du hast javascript 4.3.0, da klappts ja momentan nicht so mit den Logeinträgen.
                        Funktionieren soll (ungetestet)
                        log(id, 'info');
                        oder
                        Console.log(id);
                        Vielleicht läuft der Selector-codeschnipsel von paul, nur zeigt er nichts wegen des Logfehlers.
                        • Lenny.CBL Lenny.CB
                          log(id, 'info');
                          oder
                          Console.log(id);
                          A
                          A
                          Adnim
                          schrieb am zuletzt editiert von Adnim
                          @Lenny-CB sagte in Hilfe bei Javaskript Device Counter:
                          log(id, 'info');
                          das funzt korrekt, Danke dir Lenny
                          läuft deswegen auch das Haupt Skript nicht richtig?bzw das sind zwei Probleme glaube ich?
                          • A Adnim
                            log(id, 'info');
                            Lenny.CBL
                            Lenny.CBL
                            Lenny.CB
                            @Adnim, ich denke das wird noch eine andere Baustelle sein.
