  4. js-controller 2.0 ab sofort im Latest Repo
js-controller
1.1k Beiträge 89 Kommentatoren 475.8k Aufrufe 64 Beobachtet
  • MathiasJM
    MathiasJM
    MathiasJ
    schrieb am zuletzt editiert von MathiasJ
    BLE ist nicht erreichbar, Button ist rot.
    sudo pkill -f Adaptername
    durchgeführt, jedoch ohne Erfolg.
    Log im Debug:
    host.iobroker-slave	2019-10-12 09:48:40.150	info	Restart adapter system.adapter.ble.0 because enabled
    host.iobroker-slave	2019-10-12 09:48:40.150	error	instance system.adapter.ble.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    host.iobroker-slave	2019-10-12 09:48:40.149	error	Caught by controller[1]: at process._fatalException (internal/bootstrap/node.js:496:27)
    host.iobroker-slave	2019-10-12 09:48:40.149	error	Caught by controller[1]: at process.emit (events.js:203:15)
    host.iobroker-slave	2019-10-12 09:48:40.149	error	Caught by controller[1]: at process.on.err (/opt/iobroker/node_modules/iobroker.ble/build/main.js:391:21)
    host.iobroker-slave	2019-10-12 09:48:40.148	error	Caught by controller[1]: TypeError: Cannot read property 'error' of undefined
    host.iobroker-slave	2019-10-12 09:48:40.148	error	Caught by controller[1]: ^
    host.iobroker-slave	2019-10-12 09:48:40.148	error	Caught by controller[1]: adapter.log.error("unhandled exception:" + err.message);
    host.iobroker-slave	2019-10-12 09:48:40.147	error	Caught by controller[1]: /opt/iobroker/node_modules/iobroker.ble/build/main.js:391
    host.iobroker-slave	2019-10-12 09:48:40.147	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:69:34)
    host.iobroker-slave	2019-10-12 09:48:40.147	error	Caught by controller[0]: at emitPromiseRejectionWarnings (internal/process/promises.js:119:20)
    host.iobroker-slave	2019-10-12 09:48:40.146	error	Caught by controller[0]: at process.emit (events.js:198:13)
    host.iobroker-slave	2019-10-12 09:48:40.146	error	Caught by controller[0]: at process.on.r (/opt/iobroker/node_modules/iobroker.ble/build/main.js:386:21)
    host.iobroker-slave	2019-10-12 09:48:40.145	error	Caught by controller[0]: TypeError: Cannot read property 'error' of undefined
    Gruß,
    Mathias
    IObroker auf dem NUC als VM.
    apollon77A AlCalzoneA 3 Antworten Letzte Antwort
    • M mameier1234
      Moin,
      war ja klar, dass es nicht lange dauert, bis einer sein Multihost-system aktualisiert , ohne vorher die FAQ zu lesen....
      Bingo.. Ich habe meinen Windows Master zuerst aktualisiert und nun kommt der Slave nicht mehr drann..
      In der FAQ steht, dass ich einen Restore aus dem Ordner Backups machen soll (bei Biobroker Setup custom) Unter C:\iobroker\backups hab ich aber nur die Backups vom backitup-Adapter... (und den habe ich vor einiger Zeit deaktiviert, weil ein Testrestore nicht geklappt hatte)
      Unter c:\iobroker\iobroker-data gibt es backup-objects mit aktuellen Files... Hilft mir das ?
      Oder wie kann ich das noch retten ?
      apollon77A
      apollon77A
      @mameier1234 Naja das was Du hier referenzierst ist die Lösung für Migrationsprobleme zu redis/redis oder so.
      Dir hilft der FAQ Punkt #9 (gerade eingefügt ;) ) Aktualisiere die Slaves manuell mit npm Befehl aktualisieren.
      • MathiasJM MathiasJ
        Log im Debug:
        Gruß,
        Mathias
        apollon77A
        apollon77A
        @MathiasJ Bitte Adapter-Issue öffnen!
        PS: Und es läuft wirklich kein Prozess mehr?
        MathiasJM 1 Antwort Letzte Antwort
        • N
          N
          NightWatcher
          Mal eine allgemeine Frage:
          1.) Wieso darf ioBroker auf Windows Systemen, die mit dem Installer installiert wurden, eigentlich nicht mit npm aktualisiert werden?
          2.) Gilt das immer grundsätzlich beim aktualisieren von dem js.controller oder nur bei diesem umfangreichen update?
          3.) Wie lange wird man voraussichtlich noch auf den neuen installer warten müssen?
          Wago 750-881 - mit über 200 Ein- und Ausgängen, DMX512 Art-Net für Beleuchtung, 1-Wire für Umweltsensoren Aussen und Innen, ioBroker als Visualisierung
          apollon77A N 2 Antworten Letzte Antwort
          • D
            D
            darkiop
            @apollon77
            Ich habe zur Vorbereitung der Migration meines Produktiven System von file/file zu redis/redis eine Testumgebung aufgebaut. Kann das Verhalten aber gerade nicht einschätzen.
            # REDIS TEST
            ## ioBroker Test Instanz
            docker run -d \
            --name=iobroker-test-redis \
            --hostname=iobroker-test-redis \
            --env="LANG=de_DE.UTF-8" \
            --env="LANGUAGE=de_DE:de" \
            --env="LC_ALL=de_DE.UTF-8" \
            --env="TZ=Europe/Berlin" \
            --env="PACKAGES=powerline dnsutils vim byobu ranger htop cifs-utils net-tools html2text fping curl speedtest-cli unzip nmap toilet jq" \
            --env="AVAHI=false" \
            --volume="/volume2/docker-ssd/iobroker-test-redis/opt-iobroker:/opt/iobroker:rw" \
            --volume="/volume2/docker-ssd/iobroker-test-redis/root:/root:rw" \
            --network=mac0 \
            --ip=192.168.1.87 \
            --dns=192.168.1.43 \
            --restart=no \
            buanet/iobroker:beta
            ## Redis Test Instanz
            docker run -d \
            --name iobroker-test-redis-db \
            --network=mac0 \
            --ip=192.168.1.89 \
            --restart=no \
            redis:latest
            ## Redis Connection Test
            docker run -it --network mac0 --rm redis redis-cli -h iobroker-test-redis-db
            Verbindungs-Test zur Redis DB war positiv.
            Danach wurde der js-controller auf 2.0.25 gezogen.
            Dann via 'iobroker setup custom' auf redis umgestellt:
            ┬─[root@iobroker-test-redis:/opt/iobroker]─[10:02:44]
            ╰─># iobroker setup custom
            Current configuration:
            - Objects database:
              - Type: file
              - Host/Unix Socket: 127.0.0.1
              - Port: 9001
            - States database:
              - Type: file
              - Port: 9000
            - Data Directory: ../../iobroker-data/
            Type of objects DB [(f)ile, (r)edis], default [file]: r
            When Objects and Files are stored in a Redis database please consider the following:
            1. All data will be stored in RAM, make sure to have enough free RAM available!
            2. Make sure to check Redis persistence options to make sure a Redis problem will not cause data loss!
            3. The Redis persistence files can get big, make sure not to use an SD card to store them.
            Host / Unix Socket of objects DB(redis), default[127.0.0.1]: 192.168.1.89
            Port of objects DB(redis), default[6379]:
            Type of states DB [(f)file, (r)edis], default [redis]:
            Host / Unix Socket of states DB (redis), default[192.168.1.89]:
            Port of states DB (redis), default[6379]:
            Host name of this machine [iobroker-test-redis]:
            Please choose if this is a Master/single host (enter "m") or a Slave host (enter "s") you are about to edit. For Slave hosts the data migration will be skipped. [S/m]: m
            Important: Using Redis for the Objects database is only supported
            with js-controller 2.0 or higher!
            When your system consists of multiple hosts please make sure to have
            js-controller 2.0 or higher installed on ALL hosts *before* continuing!
            Important #2: If you already did the migration on an other host
            please *do not* migrate again! This can destroy your system!
            Important #3: The process will migrate all files that were officially
            uploaded into the ioBroker system. If you have manually copied files into
            iobroker-data/files/... into own directories then these files will NOT be
            migrated! Make sure all files are in adapter directories inside the files
            directory!
            Do you want to migrate objects and states from "file/file" to "redis/redis" [y/N]: y
            Migrating the objects database will overwrite all objects! Are you sure that this is not a slave host and you want to migrate the data? [y/N]: y
            Connecting to previous DB "file"...
            Creating backup ...
            This can take some time ... please be patient!
            host.iobroker-test-redis 361 states saved
            host.iobroker-test-redis 464 objects saved
            Backup created: /opt/iobroker/backups/2019_10_12-10_04_57_backupiobroker-migration.tar.gz
            updating conf/iobroker.json
            Connecting to new DB "redis" ...
             Cannot read system.config: null
            Restore backup ...
            iobroker controller daemon is not running
            host.iobroker-test-redis OK.
            host.iobroker-test-redis Clear all objects and states...
            clean 0 states...
            host.iobroker-test-redis done.
            host.iobroker-test-redis Processed 0/361 states
            host.iobroker-test-redis Processed 200/361 states
            361 states restored.
            host.iobroker-test-redis Processed 0/464 objects
            host.iobroker-test-redis Processed 200/464 objects
            host.iobroker-test-redis Processed 400/464 objects
            464 objects restored.
            upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
            upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
            upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
            upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
            upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
            upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
            upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
            upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
            upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
            upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
            upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
            upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/hostInfo.js lib/js/hostInfo.js application/javascript
            upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootstrap.min.js lib/js/bootstrap.min.js application/javascript
            upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/slackware.png lib/img/logos/slackware.png image/png
            upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/manjaro.png lib/img/logos/manjaro.png image/png
            upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/coreos.png lib/img/logos/coreos.png image/png
            upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/disk.png lib/img/icons/disk.png image/png
            upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/cpu.png lib/img/icons/cpu.png image/png
            upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/battery.png lib/img/icons/battery.png image/png
            upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/sechand.png lib/img/clock/sechand.png image/png
            upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/minhand.png lib/img/clock/minhand.png image/png
            upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
            upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
            upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff2 lib/fonts/fontawesome-webfont.woff2 font/woff2
            upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff lib/fonts/fontawesome-webfont.woff font/woff
            upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.ttf lib/fonts/fontawesome-webfont.ttf font/ttf
            upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
            upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.eot lib/fonts/fontawesome-webfont.eot application/vnd.ms-fontobject
            upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/FontAwesome.otf lib/fonts/FontAwesome.otf font/otf
            upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
            upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
            upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
            upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
            upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
            upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
            upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
            upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
            Backup restored!
            Important: If your system consists of multiple hosts please execute
            "iobroker upload all" on the master AFTER all other hosts/slaves have
            also been updated to this states/objects database configuration AND are
            running!
            ┬─[root@iobroker-test-redis:/opt/iobroker]─[10:06:04]
            ╰─># iobroker start
            Starting iobroker controller daemon...
            iobroker controller daemon started. PID: 5626
            ┬─[root@iobroker-test-redis:/opt/iobroker]─[10:06:12]
            ╰─># iobroker status
            At least one iobroker host is running.
            Objects type: redis
            States  type: redis
            Was mich hier verwirrt.
            Restore backup ...
            Ist das so OK?
            PS: Noch ein kleiner "Bug" am Rande:
            [S/m] --> Sollte [m/s] sein oder? :)
            ioBroker Object Explorer: https://forum.iobroker.net/topic/84117/iobroker-object-explorer-dashboard-zum-verwalten-von-dps?_=1789113045261 | Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
            • apollon77A apollon77
              MathiasJM
              MathiasJM
              MathiasJ
              @apollon77
              Da steht nur, dass @AlCalzone den Adapter überprüfen soll.
              Lösungsvorschläge gibt's da anscheinend noch nicht.
              Nein, Adapter ist komplett tot.
              • D darkiop
                @apollon77
                # REDIS TEST
                docker run -d \
                --network=mac0 \
                --ip=192.168.1.87 \
                --restart=no \
                docker run -d \
                --network=mac0 \
                --ip=192.168.1.89 \
                --restart=no \
                redis:latest
                - Objects database:
                  - Type: file
                  - Port: 9001
                - States database:
                  - Type: file
                  - Port: 9000
                directory!
                Creating backup ...
                Restore backup ...
                clean 0 states...
                Backup restored!
                running!
                ╰─># iobroker start
                Objects type: redis
                States  type: redis
                Restore backup ...
                Ist das so OK?
                apollon77A
                apollon77A
                @darkiop Wegen der Meldung schaue ich mal, aber die wäre bei einem "leeren" Redis normal (aber ja sollte nicht kommen) und es sieht alles ok aus.
                Zu deiner Text-Frage: "Gross" ist der Default geschrieben wenn Du nur Enter drücken würdest. bedeutet "Enter" = Slave = keine Migration
                  @apollon77
                  apollon77A
                  apollon77A
                  @MathiasJ ALso man könnte mal versuchen die "adapter.log..." zeilen in den beiden "process.on(..." Funktionen am Ende vom genannten File auszukommentieren. Aber ja @AlCalzone muss das ansehen
                    M
                    M
                    mameier1234
                    schrieb am zuletzt editiert von mameier1234
                    @apollon77 scheint doch nicht ganz so einfach zu sein... ...
                    pi@raspberrypi:/opt/iobroker $ sudo -u iobroker -H npm install iobroker.js-controller
                    > iobroker.js-controller@1.5.14 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                    > node lib/preinstallCheck.js
                    NPM version: 6.9.0
                    npm version >= 5: disabling package-lock
                    > iobroker.js-controller@1.5.14 install /opt/iobroker/node_modules/iobroker.js-controller
                    > node iobroker.js setup first
                    events.js:174
                          throw er; // Unhandled 'error' event
                    Error: listen EADDRNOTAVAIL: address not available 192.168.160.1:9001
                        at Server.setupListenHandle [as _listen2] (net.js:1262:19)
                        at listenInCluster (net.js:1327:12)
                        at doListen (net.js:1460:7)
                        at process._tickCallback (internal/process/next_tick.js:63:19)
                    Emitted 'error' event at:
                        at emitErrorNT (net.js:1306:8)
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                    npm ERR! code ELIFECYCLE
                    npm ERR! errno 1
                    npm ERR! iobroker.js-controller@1.5.14 install: `node iobroker.js setup first`
                    npm ERR! Exit status 1
                    npm ERR!
                    npm ERR! Failed at the iobroker.js-controller@1.5.14 install script.
                    npm ERR!     /home/iobroker/.npm/_logs/2019-10-12T10_38_19_954Z-debug.log
                    Grüße,
                    Martin
                    • M mameier1234
                      NPM version: 6.9.0
                      events.js:174
                      npm ERR! errno 1
                      npm ERR!
                      apollon77A
                      apollon77A
                      @mameier1234 whhhaatttt?! Nimm mal iobroker.js-controller@2.0.25 zum installieren.
                        Hallo ioBroker-Community,
                        passend zum Erreichen der 30.000 aktive Installationen Marke vor ein paar Tagen möchten wir Euch nun gern den neuen js-controller 2.0 vorstellen. Dieser ist ab sofort im Latest Repository und auf npm verfügbar.
                        In einem internen Test und einen sehr umfangreichen Beta-Test in der Community haben wir dieses große Update des js-controllers bereits sehr intensiv getestet. Großer Dank geht an @Arteck, @sigi234, @SBorg, @opossum, @e-s, @e-i-k-e, @Yetiberg, @Jan1, @Einstein67, @Dr. Bakterius und viele andere mehr. Das war eine super Zusammenarbeit!
                        Es sind vor allem "unter der Haube" einige grundlegende Änderungen eingeflossen, die den Wechsel auf eine neue Hauptrelease-Nummer rechtfertigen. Mehr dazu weiter unten.
                        Der js-controller 2.0 ist generell kompatibel mit allen bestehenden ioBroker-Systemen. Es kann von jeder früheren Version auf die Version 2.0 aktualisiert werden. Einzig die Node.js Version muss vor dem Update mindestens auf 8.x, besser noch auf 10.x angehoben werden! Für Node.js 12 ist es aber noch etwas zu früh, da hier immer noch einige Adapter nicht kompatibel sind.
                        Falls Ihr in diesem Zuge die Nodejs Version aktualisiert bitte Die Infos/Anleitung unter https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten berücksichtigen.
                        Weiterhin wird der ioBroke-Eigene-Dateibereich (im Normalfall bisher unter <ioBroker-Verzeichnis>/iobroker-data/files/...) nun strikter behandelt und manuell oder per Skript (fs.write) dort direkt abgelegte/hinkopierte Dateien sind ggf. nicht mehr in Visualisierungen anzeigbar!
                        Skripte müssen angepasst werden (Nutzung von writeFile) bzw. die Dateien müssen in offiziell definierte Adpater-Basisverzeichnisse (z.B. vis.0, iqontrol.meta u.ä.) abgelegt werden. Nutzt am besten auch die offiziellen Uploader via Vis oder iqontrol, damit diese Dateien korrekt registriert sind. Diese Änderung wurde auch zur Erhöhung der Sicherheit umgesetzt! Der positive Nebeneffekt ist auch das die Files dann mit im Backup landen, was bisher nicht gegeben war!
                        Bei der Installation (oder nachträglich per iobroker file sync) werden die erlaubten Verzeichnisse geprüft und bisher nicht registrierte Dateien aufgenommen. Wer komplett eigene Verzeichnisse angelegt hat bekommt dazu eine Fehlermelung - diese werden nicht automatisch übernommen und müssen manuell korrekt kopiert werden.Siehe dazu auch die Informationen zum Ordner 0_userdata.0!
                        Installation
                        VOR der Installation
                        Wie bei jedem Update dieser Art: Bitte macht ein Backup! iobroker backup, bzw. kopieren des iobroker-data Verzeichnisses reichen an sich im Zweifel auch aus (ioBroker vorher stoppen natürlich). Bitte nicht das node_modules Verzeichnis einfach kopieren, da sonst symbolische Links kaputt gehen können, was zu größeren Problemen danach führt.
                        Nötige Adapter-Aktualisierungen
                        Die folgenden Adapter müssen auf die genannten Minimalversionsnummern aktualisiert werden, da diese sonst nicht mit dem js-controller 2.0 funktionieren. Diese Updates am besten vorher ausführen, weil alle genannten Versionen auch mit den alten js-controller Versionen funktionieren.
                        • simple-api 2.1.2 or higher
                        • email 1.0.5 or higher
                        • pushover 1.1.1 or higher
                        • hue 1.2.4 or higher
                        • node-red 1.10.1 or higher
                        • vis 1.2.2 or higher
                        • iqontrol 0.2.12 or higher
                        • socketio 2.1.2 or higher
                        • radar2 1.0.9 (GitHub version 1.2.0 muss manuell angepasst werden, siehe FAQ!)
                        • broadlink2 (siehe FAQ)
                        • tr-064 (wenn noch soef Originalversion bei Fehlern community Version installieren)
                        • sonos 2.0.0 or higher (Breaking change! No Webserver anymore!)
                        • web 2.4.9 or higher
                        • hqwidgets 1.1.3 or higher
                        • ble v0.10.1 or higher
                        Achtung: Slave-Systeme zuerst!
                        Bei einem Multi-Host-System ist es beim Update auf Version 2.0 sehr wichtig, die Slave-Systeme zuerst zu aktualisieren. Der Master wird als letztes aktualisiert!
                        Wenn diese Reihenfolge nicht eingehalten wird können sich die Slave-Systeme nicht mit dem master verbinden und das Update muss manuell ausgeführt werden (Details dazu siehe FAQ Post).
                        Windows
                        Auf Systemen, die mit dem neuen Windows Installer eingerichtet wurden, darf der js-controller nicht mir npm aktualisiert werden. Es wird eine neue Version des Windows Installers geben, die das Update des js-controllers mit wenigen Mausklicks ermöglicht. Wir updaten dazu hier im Thread.
                        Für alle "alten manuellen" Installationen gilt
                        • ioBroker muss gestoppt sein.
                        • Vor dem Update bitte prüfen das keine Prozesse mehr laufen
                        • iobroker upgrade self
                        • ioBroker starten
                        Linux
                        • ioBroker stoppen (iobroker stop)
                        • prüfen das keine Prozesse (Adapter, Backups) mehr laufen (ps auxww|grep io und auch ps auxww|grep backup ). Es passiert manchmal das trotz dem Stoppen noch Zombies zurückbleiben
                        • Wie üblich wird das Update dann per iobroker upgrade self ausgeführt.
                        • ioBroker starten (iobroker start)
                        Bei Fehlern:
                        Wenn bei der Linux-Installation Fehler wegen fehlender Zugriffsrechte auftreten, am besten den Installation-Fixer nutzen und die Installation wiederholen.
                        curl -sL https://iobroker.net/fix.sh | bash -
                        Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels sudo -H -u iobroker npm install iobroker.js-controller versuchen. Bitte berichtet solche Fälle hier im Thread.
                        NACH der Installation
                        Nach der Installation den ioBroker wieder starten (z.B. mittels iobroker start).
                        Wenn alles klappt merkt Ihr ausser der höheren Versionsnummer in der Host-Ansicht im Admin keinen Unterschied. Alles funktioniert weiterhin wie vorher. Alle Adapterinstanzen starten und funktionieren. Wenn das so ist hat alles geklappt. Die großen Änderungen sind alle "Unter der Haube" versteckt.
                        Dazu, was Euch jetzt die ganzen Neuerungen bringen, findet Ihr weiter unten in diesem Text Informationen. Neue Funktionen als Basis für Weiterentwicklungen wurden behutsam integriert und einige bestehende Probleme gezielt behoben.
                        Mit iobroker help wird eine Liste der möglichen Kommandozeilen-Kommandos angezeigt, die mit Version 2.0 um einige Befehle länger geworden ist.
                        Was hat sich geändert, was besonders ansehen/beachten?
                        Eine der größeren Änderungen ist, dass die ioBroker-eigenen States- und Objects-Datenbanken vollständig neu geschrieben wurden. Im ioBroker-System wird zur Kommunikation jetzt ein TCP-basiertes und mit Redis-kompatibles Protokoll verwendet. Vor allem "Reconnection from DB"-Fehler sollten dadurch jetzt der Vergangenheit angehören. Auf Basis dieser Änderungen planen wir für die Zukunft noch einige interessante Neuerungen.
                        Durch diese Änderung steht jetzt in Logs teilweise "connected to redis" obwohl Ihr gar keinen Redis nutzt. Ihr könnt allerdings weiterhin am Port erkennen wenn es die ioBroker-eigene Datenbank ist (normalerweise Ports 9000 und 9001). Erste Tests haben gezeigt das die CPU Belastung der Adapter-Prozesse und des js-controller geringer ist als in der alten Version, da das neue Protokoll deutlich schlanker ist. Es ist weiterhin flexibler und robuster - so lange die Netzwerkverbindung nicht abreißt. Aber selbst in solch einem Fall sollte ein automatischer Reconnect stattfinden und, wenn der Abbruch nich zu lang ist, alle Änderungen aus der Zeit ohne Verbindungen nochmals gesendet werden.
                        Also falls Ihr in der Vergangenheit von "Reconnect to DB" Meldungen und Effekten geplagt wart ist Euer Bericht für uns sehr interessannt.
                        In diesem Zuge ist vor allem das Verhalten bei einer Unterbrechung der Verbindung zur Datenbank (egal ob Redis oder im "file" Falle der js-controller). Beim Verlust der Verbindung wird diese per Default in 5s Abständen bis zu 20 mal versucht wiederherzustellen. Wenn dies gelingt, bleibt das ganze System in Betrieb und in der Unterbrechungszeit aufgelaufene Befehle werden nachträglich ausgeführt. Bei Redis könnte diese Zeit sogar für ein Redis-Update ausreichen.
                        Erst danach (also nach ca. 90s) beenden sich Adapter und das System und ein automatischer Restart findet statt, wonach der js-controller wartet bis die Verbindung wieder da ist. Um ggf Netzwerk-Effekte abzufangen gibt es alle 30s einen Restart des Controllers.
                        Ebenso der berühmt berüchtigte "Error 7", welcher im Log erscheint wenn ein Adapterprozess bereits läuft, aber ein neuer gestartet werden soll wurde verbessert. Wenn ein neuer Prozess gestartet werden soll, sollten sich nun ggf noch laufende Prozesse automatisch selbst beenden und eine einmalige Meldung im Log erzeugen.
                        Wie bereits gesagt, viele Änderungen fanden hinter den Kulissen statt. Hier für Interessierte als Spoiler eine Zusammenfassung:
                        2.0 - Release Bella
                        Breaking changes
                        • Minimum requirement for js-controller 2.0 is node.js 8.x
                        • Files in iobroker-data/files are only supported in officially registered directories AND when uploaded using ioBroker tools
                        New user features
                        •   Introduced 0_userdata as home for user specific files, objects and states
                        • Add Compact Mode and compact groups (Technology Preview)
                        • Add build-in Alias handling for Objects/States (Technology Preview)
                        • Add support to also use Redis for Objects and Files
                        • Add Redis sentinel support
                        • Allow dynamic change of Loglevel for adapter instance and js-controller hosts processes
                        • Add optional migration for State and/or Objects values when using setup custom
                        • Add monitoring for event-Loop-Lag as host and adapter objects
                        • Add possibility to validate backup files
                        • Support command „iobroker logs“
                        • Support command „cert create“
                        • Remember installation location for reinstallations
                        • Use Remembered installation location for automatic adapter installs
                        • Log Process-ID for all adapter log messages
                        • Enhance some CLI commands like iobroker status
                        • Arrays are now allowed as state values and working without "JSON.stringify"
                        New adapter developer features
                        • streamline redis vs file States handling which was different also before controller 2.0:
                          • not set states will always return null now
                          • States will set to null completely (not only value) when they expire
                          • States will also be published to onChanged handlers when states are in Redis
                        • Add adapter.supportsFeature('NAME') method to check if a certain feature exists. #244
                        • Ability to define secured objects in io-pack access only via own adapter and admin. #287
                        • Added getObjectView and getObjectViewAsync on adapter object
                        • Added getObjectList and getObjectListAsync on adapter object
                        • Allow the deletion of multiple objects with wildcard
                        • setObject/setObjectNotExists now also sets default value of state after object creation
                        • Allow getPort to check for the port optionally on a certain host/IP
                        Further changes
                        • Rewrite InMem databases (States & Objects) to TCP (redis compatible) protocol and deprecate socket.io version; will be removed approx. in v2.1
                        • Add adapter handling to prevent "error 7" (adapters will stop themself as soon as PID is not as expected)
                        • Upgrade all dependencies
                        • Don't chmod 777 after controller upgrade
                        • Refactoring of many CLI commands
                        • Add possibility to return zip file as a link and not as base64
                        • Standardize error codes
                        • Root should always npm install with --unsafe-perm
                        • Enable gzip to read repositories
                        • Read hash of sources.json online before downloading the whole file
                        • Add some information about user-agent
                        • Verify the version of node.js by start of the instance
                        • Hide cmd window on windows
                        • Include certificate creation in setup first
                        • Suppress warning by npm install
                        • Allow optional dependencies being installed
                        • Optimize setup custom command and add more user guidance
                        • Add Feature overview to README
                        • Forward upload console outputs from slave to master
                        • Make sure to upload and upgrade all relevant objects on installations and updates of adapters
                        • Always upgrade instance objects after successful installs or upgrades
                        • Optimize adapter start processes, especially when combined with needed automatic installations of adapters
                        • After 2 installation tries with "last-installedFrom" use the installedVersion field to try to install from npm
                        • Hhosts now ignore object changes when the affected instances is still in installQueue
                        • Code refactoring and optimizations in various places
                        • Randomize Certificate Serial numbers
                        • delay parallel start of scheduled instances to prevent system overload scenarios (same rules asd for adapterstart, basically 4s delay)
                        • streamline reconnection handling and make more flexible (reconnedt delay to 5s with approx 20 tries) before shutting down the system
                        • iobroker upgrade all aktualisiert nicht mehr den Controller mit
                        Bugfixes
                        • Log scheduled restarts as info only (fixes #315)
                        • Fixed #340 to maintain restartSchedule on updates
                        • Fixed a bug where it was possible to set "ack" to any value via cli
                        • Enable ESLint and fix most issues
                        • Optimize multi host upload
                        • Restart stopped adapters at the end of the upload and not before to make sure to not have two adapter restarts on upgrade cases
                        • Enhance checks for failed installations in cli and controller
                        • Also update adapter instance statistic objects when no instanceObejcts are defined
                        • ".alive" state values are only checked on adapter start if ack=true to allow to start a process if not running
                        • Fix for mutlihost detection
                        • Fix backup of states
                        • Make sure also VIS global CSS is included in backup and restored
                        • Many more fixes in various places
                        Weitere Details zu den Änderungen und Bugfixes ist im Changelog einzusehen.
                        Im dritten Post dieses Threads stellen wir einige neue Features im Detail etwas "weniger technisch" vor. ;-)
                        Wie Fehler melden?
                        Wer sich unsicher ist, ob ein Fehler vorliegt, sollte am besten hier im Thread das Problem beschreiben. So können wir alle versuchen, das Problem nachzuvollziehen und ggf. einzugrenzen.
                        Sobald ein Fehler auftritt der in einer Fehlermeldung oder einen Crash mit Fehlerdetails im Log oder auf Kommandozeile endet, dann dazu am besten direkt ein GitHub-Issue im js-controller Projekt öffnen und zusätzlich hier im Thread posten. Je detaillierter die Angaben im Issue sind (genaue Fehlermeldungen/Logs, Info zur verwendeten DB-Konstellation (file(file, file/redis, redis/redis ...), Infos zur OS- und Node.js-Umgebung sowie genaue Schritte zur Reproduktion des Problems), umso schneller können wir Fehler einkreisen und beheben.
                        Ingo
                        crunchipC
                        crunchipC
                        Developer Global Moderator Most Active Forum Testing
                        @apollon77 sagte in js-controller 2.0 ab sofort im Latest Repo:
                        heisst das, ich brauch minimal diese Versionen oder ich muss all diese zurückspielen auf die genannten?
                        da mein System mit sämtlichen Adaptern auf dem neusten Stand läuft.
                          apollon77A
                          apollon77A
                          @crunchip Das steht doch genau da ... Beispiel
                          Also 2.1.2 is MINIMAL Version ... "or higher" bedeutet das aktuelle Versionen natürlich auch gehen.
                          Was ist jetzt genau die Frage? ;-)
                            crunchipC
                            crunchipC
                            @apollon77 das war genau die Frage😁
                            hab das irgendwie falsch verstanden,
                            alles ok,
                            dann werde ich mal den Versuch wagen und hoffen das anschliessend auch alles wie gewünscht weiter läuft.
                            Proxmox Backup und Snapshot sind erstellt, sicher ist sicher😁
                            • ChaotC
                              ChaotC
                              Chaot
                              Das ich nicht mehr an selbst angelegte Verzeichnisse komme habe ich gelesen.
                              Aber scheinbar mache ich irgendwas falsch bei der Umsetzung der Befehle.
                              Original:
                              exec('wget --output-document /opt/iobroker/iobroker-data/files/tuer/tuer/alarm1.jpg \'http://192.168.8.95:8765/picture/1/current/?_username=admin&_signature=ba8317b8fc071dadb725d4d0d9dbf7e606acbf1e\'');
                              will ich ändern in:
                              exec('wget --output-document /opt/iobroker/iobroker-data/files/vis.0/tuer/tuer/alarm1.jpg \'http://192.168.8.95:8765/picture/1/current/?_username=admin&_signature=ba8317b8fc071dadb725d4d0d9dbf7e606acbf1e\'');
                              Scheinbar der falsche Befehl oder warum klappt das nicht mehr?
                              • crunchipC
                                crunchipC
                                ist alles sauber durchgelaufen.
                                was nun auf die schnelle aufgefallen ist:
                                Punkt1
                                radar2.0	2019-10-12 14:04:21.300	warn	(26795) No geo location data found configured in admin to calculate UWZ AREA ID or ID not valid!
                                ist aber hinterlegt!!
                                Punkt2
                                virtualpowermeter info wird im log permanent angezeigt, obwohl es auf "error" steht
                                lad ich das log herunter, ist davon jedoch nichts zu sehen.
                                  M
                                  M
                                  mameier1234
                                  @apollon77 ja.. so läuft das besser :-)
                                  Sollte der FAQ-Artikel überarbeitet werden ?
                                  for my problem: solved !
                                  Grüße,
                                  Martin
                                  • ChaotC Chaot
                                    Original:
                                    will ich ändern in:
                                    SBorgS
                                    SBorgS
                                    SBorg
                                    @Chaot sagte in js-controller 2.0 ab sofort im Latest Repo:
                                    Ev. mit falschen Rechten angelegt? "tuer" muss dem User iobroker gehören bzw. Schreibrechte darin haben.
                                    LG SBorg ( SBorg auf GitHub)
                                    • SBorgS SBorg
                                      ChaotC
                                      ChaotC
                                      Chaot
                                      schrieb am zuletzt editiert von Chaot
                                      @SBorg
                                      Es scheint doch zu klappen.
                                      Die Mail mit den Bildern bekomme ich wenn ich das Verzeichnis so angebe.
                                      Aber in VIS kann ich die Bilder nicht sehen.
                                      Ich werde mir mal die Rechte anschauen. Danke für den Tip.
                                      Edit: Rechte scheinen zu stimmen.
                                      Die Bilder sind im Verzeichnis. Aber mit VIS lassen sie sich nicht abrufen.
                                        Punkt1
                                        Punkt2
                                        apollon77A
                                        apollon77A
                                        @crunchip Radar2 version aktualisiert bzw manuell gefixt? Siehe erster Post??
                                        Logging das „zu viel“ im Admin log tab angezeigt wird ist known. Logfile auf Platte steht es nicht drin.
                                        • ChaotC Chaot
                                          @SBorg
                                          apollon77A
                                          apollon77A
                                          @Chaot ja weil das unkontrollierte reinkopieren halt nicht mehr geht. Files in den iobroker storage müssen über die Funktionen reinkommen.
                                          Also anlegen und per writeFile oder kommandozeile iobroker Befehle uploaded.
                                          83.8k
