  4. Test Adapter zoneminder v0.3.x
zonemindermotioncamera
206 Beiträge 23 Kommentatoren 45.4k Aufrufe 26 Beobachtet
  • D djsirius
    @Meistertr
    zoneminder.0	2019-10-06 22:36:47.181	warn	No monitors found, please configure monitors in your zoneminder!
    zoneminder.0	2019-10-06 22:36:47.180	debug	reposerrStatusCodeError: 401 - "{\"success\":false,\"data\":{\"name\":\"Not Authenticated\",\"message\":\"Not Authenticated\",\"url\":\"\\/zm\\/api\\/monitors.json\",\"exception\":{\"class\":\"Unautho
    zoneminder.0	2019-10-06 22:36:47.172	debug	REQUEST: Options {"method":"GET","uri":"http://192.168.1.16/zm/api/monitors.json","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":true}
    zoneminder.0	2019-10-06 22:36:47.171	debug	SetStates
    zoneminder.0	2019-10-06 22:36:42.177	warn	No monitors found, please configure monitors in your zoneminder!
    zoneminder.0	2019-10-06 22:36:42.177	debug	reposerrStatusCodeError: 401 - "{\"success\":false,\"data\":{\"name\":\"Not Authenticated\",\"message\":\"Not Authenticated\",\"url\":\"\\/zm\\/api\\/monitors.json\",\"exception\":{\"class\":\"Unautho
    zoneminder.0	2019-10-06 22:36:42.167	debug	REQUEST: Options {"method":"GET","uri":"http://192.168.1.16/zm/api/monitors.json","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":true}
    zoneminder.0	2019-10-06 22:36:42.166	debug	SetStates
    zoneminder.0	2019-10-06 22:36:37.186	warn	No monitors found, please configure monitors in your zoneminder!
    zoneminder.0	2019-10-06 22:36:37.185	debug	reposerrStatusCodeError: 401 - "{\"success\":false,\"data\":{\"name\":\"Not Authenticated\",\"message\":\"Not Authenticated\",\"url\":\"\\/zm\\/api\\/monitors.json\",\"exception\":{\"class\":\"Unautho
    zoneminder.0	2019-10-06 22:36:37.167	debug	REQUEST: Options {"method":"GET","uri":"http://192.168.1.16/zm/api/monitors.json","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":true}
    zoneminder.0	2019-10-06 22:36:37.167	debug	SetStates
    zoneminder.0	2019-10-06 22:36:32.179	warn	No monitors found, please configure monitors in your zoneminder!
    zoneminder.0	2019-10-06 22:36:32.179	debug	reposerrStatusCodeError: 401 - "{\"success\":false,\"data\":{\"name\":\"Not Authenticated\",\"message\":\"Not Authenticated\",\"url\":\"\\/zm\\/api\\/monitors.json\",\"exception\":{\"class\":\"Unauth
    zoneminder.0	2019-10-06 22:36:32.163	debug	REQUEST: Options {"method":"GET","uri":"http://192.168.1.16/zm/api/monitors.json","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":true}
    zoneminder.0	2019-10-06 22:36:32.162	debug	SetStates
    zoneminder.0	2019-10-06 22:36:27.242	info	check user admin pw ioboker: false
    zoneminder.0	2019-10-06 22:36:27.188	info	check group user admin group admin: false
    zoneminder.0	2019-10-06 22:36:27.182	debug	reposerrStatusCodeError: 401 - "\n{\"success\":false,\"data\":{\"name\":\"User not found\",\"message\":\"User not found\",\"url\":\"\\/zm\\/api\\/host\\/login.json\",\"exception\":{\"class\":\"Unauth
    zoneminder.0	2019-10-06 22:36:27.154	debug	REQUEST: Options {"method":"POST","uri":"http://192.168.1.16/zm/api/host/login.json","body":"user=admin&pass=admin","headers":{"content-type":"application/x-www-form-urlencoded","content-length":21,"
    zoneminder.0	2019-10-06 22:36:27.153	debug	data: {"user":"admin","password":"admin","host":"http://192.168.1.16/zm"}
    zoneminder.0	2019-10-06 22:36:27.143	info	starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.zoneminder, node: v10.16.0
    zoneminder.0	2019-10-06 22:36:27.128	debug	statesDB connected
    zoneminder.0	2019-10-06 22:36:27.117	debug	objectDB connected
    host.debian	2019-10-06 22:36:26.717	info	instance system.adapter.zoneminder.0 started with pid 8577
    host.debian	2019-10-06 22:36:26.709	info	"system.adapter.zoneminder.0" enabled
    MeistertrM Offline
    MeistertrM Offline
    Meistertr
    @djsirius zoneminder antwortet dass er admin mit pw admin nicht kennt ...
    D M 2 Antworten Letzte Antwort
    • MeistertrM Meistertr
      djsirius
      @Meistertr moin. Tja und nun? Das sind genau die User und Passwort, die ich vergeben hab. Und damit kann ich mich auf der Konsole von Zoneminder ja auch anmelden.
      Ich habe auch schon mehrere unterschiedliche User mit unterschiedlichen Passwörtern angelegt und er bringt immer diese Meldung, dass er User und Passwort nicht kennt.
      Dann ist doch der Adapter kaputt!!!???
      djsirius
      • D djsirius
        djsirius
        Hallo.
        Sooooo, das Problem ist beseitigt!
        In den Einstallungen hatte ich bei OPT_USE_AUTH Authenticate user logins to ZoneMinder (?) einen Haken drin. Haken raus, Zoneminder neustart, der Adapter verbindet sich!!!
        djsirius
        MeistertrM 1 Antwort Letzte Antwort
        • D djsirius
          Hallo.
          MeistertrM Offline
          MeistertrM Offline
          Meistertr
          @djsirius das ist aber nur ein wurkaround und nicht die Lösung, zeig mal ein Screenshot deiner Config. Eigentlich sollte es mit Admin Admin gehen müssen...
            djsirius
            djsirius
              mikiline
              @Meistertr
              Das mit den Events (Motion) lässt sich mit dem zmeventmanager lösen. Diesen habe ich nun installiert und mir die App "zmninja" gezogen. Läuft alles wunderbar.
              Im Eventmanager ist auch ein MQTT Server/Client mit dabei, mit dem Du dann sicher auch etwas im Adapter verwenden kannst ;)
                djsirius
                Könnt ihr mal bitte mit http://server/zm/api/host/getVersion.json schauen, welche Version ihr von zoneminder installiert habt?
                Ich habe folgende Version installiert:
                {"version":"1.30.4","apiversion":"1.0"}
                Vielleicht liegt es daran, weil auf der Homepage steht:
                Login process for ZoneMinder v1.32.0 and above:
                curl -XPOST -d "user=XXXX&pass=YYYY" -c cookies.txt  http://yourzmip/zm/api/host/login.json
                Login process for older versions of ZoneMinder:
                curl -d "username=XXXX&password=YYYY&action=login&view=console" -c cookies.txt  http://yourzmip/zm/index.php
                djsirius
                coyoteC M D 3 Antworten Letzte Antwort
                • D djsirius
                  coyoteC Offline
                  coyoteC Offline
                  coyote
                  @djsirius sagte in [Aufruf] Zoneminder 0.2.0 Testen:
                  Ich habe die 1.32.3
                  • D djsirius
                    mikiline
                    schrieb am zuletzt editiert von mikiline
                    "version":"1.33.14","apiversion":"2.0"}
                    • M mikiline
                      @Meistertr
                      MeistertrM Offline
                      MeistertrM Offline
                      Meistertr
                      @mikiline sagte in [Aufruf] Zoneminder 0.2.0 Testen:
                      zmeventmanager
                      das war auch mein plan... konnte ihn aber noch nciht umsetzen
                        djsirius
                        Wie bekomme ich denn meine Zoneminder Version geupdatet?
                        djsirius
                        • D djsirius
                          MeistertrM Offline
                          MeistertrM Offline
                          Meistertr
                          schrieb am zuletzt editiert von Meistertr
                          @djsirius
                          add-apt-repository ppa:iconnor/zoneminder-1.32
                            @djsirius
                            djsirius
                            @Meistertr said in [Aufruf] Zoneminder 0.2.0 Testen:
                            Das funktioniert nicht.
                            Ich habe debian 9 installiert.
                            djsirius
                            XsevX 1 Antwort Letzte Antwort
                            • D djsirius
                              XsevX Offline
                              XsevX Offline
                              Xsev
                              @djsirius
                              schau mal hier da ist eigentlich alles beschrieben für die Installation von 1.32.2 auf Debian 9.
                              • D djsirius
                                djsirius
                                #66
                                @djsirius said in [Aufruf] Zoneminder 0.2.0 Testen:
                                @Meistertr könnte es daran liegen, dass mein Zoneminder-Adapter sich nicht mit Zoneminder verbinden kann?
                                djsirius
                                • D djsirius
                                  MeistertrM Offline
                                  MeistertrM Offline
                                  Meistertr
                                  #67
                                  @djsirius jep daran wird es liegen.
                                    djsirius
                                    #68
                                    Ok. :-(
                                    Dann kann ich kein Zoneminder benutzen, weil ich meine Version nicht geupdatet bekomme.
                                    Die Vorgehensweise aus dem Link den @Xsev freundlicherweise gepostet hat , bekomme ich immer eine Fehlermeldung.
                                    Ich kenne mich mit der ganzen Sache auch zu wenig aus. :-(
                                    Oder könntest du den Adapter updaten, damit man den Adapter auch mit der Version 1.30.4 benutzen kann?
                                    djsirius
                                      mikiline
                                      #69
                                      Hatte vorher auch ne kleinere Version drauf und einfach das PPA genommen ohne Versionsnummer und dann ein dist-upgrade ausgeführt
                                      vorher sollte man zoneminder stoppen, hat bei mir jedoch (weil vergessen) auch ohne funktioniert. Falls Du alles in einer VM am Laufen hast (was ich mit z.B. Proxmox wärmstens empfehlen kann), kannst ja mal nen Backup machen und versuchen....
                                        mikiline
                                        #70
                                        so....MQTT läuft nun auch und Events von Zoneminder erscheinen im MQTT Adapter zur weiteren Verarbeitung
                                        • M mikiline
                                          MeistertrM Offline
                                          MeistertrM Offline
                                          Meistertr
                                          #71
                                          @mikiline das hab ich gestern auch vergeblich versucht...
