  4. Test Adapter zoneminder v0.3.x
zonemindermotioncamera
206 Beiträge 23 Kommentatoren 45.4k Aufrufe 26 Beobachtet
  • MeistertrM Meistertr
    @djsirius hier wird erklärt wie man einen adapter auf debug umstellt:
    https://www.youtube.com/watch?v=-1PCHancttc&t=143s
    mir reicht ein auszug aus den ersten minuten
    djsirius
    @Meistertr
    zoneminder.0	2019-10-06 22:36:47.181	warn	No monitors found, please configure monitors in your zoneminder!
    zoneminder.0	2019-10-06 22:36:47.180	debug	reposerrStatusCodeError: 401 - "{\"success\":false,\"data\":{\"name\":\"Not Authenticated\",\"message\":\"Not Authenticated\",\"url\":\"\\/zm\\/api\\/monitors.json\",\"exception\":{\"class\":\"Unautho
    zoneminder.0	2019-10-06 22:36:47.172	debug	REQUEST: Options {"method":"GET","uri":"http://192.168.1.16/zm/api/monitors.json","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":true}
    zoneminder.0	2019-10-06 22:36:47.171	debug	SetStates
    zoneminder.0	2019-10-06 22:36:42.177	warn	No monitors found, please configure monitors in your zoneminder!
    zoneminder.0	2019-10-06 22:36:42.177	debug	reposerrStatusCodeError: 401 - "{\"success\":false,\"data\":{\"name\":\"Not Authenticated\",\"message\":\"Not Authenticated\",\"url\":\"\\/zm\\/api\\/monitors.json\",\"exception\":{\"class\":\"Unautho
    zoneminder.0	2019-10-06 22:36:42.167	debug	REQUEST: Options {"method":"GET","uri":"http://192.168.1.16/zm/api/monitors.json","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":true}
    zoneminder.0	2019-10-06 22:36:42.166	debug	SetStates
    zoneminder.0	2019-10-06 22:36:37.186	warn	No monitors found, please configure monitors in your zoneminder!
    zoneminder.0	2019-10-06 22:36:37.185	debug	reposerrStatusCodeError: 401 - "{\"success\":false,\"data\":{\"name\":\"Not Authenticated\",\"message\":\"Not Authenticated\",\"url\":\"\\/zm\\/api\\/monitors.json\",\"exception\":{\"class\":\"Unautho
    zoneminder.0	2019-10-06 22:36:37.167	debug	REQUEST: Options {"method":"GET","uri":"http://192.168.1.16/zm/api/monitors.json","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":true}
    zoneminder.0	2019-10-06 22:36:37.167	debug	SetStates
    zoneminder.0	2019-10-06 22:36:32.179	warn	No monitors found, please configure monitors in your zoneminder!
    zoneminder.0	2019-10-06 22:36:32.179	debug	reposerrStatusCodeError: 401 - "{\"success\":false,\"data\":{\"name\":\"Not Authenticated\",\"message\":\"Not Authenticated\",\"url\":\"\\/zm\\/api\\/monitors.json\",\"exception\":{\"class\":\"Unauth
    zoneminder.0	2019-10-06 22:36:32.163	debug	REQUEST: Options {"method":"GET","uri":"http://192.168.1.16/zm/api/monitors.json","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":true}
    zoneminder.0	2019-10-06 22:36:32.162	debug	SetStates
    zoneminder.0	2019-10-06 22:36:27.242	info	check user admin pw ioboker: false
    zoneminder.0	2019-10-06 22:36:27.188	info	check group user admin group admin: false
    zoneminder.0	2019-10-06 22:36:27.182	debug	reposerrStatusCodeError: 401 - "\n{\"success\":false,\"data\":{\"name\":\"User not found\",\"message\":\"User not found\",\"url\":\"\\/zm\\/api\\/host\\/login.json\",\"exception\":{\"class\":\"Unauth
    zoneminder.0	2019-10-06 22:36:27.154	debug	REQUEST: Options {"method":"POST","uri":"http://192.168.1.16/zm/api/host/login.json","body":"user=admin&pass=admin","headers":{"content-type":"application/x-www-form-urlencoded","content-length":21,"
    zoneminder.0	2019-10-06 22:36:27.153	debug	data: {"user":"admin","password":"admin","host":"http://192.168.1.16/zm"}
    zoneminder.0	2019-10-06 22:36:27.143	info	starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.zoneminder, node: v10.16.0
    zoneminder.0	2019-10-06 22:36:27.128	debug	statesDB connected
    zoneminder.0	2019-10-06 22:36:27.117	debug	objectDB connected
    host.debian	2019-10-06 22:36:26.717	info	instance system.adapter.zoneminder.0 started with pid 8577
    host.debian	2019-10-06 22:36:26.709	info	"system.adapter.zoneminder.0" enabled
    djsirius
    MeistertrM 1 Antwort Letzte Antwort
    • D djsirius
      @Meistertr
      MeistertrM Offline
      MeistertrM Offline
      Meistertr
      @djsirius zoneminder antwortet dass er admin mit pw admin nicht kennt ...
      D M 2 Antworten Letzte Antwort
        djsirius
        @Meistertr moin. Tja und nun? Das sind genau die User und Passwort, die ich vergeben hab. Und damit kann ich mich auf der Konsole von Zoneminder ja auch anmelden.
        Ich habe auch schon mehrere unterschiedliche User mit unterschiedlichen Passwörtern angelegt und er bringt immer diese Meldung, dass er User und Passwort nicht kennt.
        Dann ist doch der Adapter kaputt!!!???
        djsirius
        • D djsirius
          djsirius
          Hallo.
          Sooooo, das Problem ist beseitigt!
          In den Einstallungen hatte ich bei OPT_USE_AUTH Authenticate user logins to ZoneMinder (?) einen Haken drin. Haken raus, Zoneminder neustart, der Adapter verbindet sich!!!
          djsirius
          • D djsirius
            Hallo.
            MeistertrM Offline
            MeistertrM Offline
            Meistertr
            @djsirius das ist aber nur ein wurkaround und nicht die Lösung, zeig mal ein Screenshot deiner Config. Eigentlich sollte es mit Admin Admin gehen müssen...
              djsirius
              djsirius
                mikiline
                @Meistertr
                Das mit den Events (Motion) lässt sich mit dem zmeventmanager lösen. Diesen habe ich nun installiert und mir die App "zmninja" gezogen. Läuft alles wunderbar.
                Im Eventmanager ist auch ein MQTT Server/Client mit dabei, mit dem Du dann sicher auch etwas im Adapter verwenden kannst ;)
                  djsirius
                  Könnt ihr mal bitte mit http://server/zm/api/host/getVersion.json schauen, welche Version ihr von zoneminder installiert habt?
                  Ich habe folgende Version installiert:
                  {"version":"1.30.4","apiversion":"1.0"}
                  Vielleicht liegt es daran, weil auf der Homepage steht:
                  Login process for ZoneMinder v1.32.0 and above:
                  curl -XPOST -d "user=XXXX&pass=YYYY" -c cookies.txt  http://yourzmip/zm/api/host/login.json
                  Login process for older versions of ZoneMinder:
                  curl -d "username=XXXX&password=YYYY&action=login&view=console" -c cookies.txt  http://yourzmip/zm/index.php
                  djsirius
                  coyoteC M D 3 Antworten Letzte Antwort
                  • D djsirius
                    coyoteC Offline
                    coyoteC Offline
                    coyote
                    @djsirius sagte in [Aufruf] Zoneminder 0.2.0 Testen:
                    Ich habe die 1.32.3
                    • D djsirius
                      mikiline
                      schrieb am zuletzt editiert von mikiline
                      "version":"1.33.14","apiversion":"2.0"}
                      • M mikiline
                        @Meistertr
                        MeistertrM Offline
                        MeistertrM Offline
                        Meistertr
                        @mikiline sagte in [Aufruf] Zoneminder 0.2.0 Testen:
                        zmeventmanager
                        das war auch mein plan... konnte ihn aber noch nciht umsetzen
                          djsirius
                          Wie bekomme ich denn meine Zoneminder Version geupdatet?
                          djsirius
                          • D djsirius
                            MeistertrM Offline
                            MeistertrM Offline
                            Meistertr
                            schrieb am zuletzt editiert von Meistertr
                            @djsirius
                            add-apt-repository ppa:iconnor/zoneminder-1.32
                              @djsirius
                              djsirius
                              @Meistertr said in [Aufruf] Zoneminder 0.2.0 Testen:
                              Das funktioniert nicht.
                              Ich habe debian 9 installiert.
                              djsirius
                              XsevX 1 Antwort Letzte Antwort
                              • D djsirius
                                XsevX Offline
                                XsevX Offline
                                Xsev
                                @djsirius
                                schau mal hier da ist eigentlich alles beschrieben für die Installation von 1.32.2 auf Debian 9.
                                • D djsirius
                                  djsirius
                                  #66
                                  @djsirius said in [Aufruf] Zoneminder 0.2.0 Testen:
                                  @Meistertr könnte es daran liegen, dass mein Zoneminder-Adapter sich nicht mit Zoneminder verbinden kann?
                                  djsirius
                                  • D djsirius
                                    MeistertrM Offline
                                    MeistertrM Offline
                                    Meistertr
                                    #67
                                    @djsirius jep daran wird es liegen.
                                      djsirius
                                      #68
                                      Ok. :-(
                                      Dann kann ich kein Zoneminder benutzen, weil ich meine Version nicht geupdatet bekomme.
                                      Die Vorgehensweise aus dem Link den @Xsev freundlicherweise gepostet hat , bekomme ich immer eine Fehlermeldung.
                                      Ich kenne mich mit der ganzen Sache auch zu wenig aus. :-(
                                      Oder könntest du den Adapter updaten, damit man den Adapter auch mit der Version 1.30.4 benutzen kann?
                                      djsirius
                                        mikiline
                                        #69
                                        Hatte vorher auch ne kleinere Version drauf und einfach das PPA genommen ohne Versionsnummer und dann ein dist-upgrade ausgeführt
                                        vorher sollte man zoneminder stoppen, hat bei mir jedoch (weil vergessen) auch ohne funktioniert. Falls Du alles in einer VM am Laufen hast (was ich mit z.B. Proxmox wärmstens empfehlen kann), kannst ja mal nen Backup machen und versuchen....
                                          mikiline
                                          #70
                                          so....MQTT läuft nun auch und Events von Zoneminder erscheinen im MQTT Adapter zur weiteren Verarbeitung
