  4. Test Adapter HeatingControl v3.xx
heating
3.3k Beiträge 239 Kommentatoren 2.5m Aufrufe 201 Beobachtet
  • H holgerwolf
    Ich hoffe ich habe alle Relevante erwischt:
    2019-10-04 16:07:58.424 - info: host.ubuntu object change system.adapter.heatingcontrol.0
    2019-10-04 16:07:58.425 - info: heatingcontrol.0 cleaned everything up...
    2019-10-04 16:07:58.425 - info: host.ubuntu stopInstance system.adapter.heatingcontrol.0
    2019-10-04 16:07:58.425 - info: host.ubuntu stopInstance system.adapter.heatingcontrol.0 killing pid 27653
    2019-10-04 16:07:58.428 - info: heatingcontrol.0 cleaned everything up...
    2019-10-04 16:07:58.448 - error: Caught by controller[1]: (node:27653) UnhandledPromiseRejectionWarning: Empty ID: {"val":true,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin"}
    2019-10-04 16:07:58.448 - error: Caught by controller[1]: (node:27653) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 18)
    2019-10-04 16:07:58.448 - info: host.ubuntu instance system.adapter.heatingcontrol.0 terminated with code 156 ()
    2019-10-04 16:08:00.930 - info: host.ubuntu instance system.adapter.heatingcontrol.0 started with pid 17959
    2019-10-04 16:08:01.119 - debug: heatingcontrol.0 objectDB connected
    2019-10-04 16:08:01.128 - debug: heatingcontrol.0 statesDB connected
    2019-10-04 16:08:01.229 - info: heatingcontrol.0 starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.heatingcontrol, node: v10.16.3
    2019-10-04 16:08:01.240 - debug: heatingcontrol.0 devices [{"id":1,"name":"Heizung Schalter Bad.STATE","isActive":true,"room":"Bad","type":2,"OID_Target":"hm-rpc.0.HEQ0366232.3.STATE"},{"id":2,"name":"Heizung Schalter Gaeste 3","isActive":true,"room":"Gaestezimmer","type":2,"OID_Target":"hm-rpc.0.HEQ0366232.4.STATE"},{"id":3,"name":"Thermostat Hobby 1.SETPOINT","OID_Current":"hm-rpc.0.GEQ0171035.1.TEMPERATURE","OID_Target":"hm-rpc.0.GEQ0171035.2.SETPOINT","isActive":true,"type":1,"room":"Hobby"},{"id":4,"name":"","OID_Target":"","isActive":false,"type":2,"room":"Hobby"},{"id":5,"name":"","OID_Target":"","isActive":false,"type":2,"room":"Hobby"},{"id":6,"name":"Heizung Wohnzimmer 1.SETPOINT","OID_Current":"hm-rpc.0.HEQ0366475.1.TEMPERATURE","OID_Target":"hm-rpc.0.HEQ0366475.2.SETPOINT","isActive":true,"type":1,"room":"Wohnzimmer"},{"id":7,"name":"Schalter Heizung Wohn.STATE","OID_Target":"hm-rpc.0.IEQ0504267.1.STATE","isActive":true,"type":2,"room":"Wohnzimmer"},{"id":8,"name":"Heizung Bad 1.SETPOINT","OID_Current":"hm-rpc.0.JEQ0225790.1.TEMPERATURE","OID_Target":"hm-rpc.0.JEQ0225790.2.SETPOINT","isActive":true,"type":1,"room":"Bad"}]
    2019-10-04 16:08:01.241 - debug: heatingcontrol.0 CreateDatepoints
    2019-10-04 16:08:01.286 - debug: heatingcontrol.0 rooms 10
    2019-10-04 16:08:01.287 - debug: heatingcontrol.0 create data points for Wohnzimmer
    2019-10-04 16:08:01.302 - debug: heatingcontrol.0 room Wohnzimmer with 4 periods
    2019-10-04 16:08:01.302 - debug: heatingcontrol.0 Profile Type Mo-FR + Sa-So, profiles 1
    2019-10-04 16:08:01.302 - debug: heatingcontrol.0 add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.0 max 5
    2019-10-04 16:08:01.302 - debug: heatingcontrol.0 add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.1 max 5
    2019-10-04 16:08:01.302 - debug: heatingcontrol.0 add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.2 max 5
    2019-10-04 16:08:01.302 - debug: heatingcontrol.0 add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.3 max 5
    2019-10-04 16:08:01.302 - debug: heatingcontrol.0 add state Profiles.0.Wohnzimmer.Su-So.Periods.0 max 5
    2019-10-04 16:08:01.302 - debug: heatingcontrol.0 add state Profiles.0.Wohnzimmer.Su-So.Periods.1 max 5
    2019-10-04 16:08:01.302 - debug: heatingcontrol.0 add state Profiles.0.Wohnzimmer.Su-So.Periods.2 max 5
    2019-10-04 16:08:01.302 - debug: heatingcontrol.0 add state Profiles.0.Wohnzimmer.Su-So.Periods.3 max 5
    2019-10-04 16:08:01.302 - debug: heatingcontrol.0 not active.... Studio
    2019-10-04 16:08:01.303 - debug: heatingcontrol.0 create data points for Bad
    2019-10-04 16:08:01.339 - debug: heatingcontrol.0 room Bad with 4 periods
    2019-10-04 16:08:01.339 - debug: heatingcontrol.0 Profile Type Mo-FR + Sa-So, profiles 1
    2019-10-04 16:08:01.339 - debug: heatingcontrol.0 add state Profiles.0.Bad.Mo-Fr.Periods.0 max 5
    2019-10-04 16:08:01.340 - debug: heatingcontrol.0 add state Profiles.0.Bad.Mo-Fr.Periods.1 max 5
    2019-10-04 16:08:01.340 - debug: heatingcontrol.0 add state Profiles.0.Bad.Mo-Fr.Periods.2 max 5
    2019-10-04 16:08:01.340 - debug: heatingcontrol.0 add state Profiles.0.Bad.Mo-Fr.Periods.3 max 5
    2019-10-04 16:08:01.340 - debug: heatingcontrol.0 add state Profiles.0.Bad.Su-So.Periods.0 max 5
    2019-10-04 16:08:01.340 - debug: heatingcontrol.0 add state Profiles.0.Bad.Su-So.Periods.1 max 5
    2019-10-04 16:08:01.340 - debug: heatingcontrol.0 add state Profiles.0.Bad.Su-So.Periods.2 max 5
    2019-10-04 16:08:01.340 - debug: heatingcontrol.0 add state Profiles.0.Bad.Su-So.Periods.3 max 5
    2019-10-04 16:08:01.340 - debug: heatingcontrol.0 not active.... HWR
    2019-10-04 16:08:01.340 - debug: heatingcontrol.0 not active.... Garten
    2019-10-04 16:08:01.340 - debug: heatingcontrol.0 create data points for Hobby
    2019-10-04 16:08:01.378 - debug: heatingcontrol.0 room Hobby with 4 periods
    2019-10-04 16:08:01.378 - debug: heatingcontrol.0 Profile Type Mo-FR + Sa-So, profiles 1
    2019-10-04 16:08:01.378 - debug: heatingcontrol.0 add state Profiles.0.Hobby.Mo-Fr.Periods.0 max 5
    2019-10-04 16:08:01.378 - debug: heatingcontrol.0 add state Profiles.0.Hobby.Mo-Fr.Periods.1 max 5
    2019-10-04 16:08:01.378 - debug: heatingcontrol.0 add state Profiles.0.Hobby.Mo-Fr.Periods.2 max 5
    2019-10-04 16:08:01.378 - debug: heatingcontrol.0 add state Profiles.0.Hobby.Mo-Fr.Periods.3 max 5
    2019-10-04 16:08:01.378 - debug: heatingcontrol.0 add state Profiles.0.Hobby.Su-So.Periods.0 max 5
    2019-10-04 16:08:01.378 - debug: heatingcontrol.0 add state Profiles.0.Hobby.Su-So.Periods.1 max 5
    2019-10-04 16:08:01.378 - debug: heatingcontrol.0 add state Profiles.0.Hobby.Su-So.Periods.2 max 5
    2019-10-04 16:08:01.378 - debug: heatingcontrol.0 add state Profiles.0.Hobby.Su-So.Periods.3 max 5
    2019-10-04 16:08:01.378 - debug: heatingcontrol.0 not active.... Schlafzimmer
    2019-10-04 16:08:01.378 - debug: heatingcontrol.0 not active.... Gaestezimmer
    2019-10-04 16:08:01.378 - debug: heatingcontrol.0 not active.... Flur
    2019-10-04 16:08:01.378 - debug: heatingcontrol.0 not active.... Kueche
    2019-10-04 16:08:01.378 - debug: heatingcontrol.0 #start subscribtion
    2019-10-04 16:08:01.379 - info: heatingcontrol.0 subscribe feiertage.0.heute.boolean
    2019-10-04 16:08:01.379 - info: heatingcontrol.0 subscribe Hobby hm-rpc.0.GEQ0171035.2.SETPOINT / hm-rpc.0.GEQ0171035.1.TEMPERATURE
    2019-10-04 16:08:01.379 - info: heatingcontrol.0 subscribe Wohnzimmer hm-rpc.0.HEQ0366475.2.SETPOINT / hm-rpc.0.HEQ0366475.1.TEMPERATURE
    2019-10-04 16:08:01.379 - info: heatingcontrol.0 subscribe Bad hm-rpc.0.JEQ0225790.2.SETPOINT / hm-rpc.0.JEQ0225790.1.TEMPERATURE
    2019-10-04 16:08:01.379 - debug: heatingcontrol.0 #subscribtion finished
    2019-10-04 16:08:01.379 - debug: heatingcontrol.0 start CalculateNextTime, profile type 2
    2019-10-04 16:08:01.379 - debug: heatingcontrol.0 get profile
    2019-10-04 16:08:01.441 - debug: heatingcontrol.0 profile 0
    2019-10-04 16:08:01.474 - debug: heatingcontrol.0 ---1 found time for Wohnzimmer at {"val":"00:00","ack":true,"ts":1570184877412,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570184877284} 00:00
    2019-10-04 16:08:01.474 - debug: heatingcontrol.0 push to list = 00,00
    2019-10-04 16:08:01.490 - debug: heatingcontrol.0 ---1 found time for Wohnzimmer at {"val":"14:00","ack":true,"ts":1570188148737,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570188148569} 14:00
    2019-10-04 16:08:01.490 - debug: heatingcontrol.0 push to list = 14,00
    2019-10-04 16:08:01.495 - debug: heatingcontrol.0 ---1 found time for Wohnzimmer at {"val":"22:30","ack":true,"ts":1570184960855,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570184960751} 22:30
    2019-10-04 16:08:01.495 - debug: heatingcontrol.0 push to list = 22,30
    2019-10-04 16:08:01.498 - debug: heatingcontrol.0 ---1 found time for Wohnzimmer at {"val":"22:30","ack":true,"ts":1570184983804,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570184983719} 22:30
    2019-10-04 16:08:01.504 - debug: heatingcontrol.0 ---2 found time for Wohnzimmer at {"val":"00:00","ack":true,"ts":1570185076234,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570185076099} 00:00
    2019-10-04 16:08:01.504 - debug: heatingcontrol.0 push to list = 00,00
    2019-10-04 16:08:01.507 - debug: heatingcontrol.0 ---2 found time for Wohnzimmer at {"val":"08:00","ack":true,"ts":1570184609447,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570184609447} 08:00
    2019-10-04 16:08:01.507 - debug: heatingcontrol.0 push to list = 08,00
    2019-10-04 16:08:01.513 - debug: heatingcontrol.0 ---2 found time for Wohnzimmer at {"val":"22:00","ack":true,"ts":1570185196688,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570185196581} 22:00
    2019-10-04 16:08:01.513 - debug: heatingcontrol.0 push to list = 22,00
    2019-10-04 16:08:01.519 - debug: heatingcontrol.0 ---2 found time for Wohnzimmer at {"val":"22:00","ack":true,"ts":1570185251680,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570185251568} 22:00
    2019-10-04 16:08:01.521 - debug: heatingcontrol.0 ---1 found time for Bad at {"val":"00:00","ack":true,"ts":1570187067402,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570187002095} 00:00
    2019-10-04 16:08:01.524 - debug: heatingcontrol.0 ---1 found time for Bad at {"val":"04:00","ack":true,"ts":1570187129193,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570187129009} 04:00
    2019-10-04 16:08:01.524 - debug: heatingcontrol.0 push to list = 04,00
    2019-10-04 16:08:01.527 - debug: heatingcontrol.0 ---1 found time for Bad at {"val":"05:00","ack":true,"ts":1570187270903,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570187270693} 05:00
    2019-10-04 16:08:01.527 - debug: heatingcontrol.0 push to list = 05,00
    2019-10-04 16:08:01.584 - debug: heatingcontrol.0 ---1 found time for Bad at {"val":"17:00","ack":true,"ts":1570187346080,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570187345940} 17:00
    2019-10-04 16:08:01.584 - debug: heatingcontrol.0 push to list = 17,00
    2019-10-04 16:08:01.597 - debug: heatingcontrol.0 ---2 found time for Bad at {"val":"00:00","ack":true,"ts":1570187610071,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570187609898} 00:00
    2019-10-04 16:08:01.601 - debug: heatingcontrol.0 ---2 found time for Bad at {"val":"06:00","ack":true,"ts":1570187745063,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570187744889} 06:00
    2019-10-04 16:08:01.601 - debug: heatingcontrol.0 push to list = 06,00
    2019-10-04 16:08:01.609 - debug: heatingcontrol.0 ---2 found time for Bad at {"val":"23:00","ack":true,"ts":1570187869556,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570187869442} 23:00
    2019-10-04 16:08:01.612 - debug: heatingcontrol.0 push to list = 23,00
    2019-10-04 16:08:01.619 - debug: heatingcontrol.0 ---2 found time for Bad at {"val":"23:00","ack":true,"ts":1570187884926,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570187884799} 23:00
    2019-10-04 16:08:01.691 - debug: heatingcontrol.0 ---1 found time for Hobby at {"val":"00:00","ack":true,"ts":1570182698684,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570182698518} 00:00
    2019-10-04 16:08:01.700 - debug: heatingcontrol.0 ---1 found time for Hobby at {"val":"07:30","ack":true,"ts":1570184159739,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570182727294} 07:30
    2019-10-04 16:08:01.700 - debug: heatingcontrol.0 push to list = 07,30
    2019-10-04 16:08:01.712 - debug: heatingcontrol.0 ---1 found time for Hobby at {"val":"17:00","ack":true,"ts":1570182858606,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570182858536} 17:00
    2019-10-04 16:08:01.783 - debug: heatingcontrol.0 ---1 found time for Hobby at {"val":"17:00","ack":true,"ts":1570182927636,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570182927539} 17:00
    2019-10-04 16:08:01.785 - debug: heatingcontrol.0 ---2 found time for Hobby at {"val":"05:00","ack":true,"ts":1570182469509,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570182469509} 05:00
    2019-10-04 16:08:01.785 - debug: heatingcontrol.0 push to list = 05,00
    2019-10-04 16:08:01.787 - debug: heatingcontrol.0 ---2 found time for Hobby at {"val":"08:00","ack":true,"ts":1570182469512,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570182469512} 08:00
    2019-10-04 16:08:01.787 - debug: heatingcontrol.0 ---2 found time for Hobby at {"val":"12:00","ack":true,"ts":1570182469512,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570182469512} 12:00
    2019-10-04 16:08:01.788 - debug: heatingcontrol.0 push to list = 12,00
    2019-10-04 16:08:01.790 - debug: heatingcontrol.0 ---2 found time for Hobby at {"val":"16:00","ack":true,"ts":1570182469513,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570182469513} 16:00
    2019-10-04 16:08:01.791 - debug: heatingcontrol.0 push to list = 16,00
    2019-10-04 16:08:01.791 - info: heatingcontrol.0 check for heating period based on settings between 01.10. and 31.03.
    2019-10-04 16:08:01.791 - debug: heatingcontrol.0 HeatingPeriod: create cron job #0 at 01.10 string: 5 0 01 9 * Europe/Berlin
    2019-10-04 16:08:01.800 - debug: heatingcontrol.0 HeatingPeriod: create cron job #1 at 31.03 string: 55 23 31 2 * Europe/Berlin
    2019-10-04 16:08:01.806 - debug: heatingcontrol.0 create cron job #2 at 0:0 string: 0 0 0 * * 1-5 Europe/Berlin
    2019-10-04 16:08:01.808 - debug: heatingcontrol.0 create cron job #3 at 14:0 string: 0 0 14 * * 1-5 Europe/Berlin
    2019-10-04 16:08:01.809 - debug: heatingcontrol.0 create cron job #4 at 22:30 string: 0 30 22 * * 1-5 Europe/Berlin
    2019-10-04 16:08:01.811 - debug: heatingcontrol.0 create cron job #5 at 0:0 string: 0 0 0 * * 0,6 Europe/Berlin
    2019-10-04 16:08:01.813 - debug: heatingcontrol.0 create cron job #6 at 8:0 string: 0 0 8 * * 0,6 Europe/Berlin
    2019-10-04 16:08:01.814 - debug: heatingcontrol.0 create cron job #7 at 22:0 string: 0 0 22 * * 0,6 Europe/Berlin
    2019-10-04 16:08:01.815 - debug: heatingcontrol.0 create cron job #8 at 4:0 string: 0 0 4 * * 1-5 Europe/Berlin
    2019-10-04 16:08:01.816 - debug: heatingcontrol.0 create cron job #9 at 5:0 string: 0 0 5 * * 1-5 Europe/Berlin
    2019-10-04 16:08:01.821 - debug: heatingcontrol.0 create cron job #10 at 17:0 string: 0 0 17 * * 1-5 Europe/Berlin
    2019-10-04 16:08:01.824 - debug: heatingcontrol.0 create cron job #11 at 6:0 string: 0 0 6 * * 0,6 Europe/Berlin
    2019-10-04 16:08:01.825 - debug: heatingcontrol.0 create cron job #12 at 23:0 string: 0 0 23 * * 0,6 Europe/Berlin
    2019-10-04 16:08:01.826 - debug: heatingcontrol.0 create cron job #13 at 7:30 string: 0 30 7 * * 1-5 Europe/Berlin
    2019-10-04 16:08:01.827 - debug: heatingcontrol.0 create cron job #14 at 5:0 string: 0 0 5 * * 0,6 Europe/Berlin
    2019-10-04 16:08:01.828 - debug: heatingcontrol.0 create cron job #15 at 12:0 string: 0 0 12 * * 0,6 Europe/Berlin
    2019-10-04 16:08:01.828 - debug: heatingcontrol.0 create cron job #16 at 16:0 string: 0 0 16 * * 0,6 Europe/Berlin
    2019-10-04 16:08:01.830 - debug: heatingcontrol.0 cron jobs
    2019-10-04 16:08:01.831 - debug: heatingcontrol.0 [INFO] status = true next event: 1 Oct 2020 00:05:00
    2019-10-04 16:08:01.833 - debug: heatingcontrol.0 [INFO] status = true next event: 31 Mar 2020 23:55:00
    2019-10-04 16:08:01.833 - debug: heatingcontrol.0 [INFO] status = true next event: 7 Oct 2019 00:00:00
    2019-10-04 16:08:01.834 - debug: heatingcontrol.0 [INFO] status = true next event: 7 Oct 2019 14:00:00
    2019-10-04 16:08:01.835 - debug: heatingcontrol.0 [INFO] status = true next event: 4 Oct 2019 22:30:00
    2019-10-04 16:08:01.835 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 00:00:00
    2019-10-04 16:08:01.835 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 08:00:00
    2019-10-04 16:08:01.836 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 22:00:00
    2019-10-04 16:08:01.836 - debug: heatingcontrol.0 [INFO] status = true next event: 7 Oct 2019 04:00:00
    2019-10-04 16:08:01.836 - debug: heatingcontrol.0 [INFO] status = true next event: 7 Oct 2019 05:00:00
    2019-10-04 16:08:01.836 - debug: heatingcontrol.0 [INFO] status = true next event: 4 Oct 2019 17:00:00
    2019-10-04 16:08:01.837 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 06:00:00
    2019-10-04 16:08:01.840 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 23:00:00
    2019-10-04 16:08:01.840 - debug: heatingcontrol.0 [INFO] status = true next event: 7 Oct 2019 07:30:00
    2019-10-04 16:08:01.840 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 05:00:00
    2019-10-04 16:08:01.841 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 12:00:00
    2019-10-04 16:08:01.844 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 16:00:00
    2019-10-04 16:08:01.844 - info: heatingcontrol.0 calculating new target temperatures
    2019-10-04 16:08:01.889 - debug: heatingcontrol.0 profile type 2
    2019-10-04 16:08:01.889 - debug: heatingcontrol.0 get profile
    2019-10-04 16:08:01.892 - debug: heatingcontrol.0 profile 0
    2019-10-04 16:08:01.892 - debug: heatingcontrol.0 check room Wohnzimmer
    2019-10-04 16:08:01.892 - debug: heatingcontrol.0 number of periods 4
    2019-10-04 16:08:01.892 - debug: heatingcontrol.0 check ID Profiles.0.Wohnzimmer.Mo-Fr.Periods.0.time
    2019-10-04 16:08:01.895 - debug: heatingcontrol.0 check time for Wohnzimmer Profiles.0.Wohnzimmer.Mo-Fr.Periods.0.time 19
    2019-10-04 16:08:01.896 - debug: heatingcontrol.0 check ID Profiles.0.Wohnzimmer.Mo-Fr.Periods.1.time
    2019-10-04 16:08:01.899 - debug: heatingcontrol.0 check time for Wohnzimmer Profiles.0.Wohnzimmer.Mo-Fr.Periods.1.time 23
    2019-10-04 16:08:01.899 - debug: heatingcontrol.0 check ID Profiles.0.Wohnzimmer.Mo-Fr.Periods.2.time
    2019-10-04 16:08:01.899 - debug: heatingcontrol.0 check ID Profiles.0.Wohnzimmer.Mo-Fr.Periods.3.time
    2019-10-04 16:08:01.914 - debug: heatingcontrol.0 ### 23 0 0 0 0 0
    2019-10-04 16:08:01.914 - info: heatingcontrol.0 room Wohnzimmer Thermostat Heizung Wohnzimmer 1.SETPOINT set to 23
    2019-10-04 16:08:01.917 - debug: heatingcontrol.0 ### handle state change hm-rpc.0.HEQ0366475.2.SETPOINT {"val":23,"ack":false,"ts":1570198081915,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570190400054}
    2019-10-04 16:08:01.918 - debug: heatingcontrol.0 ### 111 not handled
    2019-10-04 16:08:01.918 - debug: heatingcontrol.0 handle actors hm-rpc.0.HEQ0366475.2.SETPOINT{"val":23,"ack":false,"ts":1570198081915,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570190400054}
    2019-10-04 16:08:01.918 - debug: heatingcontrol.0 ### {"id":6,"name":"Heizung Wohnzimmer 1.SETPOINT","OID_Current":"hm-rpc.0.HEQ0366475.1.TEMPERATURE","OID_Target":"hm-rpc.0.HEQ0366475.2.SETPOINT","isActive":true,"type":1,"room":"Wohnzimmer"}
    2019-10-04 16:08:01.920 - debug: heatingcontrol.0 check room Bad
    2019-10-04 16:08:01.920 - debug: heatingcontrol.0 number of periods 4
    2019-10-04 16:08:01.920 - debug: heatingcontrol.0 check ID Profiles.0.Bad.Mo-Fr.Periods.0.time
    2019-10-04 16:08:01.921 - info: heatingcontrol.0 handle actors Wohnzimmer current 22.8 target 23
    2019-10-04 16:08:01.923 - debug: heatingcontrol.0 check time for Bad Profiles.0.Bad.Mo-Fr.Periods.0.time 17
    2019-10-04 16:08:01.923 - debug: heatingcontrol.0 check ID Profiles.0.Bad.Mo-Fr.Periods.1.time
    2019-10-04 16:08:01.923 - debug: heatingcontrol.0 room Wohnzimmer actor hm-rpc.0.IEQ0504267.1.STATE on
    2019-10-04 16:08:01.923 - debug: heatingcontrol.0 ### 222 handled
    2019-10-04 16:08:01.925 - debug: heatingcontrol.0 ### all StateChange handled
    2019-10-04 16:08:01.926 - debug: heatingcontrol.0 check time for Bad Profiles.0.Bad.Mo-Fr.Periods.1.time 22
    2019-10-04 16:08:01.926 - debug: heatingcontrol.0 check ID Profiles.0.Bad.Mo-Fr.Periods.2.time
    2019-10-04 16:08:01.937 - debug: heatingcontrol.0 check time for Bad Profiles.0.Bad.Mo-Fr.Periods.2.time 17
    2019-10-04 16:08:01.937 - debug: heatingcontrol.0 check ID Profiles.0.Bad.Mo-Fr.Periods.3.time
    2019-10-04 16:08:01.938 - debug: heatingcontrol.0 ### 17 0 0 0 0 0
    2019-10-04 16:08:01.938 - info: heatingcontrol.0 room Bad Thermostat Heizung Bad 1.SETPOINT set to 17
    2019-10-04 16:08:01.943 - debug: heatingcontrol.0 check room Hobby
    2019-10-04 16:08:01.943 - debug: heatingcontrol.0 number of periods 4
    2019-10-04 16:08:01.943 - debug: heatingcontrol.0 check ID Profiles.0.Hobby.Mo-Fr.Periods.0.time
    2019-10-04 16:08:01.948 - debug: heatingcontrol.0 check time for Hobby Profiles.0.Hobby.Mo-Fr.Periods.0.time 19
    2019-10-04 16:08:01.948 - debug: heatingcontrol.0 check ID Profiles.0.Hobby.Mo-Fr.Periods.1.time
    2019-10-04 16:08:01.950 - debug: heatingcontrol.0 check time for Hobby Profiles.0.Hobby.Mo-Fr.Periods.1.time 24
    2019-10-04 16:08:01.951 - debug: heatingcontrol.0 check ID Profiles.0.Hobby.Mo-Fr.Periods.2.time
    2019-10-04 16:08:01.953 - debug: heatingcontrol.0 check ID Profiles.0.Hobby.Mo-Fr.Periods.3.time
    2019-10-04 16:08:01.965 - debug: heatingcontrol.0 ### 24 0 0 0 0 0
    2019-10-04 16:08:01.965 - info: heatingcontrol.0 room Hobby Thermostat Thermostat Hobby 1.SETPOINT set to 24
    2019-10-04 16:08:01.974 - debug: heatingcontrol.0 ### handle state change hm-rpc.0.GEQ0171035.2.SETPOINT {"val":24,"ack":false,"ts":1570198081966,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570184159724}
    2019-10-04 16:08:01.974 - debug: heatingcontrol.0 ### 111 not handled
    2019-10-04 16:08:01.974 - debug: heatingcontrol.0 handle actors hm-rpc.0.GEQ0171035.2.SETPOINT{"val":24,"ack":false,"ts":1570198081966,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1570184159724}
    2019-10-04 16:08:01.974 - debug: heatingcontrol.0 ### {"id":3,"name":"Thermostat Hobby 1.SETPOINT","OID_Current":"hm-rpc.0.GEQ0171035.1.TEMPERATURE","OID_Target":"hm-rpc.0.GEQ0171035.2.SETPOINT","isActive":true,"type":1,"room":"Hobby"}
    2019-10-04 16:08:01.982 - debug: heatingcontrol.0 cron jobs
    2019-10-04 16:08:01.983 - debug: heatingcontrol.0 [INFO] status = true next event: 1 Oct 2020 00:05:00
    2019-10-04 16:08:01.994 - debug: heatingcontrol.0 [INFO] status = true next event: 31 Mar 2020 23:55:00
    2019-10-04 16:08:01.995 - debug: heatingcontrol.0 [INFO] status = true next event: 7 Oct 2019 00:00:00
    2019-10-04 16:08:02.000 - debug: heatingcontrol.0 [INFO] status = true next event: 7 Oct 2019 14:00:00
    2019-10-04 16:08:02.001 - debug: heatingcontrol.0 [INFO] status = true next event: 4 Oct 2019 22:30:00
    2019-10-04 16:08:02.001 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 00:00:00
    2019-10-04 16:08:02.001 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 08:00:00
    2019-10-04 16:08:02.002 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 22:00:00
    2019-10-04 16:08:02.002 - debug: heatingcontrol.0 [INFO] status = true next event: 7 Oct 2019 04:00:00
    2019-10-04 16:08:02.002 - debug: heatingcontrol.0 [INFO] status = true next event: 7 Oct 2019 05:00:00
    2019-10-04 16:08:02.007 - debug: heatingcontrol.0 [INFO] status = true next event: 4 Oct 2019 17:00:00
    2019-10-04 16:08:02.007 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 06:00:00
    2019-10-04 16:08:02.008 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 23:00:00
    2019-10-04 16:08:02.009 - debug: heatingcontrol.0 [INFO] status = true next event: 7 Oct 2019 07:30:00
    2019-10-04 16:08:02.009 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 05:00:00
    2019-10-04 16:08:02.009 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 12:00:00
    2019-10-04 16:08:02.010 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 16:00:00
    2019-10-04 16:08:02.012 - info: heatingcontrol.0 handle actors Hobby current 23.2 target 24
    2019-10-04 16:08:02.013 - warn: heatingcontrol.0 Empty ID: {"val":true,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin"}
    2019-10-04 16:08:46.878 - debug: heatingcontrol.0 ### handle state change hm-rpc.0.HEQ0366475.2.SETPOINT {"val":23,"ack":true,"ts":1570198126876,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1570190400054}
    2019-10-04 16:08:46.878 - debug: heatingcontrol.0 ### 111 not handled
    2019-10-04 16:08:46.878 - debug: heatingcontrol.0 handle actors hm-rpc.0.HEQ0366475.2.SETPOINT{"val":23,"ack":true,"ts":1570198126876,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1570190400054}
    2019-10-04 16:08:46.878 - debug: heatingcontrol.0 ### {"id":6,"name":"Heizung Wohnzimmer 1.SETPOINT","OID_Current":"hm-rpc.0.HEQ0366475.1.TEMPERATURE","OID_Target":"hm-rpc.0.HEQ0366475.2.SETPOINT","isActive":true,"type":1,"room":"Wohnzimmer"}
    2019-10-04 16:08:46.881 - info: heatingcontrol.0 handle actors Wohnzimmer current 22.8 target 23
    2019-10-04 16:08:46.887 - debug: heatingcontrol.0 room Wohnzimmer actor hm-rpc.0.IEQ0504267.1.STATE on
    2019-10-04 16:08:46.889 - debug: heatingcontrol.0 ### 222 handled
    2019-10-04 16:08:46.889 - debug: heatingcontrol.0 ### all StateChange handled
    2019-10-04 16:08:46.890 - debug: heatingcontrol.0 ### handle state change hm-rpc.0.HEQ0366475.1.TEMPERATURE {"val":22.8,"ack":true,"ts":1570198126887,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1570197947846}
    2019-10-04 16:08:46.890 - debug: heatingcontrol.0 ### 111 not handled
    2019-10-04 16:08:46.890 - debug: heatingcontrol.0 handle actors hm-rpc.0.HEQ0366475.1.TEMPERATURE{"val":22.8,"ack":true,"ts":1570198126887,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1570197947846}
    2019-10-04 16:08:46.890 - debug: heatingcontrol.0 ### {"id":6,"name":"Heizung Wohnzimmer 1.SETPOINT","OID_Current":"hm-rpc.0.HEQ0366475.1.TEMPERATURE","OID_Target":"hm-rpc.0.HEQ0366475.2.SETPOINT","isActive":true,"type":1,"room":"Wohnzimmer"}
    2019-10-04 16:08:46.896 - info: heatingcontrol.0 handle actors Wohnzimmer current 22.8 target 23
    2019-10-04 16:08:46.898 - debug: heatingcontrol.0 room Wohnzimmer actor hm-rpc.0.IEQ0504267.1.STATE on
    2019-10-04 16:08:46.899 - debug: heatingcontrol.0 ### 222 handled
    2019-10-04 16:08:46.899 - debug: heatingcontrol.0 ### all StateChange handled
    Rene_HMR Offline
    Rene_HMR Offline
    Rene_HM
    #170
    @holgerwolf Du scheinst "Aktoren verwendet" aktiv zu haben. Benötigst du das? Im Normalfall schalten doch die Thermostate die Aktoren direkt...
    H 1 Antwort Letzte Antwort
    • X Offline
      X Offline
      xADDRx
      #171
      hat einer von euch eine übersichtliches Widget (view) die er zur Verfügung stellen würde?
      Ben
      Sonos, Intel Nuc, Iobroker Pro, Proxmox, IPad Air (Wand), Vis, Xiaomi, Devolo, Bose, Philips Hue, Instar, Synology
      Rene_HMR M 2 Antworten Letzte Antwort
      • X xADDRx
        Ben
        Rene_HMR Offline
        Rene_HMR Offline
        Rene_HM
        schrieb am zuletzt editiert von Rene_HM
        #172
        @xADDRx siehe https://forum.iobroker.net/topic/22579/adapter-heatingcontrol/81
        Ich selbst verwende derzeit auch noch das Vis vom Script - Vorbild. Musste nur die Datenpunkte anpassen
        • Rene_HMR Rene_HM
          holgerwolf
          #173
          @Rene_HM Ich habe sowohl Räume mit Thermostat gesteuerten Heizkörperregler als auch Fußbodenheizung die über Aktoren geschaltet werden. Das klappt auch alles prima, bis auf die Warning.
          • Rene_HMR Rene_HM
            @maarten sagte in Adapter: HeatingControl:
            Übrigens läuft Adapterversion 0.3.0
            Bitte beachte, dass die 0.3.0 noch in der Entwicklung ist. Da habe ich einige Themen begonnen aber teilweise noch nicht fertig...
            Bzgl. des o.g. Problems:
            Der Fehler scheint daher zu kommen, dass auf einen Datenpunkt geschrieben wird, den hm-rpc nicht akzeptiert. Ich sehe anhand des logs aber nicht, wo das passiert. Deshalb bitte den adapter im debug-Mode starten und das log nochmal posten.
            maarten
            #174
            @Rene_HM
            Vielen Dank für deine Antwort, ich bin leider erst jetzt dazu gekommen. Ist mir bewusst, dass diese Adapterversion noch in Entwicklung ist, bis jetzt funktioniert Sie jedoch ganz gut.
            Ich musste mich kurz einlesen wie man einen Adapter debut und hoffe ich habe soweit alles richtig gemacht:
            undefined2019-10-04 23:46:51.627 - info: host.Home-PC object change system.adapter.heatingcontrol.0
            2019-10-04 23:46:51.642 - info: host.Home-PC instance system.adapter.heatingcontrol.0 started with pid 7708
            2019-10-04 23:46:52.828 - debug: heatingcontrol.0 objectDB connected
            2019-10-04 23:46:52.859 - debug: heatingcontrol.0 statesDB connected
            2019-10-04 23:46:52.953 - info: heatingcontrol.0 starting. Version 0.3.0 in C:/ioBroker/node_modules/iobroker.heatingcontrol, node: v10.14.1
            2019-10-04 23:46:52.968 - debug: heatingcontrol.0 devices [{"id":1,"name":"EG_Wohnzimmer_Heizung_11_Kanal4.SET_TEMPERATURE","OID_Current":"hm-rpc.1.000E570999A5A3.1.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0846278.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"EG_Wohnzimmer"},{"id":2,"name":"EG_Wohnzimmer_Heizung_11_Kanal4.SET_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0846278.4.SET_TEMPERATURE","isActive":true,"type":2,"room":"EG_Wohnzimmer"},{"id":3,"name":"EG_Wohnzimmer_Heizung_12_Kanal4.SET_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0843010.4.SET_TEMPERATURE","isActive":true,"type":2,"room":"EG_Wohnzimmer"},{"id":4,"name":"EG_Wohnzimmer_Tuere_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0440463.1.STATE","isActive":true,"type":3,"room":"EG_Wohnzimmer"},{"id":5,"name":"EG_Gang_Tuere_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0440750.1.STATE","isActive":true,"type":3,"room":"EG_Wohnzimmer"},{"id":6,"name":"EG_Küche_Fenster_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0566085.1.STATE","isActive":true,"type":3,"room":"EG_Wohnzimmer"},{"id":7,"name":"EG_Wohnzimmer_Heizung_12_Kanal4.SET_TEMPERATURE","OID_Current":"hm-rpc.1.000E570999A5A3.1.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0843010.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"EG_Wohnzimmer"},{"id":8,"name":"EG_Gang_Heizung_11_Kanal4.SET_TEMPERATURE","OID_Current":"hm-rpc.1.000E570999A5A3.1.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0843134.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"EG_Wohnzimmer"},{"id":9,"name":"EG_Wohnzimmer_Tuere_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0440463.1.STATE","isActive":true,"type":3,"room":"EG_Wohnzimmer"},{"id":10,"name":"1OG_Schlafzimmer_Heizung_11_Kanal4.SET_TEMPERATURE","OID_Current":"hm-rpc.1.000E570999A397.1.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0841727.4.SET_TEMPERATURE","isActive":false,"type":1,"room":"1OG_Schlafzimmer"},{"id":11,"name":"1OG_Schlafzimmer_Fenster_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0566218.1.STATE","isActive":false,"type":3,"room":"1OG_Schlafzimmer"},{"id":12,"name":"1OG_Schlafzimmer_Tuere_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0566065.1.STATE","isActive":false,"type":3,"room":"1OG_Schlafzimmer"},{"id":13,"name":"1OG_Kinderzimmer1_Heizung_11_Kanal4.SET_TEMPERATURE","OID_Current":"hm-rpc.1.000E570999A3A5.1.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0844685.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"1OG_Kinderzimmer1"},{"id":14,"name":"1OG_Kinderzimmer1_Fenster_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0568166.1.STATE","isActive":true,"type":3,"room":"1OG_Kinderzimmer1"},{"id":15,"name":"1OG_Kinderzimmer 2_Heizung_11_Kanal4.SET_TEMPERATURE","OID_Current":"hm-rpc.1.000E570999A87B.1.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ1248833.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"1OG_Kinderzimmer2"},{"id":16,"name":"1OG_Kinderzimmer2_Fenster_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0440292.1.STATE","isActive":true,"type":3,"room":"1OG_Kinderzimmer2"},{"id":17,"name":"2OG_Schlafzimmer_Heizung_11_Kanal4.SET_TEMPERATURE","OID_Current":"hm-rpc.1.000E570999A890.1.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0846127.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"2OG_Schlafzimmer"},{"id":18,"name":"hm-rpc.1.000E570999A890.1.ACTUAL_TEMPERATURE","OID_Current":"hm-rpc.1.000E570999A890.1.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0846141.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"2OG_Schlafzimmer"},{"id":19,"name":"2OG_Schlafzimmer_Fenster_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0496790.1.STATE","isActive":true,"type":3,"room":"2OG_Schlafzimmer"},{"id":20,"name":"2OG_Schlafzimmer_Fenster_12_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0496601.1.STATE","isActive":true,"type":3,"room":"2OG_Schlafzimmer"},{"id":21,"name":"2OG_Schlafzimmer_Fenster_13_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0496803.1.STATE","isActive":true,"type":3,"room":"2OG_Schlafzimmer"},{"id":22,"name":"2OG_Schlafzimmer_Fenster_14_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0496795.1.STATE","isActive":true,"type":3,"room":"2OG_Schlafzimmer"},{"id":23,"name":"2OG_Buero1_Heizung_11_Kanal4.SET_TEMPERATURE","OID_Current":"hm-rpc.1.000E570999A5AF.1.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0845933.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"2OG_Buero1"},{"id":24,"name":"2OG_Buero11_Fenster_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0564053.1.STATE","isActive":true,"type":3,"room":"2OG_Buero1"},{"id":25,"name":"2OG_Buero2_Heizung_11_Kanal4.SET_TEMPERATURE","OID_Current":"hm-rpc.1.000E570999A419.1.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0846143.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"2OG_Buero2"},{"id":26,"name":"2OG_Buero2_Fenster_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0496792.1.STATE","isActive":true,"type":3,"room":"2OG_Buero2"},{"id":27,"name":"2OG_Buero2_Fenster_12_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0441055.1.STATE","isActive":true,"type":3,"room":"2OG_Buero2"},{"id":28,"name":"2OG_Buero2_Fenster_13_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0496740.1.STATE","isActive":true,"type":3,"room":"2OG_Buero2"},{"id":29,"name":"2OG_Bad_Heizung_11_Kanal4.SET_TEMPERATURE","OID_Current":"hm-rpc.1.000E570999A897.1.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0845830.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"2OG_Bad"},{"id":30,"name":"2OG_Bad_Fenster_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0566263.1.STATE","isActive":true,"type":3,"room":"2OG_Bad"}]
            2019-10-04 23:46:52.968 - debug: heatingcontrol.0 CreateDatepoints
            2019-10-04 23:46:53.171 - debug: heatingcontrol.0 rooms 19
            2019-10-04 23:46:53.171 - debug: heatingcontrol.0 create data points for EG_Wohnzimmer
            2019-10-04 23:46:53.218 - debug: heatingcontrol.0 room EG_Wohnzimmer with 3 periods
            2019-10-04 23:46:53.218 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
            2019-10-04 23:46:53.218 - debug: heatingcontrol.0 add state Profiles.0.EG_Wohnzimmer.Mo-Su.Periods.0 max 5
            2019-10-04 23:46:53.218 - debug: heatingcontrol.0 add state Profiles.0.EG_Wohnzimmer.Mo-Su.Periods.1 max 5
            2019-10-04 23:46:53.218 - debug: heatingcontrol.0 add state Profiles.0.EG_Wohnzimmer.Mo-Su.Periods.2 max 5
            2019-10-04 23:46:53.218 - debug: heatingcontrol.0 not active.... EG_Kueche
            2019-10-04 23:46:53.218 - debug: heatingcontrol.0 create data points for 1OG_Schlafzimmer
            2019-10-04 23:46:53.265 - debug: heatingcontrol.0 room 1OG_Schlafzimmer with 3 periods
            2019-10-04 23:46:53.265 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
            2019-10-04 23:46:53.265 - debug: heatingcontrol.0 add state Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.0 max 5
            2019-10-04 23:46:53.265 - debug: heatingcontrol.0 add state Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.1 max 5
            2019-10-04 23:46:53.265 - debug: heatingcontrol.0 add state Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.2 max 5
            2019-10-04 23:46:53.265 - debug: heatingcontrol.0 create data points for 1OG_Kinderzimmer1
            2019-10-04 23:46:53.327 - debug: heatingcontrol.0 room 1OG_Kinderzimmer1 with 3 periods
            2019-10-04 23:46:53.327 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
            2019-10-04 23:46:53.327 - debug: heatingcontrol.0 add state Profiles.0.1OG_Kinderzimmer1.Mo-Su.Periods.0 max 5
            2019-10-04 23:46:53.327 - debug: heatingcontrol.0 add state Profiles.0.1OG_Kinderzimmer1.Mo-Su.Periods.1 max 5
            2019-10-04 23:46:53.327 - debug: heatingcontrol.0 add state Profiles.0.1OG_Kinderzimmer1.Mo-Su.Periods.2 max 5
            2019-10-04 23:46:53.327 - debug: heatingcontrol.0 create data points for 1OG_Kinderzimmer2
            2019-10-04 23:46:53.374 - debug: heatingcontrol.0 room 1OG_Kinderzimmer2 with 3 periods
            2019-10-04 23:46:53.374 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
            2019-10-04 23:46:53.374 - debug: heatingcontrol.0 add state Profiles.0.1OG_Kinderzimmer2.Mo-Su.Periods.0 max 5
            2019-10-04 23:46:53.374 - debug: heatingcontrol.0 add state Profiles.0.1OG_Kinderzimmer2.Mo-Su.Periods.1 max 5
            2019-10-04 23:46:53.374 - debug: heatingcontrol.0 add state Profiles.0.1OG_Kinderzimmer2.Mo-Su.Periods.2 max 5
            2019-10-04 23:46:53.374 - debug: heatingcontrol.0 not active.... EG_Bad
            2019-10-04 23:46:53.374 - debug: heatingcontrol.0 not active.... EG_Garten
            2019-10-04 23:46:53.374 - debug: heatingcontrol.0 not active.... 1OG_Bad
            2019-10-04 23:46:53.374 - debug: heatingcontrol.0 not active.... EG_Gang
            2019-10-04 23:46:53.374 - debug: heatingcontrol.0 not active.... 1OG_Gang
            2019-10-04 23:46:53.374 - debug: heatingcontrol.0 create data points for 2OG_Schlafzimmer
            2019-10-04 23:46:53.421 - debug: heatingcontrol.0 room 2OG_Schlafzimmer with 3 periods
            2019-10-04 23:46:53.421 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
            2019-10-04 23:46:53.421 - debug: heatingcontrol.0 add state Profiles.0.2OG_Schlafzimmer.Mo-Su.Periods.0 max 5
            2019-10-04 23:46:53.421 - debug: heatingcontrol.0 add state Profiles.0.2OG_Schlafzimmer.Mo-Su.Periods.1 max 5
            2019-10-04 23:46:53.421 - debug: heatingcontrol.0 add state Profiles.0.2OG_Schlafzimmer.Mo-Su.Periods.2 max 5
            2019-10-04 23:46:53.421 - debug: heatingcontrol.0 create data points for 2OG_Buero1
            2019-10-04 23:46:53.467 - debug: heatingcontrol.0 room 2OG_Buero1 with 3 periods
            2019-10-04 23:46:53.467 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
            2019-10-04 23:46:53.467 - debug: heatingcontrol.0 add state Profiles.0.2OG_Buero1.Mo-Su.Periods.0 max 5
            2019-10-04 23:46:53.467 - debug: heatingcontrol.0 add state Profiles.0.2OG_Buero1.Mo-Su.Periods.1 max 5
            2019-10-04 23:46:53.467 - debug: heatingcontrol.0 add state Profiles.0.2OG_Buero1.Mo-Su.Periods.2 max 5
            2019-10-04 23:46:53.467 - debug: heatingcontrol.0 create data points for 2OG_Buero2
            2019-10-04 23:46:53.530 - debug: heatingcontrol.0 room 2OG_Buero2 with 3 periods
            2019-10-04 23:46:53.530 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
            2019-10-04 23:46:53.530 - debug: heatingcontrol.0 add state Profiles.0.2OG_Buero2.Mo-Su.Periods.0 max 5
            2019-10-04 23:46:53.530 - debug: heatingcontrol.0 add state Profiles.0.2OG_Buero2.Mo-Su.Periods.1 max 5
            2019-10-04 23:46:53.530 - debug: heatingcontrol.0 add state Profiles.0.2OG_Buero2.Mo-Su.Periods.2 max 5
            2019-10-04 23:46:53.530 - debug: heatingcontrol.0 not active.... 2OG_Gang
            2019-10-04 23:46:53.530 - debug: heatingcontrol.0 create data points for 2OG_Bad
            2019-10-04 23:46:53.577 - debug: heatingcontrol.0 room 2OG_Bad with 3 periods
            2019-10-04 23:46:53.577 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
            2019-10-04 23:46:53.577 - debug: heatingcontrol.0 add state Profiles.0.2OG_Bad.Mo-Su.Periods.0 max 5
            2019-10-04 23:46:53.577 - debug: heatingcontrol.0 add state Profiles.0.2OG_Bad.Mo-Su.Periods.1 max 5
            2019-10-04 23:46:53.577 - debug: heatingcontrol.0 add state Profiles.0.2OG_Bad.Mo-Su.Periods.2 max 5
            2019-10-04 23:46:53.577 - debug: heatingcontrol.0 not active.... UG_Waschkueche
            2019-10-04 23:46:53.577 - debug: heatingcontrol.0 not active.... UG_Vorratsraum
            2019-10-04 23:46:53.577 - debug: heatingcontrol.0 not active.... UG_Heizung
            2019-10-04 23:46:53.577 - debug: heatingcontrol.0 not active.... UG_Gang
            2019-10-04 23:46:53.577 - debug: heatingcontrol.0 rooms 19
            2019-10-04 23:46:53.577 - debug: heatingcontrol.0 create data points for EG_Wohnzimmer
            2019-10-04 23:46:53.639 - debug: heatingcontrol.0 room EG_Wohnzimmer with 3 periods
            2019-10-04 23:46:53.639 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
            2019-10-04 23:46:53.639 - debug: heatingcontrol.0 add state Profiles.1.EG_Wohnzimmer.Mo-Su.Periods.0 max 5
            2019-10-04 23:46:53.639 - debug: heatingcontrol.0 add state Profiles.1.EG_Wohnzimmer.Mo-Su.Periods.1 max 5
            2019-10-04 23:46:53.639 - debug: heatingcontrol.0 add state Profiles.1.EG_Wohnzimmer.Mo-Su.Periods.2 max 5
            2019-10-04 23:46:53.639 - debug: heatingcontrol.0 not active.... EG_Kueche
            2019-10-04 23:46:53.639 - debug: heatingcontrol.0 create data points for 1OG_Schlafzimmer
            2019-10-04 23:46:53.686 - debug: heatingcontrol.0 room 1OG_Schlafzimmer with 3 periods
            2019-10-04 23:46:53.686 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
            2019-10-04 23:46:53.686 - debug: heatingcontrol.0 add state Profiles.1.1OG_Schlafzimmer.Mo-Su.Periods.0 max 5
            2019-10-04 23:46:53.686 - debug: heatingcontrol.0 add state Profiles.1.1OG_Schlafzimmer.Mo-Su.Periods.1 max 5
            2019-10-04 23:46:53.686 - debug: heatingcontrol.0 add state Profiles.1.1OG_Schlafzimmer.Mo-Su.Periods.2 max 5
            2019-10-04 23:46:53.686 - debug: heatingcontrol.0 create data points for 1OG_Kinderzimmer1
            2019-10-04 23:46:53.717 - debug: heatingcontrol.0 room 1OG_Kinderzimmer1 with 3 periods
            2019-10-04 23:46:53.717 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
            2019-10-04 23:46:53.717 - debug: heatingcontrol.0 add state Profiles.1.1OG_Kinderzimmer1.Mo-Su.Periods.0 max 5
            2019-10-04 23:46:53.717 - debug: heatingcontrol.0 add state Profiles.1.1OG_Kinderzimmer1.Mo-Su.Periods.1 max 5
            2019-10-04 23:46:53.717 - debug: heatingcontrol.0 add state Profiles.1.1OG_Kinderzimmer1.Mo-Su.Periods.2 max 5
            2019-10-04 23:46:53.717 - debug: heatingcontrol.0 create data points for 1OG_Kinderzimmer2
            2019-10-04 23:46:53.764 - debug: heatingcontrol.0 room 1OG_Kinderzimmer2 with 3 periods
            2019-10-04 23:46:53.764 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
            2019-10-04 23:46:53.764 - debug: heatingcontrol.0 add state Profiles.1.1OG_Kinderzimmer2.Mo-Su.Periods.0 max 5
            2019-10-04 23:46:53.764 - debug: heatingcontrol.0 add state Profiles.1.1OG_Kinderzimmer2.Mo-Su.Periods.1 max 5
            2019-10-04 23:46:53.764 - debug: heatingcontrol.0 add state Profiles.1.1OG_Kinderzimmer2.Mo-Su.Periods.2 max 5
            2019-10-04 23:46:53.764 - debug: heatingcontrol.0 not active.... EG_Bad
            2019-10-04 23:46:53.764 - debug: heatingcontrol.0 not active.... EG_Garten
            2019-10-04 23:46:53.764 - debug: heatingcontrol.0 not active.... 1OG_Bad
            2019-10-04 23:46:53.764 - debug: heatingcontrol.0 not active.... EG_Gang
            2019-10-04 23:46:53.764 - debug: heatingcontrol.0 not active.... 1OG_Gang
            2019-10-04 23:46:53.764 - debug: heatingcontrol.0 create data points for 2OG_Schlafzimmer
            2019-10-04 23:46:53.935 - debug: heatingcontrol.0 room 2OG_Schlafzimmer with 3 periods
            2019-10-04 23:46:53.935 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
            2019-10-04 23:46:53.935 - debug: heatingcontrol.0 add state Profiles.1.2OG_Schlafzimmer.Mo-Su.Periods.0 max 5
            2019-10-04 23:46:53.935 - debug: heatingcontrol.0 add state Profiles.1.2OG_Schlafzimmer.Mo-Su.Periods.1 max 5
            2019-10-04 23:46:53.935 - debug: heatingcontrol.0 add state Profiles.1.2OG_Schlafzimmer.Mo-Su.Periods.2 max 5
            2019-10-04 23:46:53.935 - debug: heatingcontrol.0 create data points for 2OG_Buero1
            2019-10-04 23:46:53.982 - debug: heatingcontrol.0 room 2OG_Buero1 with 3 periods
            2019-10-04 23:46:53.982 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
            2019-10-04 23:46:53.982 - debug: heatingcontrol.0 add state Profiles.1.2OG_Buero1.Mo-Su.Periods.0 max 5
            2019-10-04 23:46:53.982 - debug: heatingcontrol.0 add state Profiles.1.2OG_Buero1.Mo-Su.Periods.1 max 5
            2019-10-04 23:46:53.982 - debug: heatingcontrol.0 add state Profiles.1.2OG_Buero1.Mo-Su.Periods.2 max 5
            2019-10-04 23:46:53.982 - debug: heatingcontrol.0 create data points for 2OG_Buero2
            2019-10-04 23:46:54.029 - debug: heatingcontrol.0 room 2OG_Buero2 with 3 periods
            2019-10-04 23:46:54.029 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
            2019-10-04 23:46:54.029 - debug: heatingcontrol.0 add state Profiles.1.2OG_Buero2.Mo-Su.Periods.0 max 5
            2019-10-04 23:46:54.029 - debug: heatingcontrol.0 add state Profiles.1.2OG_Buero2.Mo-Su.Periods.1 max 5
            2019-10-04 23:46:54.029 - debug: heatingcontrol.0 add state Profiles.1.2OG_Buero2.Mo-Su.Periods.2 max 5
            2019-10-04 23:46:54.029 - debug: heatingcontrol.0 not active.... 2OG_Gang
            2019-10-04 23:46:54.029 - debug: heatingcontrol.0 create data points for 2OG_Bad
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 room 2OG_Bad with 3 periods
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 add state Profiles.1.2OG_Bad.Mo-Su.Periods.0 max 5
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 add state Profiles.1.2OG_Bad.Mo-Su.Periods.1 max 5
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 add state Profiles.1.2OG_Bad.Mo-Su.Periods.2 max 5
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 not active.... UG_Waschkueche
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 not active.... UG_Vorratsraum
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 not active.... UG_Heizung
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 not active.... UG_Gang
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 #start subscribtion
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe EG_Wohnzimmer hm-rpc.0.OEQ0440463.1.STATE
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe EG_Wohnzimmer hm-rpc.0.OEQ0440750.1.STATE
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe EG_Wohnzimmer hm-rpc.0.OEQ0566085.1.STATE
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe 1OG_Kinderzimmer1 hm-rpc.0.OEQ0568166.1.STATE
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe 1OG_Kinderzimmer2 hm-rpc.0.OEQ0440292.1.STATE
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe 2OG_Schlafzimmer hm-rpc.0.OEQ0496790.1.STATE
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe 2OG_Schlafzimmer hm-rpc.0.OEQ0496601.1.STATE
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe 2OG_Schlafzimmer hm-rpc.0.OEQ0496803.1.STATE
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe 2OG_Schlafzimmer hm-rpc.0.OEQ0496795.1.STATE
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe 2OG_Buero1 hm-rpc.0.OEQ0564053.1.STATE
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe 2OG_Buero2 hm-rpc.0.OEQ0496792.1.STATE
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe 2OG_Buero2 hm-rpc.0.OEQ0441055.1.STATE
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe 2OG_Buero2 hm-rpc.0.OEQ0496740.1.STATE
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe 2OG_Bad hm-rpc.0.OEQ0566263.1.STATE
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 #subscribtion finished
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 start CalculateNextTime, profile type 1
            2019-10-04 23:46:54.091 - debug: heatingcontrol.0 get profile
            2019-10-04 23:46:54.123 - debug: heatingcontrol.0 profile 0
            2019-10-04 23:46:54.154 - debug: heatingcontrol.0 ---found time for EG_Wohnzimmer at {"val":"00:00","ack":true,"ts":1569536219762,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569536219559} 00:00
            2019-10-04 23:46:54.154 - debug: heatingcontrol.0 push to list = 00,00
            2019-10-04 23:46:54.169 - debug: heatingcontrol.0 ---found time for EG_Wohnzimmer at {"val":"06:00","ack":true,"ts":1569528844920,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569528844701} 06:00
            2019-10-04 23:46:54.169 - debug: heatingcontrol.0 push to list = 06,00
            2019-10-04 23:46:54.169 - debug: heatingcontrol.0 ---found time for EG_Wohnzimmer at {"val":"23:00","ack":true,"ts":1569451191041,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569451190916} 23:00
            2019-10-04 23:46:54.169 - debug: heatingcontrol.0 push to list = 23,00
            2019-10-04 23:46:54.169 - debug: heatingcontrol.0 ---found time for 1OG_Schlafzimmer at {"val":"00:00","ack":true,"ts":1569625025328,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625024782} 00:00
            2019-10-04 23:46:54.169 - debug: heatingcontrol.0 ---found time for 1OG_Schlafzimmer at {"val":"06:00","ack":true,"ts":1569625002817,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625002162} 06:00
            2019-10-04 23:46:54.169 - debug: heatingcontrol.0 ---found time for 1OG_Schlafzimmer at {"val":"23:00","ack":true,"ts":1569625009572,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625009119} 23:00
            2019-10-04 23:46:54.169 - debug: heatingcontrol.0 ---found time for 1OG_Kinderzimmer1 at {"val":"00:00","ack":true,"ts":1569625044843,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625044328} 00:00
            2019-10-04 23:46:54.185 - debug: heatingcontrol.0 ---found time for 1OG_Kinderzimmer1 at {"val":"06:00","ack":true,"ts":1569625049913,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625049367} 06:00
            2019-10-04 23:46:54.201 - debug: heatingcontrol.0 ---found time for 1OG_Kinderzimmer1 at {"val":"23:00","ack":true,"ts":1569625055592,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625054858} 23:00
            2019-10-04 23:46:54.201 - debug: heatingcontrol.0 ---found time for 1OG_Kinderzimmer2 at {"val":"00:00","ack":true,"ts":1569625092782,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625092189} 00:00
            2019-10-04 23:46:54.201 - debug: heatingcontrol.0 ---found time for 1OG_Kinderzimmer2 at {"val":"06:00","ack":true,"ts":1569625097509,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625096822} 06:00
            2019-10-04 23:46:54.232 - debug: heatingcontrol.0 ---found time for 1OG_Kinderzimmer2 at {"val":"23:00","ack":true,"ts":1569625101300,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625100645} 23:00
            2019-10-04 23:46:54.232 - debug: heatingcontrol.0 ---found time for 2OG_Schlafzimmer at {"val":"00:00","ack":true,"ts":1569625240249,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625239578} 00:00
            2019-10-04 23:46:54.232 - debug: heatingcontrol.0 ---found time for 2OG_Schlafzimmer at {"val":"06:00","ack":true,"ts":1569625244695,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625244087} 06:00
            2019-10-04 23:46:54.232 - debug: heatingcontrol.0 ---found time for 2OG_Schlafzimmer at {"val":"23:00","ack":true,"ts":1569625247690,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625247207} 23:00
            2019-10-04 23:46:54.247 - debug: heatingcontrol.0 ---found time for 2OG_Buero1 at {"val":"00:00","ack":true,"ts":1569625256021,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625255522} 00:00
            2019-10-04 23:46:54.247 - debug: heatingcontrol.0 ---found time for 2OG_Buero1 at {"val":"06:00","ack":true,"ts":1569625260358,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625259718} 06:00
            2019-10-04 23:46:54.247 - debug: heatingcontrol.0 ---found time for 2OG_Buero1 at {"val":"23:00","ack":true,"ts":1569625265880,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625265116} 23:00
            2019-10-04 23:46:54.247 - debug: heatingcontrol.0 ---found time for 2OG_Buero2 at {"val":"00:00","ack":true,"ts":1569625273524,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625272822} 00:00
            2019-10-04 23:46:54.247 - debug: heatingcontrol.0 ---found time for 2OG_Buero2 at {"val":"06:00","ack":true,"ts":1569625276972,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625276316} 06:00
            2019-10-04 23:46:54.247 - debug: heatingcontrol.0 ---found time for 2OG_Buero2 at {"val":"23:00","ack":true,"ts":1569625281823,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625281199} 23:00
            2019-10-04 23:46:54.263 - debug: heatingcontrol.0 ---found time for 2OG_Bad at {"val":"00:00","ack":true,"ts":1569625291058,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625290419} 00:00
            2019-10-04 23:46:54.263 - debug: heatingcontrol.0 ---found time for 2OG_Bad at {"val":"06:00","ack":true,"ts":1569625295848,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625295036} 06:00
            2019-10-04 23:46:54.263 - debug: heatingcontrol.0 ---found time for 2OG_Bad at {"val":"23:00","ack":true,"ts":1569625298843,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625298219} 23:00
            2019-10-04 23:46:54.263 - debug: heatingcontrol.0 create cron job #0 at 0:0 string: 0 0 0 * * * Europe/Berlin
            2019-10-04 23:46:54.279 - debug: heatingcontrol.0 create cron job #1 at 6:0 string: 0 0 6 * * * Europe/Berlin
            2019-10-04 23:46:54.279 - debug: heatingcontrol.0 create cron job #2 at 23:0 string: 0 0 23 * * * Europe/Berlin
            2019-10-04 23:46:54.279 - debug: heatingcontrol.0 cron jobs
            2019-10-04 23:46:54.279 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 00:00:00
            2019-10-04 23:46:54.279 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 06:00:00
            2019-10-04 23:46:54.294 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 23:00:00
            2019-10-04 23:46:54.294 - info: heatingcontrol.0 calculating new target temperatures
            2019-10-04 23:46:54.325 - debug: heatingcontrol.0 profile type 1
            2019-10-04 23:46:54.325 - debug: heatingcontrol.0 get profile
            2019-10-04 23:46:54.325 - debug: heatingcontrol.0 profile 0
            2019-10-04 23:46:54.325 - debug: heatingcontrol.0 check room EG_Wohnzimmer
            2019-10-04 23:46:54.325 - debug: heatingcontrol.0 number of periods 3
            2019-10-04 23:46:54.325 - debug: heatingcontrol.0 check ID Profiles.0.EG_Wohnzimmer.Mo-Su.Periods.0.time
            2019-10-04 23:46:54.325 - debug: heatingcontrol.0 check time for EG_Wohnzimmer Profiles.0.EG_Wohnzimmer.Mo-Su.Periods.0.time 18.0
            2019-10-04 23:46:54.325 - debug: heatingcontrol.0 check ID Profiles.0.EG_Wohnzimmer.Mo-Su.Periods.1.time
            2019-10-04 23:46:54.325 - debug: heatingcontrol.0 check time for EG_Wohnzimmer Profiles.0.EG_Wohnzimmer.Mo-Su.Periods.1.time 22
            2019-10-04 23:46:54.325 - debug: heatingcontrol.0 check ID Profiles.0.EG_Wohnzimmer.Mo-Su.Periods.2.time
            2019-10-04 23:46:54.341 - debug: heatingcontrol.0 check time for EG_Wohnzimmer Profiles.0.EG_Wohnzimmer.Mo-Su.Periods.2.time 18.0
            2019-10-04 23:46:54.341 - debug: heatingcontrol.0 ### 18.0 0 0 0 0 0
            2019-10-04 23:46:54.341 - info: heatingcontrol.0 room EG_Wohnzimmer Thermostat EG_Wohnzimmer_Heizung_11_Kanal4.SET_TEMPERATURE set to 18
            2019-10-04 23:46:54.341 - info: heatingcontrol.0 room EG_Wohnzimmer Thermostat EG_Wohnzimmer_Heizung_12_Kanal4.SET_TEMPERATURE set to 18
            2019-10-04 23:46:54.341 - info: heatingcontrol.0 room EG_Wohnzimmer Thermostat EG_Gang_Heizung_11_Kanal4.SET_TEMPERATURE set to 18
            2019-10-04 23:46:54.357 - debug: heatingcontrol.0 check room 1OG_Schlafzimmer
            2019-10-04 23:46:54.357 - debug: heatingcontrol.0 number of periods 3
            2019-10-04 23:46:54.357 - debug: heatingcontrol.0 check ID Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.0.time
            2019-10-04 23:46:54.357 - debug: heatingcontrol.0 check time for 1OG_Schlafzimmer Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.0.time 20.0
            2019-10-04 23:46:54.357 - debug: heatingcontrol.0 check ID Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.1.time
            2019-10-04 23:46:54.372 - debug: heatingcontrol.0 check time for 1OG_Schlafzimmer Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.1.time 17.0
            2019-10-04 23:46:54.372 - debug: heatingcontrol.0 check ID Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.2.time
            2019-10-04 23:46:54.372 - debug: heatingcontrol.0 check time for 1OG_Schlafzimmer Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.2.time 20.0
            2019-10-04 23:46:54.372 - debug: heatingcontrol.0 ### 20.0 0 0 0 0 0
            2019-10-04 23:46:54.372 - debug: heatingcontrol.0 check room 1OG_Kinderzimmer1
            2019-10-04 23:46:54.372 - debug: heatingcontrol.0 number of periods 3
            2019-10-04 23:46:54.372 - debug: heatingcontrol.0 check ID Profiles.0.1OG_Kinderzimmer1.Mo-Su.Periods.0.time
            2019-10-04 23:46:54.388 - debug: heatingcontrol.0 check time for 1OG_Kinderzimmer1 Profiles.0.1OG_Kinderzimmer1.Mo-Su.Periods.0.time 20.0
            2019-10-04 23:46:54.388 - debug: heatingcontrol.0 check ID Profiles.0.1OG_Kinderzimmer1.Mo-Su.Periods.1.time
            2019-10-04 23:46:54.388 - debug: heatingcontrol.0 check time for 1OG_Kinderzimmer1 Profiles.0.1OG_Kinderzimmer1.Mo-Su.Periods.1.time 17.0
            2019-10-04 23:46:54.388 - debug: heatingcontrol.0 check ID Profiles.0.1OG_Kinderzimmer1.Mo-Su.Periods.2.time
            2019-10-04 23:46:54.388 - debug: heatingcontrol.0 check time for 1OG_Kinderzimmer1 Profiles.0.1OG_Kinderzimmer1.Mo-Su.Periods.2.time 20.0
            2019-10-04 23:46:54.388 - debug: heatingcontrol.0 ### 20.0 0 0 0 0 0
            2019-10-04 23:46:54.388 - info: heatingcontrol.0 room 1OG_Kinderzimmer1 Thermostat 1OG_Kinderzimmer1_Heizung_11_Kanal4.SET_TEMPERATURE set to 20
            2019-10-04 23:46:54.388 - debug: heatingcontrol.0 check room 1OG_Kinderzimmer2
            2019-10-04 23:46:54.388 - debug: heatingcontrol.0 number of periods 3
            2019-10-04 23:46:54.388 - debug: heatingcontrol.0 check ID Profiles.0.1OG_Kinderzimmer2.Mo-Su.Periods.0.time
            2019-10-04 23:46:54.403 - debug: heatingcontrol.0 check time for 1OG_Kinderzimmer2 Profiles.0.1OG_Kinderzimmer2.Mo-Su.Periods.0.time 17.0
            2019-10-04 23:46:54.403 - debug: heatingcontrol.0 check ID Profiles.0.1OG_Kinderzimmer2.Mo-Su.Periods.1.time
            2019-10-04 23:46:54.403 - debug: heatingcontrol.0 check time for 1OG_Kinderzimmer2 Profiles.0.1OG_Kinderzimmer2.Mo-Su.Periods.1.time 20.0
            2019-10-04 23:46:54.403 - debug: heatingcontrol.0 check ID Profiles.0.1OG_Kinderzimmer2.Mo-Su.Periods.2.time
            2019-10-04 23:46:54.403 - debug: heatingcontrol.0 check time for 1OG_Kinderzimmer2 Profiles.0.1OG_Kinderzimmer2.Mo-Su.Periods.2.time 17.0
            2019-10-04 23:46:54.403 - debug: heatingcontrol.0 ### 17.0 0 0 0 0 0
            2019-10-04 23:46:54.403 - info: heatingcontrol.0 room 1OG_Kinderzimmer2 Thermostat 1OG_Kinderzimmer 2_Heizung_11_Kanal4.SET_TEMPERATURE set to 17
            2019-10-04 23:46:54.435 - debug: heatingcontrol.0 check room 2OG_Schlafzimmer
            2019-10-04 23:46:54.435 - debug: heatingcontrol.0 number of periods 3
            2019-10-04 23:46:54.435 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Schlafzimmer.Mo-Su.Periods.0.time
            2019-10-04 23:46:54.435 - debug: heatingcontrol.0 check time for 2OG_Schlafzimmer Profiles.0.2OG_Schlafzimmer.Mo-Su.Periods.0.time 18.0
            2019-10-04 23:46:54.435 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Schlafzimmer.Mo-Su.Periods.1.time
            2019-10-04 23:46:54.450 - debug: heatingcontrol.0 check time for 2OG_Schlafzimmer Profiles.0.2OG_Schlafzimmer.Mo-Su.Periods.1.time 18.0
            2019-10-04 23:46:54.450 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Schlafzimmer.Mo-Su.Periods.2.time
            2019-10-04 23:46:54.450 - debug: heatingcontrol.0 check time for 2OG_Schlafzimmer Profiles.0.2OG_Schlafzimmer.Mo-Su.Periods.2.time 18.0
            2019-10-04 23:46:54.450 - debug: heatingcontrol.0 ### 18.0 0 0 0 0 0
            2019-10-04 23:46:54.450 - info: heatingcontrol.0 room 2OG_Schlafzimmer Thermostat 2OG_Schlafzimmer_Heizung_11_Kanal4.SET_TEMPERATURE set to 18
            2019-10-04 23:46:54.450 - info: heatingcontrol.0 room 2OG_Schlafzimmer Thermostat hm-rpc.1.000E570999A890.1.ACTUAL_TEMPERATURE set to 18
            2019-10-04 23:46:54.466 - debug: heatingcontrol.0 check room 2OG_Buero1
            2019-10-04 23:46:54.466 - debug: heatingcontrol.0 number of periods 3
            2019-10-04 23:46:54.466 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Buero1.Mo-Su.Periods.0.time
            2019-10-04 23:46:54.466 - debug: heatingcontrol.0 check time for 2OG_Buero1 Profiles.0.2OG_Buero1.Mo-Su.Periods.0.time 19
            2019-10-04 23:46:54.466 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Buero1.Mo-Su.Periods.1.time
            2019-10-04 23:46:54.481 - debug: heatingcontrol.0 check time for 2OG_Buero1 Profiles.0.2OG_Buero1.Mo-Su.Periods.1.time 22.0
            2019-10-04 23:46:54.481 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Buero1.Mo-Su.Periods.2.time
            2019-10-04 23:46:54.481 - debug: heatingcontrol.0 check time for 2OG_Buero1 Profiles.0.2OG_Buero1.Mo-Su.Periods.2.time 19.0
            2019-10-04 23:46:54.481 - debug: heatingcontrol.0 ### 19.0 0 0 0 0 0
            2019-10-04 23:46:54.481 - info: heatingcontrol.0 room 2OG_Buero1 Thermostat 2OG_Buero1_Heizung_11_Kanal4.SET_TEMPERATURE set to 19
            2019-10-04 23:46:54.497 - debug: heatingcontrol.0 check room 2OG_Buero2
            2019-10-04 23:46:54.497 - debug: heatingcontrol.0 number of periods 3
            2019-10-04 23:46:54.497 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Buero2.Mo-Su.Periods.0.time
            2019-10-04 23:46:54.497 - debug: heatingcontrol.0 check time for 2OG_Buero2 Profiles.0.2OG_Buero2.Mo-Su.Periods.0.time 18.0
            2019-10-04 23:46:54.497 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Buero2.Mo-Su.Periods.1.time
            2019-10-04 23:46:54.497 - debug: heatingcontrol.0 check time for 2OG_Buero2 Profiles.0.2OG_Buero2.Mo-Su.Periods.1.time 19.0
            2019-10-04 23:46:54.497 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Buero2.Mo-Su.Periods.2.time
            2019-10-04 23:46:54.513 - debug: heatingcontrol.0 check time for 2OG_Buero2 Profiles.0.2OG_Buero2.Mo-Su.Periods.2.time 18.0
            2019-10-04 23:46:54.513 - debug: heatingcontrol.0 ### 18.0 0 0 0 0 0
            2019-10-04 23:46:54.513 - info: heatingcontrol.0 room 2OG_Buero2 Thermostat 2OG_Buero2_Heizung_11_Kanal4.SET_TEMPERATURE set to 18
            2019-10-04 23:46:54.513 - debug: heatingcontrol.0 check room 2OG_Bad
            2019-10-04 23:46:54.513 - debug: heatingcontrol.0 number of periods 3
            2019-10-04 23:46:54.513 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Bad.Mo-Su.Periods.0.time
            2019-10-04 23:46:54.513 - debug: heatingcontrol.0 check time for 2OG_Bad Profiles.0.2OG_Bad.Mo-Su.Periods.0.time 18.0
            2019-10-04 23:46:54.513 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Bad.Mo-Su.Periods.1.time
            2019-10-04 23:46:54.528 - debug: heatingcontrol.0 check time for 2OG_Bad Profiles.0.2OG_Bad.Mo-Su.Periods.1.time 22.0
            2019-10-04 23:46:54.528 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Bad.Mo-Su.Periods.2.time
            2019-10-04 23:46:54.528 - debug: heatingcontrol.0 check time for 2OG_Bad Profiles.0.2OG_Bad.Mo-Su.Periods.2.time 18.0
            2019-10-04 23:46:54.528 - debug: heatingcontrol.0 ### 18.0 0 0 0 0 0
            2019-10-04 23:46:54.528 - info: heatingcontrol.0 room 2OG_Bad Thermostat 2OG_Bad_Heizung_11_Kanal4.SET_TEMPERATURE set to 18
            2019-10-04 23:46:54.528 - debug: heatingcontrol.0 cron jobs
            2019-10-04 23:46:54.528 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 00:00:00
            2019-10-04 23:46:54.528 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 06:00:00
            2019-10-04 23:46:54.528 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 23:00:00
            2019-10-04 23:46:55.886 - error: hm-rpc.0 xmlrpc -> setValue ["4","SET_TEMPERATURE",18] FLOAT
            2019-10-04 23:46:55.886 - error: hm-rpc.0 Error: XML-RPC fault: Failure
            2019-10-04 23:46:56.104 - debug: heatingcontrol.0 system.adapter.admin.0: logging false
            2019-10-04 23:46:56.635 - error: hm-rpc.0 xmlrpc -> setValue ["4","SET_TEMPERATURE",18] FLOAT
            2019-10-04 23:46:56.635 - error: hm-rpc.0 Error: XML-RPC fault: Failure
            2019-10-04 23:46:57.368 - error: hm-rpc.0 xmlrpc -> setValue ["4","SET_TEMPERATURE",18] FLOAT
            2019-10-04 23:46:57.368 - error: hm-rpc.0 Error: XML-RPC fault: Failure
            2019-10-04 23:46:58.054 - debug: heatingcontrol.0 system.adapter.admin.0: logging true
            2019-10-04 23:46:58.148 - error: hm-rpc.0 xmlrpc -> setValue ["4","SET_TEMPERATURE",20] FLOAT
            2019-10-04 23:46:58.148 - error: hm-rpc.0 Error: XML-RPC fault: Failure
            2019-10-04 23:46:58.897 - error: hm-rpc.0 xmlrpc -> setValue ["4","SET_TEMPERATURE",17] FLOAT
            2019-10-04 23:46:58.897 - error: hm-rpc.0 Error: XML-RPC fault: Failure
            2019-10-04 23:46:59.646 - error: hm-rpc.0 xmlrpc -> setValue ["4","SET_TEMPERATURE",18] FLOAT
            2019-10-04 23:46:59.646 - error: hm-rpc.0 Error: XML-RPC fault: Failure
            2019-10-04 23:47:00.395 - error: hm-rpc.0 xmlrpc -> setValue ["4","SET_TEMPERATURE",18] FLOAT
            2019-10-04 23:47:00.395 - error: hm-rpc.0 Error: XML-RPC fault: Failure
            2019-10-04 23:47:01.143 - error: hm-rpc.0 xmlrpc -> setValue ["4","SET_TEMPERATURE",19] FLOAT
            2019-10-04 23:47:01.143 - error: hm-rpc.0 Error: XML-RPC fault: Failure
            2019-10-04 23:47:01.923 - error: hm-rpc.0 xmlrpc -> setValue ["4","SET_TEMPERATURE",18] FLOAT
            2019-10-04 23:47:01.923 - error: hm-rpc.0 Error: XML-RPC fault: Failure
            2019-10-04 23:47:02.719 - error: hm-rpc.0 xmlrpc -> setValue ["4","SET_TEMPERATURE",18] FLOAT
            2019-10-04 23:47:02.719 - error: hm-rpc.0 Error: XML-RPC fault: Failure
            2019-10-04 23:47:33.622 - debug: heatingcontrol.0 ### handle state change hm-rpc.0.OEQ0496790.1.STATE {"val":false,"ack":true,"ts":1570225653622,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1567698413860}
            2019-10-04 23:47:33.622 - debug: heatingcontrol.0 ### 111 not handled
            2019-10-04 23:47:33.622 - debug: heatingcontrol.0 handle actors hm-rpc.0.OEQ0496790.1.STATE{"val":false,"ack":true,"ts":1570225653622,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1567698413860}
            2019-10-04 23:47:33.622 - debug: heatingcontrol.0 ### {"id":19,"name":"2OG_Schlafzimmer_Fenster_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0496790.1.STATE","isActive":true,"type":3,"room":"2OG_Schlafzimmer"}
            2019-10-04 23:47:33.622 - debug: heatingcontrol.0 set 2OG_Schlafzimmer window open to {"val":false,"ack":true,"ts":1570225653622,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1567698413860}
            2019-10-04 23:47:33.622 - info: heatingcontrol.0 calculating new target temperatures
            Falls du noch mehr Daten benötigst, suche ich die gerne zusammen.
            Vielen Dank für die Unterstützung
            Rene_HMR 1 Antwort Letzte Antwort
            • X xADDRx
              Ben
              maarten
              #175
              @xADDRx
              Ich habe es ziemlich simpel gehalten mit meiner vis, für mich passt es so aber wahrscheinlich gibt es elegantere Lösungen:
              Die Einstellungen sind jeweils pro Raum, das Widget bleibt das gleiche.
              [{"tpl":"tplImage","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/icons-mfd-png/temp_temperature.png","stretch":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false},"style":{"left":"210px","top":"92px","width":"35px","height":"35px","border-style":"none","z-index":"2","position":""},"widgetSet":"basic"},{"tpl":"tplImage","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/icons-mfd-png/weather_humidity.png","stretch":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false},"style":{"left":"216px","top":"122px","width":"31px","height":"36px","border-style":"none","z-index":"2"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"87px","top":"155px","width":"630px","height":"1px","z-index":"3","background-color":"#FFFFFF"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"hm-rpc.1.000E570999A397.1.ACTUAL_TEMPERATURE","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append_plural":" °C"},"style":{"left":"245px","top":"105px","color":"#FFFFFF","width":"68px","height":"18px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"hm-rpc.1.000E570999A397.1.HUMIDITY","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append_plural":" %"},"style":{"left":"244px","top":"130px","color":"#FFFFFF","width":"68px","height":"18px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"80px","top":"95px","width":"644px","height":"123px","border-width":"1px","border-style":"solid","border-color":"#000000","border-radius":"10px","opacity":"","z-index":"1","background-color":"#000000"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"Schlafzimmer"},"style":{"left":"90px","top":"105px","width":"146px","height":"20px","color":"#ffffff","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplJquiInputDatetime","data":{"oid":"heatingcontrol.0.Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.0.time","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"timeOnly":true,"hideSeconds":true,"size":"1"},"style":{"left":"221px","top":"164px","width":"64px","height":"10px","z-index":"4"},"widgetSet":"jqui"},{"tpl":"tplJquiInput","data":{"oid":"heatingcontrol.0.Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.0.Temperature","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"label":"","digits":"1","size":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"274px","top":"192px","width":"73px","height":"24px","z-index":"4","color":"#ffffff"},"widgetSet":"jqui"},{"tpl":"tplJquiInputDatetime","data":{"oid":"heatingcontrol.0.Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.1.time","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"timeOnly":true,"hideSeconds":true,"size":"1"},"style":{"left":"332px","top":"164px","width":"64px","height":"10px","z-index":"4"},"widgetSet":"jqui"},{"tpl":"tplJquiInput","data":{"oid":"heatingcontrol.0.Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.1.Temperature","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"label":"","digits":"1","size":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"390px","top":"192px","width":"73px","height":"24px","z-index":"4","color":"#ffffff"},"widgetSet":"jqui"},{"tpl":"tplJquiInputDatetime","data":{"oid":"heatingcontrol.0.Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.2.time","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"timeOnly":true,"hideSeconds":true,"size":"1"},"style":{"left":"450px","top":"164px","width":"64px","height":"10px","z-index":"4"},"widgetSet":"jqui"},{"tpl":"tplJquiInput","data":{"oid":"heatingcontrol.0.Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.2.Temperature","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"label":"","digits":"1","size":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"508px","top":"192px","width":"72px","height":"24px","z-index":"4","color":"#ffffff"},"widgetSet":"jqui"},{"tpl":"tplJquiInputDatetime","data":{"oid":"Datenpunkte.0.EndeHeizperiodeGlobal","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"timeOnly":true,"hideSeconds":true,"size":"1"},"style":{"left":"568px","top":"164px","width":"64px","height":"10px","z-index":"4"},"widgetSet":"jqui"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"°C"},"style":{"left":"327px","top":"197px","width":"22px","height":"20px","color":"#737373","z-index":"10"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"°C"},"style":{"left":"443px","top":"197px","width":"22px","height":"20px","color":"#737373","z-index":"10"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"°C"},"style":{"left":"561px","top":"197px","width":"22px","height":"20px","color":"#737373","z-index":"10"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"bis"},"style":{"left":"301px","top":"167px","width":"22px","height":"20px","color":"#ffffff","z-index":"10"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"bis"},"style":{"left":"416px","top":"167px","width":"22px","height":"20px","color":"#ffffff","z-index":"10"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"bis"},"style":{"left":"533px","top":"167px","width":"22px","height":"20px","color":"#ffffff","z-index":"10"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"von"},"style":{"left":"187px","top":"167px","width":"29px","height":"20px","color":"#ffffff","z-index":"10"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"Temperaturabsenkung bei Abwesenheit"},"style":{"left":"424px","top":"102px","width":"289px","height":"20px","color":"#ffffff","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplJquiInput","data":{"oid":"heatingcontrol.0.Profiles.0.1OG_Schlafzimmer.AbsentDecrease","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"label":"","digits":"1","size":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"343px","top":"100px","width":"73px","height":"24px","z-index":"4","color":"#ffffff"},"widgetSet":"jqui"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"°C"},"style":{"left":"395px","top":"105px","width":"22px","height":"20px","color":"#737373","z-index":"10"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"heatingcontrol.0.Profiles.0.1OG_Schlafzimmer.CurrentTimePeriod","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"90px","top":"129px","color":"#ffffff","width":"118px","height":"20px","z-index":"4"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"Temperaturabsenkung bei Fenster offen"},"style":{"left":"424px","top":"130px","width":"289px","height":"20px","color":"#ffffff","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplJquiInput","data":{"oid":"heatingcontrol.0.Profiles.0.1OG_Schlafzimmer.WindowOpenDecrease","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"label":"","digits":"1","size":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"343px","top":"128px","width":"73px","height":"24px","z-index":"4","color":"#ffffff"},"widgetSet":"jqui"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"°C"},"style":{"left":"395px","top":"133px","width":"22px","height":"20px","color":"#737373","z-index":"10"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"Heizplan"},"style":{"left":"90px","top":"166px","width":"67px","height":"16px","color":"#ffffff","z-index":"3"},"widgetSet":"basic"}]
              • ChaotC Chaot
                Ich habe auf Verdacht mal den Adapter installiert, weil meine DECT Thermostate mit dem alten Script ja auch gelaufen sind.
                Und das ist das derzeitige Resultat:
                fritzdect.0	2019-09-25 21:20:19.023	info	Comet ID: 119600101272 identified for command (mode) : 0
                fritzdect.0	2019-09-25 21:20:19.018	info	Comet ID: 119600101272 identified for command (targettemp) : 21
                heatingcontrol.0	2019-09-25 21:20:19.016	info	room Martin Thermostat Target Temp set to 21
                fritzdect.0	2019-09-25 21:20:19.009	info	Comet ID: 119610273248 identified for command (mode) : 0
                fritzdect.0	2019-09-25 21:20:19.003	info	Comet ID: 119610273248 identified for command (targettemp) : 21
                heatingcontrol.0	2019-09-25 21:20:19.001	info	room Toilette Thermostat Target Temp set to 21
                fritzdect.0	2019-09-25 21:20:18.990	info	Comet ID: 119600122088 identified for command (mode) : 0
                fritzdect.0	2019-09-25 21:20:18.971	info	Comet ID: 119600122088 identified for command (targettemp) : 21
                heatingcontrol.0	2019-09-25 21:20:18.968	info	room Schlafzimmer Thermostat Target Temp set to 21
                fritzdect.0	2019-09-25 21:20:18.965	info	HGROUP ID: 92:40:6E-900 identified for command (mode) : 0
                fritzdect.0	2019-09-25 21:20:18.959	info	HGROUP ID: 92:40:6E-900 identified for command (targettemp) : 21
                heatingcontrol.0	2019-09-25 21:20:18.957	info	room Wohnzimmer Thermostat Target Temp set to 21
                heatingcontrol.0	2019-09-25 21:20:18.928	info	calculating new target temperatures
                heatingcontrol.0	2019-09-25 21:20:17.759	info	starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.heatingcontrol, node: v10.16.3
                heatingcontrol.0	2019-09-25 21:20:17.728	info	States connected to redis: 127.0.0.1:6379
                Es scheint das die Thermostate direkt richtig erkannt werden.
                zur zusätzlichen Erklärung: Command Mode 0 ist AUTO
                Jetzt muss ich nur noch an einer VIS basteln.
                Oder hat hier jemand was einfaches?
                Und eine Funktion hätte ich gerne noch.
                Lässt sich der Datenpunkt "Mode" auch direkt ansteuern über die Datenpunkte oder nur aus dem Adapter heraus?
                Dann könnte ich den bei "Fenster offen" direkt auf OFF Steuern anstatt nur auf Absenkung zu gehen.
                hilde0407
                #176
                @Chaot Kannst Du mir bitte genau erklären, wie Du die Fritz!Dect Thermostate im Adapter eingetragen hast?
                • H hilde0407
                  ChaotC Offline
                  ChaotC Offline
                  Chaot
                  #177
                  @hilde0407 Ich habe die im Adapter unter Thermostate eingetragen.
                  Als Adapter zusätzlich muss FritzDect laufen
                  Räume und Gewerke waren vom Script vorher schon zugeordnet.
                  OID aktueller Wert ist dann fritzdect.0.Thermostatkennung.actualtemp
                  und OID Zielwert ist dann fritzdect.0.Thermostatkennung.actualtemp
                  H 1 Antwort Letzte Antwort
                  • M maarten
                    @Rene_HM
                    Vielen Dank für deine Antwort, ich bin leider erst jetzt dazu gekommen. Ist mir bewusst, dass diese Adapterversion noch in Entwicklung ist, bis jetzt funktioniert Sie jedoch ganz gut.
                    Ich musste mich kurz einlesen wie man einen Adapter debut und hoffe ich habe soweit alles richtig gemacht:
                    undefined2019-10-04 23:46:51.627 - info: host.Home-PC object change system.adapter.heatingcontrol.0
                    2019-10-04 23:46:51.642 - info: host.Home-PC instance system.adapter.heatingcontrol.0 started with pid 7708
                    2019-10-04 23:46:52.828 - debug: heatingcontrol.0 objectDB connected
                    2019-10-04 23:46:52.859 - debug: heatingcontrol.0 statesDB connected
                    2019-10-04 23:46:52.953 - info: heatingcontrol.0 starting. Version 0.3.0 in C:/ioBroker/node_modules/iobroker.heatingcontrol, node: v10.14.1
                    2019-10-04 23:46:52.968 - debug: heatingcontrol.0 devices [{"id":1,"name":"EG_Wohnzimmer_Heizung_11_Kanal4.SET_TEMPERATURE","OID_Current":"hm-rpc.1.000E570999A5A3.1.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0846278.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"EG_Wohnzimmer"},{"id":2,"name":"EG_Wohnzimmer_Heizung_11_Kanal4.SET_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0846278.4.SET_TEMPERATURE","isActive":true,"type":2,"room":"EG_Wohnzimmer"},{"id":3,"name":"EG_Wohnzimmer_Heizung_12_Kanal4.SET_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0843010.4.SET_TEMPERATURE","isActive":true,"type":2,"room":"EG_Wohnzimmer"},{"id":4,"name":"EG_Wohnzimmer_Tuere_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0440463.1.STATE","isActive":true,"type":3,"room":"EG_Wohnzimmer"},{"id":5,"name":"EG_Gang_Tuere_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0440750.1.STATE","isActive":true,"type":3,"room":"EG_Wohnzimmer"},{"id":6,"name":"EG_Küche_Fenster_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0566085.1.STATE","isActive":true,"type":3,"room":"EG_Wohnzimmer"},{"id":7,"name":"EG_Wohnzimmer_Heizung_12_Kanal4.SET_TEMPERATURE","OID_Current":"hm-rpc.1.000E570999A5A3.1.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0843010.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"EG_Wohnzimmer"},{"id":8,"name":"EG_Gang_Heizung_11_Kanal4.SET_TEMPERATURE","OID_Current":"hm-rpc.1.000E570999A5A3.1.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0843134.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"EG_Wohnzimmer"},{"id":9,"name":"EG_Wohnzimmer_Tuere_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0440463.1.STATE","isActive":true,"type":3,"room":"EG_Wohnzimmer"},{"id":10,"name":"1OG_Schlafzimmer_Heizung_11_Kanal4.SET_TEMPERATURE","OID_Current":"hm-rpc.1.000E570999A397.1.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0841727.4.SET_TEMPERATURE","isActive":false,"type":1,"room":"1OG_Schlafzimmer"},{"id":11,"name":"1OG_Schlafzimmer_Fenster_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0566218.1.STATE","isActive":false,"type":3,"room":"1OG_Schlafzimmer"},{"id":12,"name":"1OG_Schlafzimmer_Tuere_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0566065.1.STATE","isActive":false,"type":3,"room":"1OG_Schlafzimmer"},{"id":13,"name":"1OG_Kinderzimmer1_Heizung_11_Kanal4.SET_TEMPERATURE","OID_Current":"hm-rpc.1.000E570999A3A5.1.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0844685.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"1OG_Kinderzimmer1"},{"id":14,"name":"1OG_Kinderzimmer1_Fenster_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0568166.1.STATE","isActive":true,"type":3,"room":"1OG_Kinderzimmer1"},{"id":15,"name":"1OG_Kinderzimmer 2_Heizung_11_Kanal4.SET_TEMPERATURE","OID_Current":"hm-rpc.1.000E570999A87B.1.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ1248833.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"1OG_Kinderzimmer2"},{"id":16,"name":"1OG_Kinderzimmer2_Fenster_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0440292.1.STATE","isActive":true,"type":3,"room":"1OG_Kinderzimmer2"},{"id":17,"name":"2OG_Schlafzimmer_Heizung_11_Kanal4.SET_TEMPERATURE","OID_Current":"hm-rpc.1.000E570999A890.1.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0846127.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"2OG_Schlafzimmer"},{"id":18,"name":"hm-rpc.1.000E570999A890.1.ACTUAL_TEMPERATURE","OID_Current":"hm-rpc.1.000E570999A890.1.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0846141.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"2OG_Schlafzimmer"},{"id":19,"name":"2OG_Schlafzimmer_Fenster_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0496790.1.STATE","isActive":true,"type":3,"room":"2OG_Schlafzimmer"},{"id":20,"name":"2OG_Schlafzimmer_Fenster_12_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0496601.1.STATE","isActive":true,"type":3,"room":"2OG_Schlafzimmer"},{"id":21,"name":"2OG_Schlafzimmer_Fenster_13_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0496803.1.STATE","isActive":true,"type":3,"room":"2OG_Schlafzimmer"},{"id":22,"name":"2OG_Schlafzimmer_Fenster_14_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0496795.1.STATE","isActive":true,"type":3,"room":"2OG_Schlafzimmer"},{"id":23,"name":"2OG_Buero1_Heizung_11_Kanal4.SET_TEMPERATURE","OID_Current":"hm-rpc.1.000E570999A5AF.1.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0845933.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"2OG_Buero1"},{"id":24,"name":"2OG_Buero11_Fenster_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0564053.1.STATE","isActive":true,"type":3,"room":"2OG_Buero1"},{"id":25,"name":"2OG_Buero2_Heizung_11_Kanal4.SET_TEMPERATURE","OID_Current":"hm-rpc.1.000E570999A419.1.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0846143.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"2OG_Buero2"},{"id":26,"name":"2OG_Buero2_Fenster_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0496792.1.STATE","isActive":true,"type":3,"room":"2OG_Buero2"},{"id":27,"name":"2OG_Buero2_Fenster_12_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0441055.1.STATE","isActive":true,"type":3,"room":"2OG_Buero2"},{"id":28,"name":"2OG_Buero2_Fenster_13_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0496740.1.STATE","isActive":true,"type":3,"room":"2OG_Buero2"},{"id":29,"name":"2OG_Bad_Heizung_11_Kanal4.SET_TEMPERATURE","OID_Current":"hm-rpc.1.000E570999A897.1.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0845830.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"2OG_Bad"},{"id":30,"name":"2OG_Bad_Fenster_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0566263.1.STATE","isActive":true,"type":3,"room":"2OG_Bad"}]
                    2019-10-04 23:46:52.968 - debug: heatingcontrol.0 CreateDatepoints
                    2019-10-04 23:46:53.171 - debug: heatingcontrol.0 rooms 19
                    2019-10-04 23:46:53.171 - debug: heatingcontrol.0 create data points for EG_Wohnzimmer
                    2019-10-04 23:46:53.218 - debug: heatingcontrol.0 room EG_Wohnzimmer with 3 periods
                    2019-10-04 23:46:53.218 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
                    2019-10-04 23:46:53.218 - debug: heatingcontrol.0 add state Profiles.0.EG_Wohnzimmer.Mo-Su.Periods.0 max 5
                    2019-10-04 23:46:53.218 - debug: heatingcontrol.0 add state Profiles.0.EG_Wohnzimmer.Mo-Su.Periods.1 max 5
                    2019-10-04 23:46:53.218 - debug: heatingcontrol.0 add state Profiles.0.EG_Wohnzimmer.Mo-Su.Periods.2 max 5
                    2019-10-04 23:46:53.218 - debug: heatingcontrol.0 not active.... EG_Kueche
                    2019-10-04 23:46:53.218 - debug: heatingcontrol.0 create data points for 1OG_Schlafzimmer
                    2019-10-04 23:46:53.265 - debug: heatingcontrol.0 room 1OG_Schlafzimmer with 3 periods
                    2019-10-04 23:46:53.265 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
                    2019-10-04 23:46:53.265 - debug: heatingcontrol.0 add state Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.0 max 5
                    2019-10-04 23:46:53.265 - debug: heatingcontrol.0 add state Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.1 max 5
                    2019-10-04 23:46:53.265 - debug: heatingcontrol.0 add state Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.2 max 5
                    2019-10-04 23:46:53.265 - debug: heatingcontrol.0 create data points for 1OG_Kinderzimmer1
                    2019-10-04 23:46:53.327 - debug: heatingcontrol.0 room 1OG_Kinderzimmer1 with 3 periods
                    2019-10-04 23:46:53.327 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
                    2019-10-04 23:46:53.327 - debug: heatingcontrol.0 add state Profiles.0.1OG_Kinderzimmer1.Mo-Su.Periods.0 max 5
                    2019-10-04 23:46:53.327 - debug: heatingcontrol.0 add state Profiles.0.1OG_Kinderzimmer1.Mo-Su.Periods.1 max 5
                    2019-10-04 23:46:53.327 - debug: heatingcontrol.0 add state Profiles.0.1OG_Kinderzimmer1.Mo-Su.Periods.2 max 5
                    2019-10-04 23:46:53.327 - debug: heatingcontrol.0 create data points for 1OG_Kinderzimmer2
                    2019-10-04 23:46:53.374 - debug: heatingcontrol.0 room 1OG_Kinderzimmer2 with 3 periods
                    2019-10-04 23:46:53.374 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
                    2019-10-04 23:46:53.374 - debug: heatingcontrol.0 add state Profiles.0.1OG_Kinderzimmer2.Mo-Su.Periods.0 max 5
                    2019-10-04 23:46:53.374 - debug: heatingcontrol.0 add state Profiles.0.1OG_Kinderzimmer2.Mo-Su.Periods.1 max 5
                    2019-10-04 23:46:53.374 - debug: heatingcontrol.0 add state Profiles.0.1OG_Kinderzimmer2.Mo-Su.Periods.2 max 5
                    2019-10-04 23:46:53.374 - debug: heatingcontrol.0 not active.... EG_Bad
                    2019-10-04 23:46:53.374 - debug: heatingcontrol.0 not active.... EG_Garten
                    2019-10-04 23:46:53.374 - debug: heatingcontrol.0 not active.... 1OG_Bad
                    2019-10-04 23:46:53.374 - debug: heatingcontrol.0 not active.... EG_Gang
                    2019-10-04 23:46:53.374 - debug: heatingcontrol.0 not active.... 1OG_Gang
                    2019-10-04 23:46:53.374 - debug: heatingcontrol.0 create data points for 2OG_Schlafzimmer
                    2019-10-04 23:46:53.421 - debug: heatingcontrol.0 room 2OG_Schlafzimmer with 3 periods
                    2019-10-04 23:46:53.421 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
                    2019-10-04 23:46:53.421 - debug: heatingcontrol.0 add state Profiles.0.2OG_Schlafzimmer.Mo-Su.Periods.0 max 5
                    2019-10-04 23:46:53.421 - debug: heatingcontrol.0 add state Profiles.0.2OG_Schlafzimmer.Mo-Su.Periods.1 max 5
                    2019-10-04 23:46:53.421 - debug: heatingcontrol.0 add state Profiles.0.2OG_Schlafzimmer.Mo-Su.Periods.2 max 5
                    2019-10-04 23:46:53.421 - debug: heatingcontrol.0 create data points for 2OG_Buero1
                    2019-10-04 23:46:53.467 - debug: heatingcontrol.0 room 2OG_Buero1 with 3 periods
                    2019-10-04 23:46:53.467 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
                    2019-10-04 23:46:53.467 - debug: heatingcontrol.0 add state Profiles.0.2OG_Buero1.Mo-Su.Periods.0 max 5
                    2019-10-04 23:46:53.467 - debug: heatingcontrol.0 add state Profiles.0.2OG_Buero1.Mo-Su.Periods.1 max 5
                    2019-10-04 23:46:53.467 - debug: heatingcontrol.0 add state Profiles.0.2OG_Buero1.Mo-Su.Periods.2 max 5
                    2019-10-04 23:46:53.467 - debug: heatingcontrol.0 create data points for 2OG_Buero2
                    2019-10-04 23:46:53.530 - debug: heatingcontrol.0 room 2OG_Buero2 with 3 periods
                    2019-10-04 23:46:53.530 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
                    2019-10-04 23:46:53.530 - debug: heatingcontrol.0 add state Profiles.0.2OG_Buero2.Mo-Su.Periods.0 max 5
                    2019-10-04 23:46:53.530 - debug: heatingcontrol.0 add state Profiles.0.2OG_Buero2.Mo-Su.Periods.1 max 5
                    2019-10-04 23:46:53.530 - debug: heatingcontrol.0 add state Profiles.0.2OG_Buero2.Mo-Su.Periods.2 max 5
                    2019-10-04 23:46:53.530 - debug: heatingcontrol.0 not active.... 2OG_Gang
                    2019-10-04 23:46:53.530 - debug: heatingcontrol.0 create data points for 2OG_Bad
                    2019-10-04 23:46:53.577 - debug: heatingcontrol.0 room 2OG_Bad with 3 periods
                    2019-10-04 23:46:53.577 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
                    2019-10-04 23:46:53.577 - debug: heatingcontrol.0 add state Profiles.0.2OG_Bad.Mo-Su.Periods.0 max 5
                    2019-10-04 23:46:53.577 - debug: heatingcontrol.0 add state Profiles.0.2OG_Bad.Mo-Su.Periods.1 max 5
                    2019-10-04 23:46:53.577 - debug: heatingcontrol.0 add state Profiles.0.2OG_Bad.Mo-Su.Periods.2 max 5
                    2019-10-04 23:46:53.577 - debug: heatingcontrol.0 not active.... UG_Waschkueche
                    2019-10-04 23:46:53.577 - debug: heatingcontrol.0 not active.... UG_Vorratsraum
                    2019-10-04 23:46:53.577 - debug: heatingcontrol.0 not active.... UG_Heizung
                    2019-10-04 23:46:53.577 - debug: heatingcontrol.0 not active.... UG_Gang
                    2019-10-04 23:46:53.577 - debug: heatingcontrol.0 rooms 19
                    2019-10-04 23:46:53.577 - debug: heatingcontrol.0 create data points for EG_Wohnzimmer
                    2019-10-04 23:46:53.639 - debug: heatingcontrol.0 room EG_Wohnzimmer with 3 periods
                    2019-10-04 23:46:53.639 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
                    2019-10-04 23:46:53.639 - debug: heatingcontrol.0 add state Profiles.1.EG_Wohnzimmer.Mo-Su.Periods.0 max 5
                    2019-10-04 23:46:53.639 - debug: heatingcontrol.0 add state Profiles.1.EG_Wohnzimmer.Mo-Su.Periods.1 max 5
                    2019-10-04 23:46:53.639 - debug: heatingcontrol.0 add state Profiles.1.EG_Wohnzimmer.Mo-Su.Periods.2 max 5
                    2019-10-04 23:46:53.639 - debug: heatingcontrol.0 not active.... EG_Kueche
                    2019-10-04 23:46:53.639 - debug: heatingcontrol.0 create data points for 1OG_Schlafzimmer
                    2019-10-04 23:46:53.686 - debug: heatingcontrol.0 room 1OG_Schlafzimmer with 3 periods
                    2019-10-04 23:46:53.686 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
                    2019-10-04 23:46:53.686 - debug: heatingcontrol.0 add state Profiles.1.1OG_Schlafzimmer.Mo-Su.Periods.0 max 5
                    2019-10-04 23:46:53.686 - debug: heatingcontrol.0 add state Profiles.1.1OG_Schlafzimmer.Mo-Su.Periods.1 max 5
                    2019-10-04 23:46:53.686 - debug: heatingcontrol.0 add state Profiles.1.1OG_Schlafzimmer.Mo-Su.Periods.2 max 5
                    2019-10-04 23:46:53.686 - debug: heatingcontrol.0 create data points for 1OG_Kinderzimmer1
                    2019-10-04 23:46:53.717 - debug: heatingcontrol.0 room 1OG_Kinderzimmer1 with 3 periods
                    2019-10-04 23:46:53.717 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
                    2019-10-04 23:46:53.717 - debug: heatingcontrol.0 add state Profiles.1.1OG_Kinderzimmer1.Mo-Su.Periods.0 max 5
                    2019-10-04 23:46:53.717 - debug: heatingcontrol.0 add state Profiles.1.1OG_Kinderzimmer1.Mo-Su.Periods.1 max 5
                    2019-10-04 23:46:53.717 - debug: heatingcontrol.0 add state Profiles.1.1OG_Kinderzimmer1.Mo-Su.Periods.2 max 5
                    2019-10-04 23:46:53.717 - debug: heatingcontrol.0 create data points for 1OG_Kinderzimmer2
                    2019-10-04 23:46:53.764 - debug: heatingcontrol.0 room 1OG_Kinderzimmer2 with 3 periods
                    2019-10-04 23:46:53.764 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
                    2019-10-04 23:46:53.764 - debug: heatingcontrol.0 add state Profiles.1.1OG_Kinderzimmer2.Mo-Su.Periods.0 max 5
                    2019-10-04 23:46:53.764 - debug: heatingcontrol.0 add state Profiles.1.1OG_Kinderzimmer2.Mo-Su.Periods.1 max 5
                    2019-10-04 23:46:53.764 - debug: heatingcontrol.0 add state Profiles.1.1OG_Kinderzimmer2.Mo-Su.Periods.2 max 5
                    2019-10-04 23:46:53.764 - debug: heatingcontrol.0 not active.... EG_Bad
                    2019-10-04 23:46:53.764 - debug: heatingcontrol.0 not active.... EG_Garten
                    2019-10-04 23:46:53.764 - debug: heatingcontrol.0 not active.... 1OG_Bad
                    2019-10-04 23:46:53.764 - debug: heatingcontrol.0 not active.... EG_Gang
                    2019-10-04 23:46:53.764 - debug: heatingcontrol.0 not active.... 1OG_Gang
                    2019-10-04 23:46:53.764 - debug: heatingcontrol.0 create data points for 2OG_Schlafzimmer
                    2019-10-04 23:46:53.935 - debug: heatingcontrol.0 room 2OG_Schlafzimmer with 3 periods
                    2019-10-04 23:46:53.935 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
                    2019-10-04 23:46:53.935 - debug: heatingcontrol.0 add state Profiles.1.2OG_Schlafzimmer.Mo-Su.Periods.0 max 5
                    2019-10-04 23:46:53.935 - debug: heatingcontrol.0 add state Profiles.1.2OG_Schlafzimmer.Mo-Su.Periods.1 max 5
                    2019-10-04 23:46:53.935 - debug: heatingcontrol.0 add state Profiles.1.2OG_Schlafzimmer.Mo-Su.Periods.2 max 5
                    2019-10-04 23:46:53.935 - debug: heatingcontrol.0 create data points for 2OG_Buero1
                    2019-10-04 23:46:53.982 - debug: heatingcontrol.0 room 2OG_Buero1 with 3 periods
                    2019-10-04 23:46:53.982 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
                    2019-10-04 23:46:53.982 - debug: heatingcontrol.0 add state Profiles.1.2OG_Buero1.Mo-Su.Periods.0 max 5
                    2019-10-04 23:46:53.982 - debug: heatingcontrol.0 add state Profiles.1.2OG_Buero1.Mo-Su.Periods.1 max 5
                    2019-10-04 23:46:53.982 - debug: heatingcontrol.0 add state Profiles.1.2OG_Buero1.Mo-Su.Periods.2 max 5
                    2019-10-04 23:46:53.982 - debug: heatingcontrol.0 create data points for 2OG_Buero2
                    2019-10-04 23:46:54.029 - debug: heatingcontrol.0 room 2OG_Buero2 with 3 periods
                    2019-10-04 23:46:54.029 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
                    2019-10-04 23:46:54.029 - debug: heatingcontrol.0 add state Profiles.1.2OG_Buero2.Mo-Su.Periods.0 max 5
                    2019-10-04 23:46:54.029 - debug: heatingcontrol.0 add state Profiles.1.2OG_Buero2.Mo-Su.Periods.1 max 5
                    2019-10-04 23:46:54.029 - debug: heatingcontrol.0 add state Profiles.1.2OG_Buero2.Mo-Su.Periods.2 max 5
                    2019-10-04 23:46:54.029 - debug: heatingcontrol.0 not active.... 2OG_Gang
                    2019-10-04 23:46:54.029 - debug: heatingcontrol.0 create data points for 2OG_Bad
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 room 2OG_Bad with 3 periods
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 2
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 add state Profiles.1.2OG_Bad.Mo-Su.Periods.0 max 5
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 add state Profiles.1.2OG_Bad.Mo-Su.Periods.1 max 5
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 add state Profiles.1.2OG_Bad.Mo-Su.Periods.2 max 5
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 not active.... UG_Waschkueche
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 not active.... UG_Vorratsraum
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 not active.... UG_Heizung
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 not active.... UG_Gang
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 #start subscribtion
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe EG_Wohnzimmer hm-rpc.0.OEQ0440463.1.STATE
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe EG_Wohnzimmer hm-rpc.0.OEQ0440750.1.STATE
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe EG_Wohnzimmer hm-rpc.0.OEQ0566085.1.STATE
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe 1OG_Kinderzimmer1 hm-rpc.0.OEQ0568166.1.STATE
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe 1OG_Kinderzimmer2 hm-rpc.0.OEQ0440292.1.STATE
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe 2OG_Schlafzimmer hm-rpc.0.OEQ0496790.1.STATE
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe 2OG_Schlafzimmer hm-rpc.0.OEQ0496601.1.STATE
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe 2OG_Schlafzimmer hm-rpc.0.OEQ0496803.1.STATE
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe 2OG_Schlafzimmer hm-rpc.0.OEQ0496795.1.STATE
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe 2OG_Buero1 hm-rpc.0.OEQ0564053.1.STATE
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe 2OG_Buero2 hm-rpc.0.OEQ0496792.1.STATE
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe 2OG_Buero2 hm-rpc.0.OEQ0441055.1.STATE
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe 2OG_Buero2 hm-rpc.0.OEQ0496740.1.STATE
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 subscribe 2OG_Bad hm-rpc.0.OEQ0566263.1.STATE
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 #subscribtion finished
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 start CalculateNextTime, profile type 1
                    2019-10-04 23:46:54.091 - debug: heatingcontrol.0 get profile
                    2019-10-04 23:46:54.123 - debug: heatingcontrol.0 profile 0
                    2019-10-04 23:46:54.154 - debug: heatingcontrol.0 ---found time for EG_Wohnzimmer at {"val":"00:00","ack":true,"ts":1569536219762,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569536219559} 00:00
                    2019-10-04 23:46:54.154 - debug: heatingcontrol.0 push to list = 00,00
                    2019-10-04 23:46:54.169 - debug: heatingcontrol.0 ---found time for EG_Wohnzimmer at {"val":"06:00","ack":true,"ts":1569528844920,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569528844701} 06:00
                    2019-10-04 23:46:54.169 - debug: heatingcontrol.0 push to list = 06,00
                    2019-10-04 23:46:54.169 - debug: heatingcontrol.0 ---found time for EG_Wohnzimmer at {"val":"23:00","ack":true,"ts":1569451191041,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569451190916} 23:00
                    2019-10-04 23:46:54.169 - debug: heatingcontrol.0 push to list = 23,00
                    2019-10-04 23:46:54.169 - debug: heatingcontrol.0 ---found time for 1OG_Schlafzimmer at {"val":"00:00","ack":true,"ts":1569625025328,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625024782} 00:00
                    2019-10-04 23:46:54.169 - debug: heatingcontrol.0 ---found time for 1OG_Schlafzimmer at {"val":"06:00","ack":true,"ts":1569625002817,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625002162} 06:00
                    2019-10-04 23:46:54.169 - debug: heatingcontrol.0 ---found time for 1OG_Schlafzimmer at {"val":"23:00","ack":true,"ts":1569625009572,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625009119} 23:00
                    2019-10-04 23:46:54.169 - debug: heatingcontrol.0 ---found time for 1OG_Kinderzimmer1 at {"val":"00:00","ack":true,"ts":1569625044843,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625044328} 00:00
                    2019-10-04 23:46:54.185 - debug: heatingcontrol.0 ---found time for 1OG_Kinderzimmer1 at {"val":"06:00","ack":true,"ts":1569625049913,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625049367} 06:00
                    2019-10-04 23:46:54.201 - debug: heatingcontrol.0 ---found time for 1OG_Kinderzimmer1 at {"val":"23:00","ack":true,"ts":1569625055592,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625054858} 23:00
                    2019-10-04 23:46:54.201 - debug: heatingcontrol.0 ---found time for 1OG_Kinderzimmer2 at {"val":"00:00","ack":true,"ts":1569625092782,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625092189} 00:00
                    2019-10-04 23:46:54.201 - debug: heatingcontrol.0 ---found time for 1OG_Kinderzimmer2 at {"val":"06:00","ack":true,"ts":1569625097509,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625096822} 06:00
                    2019-10-04 23:46:54.232 - debug: heatingcontrol.0 ---found time for 1OG_Kinderzimmer2 at {"val":"23:00","ack":true,"ts":1569625101300,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625100645} 23:00
                    2019-10-04 23:46:54.232 - debug: heatingcontrol.0 ---found time for 2OG_Schlafzimmer at {"val":"00:00","ack":true,"ts":1569625240249,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625239578} 00:00
                    2019-10-04 23:46:54.232 - debug: heatingcontrol.0 ---found time for 2OG_Schlafzimmer at {"val":"06:00","ack":true,"ts":1569625244695,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625244087} 06:00
                    2019-10-04 23:46:54.232 - debug: heatingcontrol.0 ---found time for 2OG_Schlafzimmer at {"val":"23:00","ack":true,"ts":1569625247690,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625247207} 23:00
                    2019-10-04 23:46:54.247 - debug: heatingcontrol.0 ---found time for 2OG_Buero1 at {"val":"00:00","ack":true,"ts":1569625256021,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625255522} 00:00
                    2019-10-04 23:46:54.247 - debug: heatingcontrol.0 ---found time for 2OG_Buero1 at {"val":"06:00","ack":true,"ts":1569625260358,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625259718} 06:00
                    2019-10-04 23:46:54.247 - debug: heatingcontrol.0 ---found time for 2OG_Buero1 at {"val":"23:00","ack":true,"ts":1569625265880,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625265116} 23:00
                    2019-10-04 23:46:54.247 - debug: heatingcontrol.0 ---found time for 2OG_Buero2 at {"val":"00:00","ack":true,"ts":1569625273524,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625272822} 00:00
                    2019-10-04 23:46:54.247 - debug: heatingcontrol.0 ---found time for 2OG_Buero2 at {"val":"06:00","ack":true,"ts":1569625276972,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625276316} 06:00
                    2019-10-04 23:46:54.247 - debug: heatingcontrol.0 ---found time for 2OG_Buero2 at {"val":"23:00","ack":true,"ts":1569625281823,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625281199} 23:00
                    2019-10-04 23:46:54.263 - debug: heatingcontrol.0 ---found time for 2OG_Bad at {"val":"00:00","ack":true,"ts":1569625291058,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625290419} 00:00
                    2019-10-04 23:46:54.263 - debug: heatingcontrol.0 ---found time for 2OG_Bad at {"val":"06:00","ack":true,"ts":1569625295848,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625295036} 06:00
                    2019-10-04 23:46:54.263 - debug: heatingcontrol.0 ---found time for 2OG_Bad at {"val":"23:00","ack":true,"ts":1569625298843,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1569625298219} 23:00
                    2019-10-04 23:46:54.263 - debug: heatingcontrol.0 create cron job #0 at 0:0 string: 0 0 0 * * * Europe/Berlin
                    2019-10-04 23:46:54.279 - debug: heatingcontrol.0 create cron job #1 at 6:0 string: 0 0 6 * * * Europe/Berlin
                    2019-10-04 23:46:54.279 - debug: heatingcontrol.0 create cron job #2 at 23:0 string: 0 0 23 * * * Europe/Berlin
                    2019-10-04 23:46:54.279 - debug: heatingcontrol.0 cron jobs
                    2019-10-04 23:46:54.279 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 00:00:00
                    2019-10-04 23:46:54.279 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 06:00:00
                    2019-10-04 23:46:54.294 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 23:00:00
                    2019-10-04 23:46:54.294 - info: heatingcontrol.0 calculating new target temperatures
                    2019-10-04 23:46:54.325 - debug: heatingcontrol.0 profile type 1
                    2019-10-04 23:46:54.325 - debug: heatingcontrol.0 get profile
                    2019-10-04 23:46:54.325 - debug: heatingcontrol.0 profile 0
                    2019-10-04 23:46:54.325 - debug: heatingcontrol.0 check room EG_Wohnzimmer
                    2019-10-04 23:46:54.325 - debug: heatingcontrol.0 number of periods 3
                    2019-10-04 23:46:54.325 - debug: heatingcontrol.0 check ID Profiles.0.EG_Wohnzimmer.Mo-Su.Periods.0.time
                    2019-10-04 23:46:54.325 - debug: heatingcontrol.0 check time for EG_Wohnzimmer Profiles.0.EG_Wohnzimmer.Mo-Su.Periods.0.time 18.0
                    2019-10-04 23:46:54.325 - debug: heatingcontrol.0 check ID Profiles.0.EG_Wohnzimmer.Mo-Su.Periods.1.time
                    2019-10-04 23:46:54.325 - debug: heatingcontrol.0 check time for EG_Wohnzimmer Profiles.0.EG_Wohnzimmer.Mo-Su.Periods.1.time 22
                    2019-10-04 23:46:54.325 - debug: heatingcontrol.0 check ID Profiles.0.EG_Wohnzimmer.Mo-Su.Periods.2.time
                    2019-10-04 23:46:54.341 - debug: heatingcontrol.0 check time for EG_Wohnzimmer Profiles.0.EG_Wohnzimmer.Mo-Su.Periods.2.time 18.0
                    2019-10-04 23:46:54.341 - debug: heatingcontrol.0 ### 18.0 0 0 0 0 0
                    2019-10-04 23:46:54.341 - info: heatingcontrol.0 room EG_Wohnzimmer Thermostat EG_Wohnzimmer_Heizung_11_Kanal4.SET_TEMPERATURE set to 18
                    2019-10-04 23:46:54.341 - info: heatingcontrol.0 room EG_Wohnzimmer Thermostat EG_Wohnzimmer_Heizung_12_Kanal4.SET_TEMPERATURE set to 18
                    2019-10-04 23:46:54.341 - info: heatingcontrol.0 room EG_Wohnzimmer Thermostat EG_Gang_Heizung_11_Kanal4.SET_TEMPERATURE set to 18
                    2019-10-04 23:46:54.357 - debug: heatingcontrol.0 check room 1OG_Schlafzimmer
                    2019-10-04 23:46:54.357 - debug: heatingcontrol.0 number of periods 3
                    2019-10-04 23:46:54.357 - debug: heatingcontrol.0 check ID Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.0.time
                    2019-10-04 23:46:54.357 - debug: heatingcontrol.0 check time for 1OG_Schlafzimmer Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.0.time 20.0
                    2019-10-04 23:46:54.357 - debug: heatingcontrol.0 check ID Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.1.time
                    2019-10-04 23:46:54.372 - debug: heatingcontrol.0 check time for 1OG_Schlafzimmer Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.1.time 17.0
                    2019-10-04 23:46:54.372 - debug: heatingcontrol.0 check ID Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.2.time
                    2019-10-04 23:46:54.372 - debug: heatingcontrol.0 check time for 1OG_Schlafzimmer Profiles.0.1OG_Schlafzimmer.Mo-Su.Periods.2.time 20.0
                    2019-10-04 23:46:54.372 - debug: heatingcontrol.0 ### 20.0 0 0 0 0 0
                    2019-10-04 23:46:54.372 - debug: heatingcontrol.0 check room 1OG_Kinderzimmer1
                    2019-10-04 23:46:54.372 - debug: heatingcontrol.0 number of periods 3
                    2019-10-04 23:46:54.372 - debug: heatingcontrol.0 check ID Profiles.0.1OG_Kinderzimmer1.Mo-Su.Periods.0.time
                    2019-10-04 23:46:54.388 - debug: heatingcontrol.0 check time for 1OG_Kinderzimmer1 Profiles.0.1OG_Kinderzimmer1.Mo-Su.Periods.0.time 20.0
                    2019-10-04 23:46:54.388 - debug: heatingcontrol.0 check ID Profiles.0.1OG_Kinderzimmer1.Mo-Su.Periods.1.time
                    2019-10-04 23:46:54.388 - debug: heatingcontrol.0 check time for 1OG_Kinderzimmer1 Profiles.0.1OG_Kinderzimmer1.Mo-Su.Periods.1.time 17.0
                    2019-10-04 23:46:54.388 - debug: heatingcontrol.0 check ID Profiles.0.1OG_Kinderzimmer1.Mo-Su.Periods.2.time
                    2019-10-04 23:46:54.388 - debug: heatingcontrol.0 check time for 1OG_Kinderzimmer1 Profiles.0.1OG_Kinderzimmer1.Mo-Su.Periods.2.time 20.0
                    2019-10-04 23:46:54.388 - debug: heatingcontrol.0 ### 20.0 0 0 0 0 0
                    2019-10-04 23:46:54.388 - info: heatingcontrol.0 room 1OG_Kinderzimmer1 Thermostat 1OG_Kinderzimmer1_Heizung_11_Kanal4.SET_TEMPERATURE set to 20
                    2019-10-04 23:46:54.388 - debug: heatingcontrol.0 check room 1OG_Kinderzimmer2
                    2019-10-04 23:46:54.388 - debug: heatingcontrol.0 number of periods 3
                    2019-10-04 23:46:54.388 - debug: heatingcontrol.0 check ID Profiles.0.1OG_Kinderzimmer2.Mo-Su.Periods.0.time
                    2019-10-04 23:46:54.403 - debug: heatingcontrol.0 check time for 1OG_Kinderzimmer2 Profiles.0.1OG_Kinderzimmer2.Mo-Su.Periods.0.time 17.0
                    2019-10-04 23:46:54.403 - debug: heatingcontrol.0 check ID Profiles.0.1OG_Kinderzimmer2.Mo-Su.Periods.1.time
                    2019-10-04 23:46:54.403 - debug: heatingcontrol.0 check time for 1OG_Kinderzimmer2 Profiles.0.1OG_Kinderzimmer2.Mo-Su.Periods.1.time 20.0
                    2019-10-04 23:46:54.403 - debug: heatingcontrol.0 check ID Profiles.0.1OG_Kinderzimmer2.Mo-Su.Periods.2.time
                    2019-10-04 23:46:54.403 - debug: heatingcontrol.0 check time for 1OG_Kinderzimmer2 Profiles.0.1OG_Kinderzimmer2.Mo-Su.Periods.2.time 17.0
                    2019-10-04 23:46:54.403 - debug: heatingcontrol.0 ### 17.0 0 0 0 0 0
                    2019-10-04 23:46:54.403 - info: heatingcontrol.0 room 1OG_Kinderzimmer2 Thermostat 1OG_Kinderzimmer 2_Heizung_11_Kanal4.SET_TEMPERATURE set to 17
                    2019-10-04 23:46:54.435 - debug: heatingcontrol.0 check room 2OG_Schlafzimmer
                    2019-10-04 23:46:54.435 - debug: heatingcontrol.0 number of periods 3
                    2019-10-04 23:46:54.435 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Schlafzimmer.Mo-Su.Periods.0.time
                    2019-10-04 23:46:54.435 - debug: heatingcontrol.0 check time for 2OG_Schlafzimmer Profiles.0.2OG_Schlafzimmer.Mo-Su.Periods.0.time 18.0
                    2019-10-04 23:46:54.435 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Schlafzimmer.Mo-Su.Periods.1.time
                    2019-10-04 23:46:54.450 - debug: heatingcontrol.0 check time for 2OG_Schlafzimmer Profiles.0.2OG_Schlafzimmer.Mo-Su.Periods.1.time 18.0
                    2019-10-04 23:46:54.450 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Schlafzimmer.Mo-Su.Periods.2.time
                    2019-10-04 23:46:54.450 - debug: heatingcontrol.0 check time for 2OG_Schlafzimmer Profiles.0.2OG_Schlafzimmer.Mo-Su.Periods.2.time 18.0
                    2019-10-04 23:46:54.450 - debug: heatingcontrol.0 ### 18.0 0 0 0 0 0
                    2019-10-04 23:46:54.450 - info: heatingcontrol.0 room 2OG_Schlafzimmer Thermostat 2OG_Schlafzimmer_Heizung_11_Kanal4.SET_TEMPERATURE set to 18
                    2019-10-04 23:46:54.450 - info: heatingcontrol.0 room 2OG_Schlafzimmer Thermostat hm-rpc.1.000E570999A890.1.ACTUAL_TEMPERATURE set to 18
                    2019-10-04 23:46:54.466 - debug: heatingcontrol.0 check room 2OG_Buero1
                    2019-10-04 23:46:54.466 - debug: heatingcontrol.0 number of periods 3
                    2019-10-04 23:46:54.466 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Buero1.Mo-Su.Periods.0.time
                    2019-10-04 23:46:54.466 - debug: heatingcontrol.0 check time for 2OG_Buero1 Profiles.0.2OG_Buero1.Mo-Su.Periods.0.time 19
                    2019-10-04 23:46:54.466 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Buero1.Mo-Su.Periods.1.time
                    2019-10-04 23:46:54.481 - debug: heatingcontrol.0 check time for 2OG_Buero1 Profiles.0.2OG_Buero1.Mo-Su.Periods.1.time 22.0
                    2019-10-04 23:46:54.481 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Buero1.Mo-Su.Periods.2.time
                    2019-10-04 23:46:54.481 - debug: heatingcontrol.0 check time for 2OG_Buero1 Profiles.0.2OG_Buero1.Mo-Su.Periods.2.time 19.0
                    2019-10-04 23:46:54.481 - debug: heatingcontrol.0 ### 19.0 0 0 0 0 0
                    2019-10-04 23:46:54.481 - info: heatingcontrol.0 room 2OG_Buero1 Thermostat 2OG_Buero1_Heizung_11_Kanal4.SET_TEMPERATURE set to 19
                    2019-10-04 23:46:54.497 - debug: heatingcontrol.0 check room 2OG_Buero2
                    2019-10-04 23:46:54.497 - debug: heatingcontrol.0 number of periods 3
                    2019-10-04 23:46:54.497 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Buero2.Mo-Su.Periods.0.time
                    2019-10-04 23:46:54.497 - debug: heatingcontrol.0 check time for 2OG_Buero2 Profiles.0.2OG_Buero2.Mo-Su.Periods.0.time 18.0
                    2019-10-04 23:46:54.497 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Buero2.Mo-Su.Periods.1.time
                    2019-10-04 23:46:54.497 - debug: heatingcontrol.0 check time for 2OG_Buero2 Profiles.0.2OG_Buero2.Mo-Su.Periods.1.time 19.0
                    2019-10-04 23:46:54.497 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Buero2.Mo-Su.Periods.2.time
                    2019-10-04 23:46:54.513 - debug: heatingcontrol.0 check time for 2OG_Buero2 Profiles.0.2OG_Buero2.Mo-Su.Periods.2.time 18.0
                    2019-10-04 23:46:54.513 - debug: heatingcontrol.0 ### 18.0 0 0 0 0 0
                    2019-10-04 23:46:54.513 - info: heatingcontrol.0 room 2OG_Buero2 Thermostat 2OG_Buero2_Heizung_11_Kanal4.SET_TEMPERATURE set to 18
                    2019-10-04 23:46:54.513 - debug: heatingcontrol.0 check room 2OG_Bad
                    2019-10-04 23:46:54.513 - debug: heatingcontrol.0 number of periods 3
                    2019-10-04 23:46:54.513 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Bad.Mo-Su.Periods.0.time
                    2019-10-04 23:46:54.513 - debug: heatingcontrol.0 check time for 2OG_Bad Profiles.0.2OG_Bad.Mo-Su.Periods.0.time 18.0
                    2019-10-04 23:46:54.513 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Bad.Mo-Su.Periods.1.time
                    2019-10-04 23:46:54.528 - debug: heatingcontrol.0 check time for 2OG_Bad Profiles.0.2OG_Bad.Mo-Su.Periods.1.time 22.0
                    2019-10-04 23:46:54.528 - debug: heatingcontrol.0 check ID Profiles.0.2OG_Bad.Mo-Su.Periods.2.time
                    2019-10-04 23:46:54.528 - debug: heatingcontrol.0 check time for 2OG_Bad Profiles.0.2OG_Bad.Mo-Su.Periods.2.time 18.0
                    2019-10-04 23:46:54.528 - debug: heatingcontrol.0 ### 18.0 0 0 0 0 0
                    2019-10-04 23:46:54.528 - info: heatingcontrol.0 room 2OG_Bad Thermostat 2OG_Bad_Heizung_11_Kanal4.SET_TEMPERATURE set to 18
                    2019-10-04 23:46:54.528 - debug: heatingcontrol.0 cron jobs
                    2019-10-04 23:46:54.528 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 00:00:00
                    2019-10-04 23:46:54.528 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 06:00:00
                    2019-10-04 23:46:54.528 - debug: heatingcontrol.0 [INFO] status = true next event: 5 Oct 2019 23:00:00
                    2019-10-04 23:46:55.886 - error: hm-rpc.0 xmlrpc -> setValue ["4","SET_TEMPERATURE",18] FLOAT
                    2019-10-04 23:46:55.886 - error: hm-rpc.0 Error: XML-RPC fault: Failure
                    2019-10-04 23:46:56.104 - debug: heatingcontrol.0 system.adapter.admin.0: logging false
                    2019-10-04 23:46:56.635 - error: hm-rpc.0 xmlrpc -> setValue ["4","SET_TEMPERATURE",18] FLOAT
                    2019-10-04 23:46:56.635 - error: hm-rpc.0 Error: XML-RPC fault: Failure
                    2019-10-04 23:46:57.368 - error: hm-rpc.0 xmlrpc -> setValue ["4","SET_TEMPERATURE",18] FLOAT
                    2019-10-04 23:46:57.368 - error: hm-rpc.0 Error: XML-RPC fault: Failure
                    2019-10-04 23:46:58.054 - debug: heatingcontrol.0 system.adapter.admin.0: logging true
                    2019-10-04 23:46:58.148 - error: hm-rpc.0 xmlrpc -> setValue ["4","SET_TEMPERATURE",20] FLOAT
                    2019-10-04 23:46:58.148 - error: hm-rpc.0 Error: XML-RPC fault: Failure
                    2019-10-04 23:46:58.897 - error: hm-rpc.0 xmlrpc -> setValue ["4","SET_TEMPERATURE",17] FLOAT
                    2019-10-04 23:46:58.897 - error: hm-rpc.0 Error: XML-RPC fault: Failure
                    2019-10-04 23:46:59.646 - error: hm-rpc.0 xmlrpc -> setValue ["4","SET_TEMPERATURE",18] FLOAT
                    2019-10-04 23:46:59.646 - error: hm-rpc.0 Error: XML-RPC fault: Failure
                    2019-10-04 23:47:00.395 - error: hm-rpc.0 xmlrpc -> setValue ["4","SET_TEMPERATURE",18] FLOAT
                    2019-10-04 23:47:00.395 - error: hm-rpc.0 Error: XML-RPC fault: Failure
                    2019-10-04 23:47:01.143 - error: hm-rpc.0 xmlrpc -> setValue ["4","SET_TEMPERATURE",19] FLOAT
                    2019-10-04 23:47:01.143 - error: hm-rpc.0 Error: XML-RPC fault: Failure
                    2019-10-04 23:47:01.923 - error: hm-rpc.0 xmlrpc -> setValue ["4","SET_TEMPERATURE",18] FLOAT
                    2019-10-04 23:47:01.923 - error: hm-rpc.0 Error: XML-RPC fault: Failure
                    2019-10-04 23:47:02.719 - error: hm-rpc.0 xmlrpc -> setValue ["4","SET_TEMPERATURE",18] FLOAT
                    2019-10-04 23:47:02.719 - error: hm-rpc.0 Error: XML-RPC fault: Failure
                    2019-10-04 23:47:33.622 - debug: heatingcontrol.0 ### handle state change hm-rpc.0.OEQ0496790.1.STATE {"val":false,"ack":true,"ts":1570225653622,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1567698413860}
                    2019-10-04 23:47:33.622 - debug: heatingcontrol.0 ### 111 not handled
                    2019-10-04 23:47:33.622 - debug: heatingcontrol.0 handle actors hm-rpc.0.OEQ0496790.1.STATE{"val":false,"ack":true,"ts":1570225653622,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1567698413860}
                    2019-10-04 23:47:33.622 - debug: heatingcontrol.0 ### {"id":19,"name":"2OG_Schlafzimmer_Fenster_11_Kanal1.STATE","OID_Current":"hm-rpc.0.OEQ0496790.1.STATE","isActive":true,"type":3,"room":"2OG_Schlafzimmer"}
                    2019-10-04 23:47:33.622 - debug: heatingcontrol.0 set 2OG_Schlafzimmer window open to {"val":false,"ack":true,"ts":1570225653622,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1567698413860}
                    2019-10-04 23:47:33.622 - info: heatingcontrol.0 calculating new target temperatures
                    Falls du noch mehr Daten benötigst, suche ich die gerne zusammen.
                    Vielen Dank für die Unterstützung
                    Rene_HMR Offline
                    Rene_HMR Offline
                    Rene_HM
                    schrieb am zuletzt editiert von Rene_HM
                    #178
                    @maarten ich habe mir das log angeschaut. Das passt soweit.
                    Was mich wundert:
                    • im Raum 1OG_Schlafzimmer hast du kein Thermostat konfiguriert?
                    • im Raum 2OG_Schlafzimmer finde ich das log
                    Actual_Temperature sollte als Ziel-Temp nicht vorkommen
                    • aber: alle Werte, die du auf die Geräte schreiben möchtest, werden nicht akzeptiert. Deshalb: zeige mir mal die Konfiguration eines Thermostats (speziell den zweiten Teil der OID, das ist in dem oben gezeigten Bild abgeschnitten... Ich denke, die Konfiguration der Datenpunkte passt nicht...
                    • ChaotC Chaot
                      hilde0407
                      #179
                      @Chaot Vielen Dank! Hat funktioniert!
                      • N Offline
                        N Offline
                        nocci
                        schrieb am zuletzt editiert von nocci
                        #180
                        Hallo an Alle
                        Ich habe heute ein wenig Zeit gefunden mich mit dem Adapter hier zu beschäftigen.
                        Den Ansatz finde ich ja richtig super, da man so diverse Hersteller unter eine Decke bringen kann. Dafür schon einmal meinen vollsten Respekt und vielen Dank an den Entwickler.
                        Im Wohnzimmer verwende ich derzeit noch Max-Thermostaten und einen Max-Fensterkontakt, den ich unter Sensor eingetragen habe und im Schlafzimmer nen HM-IP-Thermostat und einen Max-Fensterkontakt.
                        Ich habe soweit alles einrichten könnten und hoffentlich auch die richtigen DP genutzt.
                        Nach dem Start des Adapters sieht mein Log aber sehr voll aus und frage mich, ob das genau so sein soll?
                        heatingcontrol.0	2019-10-06 13:35:46.014	info	calculating new target temperatures
                        heatingcontrol.0	2019-10-06 13:35:37.097	info	handle actors Schlafzimmer current 22.4 target 16
                        heatingcontrol.0	2019-10-06 13:35:37.095	info	handle actors Schlafzimmer current 22.4 target 16
                        heatingcontrol.0	2019-10-06 13:35:36.393	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:35:36.387	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:35:36.365	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:35:36.278	info	room Schlafzimmer Thermostat Thermostat Schlafzimmer 1.SET_POINT_TEMPERATURE set to 16
                        heatingcontrol.0	2019-10-06 13:35:36.238	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:35:36.216	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:35:36.185	info	room Wohnzimmer Thermostat Fenster 1 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:35:36.168	info	room Wohnzimmer Thermostat Fenster 2 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:35:36.156	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:35:36.149	info	room Wohnzimmer Thermostat Fenster 1 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:35:36.037	info	calculating new target temperatures
                        heatingcontrol.0	2019-10-06 13:35:30.309	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:35:30.304	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:35:27.665	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:35:27.660	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:35:26.364	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:35:26.359	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:35:26.340	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:35:26.271	info	room Schlafzimmer Thermostat Thermostat Schlafzimmer 1.SET_POINT_TEMPERATURE set to 16
                        heatingcontrol.0	2019-10-06 13:35:26.218	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:35:26.209	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:35:26.166	info	room Wohnzimmer Thermostat Fenster 1 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:35:26.147	info	room Wohnzimmer Thermostat Fenster 2 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:35:26.133	info	room Wohnzimmer Thermostat Fenster 1 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:35:26.119	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:35:26.018	info	calculating new target temperatures
                        heatingcontrol.0	2019-10-06 13:35:17.867	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:35:17.866	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:35:16.424	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:35:16.419	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:35:16.336	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:35:16.271	info	room Schlafzimmer Thermostat Thermostat Schlafzimmer 1.SET_POINT_TEMPERATURE set to 16
                        heatingcontrol.0	2019-10-06 13:35:16.223	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:35:16.201	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:35:16.164	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:35:16.158	info	room Wohnzimmer Thermostat Fenster 1 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:35:16.142	info	room Wohnzimmer Thermostat Fenster 2 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:35:16.130	info	room Wohnzimmer Thermostat Fenster 1 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:35:16.041	info	calculating new target temperatures
                        heatingcontrol.0	2019-10-06 13:35:07.021	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:35:06.470	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:35:06.459	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:35:06.414	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:35:06.315	info	room Schlafzimmer Thermostat Thermostat Schlafzimmer 1.SET_POINT_TEMPERATURE set to 16
                        heatingcontrol.0	2019-10-06 13:35:06.270	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:35:06.255	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:35:06.230	info	room Wohnzimmer Thermostat Fenster 1 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:35:06.215	info	room Wohnzimmer Thermostat Fenster 2 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:35:06.201	info	room Wohnzimmer Thermostat Fenster 1 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:35:06.187	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:35:06.053	info	calculating new target temperatures
                        heatingcontrol.0	2019-10-06 13:34:57.208	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:34:57.205	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:34:56.367	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:56.363	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:56.338	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:34:56.224	info	room Schlafzimmer Thermostat Thermostat Schlafzimmer 1.SET_POINT_TEMPERATURE set to 16
                        heatingcontrol.0	2019-10-06 13:34:56.182	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:56.163	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:56.137	info	room Wohnzimmer Thermostat Fenster 1 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:34:56.123	info	room Wohnzimmer Thermostat Fenster 2 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:34:56.113	info	room Wohnzimmer Thermostat Fenster 1 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:34:56.099	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:56.012	info	calculating new target temperatures
                        heatingcontrol.0	2019-10-06 13:34:48.446	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:34:48.445	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:34:46.416	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:46.409	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:46.335	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:34:46.249	info	room Schlafzimmer Thermostat Thermostat Schlafzimmer 1.SET_POINT_TEMPERATURE set to 16
                        heatingcontrol.0	2019-10-06 13:34:46.207	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:46.179	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:46.144	info	room Wohnzimmer Thermostat Fenster 1 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:34:46.117	info	room Wohnzimmer Thermostat Fenster 2 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:34:46.109	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:46.105	info	room Wohnzimmer Thermostat Fenster 1 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:34:46.012	info	calculating new target temperatures
                        heatingcontrol.0	2019-10-06 13:34:38.658	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:34:38.654	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:34:36.501	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:36.494	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:36.409	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:34:36.339	info	room Schlafzimmer Thermostat Thermostat Schlafzimmer 1.SET_POINT_TEMPERATURE set to 16
                        heatingcontrol.0	2019-10-06 13:34:36.285	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:36.284	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:36.258	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:36.238	info	room Wohnzimmer Thermostat Fenster 1 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:34:36.224	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:36.220	info	room Wohnzimmer Thermostat Fenster 2 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:34:36.209	info	room Wohnzimmer Thermostat Fenster 1 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:34:36.106	info	calculating new target temperatures
                        heatingcontrol.0	2019-10-06 13:34:27.812	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:34:27.810	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:34:26.400	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:26.379	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:26.263	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:34:26.235	info	room Schlafzimmer Thermostat Thermostat Schlafzimmer 1.SET_POINT_TEMPERATURE set to 16
                        heatingcontrol.0	2019-10-06 13:34:26.192	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:26.185	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:26.142	info	room Wohnzimmer Thermostat Fenster 1 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:34:26.126	info	room Wohnzimmer Thermostat Fenster 2 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:34:26.120	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:26.116	info	room Wohnzimmer Thermostat Fenster 1 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:34:26.023	info	calculating new target temperatures
                        heatingcontrol.0	2019-10-06 13:34:20.111	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:34:18.654	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:34:18.557	info	room Schlafzimmer Thermostat Thermostat Schlafzimmer 1.SET_POINT_TEMPERATURE set to 16
                        heatingcontrol.0	2019-10-06 13:34:18.451	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:18.443	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:18.436	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:18.413	info	room Wohnzimmer Thermostat Fenster 1 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:34:18.400	info	room Wohnzimmer Thermostat Fenster 2 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:34:18.337	info	room Wohnzimmer Thermostat Fenster 1 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:34:17.764	info	calculating new target temperatures
                        heatingcontrol.0	2019-10-06 13:34:17.146	info	subscribe Wohnzimmer maxcube.0.devices.contact_0c1efa.opened
                        heatingcontrol.0	2019-10-06 13:34:17.146	info	subscribe Wohnzimmer maxcube.0.devices.thermostat_15dda6.setpoint / maxcube.0.devices.thermostat_15cb43.temp
                        heatingcontrol.0	2019-10-06 13:34:17.145	info	subscribe Wohnzimmer maxcube.0.devices.thermostat_15cb43.setpoint / maxcube.0.devices.thermostat_15cb43.temp
                        heatingcontrol.0	2019-10-06 13:34:17.144	info	subscribe Wohnzimmer maxcube.0.devices.thermostat_15dda6.setpoint / maxcube.0.devices.thermostat_15cb43.temp
                        heatingcontrol.0	2019-10-06 13:34:17.141	info	subscribe Schlafzimmer hm-rpc.1.001299939684BF.1.SET_POINT_TEMPERATURE / hm-rpc.1.001299939684BF.1.ACTUAL_TEMPERATURE
                        heatingcontrol.0	2019-10-06 13:34:16.597	info	starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.heatingcontrol, node: v10.16.3
                        heatingcontrol.0	2019-10-06 13:34:12.805	info	cleaned everything up...
                        heatingcontrol.0	2019-10-06 13:34:12.796	info	cleaned everything up...
                        heatingcontrol.0	2019-10-06 13:34:07.189	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:34:07.157	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:34:06.467	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:06.461	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:06.383	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:34:06.309	info	room Schlafzimmer Thermostat Thermostat Schlafzimmer 1.SET_POINT_TEMPERATURE set to 16
                        heatingcontrol.0	2019-10-06 13:34:06.250	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:06.223	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:06.205	info	room Wohnzimmer Thermostat Fenster 1 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:34:06.156	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:34:06.151	info	room Wohnzimmer Thermostat Fenster 2 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:34:06.133	info	room Wohnzimmer Thermostat Fenster 1 setpoint set to 20.5
                        heatingcontrol.0	2019-10-06 13:34:06.048	info	calculating new target temperatures
                        heatingcontrol.0	2019-10-06 13:33:58.403	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:33:58.401	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:33:56.450	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:33:56.430	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:33:56.347	info	handle actors Schlafzimmer current 22.3 target 16
                        heatingcontrol.0	2019-10-06 13:33:56.251	info	room Schlafzimmer Thermostat Thermostat Schlafzimmer 1.SET_POINT_TEMPERATURE set to 16
                        heatingcontrol.0	2019-10-06 13:33:56.214	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:33:56.209	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:33:56.199	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:33:56.190	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:33:56.159	info	handle actors Wohnzimmer current 23 target 20.5
                        heatingcontrol.0	2019-10-06 13:33:56.158	info	room Wohnzimmer Thermostat Fenster 1 setpoint set to 20.5
                        Wie gesagt, es sieht für mich so aus als wenn das Log gerade zu geflutet wird mit den entsprechenden Einträgen, wie man sie oben sehen kann und frage mich wie es bei anderen Anwendern so aussieht und ob das so richtig ist.
                        Rene_HMR 1 Antwort Letzte Antwort
                        • N nocci
                          Hallo an Alle
                          Rene_HMR Offline
                          Rene_HMR Offline
                          Rene_HM
                          #181
                          @nocci Hast du das "Use Actuators" an? Wennn du keine Aktoren konfiguriert hast (was du auch nicht brauchst, wenn deine Thermostate die Aktoren direkt schalten), dann schalte das "Use Actuators" aus.
                          So häufig wie bei dir im log sollte die Zieltemperatur nicht auf das Thermostat geschrieben werden. Entweder melden sich deine Sensoren ständig (und nicht nur bei Änderung) oder du hast eine ungünstige Zeitsteuerung konfiguriert. Kannst du mal den Adapter im debug-Mode laufen lassen und das log posten? Dann sollten wir die Ursache finden...
                          N 1 Antwort Letzte Antwort
                          • Rene_HMR Rene_HM
                            N Offline
                            N Offline
                            nocci
                            #182
                            @Rene_HM Danke! Das "Use Actors" war es. Nun sieht es seeeeeehr viel besser aus.
                            Vielen lieben Dank für den Tipp. Perfekt!
                            Eine Frage habe ich leider trotzdem noch: Wenn dann nächste Woche oder so meine bestellten Xiaomi-Temp-Sensoren ankommen und über den Zigbee-Adapter angebunden worden sind, kann ich diese dann einfach als "Sensor" laufen lassen?
                            Muss ich da irgendwas besonderes beachten?
                            Rene_HMR CKMartensC 2 Antworten Letzte Antwort
                            • N nocci
                              Rene_HMR Offline
                              Rene_HMR Offline
                              Rene_HM
                              #183
                              @nocci Nein, Sensoren sind Fenstersensoren, die einen Zustand (offen / geschlossen) liefern und zur Temperaturabsenkung gedacht sind.
                              Wie möchtest du die Xiaomi-Temp-Sensoren verwenden?
                              • Rene_HMR Rene_HM
                                N Offline
                                N Offline
                                nocci
                                #184
                                @Rene_HM Oh okay. Verstehe ich.
                                Ich wollte die Xiaomi-Temperatur-Sensoren so verwenden, dass sie die "wahre" Raumtemperatur liefern und quasi die gemessene Temperatur an den Thermostaten "überschreiben", da diese ja nur die Temperatur in unmittelbarer Umgebung des jeweiligen Thermostaten wiedergeben und eher nicht die eigentliche Raumtemperatur.
                                Ich hoffe, das war einigermaßen verständlich 😬
                                • N nocci
                                  Rene_HMR Offline
                                  Rene_HMR Offline
                                  Rene_HM
                                  #185
                                  @nocci Das wird eher schwierig:
                                  1. Weg: wie von dir vorgeschlagen, die Temperatur messen und dem Thermostat übergeben. Das wird wohl nicht funktionieren, da die gemessene Temperatur eines Thermostats ein read-only-Wert sein sollte (würde ich jedenfalls so machen und ist bei meinen HM-Thermostaten auch so). Falls der Temperatur-Datenpunkt am Thermostat wirklich schreibbar ist, könntest du ein einfaches script schreiben und die Werte bei Änderung vom Thermometer auf das Thermostat schreiben.
                                  2. Weg: Am Thermostat gar nichts regeln lassen, sondern dem Thermostat nur die Ventilstellung (auf/zu oder Prozent-Wert) übergeben. Die Variante auf/zu könnte der Adapter abbilden, wenn das Thermostat diesen Datenpunkt zur Verfügung stellt und der auch noch schreibbar ist. Dafür wäre dann das "Use Actuators" da: Im Thermostat im Adapter konfiguriert man ein Thermometer als "current OID", dort misst man die Temperatur. Der Adapter schaltet dann den Aktor ein / aus je nachdem, ob geheizt werden soll oder nicht. Derzeit ist hier aber keine "vernünftige" Regelung implementiert, sondern nur eine Ein/Aus-Regelung bei Über/Unterschreiten der Zieltemperatur. Für viele Fußbodenheizungen reicht das, für normale Heizkörper wahrscheinlich nicht...
                                  • N nocci
                                    CKMartensC Offline
                                    CKMartensC Offline
                                    CKMartens
                                    #186
                                    @nocci sagte in Adapter: HeatingControl:
                                    Ich habe die Xiaomi Temperatur Sensor als Ist Wert bei den Heizungen eingetragen. Du musst aber erstmal schauen wie die Differenz zu der richtigen Temperatur ist. Bei mir haben die im Wohnzimmer z. B. +0,8 Grad, die im Schlafzimmer - 0,5 Grad. Das habe ich den Settings meiner Thermostate kompensiert.
                                    Wenn Du Fensterkontakte von Xiaomi hast diese dann unter Sensoren für den Raum eintragen.
                                    Lg
                                    Carsten
                                    • CKMartensC CKMartens
                                      Lg
                                      Carsten
                                      Rene_HMR Offline
                                      Rene_HMR Offline
                                      Rene_HM
                                      #187
                                      @CKMartens sagte in Adapter: HeatingControl:
                                      aber nicht im Adapter, richtig?
                                      CKMartensC 1 Antwort Letzte Antwort
                                      • Rene_HMR Rene_HM
                                        CKMartensC Offline
                                        CKMartensC Offline
                                        CKMartens
                                        schrieb am zuletzt editiert von CKMartens
                                        #188
                                        @Rene_HM
                                        Doch, im Adapter. Und funktioniert soweit ganz gut. Wie gesagt, die Messdifferenz muss vorher bestimmt werden und im Thermostat einstellen.
                                        • N Offline
                                          N Offline
                                          nocci
                                          #189
                                          Hatte sonst schon überlegt, ob ein "Umweg" über einen virtuellen CuxD-Wandthermostaten oder ähnliches funktionieren könnte, aber wenn @CKMartens sagt, dass man es quasi quick-n-dirty auch so lösen kann, werde ich das echt noch vorher versuchen.
                                          Ich danke Euch beiden aber schon mal sehr für Eure Ideen und Hinweise.
                                          Das hat mir schon sehr geholfen.
