  4. Test js-controller v2.0.x (GitHub)
js-controller
1.0k Beiträge 48 Kommentatoren 448.4k Aufrufe 35 Beobachtet
  • apollon77A apollon77
    @watcherkb sagte in [Aufruf] js-controller 2.0 Beta Test:
    Kernel aktuell? Alle Updates installiert?
    VBei libuv Fehler ist man recht "weit unten" ... Sollte mit controller eher nichts zu tun haben
    W
    W
    watcherkb
    #187
    @apollon77 ja hab schon alles durch. Auch Adapter neu installieren bringt nur noch Fehler. Weiß nicht mehr weiter...
    $ ./iobroker url "https://github.com/frankjoke/ioBroker.radar2/tarball/master" radar2
    install https://github.com/frankjoke/ioBroker.radar2/tarball/master
    NPM version: 6.9.0
    npm install https://github.com/frankjoke/ioBroker.radar2/tarball/master --loglevel error --production --save --prefix "/opt/iobroker" (System call)
    In file included from ../src/raw.h:23,                 from ../src/raw.cc:6:../../nan/nan.h: In function 'void Nan::AsyncQueueWorker(Nan::AsyncWorker*)':../../nan/nan.h:2298:62: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
    In file included from ../src/raw.h:21,                 from ../src/raw.cc:6:../src/raw.cc: At global scope:/home/iobroker/.node-gyp/10.16.3/include/node/node.h:573:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.node-gyp/10.16.3/include/node/node.h:607:3: note: in expansion of macro 'NODE_MODULE_X'   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/raw.cc:55:1: note: in expansion of macro 'NODE_MODULE' NODE_MODULE(raw, InitAll) ^~~~~~~~~~~
    In file included from /home/iobroker/.node-gyp/10.16.3/include/node/node.h:63,                 from ../src/raw.h:21,                 from ../src/raw.cc:6:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h: In instantiation of 'void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]':/home/iobroker/.node-gyp/10.16.3/include/node/node_object_wrap.h:84:78:   required from here/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:9502:16: warning: cast between incompatible function types from 'v8::WeakCallbackInfo<node::ObjectWrap>::Callback' {aka 'void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)'} to 'Callback' {aka 'void (*)(const v8::WeakCallbackInfo<void>&)'} [-Wcast-function-type]                reinterpret_cast<Callback>(callback), type);                ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    /home/iobroker/.node-gyp/10.16.3/include/node/v8.h: In instantiation of 'void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]':../../nan/nan_object_wrap.h:65:61:   required from here/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:9502:16: warning: cast between incompatible function types from 'v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback' {aka 'void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)'} to 'Callback' {aka 'void (*)(const v8::WeakCallbackInfo<void>&)'} [-Wcast-function-type]
    prebuild-install
     info begin Prebuild-install version 5.3.2
    prebuild-install info looking for cached prebuild @ /home/iobroker/.npm/_prebuilds/f78b17-usb-v1.6.0-node-v64-linux-x64.tar.gz
    prebuild-install info found cached prebuild
    prebuild-install info unpacking @ /home/iobroker/.npm/_prebuilds/f78b17-usb-v1.6.0-node-v64-linux-x64.tar.gz
    prebuild-install info unpack resolved to /opt/iobroker/node_modules/usb/build/Release/usb_bindings.nodeprebuild-install info unpack required /opt/iobroker/node_modules/usb/build/Release/usb_bindings.node successfullyprebuild-install info install Successfully installed prebuilt binary!
    In file included from ../src/BluetoothHciSocket.cpp:8:../../../nan/nan.h: In function 'void Nan::AsyncQueueWorker(Nan::AsyncWorker*)':../../../nan/nan.h:2298:62: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
    ../src/BluetoothHciSocket.cpp: In member function 'void BluetoothHciSocket::poll()':../src/BluetoothHciSocket.cpp:252:95: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]     Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);        ^In file included from ../src/BluetoothHciSocket.cpp:8:../../../nan/nan.h:1045:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~../src/BluetoothHciSocket.cpp:252:95: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]     Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);        ^In file included from ../src/BluetoothHciSocket.cpp:8:../../../nan/nan.h:1045:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~
    ../src/BluetoothHciSocket.cpp: In member function 'void BluetoothHciSocket::emitErrnoError()':../src/BluetoothHciSocket.cpp:274:93: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);        ^In file included from ../src/BluetoothHciSocket.cpp:8:../../../nan/nan.h:1045:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~../src/BluetoothHciSocket.cpp:274:93: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);        ^In file included from ../src/BluetoothHciSocket.cpp:8:../../../nan/nan.h:1045:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~
    In file included from /home/iobroker/.node-gyp/10.16.3/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:../src/BluetoothHciSocket.cpp: At global scope:/home/iobroker/.node-gyp/10.16.3/include/node/node.h:573:43: warning: cast between incompatible function types from 'void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)' {aka 'void (*)(v8::Local<v8::Object>)'} to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.node-gyp/10.16.3/include/node/node.h:607:3: note: in expansion of macro 'NODE_MODULE_X'   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/BluetoothHciSocket.cpp:529:1: note: in expansion of macro 'NODE_MODULE' NODE_MODULE(binding, BluetoothHciSocket::Init); ^~~~~~~~~~~
    In file included from /home/iobroker/.node-gyp/10.16.3/include/node/node.h:63,                 from /home/iobroker/.node-gyp/10.16.3/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h: In instantiation of 'void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]':/home/iobroker/.node-gyp/10.16.3/include/node/node_object_wrap.h:84:78:   required from here/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:9502:16: warning: cast between incompatible function types from 'v8::WeakCallbackInfo<node::ObjectWrap>::Callback' {aka 'void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)'} to 'Callback' {aka 'void (*)(const v8::WeakCallbackInfo<void>&)'} [-Wcast-function-type]                reinterpret_cast<Callback>(callback), type);                ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    /home/iobroker/.node-gyp/10.16.3/include/node/v8.h: In instantiation of 'void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]':../../../nan/nan_object_wrap.h:65:61:   required from here/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:9502:16: warning: cast between incompatible function types from 'v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback' {aka 'void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)'} to 'Callback' {aka 'void (*)(const v8::WeakCallbackInfo<void>&)'} [-Wcast-function-type]
    In file included from ../src/DeviceINQ.h:17,                 from ../src/linux/BluetoothSerialPort.cc:13:../node_modules/nan/nan.h: In function 'void Nan::AsyncQueueWorker(Nan::AsyncWorker*)':../node_modules/nan/nan.h:2298:62: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
    In file included from ../src/linux/BluetoothSerialPort.cc:12:../src/linux/BluetoothSerialPort.cc: At global scope:/home/iobroker/.node-gyp/10.16.3/include/node/node.h:573:43: warning: cast between incompatible function types from 'void (*)(v8::Handle<v8::Object>)' {aka 'void (*)(v8::Local<v8::Object>)'} to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.node-gyp/10.16.3/include/node/node.h:607:3: note: in expansion of macro 'NODE_MODULE_X'   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/linux/BluetoothSerialPort.cc:23:1: note: in expansion of macro 'NODE_MODULE' NODE_MODULE(BluetoothSerialPort, InitAll) ^~~~~~~~~~~
    In file included from /home/iobroker/.node-gyp/10.16.3/include/node/node.h:63,                 from ../src/linux/BluetoothSerialPort.cc:12:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h: In instantiation of 'void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]':/home/iobroker/.node-gyp/10.16.3/include/node/node_object_wrap.h:84:78:   required from here/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:9502:16: warning: cast between incompatible function types from 'v8::WeakCallbackInfo<node::ObjectWrap>::Callback' {aka 'void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)'} to 'Callback' {aka 'void (*)(const v8::WeakCallbackInfo<void>&)'} [-Wcast-function-type]                reinterpret_cast<Callback>(callback), type);                ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    /home/iobroker/.node-gyp/10.16.3/include/node/v8.h: In instantiation of 'void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]':../node_modules/nan/nan_object_wrap.h:65:61:   required from here/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:9502:16: warning: cast between incompatible function types from 'v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback' {aka 'void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)'} to 'Callback' {aka 'void (*)(const v8::WeakCallbackInfo<void>&)'} [-Wcast-function-type]
    In file included from ../src/linux/DeviceINQ.cc:14:../node_modules/nan/nan.h: In function 'void Nan::AsyncQueueWorker(Nan::AsyncWorker*)':../node_modules/nan/nan.h:2298:62: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
    ../src/linux/DeviceINQ.cc: In static member function 'static void DeviceINQ::EIO_AfterSdpSearch(uv_work_t*)':../src/linux/DeviceINQ.cc:139:28: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]     baton->cb->Call(1, argv);                            ^In file included from ../src/linux/DeviceINQ.cc:14:../node_modules/nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~
    ../src/linux/DeviceINQ.cc: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE DeviceINQ::InquireSync(Nan::NAN_METHOD_ARGS_TYPE)':../src/linux/DeviceINQ.cc:251:26: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]       found->Call(2, argv);                          ^In file included from ../src/linux/DeviceINQ.cc:14:../node_modules/nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~../src/linux/DeviceINQ.cc:255:27: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]     callback->Call(0, argv);                           ^In file included from ../src/linux/DeviceINQ.cc:14:../node_modules/nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~
    ../src/linux/DeviceINQ.cc: In member function 'virtual void InquireWorker::HandleOKCallback()':../src/linux/DeviceINQ.cc:284:26: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]       found->Call(2, argv);                          ^In file included from ../src/linux/DeviceINQ.cc:14:../node_modules/nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~../src/linux/DeviceINQ.cc:288:27: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]     callback->Call(0, argv);                           ^In file included from ../src/linux/DeviceINQ.cc:14:../node_modules/nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~../src/linux/DeviceINQ.cc: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE DeviceINQ::SdpSearch(Nan::NAN_METHOD_ARGS_TYPE)':../src/linux/DeviceINQ.cc:317:38: warning: 'v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)' is deprecated: Use Isolate version [-Wdeprecated-declarations]     String::Utf8Value address(info[0]);                                      ^In file included from /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:26,                 from ../src/linux/DeviceINQ.cc:12:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:2892:28: note: declared here                   explicit Utf8Value(Local<v8::Value> obj));                            ^~~~~~~~~/home/iobroker/.node-gyp/10.16.3/include/node/v8config.h:324:3: note: in definition of macro 'V8_DEPRECATED'   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    ../src/linux/DeviceINQ.cc:335:88: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]     uv_queue_work(uv_default_loop(), &baton->request, EIO_SdpSearch, (uv_after_work_cb)EIO_AfterSdpSearch);        ^~~~~~~~~~~~~~~~~~
    In file included from ../src/linux/DeviceINQ.cc:12:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h: In instantiation of 'void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]':/home/iobroker/.node-gyp/10.16.3/include/node/node_object_wrap.h:84:78:   required from here/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:9502:16: warning: cast between incompatible function types from 'v8::WeakCallbackInfo<node::ObjectWrap>::Callback' {aka 'void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)'} to 'Callback' {aka 'void (*)(const v8::WeakCallbackInfo<void>&)'} [-Wcast-function-type]                reinterpret_cast<Callback>(callback), type);                ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    In file included from ../src/linux/BTSerialPortBinding.cc:14:../node_modules/nan/nan.h: In function 'void Nan::AsyncQueueWorker(Nan::AsyncWorker*)':../node_modules/nan/nan.h:2298:62: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
    ../src/linux/BTSerialPortBinding.cc: In static member function 'static void BTSerialPortBinding::EIO_AfterConnect(uv_work_t*)':../src/linux/BTSerialPortBinding.cc:83:32: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]         baton->cb->Call(0, NULL);                                ^In file included from ../src/linux/BTSerialPortBinding.cc:14:../node_modules/nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~../src/linux/BTSerialPortBinding.cc:89:33: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]         baton->ecb->Call(1, argv);                                 ^In file included from ../src/linux/BTSerialPortBinding.cc:14:../node_modules/nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~../src/linux/BTSerialPortBinding.cc: In static member function 'static void BTSerialPortBinding::EIO_Write(uv_work_t*)':../src/linux/BTSerialPortBinding.cc:115:22: warning: comparison of integer expressions of different signedness: 'size_t' {aka 'long unsigned int'} and 'int' [-Wsign-compare]     if (data->result != data->bufferLength) {         ~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~
    ../src/linux/BTSerialPortBinding.cc: In static member function 'static void BTSerialPortBinding::EIO_AfterWrite(uv_work_t*)':../src/linux/BTSerialPortBinding.cc:135:33: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]     data->callback->Call(2, argv);                                 ^In file included from ../src/linux/BTSerialPortBinding.cc:14:../node_modules/nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~../src/linux/BTSerialPortBinding.cc:144:94: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]         uv_queue_work(uv_default_loop(), &nextQueuedWrite->req, EIO_Write, (uv_after_work_cb)EIO_AfterWrite);        ^~~~~~~~~~~~~~
    ../src/linux/BTSerialPortBinding.cc: In static member function 'static void BTSerialPortBinding::EIO_AfterRead(uv_work_t*)':../src/linux/BTSerialPortBinding.cc:207:28: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]     baton->cb->Call(2, argv);                            ^In file included from ../src/linux/BTSerialPortBinding.cc:14:../node_modules/nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~../src/linux/BTSerialPortBinding.cc: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE BTSerialPortBinding::New(Nan::NAN_METHOD_ARGS_TYPE)':../src/linux/BTSerialPortBinding.cc:253:38: warning: 'v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)' is deprecated: Use Isolate version [-Wdeprecated-declarations]     String::Utf8Value address(info[0]);                                      ^In file included from /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:26,                 from ../src/linux/BTSerialPortBinding.cc:12:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:2892:28: note: declared here                   explicit Utf8Value(Local<v8::Value> obj));                            ^~~~~~~~~/home/iobroker/.node-gyp/10.16.3/include/node/v8config.h:324:3: note: in definition of macro 'V8_DEPRECATED'   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    ../src/linux/BTSerialPortBinding.cc:255:41: warning: 'int32_t v8::Value::Int32Value() const' is deprecated: Use maybe version [-Wdeprecated-declarations]     int channelID = info[1]->Int32Value();                                         ^In file included from /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:26,                 from ../src/linux/BTSerialPortBinding.cc:12:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:2478:46: note: declared here   V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);                                              ^~~~~~~~~~/home/iobroker/.node-gyp/10.16.3/include/node/v8config.h:324:3: note: in definition of macro 'V8_DEPRECATED'   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    ../src/linux/BTSerialPortBinding.cc:281:86: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]     uv_queue_work(uv_default_loop(), &baton->request, EIO_Connect, (uv_after_work_cb)EIO_AfterConnect);        ^~~~~~~~~~~~~~~~
    ../src/linux/BTSerialPortBinding.cc: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE BTSerialPortBinding::Write(Nan::NAN_METHOD_ARGS_TYPE)':../src/linux/BTSerialPortBinding.cc:314:43: warning: 'void* memset(void*, int, size_t)' clearing an object of type 'struct BTSerialPortBinding::write_baton_t' with no trivial copy-assignment; use assignment or value-initialization instead [-Wclass-memaccess]     memset(baton, 0, sizeof(write_baton_t));                                           ^In file included from ../src/linux/BTSerialPortBinding.cc:19:../src/BTSerialPortBinding.h:68:16: note: 'struct BTSerialPortBinding::write_baton_t' declared here         struct write_baton_t {                ^~~~~~~~~~~~~../src/linux/BTSerialPortBinding.cc:333:90: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]         uv_queue_work(uv_default_loop(), &queuedWrite->req, EIO_Write, (uv_after_work_cb)EIO_AfterWrite);        ^~~~~~~~~~~~~~
    ../src/linux/BTSerialPortBinding.cc: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE BTSerialPortBinding::Read(Nan::NAN_METHOD_ARGS_TYPE)':../src/linux/BTSerialPortBinding.cc:383:25: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]         nc->Call(2, argv);                         ^In file included from ../src/linux/BTSerialPortBinding.cc:14:../node_modules/nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~../src/linux/BTSerialPortBinding.cc:391:87: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]         uv_queue_work(uv_default_loop(), &baton->request, EIO_Read, (uv_after_work_cb)EIO_AfterRead);        ^~~~~~~~~~~~~
    In file included from ../src/linux/BTSerialPortBinding.cc:12:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h: In instantiation of 'void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]':/home/iobroker/.node-gyp/10.16.3/include/node/node_object_wrap.h:84:78:   required from here/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:9502:16: warning: cast between incompatible function types from 'v8::WeakCallbackInfo<node::ObjectWrap>::Callback' {aka 'void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)'} to 'Callback' {aka 'void (*)(const v8::WeakCallbackInfo<void>&)'} [-Wcast-function-type]                reinterpret_cast<Callback>(callback), type);                ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    In file included from ../src/DeviceINQ.h:17,                 from ../src/linux/BluetoothSerialPortServer.cc:13:../node_modules/nan/nan.h: In function 'void Nan::AsyncQueueWorker(Nan::AsyncWorker*)':../node_modules/nan/nan.h:2298:62: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
    In file included from ../src/linux/BluetoothSerialPortServer.cc:12:../src/linux/BluetoothSerialPortServer.cc: At global scope:/home/iobroker/.node-gyp/10.16.3/include/node/node.h:573:43: warning: cast between incompatible function types from 'void (*)(v8::Handle<v8::Object>)' {aka 'void (*)(v8::Local<v8::Object>)'} to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.node-gyp/10.16.3/include/node/node.h:607:3: note: in expansion of macro 'NODE_MODULE_X'   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/linux/BluetoothSerialPortServer.cc:22:1: note: in expansion of macro 'NODE_MODULE' NODE_MODULE(BluetoothSerialPortServer, InitAllServer) ^~~~~~~~~~~
    In file included from /home/iobroker/.node-gyp/10.16.3/include/node/node.h:63,                 from ../src/linux/BluetoothSerialPortServer.cc:12:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h: In instantiation of 'void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]':/home/iobroker/.node-gyp/10.16.3/include/node/node_object_wrap.h:84:78:   required from here/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:9502:16: warning: cast between incompatible function types from 'v8::WeakCallbackInfo<node::ObjectWrap>::Callback' {aka 'void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)'} to 'Callback' {aka 'void (*)(const v8::WeakCallbackInfo<void>&)'} [-Wcast-function-type]                reinterpret_cast<Callback>(callback), type);                ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    In file included from ../src/linux/BTSerialPortBindingServer.cc:14:../node_modules/nan/nan.h: In function 'void Nan::AsyncQueueWorker(Nan::AsyncWorker*)':../node_modules/nan/nan.h:2298:62: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
    ../src/linux/BTSerialPortBindingServer.cc: In static member function 'static void BTSerialPortBindingServer::EIO_AfterListen(uv_work_t*)':../src/linux/BTSerialPortBindingServer.cc:176:33: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]         baton->ecb->Call(1, argv);                                 ^
    In file included from ../src/linux/BTSerialPortBindingServer.cc:14:../node_modules/nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~../src/linux/BTSerialPortBindingServer.cc: In static member function 'static void BTSerialPortBindingServer::TryListenAgain()':../src/linux/BTSerialPortBindingServer.cc:199:31: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]       baton->ecb->Call(1, argv);                               ^In file included from ../src/linux/BTSerialPortBindingServer.cc:14:../node_modules/nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~../src/linux/BTSerialPortBindingServer.cc: In static member function 'static void BTSerialPortBindingServer::EIO_AfterWrite(uv_work_t*)':../src/linux/BTSerialPortBindingServer.cc:239:33: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]     data->callback->Call(2, argv);                                 ^In file included from ../src/linux/BTSerialPortBindingServer.cc:14:../node_modules/nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~../src/linux/BTSerialPortBindingServer.cc:247:94: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]         uv_queue_work(uv_default_loop(), &nextQueuedWrite->req, EIO_Write, (uv_after_work_cb)EIO_AfterWrite);        ^~~~~~~~~~~~~~
    ../src/linux/BTSerialPortBindingServer.cc: In static member function 'static void BTSerialPortBindingServer::EIO_AfterRead(uv_work_t*)':../src/linux/BTSerialPortBindingServer.cc:311:36: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]             baton->cb->Call(2, argv);                                    ^In file included from ../src/linux/BTSerialPortBindingServer.cc:14:../node_modules/nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~
    ../src/linux/BTSerialPortBindingServer.cc:326:28: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]     baton->cb->Call(2, argv);                            ^In file included from ../src/linux/BTSerialPortBindingServer.cc:14:../node_modules/nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~
    ../src/linux/BTSerialPortBindingServer.cc: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE BTSerialPortBindingServer::New(Nan::NAN_METHOD_ARGS_TYPE)':../src/linux/BTSerialPortBindingServer.cc:408:70: warning: 'v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)' is deprecated: Use Isolate version [-Wdeprecated-declarations]         string propertyName = std::string(*String::Utf8Value(property));        ^
    In file included from /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:26,                 from ../src/linux/BTSerialPortBindingServer.cc:12:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:2892:28: note: declared here                   explicit Utf8Value(Local<v8::Value> obj));                            ^~~~~~~~~/home/iobroker/.node-gyp/10.16.3/include/node/v8config.h:324:3: note: in definition of macro 'V8_DEPRECATED'   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    ../src/linux/BTSerialPortBindingServer.cc:410:75: warning: 'v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)' is deprecated: Use Isolate version [-Wdeprecated-declarations]         options[propertyName] = std::string(*String::Utf8Value(optionValue));        ^In file included from /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:26,                 from ../src/linux/BTSerialPortBindingServer.cc:12:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:2892:28: note: declared here                   explicit Utf8Value(Local<v8::Value> obj));                            ^~~~~~~~~/home/iobroker/.node-gyp/10.16.3/include/node/v8config.h:324:3: note: in definition of macro 'V8_DEPRECATED'   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/linux/BTSerialPortBindingServer.cc:434:85: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]     uv_queue_work(uv_default_loop(), &baton->request, EIO_Listen, (uv_after_work_cb)EIO_AfterListen);        ^~~~~~~~~~~~~~~
    ../src/linux/BTSerialPortBindingServer.cc: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE BTSerialPortBindingServer::Write(Nan::NAN_METHOD_ARGS_TYPE)':../src/linux/BTSerialPortBindingServer.cc:536:43: warning: 'void* memset(void*, int, size_t)' clearing an object of type 'struct BTSerialPortBindingServer::write_baton_t' with no trivial copy-assignment; use assignment or value-initialization instead [-Wclass-memaccess]     memset(baton, 0, sizeof(write_baton_t));                                           ^In file included from ../src/linux/BTSerialPortBindingServer.cc:22:../src/BTSerialPortBindingServer.h:53:16: note: 'struct BTSerialPortBindingServer::write_baton_t' declared here         struct write_baton_t {                ^~~~~~~~~~~~~
    ../src/linux/BTSerialPortBindingServer.cc:555:90: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]         uv_queue_work(uv_default_loop(), &queuedWrite->req, EIO_Write, (uv_after_work_cb)EIO_AfterWrite);        ^~~~~~~~~~~~~~
    ../src/linux/BTSerialPortBindingServer.cc: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE BTSerialPortBindingServer::Read(Nan::NAN_METHOD_ARGS_TYPE)':../src/linux/BTSerialPortBindingServer.cc:618:25: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]         nc->Call(2, argv);                         ^In file included from ../src/linux/BTSerialPortBindingServer.cc:14:../node_modules/nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~
    ../src/linux/BTSerialPortBindingServer.cc:626:83: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]     uv_queue_work(uv_default_loop(), &baton->request, EIO_Read, (uv_after_work_cb)EIO_AfterRead);        ^~~~~~~~~~~~~
    ../src/linux/BTSerialPortBindingServer.cc: In member function 'virtual void BTSerialPortBindingServer::ClientWorker::HandleOKCallback()':../src/linux/BTSerialPortBindingServer.cc:672:27: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]     callback->Call(1, argv);                           ^In file included from ../src/linux/BTSerialPortBindingServer.cc:14:../node_modules/nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~
    In file included from ../src/linux/BTSerialPortBindingServer.cc:12:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h: In instantiation of 'void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]':/home/iobroker/.node-gyp/10.16.3/include/node/node_object_wrap.h:84:78:   required from here/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:9502:16: warning: cast between incompatible function types from 'v8::WeakCallbackInfo<node::ObjectWrap>::Callback' {aka 'void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)'} to 'Callback' {aka 'void (*)(const v8::WeakCallbackInfo<void>&)'} [-Wcast-function-type]                reinterpret_cast<Callback>(callback), type);                ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    upload [13] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/words.js words.js application/javascript
    upload [12] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/radar2.png radar2.png image/png
    upload [11] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/index_m.html index_m.html text/html
    upload [10] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/index.html index.html text/html
    upload [9] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [8] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [7] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [6] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [5] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [4] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [3] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [2] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [1] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [0] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/de/translations.json i18n/de/translations.json application/json
    process exited with code 0
    CC2538+CC2592 PA-Zigbee-Funkmodul
      2.0.10 ist auf Github. Changelog:
      • (Apollon77) Optimize Compact mode CLI commands (fixes #468, fixes #471, #470)
      • (Apollon77) fixes #475, #476
      • (Apollon77) only use quit from redid and let ioredis handle the disconnect, hopefully fixes #472, update objects-ha-lib
      • (Apollon77) object changes are only logged as debug from now on, fixes #473
      • (Apollon77) Some adapter tweaks when running in "--install" mode (no reporting, don't check sigKill)
      sigi234S
      sigi234S
      #188
      @apollon77 sagte in [Aufruf] js-controller 2.0 Beta Test:
      Erledigt, läuft.
      • M
        M
        msauer
        #189
        Update auf 2.0.10 gemacht...wieder Fehler wegen pids.txt...fix script erneut ausgeführt..läuft
        Proxmox 3 Node HA-Cluster Mini-PC N150 mit 32 GB RAM und 3x1TB shared SSDs via Linstor. VM- iobroker ,OpenCCU / LXC - Adguard, Traccar, iSpy, Fileserver (emby, MiniDLNA)...etc.
        W 1 Antwort Letzte Antwort
        • M msauer
          W
          W
          watcherkb
          #190
          @msauer sagte in [Aufruf] js-controller 2.0 Beta Test:
          @apollon77
          bei mir genauso. Aber jetzt läuft alles, auch der Radar2 Adapter. Zufall?
          • W watcherkb
            @apollon77
            apollon77A
            apollon77A
            #191
            @watcherkb @msauer Das mit den PIDs.txt ist strange. Ihr habt aber nicht zufällig geschaut wem das File vor dem Fixer gehörte und so?
            @watcherkb Was Radar angeht gab es bei mir keine Änderungen ... also Zufall? ;-))
            Noch ein was zu "Anzeige im Admin Ampeln kaputt: Wenn Ihr unter "Instanzen" oben auf den Reload Button klicks (als in der ioBroker UI der ganz linke): passts danach?
            Ich habe mal eine Änderung die ich Bluefox vorschlage. Es gibt theoretisch einen kurzen Zeitraum beim neu laden vom Admin wo solche Dinge passieren könnten das Admin nicht aktuelle Daten nutzt. Aber ein "reload" mit dem oben genannten sollte das auch fixen.
            W M 2 Antworten Letzte Antwort
            • SBorgS
              SBorgS
              SBorg
              #192
              Geht noch das Node-RED Dashboard bei jemandem? Eben erst mal wieder mit der 10er probiert, aber nur noch "weißer Adler auf weißem Grund".
              An der 1.10.1 Node-RED liegt es nicht, die hatte ich schon länger drauf. Im Debug tauchen auch keine Fehler auf. IMO war ich beim letzten mal mit JS 2.0.7 drauf ... :(
              LG SBorg ( SBorg auf GitHub)
              W apollon77A 2 Antworten Letzte Antwort
              • SBorgS SBorg
                W
                W
                watcherkb
                #193
                @SBorg mit 1.7.1 gehts bei mir
                  W
                  W
                  watcherkb
                  #194
                  leider nein, nicht dran gedacht, sorry.
                  • SBorgS SBorg
                    apollon77A
                    apollon77A
                    #195
                    @SBorg Irgendwas im Browser Konsole oder Log oder irgendwas? An sich sollte sowas mit controller sehr wenig zu tun haben
                    • MathiasJM
                      MathiasJM
                      MathiasJ
                      schrieb am zuletzt editiert von MathiasJ
                      #196
                      Update gemacht, auf dem Testsystem.
                      Das Testystem ist ein Klon 1:1 mit dem laufendem System, nur läuft auf dem produktiven noch 1.5.xxxx
                      Problem:
                      Radar scannt meine G-Tags nicht mehr.
                      Sieht so aus, als Radar gar nichts mehr scant, was mit BT zu tun hat.
                      Scan mit hcitool only. kein BT wird gescant
                      Scan ohne Haken: kein BT wird gescant
                      hcitool lecan 0 problemo.
                      natürlich den fix drüber laufen lassen.
                      Gruß,
                      Mathias
                      IObroker auf dem NUC als VM.
                      • M
                        M
                        msauer
                        #197
                        hi..ich hatte ja zuvor 2.0.10 schon drauf. Habe mich aber entschlossen das alles mal neu zu machen. Also zum Snaphot zurück. Dann aber schon vorab alle adapter inkl. radar2 usw upgedated..Aber auch NMP auf 6.11.3 gebracht. Danach funktionierte der Update auf 2.0.10 nicht mehr...massen an Fehlern
                        npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/bluebird-94a2b92b/js/browser/bluebird.min.js'
                        npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/ioredis-36ec8081/built/errors'
                        npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/node-forge-b80a29ee/dist/forge.all.min.js.map'
                        npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/node-forge-b80a29ee/dist/forge.min.js'
                        npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/ioredis-36ec8081/built/index.js'
                        npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/ioredis-36ec8081/built/pipeline.js'
                        npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/ioredis-36ec8081/built/promiseContainer.js'
                        npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/ioredis-36ec8081/built/redis'
                        npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/node-forge-77fde8f3/lib/forge.js'
                        npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/ioredis-36ec8081/built/ScanStream.js'
                        npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/ioredis-36ec8081/built/script.js'
                        npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/ioredis-36ec8081/built/SubscriptionSet.js'
                        npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/ioredis-36ec8081/built/transaction.js'
                        npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/ioredis-36ec8081/built/types.js'
                        npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/ioredis-36ec8081/built/utils'
                        npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/socket.io-client-0aae0dc4/dist/socket.io.slim.dev.js'
                        npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/node-forge-77fde8f3/lib/form.js'
                        npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/node-forge-77fde8f3/lib/hmac.js'
                        npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/node-forge-77fde8f3/lib/http.js'
                        npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/fsevents-873428bc/node_modules/console-control-strings/index.js'
                        npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/fsevents-873428bc/node_modules/console-control-strings/LICENSE'
                        npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/fsevents-873428bc/node_modules/console-control-strings/package.json'
                        npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/fsevents-873428bc/node_modules/console-control-strings/README.md'
                        npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/fsevents-873428bc/node_modules/console-control-strings/README.md~'
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/chokidar/node_modules/fsevents):
                        npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/.staging/fsevents-873428bc/node_modules/abbrev' -> '/opt/iobroker/node_modules/.staging/abbrev-feda4970'
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/iobroker.luftdaten/node_modules/fsevents):
                        npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/.staging/fsevents-3bd0f148/node_modules/abbrev' -> '/opt/iobroker/node_modules/.staging/abbrev-381daafd'
                        npm ERR! code 128
                        npm ERR! Command failed: git clone --mirror -q git://github.com/ioBroker/ioBroker.js-controller.git /root/.npm/_cacache/tmp/git-clone-96cd045a/.git
                        npm ERR! fatal: Konnte führende Verzeichnisse von '/root/.npm/_cacache/tmp/git-clone-96cd045a/.git' nicht erstellen.
                        npm ERR!
                        npm ERR! /root/.npm/_logs/2019-09-26T13_23_16_967Z-debug.log
                        Es half dann letztendlich nur noch
                        sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller
                        • MathiasJM
                          MathiasJM
                          MathiasJ
                          #198
                          Update:
                          Radar2 deinstalliert, alle Objekte gelöscht und neu installiert.
                          Nun werden auch meine BT-Geräte erkannt.......
                          warum auch immer......
                          • M
                            M
                            msauer
                            #199
                            Jetzt kommt bei Radar2 die folgende Meldung
                            No geo location data found configured in admin to calculate UWZ AREA ID or ID not valid!
                            Issue ist schon aufgemacht
                            MathiasJM 1 Antwort Letzte Antwort
                              M
                              M
                              msauer
                              schrieb am zuletzt editiert von msauer
                              #200
                              @apollon77 said in [Aufruf] js-controller 2.0 Beta Test:
                              aber ein "reload" mit dem oben genannten sollte das auch fixen.
                              Keine Wirkung...Aber eine gewaltige beim Seiten neu laden...es wurden aus einer gelben dann 6 Adapter, die gelb wurden.
                              Das war übrigens vor der Redis Umstellung nicht..da waren alle grün.
                              • M msauer
                                MathiasJM
                                MathiasJM
                                MathiasJ
                                #201
                                @msauer
                                Hier gleiches Problem.
                                Reload hat hier auch nichts gebracht.
                                • M
                                  M
                                  msauer
                                  #202
                                  nachdem ich in bei allen in die info gegangen war:
                                  Nach Seiten reload
                                  • M msauer
                                    Nach Seiten reload
                                    apollon77A
                                    apollon77A
                                    #203
                                    @msauer Also so oder so: Das ist irgendwo im Admin und bei mir passiert es nicht ... finden wir noch irgendwie raus.
                                      SBorgS
                                      SBorgS
                                      SBorg
                                      schrieb am zuletzt editiert von SBorg
                                      #204
                                      Zumindest liegt es nicht am "Patch" von Node-RED, danach lief es definitiv noch. Ich sehe noch kurz "Willkommen beim Node-RED Dashboard" (oder so ähnlich). Wodurch aber jetzt in Node-RED der socket.io kommt...(FireFox-Konsole):
                                      Firefox kann keine Verbindung zu dem Server unter ws://192.168.1.30:1880/node-red/ui/socket.io/?EIO=3&transport=websocket&sid=xxx aufbauen.
                                      Hat dann wohl weniger mit dem JS-Controller zu tun?
                                      apollon77A SBorgS 3 Antworten Letzte Antwort
                                        M
                                        M
                                        msauer
                                        #205
                                        Bemerkenswert ist, das es immer die selben sind...nie andere Instanzen..
                                        • M msauer
                                          apollon77A
                                          apollon77A
                                          #206
                                          @msauer Hast Du mal beim Admin load in der Broweser Konsole geschaut. Immer die gleichen. cloud und hm-*?
                                          apollon77A M 2 Antworten Letzte Antwort
                                          83.8k
