  4. MaxCul Probleme kann HM Geräte nicht verbinden
maxculhm-cc-rt-dnhomematicnanocul868mhz
57 Beiträge 3 Kommentatoren 6.1k Aufrufe 1 Beobachtet
    @Lucy_Wolf:
    nicht Navigieren zu können
    Hat Dein Ubuntu keine graphische Oberfläche ?
    Dateien -> Andere Orte -> Rechner
    Lucy_WolfL Offline
    Lucy_WolfL Offline
    Lucy_Wolf
    @paul53 ne ist genau ubuntu server, ja war eine doffe idee, wenn ich ein pi4 habe, wirt alles auch besser laufen und weis wie alles läuft und gemacht werden muss
    • Lucy_WolfL Lucy_Wolf
      @Lucy_Wolf sagte:
      Na dann per Kommandozeile.
      Lucy_WolfL 1 Antwort Letzte Antwort
        @Lucy_Wolf sagte:
        Lucy_WolfL Offline
        Lucy_WolfL Offline
        Lucy_Wolf
        schrieb am zuletzt editiert von Lucy_Wolf
        GNU nano 2.9.3 main.conf
        Homegear configuration file
        See for more details: https://doc.homegear.eu/data/homegear/configuration.html#main-configuration-main-conf
        Default: runAsUser = root
        runAsUser = homegear
        Default: runAsGroup = root
        runAsGroup = homegear
        Set the debug log level
        0=none, 1=critical, 2=error, 3=warning, 4=info, 5=debug, >5=more debug information
        Default: 4
        debugLevel = 4
        Default: memoryDebugging = false
        memoryDebugging = true
        Prints log information helping in fixing errors
        Default: devLog = false
        devLog = false
        Logs all IPC communication to a PCAP file
        Default: ipcLog = false
        ipcLog = false
        Set to false to disable core dumps. Currently to make fixing errors easier, core dumps are enabled by default.
        Default: enableCoreDumps = true
        If set to true Homegear sets permissions on devices and GPIOs on start. On some systems that might not be
        desirable or necessary. If Homegear is part of all groups that have access to the needed devices, you can
        savely set this setting to false.
        Default: setDevicePermissions = true
        The working directory of Homegear. E. g. core dumps are written here. If workingDirectory is empty, the
        executable path is used.
        Default: workingDirectory =
        workingDirectory = /var/lib/homegear
        The socket files are placed into this directory. If socketPath is empty, the executable path is used.
        Default: socketPath =
        socketPath = /var/run/homegear
        If dataPath is empty, the executable path is used.
        Default: dataPath =
        dataPath = /var/lib/homegear
          Default: 4
          debugLevel = 4
          devLog = false
          ipcLog = false
          Default: dataPath =
          @Lucy_Wolf
          Ich denke, das kann man so lassen. Bitte das nächste Mal den Inhalt in Code tags posten.
          Lucy_WolfL 3 Antworten Letzte Antwort
            @Lucy_Wolf
            Lucy_WolfL Offline
            Lucy_WolfL Offline
            Lucy_Wolf
             GNU nano 2.9.3
            # Homegear configuration file
            # See for more details: https://doc.homegear.eu/data/homegear/configuration.html#main-configuration-
            # Default: runAsUser = root
            # runAsUser = homegear
            # Default: runAsGroup = root
            # runAsGroup = homegear
            # Set the debug log level
            # 0=none, 1=critical, 2=error, 3=warning, 4=info, 5=debug, >5=more debug information
            # Default: 4
            debugLevel = 4
            # Default: memoryDebugging = false
              GNU nano 2.9.3                             rpcclients.conf
            # rpcclients.conf
            # In this file you can define security settings for your XML RPC clients
            # The name between the square brackets is arbitrary
            [ExampleClient1]
            # For security reasons you should always use the hostname here. Otherwise
            # the certificate verification doesn't work and Homegear might send you
            # client's password to an unauthorized client.
            # "hostname" must be specified. It is used to identify the client.
            hostname = myHostName
            # The path to the certificate authority's certificate
            caFile = /path/to/ca-certficate
            # verifyCertificate checks if the server certificate received by the
            # XML RPC client from the XML RPC event server is signed by one of the
            # root CAs in /etc/ssl/certs. If you use a self signed certificate,
            # please put your root certificate in that directory. Only disable the
            # verification for testing purposes. Without verification any attacker
            # can pose as your XML RPC event server.
            # Default: verifyCertificate = true
            # For security reasons always set "forceSSL to true when the client supports
            # SSL, especially when authentification is being used. Otherwise Homegear
            # might send your clients password to an unauthorized client.
            # Default: forceSSL = true
            forceSSL = true
              @Lucy_Wolf
              Lucy_WolfL Offline
              Lucy_WolfL Offline
              Lucy_Wolf
              @paul53 ich bekomme es noch hin lol
              danke für den hinweis^^
                @Lucy_Wolf
                Lucy_WolfL Offline
                Lucy_WolfL Offline
                Lucy_Wolf
                @paul53 muss ich darin was ändern
                  @Lucy_Wolf sagte:
                  hostname solltest Du ändern. Zu SSL und Zertifikaten kann ich nichts sagen (bin kein ITler).
                    @Lucy_Wolf sagte:
                    Lucy_WolfL Offline
                    Lucy_WolfL Offline
                    Lucy_Wolf
                    @paul53 den hostname ist dann das wie der heißen soll ?
                    würde dann es homegear nennen
                      @Lucy_Wolf
                      Es gibt ein deutschsprachiges Homegear-Forum.
                        @Lucy_Wolf
                        Lucy_WolfL Offline
                        Lucy_WolfL Offline
                        Lucy_Wolf
                        @paul53 naja sind scheinbar fast durch
                        ip lass ich vom router vergeben, kann ich dann am router festlegen
                        mqtt lass ich so
                          mqtt lass ich so
                          @Lucy_Wolf :
                          Das ist die IP-Adresse von Ubuntu. Homegear und ioBroker kommunizieren über localhost (127.0.0.1).
                          @Lucy_Wolf sagte in MaxCul Probleme kann HM Geräte nicht verbinden:
                          mqtt lass ich so
                          Ja, MQTT wird nicht benötigt.
                            @Lucy_Wolf :
                            mqtt lass ich so
                            Lucy_WolfL Offline
                            Lucy_WolfL Offline
                            Lucy_Wolf
                            @paul53 bei 10.1. Main Configuration muss ich auch noch durch oder?
                              @Lucy_Wolf
                              Die Voreinstellungen sollten passen.
                                @Lucy_Wolf
                                Lucy_WolfL Offline
                                Lucy_WolfL Offline
                                Lucy_Wolf
                                @paul53 wie starte ich das jetzt oder leuft das jetzt schon
                                  @Lucy_Wolf sagte:
                                  Keine Ahnung 😧
                                  Laut Homegear Grundlagen soll es nach der Installation schon laufen.
                                  Nach der Installation läuft Homegear als Dienst im Hintergrund. Mittels sudo service homegear restart kann der Dienst bei Bedarf - zum Beispiel nach Änderungen an den Konfigurationsdateien - neu gestartet werden.
                                    @Lucy_Wolf sagte:
                                    Keine Ahnung 😧
                                    Lucy_WolfL Offline
                                    Lucy_WolfL Offline
                                    Lucy_Wolf
                                    @paul53 im router ist jedenfall nix neues dazu gekommen
                                      @Lucy_Wolf sagte:
                                      Wie auch ? ioBroker und Homegear laufen unter dem gleichen Ubuntu. Oder läuft ioBroker im Container ?
                                      Übrigens: Zum Anlernen und Konfigurieren der Geräte empfehle ich das Windows-Tool HomeMatic-Konfigurator, das ich auch verwende. Unter Einstellungen muss "Entfernter BidCos-Service" ausgewählt werden und die Ubuntu-IP-Adresse angegeben werden.
                                        @Lucy_Wolf sagte:
                                        Lucy_WolfL Offline
                                        Lucy_WolfL Offline
                                        Lucy_Wolf
                                        @paul53 iobroker läuft so wie andere Tutorials gezeigt wurde
                                          Lucy_WolfL Offline
                                          Lucy_WolfL Offline
                                          Lucy_Wolf
                                          @paul53 was für eine ccu brauche ich oder was meinst du was ich machen soll
