  4. MaxCul Probleme kann HM Geräte nicht verbinden
maxculhm-cc-rt-dnhomematicnanocul868mhz
57 Beiträge 3 Kommentatoren 6.1k Aufrufe 1 Beobachtet
    @Lucy_Wolf
    Ich denke, das kann man so lassen. Bitte das nächste Mal den Inhalt in Code tags posten.
    Lucy_WolfL Offline
    Lucy_WolfL Offline
    Lucy_Wolf
    schrieb am zuletzt editiert von Lucy_Wolf
     GNU nano 2.9.3
    # Homegear configuration file
    # See for more details: https://doc.homegear.eu/data/homegear/configuration.html#main-configuration-
    # Default: runAsUser = root
    # runAsUser = homegear
    # Default: runAsGroup = root
    # runAsGroup = homegear
    # Set the debug log level
    # 0=none, 1=critical, 2=error, 3=warning, 4=info, 5=debug, >5=more debug information
    # Default: 4
    debugLevel = 4
    # Default: memoryDebugging = false
    memoryDebugging = true
      GNU nano 2.9.3                             rpcclients.conf
    # rpcclients.conf
    # In this file you can define security settings for your XML RPC clients
    # The name between the square brackets is arbitrary
    [ExampleClient1]
    # For security reasons you should always use the hostname here. Otherwise
    # the certificate verification doesn't work and Homegear might send you
    # client's password to an unauthorized client.
    # "hostname" must be specified. It is used to identify the client.
    hostname = myHostName
    # The path to the certificate authority's certificate
    caFile = /path/to/ca-certficate
    # verifyCertificate checks if the server certificate received by the
    # XML RPC client from the XML RPC event server is signed by one of the
    # root CAs in /etc/ssl/certs. If you use a self signed certificate,
    # please put your root certificate in that directory. Only disable the
    # verification for testing purposes. Without verification any attacker
    # can pose as your XML RPC event server.
    # Default: verifyCertificate = true
    # For security reasons always set "forceSSL to true when the client supports
    # SSL, especially when authentification is being used. Otherwise Homegear
    # might send your clients password to an unauthorized client.
    # Default: forceSSL = true
    forceSSL = true
      @Lucy_Wolf
      Lucy_WolfL Offline
      Lucy_WolfL Offline
      Lucy_Wolf
      @paul53 ich bekomme es noch hin lol
      danke für den hinweis^^
        @Lucy_Wolf
        Lucy_WolfL Offline
        Lucy_WolfL Offline
        Lucy_Wolf
        @paul53 muss ich darin was ändern
        • Lucy_WolfL Lucy_Wolf
          @Lucy_Wolf sagte:
          hostname solltest Du ändern. Zu SSL und Zertifikaten kann ich nichts sagen (bin kein ITler).
          Lucy_WolfL 1 Antwort Letzte Antwort
            @Lucy_Wolf sagte:
            Lucy_WolfL Offline
            Lucy_WolfL Offline
            Lucy_Wolf
            @paul53 den hostname ist dann das wie der heißen soll ?
            würde dann es homegear nennen
              @Lucy_Wolf
              Es gibt ein deutschsprachiges Homegear-Forum.
                @Lucy_Wolf
                Lucy_WolfL Offline
                Lucy_WolfL Offline
                Lucy_Wolf
                @paul53 naja sind scheinbar fast durch
                ip lass ich vom router vergeben, kann ich dann am router festlegen
                mqtt lass ich so
                  mqtt lass ich so
                  @Lucy_Wolf :
                  Das ist die IP-Adresse von Ubuntu. Homegear und ioBroker kommunizieren über localhost (127.0.0.1).
                  @Lucy_Wolf sagte in MaxCul Probleme kann HM Geräte nicht verbinden:
                  mqtt lass ich so
                  Ja, MQTT wird nicht benötigt.
                    @Lucy_Wolf :
                    mqtt lass ich so
                    Lucy_WolfL Offline
                    Lucy_WolfL Offline
                    Lucy_Wolf
                    @paul53 bei 10.1. Main Configuration muss ich auch noch durch oder?
                      @Lucy_Wolf
                      Die Voreinstellungen sollten passen.
                        @Lucy_Wolf
                        Lucy_WolfL Offline
                        Lucy_WolfL Offline
                        Lucy_Wolf
                        @paul53 wie starte ich das jetzt oder leuft das jetzt schon
                          @Lucy_Wolf sagte:
                          Keine Ahnung 😧
                          Laut Homegear Grundlagen soll es nach der Installation schon laufen.
                          Nach der Installation läuft Homegear als Dienst im Hintergrund. Mittels sudo service homegear restart kann der Dienst bei Bedarf - zum Beispiel nach Änderungen an den Konfigurationsdateien - neu gestartet werden.
                            @Lucy_Wolf sagte:
                            Keine Ahnung 😧
                            Lucy_WolfL Offline
                            Lucy_WolfL Offline
                            Lucy_Wolf
                            @paul53 im router ist jedenfall nix neues dazu gekommen
                              @Lucy_Wolf sagte:
                              Wie auch ? ioBroker und Homegear laufen unter dem gleichen Ubuntu. Oder läuft ioBroker im Container ?
                              Übrigens: Zum Anlernen und Konfigurieren der Geräte empfehle ich das Windows-Tool HomeMatic-Konfigurator, das ich auch verwende. Unter Einstellungen muss "Entfernter BidCos-Service" ausgewählt werden und die Ubuntu-IP-Adresse angegeben werden.
                                @Lucy_Wolf sagte:
                                Lucy_WolfL Offline
                                Lucy_WolfL Offline
                                Lucy_Wolf
                                @paul53 iobroker läuft so wie andere Tutorials gezeigt wurde
                                  Lucy_WolfL Offline
                                  Lucy_WolfL Offline
                                  Lucy_Wolf
                                  @paul53 was für eine ccu brauche ich oder was meinst du was ich machen soll
                                    @Lucy_Wolf sagte:
                                    Die verlinkte Datei unter Windows entpacken, dann installieren und anschließend mit den Einstellungen wie oben genannt, die Thermostate anlernen. Das ist übersichtlicher als mit der Kommandozeile für Homegear.
                                      @Lucy_Wolf sagte:
                                      Lucy_WolfL Offline
                                      Lucy_WolfL Offline
                                      Lucy_Wolf
                                      @paul53 lan interface und dann die ip eingeben
                                        @Lucy_Wolf sagte:
                                        Nein, "Entfernter BidCos-Sevice" und dann die IP und Port 2001.
                                        Den "entfernten BidCos-Service" liefert Homegear unter Ubuntu.
                                        Lucy_WolfL 2 Antworten Letzte Antwort
                                          @Lucy_Wolf sagte:
                                          Lucy_WolfL Offline
                                          Lucy_WolfL Offline
                                          Lucy_Wolf
                                          @paul53 verbunden lampe ist grün
