  4. Test Adaper Discovergy v0.4.x
energie
294 Beiträge 33 Kommentatoren 69.6k Aufrufe 21 Beobachtet
  • opossumO opossum
    Discovergy hat wohl die API geändert. Ich erhalte vom Discovergy-Adapter Errormeldungen im Log.
    2019-09-02 00:00:06.543 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
    2019-09-02 00:00:06.543 - error: discovergy.0 Send this information to developer : manufacturerId : ESY
    2019-09-02 00:00:06.544 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
    2019-09-02 00:00:06.544 - error: discovergy.0 Send this information to developer : fullSerialNumber : 1ESY1234567890
    2019-09-02 00:00:06.544 - error: discovergy.0 Send this information to developer : loadProfileType : SLP
    Die Seriennummer habe ich verändert. Aber ich habe gesehen, dass es dazu schon ein Issue gibt.
    Egbert
    DutchmanD Offline
    DutchmanD Offline
    Dutchman
    #96
    @opossum sagte in [Aufruf] Neuer Adaper Discovergy:
    Spoiler
    Mja nicht geändert, halt neue Sachen hinzugefügt ich werde den adapter damit erweitern.
    • D danielhainich
      @Dutchman
      jetzt kommen Logs.
      2019-09-02 07:39:44.781  - info: discovergy.0 Discovergy adapter stopped, cleaning everything up :-)
      2019-09-02 07:39:44.779  - info: host.xxx stopInstance system.adapter.discovergy.0
      2019-09-02 07:39:44.779  - info: host.xxx stopInstance system.adapter.discovergy.0 killing pid 3815
      2019-09-02 07:39:44.785  - info: discovergy.0 Discovergy adapter stopped, cleaning everything up :-)
      2019-09-02 07:39:44.793  - info: host.xxx instance system.adapter.discovergy.0 terminated with code 0 (OK)
      2019-09-02 07:39:47.288  - info: host.xxx instance system.adapter.discovergy.0 started with pid 15114
      2019-09-02 07:39:47.670  - debug: discovergy.0 objectDB connected
      2019-09-02 07:39:47.695  - debug: discovergy.0 statesDB connected
      2019-09-02 07:39:47.773  - info: discovergy.0 starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v8.16.1
      2019-09-02 07:39:47.783  - debug: discovergy.0 ready - Adapter: databases are connected and adapter received configuration
      2019-09-02 07:39:47.786  - debug: discovergy.0 client_secret decrypt ready
      2019-09-02 07:39:47.933  - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
      2019-09-02 07:39:47.933  - error: discovergy.0 Send this information to developer : manufacturerId : EMH
      2019-09-02 07:39:47.933  - error: discovergy.0 Send this information to developer : fullSerialNumber : 1EMH0123456789
      2019-09-02 07:39:47.933  - error: discovergy.0 Send this information to developer : loadProfileType : RLM
      2019-09-02 07:39:50.870  - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
      2019-09-02 07:39:50.871  - error: discovergy.0 Send this information to developer : manufacturerId : EMH
      DutchmanD Offline
      DutchmanD Offline
      Dutchman
      #97
      @danielhainich sagte in [Aufruf] Neuer Adaper Discovergy:
      jetzt kommen Logs.
      ok sieht so aus also dein API key vorher 0 daten hatte, werden den jetzt auch object erstellt ?
      D 2 Antworten Letzte Antwort
      • DutchmanD Dutchman
        jetzt kommen Logs.
        danielhainich
        #98
        @Dutchman
        ich habe nur objekte für meterID, type und die ganze location-sektion.
        ansonsten fehlen mir noch die daten selbst. das dürfte aber daran liegen das du den profiletype und hersteller noch nicht kennst.
        ich werde mal schauen wenn du den adapter aktualisiert hast, was dann an daten kommt.
        danke
        daniel
        • WebrangerW Offline
          WebrangerW Offline
          Webranger
          #99
          Hab dann auch mal gerade in die logs geguckt ;)
          folgendes steht bei mir zu hauf drin:
          discovergy.0	2019-09-02 18:58:15.265	error	Information received from Discovergy which is not yet part of this adapter
          discovergy.0	2019-09-02 18:58:12.262	error	Send this information to developer : loadProfileType : SLP
          discovergy.0	2019-09-02 18:58:12.262	error	Information received from Discovergy which is not yet part of this adapter
          discovergy.0	2019-09-02 18:58:12.262	error	Send this information to developer : fullSerialNumber : 1ESY1160867681
          discovergy.0	2019-09-02 18:58:12.262	error	Send this information to developer : manufacturerId : ESY
          Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
            WebrangerW Offline
            Webranger
            schrieb am zuletzt editiert von Webranger
            #100
            Discovergy hat mich aus der Api entfernt und habe auch online keinen zugang mehr zum zähler.
            Der fresh.energy Adapter liefert seit 6:32 auch keine Daten mehr!?
            Kommt bei euch noch was an????
              jetzt kommen Logs.
              danielhainich
              #101
              @Dutchman
              hi, hattest du schon zeit den adapter entsprechend zu erweitern?
              brauchst du noch mehr infos?
              grüße
              daniel
              WebrangerW 1 Antwort Letzte Antwort
              • D danielhainich
                @Dutchman
                grüße
                daniel
                WebrangerW Offline
                WebrangerW Offline
                Webranger
                #102
                @danielhainich läuft dein discovergy Zugang noch? Bist du bei fresh energy?
                • WebrangerW Webranger
                  danielhainich
                  #103
                  @Webranger
                  es scheint zumindest so. ich bekomme im log die meldung das ich folgende daten an den entwickler schicken soll...
                  discovergy.0 2019-09-05 07:47:23.804 error Send this information to developer : loadProfileType : RLM
                  discovergy.0 2019-09-05 07:47:23.804 error Information received from Discovergy which is not yet part of this adapter
                  discovergy.0 2019-09-05 07:47:23.804 error Send this information to developer : fullSerialNumber : 1EMH0123456789
                  discovergy.0 2019-09-05 07:47:23.803 error Send this information to developer : manufacturerId : EMH
                  discovergy.0 2019-09-05 07:47:23.803 error Information received from Discovergy which is not yet part of this adapter
                  • D danielhainich
                    @Webranger
                    WebrangerW Offline
                    WebrangerW Offline
                    Webranger
                    #104
                    @danielhainich aber auch bei fresh energy bzw jetzt mark-e!?
                      danielhainich
                      #105
                      @Webranger
                      mit dem freshenergy-adapter kommt bei mir gar nichts. weder daten noch fehler.
                      • D danielhainich
                        @Webranger
                        WebrangerW Offline
                        WebrangerW Offline
                        Webranger
                        #106
                        @danielhainich aber du bist bei fresh energy?
                        Ich kann mich seit Montag zwar noch einloggen bei discovergy im Portal aber da ist dann mein Zähler nicht mehr hinterlegt.
                        Der fresh energy Adapter liefert seit Montag keine Daten und auch keine Fehler im log
                        Die fresh energy App geht ohne Probleme und liefert Daten die auch mir dem Zähler übereinstimmen.
                          danielhainich
                          #107
                          @Webranger
                          nein, bei discovergy.
                          • D danielhainich
                            @Webranger
                            WebrangerW Offline
                            WebrangerW Offline
                            Webranger
                            #108
                            @danielhainich dann wird der fresh energy Adapter bei dir auch nicht laufen. Da musst du ja die Zugangsdaten von fresh energy eintragen.
                            • C Offline
                              csamaggi
                              #109
                              Er redet hier auch vom Discovergy Adapter denn das Problem habe ich auch seit Montag ist auch mein Zähler dort nicht mehr hinterlegt was sehr schade ist denn so bekomme ich nicht die aktuellen Daten wie Verbrauch aktuell und so weiter.
                              MFG Maggi
                              • C csamaggi
                                MFG Maggi
                                WebrangerW Offline
                                WebrangerW Offline
                                Webranger
                                #110
                                @csamaggi ja das richtig doof.
                                Hoffe die von fresh energy/mark-e bekommen das wieder auf die Reihe. Ansonsten kann ich auch wieder wechseln.
                                • C Offline
                                  csamaggi
                                  #111
                                  Ich würde deswegen nicht wechseln ist zwar schade dass dies nicht läuft aber der Hauptgrund für mich war zu Fresh zu wechseln dass ich dort das bezahle was ich verbrauche jeden Monat ohne Abschlagszahlung.
                                  Hoffen wir mal dass die das irgendwie wieder hinbekommen.
                                  MFG Maggi
                                  • C csamaggi
                                    MFG Maggi
                                    WebrangerW Offline
                                    WebrangerW Offline
                                    Webranger
                                    #112
                                    @csamaggi hast du denen schon geschrieben?
                                    • C Offline
                                      csamaggi
                                      schrieb am zuletzt editiert von csamaggi
                                      #113
                                      Ich habe eine Nachricht an Discovergy geschrieben. Mal sehen was sie antworten.
                                      MFG Maggi
                                      • C csamaggi
                                        MFG Maggi
                                        WebrangerW Offline
                                        WebrangerW Offline
                                        Webranger
                                        #114
                                        @csamaggi
                                        Das ja krass! In der discovergy app werden mit tatsächlich auch noch alle Daten angezeigt und auf der Webseite nichts mehr.
                                        Da sind die aber schwer was am basteln.
                                        Hoffentlich zu unseren gunsten
                                        EDIT
                                        Das scheinen aber nicht die richtigen Daten in der App zu sein! Ganz unterschiedliche Werte im Vergleich mit der fresh energy app
                                        • C Offline
                                          csamaggi
                                          #115
                                          Ja die Werte sind so wie es scheint nur Fiktiv zu sein denn sie passen nicht mit meinen Daten überein.
                                          Mal schauen was sie antworten.
                                          Update: Ich habe so eben eine Rückmeldung von Discovergy erhalten.
                                          Sehr geehrter Herr .....,
                                          Gerne würde Ich wissen, ob Sie keine Daten im Portal sehen oder in Ihrem System via API.
                                          Ihr Account ist mit dem Zähler verknüpft und versendet auch normale Daten. Falls Sie keine Daten sehen sollten, müssen Sie sich an Ihren Partner wenden, da wir das Portal von diesem aus leider nicht Supporten.
                                          Bei Rückfrage stehe ich Ihnen gerne zur Verfügung.
                                          Freundliche Grüße
                                          Sueda Ciftci
                                          Servicemanagement
                                          Update 2: Ich habe nun auch nochmal den FreshEnergy Support kontaktiert mit dem Hinweis dass Discovergy eben an die verweist. Mal schauen was da kommt.
                                          MFG Maggi
