  4. Verbindung zu iobroker fehlgeschlagen?
iobroker knx
42 Beiträge 5 Kommentatoren 4.6k Aufrufe 3 Beobachtet
  • D daniel1to
    @apollon77
    2019-08-18 07:20:49.980  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:20:49.980  - error: hue.0 Error: connect EHOSTUNREACH 192.168.178.38:80
    2019-08-18 07:20:50.014  - error: info.0 Error: getaddrinfo ENOTFOUND raw.githubusercontent.com raw.githubusercontent.com:443
    2019-08-18 07:20:50.785  - warn: info.0 Reconnection to DB.
    2019-08-18 07:20:50.788  - warn: info.0 Reconnection to DB.
    2019-08-18 07:20:50.805  - info: info.0 starting. Version 1.3.7 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.info, node: v10.16.0
    2019-08-18 07:20:50.807  - warn: discovery.0 Reconnection to DB.
    2019-08-18 07:20:50.812  - warn: discovery.0 Reconnection to DB.
    2019-08-18 07:20:50.815  - info: discovery.0 starting. Version 1.3.0 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.discovery, node: v10.16.0
    2019-08-18 07:20:50.825  - info: discovery.0 starting. Version 1.3.0 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.discovery, node: v10.16.0
    2019-08-18 07:20:51.200  - warn: admin.0 Reconnection to DB.
    2019-08-18 07:20:51.204  - warn: admin.0 Reconnection to DB.
    2019-08-18 07:20:51.212  - info: admin.0 starting. Version 3.6.2 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.admin, node: v10.16.0
    2019-08-18 07:20:51.212  - warn: hue.0 Reconnection to DB.
    2019-08-18 07:20:51.214  - warn: hue.0 Reconnection to DB.
    2019-08-18 07:20:51.226  - info: hue.0 starting. Version 1.2.3 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.hue, node: v10.16.0
    2019-08-18 07:20:51.233  - info: admin.0 starting. Version 3.6.2 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.admin, node: v10.16.0
    2019-08-18 07:20:51.247  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:20:51.247  - error: hue.0 Error: connect EHOSTUNREACH 192.168.178.38:80
    2019-08-18 07:20:51.255  - info: hue.0 starting. Version 1.2.3 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.hue, node: v10.16.0
    2019-08-18 07:20:51.261  - info: admin.0 requesting all states
    2019-08-18 07:20:51.261  - info: admin.0 requesting all objects
    2019-08-18 07:20:51.262  - info: admin.0 Request actual repository...
    2019-08-18 07:20:51.266  - info: admin.0 requesting all states
    2019-08-18 07:20:51.266  - info: admin.0 requesting all objects
    2019-08-18 07:20:51.266  - info: admin.0 Request actual repository...
    2019-08-18 07:20:51.267  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:20:51.267  - error: hue.0 Error: connect EHOSTUNREACH 192.168.178.38:80
    2019-08-18 07:20:51.430  - warn: knx.0 Reconnection to DB.
    2019-08-18 07:20:51.434  - warn: web.0 Reconnection to DB.
    2019-08-18 07:20:51.515  - warn: knx.0 Reconnection to DB.
    2019-08-18 07:20:51.508  - warn: web.0 Reconnection to DB.
    2019-08-18 07:20:51.540  - info: admin.0 received all states
    2019-08-18 07:20:51.536  - info: knx.0 starting. Version 0.8.6 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.knx, node: v10.16.0
    2019-08-18 07:20:51.545  - info: knx.0 Connecting to knx GW:  192.168.178.60:3671   with phy. Adr:  1.1.250 and SendDelay of : 50 ms
    2019-08-18 07:20:51.545  - info: knx.0 C:/Program Files/iobroker/SmartHome/node_modules/iobroker.js-controller
    2019-08-18 07:20:51.567  - error: knx.0 uncaught exception: Cannot read property 'address' of undefined
    2019-08-18 07:20:51.567  - error: knx.0 TypeError: Cannot read property 'address' of undefined
        at fsm.getLocalAddress (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.knx\lib\knx-mod\src\FSM.js:356:71)
        at fsm.IpTunnelingConnection.instance.Connect (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.knx\lib\knx-mod\src\IpTunnelingConnection.js:31:30)
        at Object.Connection (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.knx\lib\knx-mod\src\Connection.js:302:36)
        at t (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.knx\knx.js:1:3676)
        at Socket.<anonymous> (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.knx\knx.js:1:9733)
        at Socket.onack (C:\Program Files\iobroker\SmartHome\node_modules\socket.io-client\lib\socket.js:312:9)
        at Socket.onpacket (C:\Program Files\iobroker\SmartHome\node_modules\socket.io-client\lib\socket.js:236:12)
        at Manager.<anonymous> (C:\Program Files\iobroker\SmartHome\node_modules\component-bind\index.js:21:15)
        at Manager.Emitter.emit (C:\Program Files\iobroker\SmartHome\node_modules\socket.io-client\node_modules\component-emitter\index.js:133:20)
        at Manager.ondecoded (C:\Program Files\iobroker\SmartHome\node_modules\socket.io-client\lib\manager.js:332:8)
    2019-08-18 07:20:51.565  - info: info.0 Reading CPU current speed every 3 seconds.
    2019-08-18 07:20:51.566  - info: info.0 Reading CPU data every 3 seconds.
    2019-08-18 07:20:51.569  - error: info.0 Error: getaddrinfo ENOTFOUND raw.githubusercontent.com raw.githubusercontent.com:443
    2019-08-18 07:20:51.574  - info: info.0 Reading user data every 8 seconds.
    2019-08-18 07:20:51.610  - info: info.0 starting. Version 1.3.7 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.info, node: v10.16.0
    2019-08-18 07:20:51.647  - error: Caught by controller[0]: TypeError: Cannot read property 'address' of undefined
    2019-08-18 07:20:51.647  - error: Caught by controller[0]:     at fsm.getLocalAddress (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.knx\lib\knx-mod\src\FSM.js:356:71)
    2019-08-18 07:20:51.647  - error: Caught by controller[0]:     at fsm.IpTunnelingConnection.instance.Connect (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.knx\lib\knx-mod\src\IpTunnelingConnection.js:31:30)
    2019-08-18 07:20:51.647  - error: Caught by controller[0]:     at Object.Connection (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.knx\lib\knx-mod\src\Connection.js:302:36)
    2019-08-18 07:20:51.647  - error: Caught by controller[0]:     at t (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.knx\knx.js:1:3676)
    2019-08-18 07:20:51.647  - error: Caught by controller[0]:     at Socket.<anonymous> (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.knx\knx.js:1:9733)
    2019-08-18 07:20:51.647  - error: Caught by controller[0]:     at Socket.onack (C:\Program Files\iobroker\SmartHome\node_modules\socket.io-client\lib\socket.js:312:9)
    2019-08-18 07:20:51.647  - error: Caught by controller[0]:     at Socket.onpacket (C:\Program Files\iobroker\SmartHome\node_modules\socket.io-client\lib\socket.js:236:12)
    2019-08-18 07:20:51.647  - error: Caught by controller[0]:     at Manager.<anonymous> (C:\Program Files\iobroker\SmartHome\node_modules\component-bind\index.js:21:15)
    2019-08-18 07:20:51.647  - error: Caught by controller[0]:     at Manager.Emitter.emit (C:\Program Files\iobroker\SmartHome\node_modules\socket.io-client\node_modules\component-emitter\index.js:133:20)
    2019-08-18 07:20:51.647  - error: Caught by controller[0]:     at Manager.ondecoded (C:\Program Files\iobroker\SmartHome\node_modules\socket.io-client\lib\manager.js:332:8)
    2019-08-18 07:20:51.647  - error: host.DESKTOP-GFRKJ98(SmartHome) instance system.adapter.knx.0 terminated with code 0 (OK)
    2019-08-18 07:20:51.647  - info: host.DESKTOP-GFRKJ98(SmartHome) Restart adapter system.adapter.knx.0 because enabled
    2019-08-18 07:20:51.645  - info: web.0 starting. Version 2.4.1 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.web, node: v10.16.0
    2019-08-18 07:20:51.697  - info: web.0 starting. Version 2.4.1 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.web, node: v10.16.0
    2019-08-18 07:20:51.785  - info: web.0 socket.io server listening on port 8082
    2019-08-18 07:20:51.789  - info: web.0 socket.io server listening on port 8082
    2019-08-18 07:20:51.832  - info: admin.0 received all objects
    2019-08-18 07:20:51.890  - error: web.0 port 8082 already in use
    2019-08-18 07:20:51.923  - info: admin.0 received all states
    2019-08-18 07:20:51.960  - error: admin.0 port 8081 already in use
    2019-08-18 07:20:52.001  - error: host.DESKTOP-GFRKJ98(SmartHome) instance system.adapter.web.0 terminated with code 1 ()
    2019-08-18 07:20:52.001  - info: host.DESKTOP-GFRKJ98(SmartHome) Restart adapter system.adapter.web.0 because enabled
    2019-08-18 07:20:52.076  - error: host.DESKTOP-GFRKJ98(SmartHome) instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2019-08-18 07:20:52.076  - info: host.DESKTOP-GFRKJ98(SmartHome) Do not restart adapter system.adapter.admin.0 because desired by instance
    2019-08-18 07:20:52.281  - info: info.0 Reading CPU current speed every 3 seconds.
    2019-08-18 07:20:52.281  - info: info.0 Reading CPU data every 3 seconds.
    2019-08-18 07:20:52.287  - error: info.0 Error: getaddrinfo ENOTFOUND raw.githubusercontent.com raw.githubusercontent.com:443
    2019-08-18 07:20:52.414  - info: info.0 Reading memory data every 3 seconds.
    2019-08-18 07:20:52.573  - info: info.0 Reading user data every 8 seconds.
    2019-08-18 07:20:52.815  - info: info.0 Reading disk data every 8 seconds.
    2019-08-18 07:20:53.690  - info: info.0 Reading memory data every 3 seconds.
    2019-08-18 07:20:53.691  - info: info.0 Reading disk data every 8 seconds.
    2019-08-18 07:20:53.933  - info: info.0 Reading battery data every 8 seconds.
    2019-08-18 07:20:54.032  - info: info.0 Reading process data every 8 seconds.
    2019-08-18 07:20:54.069  - info: info.0 Reading process data every 8 seconds.
    2019-08-18 07:20:54.310  - info: info.0 Reading battery data every 8 seconds.
    2019-08-18 07:20:55.230  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:20:55.230  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:20:56.468  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:20:56.468  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:00.336  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:00.336  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:01.629  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:01.629  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:05.435  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:05.435  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:06.770  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:06.770  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:10.552  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:10.552  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:11.914  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:11.914  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:15.703  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:15.703  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:17.073  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:17.073  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:17.074  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:17.074  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:20.802  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:20.803  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:21.655  - info: host.DESKTOP-GFRKJ98(SmartHome) instance system.adapter.knx.0 started with pid 8468
    2019-08-18 07:21:22.012  - info: host.DESKTOP-GFRKJ98(SmartHome) instance system.adapter.web.0 started with pid 21448
    2019-08-18 07:21:22.060  - info: knx.0 starting. Version 0.8.6 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.knx, node: v10.16.0
    2019-08-18 07:21:22.073  - info: knx.0 Connecting to knx GW:  192.168.178.60:3671   with phy. Adr:  1.1.250 and SendDelay of : 50 ms
    2019-08-18 07:21:22.073  - info: knx.0 C:/Program Files/iobroker/SmartHome/node_modules/iobroker.js-controller
    2019-08-18 07:21:22.111  - info: knx.0  DPP erstellt für : 9/4/33    Schwellwert 2mit DPT1.001
    2019-08-18 07:21:22.111  - info: knx.0  DPP erstellt für : 9/4/32    Schwellwert 1mit DPT1.001
    2019-08-18 07:21:22.132  - info: knx.0 Connected!
    2019-08-18 07:21:22.258  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:22.258  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:22.259  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:22.259  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:22.432  - info: web.0 starting. Version 2.4.1 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.web, node: v10.16.0
    2019-08-18 07:21:22.557  - info: web.0 socket.io server listening on port 8082
    2019-08-18 07:21:22.558  - info: web.0 http server listening on port 8082
    2019-08-18 07:21:23.808  - info: knx.0  update of actGARefId : P-04A5-0_GA-222     of  knx.0.Wetter.Helligkeit.Schwellwert_2   with value  0
    2019-08-18 07:21:23.910  - info: knx.0  update of actGARefId : P-04A5-0_GA-221     of  knx.0.Wetter.Helligkeit.Schwellwert_1   with value  0
    2019-08-18 07:21:25.898  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:25.898  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:27.404  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:27.404  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:30.995  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:30.995  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:32.534  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:32.534  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:36.090  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:36.090  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:37.684  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:37.684  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:41.197  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:41.197  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:42.840  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:42.840  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:46.310  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:46.310  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:47.990  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:47.990  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:47.991  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:47.991  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:51.535  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:51.535  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:53.427  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:53.427  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:53.428  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:53.428  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:57.113  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:57.113  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:58.781  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:58.781  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:21:58.839  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:21:58.839  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:02.216  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:02.216  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:03.937  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:03.937  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:03.938  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:03.938  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:05.697  - warn: knx.0 Value received on unknown GA : 9/4/11
    2019-08-18 07:22:07.300  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:07.300  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:07.711  - warn: knx.0 Value received on unknown GA : 9/4/21
    2019-08-18 07:22:09.093  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:09.093  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:09.094  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:09.094  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:12.417  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:12.418  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:14.255  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:14.255  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:17.526  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:17.526  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:19.424  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:19.424  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:19.425  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:19.425  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:22.627  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:22.627  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:24.592  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:24.593  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:24.593  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:27.731  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:27.731  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:29.741  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:29.741  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:32.832  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:32.832  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:34.885  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:34.885  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:37.935  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:37.935  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:40.042  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:40.042  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:43.035  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:43.035  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:45.189  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:45.189  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:48.139  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:48.139  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:50.345  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:50.345  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:53.238  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:53.238  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:55.504  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:55.504  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:22:58.342  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:22:58.342  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:00.666  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:00.666  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:03.461  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:03.461  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:05.820  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:05.820  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:08.574  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:08.574  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:10.976  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:10.976  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:13.678  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:13.678  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:16.137  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:16.137  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:16.138  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:16.138  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:18.783  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:18.783  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:21.294  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:21.295  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:21.295  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:23.883  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:23.883  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:26.450  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:26.450  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:28.984  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:28.984  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:31.614  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:31.614  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:34.077  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:34.077  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:36.757  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:36.757  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:36.758  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:36.758  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:39.179  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:39.179  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:41.912  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:41.912  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:41.913  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:41.913  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:44.279  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:44.279  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:47.065  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:47.065  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:49.382  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:49.382  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:52.222  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:52.222  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:54.492  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:54.492  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:55.684  - warn: knx.0 Value received on unknown GA : 9/4/11
    2019-08-18 07:23:57.382  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:57.382  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:23:57.690  - warn: knx.0 Value received on unknown GA : 9/4/21
    2019-08-18 07:23:59.592  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:23:59.592  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:02.539  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:02.539  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:02.540  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:02.540  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:04.693  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:04.693  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:07.715  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:07.715  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:07.716  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:07.716  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:09.796  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:09.796  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:12.898  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:12.898  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:14.905  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:14.905  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:18.068  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:18.068  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:18.069  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:18.069  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:20.025  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:20.025  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:23.216  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:23.217  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:23.217  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:25.356  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:25.356  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:28.431  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:28.431  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:28.432  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:28.433  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:30.477  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:30.477  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:33.576  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:33.576  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:35.581  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:35.581  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:38.746  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:38.746  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:40.680  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:40.680  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:43.912  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:43.912  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:45.782  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:45.782  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:49.067  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:49.068  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:49.068  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:50.889  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:50.889  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:54.231  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:54.231  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:55.990  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:55.990  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:24:59.370  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:24:59.370  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:25:01.077  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:25:01.077  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:25:04.533  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:25:04.533  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:25:06.188  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:25:06.188  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:25:09.679  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:25:09.679  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:25:09.680  - warn: hue.0 could not connect to HUE bridge (192.168.178.38:80)
    2019-08-18 07:25:09.680  - error: hue.0 Api Error: method, GET, not available for resource, /
    2019-08-18 07:32:26.412  - error: hue.0 Api Error: method, GET, not available for resource, /
    SegwayS Offline
    SegwayS Offline
    Segway
    @daniel1to
    Der API Key zur HUE-Bridge stimmt nicht daher wirft er die Fehler raus. Deaktiviere mal den HUE Adapter damit das Log damit nicht zugemüllt wird und schaue dann nochmal ins Log und schicke es.
    Gruß Dirk
    • D daniel1to
      Hallo Zusammen,
      ich habe gestern iobroker installiert um mir eine eigene Visu für mein KNX System zu basteln. Nachdem ich daran gestern kläglich gescheitert bin wollte ich einen neuen Anlauf starten, was sich jedoch schwierig gestaltet, da ich iobroker nicht starten kann. Ich habe schon die Forensuche bemüht und einiges ausprobiert, leider jedoch ohne Erfolg.
      Die Instanz scheint meines Erachtens nach jedoch zu laufen:```
      C:\Program Files\iobroker\SmartHome>iobroker list i
        system.adapter.admin.0                 : admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.discovery.0             : discovery   -  enabled
      + system.adapter.hue.0                   : hue         -  enabled, port: 80
      + system.adapter.info.0                  : info        -  enabled
      + system.adapter.knx.0                   : knx         -  enabled
        system.adapter.vis.0                   : vis         -  enabled
      + system.adapter.web.0                   : web         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      Die log-file gibt mir im Sekundentakt den Fehler aus, das Sie meine HUE BRidge nicht finden konnte. Dies sollte jedoch nicht der Grund sein warum ich nicht in die Admin Oberfläche galange nehme ich an.
      Hat evtl jemand einen Rat?
      Vielen Dank vorab.
      StabilostickS Offline
      Stabilostick
      schrieb am zuletzt editiert von Stabilostick
      @daniel1to
      Am fehlenden + -Zeichen vor der admin.0-Adapterinstanz sieht man, dass diese zu dem Zeitpunkt des ersten Beitrags nicht lief. Schaue im Log nach entsprechenden Fehlern.
      ‚iobroker start admin.0’ sollte den Admin starten. Ggf. kannst Du auch mit ‚iobroker add admin 1‘ eine weitere Instanz mit neuem Port hinzufügen.
      • SegwayS Segway
        @daniel1to
        daniel1to
        @Segway
        Würde ich ja tun wenn ich in die Admin Oberfläche kommen würde. Oder verstehe ich dich falsch?
        • D daniel1to
          @Segway
          @daniel1to sagte in Verbindung zu iobroker fehlgeschlagen?:
          wahrscheinlich
          @Stabilostick sagte in Verbindung zu iobroker fehlgeschlagen?:
          iobroker start admin.0 sollte den Admin starten. Ggf. kannst Du auch mit iobroker add admin 1 eine weitere Instanz mit neuem Port hinzufügen.
          Das sind Konsolenbefehle
            wahrscheinlich
            daniel1to
            @Homoran
            OK, so bin ich schonmal wieder ins Admin Menü gelangt, vielen Dank dafür!
            Sollte/müsste/könnte ich die erste admin Instanz jetzt löschen oder wie ist zu erklären, das diese nicht funktioniert?
            • D daniel1to
              @Homoran
              Wie denn?
              Option 1 oder 2?
              Ja.
              Oder das Problem fixen (Konfiguration der Instanz??) und die neue Instanz löschen
              StabilostickS 1 Antwort Letzte Antwort
                Wie denn?
                Option 1 oder 2?
                Ja.
                Stabilostick
                @Homoran et al:
                Vielleicht hat er doppelte Ports. Log ansehen, wenn er im zweiten Admin.1 ist und versucht, den ersten admin.0 zu starten.
                  daniel1to
                  schrieb am zuletzt editiert von daniel1to
                  OK, ich hab jetzt admin.0 gelöscht. Der funktioniert irgendwie nicht. Oder ist es sinnvoll bei .0 zu bleiben?
                  Ich habe mal versucht iobroker zu stoppen...dann erhalte ich folgendes:
                  C:\Program Files\iobroker\SmartHome>iobroker stop
                  2019-08-18 18:08:05,828 INFO  - Stopping the service with id 'iobroker(SmartHome)'
                  2019-08-18 18:08:05,838 FATAL - WMI Operation failure: ServiceCannotAcceptControl
                  WMI.WmiException: ServiceCannotAcceptControl
                     bei WMI.WmiRoot.BaseHandler.CheckError(ManagementBaseObject result)
                     bei WMI.WmiRoot.InstanceHandler.Invoke(Object proxy, MethodInfo method, Object[] args)
                     bei winsw.WrapperService.Run(String[] _args, ServiceDescriptor descriptor)
                     bei winsw.WrapperService.Main(String[] args)
                  StabilostickS 2 Antworten Letzte Antwort
                  • apollon77A Offline
                    Generell sieht das Log alles andere als gesund aus. Die ganzen "Reconnect to DB" sind kritisch! Irgendetwas blockiert da für 20+ Sekunden den Adapterprozess.
                    Bei knx stimmt auch was nicht und so weiter.
                    Was für ein System? RAM? Wieviel frei? (Ausgabe top bzw "free -m")? Wieviele Adapter-Instanzen laufen?
                    Falls das WMI zeig von den info-Systemdaten Checks Probleme macht: ausschalten!
                    Da würde ich mal anfangen:
                    • Alles ausser Admin abschalten
                    • Dann einen Adapter nach dem anderen langsam der Wichtigkeit nach wieder einschalten
                    • Log beobachten, nicht funktionierende Adapter gleich aus lassen und Ursache (Konfig?) fixen
                    Sobald wieder "Reconnect to DB" oder sowas kommt stoppen und Ursachen analysieren
                    • apollon77A apollon77
                      daniel1to
                      @apollon77
                      Also ich muss ehrlich gestehen ich verstehe nur einen Bruchteil von alledem. Ich habe gestern nichts gemacht außer iobroker zu installieren und die adapter runterzuladen. Ich habe eigentlich noch gar nicht mehr getan, wollte heute morgen eigentlich damit so langsam anfangen zu üben.
                      Mein PC hat 16GB Ram, daran sollte es wohl nicht scheitern.
                      was bedeutet free -m?
                      Ich lösche mal die adapter und schaue was dann so passiert. Evtl hilft das ja schonmal weiter.
                      Vielen Dank schonmal!
                      Edit: Also ich habe nun alles runter außer die Standardsachen.
                      admin.0
                      admin.1
                      discovery.0
                      info.0
                      web.0
                      Trotzdem geht es immer nur mit admin.1. Sobald ich den lösche und nur noch admin.0 übrig ist geht es nicht mehr. Vor der Instanz admin.0 befindet sich zudem ein roter Punkt der sagt das keine Verbindung zum Host besteht.
                      StabilostickS apollon77A 2 Antworten Letzte Antwort
                      • D daniel1to
                        @apollon77
                        admin.0
                        admin.1
                        discovery.0
                        info.0
                        web.0
                        Stabilostick
                        @daniel1to
                        Du hast eine Nachricht von mir. Interesse?
                          daniel1to
                          Soe sieht das ganze aus
                          • D daniel1to
                            @apollon77
                            admin.0
                            admin.1
                            discovery.0
                            info.0
                            web.0
                            @daniel1to Naja beendend wäre ok gewesen, löschen eher unnötig :-)
                            Was sagt denn "iobroker list instances" in der ioBroker-Shell?
                            Bzw hier wäre jetzt das Log interessant wenn du admin.0 mal stoppst und startest
                              @apollon77
                              ... und was steht im log unmittelbar nachdem du die Instanz .0 neu startest
                              • D daniel1to
                                Stabilostick
                                Wenn so was kommt, dann stehen im Ordner ‚daemon‘ im ioBroker Verzeichnis weitere Logdateien bzgl. Windows-Dienste und ioBroker zur Verfügung. Auf jeden Fall passt da was überhaupt nicht.
                                Schon mal in den Chat oben rechts im Forum geschaut?
                                  daniel1to
                                  List Instances:
                                  C:\Program Files\iobroker\SmartHome>iobroker list instances
                                  + system.adapter.admin.1                 : admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  + instance is alive
                                  Neu Laden:
                                  host.DESKTOP-GFRKJ98(SmartHome)	2019-08-18 18:29:08.468	info	Do not restart adapter system.adapter.admin.0 because desired by instance
                                  host.DESKTOP-GFRKJ98(SmartHome)	2019-08-18 18:29:08.468	error	instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                                  admin.0	2019-08-18 18:29:08.429	error	port 8081 already in use
                                  host.DESKTOP-GFRKJ98(SmartHome)	2019-08-18 18:29:08.230	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                                  admin.0	2019-08-18 18:29:08.214	info	received all objects
                                  admin.0	2019-08-18 18:29:08.076	info	received all states
                                  admin.0	2019-08-18 18:29:08.015	info	Request actual repository...
                                  admin.0	2019-08-18 18:29:08.015	info	requesting all objects
                                  admin.0	2019-08-18 18:29:08.015	info	requesting all states
                                  admin.0	2019-08-18 18:29:08.005	info	starting. Version 3.6.2 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.admin, node: v10.16.0
                                  host.DESKTOP-GFRKJ98(SmartHome)	2019-08-18 18:29:07.435	info	instance system.adapter.admin.0 started with pid 63700
                                  @Stabolostick: habe leider das Programm nicht.
                                  • D daniel1to
                                    List Instances:
                                    + instance is alive
                                    Neu Laden:
                                    + system.adapter.admin.1                 > + admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    2x Port 8081 geht nicht
                                      daniel1to
                                      @Homoran
                                      vorher war aber nur der admin.0 da und der alleine ging ja auch nicht. und der .1 geht trotz alledem.
                                      • D daniel1to
                                        @Homoran
                                        @Homoran
                                        Dann setze eben mal .0 auf 8089 oder welchen Port du noch frei hast
                                        • StabilostickS Offline
                                          Stabilostick
                                          Der Installer prüft beim Setup, ob die gewählten Ports frei sind. Doppelt belegte Ports müssen später passiert sein.
