  4. [Aufruf] Test Shelly Adapter
    apollon77A
shellyadapter
717 Beiträge 81 Kommentatoren 303.1k Aufrufe 30 Beobachtet
  • DiginixD
    DiginixD
    Diginix
    #607
    Ich habe täglich wenn die Rollläden hoch/runter fahren folgenden Fehler im Log:
    2019-07-28 21:23:59.719  - info: shelly.0 Error handling Shelly data: SyntaxError: Unexpected token P in JSON at position 420 for JSON {"blk":[{"I":0,"D":"Relay0"},{"I":1,"D":"Relay1"},{"I":2,"D":"Device"}],"sen":[{"I":112,"T":"S","D":"State","R":"0/1","L":0},{"I":122,"T":"S","D":"State","R":"0/1","L":1},{"I":111,"T":"W","D":"Power","R":"0/3680","L":2},{"I":113,"T":"S","D":"Position","R":"0/100","L":2}],"act":[{"I":211,"D":"Switch","L":0,"P":[{"I":2011,"D":"ToState","R":"0/1"}]},{"I":221,"D":"Switch","L":1,"P":[{"I":2021,"D":"ToState","R":"0/1"}]}]}P
    2019-07-29 21:23:01.705  - info: shelly.0 Error handling Shelly data: SyntaxError: Unexpected token ` in JSON at position 420 for JSON {"blk":[{"I":0,"D":"Relay0"},{"I":1,"D":"Relay1"},{"I":2,"D":"Device"}],"sen":[{"I":112,"T":"S","D":"State","R":"0/1","L":0},{"I":122,"T":"S","D":"State","R":"0/1","L":1},{"I":111,"T":"W","D":"Power","R":"0/3680","L":2},{"I":113,"T":"S","D":"Position","R":"0/100","L":2}],"act":[{"I":211,"D":"Switch","L":0,"P":[{"I":2011,"D":"ToState","R":"0/1"}]},{"I":221,"D":"Switch","L":1,"P":[{"I":2021,"D":"ToState","R":"0/1"}]}]}`E
    An sich funktioniert alles. Ist mir eben nur durch Zufall aufgefallen.
    ..:: So long! Tom ::..
    StuebiS N 2 Antworten Letzte Antwort
    • DiginixD Diginix
      StuebiS
      StuebiS
      Stuebi
      #608
      @Diginix , danke für den Hinweis. Wenn alles funktioniert, werde ich die Meldung nur noch im Debug Modus anzeigen lassen.
      ioBroker auf Synology DS216+II im Docker Container
      • DiginixD Diginix
        N
        N
        NemoN
        #609
        @Diginix hinter dem JSON kommen noch "Müllbytes". Es wäre evtl. sauberer alles nach dem letzten } abzuschneiden und dann das JSON zu parsen!?
        StuebiS 1 Antwort Letzte Antwort
        • N NemoN
          StuebiS
          StuebiS
          Stuebi
          #610
          @NemoN , das ist leider ein Fehler von Shelly. Die senden teilweise kaputte JSONs. Ich werde ab Version 3.0.8 diese Fehlerhaften JSONs nur noch im Debug Modus anzeigen. Eine Korrektur des Shelly JSONs in ioBroker werde ich nicht vornehmen, da diese vom Adapter nicht benötigt werden. Diese beschreiben den Aufbau der CoAP Daten-Nachrichten.
          • StuebiS Stuebi
            @srkonus , kannst du einmal schauen ob Power Werte in ioBroker für den Shelly Plug S noch angepasst werden, sobald Dein Blocky nicht mehr geht.
            Leider werden die Daten zu Power per CoAP vom Shelly nicht mitgeliefert. Daher hole ich mir die Power Werte alle paar Sekunden per http Abfrage vom Shelly. Dieser Prozess läuft in einer Endlosschleife. Vielleicht wird die Schleife irgendwann nicht mehr durchlaufen. Das muss ich mir einmal genauer anschauen und testen
            S
            S
            srkonus
            #611
            @Stuebi Hi Stübi,
            gerade hatte ich den Fall, das mein Script nicht ging. Flott nachgeschaut und bemerkt, das der Power-Wert nicht gefüllt war. Somit ist klar warum das Script nicht geht.
            Hilft MQTT dabei die Power-Werte zu übermitteln? Im Einsatz habe ich die neueste Version des Adapters
            • S srkonus
              @Stuebi Hi Stübi,
              StuebiS
              StuebiS
              Stuebi
              #612
              @srkonus , kannst Du mir sagen welches Shelly Gerät du im Einsatz hast? Eigentlich sollte es mit dem Shelly 2, Shelly 2.5, Shelly PM und Shelly Plug S gehen.
              • StuebiS Stuebi
                S
                S
                srkonus
                #613
                @Stuebi Ich nutze den Shelly Plug S mit neuester Firmware und neuestem Shelly Adapter
                • S srkonus
                  StuebiS
                  StuebiS
                  Stuebi
                  #614
                  @srkonus , welche ioBroker Shelly Adapter Version hast du im Einsarz?
                  • StuebiS Stuebi
                    S
                    S
                    srkonus
                    #615
                    @Stuebi Die neueste Version, 3.0.8
                    Einen Tag später funktionierte es wieder. Der Adapter wird täglich früh morgens neugestartet.
                    • S srkonus
                      StuebiS
                      StuebiS
                      Stuebi
                      #616
                      @srkonus , noch ein paar Fragen hätte ich:
                      1. warum wird der Adapter neu gestartet? Stürzt dieser ab?
                      2. Schaust Du einmal im Logfile nach, ob der Shelly Adapter irgendwann einen Fehler ausgibt?
                      3. Weisst Du ob der Shelly Plug S ab und an eine neue IP Adresse erhält?
                      Ich habe auch den Shelly Plug S und bei mir werden die Power Werte immer angezeigt.
                      S 3 Antworten Letzte Antwort
                      • StuebiS Stuebi
                        S
                        S
                        srkonus
                        #617
                        @Stuebi vielen Dank für die schnelle Antwort. Hier mein Versuch alles zu beantworten:
                        1: warum wird der Adapter neu gestartet? Stürzt dieser ab?
                        Der Adapter stürzt nicht ab. Nachdem ich das ganze eingerichtet hatte (meine mit Adapter 3.0.3 oder so) habe ich bemerkt das mein Script (Lastabhängiges schalten eines zweiten Plug S) wieder läuft wenn der Adapter neugestartet wurde. Da kam ich auf die Idee einen täglichen Neustart einzubauen
                        2: Schaust Du einmal im Logfile nach, ob der Shelly Adapter irgendwann einen Fehler ausgibt?
                        Muss ich nachschauen
                        3: Weisst Du ob der Shelly Plug S ab und an eine neue IP Adresse erhält?
                        Die IP wird als Reservierung vergeben, der Adapter hat immer die gleiche Adresse
                        • StuebiS Stuebi
                          S
                          S
                          srkonus
                          #618
                          Hier 2 Screenshots meiner PlugS. Es hat gerade nicht funktioniert und über beide PlugS fließt gerade Strom. Die angezeigten 70W von Adapter PlugS-2 hätte den anderen einschalten sollen. Gestern Abend ging das an- sowie das ausschalten. Allerdings habe ich gestern später am Abend einen Adapter (PlugS-1) über die Shelly App einmal ein- und ausgeschaltet.
                          Im Logfile ist zum Zeitpunkt der "Fehlfunktion" kein Eintrag vom Shelly Adapter.
                          • StuebiS Stuebi
                            S
                            S
                            srkonus
                            #619
                            @Stuebi Das ausschalten hat gerade auch nicht funktioniert, als ob das schalten über die Shelly App das System durcheinander gebracht hat
                            • StuebiS
                              StuebiS
                              Stuebi
                              #620
                              Wie schaltest du denn die Shellys über ioBroker? Es gibt dazu ein Issue, da hat jemand in den Datenpunkt Switch 1 oder 0 statt true/false (boolean) über VIS reingeschrieben (ohne das er es wusste). Damit hat er den Datenpunkt Switch komplett lahmgelegt.
                              Kann es daran liegen?
                              • StuebiS Stuebi
                                S
                                S
                                srkonus
                                schrieb am zuletzt editiert von srkonus
                                #621
                                @Stuebi Das ist mein Script in Java, erstellt habe ich es aber mit Blockly. Da ich auf der Arbeit bin und keinen Zugang nach Hause habe, kopiere ich das Script hier noch einmal rein. Hatte es irgendwann schon einmal hier gepostet:
                                on({id: "shelly.0.SHPLG-S#7AE7B6#1.Relay0.Power"/*Power*/, change: "ne", ack: true}, function (obj) {
                                  var value = obj.state.val;
                                  if (getState("shelly.0.SHPLG-S#7AE7B6#1.Relay0.Power").val > 20) {
                                    setState("shelly.0.SHPLG-S#7ADFCD#1.Relay0.Switch"/*Switch*/, true);
                                  if (getState("shelly.0.SHPLG-S#7AE7B6#1.Relay0.Power").val < 50) {
                                    setState("shelly.0.SHPLG-S#7ADFCD#1.Relay0.Switch"/*Switch*/, false);
                                Ich möchte nicht ausschließen, das im Blockly 1/0 verwendet wird, aber das würde man in Java dann auch so sehen.
                                • S srkonus
                                  StuebiS
                                  StuebiS
                                  Stuebi
                                  #622
                                  @srkonus , noch eine Frage, kannst Du denn wenn Du in ioBroker auf dem Reiter Objekte stehst, den Datenpunkt shelly.0.SHPLG-S#7ADFCD#1.Relay0.Switch schalten. Also nicht über Dein Blocky Skript?
                                  • StuebiS Stuebi
                                    S
                                    S
                                    srkonus
                                    #623
                                    @Stuebi Kann ich dir im Moment nicht sagen. Wüsste auch nicht, wie das geht
                                    • S srkonus
                                      StuebiS
                                      StuebiS
                                      Stuebi
                                      #624
                                      @srkonus , dafür gehst Du in ioBroker (Admin) auf den Reiter Objekte und suchst den Datenpunkt shelly.0.SHPLG-S#7ADFCD#1.Relay0.Switch . in der Spalte "Wert" kannst Du den Wert mit der Maus auf false/true setzen.
                                      Versuche dieses einmal wenn Dein Blocky Skript bzw. der Shelly nicht mehr tut was es soll. Wenn Du den Wert im Datenpunkt änderst schaue in der Shelly Web App ob sich dort der Wert ändert (d.h. Schalter an/aus). Du kannst auch sicherheitshalber umgekehrt nachschauen. D.h. in der Shelly App den Wert ändern und dann den Inhalt im Datenpunkt shelly.0.SHPLG-S#7ADFCD#1.Relay0.Switch anschauen.
                                      Sollten die Werte in dem Datenpunkt und Shelly Web App nicht identisch sein, deaktiviere einmal Dein Blocky Script (bitte nicht Shelly Adapter neu starten!) und ändere dann nochmals die Werte im Datenpunkt und in der Shelly App. Sind dann die Werte in der Shelly Web App und des Datenpunktes identisch?
                                      S 2 Antworten Letzte Antwort
                                      • StuebiS Stuebi
                                        S
                                        S
                                        srkonus
                                        #625
                                        @Stuebi Vielen Dank für deine Antwort. Gerade hat das Script nicht gegriffen. Der Status des Value Switch ist auf true.
                                        Habe das Script jetzt neugestartet, Mal schauen wie nachher beim ausschalten das Verhalten ist
                                        • StuebiS Stuebi
                                          S
                                          S
                                          srkonus
                                          #626
                                          @Stuebi das ausschalten hat auch nicht geklappt
                                          84.0k
