  4. [Diskussion] js-controller 1.5.14 in latest
js-controller
89 Beiträge 19 Kommentatoren 7.9k Aufrufe 20 Beobachtet
  • B Brati
    @apollon77
    Hab nix kopiert :). Ok, also lösche ich den mal und lasse das js-controller Update neu laufen...
    Brati
    apollon77A Online
    apollon77A Online
    #66
    @Brati ALles gut, können auch npm altlasten sein oder so
    • apollon77A apollon77
      Brati
      #67
      @apollon77
      Die "rimraf" musste ich auch noch löschen und jetzt ist der js-controller auf v. 1.5.14. Alle Adapter auf "grün". Die folgenden Meldungen ignoriere ich mal:
      Update js-controller from @1.5.12 to @1.5.14
      NPM version: 6.4.1
      npm install iobroker.js-controller@1.5.14 --unsafe-perm --production --save --prefix "/opt/iobroker" (S                         ystem call)
      ../src/diskusage_posix.cpp: In function ‘DiskUsage GetDiskUsage(const char*)’:
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_bsize’ [-Wmissing                         -field-initializers]
           struct statvfs info = {};
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_frsize’ [-Wmissin                         g-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_blocks’ [-Wmissin                         g-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_bfree’ [-Wmissing                         -field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_bavail’ [-Wmissin                         g-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_files’ [-Wmissing                         -field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_ffree’ [-Wmissing                         -field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_favail’ [-Wmissin                         g-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_fsid’ [-Wmissing-                         field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_flag’ [-Wmissing-                         field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_namemax’ [-Wmissi                         ng-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::__f_spare’ [-Wmissi                         ng-field-initializers]
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperat                         ure-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wa                         nted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"o                         s":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      Host "ioBroker" (linux) updated
      Execute: chmod -R 777 /opt/iobroker
      Chmod finished. Restart controller
      Starting node restart.js
      oder müßte ich hier auch noch reagieren?
      Brati
      • B Brati
        @apollon77
        NPM version: 6.4.1
        Brati
        apollon77A Online
        apollon77A Online
        #68
        @Brati Ich tippe auf nodejs 8? Dann ost das ok .. mit nodejs 10 kommen keine Meldungen mehr
          Brati
          #69
          @apollon77 sagte in [Diskussion] js-controller 1.5.14 in latest:
          Jepp, "v8.16.0". Na dann werde ich das auch mal updaten.
          Vielen Dank.
          Grüße Brati
          • B Brati
            Vielen Dank.
            Grüße Brati
            apollon77A Online
            apollon77A Online
            #70
            @Brati Stop! DFas hab ich nicht gesagt. Es tiut auch so alles, sind nur Warnungen. Formal hast Du zeit bis April 2020!! Erst dann geht die nodejs 8 EOL.
              Brati
              #71
              @apollon77
              Noch nix passiert :) lege es auf Wiedervorlage...
              • SRo769S Offline
                SRo769S Offline
                SRo769
                #72
                habe 3 iobroker auf js-controller 1.5.14 aktualisiert - keine Probleme während u. nach dem Update. Alle Installationen laufen mit Node 10.16.0 und NPM 6.9.0. Soweit so gut. Hab im Anschluss mal versucht, ein Backup-File (vom akt. Stand) auf einem neu installierten Testsystem unter gleichen Bedingungen (Node 10.16.0/NPM 6.9.0 und js-controller 1.5.14) zu restoren.
                Das funktioniert leider überhaupt nicht. Folgen Fehlermeldungen erscheinen:
                Hab das mit allen 3 Installationen bzw. Backups probiert - immer das gleiche Resultat. Das neuinstallierte Testsystem wurde mit Debian Stretch als auch Buster aufgesetzt. Auch das macht keinen Unterschied. 😧
                Die Backups (minimal) wurden mit dem Adapter Backitup erstellt und haben in der Vergangenheit funktioniert.
                Ist dieses Problem bekannt bzw. auch bei anderen schon aufgetreten? Wäre super, wenn es da eine Lösung gebe - so richtig wohl ist mir nicht bei dem Gedanken, kein Backup restoren zu können.
                Grüße Sven
                E 1 Antwort Letzte Antwort
                • SRo769S SRo769
                  Grüße Sven
                  Einstein67
                  #73
                  @SRo769
                  "restore 0" funktioniert schon länger nicht mehr. Zumindest bei mir.
                  Aber egal, mit Angabe des Dateinamens statt der 0 läuft Restore perfekt.
                  • SRo769S Offline
                    SRo769S Offline
                    SRo769
                    #74
                    @Einstein67
                    danke, das war der richtige Hinweis. Jetzt klappt es mit dem Einspielen des Backups. Das die Ziffern nicht mehr funktionieren war mir gar nicht bekannt. Hatte das gestern mit einem File an 2. Stelle (1) probiert - ging auch nicht.
                    Hat aber somit nichts mit dem Update des js-controllers zu tun. Puh, Erleichterung.
                    • H Offline
                      hesse
                      #75
                      Hat jemand schon den sonos adapter mit dem js-controller 1.5.14 getestet?
                      Auf meinem Testsystem mit 1.5.12 funktioniert alles einwandfrei, auf der Neuinstallation mit dem neuen install script und js-controller 1.5.14 werden die Werte nicht mehr aktualisiert und der Adapter schmiert ab...
                      • H hesse
                        apollon77A Online
                        apollon77A Online
                        #76
                        @hesse Logs?
                        • H Offline
                          hesse
                          schrieb am zuletzt editiert von hesse
                          #77
                          @apollon77
                          2019-07-30 19:05:52.116 - info: sonos.0 terminating
                          2019-07-30 19:05:52.124 - error: sonos.0 Got error: Parse Error
                          2019-07-30 19:05:52.167 - error: Caught by controller[1]: TypeError [ERR_INVALID_CALLBACK]: Callback must be a function
                          2019-07-30 19:05:52.167 - error: Caught by controller[1]: at maybeCallback (fs.js:128:9)
                          2019-07-30 19:05:52.168 - error: Caught by controller[1]: at Object.exists (fs.js:196:3)
                          2019-07-30 19:05:52.168 - error: Caught by controller[1]: at ClientRequest.http.get.res2 (/opt/iobroker/node_modules/iobroker.sonos/main.js:1783:37)
                          2019-07-30 19:05:52.168 - error: Caught by controller[1]: at Object.onceWrapper (events.js:286:20)
                          2019-07-30 19:05:52.168 - error: Caught by controller[1]: at ClientRequest.emit (events.js:198:13)
                          2019-07-30 19:05:52.169 - error: Caught by controller[1]: at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:556:21)
                          2019-07-30 19:05:52.169 - error: Caught by controller[1]: at HTTPParser.parserOnHeadersComplete (_http_common.js:109:17)
                          2019-07-30 19:05:52.169 - error: Caught by controller[1]: at Socket.socketOnData (_http_client.js:442:20)
                          2019-07-30 19:05:52.170 - error: Caught by controller[1]: at Socket.emit (events.js:198:13)
                          2019-07-30 19:05:52.170 - error: Caught by controller[1]: at addChunk (_stream_readable.js:288:12)
                          2019-07-30 19:05:52.170 - error: Caught by controller[1]: at readableAddChunk (_stream_readable.js:269:11)
                          2019-07-30 19:05:52.170 - error: Caught by controller[1]: at Socket.Readable.push (_stream_readable.js:224:10)
                          2019-07-30 19:05:52.171 - error: Caught by controller[1]: at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
                          2019-07-30 19:05:52.171 - error: host.iobroker instance system.adapter.sonos.0 terminated with code 0 (OK)
                          2019-07-30 19:05:52.171 - info: host.iobroker Restart adapter system.adapter.sonos.0 because enabled
                          2019-07-30 19:06:22.198 - info: host.iobroker instance system.adapter.sonos.0 started with pid 21570
                          2019-07-30 19:06:24.125 - info: sonos.0 starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v10.16.0
                          2019-07-30 19:06:24.241 - info: sonos.0 http sonos server listening on port 8080
                          Ich hab jetzt mehrfach rumgedocktert und auch 4 mal eine komplett neue Installation von raspbian (buster und stretch) und iobroker gemacht, aber das Ergebnis ist immer das gleiche ... Ich weiss nun nicht mehr was ich noch testen kann..
                          Ich hatte auch einen thread aufgemacht mit den LOGs:
                          https://forum.iobroker.net/topic/24124/sonos-adapter-fehler
                          • H hesse
                            @apollon77
                            apollon77A Online
                            apollon77A Online
                            #78
                            @hesse Report diesen Bug mit der Fehlermeldung mal im sonos Adapter auf GitHub
                            • H Offline
                              hesse
                              #79
                              @apollon77 Danke, guter Hinweis, werde ich gleich tun.
                              Gibt es die Möglichkeit ein Downgrade zu machen, um das ganze nochmal gegen zu prüfen, ob es wirklich an der js-controller version liegt? Wenn ja, wie mache ich das am besten?
                              Vielen Dank für eure Hilfe.
                              • H hesse
                                apollon77A Online
                                apollon77A Online
                                #80
                                @hesse die Fehlermeldung kommt vom Adapter. Da hat der js-Controller nichts mit zu tun. Und falls doch ist dennoch der Adapter fehlerhaft.
                                • H Offline
                                  hesse
                                  #81
                                  @apollon77 Aber warum geht es dann in der "alten" Version Einwandfrei?
                                  Dann muss ich wohl auf einen fix warten, denn so ist das erstmal unbrauchbar für mich und die Testinstalltion kann ich nicht produktiv einsetzen, da ich zuviel verbogen habe :(
                                  • apollon77A Online
                                    apollon77A Online
                                    #82
                                    Der Fehler hat nichts mit js-controller zu tun ... hast Du ggf noch ein nodej update gemacht?
                                    Versuch mal die version vom GitHub (Version bleibt gleich, aber da war exakt eine zeile die falsch war und seit nodejs 10 wohl Probleme macht
                                    • 0 Offline
                                      0 Offline
                                      0018
                                      #83
                                      habe gerade versucht das Update zu machen und erhalte folgende Meldung:
                                      nuc@BrokerNUC:~$ cd /opt/iobroker
                                      nuc@BrokerNUC:/opt/iobroker$ iobroker stop
                                      nuc@BrokerNUC:/opt/iobroker$ iobroker update
                                      [sudo] Passwort für nuc:
                                      Used repository: latest
                                      hash not changed, use actual sources
                                      update done
                                      nuc@BrokerNUC:/opt/iobroker$ iobroker upgrade self
                                      Cannot find this controller "js-controller" in repository.
                                      nuc@BrokerNUC:/opt/iobroker$ node -v
                                      v10.16.0
                                      nuc@BrokerNUC:/opt/iobroker$ nodejs -v
                                      v10.16.0
                                      nuc@BrokerNUC:/opt/iobroker$ npm -v
                                      6.9.0
                                      Irgendwie werde die Adapter beim Update nicht gefunden. Woran kann das liegen?
                                      Mfg
                                      0018
                                      • apollon77A Online
                                        apollon77A Online
                                        #84
                                        Bitte in 15 Minuten nochmal neu versuchen, dann sollte das gefixt sein
                                        • H Offline
                                          hesse
                                          #85
                                          @apollon77
                                          Es war eine Nagelneue Installation auf aktuellen Raspian und neuer Installation von Nodejs, npm usw und IObroker wie auf der Seite beschrieben.
                                          Dank für die Änderung im Git. Nun hat sich Fehlermeldung verändert:
                                          2019-08-01 20:46:31.869 - info: sonos.0 terminating
                                          2019-08-01 20:46:31.966 - error: Caught by controller[0]: (node:8791) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'startsWith' of undefined
                                          2019-08-01 20:46:31.971 - error: Caught by controller[0]: at isRadio (/opt/iobroker/node_modules/iobroker.sonos/node_modules/sonos-discovery/lib/prototypes/Player/getUriType.js:4:14)
                                          2019-08-01 20:46:31.972 - error: Caught by controller[0]: at Player.getUriType (/opt/iobroker/node_modules/iobroker.sonos/node_modules/sonos-discovery/lib/prototypes/Player/getUriType.js:18:10)
                                          2019-08-01 20:46:31.972 - error: Caught by controller[0]: at parseTrackMetadata.then.track (/opt/iobroker/node_modules/iobroker.sonos/node_modules/sonos-discovery/lib/models/Player.js:243:43)
                                          2019-08-01 20:46:31.972 - error: Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
                                          2019-08-01 20:46:31.972 - error: Caught by controller[1]: (node:8791) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
                                          2019-08-01 20:46:31.972 - error: Caught by controller[1]: (node:8791) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                                          2019-08-01 20:46:31.972 - error: Caught by controller[2]: (node:8791) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'startsWith' of undefined
                                          2019-08-01 20:46:31.973 - error: Caught by controller[2]: at isRadio (/opt/iobroker/node_modules/iobroker.sonos/node_modules/sonos-discovery/lib/prototypes/Player/getUriType.js:4:14)
                                          2019-08-01 20:46:31.973 - error: Caught by controller[2]: at Player.getUriType (/opt/iobroker/node_modules/iobroker.sonos/node_modules/sonos-discovery/lib/prototypes/Player/getUriType.js:18:10)
                                          2019-08-01 20:46:31.973 - error: Caught by controller[2]: at parseTrackMetadata.then.track (/opt/iobroker/node_modules/iobroker.sonos/node_modules/sonos-discovery/lib/models/Player.js:243:43)
                                          2019-08-01 20:46:31.973 - error: Caught by controller[2]: at process._tickCallback (internal/process/next_tick.js:68:7)
                                          2019-08-01 20:46:31.973 - error: Caught by controller[3]: (node:8791) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
                                          und ich habe festgestellt, das ein Paar Datenpunkte aktualisert werden (z.B. Lautstärke) aber die überwigende Anzahl leider nicht
