  4. Sonos Adapter Fehler
sonos
1 Beiträge 1 Kommentatoren 356 Aufrufe
  • H Offline
    hesse
    auf meiner neuen Iobroker Installtion (raspbian buster light) geht der Sonos Adpater nicht.
    Er startet ständig neu und bringt folgenden Meldungen im LOG:
    2019-07-28 16:26:39.932 - info: sonos.0 terminating
    2019-07-28 16:26:39.938 - error: sonos.0 Got error: Parse Error
    2019-07-28 16:26:39.951 - info: sonos.0 terminating
    2019-07-28 16:26:39.974 - error: Caught by controller[0]: (node:8468) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'startsWith' of undefined
    2019-07-28 16:26:39.975 - error: Caught by controller[0]: at isRadio (/opt/iobroker/node_modules/iobroker.sonos/node_modules/sonos-discovery/lib/prototypes/Player/getUriType.js:4:14)
    2019-07-28 16:26:39.975 - error: Caught by controller[0]: at Player.getUriType (/opt/iobroker/node_modules/iobroker.sonos/node_modules/sonos-discovery/lib/prototypes/Player/getUriType.js:18:10)
    2019-07-28 16:26:39.975 - error: Caught by controller[0]: at parseTrackMetadata.then.track (/opt/iobroker/node_modules/iobroker.sonos/node_modules/sonos-discovery/lib/models/Player.js:243:43)
    2019-07-28 16:26:39.975 - error: Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
    2019-07-28 16:26:39.975 - error: Caught by controller[1]: (node:8468) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
    2019-07-28 16:26:39.976 - error: Caught by controller[2]: (node:8468) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
    2019-07-28 16:26:39.976 - error: Caught by controller[3]: TypeError [ERR_INVALID_CALLBACK]: Callback must be a function
    2019-07-28 16:26:39.976 - error: Caught by controller[3]: at maybeCallback (fs.js:128:9)
    2019-07-28 16:26:39.976 - error: Caught by controller[3]: at Object.exists (fs.js:196:3)
    2019-07-28 16:26:39.976 - error: Caught by controller[3]: at ClientRequest.http.get.res2 (/opt/iobroker/node_modules/iobroker.sonos/main.js:1767:37)
    2019-07-28 16:26:39.976 - error: Caught by controller[3]: at Object.onceWrapper (events.js:286:20)
    2019-07-28 16:26:39.976 - error: Caught by controller[3]: at ClientRequest.emit (events.js:198:13)
    2019-07-28 16:26:39.976 - error: Caught by controller[3]: at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:556:21)
    2019-07-28 16:26:39.976 - error: Caught by controller[3]: at HTTPParser.parserOnHeadersComplete (_http_common.js:109:17)
    2019-07-28 16:26:39.977 - error: Caught by controller[3]: at Socket.socketOnData (_http_client.js:442:20)
    2019-07-28 16:26:39.977 - error: Caught by controller[3]: at Socket.emit (events.js:198:13)
    2019-07-28 16:26:39.977 - error: Caught by controller[3]: at addChunk (_stream_readable.js:288:12)
    2019-07-28 16:26:39.977 - error: Caught by controller[3]: at readableAddChunk (_stream_readable.js:269:11)
    2019-07-28 16:26:39.977 - error: Caught by controller[3]: at Socket.Readable.push (_stream_readable.js:224:10)
    2019-07-28 16:26:39.977 - error: Caught by controller[3]: at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
    2019-07-28 16:26:39.977 - error: host.iobroker instance system.adapter.sonos.0 terminated with code 0 (OK)
    2019-07-28 16:26:39.978 - info: host.iobroker Restart adapter system.adapter.sonos.0 because enabled
    hat evtl. jemand eine Idee woran das liegen könnte?
    Vielen Dank schonmal
