7.6k Beiträge 296 Kommentatoren 8.1m Aufrufe 201 Beobachtet
  • K
    K
    kilasat
    #914
    mit *.state habe ich es schon probiert. Hmm...
    • K kilasat
      dslraserD
      dslraserD
      dslraser
      #915
      @kilasat
      bei Dir ist Fenster = fenster, oder ? (klein geschrieben--hinten)
      bei mir groß
      • dslraserD dslraser
        @kilasat
        bei mir groß
        K
        K
        kilasat
        #916
        @dslraser es war klein. Habs nun auf Gross geändert. Ohne erfolgt.
        • K kilasat
          dslraserD
          dslraserD
          dslraser
          #917
          @kilasat
          zeig mal ein RAW von einem Fenster
          hier HMIP
            "type": "state",
            "common": {
              "def": "CLOSED",
              "type": "number",
              "read": true,
              "write": false,
              "min": "CLOSED",
              "max": "OPEN",
              "states": {
                "0": "CLOSED",
                "1": "OPEN"
              "unit": "\"\"",
              "role": "value.window",
              "name": "Wohnzimmerfenster links.STATE"
            "native": {
              "MIN": "CLOSED",
              "UNIT": "\"\"",
              "OPERATIONS": 5,
              "MAX": "OPEN",
              "FLAGS": 1,
              "ID": "STATE",
              "TAB_ORDER": 0,
              "TYPE": "ENUM",
              "DEFAULT": "CLOSED",
              "VALUE_LIST": [
                "CLOSED",
                "OPEN"
              "CONTROL": "DOOR_SENSOR.STATE"
            "from": "system.adapter.hm-rega.0",
            "user": "system.user.admin",
            "ts": 1559315348552,
            "_id": "hm-rpc.0.xxx.1.STATE",
            "acl": {
              "object": 1636,
              "state": 1636,
              "owner": "system.user.admin",
            @kilasat
            hier HMIP
              "type": "state",
              "common": {
                "def": "CLOSED",
                "type": "number",
                "read": true,
                "write": false,
                "min": "CLOSED",
                "max": "OPEN",
                "states": {
                  "0": "CLOSED",
                  "1": "OPEN"
                "unit": "\"\"",
              "native": {
                "MIN": "CLOSED",
                "UNIT": "\"\"",
                "OPERATIONS": 5,
                "MAX": "OPEN",
                "FLAGS": 1,
                "ID": "STATE",
                "TAB_ORDER": 0,
                "TYPE": "ENUM",
                "VALUE_LIST": [
                  "CLOSED",
                  "OPEN"
              "acl": {
                "object": 1636,
                "state": 1636,
            K
            K
            kilasat
            #918
            @dslraser
            "_id": "mihome.0.devices.magnet_158d000315c1a9.state",
            "common": {
            "name": "Is opened",
            "role": "state",
            "write": false,
            "read": true,
            "type": "boolean"
            "type": "state",
            "native": {},
            "from": "system.adapter.mihome.0",
            "ts": 1562618691659,
            "acl": {
            "object": 1636,
            "state": 1636,
            • K kilasat
              @dslraser
              "common": {
              "role": "state",
              "write": false,
              "read": true,
              "type": "boolean"
              "type": "state",
              "native": {},
              "acl": {
              "object": 1636,
              "state": 1636,
              dslraserD
              dslraserD
              dslraser
              #919
              @kilasat
              ich habe mal im Forum gesucht...
              geht das ?
              $('state[id=*.opened](functions="Fenster")');
              • K kilasat
                @sigi234
                Besten Dank. Was muss ich hier noch anpassen damit es läuft? Habe Xiaomi Kontakte.
                sigi234S
                sigi234S
                #920
                @kilasat sagte in [Neuer Adapter] Visualisierung iQontrol:
                @sigi234
                Habe leider keine Xiaomi..............
                  @kilasat
                  geht das ?
                  K
                  K
                  kilasat
                  #921
                  @dslraser sagte in [Neuer Adapter] Visualisierung iQontrol:
                  leider nicht - das habe ich auch schon probiert ;-((((
                  channelstate.id=*.isopen
                  • Paulchen67P Paulchen67
                    Hallo Zusammen,
                    erst mal ein Lob an den Entwickler des Adapter.
                    Finde ihn prima und bei mir läuft er auch tadellos.
                    Eine Anregung hätte ich allerdings. Es wäre schön wenn man
                    invertieren könnte, also aus Ein wird dann Aus.
                    Könnte man das umsetzen?
                    s.bormannS
                    s.bormannS
                    s.bormann
                    #922
                    @Paulchen67 sagte in [Neuer Adapter] Visualisierung iQontrol:
                    Hallo Zusammen,
                    Danke!
                    Steht auf der ToDo-Liste :)
                      @kilasat
                      ich habe mal eben was zusammengesteckt...
                      (ist für meine HMIP Fensterkontakte ohne Unterscheidung ob kipp/auf. Ich schaue hier nur nach offenen Fenstern und der Gesamtanzahl der Fenster) HMIP hat STATE (Großschreibung) und meine Aufzählung (functions) heißt Fenster.
                      Javascript Adapter ist 4.1.14
                      iQontrol ist 0.0.45
                        <variables>
                          <variable type="" id="GBP*^g/p%y(A!z9wYIAp">Anzahl_Fenster_Gesamt</variable>
                          <variable type="" id=".Yia3JB]R6UM8||#rtEy">offene_Fenster</variable>
                          <variable type="" id="k1V%Om2^GrHwhE.r-Ooe">Fenster</variable>
                        </variables>
                        <block type="procedures_defcustomnoreturn" id="EJhG@Zv:/.r@(DzIU,:6" x="-337" y="-313">
                          <mutation statements="false"></mutation>
                          <field name="NAME">Datenpunkte_erstellen</field>
                          <field name="SCRIPT">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</field>
                        </block>
                        <block type="procedures_callcustomnoreturn" id="X+4?!FV=R(MUJl~Yi2L." x="-338" y="-262">
                          <mutation name="Datenpunkte_erstellen"></mutation>
                          <next>
                            <block type="on_ext" id="V1kpsdPQC:|sufssEQ*z">
                              <mutation items="1"></mutation>
                              <value name="OID0">
                                <shadow type="field_oid" id="#4w([E@;X_!loV@[Dy]:">
                                </shadow>
                                <block type="selector" id="?)@(:rQgwvNK-P2_ANwr">
                                  <field name="TEXT">channel[state.id=STATE](functions='Fenster')</field>
                                </block>
                              </value>
                              <statement name="STATEMENT">
                                <block type="variables_set" id="qa97CpeWKQ%uN2N-R|r,">
                                  <field name="VAR" id="GBP*^g/p%y(A!z9wYIAp" variabletype="">Anzahl_Fenster_Gesamt</field>
                                  <value name="VALUE">
                                    <block type="math_number" id="6(KoRd0Q#{nzJM3dX62)">
                                      <field name="NUM">0</field>
                                    </block>
                                  </value>
                                  <next>
                                    <block type="variables_set" id="hd@3RL`}?+y^=cZX*kfB">
                                      <field name="VAR" id=".Yia3JB]R6UM8||#rtEy" variabletype="">offene_Fenster</field>
                                        <block type="math_number" id="FyhKfYo#Cn@M)jG/qfhC">
                                        </block>
                                      </value>
                                      <next>
                                        <block type="controls_forEach" id=".m+JeoExV[1]:#qZCzBq">
                                          <field name="VAR" id="k1V%Om2^GrHwhE.r-Ooe" variabletype="">Fenster</field>
                                          <value name="LIST">
                                            <block type="selector" id="]=0?,b+1!^B3f.Qx7{zl">
                                            </block>
                                          </value>
                                          <statement name="DO">
                                            <block type="math_change" id="w-AGl|nLX9gm8g(ZNQhz">
                                              <value name="DELTA">
                                                <shadow type="math_number" id="MR[}3[zrLeXB1v0X;wSm">
                                                  <field name="NUM">1</field>
                                                </shadow>
                                              </value>
                                              <next>
                                                <block type="controls_if" id="kFe#]pQ7akH6[,!wu4,8">
                                                  <value name="IF0">
                                                    <block type="logic_compare" id=".9mBUt}8pUY02GvL+1rX">
                                                      <field name="OP">GT</field>
                                                      <value name="A">
                                                        <block type="get_value_var" id="O6YMOK$=G[k/s}#h[F(y">
                                                          <value name="OID">
                                                            <shadow type="text" id="H+Si!dLFm_55HjmGoqp+">
                                                              <field name="TEXT"></field>
                                                            </shadow>
                                                            <block type="variables_get" id="*r*n~D4DFTcmV^IQ]ak~">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        <block type="math_number" id="%@9u.Wel0{9lZsIubw52">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <statement name="DO0">
                                                    <block type="math_change" id="/{nU_fYTJAjqq;iPylsx">
                                                        <shadow type="math_number" id="$5[-hLU3]|W5Iq9-k*Fx">
                                                        </shadow>
                                                      </value>
                                                    </block>
                                                  </statement>
                                                </block>
                                              </next>
                                            </block>
                                          </statement>
                                          <next>
                                            <block type="update" id="TGU9Lp,C0O-et)3!wE0T">
                                              <mutation delay_input="false"></mutation>
                                              <field name="OID">javascript.0.Eigene_Datenpunkte.14Fenster.Fenster_Anzahl_gesamt</field>
                                                <block type="variables_get" id="LDD}d$t@L!$Hl?^(._6u">
                                                </block>
                                              </value>
                                              <next>
                                                <block type="update" id="cp36p9J_H=MvrYz(K0;q">
                                                  <field name="OID">javascript.0.Eigene_Datenpunkte.14Fenster.Fenster_Anzahl_offen</field>
                                                    <block type="variables_get" id="95h*1t+vKZs6mraN20Ht">
                                                    </block>
                                                  </value>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </statement>
                            </block>
                          </next>
                        </block>
                      </xml>
                      Diese beiden Datenpunkte werden bei mir angelegt.
                      in iQontrol habe ich es dann so eingefügt
                      Sieht dann so aus
                      Ein weiterer Klick öffnet die Seite mit allen Fenstern
                      K
                      K
                      kilasat
                      #923
                      @dslraser
                      mit dieser Einstellung sehe ich zumindest etwas im Log aber die Variablen bleiben leer. Noch eine Idee?
                      K Z 2 Antworten Letzte Antwort
                      • K kilasat
                        @dslraser
                        K
                        K
                        kilasat
                        #924
                        @dslraser
                        Es funktioniert. Vielen Dank für die Unterstützung.
                        • K kilasat
                          @dslraser
                          s.bormannS
                          s.bormannS
                          s.bormann
                          #925
                          @dslraser
                          Ergänzend kann man als Einheit im Datenpunkt noch "Fenster" einstellen - dann steht da:
                          Offene Fenster
                          2 Fenster
                          Fürs Auge :)
                          K dslraserD 2 Antworten Letzte Antwort
                          • s.bormannS s.bormann
                            @dslraser
                            Offene Fenster
                            2 Fenster
                            Fürs Auge :)
                            K
                            K
                            kilasat
                            #926
                            @s-bormann vielen Dank für den Input und den genialen Adapter. Ist wirklich cool das Teil.
                            • K kilasat
                              D
                              D
                              Dominique
                              schrieb am zuletzt editiert von Dominique
                              #927
                              @kilasat kannst Du bitte mal genau beschreiben wie das nun geklappt hat mit der Aufzählung der Fenster, ich bekomm das irgend wie nicht hin und wie habt ihr die Anbindung an die eigendlichen Sensoren gemacht---mir fehlen da ein paar Schritte--- oder ich hab da total ein Brett vor Kopp.
                              Danke Dominique
                              • K kilasat
                                @dslraser
                                Z
                                Z
                                zahnheinrich
                                #928
                                @kilasat
                                Muss im blockly nicht heissen (function='Fenster'),
                                also mit Anführungszeichen?
                                MfG Ulrich
                                • D Dominique
                                  Danke Dominique
                                  K
                                  K
                                  kilasat
                                  #929
                                  @Dominique
                                  Hallo Dominique,
                                  viele viele Versuche.
                                  Hier das angepasste Blockly vom @dslraser
                                  hier die Funktion Fenster. Bei mir ist Fenster gross geschrieben.
                                  Wichtig ist noch zu den JS Adapter neu zu starten und das script auch noch. Fenster öffnen zum triggern hilft auch.
                                  • Z zahnheinrich
                                    @kilasat
                                    K
                                    K
                                    kilasat
                                    #930
                                    @zahnheinrich
                                    @zahnheinrich sagte in [Neuer Adapter] Visualisierung iQontrol:
                                    @kilasat
                                    Funktioniert beides bei mir ;-)
                                      @kilasat
                                      nein, ich meine sowas in der Art (ist etwas länger und schickt das Ergebnis an Telegram. Die Ergebnisse könnte man ja auch in eigene Datenpunkte schreiben und die dann für iQontrol benutzen.
                                      Ergebnis z.B.:
                                      Oder das bekannte Fenster zählen Script aus dem Forum. (sollte in der Suche zu finden sein)
                                      K
                                      K
                                      kilasat
                                      #931
                                      @kilasat
                                      Ergebnis z.B.:
                                      könntest Du mir das ganze Fensterblockly für Telegram zeigen? Auf dem Bild ist es leider abgeschnitten.
                                      • K kilasat
                                        @Dominique
                                        Hallo Dominique,
                                        D
                                        D
                                        Dominique
                                        #932
                                        @kilasat ok soweit so gut das Blockly hab ich nun angepasst, nur ist mir nicht klar wo jetzt die einzelnen Fensterkontakte abgefragt werden. Läuft da ein weiteres Script?---irgend wie steh ich momentan total auf dem Schlauch.
                                        • D Dominique
                                          K
                                          K
                                          kilasat
                                          schrieb am zuletzt editiert von kilasat
                                          #933
                                          @Dominique
                                          Hast du auch manuell die zwei benötigten Datenpunkte erstellt? Und diese dann im blockly jeweils zugewiesen?
                                          Wenn ja und alles funktioniert solltest du bei diesen Datenpunkt zumindest die Anzahl der gesamten Fenster sehen.
                                          Im nächsten Schritt müsstest du im iqontrol ein device hinzufügen und dort entsprechend die Variablen zuordnen.
                                          Weiter oben findest du ein Post von dslraser wo er das sehr genau beschreibt sogar mit Bildern.
                                          Ich hoffe nun etwas Licht ins Dunkle gebracht zu haben
                                          83.8k
