  4. VIS-Widget-Wunsch: Countdown
63 Beiträge 21 Kommentatoren 25.5k Aufrufe 3 Beobachtet
  • P Offline
    pix
    Hallo Bluefox,
    @Bluefox:
    Javascript:
    createState('countdown', 10);
    createState('afterCount', false);
    createState('countTrigger', false);
    function count() {
        setTimeout(function () {
            var timer = getState('countdown').val || 10;
            if (timer > 1) {
                setState('countTrigger', false);
                setState('countdown', timer - 1);
                count();
            } else {
                setState('countdown', 0);
                setState('afterCount', true);
        }, 1000);
    on('countTrigger', function (obj) {
        if (obj.newState.val === true || obj.newState.val === 'true' || obj.newState.val == 1) {
            setState('countdown', 10);
            setState('afterCount', false);
            count();
    Widgets:
    ! [ { "tpl": "tplHqButton", "data": { "visibility-cond": "==", "visibility-val": 1, "oid": "javascript.0.countTrigger", "min": "false", "max": "true", "iconName": "img/bulb_off.png", "btIconWidth": "56", "offsetAuto": "true", "leftOffset": "15", "topOffset": "55", "timeAsInterval": "true", "infoLeftFontSize": "12", "infoFontRightSize": "12" }, "style": { "left": "64px", "top": "61px" }, "widgetSet": "hqWidgets" }, { "tpl": "tplHqCircle", "data": { "visibility-cond": "==", "visibility-val": 1, "oid": "javascript.0.countdown", "min": "0", "max": "10", "step": "1", "displayPrevious": "true", "readOnly": true, "unit": "s" }, "style": { "left": "174px", "top": "58px" }, "widgetSet": "hqWidgets" }, { "tpl": "tplHqButton", "data": { "visibility-cond": "==", "visibility-val": 1, "oid": "javascript.0.afterCount", "min": "false", "max": "true", "iconName": "img/bulb_off.png", "btIconWidth": "56", "offsetAuto": "true", "leftOffset": "15", "topOffset": "55", "timeAsInterval": "true", "infoLeftFontSize": "12", "infoFontRightSize": "12" }, "style": { "left": "274px", "top": "61px" }, "widgetSet": "hqWidgets" } ] `
    vielen Dank für die Hilfe! Es funktioniert sehr zuverlässig und braucht nicht annähernd so viel Saft wie mein altes Skript.
    Unter DashUI hatte ich einen Countdown, der bei Abwesenheit nach 50s die Alarmanlage (Variable) auf scharf schaltete. Eine Besonderheit: Der Countdown musste unterbrochen werden können, falls man vor Ablauf des Countdowns doch wieder in die Wohnung geht. Das Skript verwendete die Systemzeit, damit der Countdown immer gleicht schnell ablief, auch wenn der Rechner unter hoher Last lief.
    Sah so aus:
    ! A L T E S S K R I P T - bitte nicht verwenden!
    /* Alarmanlage Scharfschaltung Countdown
    >! Erstellung der Variablen Scharfschaltung Gesamtdauer und Timer Countdown (für VIS)
    Die Variable working sorgt dafür, dass der Timer nur einmal gestartet wird
    >! createState('Alarmanlage_Timer_Gesamtdauer', 40, {forceCreation: true}, {name: 'Alarmanlage Timer Gesamtdauer', type: 'number'}); // kann vom User geändert werden
    createState('Alarmanlage_Scharfschaltung_Countdown', 0, {forceCreation: true}, {name: 'Alarmanlage Scharfschaltung Countdown', type: 'number'});  // zur Anzeige in VIS
    >! var idAlarmanlage = "javascript.0.Alarmanlage"/*Status Alarmanlage (r)*/,      // Variable Alarmanlage ValueList: 'unscharf;scharf'
        idAnwesenheit = "javascript.0.Anwesenheit"/*Status Anwesenheit*/,          // Variable Anwesenheit (abwesend; anwesend)
        idRestzeitTimer = "javascript.0.Alarmanlage_Scharfschaltung_Countdown",    // Variable mit der Restzeit des Counters in Sekunden aus JavaScript Funktion timer()
    >!     working = false, // timer läuft
        abbruch = false, // timer soll abgebrochen werden
        // Folgende Variable wird erstmal nicht verwendet, in Zeile 84 wird der wert erstmal manuell eingegeben
        idStartzeit = "javascript.0.Alarmanlage_Timer_Gesamtdauer";                // Variable legt die Countdown Dauer ins s fest
    >! // Die Gesamtzeit in Sekunden kann vom User eingetragen eingetragen. Hier erfolgt Meldung bei Änderung
    subscribe( {
        change: 'ne'
    }, function (data) { // Status ändert sich
        log('Neue Dauer für Countdown bis Alarmscharfschaltung eingestellt: ' + data.newState.val + ' Sekunden');
    >! function timer(time,update,complete) {
        var start = new Date().getTime();
        var interval = setInterval(function() {
            working = true;
            var anwesenheit = getState(idAnwesenheit),
                now = time-(new Date().getTime()-start),
                restzeit = Math.floor(now/1000);
            setState(idRestzeitTimer, restzeit);
            if (now % 1000 === 0 ) { // diese drei Zeilen können nach dem Testen gelöscht werden
                log('Countdown Rest: ' + restzeit + 's','info');
            if (now <= 0) {
                clearInterval(interval);
                complete();
                setState(idRestzeitTimer, 0);
                working = false;
            if (anwesenheit.val === 1) { // wenn während des Countdowns auf Anwesenheit geschaltet wird
                complete();
                log('Javascript-Timer zur VIS Anzeige wegen Anwesenheit abgebrochen.');
                setState(idAlarmanlage, 0);
            if (abbruch === true) {
                complete();
                working = false;
                log('Javascript-Timer zur VIS Anzeige wegen Abbruch-Code durch Anwesenheit abgebrochen.');
    >! // Abbruch des Timers bei einsetzender Anwesenheit und Start des Timers bei einsetzender Abwesenheit timer(startzeit 40s, restzeit, aktionen danach)
    subscribe( {
        change: 'ne'
        if (data.newState.val === 1 && data.oldState.val !== 1) { // Anwesenheit hergestellt
            abbruch = true;
            timer(0,0,
                function() { // what to do after
                    working = false;
                    log('Working: ' + working);
        } else if (data.newState.val === 0) { // Abwesenheit hergestellt
            if (working !== true) { // wenn Timer noch nicht läuft
                var eingabe_startzeit = 40, // vom User eingegeben - später kommt der Wert aus der Variable idStartzeit
                    startzeit = 1000 * Math.floor(eingabe_startzeit);
                    log(eingabe_startzeit);
                    log(startzeit);
                    log('TimerStart!');
                timer(
                    startzeit, // in Millisekunden (zB 40000)
                    function(timeleft) { // über den Datenpunkt idRestzeitTimer kann hier die Restzeit ausgelesen werden (Zeile 39)
                    function() { // Nach Ablauf des Timers
                        log('Javascript-Timer zur VIS Anzeige bis Alarmscharfschaltung abgelaufen', 'info');
                        working = false;
                        setState(idAlarmanlage, 1);
                        log('Alarmanlage nach Ablauf des Countdowns eingeschaltet.','info');
                ); // Ende timer()
            } // Ende Working
        } // Ende Abwesenheit
    Ich habe die Portierung zu ioBroker aber nicht hinbekommen, deshalb bin ich dir sehr dankbar für diese tolle und vielseitig nutzbare Lösung mit der Kombination Javascript Adapter und VIS-Widget.
    Ich habe im Widget einfach unter Allgemein/Wert/Max: {javascript.0.countdown} eingetragen (siehe Edit). Damit muss ich das Widget nicht mehr ändern, wenn ich mich für eine andere Zeit entscheide.
    Sichtbar ist das Widget nur, wenn javascript.0.countdown > 0.
    Zwei Fragen bleiben noch: Wo kann ich die Farbe des Widgets ändern (hellblau zu rot), und geht bei dir auch nur die maximale Kantenlänge von 200px für die Kreisrunde Darstellung?
    Gruß :D
    Pix
    Edit: Habe eine weitere Variable Countdown_Gesamtzeit erstellt (die kann ich ändern, ohne das Skript zu editieren). Und diese steht natürlich hinter max: {javascript.0.Countdown_Gesamtzeit}
    • BluefoxB Offline
      BluefoxB Offline
      @pix:
      Zwei Fragen bleiben noch: Wo kann ich die Farbe des Widgets ändern (hellblau zu rot) `
      @pix:
      und geht bei dir auch nur die maximale Kantenlänge von 200px für die Kreisrunde Darstellung? `
      Das ist ein Bug. Danke.
      Du kannst jetzt schon /opt/iobroker/node_modules/iobroker.vis/www/widgets/hqWidgets/js/hqWidgets.js Zeile 1017
      var $knobDiv = $scalaInput.knob({
                      width:   $div.width(),
                      release: function () ...
      auf
                      height:   $div.height(),
      Ändern und dann in /opt/iobroker:
      npm upload vis
      schreiben und jetzt schon damit arbeiten.
      • P Offline
        pix
        Hallo Bluefox,
        danke für die schnelle Hilfe.
        Ist der Befehl korrekt?
        @Bluefox:
        CODE: ALLES AUSWÄHLEN
        npm upload vis
        schreiben und jetzt schon damit arbeiten. `
        npm-Hilfe sagt, upload gibt es nicht.
        Usage: npm <command></command>
        where <command></command> is one of:
            add-user, adduser, apihelp, author, bin, bugs, c, cache,
            completion, config, ddp, dedupe, deprecate, docs, edit,
            explore, faq, find, find-dupes, get, help, help-search,
            home, i, info, init, install, isntall, issues, la, link,
            list, ll, ln, login, ls, outdated, owner, pack, prefix,
            prune, publish, r, rb, rebuild, remove, repo, restart, rm,
            root, run-script, s, se, search, set, show, shrinkwrap,
            star, stars, start, stop, submodule, t, tag, test, tst, un,
            uninstall, unlink, unpublish, unstar, up, update, v,
            version, view, whoami
        Pix
        • BluefoxB Offline
          BluefoxB Offline
          @pix:
          Hallo Bluefox,
          @Bluefox:
          npm upload vis
          Pix `
          Nicht korrekt.
          es muss````
          iobroker upload vis
          sein. (in /opt/iobroker)
          • P Offline
            pix
            @Bluefox:
            Widgets:
            leider sind die schönen Countdown Widgets aus VIS verschwunden. Ich vermute, das liegt an den fehlenden hqWidgets, korrekt?
            Pix
            • htreckslerH Offline
              htreckslerH Offline
              htrecksler
              Forum Testing
              ja, ich denke schon, meine (wenigen) hqWidgets sind auch seit dem letzten Update verschwunden.
              Aber lange kann es nicht mehr dauern. Es gibt immerhin schon den neuen hqWidget-Adapter.
              Allerdings noch ohne Widgets. Auch wenn man diesen als Instanz hinzufügt hat man in vis noch keine Widgets.
              Es sei denn ich mach irgendwas falsch.
              Aber so ist die Vorfreude auf die hqWidgets größer :D :D :D
              Gruss Hermann
                bei mir waren in dem Paket einzelne widgets enthalten.
                muss msl zu hause nachsehen, ob die nach dem update noch drin sind.
                Gesendet von meinem Cynus T7 mit Tapatalk
                  htreckslerH Offline
                  htrecksler
                  Forum Testing
                  Ja, zwischendurch waren mal ein paar Widgets mit dem Hinweis "Beta" da.
                  Aber seit gestern (js-controller 0.7.5 und vis 0.6.5) sind die weg.
                  Wie gesagt, den Adapter habe ich als Instanz hinzugefügt und dann sowohl den vis-Adapter als auch den web-Adapter neu geladen.
                  Anschließend sogar (musste eh mal wieder sein) das ganze System rebootet.
                  Aber ich habe in vis auf der linken Seite keine hqwidgets mehr
                  Gruss Hermann
                    @htrecksler:
                    Aber ich habe in vis auf der linken Seite keine hqwidgets mehr `
                    filename="HQ-widgets.jpg" index="0">~~
                    Bei mir sind sie da.
                    Ich weiss nicht mehr, da war aber viel über einander zu installieren und reboot und…
                    So richtig auf Anhieb lief das auch nicht
                    Gesendet von meinem LIFETAB_S785X mit Tapatalk
                      htreckslerH Offline
                      htrecksler
                      Forum Testing
                      na toll… ich will auch :? :o
                      Gruss Hermann
                      • P Offline
                        pix
                        Hab im laufenden System
                        ./iobroker upgrade iobroker.vis
                        ausgeführt. Danach waren die hqwidgets und damit die Countdowns wieder da.
                        Pix
                          htreckslerH Offline
                          htrecksler
                          Forum Testing
                          Der Befehl für Windows war irgendwie anders, aber ich finde den Post nicht mehr.
                          Ich glaube ich werde morgen mal den Visa-Adapter löschen nachdem ich eine komplettsicherung gemacht habe.
                          EDIT:
                          Geschafft. Unter Windows ist das in einer Admin Dos Box im ioBroker Verzeichnis der Befehl:
                          Dann dauerts einen Moment und dann kommt ganz viel Data…
                          Und jetzt hab ich 5 hqWidgets ... Yes, ich liebe es wenn etwas funktioniert...
                          378_thermostatsteuerung.js
                          Gruss Hermann
                          • BluefoxB Offline
                            BluefoxB Offline
                            @htrecksler:
                            Ich glaube ich werde morgen mal den Visa-Adapter löschen nachdem ich eine komplettsicherung gemacht habe. `
                            Du gehst mit der Konsole, da wo iobroker liegt. (Ich denke, die Konsole muss admin-Rechte haben)
                            cd C:\Program Files\ioBroker
                              htreckslerH Offline
                              htrecksler
                              Forum Testing
                              Danke Bluefox.
                              Siehe mein Edit im letzten Post.
                              Ich hab einfach probiert und irgendwann hatte ich es dann.
                              Trotzdem Danke.
                              Hast Du schon eine "Roadmap" für weitere hqWidgets?
                              Aber nicht falsch verstehen… ich bin sehr geduldig.
                              Gruss Hermann
                              • BluefoxB Offline
                                BluefoxB Offline
                                Momentan bin ich an Rolladen: 48_shutter.gif
                                Danach will ich Tür und Schloss machen. Dann weiß ich nicht.
                                • P Offline
                                  pix
                                  Hall Bluefox,
                                  @Bluefox:
                                  Momentan bin ich an Rolladen: `
                                  hui, das freut mich. Zwar offtopic: Wie schon mal beschrieben, wünsche ich mir, das Level auch umkehren zu können (Level 100% bedeutet Rollladen zu [bei Homepilot], statt auf [bei Homematic)].
                                  Gruß,
                                  Pix
                                    thomassch
                                    was macht die Zeile
                                    bei mir zählt leider der Countdown fast doppelt zu schnell ??
                                    Ich habe den Countdown über eine Variabel im trigger ON drin.
                                    Funktioniert soweit auch alles, aber eben nur fast doppelt so schnell ?
                                    // Idee von: http://forum.iobroker.net/viewtopic.php?t=737
                                    // 05.05.2016
                                    var logging = true;
                                    var szpfad = 'javascript.0.CountDown.';
                                    // Variablen erstellen (Javascript Instanz nach dem ersten Speichern des Skriptes einmal neustarten)
                                    function create(szZaehler) {
                                        if (logging) log('Countdown-> function create Name: '+szZaehler,'info');
                                        createState(szpfad+szZaehler              , 300,   {name: szZaehler              ,desc: 'Countdownzähler',unit: 's'});
                                        createState(szpfad+szZaehler+'_abgelaufen', false, {name: szZaehler+'_abgelaufen',desc: 'Countdown abgelaufen'});
                                        createState(szpfad+szZaehler+'_trigger'   , false, {name: szZaehler+'_trigger'   ,desc: 'Trigger'});
                                        createState(szpfad+szZaehler+'_max'       , 300,   {name: szZaehler+'_max'       ,desc: 'Startwert'});
                                    // Zählen
                                    function count(szZaehler) {
                                            //if (logging) log('CountDown-> function count: '+szZaehler,'info');
                                            var timer = getState(szZaehler).val ;//|| 300;
                                            //if (logging) log('CountDown->count()->var timer: '+timer,'info');
                                            if (timer > 1) {
                                                setState(szZaehler+'_trigger', false);
                                                setState(szZaehler, timer - 1);
                                                count(szZaehler);
                                            } else {
                                                setState(szZaehler, 0);
                                                setState(szZaehler+'_abgelaufen', true);
                                        }, 1000);
                                    // Countown ausführen
                                    function start(myobj,szCountDownObjekt){
                                        // den Namen des Hauptobjektes bilden
                                        var szName = szpfad+szCountDownObjekt;
                                        // nun den Max wert laden
                                        if (logging) log('Countdown->function start->szName: '+szName,'info');
                                        var iMax = getState(szName+'_max').val;
                                        if (logging) log('CountDown: iMax: '+iMax, 'info');
                                        if (myobj.newState.val === true || myobj.newState.val === 'true' || myobj.newState.val == 1) {
                                            if (logging) log('Countdown->function start->Countdown start: '+myobj.name + "->" + szCountDownObjekt,'info');
                                            setState(szName, iMax);
                                            setState(szName+'_abgelaufen', false);
                                            setState(szName+'_trigger', true);
                                            count(szName);
                                        } else{
                                            if (logging) log('Countdown->function start->Countdown abgelaufen: '+myobj.name + "->" + szCountDownObjekt,'info');
                                            setState(szName+'_trigger', false);
                                            setState(szName, 0);
                                            setState(szName+'_abgelaufen', true);
                                    // ON Trigger
                                    //on({id:"hm-rega.0.16281", change:"ne"},  function(obj) { xaktion(obj, "(i) Alarmüberwachung Zone 1","-> einschalten","-> ausschalten"); }); // varAlarm1CmdEin
                                    on({id:"hm-rega.0.16282", change:"ne"}, function(obj) {
                                        if (logging) log('Countdown->ON erkannt: '+'hm-rega.0.16281','info');
                                        start(obj,'Z01_Alarm_Zone1');
                                    // beim Start die Zähler anlegen
                                    if (logging) log('Countdown->Variablen anlegen','info');
                                    create('Z01_Alarm_Zone1');
                                    ******* iobroker auf Intel PC, Raspberry PI4 + Homematic CCU *******
                                    • BluefoxB Offline
                                      BluefoxB Offline
                                      @pix:
                                      Hall Bluefox,
                                      @Bluefox:
                                      Gruß,
                                      Pix `
                                      Ist schon ewig da.
                                      • P Offline
                                        pix
                                        @Bluefox:
                                        Ist schon ewig da. `
                                        Oh, das hab ich übersehen. Vielen Dank. Beim Metro Widget für Jalousien gibt es den "invertieren"-Knopf aber nicht, oder?
                                        Pix
                                          dtp
                                          Hätte hierzu mal eine ergänzende Frage.
                                          Kann ich einen CUxD-Timer in ein Widget einbinden, um dessen Countdown anzuzeigen?
                                          Der CUxD-Timer kennt ja nur die folgenden Parameter:
                                          CMD_RET
                                          INHIBIT
                                          STATE
                                          TIMER_EVENT
                                          TIMER_GET
                                          TIMER_SET
                                          TIMER_STOP
                                          WORKING
                                          Sobald WORKING den Wert true hat, wird ausgehend vom Wert TIMER_SET heruntergezählt. Wenn 0s erreicht sind, geht WORKING auf false.
                                          Ich suche jetzt nach einer Möglichkeit zur Anzeige des Countdowns als simplen Zahlenwert in einem Widget.
                                          Gruß,
                                          Thorsten
