  4. [Aufruf] Adapter: Snips - Offline Speak2Text
    1.0k
snips
635 Beiträge 43 Kommentatoren 209.0k Aufrufe 22 Beobachtet
  • Daniel BeiderwiedenD Daniel Beiderwieden
    Moin,
    ich bin jetzt schon 2 Tage dran Snips zu installieren bzw. zum laufen zu bringen.
    IoBroker hat den Snips und den Command Adapter wie beschrieben installiert. Er wurde auch entsprechend in der Sinps Console hinzugefügt.
    Der Snips Server läuft in Proxmox in einer Debian VM.
    Das Hotword wird erkannt und per sam watch bekomme ich folgende Informationen:
    sam watch
    [17:31:25] Watching on localhost:1883 (MQTT)
    [17:31:27] [Hotword] detected on site room1, for model hey_snips
    [17:31:27] [Asr] was asked to stop listening on site room1
    [17:31:27] [Hotword] was asked to toggle itself 'off' on site room1
    [17:31:27] [Dialogue] session with id '19c5c8b4-b002-49d7-9c2e-0e6bb5453ed0' was started on site room1
    [17:31:27] [AudioServer] was asked to play a wav of 41.1 kB with id '61c42146-84bc-4820-a907-0a59dc623e5d' on site room1
    [17:31:42] [Dialogue] session with id '19c5c8b4-b002-49d7-9c2e-0e6bb5453ed0' was ended on site room1. The session was ended because one of the component didn't respond in a timely manner
    [17:31:42] [Asr] was asked to stop listening on site room1
    [17:31:42] [Hotword] was asked to toggle itself 'on' on site room1
    der Satellite wurde mit dem git Script hinzugefügt von Psychokiller..
    Sam Status gibt mir folgendes aus:
    sam status
    Connected to device localhost
    OS version ................... Debian GNU/Linux 9 (stretch)
    Installed assistant .......... MainSnips
    Language ..................... de
    Hotword ...................... hey_snips
    ASR engine ................... snips
    Status ....................... Live
    Service status:
    snips-analytics .............. (not running)
    snips-asr .................... 0.63.2 (running)
    snips-audio-server ........... 0.63.2 (running)
    snips-dialogue ............... 0.63.2 (running)
    snips-hotword ................ 0.63.2 (running)
    snips-nlu .................... 0.63.2 (running)
    snips-skill-server ........... 0.63.2 (running)
    snips-tts .................... 0.63.2 (running)
    Den Audio Server habe ich zum laufen gebracht indem ich die Soundkarte durchgeschliffen habe.
    Auf dem Satellite habe ich wie in auf dem git reposetory die entsprechen packte installiert.
    Ich verwende ein Rasb. mit ReSpeaker ohne lautsprecher derzeit.
    Daher die Frage, was läuft hier falsch? was muss ich tun, ich finde einfach keine Lösung.
    Und muss auf der VM der Skill-server laufen?
    unltdnetworxU Offline
    unltdnetworx
    #578
    @Daniel-Beiderwieden
    Hi, also zum Skill-Server: Nein, der muss nicht laufen.
    Es sieht so aus, als würde er zumindest das Hotword erkennen, soweit so gut. Hast du evtl. zu früh begonnen zu sprechen? Du bekommst ja keine Feedback ohne Lautsprecher.
    Gruß, Michael
    Weitere Infos im Profil.
    Wenn euch der Beitrag weitergeholfen hat, könnt ihr die Bewertung rechts unten im Beitrag nutzen.
    Daniel BeiderwiedenD 1 Antwort Letzte Antwort
    • unltdnetworxU unltdnetworx
      Daniel BeiderwiedenD Offline
      Daniel Beiderwieden
      #579
      @unltdnetworx habe das ganze jetzt erneut gestest und in verschiedenen Abständen gesprochen. Es kommt leider immer die selbe meldung.
      • unltdnetworxU Offline
        unltdnetworx
        #580
        Ich habe das Tool noch nie verwendet, aber ich denke, dass zu viele Server auf dem Satelliten laufen. Weiter oben war schon mal das Thema. Ich glaube es müssen nur 2 auf dem Satelliten aktiv sein, auf dem Server natürlich mehr. (Skill kannst du ausmachen.)
        Gruß, Michael
        • Daniel BeiderwiedenD Offline
          Daniel Beiderwieden
          #581
          Bin nun noch mal die Server durch gegangen. diese wurden wohl doch mit installiert.
          Nach dem Ausschalten kommt immer noch der selbe Fehler.
          allerdings konnte ich mit dem Befehlt: sudo tail -f /var/log/syslog folgendes raus bekommen.
          May 23 17:45:14 raspberrypi snips-hotword[548]: INFO:snips_hotword_lib::audio: Audio thread for site room1 stopped.
          May 23 17:45:14 raspberrypi snips-audio-server[547]: INFO:snips_audio_portaudio      : Playing "3df58b5b-396b-4403-957b-67dd680d6818" using output "bcm2835 ALSA: IEC958/HDMI (hw:0,1)", wav spec: WavSpec { channels: 2, sample_rate: 22050, bits_per_sample: 16, sample_format: Int }
          May 23 17:45:14 raspberrypi snips-audio-server[547]: Expression 'paInvalidSampleRate' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2043
          May 23 17:45:14 raspberrypi snips-audio-server[547]: Expression 'PaAlsaStreamComponent_InitialConfigure( &self->playback, outParams, self->primeBuffers, hwParamsPlayback, &realSr )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2717
          May 23 17:45:14 raspberrypi snips-audio-server[547]: Expression 'PaAlsaStream_Configure( stream, inputParameters, outputParameters, sampleRate, framesPerBuffer, &inputLatency, &outputLatency, &hostBufferSizeMode )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2838
          May 23 17:45:14 raspberrypi snips-audio-server[547]: thread 'portaudio.player' panicked at 'ERROR:snips_audio_server_hermes  : could not play "3df58b5b-396b-4403-957b-67dd680d6818"
          May 23 17:45:14 raspberrypi snips-audio-server[547]:  -> caused by: InvalidSampleRate
          May 23 17:45:14 raspberrypi snips-audio-server[547]: called `Result::unwrap()` on an `Err` value: "SendError(..)"', src/libcore/result.rs:997:5
          werde also wohl irgendwas vergessen haben zu installieren oder so. Ich werde dann mal googlen was ich vergessen habe oder hast du noch eine Idee`?
          unltdnetworxU 1 Antwort Letzte Antwort
            unltdnetworx
            schrieb am zuletzt editiert von unltdnetworx
            #582
            @Daniel-Beiderwieden sagte in [Aufruf] Adapter: Snips - Offline Speak2Text:
            22050
            Sind da USB-Lautsprecher bzw. irgendwie HDMI dran? Vllt. unterstützen diese die Rate von 22050 nicht? Scheint ein Konfigurationsfehler zu sein?!
            Gruß, Michael
            • WalW Offline
              WalW Offline
              Wal
              #583
              Auf dieser Seite steht was auf dem Server bzw. Client laufen muß. Link Text
              Walter
              DoorIO-Adapter
                Daniel Beiderwieden
                #584
                Vielen Dank für die Hilfe.
                Satellite und VM laufen nun und in IoBroker kommt auch etwas an.
                Irgendwie scheine ich wohl undeutlich zu sprechen und bisher führt er noch keine Commands aus aber das wird noch.
                • O Offline
                  O Offline
                  onlinepilot
                  schrieb am zuletzt editiert von onlinepilot
                  #585
                  Hallo Zusammen,
                  Auch ich hatte anfangs Schwierigkeiten mit dem Hey Snips, aber seit ich "Snips" dann mal als deutsches Wort (also nicht englisch) ausspreche, läuft die Erkennung ca. bei 80%. Ich habe eine ähnliche Konfiguration, bloß dass ich kein Proxmox, sondern vSphere verwende. Bei mir laufen die Audio-Server auf den Satelliten (RPi Zero W). Über: sudo apt install snips-hotword-model-heysnipsv4 sudo apt install snips-satellite werden sie mitinstalliert. Mit snips-watch -vvv kann man die Hotworderkennung gut nachvollziehen. Nun muss ich nur noch das mit den Befehlen über iobroker hinbekommen - ich verzweifle. Vielleicht kann mir jemand dabei einen Tipp geben, wie ich das brauchbar konfigurieren und gestalten kann. Mit dem text2command-Adapter komme ich irgendwie nicht klar.
                  Danke im Voraus
                  onlinepilot
                  Debian 9 VM
                  ioBroker 1.5.11
                  vis 1.2.0
                  unltdnetworxU 2 Antworten Letzte Antwort
                  • O onlinepilot
                    Hallo Zusammen,
                    Danke im Voraus
                    onlinepilot
                    unltdnetworx
                    #586
                    @onlinepilot sagte in [Aufruf] Adapter: Snips - Offline Speak2Text:
                    also nicht englisch
                    Was meinst du mit englisch? Wäre m.M.n. ja in englisch und deutsch gleich auszusprechen. Siehe auch Windows Snipping-Tool.
                    Meinst du vllt. Snipes, so wie Wesley Snipes?
                    Gruß, Michael
                    O 1 Antwort Letzte Antwort
                    • O onlinepilot
                      Hallo Zusammen,
                      Danke im Voraus
                      onlinepilot
                      unltdnetworx
                      #587
                      Was willst denn erreichen?
                      Gruß, Michael
                        Hi @xulkar,
                        ich versuche mal etwas Licht ins Dunkel zu bringen. Soweit das bei individuellen Installationen geht. Alle Einstellungen in den Screenshots unten sind aus der Version 1.1.1 und sollten ab Version 1.1.0 funktionieren.
                        @xulkar sagte in [Aufruf] Adapter: Snips - Offline Speak2Text:
                        Nun komme ich nicht weiter, bzw verstehe das weitere vorgehen nicht.
                        • Im Grunde musst man zuerst das Snips-Geräte installieren und ausschließlich die unltdnetworx Snips-App installieren. Keinen eigenen Fork oder andere Apps.
                          • Eigene Forks werden nicht erkannt (bei Wünschen nicht enthaltener Wörter, nicht erkannter Sätze, etc. einfach Meldung hier im Thread, dann kann ich das noch einspielen, alternativ können auch eigene Injections gemacht werden, also eigene Worte angelernt)
                          • zusätzlich installierte Apps können dazu führen, dass der gewünschte Satz mit der falschen App erkannt wird und ioBroker nichts davon mitbekommt.
                        • Als nächsten Schritt muss man den text2command-Adapter installieren, falls noch nicht geschehen, Einstellungen dazu folgen im übernächsten Schritt
                        • Als dritten Schritt den Adapter Snips installieren und wie folgt konfigurieren
                          • Die URL ist die IP-Adresse des Snips-Gerätes
                          • Port falls weitere MQTT-Adapter bereits 1883 blockieren entsprechend anpassen
                          • Text2command-Instanz entsprechend anpassen, falls mehrere Instanzen laufen, Standard ist 0
                          • Filter mit "verstehe" befüllen, da sonst alle nicht erkannten Sätze mit "Ich verstehe blablabla nicht." quittiert werden
                          • Client-ID kann auch erhöht werden, falls man Satelliten im Einsatz hat. Die laufende Nummer beginnt bei 0 und erhöht sich pro Satellit um 1
                        • Nach dem Speichern nun den text2command Adapter konfigurieren
                          • text2command Oberfläche aufrufen und das Zahnrad rechts oben klicken (Erweiterte Einstellungen)
                        • Nun noch die Regeln in text2command konfigurieren, etwa so
                          Damit ist das Schalten von Licht und Rollos möglich, sofern diese mit Raum und Funktion bezeichnet wurden.
                        • weitere Regeln könnten etwa so aussehen
                          Wichtig dabei ist, dass an/aus als true/false rückgemeldet wird.
                        unltdnetworx
                        #588
                        @onlinepilot
                        Schau dir mal diesen Post an. Vllt. bringt er dich schon mal weiter.
                        Gruß, Michael
                          also nicht englisch
                          O Offline
                          O Offline
                          onlinepilot
                          #589
                          @unltdnetworx said in [Aufruf] Adapter: Snips - Offline Speak2Text:
                          also nicht englisch
                          Wie man eben der englischen Aussprache mächtig ist, vielleicht ist es auch texanisches Kauderwelsch gewesen ;).
                          Das Ziel ist natürlich ein für den Alltag benutzbares System zu erhalten, vorrangig als parallele Integration zum VIS. Das bedeutet in meiner Wahrnehmung, dass ich bestehende Strukturen gern weiter nutzen würde und nicht unbedingt eine zweite, völlig anders aufzubauende Logik erarbeiten muss.
                          @onlinepilot
                          Ja, das nehme ich gern mal an. Ich schau mal, wie weit ich damit komme.
                          Danke Dir erstmal!
                          onlinepilot
                          Debian 9 VM
                          ioBroker 1.5.11
                          vis 1.2.0
                          • BluePixelHDB Offline
                            BluePixelHD
                            schrieb am zuletzt editiert von BluePixelHD
                            #590
                            Hallo Leute,
                            ich versuch seit ein paar Wochen Snips problemlos mit dem ioBroker zum laufen zu bekommen (möchte von Googles Cloud wegkommen 😌 ), aber irgendwie klappt das nicht so gut 😕
                            Zur Hardware:
                            Aktuelle benutze ich für Snips einen Pi3 mit der Playstation Eye und einen zweiten Pi3 für ioBroker und etc.
                            Jetzt zu meinen Problemen:
                            1. Snips erkennt die gesprochenen Wörter häufig falsch (leider deutlich schlechter als Google Home und Alexa), obwohl ich viele "Geräte" über snips.0.send.inject.device hinzugefügt habe.
                            2. Die Geräte Namen habe ich hinzugefügt: Tischlampe, Lampe eins, Lampe zwei, Lampe drei, PlayStation, Netflix, Prime Video, Spotify und YouTube.
                              Trotzdem erkennt er alle Wörter, bis auf die Tischlampe, nicht richtig.
                            3. Text2Command schaltet manche Geräte nicht immer in den gewünschten Zustand, obwohl es richtig eingetragen ist.
                            4. Snips ignoriert, trotz kurzer Pause am Anfang, das erste Wort häufig und er hört oft nicht lange genug zu und weiß dann nicht, ob das Gerät ein/aus geschaltet werden soll.
                            5. Eine Funktion, um die Mikrofone von der PS Eye lauter zu machen, gibt es glaube ich nicht, oder?
                            Ich hoffe ihr könnt mir weiterhelfen und könnt meine Probleme nachvollziehen 😌
                            Anbei noch ein paar Bilder, die ich gemacht habe 🤓
                            • O Offline
                              O Offline
                              Oak
                              #591
                              Moin,
                              Ich habe zurzeit auch das Problem das Snips und Texttocommand zwar richtig erkennt, jedoch genau wie im letzten Bild trotz erkannten "false" einfach true weitergibt. Wenn Ich den Adapter neu starte tuts das das ein paar mal bis der Fehler wieder auftaucht! Gibt's dazu schon eine Lösung?
                              • BluePixelHDB BluePixelHD
                                Hallo Leute,
                                Zur Hardware:
                                unltdnetworx
                                #592
                                @BluePixelHD
                                Hi. Es gibt meines Erachtens nach momentan zwei große Probleme. Das eine sind geeignete Mikros. Ich hab das 4-Mic-Hat und bin je nach Entfernung zum Snips-Endgerät unterschiedlich zufrieden damit. Das schwankt von Top zufrieden bis geht gar nicht.
                                Das andere sind englische Worte. Ich habe den Eindruck, dass Snips bei eingestellter deutscher Sprache Probleme mit dem Erkennen von englischen Worten hat. Siehe z.B. bei dir YouTube, etc.
                                Du kannst ja mal mit Sam deine Spracheingabe überwachen und sehen, was jeweils erkannt wird.
                                Sam watch
                                wäre der Befehl. Außerdem würde ich dir in text2command die Funktion "Steuere mit Funktion" ans Herz legen. Du musst dazu lediglich die Funktion "light" und einen Raum aus den Enums in den Objekten zuweisen.
                                Ich werde mal versuchen eine grobe Anleitung zu schreiben, sobald ich Zeit dafür finde.
                                Gruß, Michael
                                  unltdnetworx
                                  #593
                                  da ich gebeten wurde, die Spracheingabe bei Bedarf auf die Räume zu beschränken, in denen der jeweilige Satellit steht, habe ich eine Testversion auf Github hochgeladen. Der Sinn einer solchen Funktion ist, dass z.B. bei Häusern mit vielen Zimmern die Bewohner keine fremden Räume schalten können, etwa in Hotels.
                                  Ich hatte mir das so gedacht, dass man dem Gerät über die Enumerationen (Aufzählungen) einen Raum zuweist und dann den Punkt "enforceSameRoom" auf wahr setzt.
                                  Jetzt tritt bei mir ein kurioses Phänomen auf und ich komme auf keine Lösung. Ich habe ein Testsystem, auf dem klappt das Ganze einwandfrei. Raum auf "Wohnzimmer", "enforceSameRoom" auf "true" und der Befehl "Schalte das Licht in der Küche aus" bewirkt ein "Schalte das Licht im Wohnzimmer aus".
                                  In meinem Echtsystem hingegen wird mit dem selben Satelliten der Raum auf "undefined" gesetzt und text2command meldet, dass es diesen Raum nicht gibt.
                                  Evlt. kann das mal jemand testen. Wenn das "enforceSameRoom" auf false steht, läuft der Adapter und die Befehle wieder wie gewohnt, es sollte also keine Gefahr drohen, etwas zu zerstören.
                                  Danke schon mal für eure Hilfe.
                                  Gruß, Michael
                                  • O Oak
                                    Moin,
                                    unltdnetworx
                                    #594
                                    @Oak
                                    Das Problem hatte ich bisher nicht. Außer ich war zu weit weg und wurde nicht einwandfrei verstanden. Aber dann wurde der Text auch auf true statt false gesetzt. Gab es denn ein Update von text2command?
                                    Welchen Adapter startest du neu? Liefert Snips den richtigen Wert an text2command?
                                    Gruß, Michael
                                    • O Offline
                                      O Offline
                                      Oak
                                      #595
                                      Guten Abend,
                                      kann mir bitte vielleicht kurz jemand erläutern wie ich Snips neue Räume beibringen kann.
                                      Die Vordefinierten Räume erkennt er ohne Problemem, wenn Ich jedoch Haustüre als Raum eingebe wird dieser nicht mehr gefunden!
                                      Vielen Dank
                                        @Oak
                                        O Offline
                                        O Offline
                                        Oak
                                        #596
                                        @unltdnetworx
                                        dadurch das Ich nun Schalte mit Funktion eingestellt habe, schaltet er immer richtig. Vielen Dank
                                        • O Oak
                                          Guten Abend,
                                          Vielen Dank
                                          unltdnetworx
                                          #597
                                          @Oak
                                          Das liegt an text2command. Dort gibt es nur eine begrenzte Anzahl an Räumen, weil dafür Genitiv und Dativ in mehreren Sprachen fest codiert ist.
                                          Es fehlt eine Funktion, die alle anderen Räume abfängt und z.B. sagt "schalte das Licht im Raum Haustür ein" anstatt "schalte das Licht in der Haustüre ein".
                                          Du könntest das mit einer eigenen Regel in text2command abfangen oder einen Issue im Repository von text2command bei Github einreichen.
                                          Gruß, Michael
